commit 2e356101e72ab1361821b3af024d64877d9a798d upstream.
Currently, when we add a new user key, the calltrace as below:
add_key()
key_create_or_update()
key_alloc()
__key_instantiate_and_link
generic_key_instantiate
key_payload_reserve
Since commit a08bf91ce28e ("KEYS: allow reaching the keys quotas exactly"),
we can reach max bytes/keys in key_alloc, but we forget to remove this
limit when we reserver space for payload in key_payload_reserve. So we
can only reach max keys but not max bytes when having delta between plen
and type->def_datalen. Remove this limit when instantiating the key, so we
can keep consistent with key_alloc.
Also, fix the similar problem in keyctl_chown_key().
Fixes: 0b77f5bfb45c ("keys: make the keyring quotas controllable through /proc/sys")
Fixes: a08bf91ce28e ("KEYS: allow reaching the keys quotas exactly")
Cc: stable@vger.kernel.org # 5.0.x
Cc: Eric Biggers <ebiggers@google.com>
Signed-off-by: Yang Xu <xuyang2018.jy@cn.fujitsu.com>
Reviewed-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Reviewed-by: Eric Biggers <ebiggers@google.com>
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
[ Upstream commit 7c1857bdbdf1e4c541e45eab477ee23ed4333ea4 ]
Set the timestamp on new keys rather than leaving it unset.
Fixes: 31d5a79d7f3d ("KEYS: Do LRU discard in full keyrings")
Signed-off-by: James Morris <james.morris@microsoft.com>
[ Upstream commit d41a3effbb53b1bcea41e328d16a4d046a508381 ]
If a request_key authentication token key gets revoked, there's a window in
which request_key_auth_describe() can see it with a NULL payload - but it
makes no check for this and something like the following oops may occur:
BUG: Kernel NULL pointer dereference at 0x00000038
Faulting instruction address: 0xc0000000004ddf30
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [...] request_key_auth_describe+0x90/0xd0
LR [...] request_key_auth_describe+0x54/0xd0
Call Trace:
[...] request_key_auth_describe+0x54/0xd0 (unreliable)
[...] proc_keys_show+0x308/0x4c0
[...] seq_read+0x3d0/0x540
[...] proc_reg_read+0x90/0x110
[...] __vfs_read+0x3c/0x70
[...] vfs_read+0xb4/0x1b0
[...] ksys_read+0x7c/0x130
[...] system_call+0x5c/0x70
Fix this by checking for a NULL pointer when describing such a key.
Also make the read routine check for a NULL pointer to be on the safe side.
[DH: Modified to not take already-held rcu lock and modified to also check
in the read routine]
Fixes: 04c567d9313e ("[PATCH] Keys: Fix race between two instantiators of a key")
Reported-by: Sachin Sant <sachinp@linux.vnet.ibm.com>
Signed-off-by: Hillf Danton <hdanton@sina.com>
Tested-by: Sachin Sant <sachinp@linux.vnet.ibm.com>
commit 4aa68e07d845562561f5e73c04aa521376e95252 upstream.
When checking for permission to view keys whilst reading from
/proc/keys, we should use the credentials with which the /proc/keys file
was opened. This is because, in a classic type of exploit, it can be
possible to bypass checks for the *current* credentials by passing the
file descriptor to a suid program.
Following commit 34dbbcdbf633 ("Make file credentials available to the
seqfile interfaces") we can finally fix it. So let's do it.
Signed-off-by: Zubin Mithra <zsm@chromium.org>
commit ede0fa98a900e657d1fcd80b50920efc896c1a4c upstream.
syzbot hit the 'BUG_ON(index_key->desc_len == 0);' in __key_link_begin()
called from construct_alloc_key() during sys_request_key(), because the
length of the key description was never calculated.
The problem is that we rely on ->desc_len being initialized by
search_process_keyrings(), specifically by search_nested_keyrings().
But, if the process isn't subscribed to any keyrings that never happens.
Fix it by always initializing keyring_index_key::desc_len as soon as the
description is set, like we already do in some places.
The following program reproduces the BUG_ON() when it's run as root and
no session keyring has been installed. If it doesn't work, try removing
pam_keyinit.so from /etc/pam.d/login and rebooting.
#include <stdlib.h>
#include <unistd.h>
#include <keyutils.h>
int main(void)
int id = add_key("keyring", "syz", NULL, 0, KEY_SPEC_USER_KEYRING);
keyctl_setperm(id, KEY_OTH_WRITE);
setreuid(5000, 5000);
request_key("user", "desc", "", id);
Reported-by: syzbot+ec24e95ea483de0a24da@syzkaller.appspotmail.com
Fixes: b2a4df200d57 ("KEYS: Expand the capacity of a keyring")
commit a08bf91ce28ed3ae7b6fef35d843fef8dc8c2cd9 upstream.
If the sysctl 'kernel.keys.maxkeys' is set to some number n, then
actually users can only add up to 'n - 1' keys. Likewise for
'kernel.keys.maxbytes' and the root_* versions of these sysctls. But
these sysctls are apparently supposed to be *maximums*, as per their
names and all documentation I could find -- the keyrings(7) man page,
Documentation/security/keys/core.rst, and all the mentions of EDQUOT
meaning that the key quota was *exceeded* (as opposed to reached).
Thus, fix the code to allow reaching the quotas exactly.
commit 3cd18d1981731d5f74b8e437009124ac99905d14 upstream.
The recent rework introduced a possible randconfig build failure
when CONFIG_CRYPTO configured to only allow modules:
security/keys/big_key.o: In function `big_key_crypt':
big_key.c:(.text+0x29f): undefined reference to `crypto_aead_setkey'
security/keys/big_key.o: In function `big_key_init':
big_key.c:(.init.text+0x1a): undefined reference to `crypto_alloc_aead'
big_key.c:(.init.text+0x45): undefined reference to `crypto_aead_setauthsize'
big_key.c:(.init.text+0x77): undefined reference to `crypto_destroy_tfm'
crypto/gcm.o: In function `gcm_hash_crypt_remain_continue':
gcm.c:(.text+0x167): undefined reference to `crypto_ahash_finup'
crypto/gcm.o: In function `crypto_gcm_exit_tfm':
gcm.c:(.text+0x847): undefined reference to `crypto_destroy_tfm'
When we 'select CRYPTO' like the other users, we always get a
configuration that builds.
Fixes: 428490e38b2e ("security/keys: rewrite all of big_key crypto")
commit 794b4bc292f5d31739d89c0202c54e7dc9bc3add upstream.
With the 'encrypted' key type it was possible for userspace to provide a
data blob ending with a master key description shorter than expected,
e.g. 'keyctl add encrypted desc "new x" @s'. When validating such a
master key description, validate_master_desc() could read beyond the end
of the buffer. Fix this by using strncmp() instead of memcmp(). [Also
clean up the code to deduplicate some logic.]
