[ Upstream commit 822ad64d7e46a8e2c8b8a796738d7b657cbb146d ]
In the request_key() upcall mechanism there's a dependency loop by which if
a key type driver overrides the ->request_key hook and the userspace side
manages to lose the authorisation key, the auth key and the internal
construction record (struct key_construction) can keep each other pinned.
Fix this by the following changes:
(1) Killing off the construction record and using the auth key instead.
(2) Including the operation name in the auth key payload and making the
payload available outside of security/keys/.
(3) The ->request_key hook is given the authkey instead of the cons
record and operation name.
Changes (2) and (3) allow the auth key to naturally be cleaned up if the
keyring it is in is destroyed or cleared or the auth key is unlinked.
Fixes: 7ee02a316600 ("keys: Fix dependency loop between construction record and auth key")
Signed-off-by: James Morris <james.morris@microsoft.com>
keyctl_restrict_keyring() allows through a NULL restriction when the
"type" is non-NULL, which causes a NULL pointer dereference in
asymmetric_lookup_restriction() when it calls strcmp() on the
restriction string.
But no key types actually use a "NULL restriction" to mean anything, so
update keyctl_restrict_keyring() to reject it with EINVAL.
Reported-by: syzbot <syzkaller@googlegroups.com>
Fixes: 97d3aa0f3134 ("KEYS: Add a lookup_restriction function for the asymmetric key type")
Cc: <stable@vger.kernel.org> # v4.12+
Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection
error into one field such that:
(1) The instantiation state can be modified/read atomically.
(2) The error can be accessed atomically with the state.
(3) The error isn't stored unioned with the payload pointers.
This deals with the problem that the state is spread over three different
objects (two bits and a separate variable) and reading or updating them
atomically isn't practical, given that not only can uninstantiated keys
change into instantiated or rejected keys, but rejected keys can also turn
into instantiated keys - and someone accessing the key might not be using
any locking.
The main side effect of this problem is that what was held in the payload
may change, depending on the state. For instance, you might observe the
key to be in the rejected state. You then read the cached error, but if
the key semaphore wasn't locked, the key might've become instantiated
between the two reads - and you might now have something in hand that isn't
actually an error code.
The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error
code if the key is negatively instantiated. The key_is_instantiated()
function is replaced with key_is_positive() to avoid confusion as negative
keys are also 'instantiated'.
Additionally, barriering is included:
(1) Order payload-set before state-set during instantiation.
(2) Order state-read before payload-read when using the key.
Further separate barriering is necessary if RCU is being used to access the
payload content after reading the payload pointers.
Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data")
Cc: stable@vger.kernel.org # v4.4+
Reported-by: Eric Biggers <ebiggers@google.com>
Reviewed-by: Eric Biggers <ebiggers@google.com>
Because keyctl_read_key() looks up the key with no permissions
requested, it may find a negatively instantiated key. If the key is
also possessed, we went ahead and called ->read() on the key. But the
key payload will actually contain the ->reject_error rather than the
normal payload. Thus, the kernel oopses trying to read the
user_key_payload from memory address (int)-ENOKEY = 0x00000000ffffff82.
Fortunately the payload data is stored inline, so it shouldn't be
possible to abuse this as an arbitrary memory read primitive...
