commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream.
Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection
error into one field such that:
(1) The instantiation state can be modified/read atomically.
(2) The error can be accessed atomically with the state.
(3) The error isn't stored unioned with the payload pointers.
This deals with the problem that the state is spread over three different
objects (two bits and a separate variable) and reading or updating them
atomically isn't practical, given that not only can uninstantiated keys
change into instantiated or rejected keys, but rejected keys can also turn
into instantiated keys - and someone accessing the key might not be using
any locking.
The main side effect of this problem is that what was held in the payload
may change, depending on the state. For instance, you might observe the
key to be in the rejected state. You then read the cached error, but if
the key semaphore wasn't locked, the key might've become instantiated
between the two reads - and you might now have something in hand that isn't
actually an error code.
The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error
code if the key is negatively instantiated. The key_is_instantiated()
function is replaced with key_is_positive() to avoid confusion as negative
keys are also 'instantiated'.
Additionally, barriering is included:
(1) Order payload-set before state-set during instantiation.
(2) Order state-read before payload-read when using the key.
Further separate barriering is necessary if RCU is being used to access the
payload content after reading the payload pointers.
Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data")
Reported-by: Eric Biggers <ebiggers@google.com>
Reviewed-by: Eric Biggers <ebiggers@google.com>
commit 237bbd29f7a049d310d907f4b2716a7feef9abf3 upstream.
It was possible for an unprivileged user to create the user and user
session keyrings for another user. For example:
sudo -u '#3000' sh -c 'keyctl add keyring _uid.4000 "" @u
keyctl add keyring _uid_ses.4000 "" @u
sleep 15' &
sleep 1
sudo -u '#4000' keyctl describe @u
sudo -u '#4000' keyctl describe @us
This is problematic because these "fake" keyrings won't have the right
permissions. In particular, the user who created them first will own
them and will have full access to them via the possessor permissions,
which can be used to compromise the security of a user's keys:
-4: alswrv-----v------------ 3000 0 keyring: _uid.4000
-5: alswrv-----v------------ 3000 0 keyring: _uid_ses.4000
Fix it by marking user and user session keyrings with a flag
KEY_FLAG_UID_KEYRING. Then, when searching for a user or user session
keyring by name, skip all keyrings that don't have the flag set.
Fixes: 69664cf16af4 ("keys: don't generate user and user session keyrings unless they're accessed")
commit c9f838d104fed6f2f61d68164712e3204bf5271b upstream.
This fixes CVE-2017-7472.
Running the following program as an unprivileged user exhausts kernel
memory by leaking thread keyrings:
#include <keyutils.h>
int main()
for (;;)
keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_THREAD_KEYRING);
Fix it by only creating a new thread keyring if there wasn't one before.
To make things more consistent, make install_thread_keyring_to_cred()
and install_process_keyring_to_cred() both return 0 if the corresponding
keyring is already present.
Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials")
Add a facility whereby proposed new links to be added to a keyring can be
vetted, permitting them to be rejected if necessary. This can be used to
block public keys from which the signature cannot be verified or for which
the signature verification fails. It could also be used to provide
blacklisting.
This affects operations like add_key(), KEYCTL_LINK and KEYCTL_INSTANTIATE.
To this end:
(1) A function pointer is added to the key struct that, if set, points to
the vetting function. This is called as:
int (*restrict_link)(struct key *keyring,
const struct key_type *key_type,
unsigned long key_flags,
const union key_payload *key_payload),
where 'keyring' will be the keyring being added to, key_type and
key_payload will describe the key being added and key_flags[*] can be
AND'ed with KEY_FLAG_TRUSTED.
[*] This parameter will be removed in a later patch when
KEY_FLAG_TRUSTED is removed.
The function should return 0 to allow the link to take place or an
error (typically -ENOKEY, -ENOPKG or -EKEYREJECTED) to reject the
link.
The pointer should not be set directly, but rather should be set
through keyring_alloc().
Note that if called during add_key(), preparse is called before this
method, but a key isn't actually allocated until after this function
is called.
(2) KEY_ALLOC_BYPASS_RESTRICTION is added. This can be passed to
key_create_or_update() or key_instantiate_and_link() to bypass the
restriction check.
(3) KEY_FLAG_TRUSTED_ONLY is removed. The entire contents of a keyring
with this restriction emplaced can be considered 'trustworthy' by
virtue of being in the keyring when that keyring is consulted.
(4) key_alloc() and keyring_alloc() take an extra argument that will be
used to set restrict_link in the new key. This ensures that the
pointer is set before the key is published, thus preventing a window
of unrestrictedness. Normally this argument will be NULL.
(5) As a temporary affair, keyring_restrict_trusted_only() is added. It
should be passed to keyring_alloc() as the extra argument instead of
setting KEY_FLAG_TRUSTED_ONLY on a keyring. This will be replaced in
a later patch with functions that look in the appropriate places for
authoritative keys.
Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
This fixes CVE-2016-0728.
If a thread is asked to join as a session keyring the keyring that's already
set as its session, we leak a keyring reference.
This can be tested with the following program:
#include <stddef.h>
#include <stdio.h>
#include <sys/types.h>
int main(int argc, const char *argv[])
int i = 0;
key_serial_t serial;
serial = keyctl(KEYCTL_JOIN_SESSION_KEYRING,
"leaked-keyring");
if (serial < 0) {
perror("keyctl");
return -1;
if (keyctl(KEYCTL_SETPERM, serial,
KEY_POS_ALL | KEY_USR_ALL) < 0) {
perror("keyctl");
return -1;
for (i = 0; i < 100; i++) {
"leaked-keyring");
if (serial < 0) {
perror("keyctl");
return -1;
return 0;
If, after the program has run, there something like the following line in
/proc/keys:
3f3d898f I--Q--- 100 perm 3f3f0000 0 0 keyring leaked-keyring: empty
with a usage count of 100 * the number of times the program has been run,
then the kernel is malfunctioning. If leaked-keyring has zero usages or
has been garbage collected, then the problem is fixed.
Reported-by: Yevgeny Pats <yevgeny@perception-point.io>
Acked-by: Don Zickus <dzickus@redhat.com>
Acked-by: Prarit Bhargava <prarit@redhat.com>
Acked-by: Jarod Wilson <jarod@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Merge the type-specific data with the payload data into one four-word chunk
as it seems pointless to keep them separate.
Use user_key_payload() for accessing the payloads of overloaded
user-defined keys.
cc: linux-cifs@vger.kernel.org
cc: ecryptfs@vger.kernel.org
cc: linux-ext4@vger.kernel.org
cc: linux-f2fs-devel@lists.sourceforge.net
cc: linux-nfs@vger.kernel.org
cc: ceph-devel@vger.kernel.org
cc: linux-ima-devel@lists.sourceforge.net
Credit where credit is due: this idea comes from Christoph Lameter with
a lot of valuable input from Serge Hallyn. This patch is heavily based
on Christoph's patch.
