commit 9f35a33b8d06263a165efe3541d9aa0cdbd70b3b upstream.
Fix a NULL pointer deref in the user-defined key type whereby updating a
negative key into a fully instantiated key will cause an oops to occur
when the code attempts to free the non-existent old payload.
This results in an oops that looks something like the following:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
PGD 3391d067 PUD 3894a067 PMD 0
Oops: 0002 [#1] SMP
CPU 1
Pid: 4354, comm: keyctl Not tainted 3.1.0-fsdevel+ #1140 /DG965RY
RIP: 0010:[<ffffffff81085fa1>] [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
RSP: 0018:ffff88003d591df8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000006e
RDX: ffffffff8161d0c0 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88003d591e18 R08: 0000000000000000 R09: ffffffff8152fa6c
R10: 0000000000000000 R11: 0000000000000300 R12: ffff88003b8f9538
R13: ffffffff8161d0c0 R14: ffff88003b8f9d50 R15: ffff88003c69f908
FS: 00007f97eb18c720(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CR2: 0000000000000008 CR3: 000000003d47a000 CR4: 00000000000006e0
Process keyctl (pid: 4354, threadinfo ffff88003d590000, task ffff88003c78a040)
Stack:
ffff88003e0ffde0 ffff88003b8f9538 0000000000000001 ffff88003b8f9d50
ffff88003d591e28 ffffffff810860f0 ffff88003d591e68 ffffffff8117bfea
ffff88003d591e68 ffffffff00000000 ffff88003e0ffde1 ffff88003e0ffde0
Call Trace:
[<ffffffff810860f0>] call_rcu_sched+0x10/0x12
[<ffffffff8117bfea>] user_update+0x8d/0xa2
[<ffffffff8117723a>] key_create_or_update+0x236/0x270
[<ffffffff811789b1>] sys_add_key+0x123/0x17e
[<ffffffff813b84bb>] system_call_fastpath+0x16/0x1b
Acked-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Neil Horman <nhorman@redhat.com>
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: James Morris <jmorris@namei.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits)
tpm_nsc: Fix bug when loading multiple TPM drivers
tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block
tpm: Fix compilation warning when CONFIG_PNP is not defined
TOMOYO: Update kernel-doc.
tpm: Fix a typo
tpm_tis: Probing function for Intel iTPM bug
tpm_tis: Fix the probing for interrupts
tpm_tis: Delay ACPI S3 suspend while the TPM is busy
tpm_tis: Re-enable interrupts upon (S3) resume
tpm: Fix display of data in pubek sysfs entry
tpm_tis: Add timeouts sysfs entry
tpm: Adjust interface timeouts if they are too small
tpm: Use interface timeouts returned from the TPM
tpm_tis: Introduce durations sysfs entry
tpm: Adjust the durations if they are too small
tpm: Use durations returned from TPM
TOMOYO: Enable conditional ACL.
TOMOYO: Allow using argv[]/envp[] of execve() as conditions.
TOMOYO: Allow using executable's realpath and symlink's target as conditions.
TOMOYO: Allow using owner/group etc. of file objects as conditions.
Fix up trivial conflict in security/tomoyo/realpath.c
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Since ca5ecddf (rcu: define __rcu address space modifier for sparse)
rcu_dereference_check use rcu_read_lock_held as a part of condition
automatically so callers do not have to do that as well.
The 'encrypted' key type defines its own payload format which contains a
symmetric key randomly generated that cannot be used directly to mount
an eCryptfs filesystem, because it expects an authentication token
structure.
This patch introduces the new format 'ecryptfs' that allows to store an
authentication token structure inside the encrypted key payload containing
a randomly generated symmetric key, as the same for the format 'default'.