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Signed-off-by: Jin Qian <jinqian@google.com>
commit 4dca6ea1d9432052afb06baf2e3ae78188a4410b upstream.
When the request_key() syscall is not passed a destination keyring, it
links the requested key (if constructed) into the "default" request-key
keyring. This should require Write permission to the keyring. However,
there is actually no permission check.
This can be abused to add keys to any keyring to which only Search
permission is granted. This is because Search permission allows joining
the keyring. keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_SESSION_KEYRING)
then will set the default request-key keyring to the session keyring.
Then, request_key() can be used to add keys to the keyring.
Both negatively and positively instantiated keys can be added using this
method. Adding negative keys is trivial. Adding a positive key is a
bit trickier. It requires that either /sbin/request-key positively
instantiates the key, or that another thread adds the key to the process
keyring at just the right time, such that request_key() misses it
initially but then finds it in construct_alloc_key().
Fix this bug by checking for Write permission to the keyring in
construct_get_dest_keyring() when the default keyring is being used.
We don't do the permission check for non-default keyrings because that
was already done by the earlier call to lookup_user_key(). Also,
request_key_and_link() is currently passed a 'struct key *' rather than
a key_ref_t, so the "possessed" bit is unavailable.
We also don't do the permission check for the "requestor keyring", to
continue to support the use case described by commit 8bbf4976b59f
("KEYS: Alter use of key instantiation link-to-keyring argument") where
/sbin/request-key recursively calls request_key() to add keys to the
original requestor's destination keyring. (I don't know of any users
who actually do that, though...)
Fixes: 3e30148c3d52 ("[PATCH] Keys: Make request-key create an authorisation key")
commit 47b2c3fff4932e6fc17ce13d51a43c6969714e20 upstream.
CONFIG_KEYS_COMPAT is defined in arch-specific Kconfigs and is missing for
several 64-bit architectures : mips, parisc, tile.
At the moment and for those architectures, calling in 32-bit userspace the
keyctl syscall would return an ENOSYS error.
This patch moves the CONFIG_KEYS_COMPAT option to security/keys/Kconfig, to
make sure the compatibility wrapper is registered by default for any 64-bit
architecture as long as it is configured with CONFIG_COMPAT.
[DH: Modified to remove arm64 compat enablement also as requested by Eric
Biggers]
Signed-off-by: Bilal Amarni <bilal.amarni@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
cc: Eric Biggers <ebiggers3@gmail.com>
Cc: James Cowgill <james.cowgill@mips.com>
commit a3c812f7cfd80cf51e8f5b7034f7418f6beb56c1 upstream.
When calling keyctl_read() on a key of type "trusted", if the
user-supplied buffer was too small, the kernel ignored the buffer length
and just wrote past the end of the buffer, potentially corrupting
userspace memory. Fix it by instead returning the size required, as per
the documentation for keyctl_read().
We also don't even fill the buffer at all in this case, as this is
slightly easier to implement than doing a short read, and either
behavior appears to be permitted. It also makes it match the behavior
of the "encrypted" key type.
Fixes: d00a1c72f7f4 ("keys: add new trusted key-type")
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Reviewed-by: James Morris <james.l.morris@oracle.com>
commit ee618b4619b72527aaed765f0f0b74072b281159 upstream.
As the previous patch did for encrypted-keys, zero sensitive any
potentially sensitive data related to the "trusted" key type before it
is freed. Notably, we were not zeroing the tpm_buf structures in which
the actual key is stored for TPM seal and unseal, nor were we zeroing
the trusted_key_payload in certain error paths.
Cc: David Safford <safford@us.ibm.com>
commit 3239b6f29bdfb4b0a2ba59df995fc9e6f4df7f1f upstream.
Commit e645016abc80 ("KEYS: fix writing past end of user-supplied buffer
in keyring_read()") made keyring_read() stop corrupting userspace memory
when the user-supplied buffer is too small. However it also made the
return value in that case be the short buffer size rather than the size
required, yet keyctl_read() is actually documented to return the size
required. Therefore, switch it over to the documented behavior.
Note that for now we continue to have it fill the short buffer, since it
did that before (pre-v3.13) and dump_key_tree_aux() in keyutils arguably
relies on it.
Fixes: e645016abc80 ("KEYS: fix writing past end of user-supplied buffer in keyring_read()")
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream.
Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection
error into one field such that:
(1) The instantiation state can be modified/read atomically.
(2) The error can be accessed atomically with the state.
(3) The error isn't stored unioned with the payload pointers.
This deals with the problem that the state is spread over three different
objects (two bits and a separate variable) and reading or updating them
atomically isn't practical, given that not only can uninstantiated keys
change into instantiated or rejected keys, but rejected keys can also turn
into instantiated keys - and someone accessing the key might not be using
any locking.
The main side effect of this problem is that what was held in the payload
may change, depending on the state. For instance, you might observe the
key to be in the rejected state. You then read the cached error, but if
the key semaphore wasn't locked, the key might've become instantiated
between the two reads - and you might now have something in hand that isn't
actually an error code.
The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error
code if the key is negatively instantiated. The key_is_instantiated()
function is replaced with key_is_positive() to avoid confusion as negative
keys are also 'instantiated'.
Additionally, barriering is included:
(1) Order payload-set before state-set during instantiation.
(2) Order state-read before payload-read when using the key.
Further separate barriering is necessary if RCU is being used to access the
payload content after reading the payload pointers.
Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data")
Reported-by: Eric Biggers <ebiggers@google.com>
commit 60ff5b2f547af3828aebafd54daded44cfb0807a upstream.
Currently, when passed a key that already exists, add_key() will call the
key's ->update() method if such exists. But this is heavily broken in the
case where the key is uninstantiated because it doesn't call
__key_instantiate_and_link(). Consequently, it doesn't do most of the
things that are supposed to happen when the key is instantiated, such as
setting the instantiation state, clearing KEY_FLAG_USER_CONSTRUCT and
awakening tasks waiting on it, and incrementing key->user->nikeys.
It also never takes key_construction_mutex, which means that
->instantiate() can run concurrently with ->update() on the same key. In
the case of the "user" and "logon" key types this causes a memory leak, at
best. Maybe even worse, the ->update() methods of the "encrypted" and
"trusted" key types actually just dereference a NULL pointer when passed an
uninstantiated key.
Change key_create_or_update() to wait interruptibly for the key to finish
construction before continuing.
This patch only affects *uninstantiated* keys. For now we still allow a
negatively instantiated key to be updated (thereby positively
instantiating it), although that's broken too (the next patch fixes it)
and I'm not sure that anyone actually uses that functionality either.
