Change-Id: I318afbe66efa346b71e82413ac6442672cef4d36
Reviewed-on: http://git-master/r/21196
Reviewed-by: Jonathan B White (Engrg-Mobile) <jwhite@nvidia.com>
Tested-by: Jonathan B White (Engrg-Mobile) <jwhite@nvidia.com>
Reviewed-by: Maria Gutowski <mgutowski@nvidia.com>
Kconfig and Makefiles to enable configuration and building of AppArmor.
Signed-off-by: John Johansen <john.johansen@canonical.com>
Signed-off-by: James Morris <jmorris@namei.org>
In NOMMU mode clamp dac_mmap_min_addr to zero to cause the tests on it to be
skipped by the compiler. We do this as the minimum mmap address doesn't make
any sense in NOMMU mode.
mmap_min_addr and round_hint_to_min() can be discarded entirely in NOMMU mode.
Acked-by: Eric Paris <eparis@redhat.com>
Remove the root_plug example LSM code. It's unmaintained and
increasingly broken in various ways.
Made at the 2009 Kernel Summit in Tokyo!
Convert avc_audit in security/selinux/avc.c to use lsm_audit.h,
for better maintainability.
- changed selinux to use common_audit_data instead of
avc_audit_data
- eliminated code in avc.c and used code from lsm_audit.h instead.
Had to add a LSM_AUDIT_NO_AUDIT to lsm_audit.h so that avc_audit
can call common_lsm_audit and do the pre and post callbacks without
doing the actual dump. This makes it so that the patched version
behaves the same way as the unpatched version.
Also added a denied field to the selinux_audit_data private space,
once again to make it so that the patched version behaves like the
unpatched.
I've tested and confirmed that AVCs look the same before and after
this patch.
Signed-off-by: Thomas Liu <tliu@redhat.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Currently SELinux enforcement of controls on the ability to map low memory
is determined by the mmap_min_addr tunable. This patch causes SELinux to
ignore the tunable and instead use a seperate Kconfig option specific to how
much space the LSM should protect.
The tunable will now only control the need for CAP_SYS_RAWIO and SELinux
permissions will always protect the amount of low memory designated by
CONFIG_LSM_MMAP_MIN_ADDR.
This allows users who need to disable the mmap_min_addr controls (usual reason
being they run WINE as a non-root user) to do so and still have SELinux
controls preventing confined domains (like a web server) from being able to
map some area of low memory.
Signed-off-by: Eric Paris <eparis@redhat.com>
This reverts commit 8113a8d80f4c6a3dc3724b39b470f3fee9c426b6.
The patch causes a stack overflow on my system during boot.
for better maintainability and for less code duplication.
avc_audit_data
I have tested to make sure that the avcs look the same before and
after this patch.
the following patch, add logging of Smack security decisions.
This is of course very useful to understand what your current smack policy does.
As suggested by Casey, it also now forbids labels with ', " or \
It introduces a '/smack/logging' switch :
0: no logging
1: log denied (default)
2: log accepted
3: log denied&accepted
Signed-off-by: Etienne Basset <etienne.basset@numericable.fr>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
LSMs need to be linked before root_plug to ensure the security=
boot parameter works with them. Do this for Tomoyo.
(root_plug probably needs to be taken out and shot at some point,
too).
TOMOYO uses LSM hooks for pathname based access control and securityfs support.
Signed-off-by: Kentaro Takeda <takedakn@nttdata.co.jp>
IMA provides hardware (TPM) based measurement and attestation for
file measurements. As the Trusted Computing (TPM) model requires,
IMA measures all files before they are accessed in any way (on the
integrity_bprm_check, integrity_path_check and integrity_file_mmap
hooks), and commits the measurements to the TPM. Once added to the
TPM, measurements can not be removed.
In addition, IMA maintains a list of these file measurements, which
can be used to validate the aggregate value stored in the TPM. The
TPM can sign these measurements, and thus the system can prove, to
itself and to a third party, the system's integrity in a way that
cannot be circumvented by malicious or compromised software.
- alloc ima_template_entry before calling ima_store_template()
- log ima_add_boot_aggregate() failure
- removed unused IMA_TEMPLATE_NAME_LEN
- replaced hard coded string length with #define name
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Add a new Kconfig option SECURITYFS which will build securityfs support
but does not require CONFIG_SECURITY. The only current user of
securityfs does not depend on CONFIG_SECURITY and there is no reason the
full LSM needs to be built to build this fs.
Remove the dummy module and make the "capability" module the default.
Compile and boot tested.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Implement a cgroup to track and enforce open and mknod restrictions on device
files. A device cgroup associates a device access whitelist with each cgroup.
A whitelist entry has 4 fields. 'type' is a (all), c (char), or b (block).
'all' means it applies to all types and all major and minor numbers. Major
and minor are either an integer or * for all. Access is a composition of r
(read), w (write), and m (mknod).
The root device cgroup starts with rwm to 'all'. A child devcg gets a copy of
the parent. Admins can then remove devices from the whitelist or add new
entries. A child cgroup can never receive a device access which is denied its
parent. However when a device access is removed from a parent it will not
also be removed from the child(ren).
An entry is added using devices.allow, and removed using
devices.deny. For instance
echo 'c 1:3 mr' > /cgroups/1/devices.allow
allows cgroup 1 to read and mknod the device usually known as
/dev/null. Doing
echo a > /cgroups/1/devices.deny
will remove the default 'a *:* mrw' entry.