More details about the usage of encrypted keys with the eCryptfs
filesystem can be found in the file 'Documentation/keys-ecryptfs.txt'.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Acked-by: Gianluca Ramunno <ramunno@polito.it>
Acked-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
This patch introduces a new parameter, called 'format', that defines the
format of data stored by encrypted keys. The 'default' format identifies
encrypted keys containing only the symmetric key, while other formats can
be defined to support additional information. The 'format' parameter is
written in the datablob produced by commands 'keyctl print' or
'keyctl pipe' and is integrity protected by the HMAC.
Some debug messages have been added in the function datablob_parse() in
order to better identify errors returned when dealing with 'encrypted'
keys.
Changelog from version v4:
- made the debug messages more understandable
Valid key type prefixes for the parameter 'key-type' are: 'trusted' and
'user'.
Do not dump the master key if an error is encountered during the request.
Fix error handling in construct_key_and_link().
If construct_alloc_key() returns an error, it shouldn't pass out through
the normal path as the key_serial() called by the kleave() statement
will oops when it gets an error code in the pointer:
BUG: unable to handle kernel paging request at ffffffffffffff84
IP: [<ffffffff8120b401>] request_key_and_link+0x4d7/0x52f
Call Trace:
[<ffffffff8120b52c>] request_key+0x41/0x75
[<ffffffffa00ed6e8>] cifs_get_spnego_key+0x206/0x226 [cifs]
[<ffffffffa00eb0c9>] CIFS_SessSetup+0x511/0x1234 [cifs]
[<ffffffffa00d9799>] cifs_setup_session+0x90/0x1ae [cifs]
[<ffffffffa00d9c02>] cifs_get_smb_ses+0x34b/0x40f [cifs]
[<ffffffffa00d9e05>] cifs_mount+0x13f/0x504 [cifs]
[<ffffffffa00caabb>] cifs_do_mount+0xc4/0x672 [cifs]
[<ffffffff8113ae8c>] mount_fs+0x69/0x155
[<ffffffff8114ff0e>] vfs_kern_mount+0x63/0xa0
[<ffffffff81150be2>] do_kern_mount+0x4d/0xdf
[<ffffffff81152278>] do_mount+0x63c/0x69f
[<ffffffff8115255c>] sys_mount+0x88/0xc2
[<ffffffff814fbdc2>] system_call_fastpath+0x16/0x1b
____call_usermodehelper() now erases any credentials set by the
subprocess_inf::init() function. The problem is that commit
17f60a7da150 ("capabilites: allow the application of capability limits
to usermode helpers") creates and commits new credentials with
prepare_kernel_cred() after the call to the init() function. This wipes
all keyrings after umh_keys_init() is called.
The best way to deal with this is to put the init() call just prior to
the commit_creds() call, and pass the cred pointer to init(). That
means that umh_keys_init() and suchlike can modify the credentials
_before_ they are published and potentially in use by the rest of the
system.
This prevents request_key() from working as it is prevented from passing
the session keyring it set up with the authorisation token to
/sbin/request-key, and so the latter can't assume the authority to
instantiate the key. This causes the in-kernel DNS resolver to fail
with ENOKEY unconditionally.
Acked-by: Eric Paris <eparis@redhat.com>
Tested-by: Jeff Layton <jlayton@redhat.com>
Don't return EAGAIN to keyctl_assume_authority() to indicate that a key could
not be found (ENOKEY is only returned if a negative key is found). Instead
return ENOKEY in both cases.
Signed-off-by: James Morris <jmorris@namei.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs
* 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs:
Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
Since this cred was not created with copy_creds(), it needs to get
initialized. Otherwise use of syscall(__NR_keyctl, KEYCTL_SESSION_TO_PARENT);
can lead to a NULL deref. Thanks to Robert for finding this.
But introduced by commit 47a150edc2a ("Cache user_ns in struct cred").
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Reported-by: Robert Święcki <robert@swiecki.net>
Cc: stable@kernel.org (2.6.39)
The rcu callback user_update_rcu_disposal() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(user_update_rcu_disposal).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Make request_key() and co. return an error for a negative or rejected key. If
the key was simply negated, then return ENOKEY, otherwise return the error
with which it was rejected.