Here is a simple reproducer for the bug using the "encrypted" key type
(requires CONFIG_ENCRYPTED_KEYS=y), though as noted above the bug
pertained to more than just the "encrypted" key type:
#include <stdlib.h>
#include <unistd.h>
int main(void)
int ringid = keyctl_join_session_keyring(NULL);
if (fork()) {
for (;;) {
const char payload[] = "update user:foo 32";
usleep(rand() % 10000);
add_key("encrypted", "desc", payload, sizeof(payload), ringid);
keyctl_clear(ringid);
} else {
for (;;)
request_key("encrypted", "desc", "callout_info", ringid);
It causes:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: encrypted_update+0xb0/0x170
PGD 7a178067 P4D 7a178067 PUD 77269067 PMD 0
PREEMPT SMP
CPU: 0 PID: 340 Comm: reproduce Tainted: G D 4.14.0-rc1-00025-g428490e38b2e #796
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff8a467a39a340 task.stack: ffffb15c40770000
RIP: 0010:encrypted_update+0xb0/0x170
RSP: 0018:ffffb15c40773de8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff8a467a275b00 RCX: 0000000000000000
RDX: 0000000000000005 RSI: ffff8a467a275b14 RDI: ffffffffb742f303
RBP: ffffb15c40773e20 R08: 0000000000000000 R09: ffff8a467a275b17
R10: 0000000000000020 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: ffff8a4677057180 R15: ffff8a467a275b0f
FS: 00007f5d7fb08700(0000) GS:ffff8a467f200000(0000) knlGS:0000000000000000
CR2: 0000000000000018 CR3: 0000000077262005 CR4: 00000000001606f0
Call Trace:
key_create_or_update+0x2bc/0x460
SyS_add_key+0x10c/0x1d0
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x7f5d7f211259
RSP: 002b:00007ffed03904c8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8
RAX: ffffffffffffffda RBX: 000000003b2a7955 RCX: 00007f5d7f211259
RDX: 00000000004009e4 RSI: 00000000004009ff RDI: 0000000000400a04
RBP: 0000000068db8bad R08: 000000003b2a7955 R09: 0000000000000004
R10: 000000000000001a R11: 0000000000000246 R12: 0000000000400868
R13: 00007ffed03905d0 R14: 0000000000000000 R15: 0000000000000000
Code: 77 28 e8 64 34 1f 00 45 31 c0 31 c9 48 8d 55 c8 48 89 df 48 8d 75 d0 e8 ff f9 ff ff 85 c0 41 89 c4 0f 88 84 00 00 00 4c 8b 7d c8 <49> 8b 75 18 4c 89 ff e8 24 f8 ff ff 85 c0 41 89 c4 78 6d 49 8b
RIP: encrypted_update+0xb0/0x170 RSP: ffffb15c40773de8
cc: Eric Biggers <ebiggers@google.com>
commit 13923d0865ca96312197962522e88bc0aedccd74 upstream.
A key of type "encrypted" references a "master key" which is used to
encrypt and decrypt the encrypted key's payload. However, when we
accessed the master key's payload, we failed to handle the case where
the master key has been revoked, which sets the payload pointer to NULL.
Note that request_key() *does* skip revoked keys, but there is still a
window where the key can be revoked before we acquire its semaphore.
Fix it by checking for a NULL payload, treating it like a key which was
already revoked at the time it was requested.
This was an issue for master keys of type "user" only. Master keys can
also be of type "trusted", but those cannot be revoked.
Fixes: 7e70cb497850 ("keys: add new key-type encrypted")
commit 37863c43b2c6464f252862bf2e9768264e961678 upstream.
Because keyctl_read_key() looks up the key with no permissions
requested, it may find a negatively instantiated key. If the key is
also possessed, we went ahead and called ->read() on the key. But the
key payload will actually contain the ->reject_error rather than the
normal payload. Thus, the kernel oopses trying to read the
user_key_payload from memory address (int)-ENOKEY = 0x00000000ffffff82.
Fortunately the payload data is stored inline, so it shouldn't be
possible to abuse this as an arbitrary memory read primitive...
Reproducer:
keyctl new_session
keyctl request2 user desc '' @s
keyctl read $(keyctl show | awk '/user: desc/ {print $1}')
It causes a crash like the following:
BUG: unable to handle kernel paging request at 00000000ffffff92
IP: user_read+0x33/0xa0
PGD 36a54067 P4D 36a54067 PUD 0
Oops: 0000 [#1] SMP
CPU: 0 PID: 211 Comm: keyctl Not tainted 4.14.0-rc1 #337
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014
task: ffff90aa3b74c3c0 task.stack: ffff9878c0478000
RIP: 0010:user_read+0x33/0xa0
RSP: 0018:ffff9878c047bee8 EFLAGS: 00010246
RAX: 0000000000000001 RBX: ffff90aa3d7da340 RCX: 0000000000000017
RDX: 0000000000000000 RSI: 00000000ffffff82 RDI: ffff90aa3d7da340
RBP: ffff9878c047bf00 R08: 00000024f95da94f R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f58ece69740(0000) GS:ffff90aa3e200000(0000) knlGS:0000000000000000
CR2: 00000000ffffff92 CR3: 0000000036adc001 CR4: 00000000003606f0
Call Trace:
keyctl_read_key+0xac/0xe0
SyS_keyctl+0x99/0x120
RIP: 0033:0x7f58ec787bb9
RSP: 002b:00007ffc8d401678 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa
RAX: ffffffffffffffda RBX: 00007ffc8d402800 RCX: 00007f58ec787bb9
RDX: 0000000000000000 RSI: 00000000174a63ac RDI: 000000000000000b
RBP: 0000000000000004 R08: 00007ffc8d402809 R09: 0000000000000020
R10: 0000000000000000 R11: 0000000000000206 R12: 00007ffc8d402800
R13: 00007ffc8d4016e0 R14: 0000000000000000 R15: 0000000000000000
Code: e5 41 55 49 89 f5 41 54 49 89 d4 53 48 89 fb e8 a4 b4 ad ff 85 c0 74 09 80 3d b9 4c 96 00 00 74 43 48 8b b3 20 01 00 00 4d 85 ed <0f> b7 5e 10 74 29 4d 85 e4 74 24 4c 39 e3 4c 89 e2 4c 89 ef 48
RIP: user_read+0x33/0xa0 RSP: ffff9878c047bee8
Fixes: 61ea0c0ba904 ("KEYS: Skip key state checks when checking for possession")
commit 237bbd29f7a049d310d907f4b2716a7feef9abf3 upstream.
It was possible for an unprivileged user to create the user and user
session keyrings for another user. For example:
sudo -u '#3000' sh -c 'keyctl add keyring _uid.4000 "" @u
keyctl add keyring _uid_ses.4000 "" @u
sleep 15' &
sleep 1
sudo -u '#4000' keyctl describe @u
sudo -u '#4000' keyctl describe @us
This is problematic because these "fake" keyrings won't have the right
permissions. In particular, the user who created them first will own
them and will have full access to them via the possessor permissions,
which can be used to compromise the security of a user's keys:
-4: alswrv-----v------------ 3000 0 keyring: _uid.4000
-5: alswrv-----v------------ 3000 0 keyring: _uid_ses.4000
Fix it by marking user and user session keyrings with a flag
KEY_FLAG_UID_KEYRING. Then, when searching for a user or user session
keyring by name, skip all keyrings that don't have the flag set.