Reproducer:
keyctl new_session
keyctl request2 user desc '' @s
keyctl read $(keyctl show | awk '/user: desc/ {print $1}')
It causes a crash like the following:
BUG: unable to handle kernel paging request at 00000000ffffff92
IP: user_read+0x33/0xa0
PGD 36a54067 P4D 36a54067 PUD 0
Oops: 0000 [#1] SMP
CPU: 0 PID: 211 Comm: keyctl Not tainted 4.14.0-rc1 #337
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014
task: ffff90aa3b74c3c0 task.stack: ffff9878c0478000
RIP: 0010:user_read+0x33/0xa0
RSP: 0018:ffff9878c047bee8 EFLAGS: 00010246
RAX: 0000000000000001 RBX: ffff90aa3d7da340 RCX: 0000000000000017
RDX: 0000000000000000 RSI: 00000000ffffff82 RDI: ffff90aa3d7da340
RBP: ffff9878c047bf00 R08: 00000024f95da94f R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f58ece69740(0000) GS:ffff90aa3e200000(0000) knlGS:0000000000000000
CR2: 00000000ffffff92 CR3: 0000000036adc001 CR4: 00000000003606f0
Call Trace:
keyctl_read_key+0xac/0xe0
SyS_keyctl+0x99/0x120
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x7f58ec787bb9
RSP: 002b:00007ffc8d401678 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa
RAX: ffffffffffffffda RBX: 00007ffc8d402800 RCX: 00007f58ec787bb9
RDX: 0000000000000000 RSI: 00000000174a63ac RDI: 000000000000000b
RBP: 0000000000000004 R08: 00007ffc8d402809 R09: 0000000000000020
R10: 0000000000000000 R11: 0000000000000206 R12: 00007ffc8d402800
R13: 00007ffc8d4016e0 R14: 0000000000000000 R15: 0000000000000000
Code: e5 41 55 49 89 f5 41 54 49 89 d4 53 48 89 fb e8 a4 b4 ad ff 85 c0 74 09 80 3d b9 4c 96 00 00 74 43 48 8b b3 20 01 00 00 4d 85 ed <0f> b7 5e 10 74 29 4d 85 e4 74 24 4c 39 e3 4c 89 e2 4c 89 ef 48
RIP: user_read+0x33/0xa0 RSP: ffff9878c047bee8
Fixes: 61ea0c0ba904 ("KEYS: Skip key state checks when checking for possession")
Cc: <stable@vger.kernel.org> [v3.13+]
In keyctl_read_key(), if key_permission() were to return an error code
other than EACCES, we would leak a the reference to the key. This can't
actually happen currently because key_permission() can only return an
error code other than EACCES if security_key_permission() does, only
SELinux and Smack implement that hook, and neither can return an error
code other than EACCES. But it should still be fixed, as it is a bug
waiting to happen.
Fixes: 29db91906340 ("[PATCH] Keys: Add LSM hooks for key management [try #3]")
In keyctl_assume_authority(), if keyctl_change_reqkey_auth() were to
fail, we would leak the reference to the 'authkey'. Currently this can
only happen if prepare_creds() fails to allocate memory. But it still
should be fixed, as it is a more severe bug waiting to happen.
This patch also moves the read of 'authkey->serial' to before the
reference to the authkey is dropped. Doing the read after dropping the
reference is very fragile because it assumes we still hold another
reference to the key. (Which we do, in current->cred->request_key_auth,
but there's no reason not to write it in the "obviously correct" way.)
Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials")
Before returning from add_key() or one of the keyctl() commands that
takes in a key payload, zero the temporary buffer that was allocated to
hold the key payload copied from userspace. This may contain sensitive
key material that should not be kept around in the slab caches.
Signed-off-by: James Morris <james.l.morris@oracle.com>
sys_add_key() and the KEYCTL_UPDATE operation of sys_keyctl() allowed a
NULL payload with nonzero length to be passed to the key type's
->preparse(), ->instantiate(), and/or ->update() methods. Various key
types including asymmetric, cifs.idmap, cifs.spnego, and pkcs7_test did
not handle this case, allowing an unprivileged user to trivially cause a
NULL pointer dereference (kernel oops) if one of these key types was
present. Fix it by doing the copy_from_user() when 'plen' is nonzero
rather than when '_payload' is non-NULL, causing the syscall to fail
with EFAULT as expected when an invalid buffer is specified.
Cc: stable@vger.kernel.org # 2.6.10+
There are many code paths opencoding kvmalloc. Let's use the helper
instead. The main difference to kvmalloc is that those users are
usually not considering all the aspects of the memory allocator. E.g.
allocation requests <= 32kB (with 4kB pages) are basically never failing
and invoke OOM killer to satisfy the allocation. This sounds too
disruptive for something that has a reasonable fallback - the vmalloc.
On the other hand those requests might fallback to vmalloc even when the
memory allocator would succeed after several more reclaim/compaction
attempts previously. There is no guarantee something like that happens
though.
This patch converts many of those places to kv[mz]alloc* helpers because
they are more conservative.