Without this patch, the following command returns a key number (with the latest
keyutils):
[root@andromeda ~]# keyctl request2 user debug:foo rejected @s
586569904
Trying to print the key merely gets you a permission denied error:
[root@andromeda ~]# keyctl print 586569904
keyctl_read_alloc: Permission denied
Doing another request_key() call does get you the error, as long as it hasn't
expired yet:
[root@andromeda ~]# keyctl request user debug:foo
request_key: Key was rejected by service
Improve /proc/keys by:
(1) Don't attempt to summarise the payload of a negated key. It won't have
one. To this end, a helper function - key_is_instantiated() has been
added that allows the caller to find out whether the key is positively
instantiated (as opposed to being uninstantiated or negatively
instantiated).
(2) Do show keys that are negative, expired or revoked rather than hiding
them. This requires an override flag (no_state_check) to be passed to
search_my_process_keyrings() and keyring_search_aux() to suppress this
check.
Without this, keys that are possessed by the caller, but only grant
permissions to the caller if possessed are skipped as the possession check
fails.
Keys that are visible due to user, group or other checks are visible with
or without this patch.
Add a keyctl op (KEYCTL_INSTANTIATE_IOV) that is like KEYCTL_INSTANTIATE, but
takes an iovec array and concatenates the data in-kernel into one buffer.
Since the KEYCTL_INSTANTIATE copies the data anyway, this isn't too much of a
problem.
Add a new keyctl op to reject a key with a specified error code. This works
much the same as negating a key, and so keyctl_negate_key() is made a special
case of keyctl_reject_key(). The difference is that keyctl_negate_key()
selects ENOKEY as the error to be reported.
Typically the key would be rejected with EKEYEXPIRED, EKEYREVOKED or
EKEYREJECTED, but this is not mandatory.
Add a key type operation to permit the key type to vet the description of a new
key that key_alloc() is about to allocate. The operation may reject the
description if it wishes with an error of its choosing. If it does this, the
key will not be allocated.
Reviewed-by: Mimi Zohar <zohar@us.ibm.com>
Add an RCU payload dereference macro as this seems to be a common piece of code
amongst key types that use RCU referenced payloads.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Fix __key_link_end()'s attempt to fix up the quota if an error occurs.
There are two erroneous cases: Firstly, we always decrease the quota if
the preallocated replacement keyring needs cleaning up, irrespective of
whether or not we should (we may have replaced a pointer rather than
adding another pointer).
Secondly, we never clean up the quota if we added a pointer without the
keyring storage being extended (we allocate multiple pointers at a time,
even if we're not going to use them all immediately).
We handle this by setting the bottom bit of the preallocation pointer in
__key_link_begin() to indicate that the quota needs fixing up, which is
then passed to __key_link() (which clears the whole thing) and
__key_link_end().
One failure path in security/keys/trusted.c::trusted_update() does
not free 'new_p' while the others do. This patch makes sure we also free
it in the remaining path (if datablob_parse() returns different from
Opt_update).
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Rename encrypted_defined.c and encrypted_defined.h files to encrypted.c and
encrypted.h, respectively. Based on request from David Howells.
Rename trusted_defined.c and trusted_defined.h files to trusted.c and
trusted.h, respectively. Based on request from David Howells.
Fix up comments in the key management code. No functional changes.
Do a bit of a style clean up in the key management code. No functional
changes.
Done using:
perl -p -i -e 's!^/[*]*/\n!!' security/keys/*.c
perl -p -i -e 's!} /[*] end [a-z0-9_]*[(][)] [*]/\n!}\n!' security/keys/*.c
sed -i -s -e ": next" -e N -e 's/^\n[}]$/}/' -e t -e P -e 's/^.*\n//' -e "b next" security/keys/*.c
To remove /*****/ lines, remove comments on the closing brace of a
function to name the function and remove blank lines before the closing
brace of a function.
We can avoid scattering va_end() within the
va_start();
for (;;) {
va_end();
loop, assuming that crypto_shash_init()/crypto_shash_update() return 0 on
success and negative value otherwise.
