path: root/security/keys/trusted.c
2011-05-19Create Documentation/security/,Randy Dunlap
move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
2011-03-08KEYS: Add an RCU payload dereference macroDavid Howells
Add an RCU payload dereference macro as this seems to be a common piece of code amongst key types that use RCU referenced payloads. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-24trusted keys: Fix a memory leak in trusted_update().Jesper Juhl
One failure path in security/keys/trusted.c::trusted_update() does not free 'new_p' while the others do. This patch makes sure we also free it in the remaining path (if datablob_parse() returns different from Opt_update). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-24trusted-keys: rename trusted_defined files to trustedMimi Zohar
Rename trusted_defined.c and trusted_defined.h files to trusted.c and trusted.h, respectively. Based on request from David Howells. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