Link: http://lkml.kernel.org/r/20170306103327.2766-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> # Xen bits
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Andreas Dilger <andreas.dilger@intel.com> # Lustre
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> # KVM/s390
Acked-by: Dan Williams <dan.j.williams@intel.com> # nvdim
Acked-by: David Sterba <dsterba@suse.com> # btrfs
Acked-by: Ilya Dryomov <idryomov@gmail.com> # Ceph
Acked-by: Tariq Toukan <tariqt@mellanox.com> # mlx4
Acked-by: Leon Romanovsky <leonro@mellanox.com> # mlx5
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Kent Overstreet <kent.overstreet@gmail.com>
Cc: Santosh Raspatur <santosh@chelsio.com>
Cc: Hariprasad S <hariprasad@chelsio.com>
Cc: Yishai Hadas <yishaih@mellanox.com>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: "Yan, Zheng" <zyan@redhat.com>
Cc: Alexei Starovoitov <ast@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
IMA:
- provide ">" and "<" operators for fowner/uid/euid rules
KEYS:
- add a system blacklist keyring
- add KEYCTL_RESTRICT_KEYRING, exposes keyring link restriction
functionality to userland via keyctl()
LSM:
- harden LSM API with __ro_after_init
- add prlmit security hook, implement for SELinux
- revive security_task_alloc hook
TPM:
- implement contextual TPM command 'spaces'"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (98 commits)
tpm: Fix reference count to main device
tpm_tis: convert to using locality callbacks
tpm: fix handling of the TPM 2.0 event logs
tpm_crb: remove a cruft constant
keys: select CONFIG_CRYPTO when selecting DH / KDF
apparmor: Make path_max parameter readonly
apparmor: fix parameters so that the permission test is bypassed at boot
apparmor: fix invalid reference to index variable of iterator line 836
apparmor: use SHASH_DESC_ON_STACK
security/apparmor/lsm.c: set debug messages
apparmor: fix boolreturn.cocci warnings
Smack: Use GFP_KERNEL for smk_netlbl_mls().
smack: fix double free in smack_parse_opts_str()
KEYS: add SP800-56A KDF support for DH
KEYS: Keyring asymmetric key restrict method with chaining
KEYS: Restrict asymmetric key linkage using a specific keychain
KEYS: Add KEYCTL_RESTRICT_KEYRING
KEYS: Consistent ordering for __key_link_begin and restrict check
KEYS: Add an optional lookup_restriction hook to key_type
This fixes CVE-2017-7472.
Running the following program as an unprivileged user exhausts kernel
memory by leaking thread keyrings:
#include <keyutils.h>
int main()
for (;;)
keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_THREAD_KEYRING);
Fix it by only creating a new thread keyring if there wasn't one before.
To make things more consistent, make install_thread_keyring_to_cred()
and install_process_keyring_to_cred() both return 0 if the corresponding
keyring is already present.
Cc: stable@vger.kernel.org # 2.6.29+
This fixes CVE-2016-9604.
Keyrings whose name begin with a '.' are special internal keyrings and so
userspace isn't allowed to create keyrings by this name to prevent
shadowing. However, the patch that added the guard didn't fix
KEYCTL_JOIN_SESSION_KEYRING. Not only can that create dot-named keyrings,
it can also subscribe to them as a session keyring if they grant SEARCH
permission to the user.
This, for example, allows a root process to set .builtin_trusted_keys as
its session keyring, at which point it has full access because now the
possessor permissions are added. This permits root to add extra public
keys, thereby bypassing module verification.
This also affects kexec and IMA.
This can be tested by (as root):
keyctl session .builtin_trusted_keys
keyctl add user a a @s
keyctl list @s
which on my test box gives me:
2 keys in keyring:
180010936: ---lswrv 0 0 asymmetric: Build time autogenerated kernel key: ae3d4a31b82daa8e1a75b49dc2bba949fd992a05
801382539: --alswrv 0 0 user: a
Fix this by rejecting names beginning with a '.' in the keyctl.
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
cc: linux-ima-devel@lists.sourceforge.net
cc: stable@vger.kernel.org
SP800-56A defines the use of DH with key derivation function based on a
counter. The input to the KDF is defined as (DH shared secret || other
information). The value for the "other information" is to be provided by
the caller.
The KDF is implemented using the hash support from the kernel crypto API.
The implementation uses the symmetric hash support as the input to the
hash operation is usually very small. The caller is allowed to specify
the hash name that he wants to use to derive the key material allowing
the use of all supported hashes provided with the kernel crypto API.
As the KDF implements the proper truncation of the DH shared secret to
the requested size, this patch fills the caller buffer up to its size.
The patch is tested with a new test added to the keyutils user space
code which uses a CAVS test vector testing the compliance with
SP800-56A.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
Keyrings recently gained restrict_link capabilities that allow
individual keys to be validated prior to linking. This functionality
was only available using internal kernel APIs.
With the KEYCTL_RESTRICT_KEYRING command existing keyrings can be
configured to check the content of keys before they are linked, and
then allow or disallow linkage of that key to the keyring.
To restrict a keyring, call:
keyctl(KEYCTL_RESTRICT_KEYRING, key_serial_t keyring, const char *type,
const char *restriction)
where 'type' is the name of a registered key type and 'restriction' is a
string describing how key linkage is to be restricted. The restriction
option syntax is specific to each key type.