Make TSS_authhmac()/TSS_checkhmac1()/TSS_checkhmac2() similar to TSS_rawhmac()
by removing "va_end()/goto" from the loop.
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Mimi Zohar <zohar@us.ibm.com>
TSS_rawhmac() checks for data != NULL before using it.
We should do the same thing for TSS_authhmac().
TSS_rawhmac() forgot to call va_end()/kfree() when data == NULL and
forgot to call va_end() when crypto_shash_update() < 0.
Fix these bugs by escaping from the loop using "break"
(rather than "return"/"goto") in order to make sure that
va_end()/kfree() are always called.
Add missing kfree(td) in tpm_seal() before the return, freeing
td on error paths as well.
Reported-by: Dan Carpenter <error27@gmail.com>
Acked-by: David Safford <safford@watson.ibm.com>
Signed-off-by: Serge Hallyn <serge@hallyn.com>
security/smack/smack_lsm.c
Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au>
Ok'd by Casey Schaufler <casey@schaufler-ca.com>
In construct_alloc_key(), up_write() is called in the error path if
__key_link_begin() fails, but this is incorrect as __key_link_begin() only
returns with the nominated keyring locked if it returns successfully.
Without this patch, you might see the following in dmesg:
[ BUG: bad unlock balance detected! ]
mount.cifs/5769 is trying to release lock (&key->sem) at:
[<ffffffff81201159>] request_key_and_link+0x263/0x3fc
but there are no more locks to release!
3 locks held by mount.cifs/5769:
#0: (&type->s_umount_key#41/1){+.+.+.}, at: [<ffffffff81131321>] sget+0x278/0x3e7
#1: (&ret_buf->session_mutex){+.+.+.}, at: [<ffffffffa0258e59>] cifs_get_smb_ses+0x35a/0x443 [cifs]
#2: (root_key_user.cons_lock){+.+.+.}, at: [<ffffffff81201000>] request_key_and_link+0x10a/0x3fc
stack backtrace:
Pid: 5769, comm: mount.cifs Not tainted 2.6.37-rc6+ #1
Call Trace:
[<ffffffff81201159>] ? request_key_and_link+0x263/0x3fc
[<ffffffff81081601>] print_unlock_inbalance_bug+0xca/0xd5
[<ffffffff81083248>] lock_release_non_nested+0xc1/0x263
[<ffffffff81083567>] lock_release+0x17d/0x1a4
[<ffffffff81073f45>] up_write+0x23/0x3b
[<ffffffffa026fe9e>] ? cifs_get_spnego_key+0x61/0x21f [cifs]
[<ffffffff812013c5>] request_key+0x41/0x74
[<ffffffffa027003d>] cifs_get_spnego_key+0x200/0x21f [cifs]
[<ffffffffa026e296>] CIFS_SessSetup+0x55d/0x1273 [cifs]
[<ffffffffa02589e1>] cifs_setup_session+0x90/0x1ae [cifs]
[<ffffffffa0258e7e>] cifs_get_smb_ses+0x37f/0x443 [cifs]
[<ffffffffa025a9e3>] cifs_mount+0x1aa1/0x23f3 [cifs]
[<ffffffff8111fd94>] ? alloc_debug_processing+0xdb/0x120
[<ffffffffa027002c>] ? cifs_get_spnego_key+0x1ef/0x21f [cifs]
[<ffffffffa024cc71>] cifs_do_mount+0x165/0x2b3 [cifs]
[<ffffffff81130e72>] vfs_kern_mount+0xaf/0x1dc
[<ffffffff81131007>] do_kern_mount+0x4d/0xef
[<ffffffff811483b9>] do_mount+0x6f4/0x733
[<ffffffff8114861f>] sys_mount+0x88/0xc2
[<ffffffff8100ac42>] system_call_fastpath+0x16/0x1b
Reported-by: Jeff Layton <jlayton@redhat.com>
Reviewed-and-Tested-by: Jeff Layton <jlayton@redhat.com>
Cleanup based on David Howells suggestions:
- use static const char arrays instead of #define
- rename init_sdesc to alloc_sdesc
- convert 'unsigned int' definitions to 'size_t'
- revert remaining 'const unsigned int' definitions to 'unsigned int'
Verify the hex ascii datablob length is correct before converting the IV,
encrypted data, and HMAC to binary.