CAP_SYS_ADMIN is needed to change permissions or move another task to a new
cgroup. A cgroup may not be granted more permissions than the cgroup's parent
has. Any task can move itself between cgroups. This won't be sufficient, but
we can decide the best way to adequately restrict movement later.
[akpm@linux-foundation.org: fix may-be-used-uninitialized warning]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Acked-by: James Morris <jmorris@namei.org>
Looks-good-to: Pavel Emelyanov <xemul@openvz.org>
Cc: Daniel Hokka Zakrisson <daniel@hozac.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Smack is the Simplified Mandatory Access Control Kernel.
Smack implements mandatory access control (MAC) using labels
attached to tasks and data containers, including files, SVIPC,
and other tasks. Smack is a kernel based scheme that requires
an absolute minimum of application support and a very small
amount of configuration data.
Smack uses extended attributes and
provides a set of general mount options, borrowing technics used
elsewhere. Smack uses netlabel for CIPSO labeling. Smack provides
a pseudo-filesystem smackfs that is used for manipulation of
system Smack attributes.
The patch, patches for ls and sshd, a README, a startup script,
and x86 binaries for ls and sshd are also available on
http://www.schaufler-ca.com
Development has been done using Fedora Core 7 in a virtual machine
environment and on an old Sony laptop.
Smack provides mandatory access controls based on the label attached
to a task and the label attached to the object it is attempting to
access. Smack labels are deliberately short (1-23 characters) text
strings. Single character labels using special characters are reserved
for system use. The only operation applied to Smack labels is equality
comparison. No wildcards or expressions, regular or otherwise, are
used. Smack labels are composed of printable characters and may not
include "/".
A file always gets the Smack label of the task that created it.
Smack defines and uses these labels:
"*" - pronounced "star"
"_" - pronounced "floor"
"^" - pronounced "hat"
"?" - pronounced "huh"
The access rules enforced by Smack are, in order:
1. Any access requested by a task labeled "*" is denied.
2. A read or execute access requested by a task labeled "^"
is permitted.
3. A read or execute access requested on an object labeled "_"
is permitted.
4. Any access requested on an object labeled "*" is permitted.
5. Any access requested by a task on an object with the same
label is permitted.
6. Any access requested that is explicitly defined in the loaded
rule set is permitted.
7. Any other access is denied.
Rules may be explicitly defined by writing subject,object,access
triples to /smack/load.
Smack rule sets can be easily defined that describe Bell&LaPadula
sensitivity, Biba integrity, and a variety of interesting
configurations. Smack rule sets can be modified on the fly to
accommodate changes in the operating environment or even the time
of day.
Some practical use cases:
Hierarchical levels. The less common of the two usual uses
for MLS systems is to define hierarchical levels, often
unclassified, confidential, secret, and so on. To set up smack
to support this, these rules could be defined:
C Unclass rx
S C rx
S Unclass rx
TS S rx
TS C rx
TS Unclass rx
A TS process can read S, C, and Unclass data, but cannot write it.
An S process can read C and Unclass. Note that specifying that
TS can read S and S can read C does not imply TS can read C, it
has to be explicitly stated.
Non-hierarchical categories. This is the more common of the
usual uses for an MLS system. Since the default rule is that a
subject cannot access an object with a different label no
access rules are required to implement compartmentalization.
A case that the Bell & LaPadula policy does not allow is demonstrated
with this Smack access rule:
A case that Bell&LaPadula does not allow that Smack does:
ESPN ABC r
ABC ESPN r
On my portable video device I have two applications, one that
shows ABC programming and the other ESPN programming. ESPN wants
to show me sport stories that show up as news, and ABC will
only provide minimal information about a sports story if ESPN
is covering it. Each side can look at the other's info, neither
can change the other. Neither can see what FOX is up to, which
is just as well all things considered.
Another case that I especially like:
SatData Guard w
Guard Publish w
A program running with the Guard label opens a UDP socket and
accepts messages sent by a program running with a SatData label.
The Guard program inspects the message to ensure it is wholesome
and if it is sends it to a program running with the Publish label.
This program then puts the information passed in an appropriate
place. Note that the Guard program cannot write to a Publish
file system object because file system semanitic require read as
well as write.
The four cases (categories, levels, mutual read, guardbox) here
are all quite real, and problems I've been asked to solve over
the years. The first two are easy to do with traditonal MLS systems
while the last two you can't without invoking privilege, at least
for a while.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Cc: Joshua Brindle <method@manicmethod.com>
Cc: Paul Moore <paul.moore@hp.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: "Ahmed S. Darwish" <darwish.07@gmail.com>
Cc: Andrew G. Morgan <morgan@kernel.org>
This code has suffered from broken core design and lack of developer
attention. Broken security modules are too dangerous to leave around. It
is time to remove this one.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Acked-by: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: Davi Arnaut <davi.arnaut@gmail.com>
Acked-by: Alan Cox <alan@redhat.com>
Here's a small patch against 2.6.13-rc2 that adds securityfs, a virtual
fs that all LSMs can use instead of creating their own. The fs should
be mounted at /sys/kernel/security, and the fs creates that mount point.
This will make the LSB people happy that we aren't creating a new
/my_lsm_fs directory in the root for every different LSM.
It has changed a bit since the last version, thanks to comments from
Mike Waychison.
Signed-off-by: Chris Wright <chrisw@osdl.org>
infrastructure for it.
Let it rip!