Signed-off-by: Mat Martineau <mathew.j.martineau@linux.intel.com>
<linux/sched/task.h>
We are going to split <linux/sched/task.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/task.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h
doing that for them.
Note that even if the count where we need to add extra headers seems high,
it's still a net win, because <linux/sched.h> is included in over
2,200 files ...
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
copy_from_iter_full(), copy_from_iter_full_nocache() and
csum_and_copy_from_iter_full() - counterparts of copy_from_iter()
et.al., advancing iterator only in case of successful full copy
and returning whether it had been successful or not.
Convert some obvious users. *NOTE* - do not blindly assume that
something is a good candidate for those unless you are sure that
not advancing iov_iter in failure case is the right thing in
this case. Anything that does short read/short write kind of
stuff (or is in a loop, etc.) is unlikely to be a good one.
The values computed during Diffie-Hellman key exchange are often used
in combination with key derivation functions to create cryptographic
keys. Add a placeholder for a later implementation to configure a
key derivation function that will transform the Diffie-Hellman
result returned by the KEYCTL_DH_COMPUTE command.
[This patch was stripped down from a patch produced by Mat Martineau that
had a bug in the compat code - so for the moment Stephan's patch simply
requires that the placeholder argument must be NULL]
Original-signed-off-by: Mat Martineau <mathew.j.martineau@linux.intel.com>
This adds userspace access to Diffie-Hellman computations through a
new keyctl() syscall command to calculate shared secrets or public
keys using input parameters stored in the keyring.
Input key ids are provided in a struct due to the current 5-arg limit
for the keyctl syscall. Only user keys are supported in order to avoid
exposing the content of logon or encrypted keys.
The output is written to the provided buffer, based on the assumption
that the values are only needed in userspace.
Future support for other types of key derivation would involve a new
command, like KEYCTL_ECDH_COMPUTE.
Once Diffie-Hellman support is included in the crypto API, this code
can be converted to use the crypto API to take advantage of possible
hardware acceleration and reduce redundant code.
- EVM gains support for loading an x509 cert from the kernel
(EVM_LOAD_X509), into the EVM trusted kernel keyring.
- Smack implements 'file receive' process-based permission checking for
sockets, rather than just depending on inode checks.
- Misc enhancments for TPM & TPM2.
- Cleanups and bugfixes for SELinux, Keys, and IMA.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (41 commits)
selinux: Inode label revalidation performance fix
KEYS: refcount bug fix
ima: ima_write_policy() limit locking
IMA: policy can be updated zero times
selinux: rate-limit netlink message warnings in selinux_nlmsg_perm()
selinux: export validatetrans decisions
gfs2: Invalid security labels of inodes when they go invalid
selinux: Revalidate invalid inode security labels
security: Add hook to invalidate inode security labels
selinux: Add accessor functions for inode->i_security
security: Make inode argument of inode_getsecid non-const
security: Make inode argument of inode_getsecurity non-const
selinux: Remove unused variable in selinux_inode_init_security
keys, trusted: seal with a TPM2 authorization policy
keys, trusted: select hash algorithm for TPM2 chips
keys, trusted: fix: *do not* allow duplicate key options
tpm_ibmvtpm: properly handle interrupted packet receptions
tpm_tis: Tighten IRQ auto-probing
tpm_tis: Refactor the interrupt setup
tpm_tis: Get rid of the duplicate IRQ probing code
This patch fixes the key_ref leak, removes the unnecessary KEY_FLAG_KEEP
test before setting the flag, and cleans up the if/then brackets style
introduced in commit:
d3600bc KEYS: prevent keys from being removed from specified keyrings
Reported-by: David Howells <dhowells@redhat.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
This fixes CVE-2015-7550.
There's a race between keyctl_read() and keyctl_revoke(). If the revoke
happens between keyctl_read() checking the validity of a key and the key's
semaphore being taken, then the key type read method will see a revoked key.
This causes a problem for the user-defined key type because it assumes in
its read method that there will always be a payload in a non-revoked key
and doesn't check for a NULL pointer.
Fix this by making keyctl_read() check the validity of a key after taking
semaphore instead of before.
I think the bug was introduced with the original keyrings code.