Reported-by: David Howells <dhowells@redhat.com>
- replace kzalloc, where possible, with kmalloc
- revert 'const unsigned int' definitions to 'unsigned int'
Signed-off-by: David Safford <safford@watson.ibm.com>
Previously not all TSS return codes were tested, as they were all eventually
caught by the TPM. Now all returns are tested and handled immediately.
This patch also fixes memory leaks in error and non-error paths.
Acked-by: Serge E. Hallyn <serge@hallyn.com>
This patch fixes the linux-next powerpc build errors as reported by
Stephen Rothwell.
Tested-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
Define a new kernel key-type called 'encrypted'. Encrypted keys are kernel
generated random numbers, which are encrypted/decrypted with a 'trusted'
symmetric key. Encrypted keys are created/encrypted/decrypted in the kernel.
Userspace only ever sees/stores encrypted blobs.
Changelog:
- bug fix: replaced master-key rcu based locking with semaphore
(reported by David Howells)
- Removed memset of crypto_shash_digest() digest output
- Replaced verification of 'key-type:key-desc' using strcspn(), with
one based on string constants.
- Moved documentation to Documentation/keys-trusted-encrypted.txt
- Replace hash with shash (based on comments by David Howells)
- Make lengths/counts size_t where possible (based on comments by David Howells)
Could not convert most lengths, as crypto expects 'unsigned int'
(size_t: on 32 bit is defined as unsigned int, but on 64 bit is unsigned long)
- Add 'const' where possible (based on comments by David Howells)
- allocate derived_buf dynamically to support arbitrary length master key
(fixed by Roberto Sassu)
- wait until late_initcall for crypto libraries to be registered
- cleanup security/Kconfig
- Add missing 'update' keyword (reported/fixed by Roberto Sassu)
- Free epayload on failure to create key (reported/fixed by Roberto Sassu)
- Increase the data size limit (requested by Roberto Sassu)
- Crypto return codes are always 0 on success and negative on failure,
remove unnecessary tests.
- Replaced kzalloc() with kmalloc()
Reviewed-by: Roberto Sassu <roberto.sassu@polito.it>
Define a new kernel key-type called 'trusted'. Trusted keys are random
number symmetric keys, generated and RSA-sealed by the TPM. The TPM
only unseals the keys, if the boot PCRs and other criteria match.
Userspace can only ever see encrypted blobs.
Based on suggestions by Jason Gunthorpe, several new options have been
added to support additional usages.
The new options are:
migratable= designates that the key may/may not ever be updated
(resealed under a new key, new pcrinfo or new auth.)
pcrlock=n extends the designated PCR 'n' with a random value,
so that a key sealed to that PCR may not be unsealed
again until after a reboot.
keyhandle= specifies the sealing/unsealing key handle.
keyauth= specifies the sealing/unsealing key auth.
blobauth= specifies the sealed data auth.
Implementation of a kernel reserved locality for trusted keys will be
investigated for a possible future extension.
Changelog:
- Updated and added examples to Documentation/keys-trusted-encrypted.txt
- Moved generic TPM constants to include/linux/tpm_command.h
(David Howell's suggestion.)
- trusted_defined.c: replaced kzalloc with kmalloc, added pcrlock failure
error handling, added const qualifiers where appropriate.