===== The status quo =====
On Linux, there are a number of capabilities defined by the kernel. To
perform various privileged tasks, processes can wield capabilities that
they hold.
Each task has four capability masks: effective (pE), permitted (pP),
inheritable (pI), and a bounding set (X). When the kernel checks for a
capability, it checks pE. The other capability masks serve to modify
what capabilities can be in pE.
Any task can remove capabilities from pE, pP, or pI at any time. If a
task has a capability in pP, it can add that capability to pE and/or pI.
If a task has CAP_SETPCAP, then it can add any capability to pI, and it
can remove capabilities from X.
Tasks are not the only things that can have capabilities; files can also
have capabilities. A file can have no capabilty information at all [1].
If a file has capability information, then it has a permitted mask (fP)
and an inheritable mask (fI) as well as a single effective bit (fE) [2].
File capabilities modify the capabilities of tasks that execve(2) them.
A task that successfully calls execve has its capabilities modified for
the file ultimately being excecuted (i.e. the binary itself if that
binary is ELF or for the interpreter if the binary is a script.) [3] In
the capability evolution rules, for each mask Z, pZ represents the old
value and pZ' represents the new value. The rules are:
pP' = (X & fP) | (pI & fI)
pI' = pI
pE' = (fE ? pP' : 0)
X is unchanged
For setuid binaries, fP, fI, and fE are modified by a moderately
complicated set of rules that emulate POSIX behavior. Similarly, if
euid == 0 or ruid == 0, then fP, fI, and fE are modified differently
(primary, fP and fI usually end up being the full set). For nonroot
users executing binaries with neither setuid nor file caps, fI and fP
are empty and fE is false.
As an extra complication, if you execute a process as nonroot and fE is
set, then the "secure exec" rules are in effect: AT_SECURE gets set,
LD_PRELOAD doesn't work, etc.
This is rather messy. We've learned that making any changes is
dangerous, though: if a new kernel version allows an unprivileged
program to change its security state in a way that persists cross
execution of a setuid program or a program with file caps, this
persistent state is surprisingly likely to allow setuid or file-capped
programs to be exploited for privilege escalation.
===== The problem =====
Capability inheritance is basically useless.
If you aren't root and you execute an ordinary binary, fI is zero, so
your capabilities have no effect whatsoever on pP'. This means that you
can't usefully execute a helper process or a shell command with elevated
capabilities if you aren't root.
On current kernels, you can sort of work around this by setting fI to
the full set for most or all non-setuid executable files. This causes
pP' = pI for nonroot, and inheritance works. No one does this because
it's a PITA and it isn't even supported on most filesystems.
If you try this, you'll discover that every nonroot program ends up with
secure exec rules, breaking many things.
This is a problem that has bitten many people who have tried to use
capabilities for anything useful.
===== The proposed change =====
This patch adds a fifth capability mask called the ambient mask (pA).
pA does what most people expect pI to do.
pA obeys the invariant that no bit can ever be set in pA if it is not
set in both pP and pI. Dropping a bit from pP or pI drops that bit from
pA. This ensures that existing programs that try to drop capabilities
still do so, with a complication. Because capability inheritance is so
broken, setting KEEPCAPS, using setresuid to switch to nonroot uids, and
then calling execve effectively drops capabilities. Therefore,
setresuid from root to nonroot conditionally clears pA unless
SECBIT_NO_SETUID_FIXUP is set. Processes that don't like this can
re-add bits to pA afterwards.
The capability evolution rules are changed:
pA' = (file caps or setuid or setgid ? 0 : pA)
pP' = (X & fP) | (pI & fI) | pA'
pI' = pI
pE' = (fE ? pP' : pA')
X is unchanged
If you are nonroot but you have a capability, you can add it to pA. If
you do so, your children get that capability in pA, pP, and pE. For
example, you can set pA = CAP_NET_BIND_SERVICE, and your children can
automatically bind low-numbered ports. Hallelujah!
Unprivileged users can create user namespaces, map themselves to a
nonzero uid, and create both privileged (relative to their namespace)
and unprivileged process trees. This is currently more or less
impossible. Hallelujah!
You cannot use pA to try to subvert a setuid, setgid, or file-capped
program: if you execute any such program, pA gets cleared and the
resulting evolution rules are unchanged by this patch.
Users with nonzero pA are unlikely to unintentionally leak that
capability. If they run programs that try to drop privileges, dropping
privileges will still work.
It's worth noting that the degree of paranoia in this patch could
possibly be reduced without causing serious problems. Specifically, if
we allowed pA to persist across executing non-pA-aware setuid binaries
and across setresuid, then, naively, the only capabilities that could
leak as a result would be the capabilities in pA, and any attacker
*already* has those capabilities. This would make me nervous, though --
setuid binaries that tried to privilege-separate might fail to do so,
and putting CAP_DAC_READ_SEARCH or CAP_DAC_OVERRIDE into pA could have
unexpected side effects. (Whether these unexpected side effects would
be exploitable is an open question.) I've therefore taken the more
paranoid route. We can revisit this later.
An alternative would be to require PR_SET_NO_NEW_PRIVS before setting
ambient capabilities. I think that this would be annoying and would
make granting otherwise unprivileged users minor ambient capabilities
(CAP_NET_BIND_SERVICE or CAP_NET_RAW for example) much less useful than
it is with this patch.
===== Footnotes =====
[1] Files that are missing the "security.capability" xattr or that have
unrecognized values for that xattr end up with has_cap set to false.
The code that does that appears to be complicated for no good reason.
[2] The libcap capability mask parsers and formatters are dangerously
misleading and the documentation is flat-out wrong. fE is *not* a mask;
it's a single bit. This has probably confused every single person who
has tried to use file capabilities.
[3] Linux very confusingly processes both the script and the interpreter
if applicable, for reasons that elude me. The results from thinking
about a script's file capabilities and/or setuid bits are mostly
discarded.
Preliminary userspace code is here, but it needs updating:
https://git.kernel.org/cgit/linux/kernel/git/luto/util-linux-playground.git/commit/?h=cap_ambient&id=7f5afbd175d2
Here is a test program that can be used to verify the functionality
(from Christoph):
* Test program for the ambient capabilities. This program spawns a shell
* that allows running processes with a defined set of capabilities.
* (C) 2015 Christoph Lameter <cl@linux.com>
* Released under: GPL v3 or later.
* Compile using:
* gcc -o ambient_test ambient_test.o -lcap-ng
* This program must have the following capabilities to run properly:
* Permissions for CAP_NET_RAW, CAP_NET_ADMIN, CAP_SYS_NICE
* A command to equip the binary with the right caps is:
* setcap cap_net_raw,cap_net_admin,cap_sys_nice+p ambient_test
* To get a shell with additional caps that can be inherited by other processes:
* ./ambient_test /bin/bash
* Verifying that it works:
* From the bash spawed by ambient_test run
* cat /proc/$$/status
* and have a look at the capabilities.
#include <stdlib.h>
#include <stdio.h>
#include <errno.h>
#include <cap-ng.h>
#include <sys/prctl.h>
#include <linux/capability.h>
* Definitions from the kernel header files. These are going to be removed
* when the /usr/include files have these defined.