Fixes: 69664cf16af4 ("keys: don't generate user and user session keyrings unless they're accessed")
commit e645016abc803dafc75e4b8f6e4118f088900ffb upstream.
Userspace can call keyctl_read() on a keyring to get the list of IDs of
keys in the keyring. But if the user-supplied buffer is too small, the
kernel would write the full list anyway --- which will corrupt whatever
userspace memory happened to be past the end of the buffer. Fix it by
only filling the space that is available.
commit 428490e38b2e352812e0b765d8bceafab0ec441d upstream.
This started out as just replacing the use of crypto/rng with
get_random_bytes_wait, so that we wouldn't use bad randomness at boot
time. But, upon looking further, it appears that there were even deeper
underlying cryptographic problems, and that this seems to have been
committed with very little crypto review. So, I rewrote the whole thing,
trying to keep to the conventions introduced by the previous author, to
fix these cryptographic flaws.
It makes no sense to seed crypto/rng at boot time and then keep
using it like this, when in fact there's already get_random_bytes_wait,
which can ensure there's enough entropy and be a much more standard way
of generating keys. Since this sensitive material is being stored
untrusted, using ECB and no authentication is simply not okay at all. I
find it surprising and a bit horrifying that this code even made it past
basic crypto review, which perhaps points to some larger issues. This
patch moves from using AES-ECB to using AES-GCM. Since keys are uniquely
generated each time, we can set the nonce to zero. There was also a race
condition in which the same key would be reused at the same time in
different threads. A mutex fixes this issue now.
So, to summarize, this commit fixes the following vulnerabilities:
* Low entropy key generation, allowing an attacker to potentially
guess or predict keys.
* Unauthenticated encryption, allowing an attacker to modify the
cipher text in particular ways in order to manipulate the plaintext,
which is is even more frightening considering the next point.
* Use of ECB mode, allowing an attacker to trivially swap blocks or
compare identical plaintext blocks.
* Key re-use.
* Faulty memory zeroing.
[Note that in backporting this commit to 4.9, get_random_bytes_wait was
replaced with get_random_bytes, since 4.9 does not have the former
function. This might result in slightly worse entropy in key generation,
but common use cases of big_keys makes that likely not a huge deal. And,
this is the best we can do with this old kernel. Alas.]
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Reviewed-by: Eric Biggers <ebiggers3@gmail.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Kirill Marinushkin <k.marinushkin@gmail.com>
Cc: security@kernel.org
commit 910801809b2e40a4baedd080ef5d80b4a180e70e upstream.
Error paths forgot to zero out sensitive material, so this patch changes
some kfrees into a kzfrees.
commit 57cb17e764ba0aaa169d07796acce54ccfbc6cae upstream.
This function has two callers and neither are able to handle a NULL
return. Really, -EINVAL is the correct thing return here anyway. This
fixes some static checker warnings like:
security/keys/encrypted-keys/encrypted.c:709 encrypted_key_decrypt()
error: uninitialized symbol 'master_key'.
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit e9ff56ac352446f55141aaef1553cee662b2e310 upstream.
Since v4.9, the crypto API cannot (normally) be used to encrypt/decrypt
stack buffers because the stack may be virtually mapped. Fix this for
the padding buffers in encrypted-keys by using ZERO_PAGE for the
encryption padding and by allocating a temporary heap buffer for the
decryption padding.
Tested with CONFIG_DEBUG_SG=y:
keyctl new_session
keyctl add user master "abcdefghijklmnop" @s
keyid=$(keyctl add encrypted desc "new user:master 25" @s)
datablob="$(keyctl pipe $keyid)"
keyctl unlink $keyid
keyid=$(keyctl add encrypted desc "load $datablob" @s)
datablob2="$(keyctl pipe $keyid)"
[ "$datablob" = "$datablob2" ] && echo "Success!"
commit 63a0b0509e700717a59f049ec6e4e04e903c7fe2 upstream.
key_update() freed the key_preparsed_payload even if it was not
initialized first. This would cause a crash if userspace called
keyctl_update() on a key with type like "asymmetric" that has a
->preparse() method but not an ->update() method. Possibly it could
even be triggered for other key types by racing with keyctl_setperm() to
make the KEY_NEED_WRITE check fail (the permission was already checked,
so normally it wouldn't fail there).
Reproducer with key type "asymmetric", given a valid cert.der:
keyctl new_session
keyid=$(keyctl padd asymmetric desc @s < cert.der)
keyctl setperm $keyid 0x3f000000
keyctl update $keyid data
[ 150.686666] BUG: unable to handle kernel NULL pointer dereference at 0000000000000001
[ 150.687601] IP: asymmetric_key_free_kids+0x12/0x30
[ 150.688139] PGD 38a3d067
[ 150.688141] PUD 3b3de067
[ 150.688447] PMD 0
[ 150.688745]
[ 150.689160] Oops: 0000 [#1] SMP
[ 150.689455] Modules linked in:
[ 150.689769] CPU: 1 PID: 2478 Comm: keyctl Not tainted 4.11.0-rc4-xfstests-00187-ga9f6b6b8cd2f #742
[ 150.690916] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014
[ 150.692199] task: ffff88003b30c480 task.stack: ffffc90000350000
[ 150.692952] RIP: 0010:asymmetric_key_free_kids+0x12/0x30
[ 150.693556] RSP: 0018:ffffc90000353e58 EFLAGS: 00010202
[ 150.694142] RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000004
[ 150.694845] RDX: ffffffff81ee3920 RSI: ffff88003d4b0700 RDI: 0000000000000001
[ 150.697569] RBP: ffffc90000353e60 R08: ffff88003d5d2140 R09: 0000000000000000
[ 150.702483] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000001
[ 150.707393] R13: 0000000000000004 R14: ffff880038a4d2d8 R15: 000000000040411f
[ 150.709720] FS: 00007fcbcee35700(0000) GS:ffff88003fd00000(0000) knlGS:0000000000000000
[ 150.711504] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 150.712733] CR2: 0000000000000001 CR3: 0000000039eab000 CR4: 00000000003406e0
[ 150.714487] Call Trace:
[ 150.714975] asymmetric_key_free_preparse+0x2f/0x40
[ 150.715907] key_update+0xf7/0x140
[ 150.716560] ? key_default_cmp+0x20/0x20
[ 150.717319] keyctl_update_key+0xb0/0xe0
[ 150.718066] SyS_keyctl+0x109/0x130
[ 150.718663] entry_SYSCALL_64_fastpath+0x1f/0xc2
[ 150.719440] RIP: 0033:0x7fcbce75ff19
[ 150.719926] RSP: 002b:00007ffd5d167088 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa
[ 150.720918] RAX: ffffffffffffffda RBX: 0000000000404d80 RCX: 00007fcbce75ff19
[ 150.721874] RDX: 00007ffd5d16785e RSI: 000000002866cd36 RDI: 0000000000000002
[ 150.722827] RBP: 0000000000000006 R08: 000000002866cd36 R09: 00007ffd5d16785e
[ 150.723781] R10: 0000000000000004 R11: 0000000000000206 R12: 0000000000404d80
[ 150.724650] R13: 00007ffd5d16784d R14: 00007ffd5d167238 R15: 000000000040411f
[ 150.725447] Code: 83 c4 08 31 c0 5b 41 5c 41 5d 41 5e 41 5f 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 85 ff 74 23 55 48 89 e5 53 48 89 fb <48> 8b 3f e8 06 21 c5 ff 48 8b 7b 08 e8 fd 20 c5 ff 48 89 df e8
[ 150.727489] RIP: asymmetric_key_free_kids+0x12/0x30 RSP: ffffc90000353e58
[ 150.728117] CR2: 0000000000000001
[ 150.728430] ---[ end trace f7f8fe1da2d5ae8d ]---
Fixes: 4d8c0250b841 ("KEYS: Call ->free_preparse() even after ->preparse() returns an error")
commit 5649645d725c73df4302428ee4e02c869248b4c5 upstream.