This was discovered by a multithreaded test program generated by syzkaller
(http://github.com/google/syzkaller). Here's a cleaned up version:
#include <sys/types.h>
#include <pthread.h>
void *thr0(void *arg)
key_serial_t key = (unsigned long)arg;
keyctl_revoke(key);
return 0;
void *thr1(void *arg)
char buffer[16];
keyctl_read(key, buffer, 16);
return 0;
int main()
key_serial_t key = add_key("user", "%", "foo", 3, KEY_SPEC_USER_KEYRING);
pthread_t th[5];
pthread_create(&th[0], 0, thr0, (void *)(unsigned long)key);
pthread_create(&th[1], 0, thr1, (void *)(unsigned long)key);
pthread_create(&th[2], 0, thr0, (void *)(unsigned long)key);
pthread_create(&th[3], 0, thr1, (void *)(unsigned long)key);
pthread_join(th[0], 0);
pthread_join(th[1], 0);
pthread_join(th[2], 0);
pthread_join(th[3], 0);
return 0;
Build as:
cc -o keyctl-race keyctl-race.c -lkeyutils -lpthread
Run as:
while keyctl-race; do :; done
as it may need several iterations to crash the kernel. The crash can be
summarised as:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: [<ffffffff81279b08>] user_read+0x56/0xa3
Call Trace:
[<ffffffff81276aa9>] keyctl_read_key+0xb6/0xd7
[<ffffffff81277815>] SyS_keyctl+0x83/0xe0
[<ffffffff815dbb97>] entry_SYSCALL_64_fastpath+0x12/0x6f
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Userspace should not be allowed to remove keys from certain keyrings
(eg. blacklist), though the keys themselves can expire.
This patch defines a new key flag named KEY_FLAG_KEEP to prevent
userspace from being able to unlink, revoke, invalidate or timed
out a key on a keyring. When this flag is set on the keyring, all
keys subsequently added are flagged.
In addition, when this flag is set, the keyring itself can not be
cleared.
Merge the type-specific data with the payload data into one four-word chunk
as it seems pointless to keep them separate.
Use user_key_payload() for accessing the payloads of overloaded
user-defined keys.
cc: linux-cifs@vger.kernel.org
cc: ecryptfs@vger.kernel.org
cc: linux-ext4@vger.kernel.org
cc: linux-f2fs-devel@lists.sourceforge.net
cc: linux-nfs@vger.kernel.org
cc: ceph-devel@vger.kernel.org
There is no need to make a flag to tell that this memory is allocated by
kmalloc or vmalloc. Just use kvfree to free the memory.
Signed-off-by: Geliang Tang <geliangtang@163.com>
When a key description argument is imported into the kernel from userspace, as
happens in add_key(), request_key(), KEYCTL_JOIN_SESSION_KEYRING,
KEYCTL_SEARCH, the description is copied into a buffer up to PAGE_SIZE in size.
PAGE_SIZE, however, is a variable quantity, depending on the arch. Fix this at
4096 instead (ie. 4095 plus a NUL termination) and define a constant
(KEY_MAX_DESC_SIZE) to this end.
When reading the description back with KEYCTL_DESCRIBE, a PAGE_SIZE internal
buffer is allocated into which the information and description will be
rendered. This means that the description will get truncated if an extremely
long description it has to be crammed into the buffer with the stringified
information. There is no particular need to copy the description into the
buffer, so just copy it directly to userspace in a separate operation.
Reported-by: Christian Kastner <debian@kvr.at>
Tested-by: Christian Kastner <debian@kvr.at>
Reinstate the generation of EPERM for a key type name beginning with a '.' in
a userspace call. Types whose name begins with a '.' are internal only.
The test was removed by:
commit a4e3b8d79a5c6d40f4a9703abf7fe3abcc6c3b8d
Author: Mimi Zohar <zohar@linux.vnet.ibm.com>
Date: Thu May 22 14:02:23 2014 -0400
Subject: KEYS: special dot prefixed keyring name bug fix
I think we want to keep the restriction on type name so that userspace can't
add keys of a special internal type.
Note that removal of the test causes several of the tests in the keyutils
testsuite to fail.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Special kernel keys, such as those used to hold DNS results for AFS, CIFS and
NFS and those used to hold idmapper results for NFS, used to be
'invalidateable' with key_revoke(). However, since the default permissions for
keys were reduced:
Commit: 96b5c8fea6c0861621051290d705ec2e971963f1
KEYS: Reduce initial permissions on keys
it has become impossible to do this.
Add a key flag (KEY_FLAG_ROOT_CAN_INVAL) that will permit a key to be
invalidated by root. This should not be used for system keyrings as the
garbage collector will try and remove any invalidate key. For system keyrings,
KEY_FLAG_ROOT_CAN_CLEAR can be used instead.