#define PR_CAP_AMBIENT 47
#define PR_CAP_AMBIENT_IS_SET 1
#define PR_CAP_AMBIENT_RAISE 2
#define PR_CAP_AMBIENT_LOWER 3
#define PR_CAP_AMBIENT_CLEAR_ALL 4
static void set_ambient_cap(int cap)
int rc;
capng_get_caps_process();
rc = capng_update(CAPNG_ADD, CAPNG_INHERITABLE, cap);
if (rc) {
printf("Cannot add inheritable cap\n");
exit(2);
capng_apply(CAPNG_SELECT_CAPS);
/* Note the two 0s at the end. Kernel checks for these */
if (prctl(PR_CAP_AMBIENT, PR_CAP_AMBIENT_RAISE, cap, 0, 0)) {
perror("Cannot set cap");
exit(1);
int main(int argc, char **argv)
int rc;
set_ambient_cap(CAP_NET_RAW);
set_ambient_cap(CAP_NET_ADMIN);
set_ambient_cap(CAP_SYS_NICE);
printf("Ambient_test forking shell\n");
if (execv(argv[1], argv + 1))
perror("Cannot exec");
return 0;
Signed-off-by: Christoph Lameter <cl@linux.com> # Original author
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Aaron Jones <aaronmdjones@gmail.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: Austin S Hemmelgarn <ahferroin7@gmail.com>
Cc: Markku Savela <msa@moth.iki.fi>
Cc: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: James Morris <james.l.morris@oracle.com>
Make the key matching functions pointed to by key_match_data::cmp return bool
rather than int.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Preparse the match data. This provides several advantages:
(1) The preparser can reject invalid criteria up front.
(2) The preparser can convert the criteria to binary data if necessary (the
asymmetric key type really wants to do binary comparison of the key IDs).
(3) The preparser can set the type of search to be performed. This means
that it's not then a one-off setting in the key type.
(4) The preparser can set an appropriate comparator function.
In order to create the integrity keyrings (eg. _evm, _ima), root's
uid and session keyrings need to be initialized early.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Define a __key_get() wrapper to use rather than atomic_inc() on the key usage
count as this makes it easier to hook in refcount error debugging.
Search functions pass around a bunch of arguments, each of which gets copied
with each call. Introduce a search context structure to hold these.
Whilst we're at it, create a search flag that indicates whether the search
should be directly to the description or whether it should iterate through all
keys looking for a non-description match.
This will be useful when keyrings use a generic data struct with generic
routines to manage their content as the search terms can just be passed
through to the iterator callback function.
Also, for future use, the data to be supplied to the match function is
separated from the description pointer in the search context. This makes it
clear which is being supplied.
Skip key state checks (invalidation, revocation and expiration) when checking
for possession. Without this, keys that have been marked invalid, revoked
keys and expired keys are not given a possession attribute - which means the
possessor is not granted any possession permits and cannot do anything with
them unless they also have one a user, group or other permit.
This causes failures in the keyutils test suite's revocation and expiration
tests now that commit 96b5c8fea6c0861621051290d705ec2e971963f1 reduced the
initial permissions granted to a key.
The failures are due to accesses to revoked and expired keys being given
EACCES instead of EKEYREVOKED or EKEYEXPIRED.
This fixes CVE-2013-1792.
There is a race in install_user_keyrings() that can cause a NULL pointer
dereference when called concurrently for the same user if the uid and
uid-session keyrings are not yet created. It might be possible for an
unprivileged user to trigger this by calling keyctl() from userspace in
parallel immediately after logging in.
Assume that we have two threads both executing lookup_user_key(), both
looking for KEY_SPEC_USER_SESSION_KEYRING.
THREAD A THREAD B
==>call install_user_keyrings();
if (!cred->user->session_keyring)
user->uid_keyring = uid_keyring;
if (user->uid_keyring)
return 0;
key = cred->user->session_keyring [== NULL]
user->session_keyring = session_keyring;
atomic_inc(&key->usage); [oops]
At the point thread A dereferences cred->user->session_keyring, thread B
hasn't updated user->session_keyring yet, but thread A assumes it is
populated because install_user_keyrings() returned ok.
The race window is really small but can be exploited if, for example,
thread B is interrupted or preempted after initializing uid_keyring, but
before doing setting session_keyring.
This couldn't be reproduced on a stock kernel. However, after placing
systemtap probe on 'user->session_keyring = session_keyring;' that
introduced some delay, the kernel could be crashed reliably.
Fix this by checking both pointers before deciding whether to return.
Alternatively, the test could be done away with entirely as it is checked
inside the mutex - but since the mutex is global, that may not be the best
way.
Reported-by: Mateusz Guzik <mguzik@redhat.com>
Cc: <stable@kernel.org>
Dave Jones <davej@redhat.com> writes:
> Just hit this on Linus' current tree.