sys_add_key() and the KEYCTL_UPDATE operation of sys_keyctl() allowed a
NULL payload with nonzero length to be passed to the key type's
->preparse(), ->instantiate(), and/or ->update() methods. Various key
types including asymmetric, cifs.idmap, cifs.spnego, and pkcs7_test did
not handle this case, allowing an unprivileged user to trivially cause a
NULL pointer dereference (kernel oops) if one of these key types was
present. Fix it by doing the copy_from_user() when 'plen' is nonzero
rather than when '_payload' is non-NULL, causing the syscall to fail
with EFAULT as expected when an invalid buffer is specified.
commit c9f838d104fed6f2f61d68164712e3204bf5271b upstream.
This fixes CVE-2017-7472.
Running the following program as an unprivileged user exhausts kernel
memory by leaking thread keyrings:
int main()
for (;;)
keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_THREAD_KEYRING);
Fix it by only creating a new thread keyring if there wasn't one before.
To make things more consistent, make install_thread_keyring_to_cred()
and install_process_keyring_to_cred() both return 0 if the corresponding
keyring is already present.
Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials")
commit c1644fe041ebaf6519f6809146a77c3ead9193af upstream.
This fixes CVE-2017-6951.
Userspace should not be able to do things with the "dead" key type as it
doesn't have some of the helper functions set upon it that the kernel
needs. Attempting to use it may cause the kernel to crash.
Fix this by changing the name of the type to ".dead" so that it's rejected
up front on userspace syscalls by key_get_type_from_user().
Though this doesn't seem to affect recent kernels, it does affect older
ones, certainly those prior to:
commit c06cfb08b88dfbe13be44a69ae2fdc3a7c902d81
Author: David Howells <dhowells@redhat.com>
Date: Tue Sep 16 17:36:06 2014 +0100
KEYS: Remove key_type::match in favour of overriding default by match_preparse
which went in before 3.18-rc1.
commit ee8f844e3c5a73b999edf733df1c529d6503ec2f upstream.
This fixes CVE-2016-9604.
Keyrings whose name begin with a '.' are special internal keyrings and so
userspace isn't allowed to create keyrings by this name to prevent
shadowing. However, the patch that added the guard didn't fix
KEYCTL_JOIN_SESSION_KEYRING. Not only can that create dot-named keyrings,
it can also subscribe to them as a session keyring if they grant SEARCH
permission to the user.
This, for example, allows a root process to set .builtin_trusted_keys as
its session keyring, at which point it has full access because now the
possessor permissions are added. This permits root to add extra public
keys, thereby bypassing module verification.
This also affects kexec and IMA.
This can be tested by (as root):
keyctl session .builtin_trusted_keys
keyctl add user a a @s
keyctl list @s
which on my test box gives me:
2 keys in keyring:
180010936: ---lswrv 0 0 asymmetric: Build time autogenerated kernel key: ae3d4a31b82daa8e1a75b49dc2bba949fd992a05
801382539: --alswrv 0 0 user: a
Fix this by rejecting names beginning with a '.' in the keyctl.
cc: linux-ima-devel@lists.sourceforge.net
Since BIG_KEYS can't be compiled as module it requires one of the "stdrng"
providers to be compiled into kernel. Otherwise big_key_crypto_init() fails
on crypto_alloc_rng step and next dereference of big_key_skcipher (e.g. in
big_key_preparse()) results in a NULL pointer dereference.
Fixes: 13100a72f40f5748a04017e0ab3df4cf27c809ef ('Security: Keys: Big keys stored encrypted')
Signed-off-by: Artem Savkov <asavkov@redhat.com>
cc: Stephan Mueller <smueller@chronox.de>
cc: Kirill Marinushkin <k.marinushkin@gmail.com>
cc: stable@vger.kernel.org
big_key has two separate initialisation functions, one that registers the
key type and one that registers the crypto. If the key type fails to
register, there's no problem if the crypto registers successfully because
there's no way to reach the crypto except through the key type.
However, if the key type registers successfully but the crypto does not,
big_key_rng and big_key_blkcipher may end up set to NULL - but the code
neither checks for this nor unregisters the big key key type.
Furthermore, since the key type is registered before the crypto, it is
theoretically possible for the kernel to try adding a big_key before the
crypto is set up, leading to the same effect.
Fix this by merging big_key_crypto_init() and big_key_init() and calling
the resulting function late. If they're going to be encrypted, we
shouldn't be creating big_keys before we have the facilities to do the
encryption available. The key type registration is also moved after the
crypto initialisation.
The fix also includes message printing on failure.
If the big_key type isn't correctly set up, simply doing:
dd if=/dev/zero bs=4096 count=1 | keyctl padd big_key a @s
ought to cause an oops.
cc: Peter Hlavaty <zer0mem@yahoo.com>
cc: Artem Savkov <asavkov@redhat.com>
This fixes CVE-2016-7042.
Fix a short sprintf buffer in proc_keys_show(). If the gcc stack protector
is turned on, this can cause a panic due to stack corruption.
The problem is that xbuf[] is not big enough to hold a 64-bit timeout
rendered as weeks:
(gdb) p 0xffffffffffffffffULL/(60*60*24*7)
$2 = 30500568904943
That's 14 chars plus NUL, not 11 chars plus NUL.
Expand the buffer to 16 chars.
I think the unpatched code apparently works if the stack-protector is not
enabled because on a 32-bit machine the buffer won't be overflowed and on a
64-bit machine there's a 64-bit aligned pointer at one side and an int that
isn't checked again on the other side.