- moved to late_initcall
- updated from hash to shash (suggestion by David Howells)
- reduced worst stack usage (tpm_seal) from 530 to 312 bytes
- moved documentation to Documentation directory (suggestion by David Howells)
- all the other code cleanups suggested by David Howells
- Add pcrlock CAP_SYS_ADMIN dependency (based on comment by Jason Gunthorpe)
- New options: migratable, pcrlock, keyhandle, keyauth, blobauth (based on
discussions with Jason Gunthorpe)
- Free payload on failure to create key(reported/fixed by Roberto Sassu)
- Updated Kconfig and other descriptions (based on Serge Hallyn's suggestion)
- Replaced kzalloc() with kmalloc() (reported by Serge Hallyn)
Fix an incorrect error check that returns 1 for error instead of the
expected error code.
Fix a bug in keyctl_session_to_parent() whereby it tries to check the ownership
of the parent process's session keyring whether or not the parent has a session
keyring [CVE-2010-2960].
This results in the following oops:
BUG: unable to handle kernel NULL pointer dereference at 00000000000000a0
IP: [<ffffffff811ae4dd>] keyctl_session_to_parent+0x251/0x443
Call Trace:
[<ffffffff811ae2f3>] ? keyctl_session_to_parent+0x67/0x443
[<ffffffff8109d286>] ? __do_fault+0x24b/0x3d0
[<ffffffff811af98c>] sys_keyctl+0xb4/0xb8
[<ffffffff81001eab>] system_call_fastpath+0x16/0x1b
if the parent process has no session keyring.
If the system is using pam_keyinit then it mostly protected against this as all
processes derived from a login will have inherited the session keyring created
by pam_keyinit during the log in procedure.
To test this, pam_keyinit calls need to be commented out in /etc/pam.d/.
Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com>
Acked-by: Tavis Ormandy <taviso@cmpxchg8b.com>
There's an protected access to the parent process's credentials in the middle
of keyctl_session_to_parent(). This results in the following RCU warning:
[ INFO: suspicious rcu_dereference_check() usage. ]
security/keys/keyctl.c:1291 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 0
1 lock held by keyctl-session-/2137:
#0: (tasklist_lock){.+.+..}, at: [<ffffffff811ae2ec>] keyctl_session_to_parent+0x60/0x236
stack backtrace:
Pid: 2137, comm: keyctl-session- Not tainted 2.6.36-rc2-cachefs+ #1
Call Trace:
[<ffffffff8105606a>] lockdep_rcu_dereference+0xaa/0xb3
[<ffffffff811ae379>] keyctl_session_to_parent+0xed/0x236
[<ffffffff811af77e>] sys_keyctl+0xb4/0xb6
The code should take the RCU read lock to make sure the parents credentials
don't go away, even though it's holding a spinlock and has IRQ disabled.
Add a dummy printk function for the maintenance of unused printks through gcc
format checking, and also so that side-effect checking is maintained too.
request_key() should return -ENOKEY if the key it constructs has been
negatively instantiated.
Without this, request_key() can return an unusable key to its caller,
and if the caller then does key_validate() that won't catch the problem.
In commit bb952bb98a7e479262c7eb25d5592545a3af147d there was the accidental
deletion of a statement from call_sbin_request_key() to render the process
keyring ID to a text string so that it can be passed to /sbin/request-key.
With gcc 4.6.0 this causes the following warning:
CC security/keys/request_key.o
security/keys/request_key.c: In function 'call_sbin_request_key':
security/keys/request_key.c:102:15: warning: variable 'prkey' set but not used
This patch reinstates that statement.
Without this statement, /sbin/request-key will get some random rubbish from the
stack as that parameter.
keyctl_describe_key() turns the key reference it gets into a usable key pointer
and assigns that to a variable called 'key', which it then ignores in favour of
recomputing the key pointer each time it needs it. Make it use the precomputed
pointer instead.
Without this patch, gcc 4.6 reports that the variable key is set but not used:
building with gcc 4.6 I'm getting a warning message:
CC security/keys/keyctl.o
security/keys/keyctl.c: In function 'keyctl_describe_key':
security/keys/keyctl.c:472:14: warning: variable 'key' set but not used
Reported-by: Justin P. Mattock <justinmattock@gmail.com>