> [ 89.621770] BUG: unable to handle kernel NULL pointer dereference at 00000000000000c8
> [ 89.623111] IP: [<ffffffff810784b0>] commit_creds+0x250/0x2f0
> [ 89.624062] PGD 122bfd067 PUD 122bfe067 PMD 0
> [ 89.624901] Oops: 0000 [#1] PREEMPT SMP
> [ 89.625678] Modules linked in: caif_socket caif netrom bridge hidp 8021q garp stp mrp rose llc2 af_rxrpc phonet af_key binfmt_misc bnep l2tp_ppp can_bcm l2tp_core pppoe pppox can_raw scsi_transport_iscsi ppp_generic slhc nfnetlink can ipt_ULOG ax25 decnet irda nfc rds x25 crc_ccitt appletalk atm ipx p8023 psnap p8022 llc lockd sunrpc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_conntrack nf_conntrack ip6table_filter ip6_tables btusb bluetooth snd_hda_codec_realtek snd_hda_intel snd_hda_codec snd_pcm vhost_net snd_page_alloc snd_timer tun macvtap usb_debug snd rfkill microcode macvlan edac_core pcspkr serio_raw kvm_amd soundcore kvm r8169 mii
> [ 89.637846] CPU 2
> [ 89.638175] Pid: 782, comm: trinity-main Not tainted 3.8.0+ #63 Gigabyte Technology Co., Ltd. GA-MA78GM-S2H/GA-MA78GM-S2H
> [ 89.639850] RIP: 0010:[<ffffffff810784b0>] [<ffffffff810784b0>] commit_creds+0x250/0x2f0
> [ 89.641161] RSP: 0018:ffff880115657eb8 EFLAGS: 00010207
> [ 89.641984] RAX: 00000000000003e8 RBX: ffff88012688b000 RCX: 0000000000000000
> [ 89.643069] RDX: 0000000000000000 RSI: ffffffff81c32960 RDI: ffff880105839600
> [ 89.644167] RBP: ffff880115657ed8 R08: 0000000000000000 R09: 0000000000000000
> [ 89.645254] R10: 0000000000000001 R11: 0000000000000246 R12: ffff880105839600
> [ 89.646340] R13: ffff88011beea490 R14: ffff88011beea490 R15: 0000000000000000
> [ 89.647431] FS: 00007f3ac063b740(0000) GS:ffff88012b200000(0000) knlGS:0000000000000000
> [ 89.648660] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
> [ 89.649548] CR2: 00000000000000c8 CR3: 0000000122bfc000 CR4: 00000000000007e0
> [ 89.650635] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
> [ 89.651723] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
> [ 89.652812] Process trinity-main (pid: 782, threadinfo ffff880115656000, task ffff88011beea490)
> [ 89.654128] Stack:
> [ 89.654433] 0000000000000000 ffff8801058396a0 ffff880105839600 ffff88011beeaa78
> [ 89.655769] ffff880115657ef8 ffffffff812c7d9b ffffffff82079be0 0000000000000000
> [ 89.657073] ffff880115657f28 ffffffff8106c665 0000000000000002 ffff880115657f58
> [ 89.658399] Call Trace:
> [ 89.658822] [<ffffffff812c7d9b>] key_change_session_keyring+0xfb/0x140
> [ 89.659845] [<ffffffff8106c665>] task_work_run+0xa5/0xd0
> [ 89.660698] [<ffffffff81002911>] do_notify_resume+0x71/0xb0
> [ 89.661581] [<ffffffff816c9a4a>] int_signal+0x12/0x17
> [ 89.662385] Code: 24 90 00 00 00 48 8b b3 90 00 00 00 49 8b 4c 24 40 48 39 f2 75 08 e9 83 00 00 00 48 89 ca 48 81 fa 60 29 c3 81 0f 84 41 fe ff ff <48> 8b 8a c8 00 00 00 48 39 ce 75 e4 3b 82 d0 00 00 00 0f 84 4b
> [ 89.667778] RIP [<ffffffff810784b0>] commit_creds+0x250/0x2f0
> [ 89.668733] RSP <ffff880115657eb8>
> [ 89.669301] CR2: 00000000000000c8
> My fastest trinity induced oops yet!
> Appears to be..
> if ((set_ns == subset_ns->parent) &&
> 850: 48 8b 8a c8 00 00 00 mov 0xc8(%rdx),%rcx
> from the inlined cred_cap_issubset
By historical accident we have been reading trying to set new->user_ns
from new->user_ns. Which is totally silly as new->user_ns is NULL (as
is every other field in new except session_keyring at that point).
The intent is clearly to copy all of the fields from old to new so copy
old->user_ns into into new->user_ns.
Cc: stable@vger.kernel.org
Reported-by: Dave Jones <davej@redhat.com>
Tested-by: Dave Jones <davej@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
A patch to fix some unreachable code in search_my_process_keyrings() got
applied twice by two different routes upstream as commits e67eab39bee2
and b010520ab3d2 (both "fix unreachable code").
Unfortunately, the second application removed something it shouldn't
have and this wasn't detected by GIT. This is due to the patch not
having sufficient lines of context to distinguish the two places of
application.
The effect of this is relatively minor: inside the kernel, the keyring
search routines may search multiple keyrings and then prioritise the
errors if no keys or negative keys are found in any of them. With the
extra deletion, the presence of a negative key in the thread keyring
(causing ENOKEY) is incorrectly overridden by an error searching the
process keyring.
So revert the second application of the patch.
Cc: Jiri Kosina <jkosina@suse.cz>
We set ret to NULL then test it. Remove the bogus test
Signed-off-by: Alan Cox <alan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"A quiet cycle for the security subsystem with just a few maintenance
updates."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
Smack: create a sysfs mount point for smackfs
Smack: use select not depends in Kconfig
Yama: remove locking from delete path
Yama: add RCU to drop read locking
drivers/char/tpm: remove tasklet and cleanup
KEYS: Use keyring_alloc() to create special keyrings
KEYS: Reduce initial permissions on keys
KEYS: Make the session and process keyrings per-thread
seccomp: Make syscall skipping and nr changes more consistent
key: Fix resource leak
keys: Fix unreachable code
KEYS: Add payload preparsing opportunity prior to key instantiate or update
Sync up with Linus' tree to be able to apply Cesar's patch
against newer version of the code.
Reduce the initial permissions on new keys to grant the possessor everything,
view permission only to the user (so the keys can be seen in /proc/keys) and
nothing else.
This gives the creator a chance to adjust the permissions mask before other
processes can access the new key or create a link to it.
To aid with this, keyring_alloc() now takes a permission argument rather than
setting the permissions itself.
The following permissions are now set:
(1) The user and user-session keyrings grant the user that owns them full
permissions and grant a possessor everything bar SETATTR.
(2) The process and thread keyrings grant the possessor full permissions but
only grant the user VIEW. This permits the user to see them in
/proc/keys, but not to do anything with them.
(3) Anonymous session keyrings grant the possessor full permissions, but only
grant the user VIEW and READ. This means that the user can see them in
/proc/keys and can list them, but nothing else. Possibly READ shouldn't
be provided either.
(4) Named session keyrings grant everything an anonymous session keyring does,
plus they grant the user LINK permission. The whole point of named
session keyrings is that others can also subscribe to them. Possibly this
should be a separate permission to LINK.
(5) The temporary session keyring created by call_sbin_request_key() gets the
same permissions as an anonymous session keyring.
(6) Keys created by add_key() get VIEW, SEARCH, LINK and SETATTR for the
possessor, plus READ and/or WRITE if the key type supports them. The used
only gets VIEW now.
(7) Keys created by request_key() now get the same as those created by
add_key().
Reported-by: Lennart Poettering <lennart@poettering.net>
Reported-by: Stef Walter <stefw@redhat.com>
Make the session keyring per-thread rather than per-process, but still
inherited from the parent thread to solve a problem with PAM and gdm.
The problem is that join_session_keyring() will reject attempts to change the
session keyring of a multithreaded program but gdm is now multithreaded before
it gets to the point of starting PAM and running pam_keyinit to create the
session keyring. See:
https://bugs.freedesktop.org/show_bug.cgi?id=49211
The reason that join_session_keyring() will only change the session keyring
under a single-threaded environment is that it's hard to alter the other
thread's credentials to effect the change in a multi-threaded program. The
problems are such as:
(1) How to prevent two threads both running join_session_keyring() from
racing.
(2) Another thread's credentials may not be modified directly by this process.
(3) The number of threads is uncertain whilst we're not holding the
appropriate spinlock, making preallocation slightly tricky.
(4) We could use TIF_NOTIFY_RESUME and key_replace_session_keyring() to get
another thread to replace its keyring, but that means preallocating for
each thread.
A reasonable way around this is to make the session keyring per-thread rather
than per-process and just document that if you want a common session keyring,
you must get it before you spawn any threads - which is the current situation
anyway.
Whilst we're at it, we can the process keyring behave in the same way. This
means we can clean up some of the ickyness in the creds code.