After this, from userspace, keyctl_invalidate() and "keyctl invalidate" can be
used by any possessor of CAP_SYS_ADMIN (typically root) to invalidate DNS and
idmapper keys. Invalidated keys are immediately garbage collected and will be
immediately rerequested if needed again.
Tested-by: Steve Dickson <steved@redhat.com>
Dot prefixed keyring names are supposed to be reserved for the
kernel, but add_key() calls key_get_type_from_user(), which
incorrectly verifies the 'type' field, not the 'description' field.
This patch verifies the 'description' field isn't dot prefixed,
when creating a new keyring, and removes the dot prefix test in
key_get_type_from_user().
Changelog v6:
- whitespace and other cleanup
Changelog v5:
- Only prevent userspace from creating a dot prefixed keyring, not
regular keys - Dmitry
Reported-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Move the flags representing required permission to linux/key.h as the perm
parameter of security_key_permission() is in terms of them - and not the
permissions mask flags used in key->perm.
Whilst we're at it:
(1) Rename them to be KEY_NEED_xxx rather than KEY_xxx to avoid collisions
with symbols in uapi/linux/input.h.
(2) Don't use key_perm_t for a mask of required permissions, but rather limit
it to the permissions mask attached to the key and arguments related
directly to that.
Tested-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Add support for per-user_namespace registers of persistent per-UID kerberos
caches held within the kernel.
This allows the kerberos cache to be retained beyond the life of all a user's
processes so that the user's cron jobs can work.
The kerberos cache is envisioned as a keyring/key tree looking something like:
struct user_namespace
\___ .krb_cache keyring - The register
\___ _krb.0 keyring - Root's Kerberos cache
\___ _krb.5000 keyring - User 5000's Kerberos cache
\___ _krb.5001 keyring - User 5001's Kerberos cache
\___ tkt785 big_key - A ccache blob
\___ tkt12345 big_key - Another ccache blob
Or possibly:
\___ tkt785 keyring - A ccache
\___ krbtgt/REDHAT.COM@REDHAT.COM big_key
\___ http/REDHAT.COM@REDHAT.COM user
\___ afs/REDHAT.COM@REDHAT.COM user
\___ nfs/REDHAT.COM@REDHAT.COM user
\___ krbtgt/KERNEL.ORG@KERNEL.ORG big_key
\___ http/KERNEL.ORG@KERNEL.ORG big_key
What goes into a particular Kerberos cache is entirely up to userspace. Kernel
support is limited to giving you the Kerberos cache keyring that you want.
The user asks for their Kerberos cache by:
krb_cache = keyctl_get_krbcache(uid, dest_keyring);
The uid is -1 or the user's own UID for the user's own cache or the uid of some
other user's cache (requires CAP_SETUID). This permits rpc.gssd or whatever to
mess with the cache.
The cache returned is a keyring named "_krb.<uid>" that the possessor can read,
search, clear, invalidate, unlink from and add links to. Active LSMs get a
chance to rule on whether the caller is permitted to make a link.
Each uid's cache keyring is created when it first accessed and is given a
timeout that is extended each time this function is called so that the keyring
goes away after a while. The timeout is configurable by sysctl but defaults to
three days.
Each user_namespace struct gets a lazily-created keyring that serves as the
register. The cache keyrings are added to it. This means that standard key
search and garbage collection facilities are available.
The user_namespace struct's register goes away when it does and anything left
in it is then automatically gc'd.
Tested-by: Simo Sorce <simo@redhat.com>
cc: Serge E. Hallyn <serge.hallyn@ubuntu.com>
cc: Eric W. Biederman <ebiederm@xmission.com>
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
"A quiet cycle for the security subsystem with just a few maintenance
updates."
Smack: create a sysfs mount point for smackfs
Smack: use select not depends in Kconfig
Yama: remove locking from delete path
Yama: add RCU to drop read locking
drivers/char/tpm: remove tasklet and cleanup
KEYS: Use keyring_alloc() to create special keyrings
KEYS: Make the session and process keyrings per-thread
seccomp: Make syscall skipping and nr changes more consistent
key: Fix resource leak
keys: Fix unreachable code
KEYS: Add payload preparsing opportunity prior to key instantiate or update
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module signing support from Rusty Russell:
"module signing is the highlight, but it's an all-over David Howells frenzy..."
Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG.
* 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits)
X.509: Fix indefinite length element skip error handling
X.509: Convert some printk calls to pr_devel
asymmetric keys: fix printk format warning
MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking
MODSIGN: Make mrproper should remove generated files.
MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs
MODSIGN: Use the same digest for the autogen key sig as for the module sig
MODSIGN: Sign modules during the build process
MODSIGN: Provide a script for generating a key ID from an X.509 cert
MODSIGN: Implement module signature checking
MODSIGN: Provide module signing public keys to the kernel
MODSIGN: Automatically generate module signing keys if missing
MODSIGN: Provide Kconfig options
MODSIGN: Provide gitignore and make clean rules for extra files
MODSIGN: Add FIPS policy
module: signature checking hook
X.509: Add a crypto key parser for binary (DER) X.509 certificates
MPILIB: Provide a function to read raw data into an MPI
X.509: Add an ASN.1 decoder
X.509: Add simple ASN.1 grammar compiler
Give the key type the opportunity to preparse the payload prior to the
instantiation and update routines being called. This is done with the
provision of two new key type operations:
int (*preparse)(struct key_preparsed_payload *prep);
void (*free_preparse)(struct key_preparsed_payload *prep);
If the first operation is present, then it is called before key creation (in
the add/update case) or before the key semaphore is taken (in the update and
instantiate cases). The second operation is called to clean up if the first
was called.
preparse() is given the opportunity to fill in the following structure:
struct key_preparsed_payload {
char *description;
void *type_data[2];
void *payload;
const void *data;
size_t datalen;
size_t quotalen;
Before the preparser is called, the first three fields will have been cleared,
the payload pointer and size will be stored in data and datalen and the default
quota size from the key_type struct will be stored into quotalen.
The preparser may parse the payload in any way it likes and may store data in
the type_data[] and payload fields for use by the instantiate() and update()
ops.
The preparser may also propose a description for the key by attaching it as a
string to the description field. This can be used by passing a NULL or ""
description to the add_key() system call or the key_create_or_update()
function. This cannot work with request_key() as that required the description
to tell the upcall about the key to be created.
This, for example permits keys that store PGP public keys to generate their own
name from the user ID and public key fingerprint in the key.
The instantiate() and update() operations are then modified to look like this:
int (*instantiate)(struct key *key, struct key_preparsed_payload *prep);
int (*update)(struct key *key, struct key_preparsed_payload *prep);
and the new payload data is passed in *prep, whether or not it was preparsed.
Make the session keyring per-thread rather than per-process, but still
inherited from the parent thread to solve a problem with PAM and gdm.
The problem is that join_session_keyring() will reject attempts to change the
session keyring of a multithreaded program but gdm is now multithreaded before
it gets to the point of starting PAM and running pam_keyinit to create the
session keyring. See:
https://bugs.freedesktop.org/show_bug.cgi?id=49211
The reason that join_session_keyring() will only change the session keyring
under a single-threaded environment is that it's hard to alter the other
thread's credentials to effect the change in a multi-threaded program. The
problems are such as:
(1) How to prevent two threads both running join_session_keyring() from
racing.
(2) Another thread's credentials may not be modified directly by this process.
(3) The number of threads is uncertain whilst we're not holding the
appropriate spinlock, making preallocation slightly tricky.
(4) We could use TIF_NOTIFY_RESUME and key_replace_session_keyring() to get
another thread to replace its keyring, but that means preallocating for
each thread.
A reasonable way around this is to make the session keyring per-thread rather
than per-process and just document that if you want a common session keyring,
you must get it before you spawn any threads - which is the current situation
anyway.
Whilst we're at it, we can the process keyring behave in the same way. This
means we can clean up some of the ickyness in the creds code.
Basically, after this patch, the session, process and thread keyrings are about
inheritance rules only and not about sharing changes of keyring.
Reported-by: Mantas M. <grawity@gmail.com>
Tested-by: Ray Strode <rstrode@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"This is a mostly modest set of changes to enable basic user namespace
support. This allows the code to code to compile with user namespaces
enabled and removes the assumption there is only the initial user
namespace. Everything is converted except for the most complex of the
filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs,
nfs, ocfs2 and xfs as those patches need a bit more review.
The strategy is to push kuid_t and kgid_t values are far down into
subsystems and filesystems as reasonable. Leaving the make_kuid and
from_kuid operations to happen at the edge of userspace, as the values
come off the disk, and as the values come in from the network.
Letting compile type incompatible compile errors (present when user
namespaces are enabled) guide me to find the issues.
The most tricky areas have been the places where we had an implicit
union of uid and gid values and were storing them in an unsigned int.
Those places were converted into explicit unions. I made certain to
handle those places with simple trivial patches.