The panic incurred looks something like:
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff81352ebe
CPU: 0 PID: 1692 Comm: reproducer Not tainted 4.7.2-201.fc24.x86_64 #1
Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011
0000000000000086 00000000fbbd2679 ffff8800a044bc00 ffffffff813d941f
ffffffff81a28d58 ffff8800a044bc98 ffff8800a044bc88 ffffffff811b2cb6
ffff880000000010 ffff8800a044bc98 ffff8800a044bc30 00000000fbbd2679
Call Trace:
[<ffffffff813d941f>] dump_stack+0x63/0x84
[<ffffffff811b2cb6>] panic+0xde/0x22a
[<ffffffff81352ebe>] ? proc_keys_show+0x3ce/0x3d0
[<ffffffff8109f7f9>] __stack_chk_fail+0x19/0x30
[<ffffffff81352ebe>] proc_keys_show+0x3ce/0x3d0
[<ffffffff81350410>] ? key_validate+0x50/0x50
[<ffffffff8134db30>] ? key_default_cmp+0x20/0x20
[<ffffffff8126b31c>] seq_read+0x2cc/0x390
[<ffffffff812b6b12>] proc_reg_read+0x42/0x70
[<ffffffff81244fc7>] __vfs_read+0x37/0x150
[<ffffffff81357020>] ? security_file_permission+0xa0/0xc0
[<ffffffff81246156>] vfs_read+0x96/0x130
[<ffffffff81247635>] SyS_read+0x55/0xc0
[<ffffffff817eb872>] entry_SYSCALL_64_fastpath+0x1a/0xa4
Reported-by: Ondrej Kozina <okozina@redhat.com>
Tested-by: Ondrej Kozina <okozina@redhat.com>
The IV must not be modified by the skcipher operation so we need
to duplicate it.
Fixes: c3917fd9dfbc ("KEYS: Use skcipher")
Reported-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- TPM core and driver updates/fixes
- IPv6 security labeling (CALIPSO)
- Lots of Apparmor fixes
- Seccomp: remove 2-phase API, close hole where ptrace can change
syscall #"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (156 commits)
apparmor: fix SECURITY_APPARMOR_HASH_DEFAULT parameter handling
tpm: Add TPM 2.0 support to the Nuvoton i2c driver (NPCT6xx family)
tpm: Factor out common startup code
tpm: use devm_add_action_or_reset
tpm2_i2c_nuvoton: add irq validity check
tpm: read burstcount from TPM_STS in one 32-bit transaction
tpm: fix byte-order for the value read by tpm2_get_tpm_pt
tpm_tis_core: convert max timeouts from msec to jiffies
apparmor: fix arg_size computation for when setprocattr is null terminated
apparmor: fix oops, validate buffer size in apparmor_setprocattr()
apparmor: do not expose kernel stack
apparmor: fix module parameters can be changed after policy is locked
apparmor: fix oops in profile_unpack() when policy_db is not present
apparmor: don't check for vmalloc_addr if kvzalloc() failed
apparmor: add missing id bounds check on dfa verification
apparmor: allow SYS_CAP_RESOURCE to be sufficient to prlimit another task
apparmor: use list_next_entry instead of list_entry_next
apparmor: fix refcount race when finding a child profile
apparmor: fix ref count leak when profile sha1 hash is read
apparmor: check that xindex is in trans_table bounds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 4.8:
API:
- first part of skcipher low-level conversions
- add KPP (Key-agreement Protocol Primitives) interface.
Algorithms:
- fix IPsec/cryptd reordering issues that affects aesni
- RSA no longer does explicit leading zero removal
- add SHA3
- add DH
- add ECDH
- improve DRBG performance by not doing CTR by hand
Drivers:
- add x86 AVX2 multibuffer SHA256/512
- add POWER8 optimised crc32c
- add xts support to vmx
- add DH support to qat
- add RSA support to caam
- add Layerscape support to caam
- add SEC1 AEAD support to talitos
- improve performance by chaining requests in marvell/cesa
- add support for Araneus Alea I USB RNG
- add support for Broadcom BCM5301 RNG
- add support for Amlogic Meson RNG
- add support Broadcom NSP SoC RNG"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (180 commits)
crypto: vmx - Fix aes_p8_xts_decrypt build failure
crypto: vmx - Ignore generated files
crypto: vmx - Adding support for XTS
crypto: vmx - Adding asm subroutines for XTS
crypto: skcipher - add comment for skcipher_alg->base
crypto: testmgr - Print akcipher algorithm name
crypto: marvell - Fix wrong flag used for GFP in mv_cesa_dma_add_iv_op
crypto: nx - off by one bug in nx_of_update_msc()
crypto: rsa-pkcs1pad - fix rsa-pkcs1pad request struct
crypto: scatterwalk - Inline start/map/done
crypto: scatterwalk - Remove unnecessary BUG in scatterwalk_start
crypto: scatterwalk - Remove unnecessary advance in scatterwalk_pagedone
crypto: scatterwalk - Fix test in scatterwalk_done
crypto: api - Optimise away crypto_yield when hard preemption is on
crypto: scatterwalk - add no-copy support to copychunks
crypto: scatterwalk - Remove scatterwalk_bytes_sglen
crypto: omap - Stop using crypto scatterwalk_bytes_sglen
crypto: skcipher - Remove top-level givcipher interface
crypto: user - Remove crypto_lookup_skcipher call
crypto: cts - Convert to skcipher
This patch replaces use of the obsolete blkcipher with skcipher.
If __key_link_begin() failed then "edit" would be uninitialized. I've
added a check to fix that.
This allows a random user to crash the kernel, though it's quite
difficult to achieve. There are three ways it can be done as the user
would have to cause an error to occur in __key_link():
(1) Cause the kernel to run out of memory. In practice, this is difficult
to achieve without ENOMEM cropping up elsewhere and aborting the
attempt.
(2) Revoke the destination keyring between the keyring ID being looked up
and it being tested for revocation. In practice, this is difficult to
time correctly because the KEYCTL_REJECT function can only be used
from the request-key upcall process. Further, users can only make use
of what's in /sbin/request-key.conf, though this does including a
rejection debugging test - which means that the destination keyring
has to be the caller's session keyring in practice.
(3) Have just enough key quota available to create a key, a new session
keyring for the upcall and a link in the session keyring, but not then
sufficient quota to create a link in the nominated destination keyring
so that it fails with EDQUOT.
The bug can be triggered using option (3) above using something like the
following:
echo 80 >/proc/sys/kernel/keys/root_maxbytes
keyctl request2 user debug:fred negate @t
The above sets the quota to something much lower (80) to make the bug
easier to trigger, but this is dependent on the system. Note also that
the name of the keyring created contains a random number that may be
between 1 and 10 characters in size, so may throw the test off by
changing the amount of quota used.