Basically, after this patch, the session, process and thread keyrings are about
inheritance rules only and not about sharing changes of keyring.
Reported-by: Mantas M. <grawity@gmail.com>
Tested-by: Ray Strode <rstrode@redhat.com>
- Replace key_user ->user_ns equality checks with kuid_has_mapping checks.
- Use from_kuid to generate key descriptions
- Use kuid_t and kgid_t and the associated helpers instead of uid_t and gid_t
- Avoid potential problems with file descriptor passing by displaying
keys in the user namespace of the opener of key status proc files.
Cc: linux-security-module@vger.kernel.org
Cc: keyrings@linux-nfs.org
task_work and rcu_head are identical now; merge them (calling the result
struct callback_head, rcu_head #define'd to it), kill separate allocation
in security/keys since we can just use cred->rcu now.
get rid of the only user of ->data; this is _not_ the final variant - in the
end we'll have task_work and rcu_head identical and just use cred->rcu,
at which point the separate allocation will be gone completely.
Change keyctl_session_to_parent() to use task_work_add() and move
key_replace_session_keyring() logic into task_work->func().
Note that we do task_work_cancel() before task_work_add() to ensure that
only one work can be pending at any time. This is important, we must not
allow user-space to abuse the parent's ->task_works list.
The callback, replace_session_keyring(), checks PF_EXITING. I guess this
is not really needed but looks better.
As a side effect, this fixes the (unlikely) race. The callers of
key_replace_session_keyring() and keyctl_session_to_parent() lack the
necessary barriers, the parent can miss the request.
Now we can remove task_struct->replacement_session_keyring and related
code.
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Alexander Gordeev <agordeev@redhat.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: David Smith <dsmith@redhat.com>
Cc: "Frank Ch. Eigler" <fche@redhat.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Tejun Heo <tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace enhancements from Eric Biederman:
"This is a course correction for the user namespace, so that we can
reach an inexpensive, maintainable, and reasonably complete
implementation.
Highlights:
- Config guards make it impossible to enable the user namespace and
code that has not been converted to be user namespace safe.
- Use of the new kuid_t type ensures the if you somehow get past the
config guards the kernel will encounter type errors if you enable
user namespaces and attempt to compile in code whose permission
checks have not been updated to be user namespace safe.
- All uids from child user namespaces are mapped into the initial
user namespace before they are processed. Removing the need to add
an additional check to see if the user namespace of the compared
uids remains the same.
- With the user namespaces compiled out the performance is as good or
better than it is today.
- For most operations absolutely nothing changes performance or
operationally with the user namespace enabled.
- The worst case performance I could come up with was timing 1
billion cache cold stat operations with the user namespace code
enabled. This went from 156s to 164s on my laptop (or 156ns to
164ns per stat operation).
- (uid_t)-1 and (gid_t)-1 are reserved as an internal error value.
Most uid/gid setting system calls treat these value specially
anyway so attempting to use -1 as a uid would likely cause
entertaining failures in userspace.
- If setuid is called with a uid that can not be mapped setuid fails.
I have looked at sendmail, login, ssh and every other program I
could think of that would call setuid and they all check for and
handle the case where setuid fails.
- If stat or a similar system call is called from a context in which
we can not map a uid we lie and return overflowuid. The LFS
experience suggests not lying and returning an error code might be
better, but the historical precedent with uids is different and I
can not think of anything that would break by lying about a uid we
can't map.
- Capabilities are localized to the current user namespace making it
safe to give the initial user in a user namespace all capabilities.
My git tree covers all of the modifications needed to convert the core
kernel and enough changes to make a system bootable to runlevel 1."
Fix up trivial conflicts due to nearby independent changes in fs/stat.c
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits)
userns: Silence silly gcc warning.
cred: use correct cred accessor with regards to rcu read lock
userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq
userns: Convert cgroup permission checks to use uid_eq
userns: Convert tmpfs to use kuid and kgid where appropriate
userns: Convert sysfs to use kgid/kuid where appropriate
userns: Convert sysctl permission checks to use kuid and kgids.
userns: Convert proc to use kuid/kgid where appropriate
userns: Convert ext4 to user kuid/kgid where appropriate
userns: Convert ext3 to use kuid/kgid where appropriate
userns: Convert ext2 to use kuid/kgid where appropriate.
userns: Convert devpts to use kuid/kgid where appropriate
userns: Convert binary formats to use kuid/kgid where appropriate
userns: Add negative depends on entries to avoid building code that is userns unsafe
userns: signal remove unnecessary map_cred_ns
userns: Teach inode_capable to understand inodes whose uids map to other namespaces.
userns: Fail exec for suid and sgid binaries with ids outside our user namespace.
userns: Convert stat to return values mapped from kuids and kgids
userns: Convert user specfied uids and gids in chown into kuids and kgid
userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs
Do an LRU discard in keyrings that are full rather than returning ENFILE. To
perform this, a time_t is added to the key struct and updated by the creation
of a link to a key and by a key being found as the result of a search. At the
completion of a successful search, the keyrings in the path between the root of
the search and the first found link to it also have their last-used times
updated.
Note that discarding a link to a key from a keyring does not necessarily
destroy the key as there may be references held by other places.
An alternate discard method that might suffice is to perform FIFO discard from
the keyring, using the spare 2-byte hole in the keylist header as the index of
the next link to be discarded.
This is useful when using a keyring as a cache for DNS results or foreign
filesystem IDs.
This can be tested by the following. As root do:
echo 1000 >/proc/sys/kernel/keys/root_maxkeys
kr=`keyctl newring foo @s`
for ((i=0; i<2000; i++)); do keyctl add user a$i a $kr; done
Without this patch ENFILE should be reported when the keyring fills up. With
this patch, the keyring discards keys in an LRU fashion. Note that the stored
LRU time has a granularity of 1s.
After doing this, /proc/key-users can be observed and should show that most of
the 2000 keys have been discarded:
[root@andromeda ~]# cat /proc/key-users
0: 517 516/516 513/1000 5249/20000
The "513/1000" here is the number of quota-accounted keys present for this user
out of the maximum permitted.
In /proc/keys, the keyring shows the number of keys it has and the number of
slots it has allocated:
[root@andromeda ~]# grep foo /proc/keys
200c64c4 I--Q-- 1 perm 3b3f0000 0 0 keyring foo: 509/509
The maximum is (PAGE_SIZE - header) / key pointer size. That's typically 509
on a 64-bit system and 1020 on a 32-bit system.
struct user_struct will shortly loose it's user_ns reference
so make the cred user_ns reference a proper reference complete
with reference counting.
Optimize performance and prepare for the removal of the user_ns reference
from user_struct. Remove the slow long walk through cred->user->user_ns and
instead go straight to cred->user_ns.
The test for "if (cred->request_key_auth->flags & KEY_FLAG_REVOKED) {"
should actually testing that the (1 << KEY_FLAG_REVOKED) bit is set.
The current code actually checks for KEY_FLAG_DEAD.
