path: root/security/apparmor/policy_unpack.c
2011-09-09apparmor: sparse fix: rename shadowed variables in policy_unpack.cJames Morris
Fix the following warnings: security/apparmor/policy_unpack.c:384:35: warning: symbol 'size' shadows an earlier one security/apparmor/policy_unpack.c:370:24: originally declared here security/apparmor/policy_unpack.c:443:29: warning: symbol 'tmp' shadows an earlier one security/apparmor/policy_unpack.c:434:21: originally declared here Signed-off-by: James Morris <jmorris@namei.org> Acked-by: John Johansen <john.johansen@canonical.com>
2011-05-19Create Documentation/security/,Randy Dunlap
move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
2010-08-02AppArmor: policy routines for loading and unpacking policyJohn Johansen
AppArmor policy is loaded in a platform independent flattened binary stream. Verify and unpack the data converting it to the internal format needed for enforcement. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