Assuming the failure occurs, something like the following will be seen:
kfree_debugcheck: out of range ptr 6b6b6b6b6b6b6b68h
kernel BUG at ../mm/slab.c:2821!
RIP: 0010:[<ffffffff811600f9>] kfree_debugcheck+0x20/0x25
RSP: 0018:ffff8804014a7de8 EFLAGS: 00010092
RAX: 0000000000000034 RBX: 6b6b6b6b6b6b6b68 RCX: 0000000000000000
RDX: 0000000000040001 RSI: 00000000000000f6 RDI: 0000000000000300
RBP: ffff8804014a7df0 R08: 0000000000000001 R09: 0000000000000000
R10: ffff8804014a7e68 R11: 0000000000000054 R12: 0000000000000202
R13: ffffffff81318a66 R14: 0000000000000000 R15: 0000000000000001
Call Trace:
kfree+0xde/0x1bc
assoc_array_cancel_edit+0x1f/0x36
__key_link_end+0x55/0x63
key_reject_and_link+0x124/0x155
keyctl_reject_key+0xb6/0xe0
keyctl_negate_key+0x10/0x12
SyS_keyctl+0x9f/0xe7
do_syscall_64+0x63/0x13a
entry_SYSCALL64_slow_path+0x25/0x25
Fixes: f70e2e06196a ('KEYS: Do preallocation for __key_link()')
Strip some trailing spaces.
The values computed during Diffie-Hellman key exchange are often used
in combination with key derivation functions to create cryptographic
keys. Add a placeholder for a later implementation to configure a
key derivation function that will transform the Diffie-Hellman
result returned by the KEYCTL_DH_COMPUTE command.
[This patch was stripped down from a patch produced by Mat Martineau that
had a bug in the compat code - so for the moment Stephan's patch simply
requires that the placeholder argument must be NULL]
Original-signed-off-by: Mat Martineau <mathew.j.martineau@linux.intel.com>
Signed-off-by: Stephan Mueller <smueller@chronox.de>
Here's a set of patches that changes how certificates/keys are determined
to be trusted. That's currently a two-step process:
(1) Up until recently, when an X.509 certificate was parsed - no matter
the source - it was judged against the keys in .system_keyring,
assuming those keys to be trusted if they have KEY_FLAG_TRUSTED set
upon them.
This has just been changed such that any key in the .ima_mok keyring,
if configured, may also be used to judge the trustworthiness of a new
certificate, whether or not the .ima_mok keyring is meant to be
consulted for whatever process is being undertaken.
If a certificate is determined to be trustworthy, KEY_FLAG_TRUSTED
will be set upon a key it is loaded into (if it is loaded into one),
no matter what the key is going to be loaded for.
(2) If an X.509 certificate is loaded into a key, then that key - if
KEY_FLAG_TRUSTED gets set upon it - can be linked into any keyring
with KEY_FLAG_TRUSTED_ONLY set upon it. This was meant to be the
system keyring only, but has been extended to various IMA keyrings.
A user can at will link any key marked KEY_FLAG_TRUSTED into any
keyring marked KEY_FLAG_TRUSTED_ONLY if the relevant permissions masks
permit it.
These patches change that:
(1) Trust becomes a matter of consulting the ring of trusted keys supplied
when the trust is evaluated only.
(2) Every keyring can be supplied with its own manager function to
restrict what may be added to that keyring. This is called whenever a
key is to be linked into the keyring to guard against a key being
created in one keyring and then linked across.
This function is supplied with the keyring and the key type and
payload[*] of the key being linked in for use in its evaluation. It
is permitted to use other data also, such as the contents of other
keyrings such as the system keyrings.
[*] The type and payload are supplied instead of a key because as an
optimisation this function may be called whilst creating a key and
so may reject the proposed key between preparse and allocation.
(3) A default manager function is provided that permits keys to be
restricted to only asymmetric keys that are vouched for by the
contents of the system keyring.
A second manager function is provided that just rejects with EPERM.
(4) A key allocation flag, KEY_ALLOC_BYPASS_RESTRICTION, is made available
so that the kernel can initialise keyrings with keys that form the
root of the trust relationship.
(5) KEY_FLAG_TRUSTED and KEY_FLAG_TRUSTED_ONLY are removed, along with
key_preparsed_payload::trusted.
This change also makes it possible in future for userspace to create a private
set of trusted keys and then to have it sealed by setting a manager function
where the private set is wholly independent of the kernel's trust
relationships.
Further changes in the set involve extracting certain IMA special keyrings
and making them generally global:
(*) .system_keyring is renamed to .builtin_trusted_keys and remains read
only. It carries only keys built in to the kernel. It may be where
UEFI keys should be loaded - though that could better be the new
secondary keyring (see below) or a separate UEFI keyring.
(*) An optional secondary system keyring (called .secondary_trusted_keys)
is added to replace the IMA MOK keyring.
(*) Keys can be added to the secondary keyring by root if the keys can
be vouched for by either ring of system keys.
(*) Module signing and kexec only use .builtin_trusted_keys and do not use
the new secondary keyring.
(*) Config option SYSTEM_TRUSTED_KEYS now depends on ASYMMETRIC_KEY_TYPE as
that's the only type currently permitted on the system keyrings.
(*) A new config option, IMA_KEYRINGS_PERMIT_SIGNED_BY_BUILTIN_OR_SECONDARY,
is provided to allow keys to be added to IMA keyrings, subject to the
restriction that such keys are validly signed by a key already in the
system keyrings.
If this option is enabled, but secondary keyrings aren't, additions to
the IMA keyrings will be restricted to signatures verifiable by keys in
the builtin system keyring only.
This adds userspace access to Diffie-Hellman computations through a
new keyctl() syscall command to calculate shared secrets or public
keys using input parameters stored in the keyring.
Input key ids are provided in a struct due to the current 5-arg limit
for the keyctl syscall. Only user keys are supported in order to avoid
exposing the content of logon or encrypted keys.
The output is written to the provided buffer, based on the assumption
that the values are only needed in userspace.
Future support for other types of key derivation would involve a new
command, like KEYCTL_ECDH_COMPUTE.
Once Diffie-Hellman support is included in the crypto API, this code
can be converted to use the crypto API to take advantage of possible
hardware acceleration and reduce redundant code.
Signed-off-by: Mat Martineau <mathew.j.martineau@linux.intel.com>
Solved TODO task: big keys saved to shmem file are now stored encrypted.
The encryption key is randomly generated and saved to payload[big_key_data].
Signed-off-by: Kirill Marinushkin <k.marinushkin@gmail.com>
The payload preparsing routine for user keys makes a copy of the payload
provided by the caller and stashes it in the key_preparsed_payload struct for
->instantiate() or ->update() to use. However, ->update() takes another copy
of this to attach to the keyring. ->update() should be using this directly
and clearing the pointer in the preparse data.