Out of that work I discovered we have generic interfaces for storing
quota by projid. I had never heard of the project identifiers before.
Adding full user namespace support for project identifiers accounts
for most of the code size growth in my git tree.
Ultimately there will be work to relax privlige checks from
"capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing
root in a user names to do those things that today we only forbid to
non-root users because it will confuse suid root applications.
While I was pushing kuid_t and kgid_t changes deep into the audit code
I made a few other cleanups. I capitalized on the fact we process
netlink messages in the context of the message sender. I removed
usage of NETLINK_CRED, and started directly using current->tty.
Some of these patches have also made it into maintainer trees, with no
problems from identical code from different trees showing up in
linux-next.
After reading through all of this code I feel like I might be able to
win a game of kernel trivial pursuit."
Fix up some fairly trivial conflicts in netfilter uid/git logging code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits)
userns: Convert the ufs filesystem to use kuid/kgid where appropriate
userns: Convert the udf filesystem to use kuid/kgid where appropriate
userns: Convert ubifs to use kuid/kgid
userns: Convert squashfs to use kuid/kgid where appropriate
userns: Convert reiserfs to use kuid and kgid where appropriate
userns: Convert jfs to use kuid/kgid where appropriate
userns: Convert jffs2 to use kuid and kgid where appropriate
userns: Convert hpfs to use kuid and kgid where appropriate
userns: Convert btrfs to use kuid/kgid where appropriate
userns: Convert bfs to use kuid/kgid where appropriate
userns: Convert affs to use kuid/kgid wherwe appropriate
userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids
userns: On ia64 deal with current_uid and current_gid being kuid and kgid
userns: On ppc convert current_uid from a kuid before printing.
userns: Convert s390 getting uid and gid system calls to use kuid and kgid
userns: Convert s390 hypfs to use kuid and kgid where appropriate
userns: Convert binder ipc to use kuids
userns: Teach security_path_chown to take kuids and kgids
userns: Add user namespace support to IMA
userns: Convert EVM to deal with kuids and kgids in it's hmac computation
On an error iov may still have been reallocated and need freeing
Signed-off-by: Alan Cox <alan@linux.intel.com>
- Replace key_user ->user_ns equality checks with kuid_has_mapping checks.
- Use from_kuid to generate key descriptions
- Use kuid_t and kgid_t and the associated helpers instead of uid_t and gid_t
- Avoid potential problems with file descriptor passing by displaying
keys in the user namespace of the opener of key status proc files.
Cc: linux-security-module@vger.kernel.org
Cc: keyrings@linux-nfs.org
This reverts commit d35abdb28824cf74f0a106a0f9c6f3ff700a35bf.
task_lock() was added to ensure exit_mm() and thus exit_task_work() is
not possible before task_work_add().
This is wrong, task_lock() must not be nested with write_lock(tasklist).
And this is no longer needed, task_work_add() now fails if it is called
after exit_task_work().
Reported-by: Dave Jones <davej@redhat.com>
Link: http://lkml.kernel.org/r/20120826191214.GA4231@redhat.com
was called.
char *description;
void *type_data[2];
void *payload;
const void *data;
size_t datalen;
size_t quotalen;
ops.
"Nothing groundbreaking for this kernel, just cleanups and fixes, and a
couple of Smack enhancements."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits)
Smack: Maintainer Record
Smack: don't show empty rules when /smack/load or /smack/load2 is read
Smack: user access check bounds
Smack: onlycap limits on CAP_MAC_ADMIN
Smack: fix smack_new_inode bogosities
ima: audit is compiled only when enabled
ima: ima_initialized is set only if successful
ima: add policy for pseudo fs
ima: remove unused cleanup functions
ima: free securityfs violations file
ima: use full pathnames in measurement list
security: Fix nommu build.
samples: seccomp: add .gitignore for untracked executables
tpm: check the chip reference before using it
TPM: fix memleak when register hardware fails
TPM: chip disabled state erronously being reported as error
MAINTAINERS: TPM maintainers' contacts update
Merge branches 'next-queue' and 'next' into next
Remove unused code from MPI library
Revert "crypto: GnuPG based MPI lib - additional sources (part 4)"
task_work and rcu_head are identical now; merge them (calling the result
struct callback_head, rcu_head #define'd to it), kill separate allocation
in security/keys since we can just use cred->rcu now.
get rid of the only user of ->data; this is _not_ the final variant - in the
end we'll have task_work and rcu_head identical and just use cred->rcu,
at which point the separate allocation will be gone completely.