The keyctl call:
keyctl_get_keyring_ID(KEY_SPEC_SESSION_KEYRING, 1)
should create a session keyring if the process doesn't have one of its own
because the create flag argument is set - rather than subscribing to and
returning the user-session keyring as:
keyctl_get_keyring_ID(KEY_SPEC_SESSION_KEYRING, 0)
will do.
This can be tested by commenting out pam_keyinit in the /etc/pam.d files and
running the following program a couple of times in a row:
#include <stdio.h>
#include <stdlib.h>
int main(int argc, char *argv[])
key_serial_t uk, usk, sk, nsk;
uk = keyctl_get_keyring_ID(KEY_SPEC_USER_KEYRING, 0);
usk = keyctl_get_keyring_ID(KEY_SPEC_USER_SESSION_KEYRING, 0);
sk = keyctl_get_keyring_ID(KEY_SPEC_SESSION_KEYRING, 0);
nsk = keyctl_get_keyring_ID(KEY_SPEC_SESSION_KEYRING, 1);
printf("keys: %08x %08x %08x %08x\n", uk, usk, sk, nsk);
return 0;
Without this patch, I see:
keys: 3975ddc7 119c0c66 119c0c66 119c0c66
With this patch, I see:
keys: 2cb4997b 34112878 34112878 17db2ce3
keys: 2cb4997b 34112878 34112878 39f3c73e
As can be seen, the session keyring starts off the same as the user-session
keyring each time, but with the patch a new session keyring is created when
the create flag is set.
Reported-by: Greg Wettstein <greg@enjellic.com>
Tested-by: Greg Wettstein <greg@enjellic.com>
Signed-off-by: James Morris <jmorris@namei.org>
If install_session_keyring() is given a keyring, it should install it rather
than just creating a new one anyway. This was accidentally broken in:
commit d84f4f992cbd76e8f39c488cf0c5d123843923b1
Author: David Howells <dhowells@redhat.com>
Date: Fri Nov 14 10:39:23 2008 +1100
Subject: CRED: Inaugurate COW credentials
The impact of that commit is that pam_keyinit no longer works correctly if
'force' isn't specified against a login process. This is because:
now always creates a new session keyring and thus the check whether the session
keyring and the user-session keyring are the same is always false. This leads
pam_keyinit to conclude that a session keyring is installed and it shouldn't be
revoked by pam_keyinit here if 'revoke' is specified.
Any system that specifies 'force' against pam_keyinit in the PAM configuration
files for login methods (login, ssh, su -l, kdm, etc.) is not affected since
that bypasses the broken check and forces the creation of a new session keyring
anyway (for which the revoke flag is not cleared) - and any subsequent call to
pam_keyinit really does have a session keyring already installed, and so the
check works correctly there.
Reverting to the previous behaviour will cause the kernel to subscribe the
process to the user-session keyring as its session keyring if it doesn't have a
session keyring of its own. pam_keyinit will detect this and install a new
session keyring anyway (and won't clear the revert flag).
#include <stdio.h>
#include <stdlib.h>
key_serial_t uk, usk, sk;
printf("keys: %08x %08x %08x\n", uk, usk, sk);
return 0;
Without the patch, I see:
keys: 3884e281 24c4dfcf 22825f8e
keys: 3884e281 24c4dfcf 068772be
With the patch, I see:
keys: 26be9c83 0e755ce0 0e755ce0
As can be seen, with the patch, the session keyring is the same as the
user-session keyring each time; without the patch a new session keyring is
generated each time.
Since this cred was not created with copy_creds(), it needs to get
initialized. Otherwise use of syscall(__NR_keyctl, KEYCTL_SESSION_TO_PARENT);
can lead to a NULL deref. Thanks to Robert for finding this.
But introduced by commit 47a150edc2a ("Cache user_ns in struct cred").
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Reported-by: Robert Święcki <robert@swiecki.net>
Cc: stable@kernel.org (2.6.39)
Improve /proc/keys by:
(1) Don't attempt to summarise the payload of a negated key. It won't have
one. To this end, a helper function - key_is_instantiated() has been
added that allows the caller to find out whether the key is positively
instantiated (as opposed to being uninstantiated or negatively
instantiated).
(2) Do show keys that are negative, expired or revoked rather than hiding
them. This requires an override flag (no_state_check) to be passed to
search_my_process_keyrings() and keyring_search_aux() to suppress this
check.
Without this, keys that are possessed by the caller, but only grant
permissions to the caller if possessed are skipped as the possession check
fails.
Keys that are visible due to user, group or other checks are visible with
or without this patch.
Fix up comments in the key management code. No functional changes.
Do a bit of a style clean up in the key management code. No functional
changes.
Done using:
perl -p -i -e 's!^/[*]*/\n!!' security/keys/*.c
perl -p -i -e 's!} /[*] end [a-z0-9_]*[(][)] [*]/\n!}\n!' security/keys/*.c
sed -i -s -e ": next" -e N -e 's/^\n[}]$/}/' -e t -e P -e 's/^.*\n//' -e "b next" security/keys/*.c
To remove /*****/ lines, remove comments on the closing brace of a
function to name the function and remove blank lines before the closing
brace of a function.
Fix an incorrect error check that returns 1 for error instead of the
expected error code.
Make /proc/keys check to see if the calling process possesses each key before
performing the security check. The possession check can be skipped if the key
doesn't have the possessor-view permission bit set.
This causes the keys a process possesses to show up in /proc/keys, even if they
don't have matching user/group/other view permissions.
call_usermodehelper_keys() uses call_usermodehelper_setkeys() to change
subprocess_info->cred in advance. Now that we have info->init() we can
change this code to set tgcred->session_keyring in context of execing
kernel thread.
Note: since currently call_usermodehelper_keys() is never called with
UMH_NO_WAIT, call_usermodehelper_keys()->key_get() and umh_keys_cleanup()
are not really needed, we could rely on install_session_keyring_to_cred()
which does key_get() on success.
We were using the wrong variable here so the error codes weren't being returned
properly. The original code returns -ENOKEY.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Add a keyctl to install a process's session keyring onto its parent. This
replaces the parent's session keyring. Because the COW credential code does
not permit one process to change another process's credentials directly, the
change is deferred until userspace next starts executing again. Normally this
will be after a wait*() syscall.
To support this, three new security hooks have been provided:
cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in
the blank security creds and key_session_to_parent() - which asks the LSM if
the process may replace its parent's session keyring.
The replacement may only happen if the process has the same ownership details
as its parent, and the process has LINK permission on the session keyring, and
the session keyring is owned by the process, and the LSM permits it.
Note that this requires alteration to each architecture's notify_resume path.
This has been done for all arches barring blackfin, m68k* and xtensa, all of
which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the
replacement to be performed at the point the parent process resumes userspace
execution.
This allows the userspace AFS pioctl emulation to fully emulate newpag() and
the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to
alter the parent process's PAG membership. However, since kAFS doesn't use
PAGs per se, but rather dumps the keys into the session keyring, the session
keyring of the parent must be replaced if, for example, VIOCSETTOK is passed
the newpag flag.