Remove KEY_FLAG_TRUSTED and KEY_ALLOC_TRUSTED as they're no longer
meaningful. Also we can drop the trusted flag from the preparse structure.
Given this, we no longer need to pass the key flags through to
restrict_link().
Further, we can now get rid of keyring_restrict_trusted_only() also.
Add a facility whereby proposed new links to be added to a keyring can be
vetted, permitting them to be rejected if necessary. This can be used to
block public keys from which the signature cannot be verified or for which
the signature verification fails. It could also be used to provide
blacklisting.
This affects operations like add_key(), KEYCTL_LINK and KEYCTL_INSTANTIATE.
To this end:
(1) A function pointer is added to the key struct that, if set, points to
the vetting function. This is called as:
int (*restrict_link)(struct key *keyring,
const struct key_type *key_type,
unsigned long key_flags,
const union key_payload *key_payload),
where 'keyring' will be the keyring being added to, key_type and
key_payload will describe the key being added and key_flags[*] can be
AND'ed with KEY_FLAG_TRUSTED.
[*] This parameter will be removed in a later patch when
KEY_FLAG_TRUSTED is removed.
The function should return 0 to allow the link to take place or an
error (typically -ENOKEY, -ENOPKG or -EKEYREJECTED) to reject the
link.
The pointer should not be set directly, but rather should be set
through keyring_alloc().
Note that if called during add_key(), preparse is called before this
method, but a key isn't actually allocated until after this function
is called.
(2) KEY_ALLOC_BYPASS_RESTRICTION is added. This can be passed to
key_create_or_update() or key_instantiate_and_link() to bypass the
restriction check.
(3) KEY_FLAG_TRUSTED_ONLY is removed. The entire contents of a keyring
with this restriction emplaced can be considered 'trustworthy' by
virtue of being in the keyring when that keyring is consulted.
(4) key_alloc() and keyring_alloc() take an extra argument that will be
used to set restrict_link in the new key. This ensures that the
pointer is set before the key is published, thus preventing a window
of unrestrictedness. Normally this argument will be NULL.
(5) As a temporary affair, keyring_restrict_trusted_only() is added. It
should be passed to keyring_alloc() as the extra argument instead of
setting KEY_FLAG_TRUSTED_ONLY on a keyring. This will be replaced in
a later patch with functions that look in the appropriate places for
authoritative keys.
Pull security layer updates from James Morris:
"There are a bunch of fixes to the TPM, IMA, and Keys code, with minor
fixes scattered across the subsystem.
IMA now requires signed policy, and that policy is also now measured
and appraised"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (67 commits)
X.509: Make algo identifiers text instead of enum
akcipher: Move the RSA DER encoding check to the crypto layer
crypto: Add hash param to pkcs1pad
sign-file: fix build with CMS support disabled
MAINTAINERS: update tpmdd urls
MODSIGN: linux/string.h should be #included to get memcpy()
certs: Fix misaligned data in extra certificate list
X.509: Handle midnight alternative notation in GeneralizedTime
X.509: Support leap seconds
Handle ISO 8601 leap seconds and encodings of midnight in mktime64()
X.509: Fix leap year handling again
PKCS#7: fix unitialized boolean 'want'
firmware: change kernel read fail to dev_dbg()
KEYS: Use the symbol value for list size, updated by scripts/insert-sys-cert
KEYS: Reserve an extra certificate symbol for inserting without recompiling
modsign: hide openssl output in silent builds
tpm_tis: fix build warning with tpm_tis_resume
ima: require signed IMA policy
ima: measure and appraise the IMA policy itself
ima: load policy using path
Pull crypto update from Herbert Xu:
"Here is the crypto update for 4.6:
API:
- Convert remaining crypto_hash users to shash or ahash, also convert
blkcipher/ablkcipher users to skcipher.
- Remove crypto_hash interface.
- Remove crypto_pcomp interface.
- Add crypto engine for async cipher drivers.
- Add akcipher documentation.
- Add skcipher documentation.
Algorithms:
- Rename crypto/crc32 to avoid name clash with lib/crc32.
- Fix bug in keywrap where we zero the wrong pointer.
Drivers:
- Support T5/M5, T7/M7 SPARC CPUs in n2 hwrng driver.
- Add PIC32 hwrng driver.
- Support BCM6368 in bcm63xx hwrng driver.
- Pack structs for 32-bit compat users in qat.
- Use crypto engine in omap-aes.
- Add support for sama5d2x SoCs in atmel-sha.
- Make atmel-sha available again.
- Make sahara hashing available again.
- Make ccp hashing available again.
- Make sha1-mb available again.
- Add support for multiple devices in ccp.
- Improve DMA performance in caam.
- Add hashing support to rockchip"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (116 commits)
crypto: qat - remove redundant arbiter configuration
crypto: ux500 - fix checks of error code returned by devm_ioremap_resource()
crypto: atmel - fix checks of error code returned by devm_ioremap_resource()
crypto: qat - Change the definition of icp_qat_uof_regtype
hwrng: exynos - use __maybe_unused to hide pm functions
crypto: ccp - Add abstraction for device-specific calls
crypto: ccp - CCP versioning support
crypto: ccp - Support for multiple CCPs
crypto: ccp - Remove check for x86 family and model
crypto: ccp - memset request context to zero during import
lib/mpi: use "static inline" instead of "extern inline"
lib/mpi: avoid assembler warning
hwrng: bcm63xx - fix non device tree compatibility
crypto: testmgr - allow rfc3686 aes-ctr variants in fips mode.
crypto: qat - The AE id should be less than the maximal AE number
lib/mpi: Endianness fix
crypto: rockchip - add hash support for crypto engine in rk3288
crypto: xts - fix compile errors
crypto: doc - add skcipher API documentation
crypto: doc - update AEAD AD handling
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into next
The Kconfig currently controlling compilation of this code is:
config BIG_KEYS
bool "Large payload keys"
...meaning that it currently is not being built as a module by anyone.
Lets remove the modular code that is essentially orphaned, so that
when reading the driver there is no doubt it is builtin-only.
Since module_init translates to device_initcall in the non-modular
case, the init ordering remains unchanged with this commit.
We also delete the MODULE_LICENSE tag since all that information
is already contained at the top of the file in the comments.
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Serge E. Hallyn" <serge@hallyn.com>
Cc: keyrings@vger.kernel.org
Cc: linux-security-module@vger.kernel.org
In my original patch sealing with policy was done with dynamically
allocated buffer that I changed later into an array so the checks in
tpm2-cmd.c became invalid. This patch fixes the issue.
Fixes: 5beb0c435bdd ("keys, trusted: seal with a TPM2 authorization policy")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Peter Huewe <peterhuewe@gmx.de>
Add KEY_ALLOC_BUILT_IN to convey that a key should have KEY_FLAG_BUILTIN
set rather than setting it after the fact.