#include <stdio.h>
#include <stdlib.h>
#define KEYCTL_SESSION_TO_PARENT 18
#define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0)
key_serial_t keyring, key;
long ret;
keyring = keyctl_join_session_keyring(argv[1]);
OSERROR(keyring, "keyctl_join_session_keyring");
key = add_key("user", "a", "b", 1, keyring);
OSERROR(key, "add_key");
ret = keyctl(KEYCTL_SESSION_TO_PARENT);
OSERROR(ret, "KEYCTL_SESSION_TO_PARENT");
return 0;
Compiled and linked with -lkeyutils, you should see something like:
[dhowells@andromeda ~]$ keyctl show
Session Keyring
-3 --alswrv 4043 4043 keyring: _ses
355907932 --alswrv 4043 -1 \_ keyring: _uid.4043
[dhowells@andromeda ~]$ /tmp/newpag
Session Keyring
1055658746 --alswrv 4043 4043 \_ user: a
[dhowells@andromeda ~]$ /tmp/newpag hello
Session Keyring
-3 --alswrv 4043 4043 keyring: hello
340417692 --alswrv 4043 4043 \_ user: a
Where the test program creates a new session keyring, sticks a user key named
'a' into it and then installs it on its parent.
Allow keys for which the key type has been removed to be unlinked. Currently
dead-type keys can only be disposed of by completely clearing the keyrings
that point to them.
Acked-by: Serge Hallyn <serue@us.ibm.com>
- is_single_threaded(task) is not safe unless task == current,
we can't use task->signal or task->mm.
- it doesn't make sense unless task == current, the task can
fork right after the check.
Rename it to current_is_single_threaded() and kill the argument.
per-uid keys were looked by uid only. Use the user namespace
to distinguish the same uid in different namespaces.
This does not address key_permission. So a task can for instance
try to join a keyring owned by the same uid in another namespace.
That will be handled by a separate patch.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Make execve() take advantage of copy-on-write credentials, allowing it to set
up the credentials in advance, and then commit the whole lot after the point
of no return.
This patch and the preceding patches have been tested with the LTP SELinux
testsuite.
This patch makes several logical sets of alteration:
(1) execve().
The credential bits from struct linux_binprm are, for the most part,
replaced with a single credentials pointer (bprm->cred). This means that
all the creds can be calculated in advance and then applied at the point
of no return with no possibility of failure.
I would like to replace bprm->cap_effective with:
cap_isclear(bprm->cap_effective)
but this seems impossible due to special behaviour for processes of pid 1
(they always retain their parent's capability masks where normally they'd
be changed - see cap_bprm_set_creds()).
The following sequence of events now happens:
(a) At the start of do_execve, the current task's cred_exec_mutex is
locked to prevent PTRACE_ATTACH from obsoleting the calculation of
creds that we make.
(a) prepare_exec_creds() is then called to make a copy of the current
task's credentials and prepare it. This copy is then assigned to
bprm->cred.
This renders security_bprm_alloc() and security_bprm_free()
unnecessary, and so they've been removed.
(b) The determination of unsafe execution is now performed immediately
after (a) rather than later on in the code. The result is stored in
bprm->unsafe for future reference.
(c) prepare_binprm() is called, possibly multiple times.
(i) This applies the result of set[ug]id binaries to the new creds
attached to bprm->cred. Personality bit clearance is recorded,
but now deferred on the basis that the exec procedure may yet
fail.
(ii) This then calls the new security_bprm_set_creds(). This should
calculate the new LSM and capability credentials into *bprm->cred.
This folds together security_bprm_set() and parts of
security_bprm_apply_creds() (these two have been removed).
Anything that might fail must be done at this point.
(iii) bprm->cred_prepared is set to 1.
bprm->cred_prepared is 0 on the first pass of the security
calculations, and 1 on all subsequent passes. This allows SELinux
in (ii) to base its calculations only on the initial script and
not on the interpreter.
(d) flush_old_exec() is called to commit the task to execution. This
performs the following steps with regard to credentials:
(i) Clear pdeath_signal and set dumpable on certain circumstances that
may not be covered by commit_creds().
(ii) Clear any bits in current->personality that were deferred from
(c.i).
(e) install_exec_creds() [compute_creds() as was] is called to install the
new credentials. This performs the following steps with regard to
credentials:
(i) Calls security_bprm_committing_creds() to apply any security
requirements, such as flushing unauthorised files in SELinux, that
must be done before the credentials are changed.
This is made up of bits of security_bprm_apply_creds() and
security_bprm_post_apply_creds(), both of which have been removed.
This function is not allowed to fail; anything that might fail
must have been done in (c.ii).
(ii) Calls commit_creds() to apply the new credentials in a single
assignment (more or less). Possibly pdeath_signal and dumpable
should be part of struct creds.
(iii) Unlocks the task's cred_replace_mutex, thus allowing
PTRACE_ATTACH to take place.
(iv) Clears The bprm->cred pointer as the credentials it was holding
are now immutable.
(v) Calls security_bprm_committed_creds() to apply any security
alterations that must be done after the creds have been changed.
SELinux uses this to flush signals and signal handlers.
(f) If an error occurs before (d.i), bprm_free() will call abort_creds()
to destroy the proposed new credentials and will then unlock
cred_replace_mutex. No changes to the credentials will have been
made.
(2) LSM interface.
A number of functions have been changed, added or removed:
(*) security_bprm_alloc(), ->bprm_alloc_security()
(*) security_bprm_free(), ->bprm_free_security()
Removed in favour of preparing new credentials and modifying those.
(*) security_bprm_apply_creds(), ->bprm_apply_creds()
(*) security_bprm_post_apply_creds(), ->bprm_post_apply_creds()
Removed; split between security_bprm_set_creds(),
security_bprm_committing_creds() and security_bprm_committed_creds().
(*) security_bprm_set(), ->bprm_set_security()
Removed; folded into security_bprm_set_creds().
(*) security_bprm_set_creds(), ->bprm_set_creds()
New. The new credentials in bprm->creds should be checked and set up
as appropriate. bprm->cred_prepared is 0 on the first call, 1 on the
second and subsequent calls.
(*) security_bprm_committing_creds(), ->bprm_committing_creds()
(*) security_bprm_committed_creds(), ->bprm_committed_creds()
New. Apply the security effects of the new credentials. This
includes closing unauthorised files in SELinux. This function may not
fail. When the former is called, the creds haven't yet been applied
to the process; when the latter is called, they have.
The former may access bprm->cred, the latter may not.
(3) SELinux.
SELinux has a number of changes, in addition to those to support the LSM
interface changes mentioned above:
(a) The bprm_security_struct struct has been removed in favour of using
the credentials-under-construction approach.
(c) flush_unauthorized_files() now takes a cred pointer and passes it on
to inode_has_perm(), file_has_perm() and dentry_open().
Acked-by: James Morris <jmorris@namei.org>
Inaugurate copy-on-write credentials management. This uses RCU to manage the
credentials pointer in the task_struct with respect to accesses by other tasks.
A process may only modify its own credentials, and so does not need locking to
access or modify its own credentials.
A mutex (cred_replace_mutex) is added to the task_struct to control the effect
of PTRACE_ATTACHED on credential calculations, particularly with respect to
execve().
With this patch, the contents of an active credentials struct may not be
changed directly; rather a new set of credentials must be prepared, modified
and committed using something like the following sequence of events:
struct cred *new = prepare_creds();
int ret = blah(new);
if (ret < 0) {
abort_creds(new);
return ret;
return commit_creds(new);
There are some exceptions to this rule: the keyrings pointed to by the active
credentials may be instantiated - keyrings violate the COW rule as managing
COW keyrings is tricky, given that it is possible for a task to directly alter
the keys in a keyring in use by another task.
To help enforce this, various pointers to sets of credentials, such as those in
the task_struct, are declared const. The purpose of this is compile-time
discouragement of altering credentials through those pointers. Once a set of
credentials has been made public through one of these pointers, it may not be
modified, except under special circumstances:
(1) Its reference count may incremented and decremented.
(2) The keyrings to which it points may be modified, but not replaced.
The only safe way to modify anything else is to create a replacement and commit
using the functions described in Documentation/credentials.txt (which will be
added by a later patch).
testsuite.
(1) execve().
This now prepares and commits credentials in various places in the
security code rather than altering the current creds directly.
(2) Temporary credential overrides.
do_coredump() and sys_faccessat() now prepare their own credentials and
temporarily override the ones currently on the acting thread, whilst
preventing interference from other threads by holding cred_replace_mutex
on the thread being dumped.
This will be replaced in a future patch by something that hands down the
credentials directly to the functions being called, rather than altering
the task's objective credentials.
(3) LSM interface.
(*) security_capset_check(), ->capset_check()
(*) security_capset_set(), ->capset_set()
Removed in favour of security_capset().
(*) security_capset(), ->capset()
New. This is passed a pointer to the new creds, a pointer to the old
creds and the proposed capability sets. It should fill in the new
creds or return an error. All pointers, barring the pointer to the
new creds, are now const.
Changed; now returns a value, which will cause the process to be
killed if it's an error.
(*) security_task_alloc(), ->task_alloc_security()
Removed in favour of security_prepare_creds().
(*) security_cred_free(), ->cred_free()
New. Free security data attached to cred->security.
(*) security_prepare_creds(), ->cred_prepare()
New. Duplicate any security data attached to cred->security.
(*) security_commit_creds(), ->cred_commit()
New. Apply any security effects for the upcoming installation of new
security by commit_creds().
(*) security_task_post_setuid(), ->task_post_setuid()
Removed in favour of security_task_fix_setuid().
(*) security_task_fix_setuid(), ->task_fix_setuid()
Fix up the proposed new credentials for setuid(). This is used by
cap_set_fix_setuid() to implicitly adjust capabilities in line with
setuid() changes. Changes are made to the new credentials, rather
than the task itself as in security_task_post_setuid().
(*) security_task_reparent_to_init(), ->task_reparent_to_init()
Removed. Instead the task being reparented to init is referred
directly to init's credentials.
NOTE! This results in the loss of some state: SELinux's osid no
longer records the sid of the thread that forked it.
(*) security_key_alloc(), ->key_alloc()
(*) security_key_permission(), ->key_permission()
Changed. These now take cred pointers rather than task pointers to
refer to the security context.
(4) sys_capset().
This has been simplified and uses less locking. The LSM functions it
calls have been merged.
(5) reparent_to_kthreadd().
This gives the current thread the same credentials as init by simply using
commit_thread() to point that way.
(6) __sigqueue_alloc() and switch_uid()
__sigqueue_alloc() can't stop the target task from changing its creds
beneath it, so this function gets a reference to the currently applicable
user_struct which it then passes into the sigqueue struct it returns if
successful.
switch_uid() is now called from commit_creds(), and possibly should be
folded into that. commit_creds() should take care of protecting
__sigqueue_alloc().
(7) [sg]et[ug]id() and co and [sg]et_current_groups.
The set functions now all use prepare_creds(), commit_creds() and
abort_creds() to build and check a new set of credentials before applying
it.
security_task_set[ug]id() is called inside the prepared section. This
guarantees that nothing else will affect the creds until we've finished.
The calling of set_dumpable() has been moved into commit_creds().
Much of the functionality of set_user() has been moved into
commit_creds().
The get functions all simply access the data directly.
(8) security_task_prctl() and cap_task_prctl().
security_task_prctl() has been modified to return -ENOSYS if it doesn't
want to handle a function, or otherwise return the return value directly
rather than through an argument.
Additionally, cap_task_prctl() now prepares a new set of credentials, even
if it doesn't end up using it.
(9) Keyrings.
A number of changes have been made to the keyrings code:
(a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have
all been dropped and built in to the credentials functions directly.
They may want separating out again later.
(b) key_alloc() and search_process_keyrings() now take a cred pointer
rather than a task pointer to specify the security context.
(c) copy_creds() gives a new thread within the same thread group a new
thread keyring if its parent had one, otherwise it discards the thread
keyring.
(d) The authorisation key now points directly to the credentials to extend
the search into rather pointing to the task that carries them.
(e) Installing thread, process or session keyrings causes a new set of
credentials to be created, even though it's not strictly necessary for
process or session keyrings (they're shared).
(10) Usermode helper.
The usermode helper code now carries a cred struct pointer in its
subprocess_info struct instead of a new session keyring pointer. This set
of credentials is derived from init_cred and installed on the new process
after it has been cloned.
call_usermodehelper_setup() allocates the new credentials and
call_usermodehelper_freeinfo() discards them if they haven't been used. A
special cred function (prepare_usermodeinfo_creds()) is provided
specifically for call_usermodehelper_setup() to call.
call_usermodehelper_setkeys() adjusts the credentials to sport the
supplied keyring as the new session keyring.
(11) SELinux.
(a) selinux_setprocattr() no longer does its check for whether the
current ptracer can access processes with the new SID inside the lock
that covers getting the ptracer's SID. Whilst this lock ensures that
the check is done with the ptracer pinned, the result is only valid
until the lock is released, so there's no point doing it inside the
lock.
(12) is_single_threaded().
This function has been extracted from selinux_setprocattr() and put into
a file of its own in the lib/ directory as join_session_keyring() now
wants to use it too.
The code in SELinux just checked to see whether a task shared mm_structs
with other tasks (CLONE_VM), but that isn't good enough. We really want
to know if they're part of the same thread group (CLONE_THREAD).
(13) nfsd.
The NFS server daemon now has to use the COW credentials to set the
credentials it is going to use. It really needs to pass the credentials
down to the functions it calls, but it can't do that until other patches
in this series have been applied.
Separate per-task-group keyrings from signal_struct and dangle their anchor
from the cred struct rather than the signal_struct.
Reviewed-by: James Morris <jmorris@namei.org>
