This fixes the problem of an oops occuring when a user attempts to add a
key to a non-keyring key [CVE-2006-1522].
The problem is that __keyring_search_one() doesn't check that the
keyring it's been given is actually a keyring.
I've fixed this problem by:
(1) declaring that caller of __keyring_search_one() must guarantee that
the keyring is a keyring; and
(2) making key_create_or_update() check that the keyring is a keyring,
and return -ENOTDIR if it isn't.
This can be tested by:
keyctl add user b b `keyctl add user a a @s`
In the small window between strnlen_user() and copy_from_user() userspace
could alter the terminating `\0' character.
Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com>
Cc: <stable@kernel.org>
- Move capable() from sched.h to capability.h;
- Use <linux/capability.h> where capable() is used
(in include/, block/, ipc/, kernel/, a few drivers/,
mm/, security/, & sound/;
many more drivers/ to go)
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Make it possible for a running process (such as gssapid) to be able to
instantiate a key, as was requested by Trond Myklebust for NFS4.
The patch makes the following changes:
(1) A new, optional key type method has been added. This permits a key type
to intercept requests at the point /sbin/request-key is about to be
spawned and do something else with them - passing them over the
rpc_pipefs files or netlink sockets for instance.
The uninstantiated key, the authorisation key and the intended operation
name are passed to the method.
(2) The callout_info is no longer passed as an argument to /sbin/request-key
to prevent unauthorised viewing of this data using ps or by looking in
/proc/pid/cmdline.
This means that the old /sbin/request-key program will not work with the
patched kernel as it will expect to see an extra argument that is no
longer there.
A revised keyutils package will be made available tomorrow.
(3) The callout_info is now attached to the authorisation key. Reading this
key will retrieve the information.
(4) A new field has been added to the task_struct. This holds the
authorisation key currently active for a thread. Searches now look here
for the caller's set of keys rather than looking for an auth key in the
lowest level of the session keyring.
This permits a thread to be servicing multiple requests at once and to
switch between them. Note that this is per-thread, not per-process, and
so is usable in multithreaded programs.
The setting of this field is inherited across fork and exec.
(5) A new keyctl function (KEYCTL_ASSUME_AUTHORITY) has been added that
permits a thread to assume the authority to deal with an uninstantiated
key. Assumption is only permitted if the authorisation key associated
with the uninstantiated key is somewhere in the thread's keyrings.
This function can also clear the assumption.
(6) A new magic key specifier has been added to refer to the currently
assumed authorisation key (KEY_SPEC_REQKEY_AUTH_KEY).
(7) Instantiation will only proceed if the appropriate authorisation key is
assumed first. The assumed authorisation key is discarded if
instantiation is successful.
(8) key_validate() is moved from the file of request_key functions to the
file of permissions functions.
(9) The documentation is updated.
Build fix.
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Alexander Zangerl <az@bond.edu.au>
Cause any links within a keyring to keys that match a key to be linked into
that keyring to be discarded as a link to the new key is added. The match is
contingent on the type and description strings being the same.
This permits requests, adds and searches to displace negative, expired,
revoked and dead keys easily. After some discussion it was concluded that
duplicate valid keys should probably be discarded also as they would otherwise
hide the new key.
Since request_key() is intended to be the primary method by which keys are
added to a keyring, duplicate valid keys wouldn't be an issue there as that
function would return an existing match in preference to creating a new key.
Add a new keyctl function that allows the expiry time to be set on a key or
removed from a key, provided the caller has attribute modification access.
make needlessly global code static
Remove the key duplication stuff since there's nothing that uses it, no way
to get at it and it's awkward to deal with for LSM purposes.
Permit add_key() to once again update a matching key rather than adding a
new one if a matching key already exists in the target keyring.
This bug causes add_key() to always add a new key, displacing the old from
the target keyring.
This is the security/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in security/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: James Morris <jmorris@namei.org>
The attached patch removes a couple of incorrect and obsolete '!' operators
left over from the conversion of the key permission functions from
true/false returns to zero/error returns.
Signed-Off-By: David Howells <dhowells@redhat.com>
The attached patch adds LSM hooks for key management facilities. The notable
changes are:
(1) The key struct now supports a security pointer for the use of security
modules. This will permit key labelling and restrictions on which
programs may access a key.
(2) Security modules get a chance to note (or abort) the allocation of a key.
(3) The key permission checking can now be enhanced by the security modules;
the permissions check consults LSM if all other checks bear out.
(4) The key permissions checking functions now return an error code rather
than a boolean value.
(5) An extra permission has been added to govern the modification of
attributes (UID, GID, permissions).
Note that there isn't an LSM hook specifically for each keyctl() operation,
but rather the permissions hook allows control of individual operations based
on the permission request bits.
Key management access control through LSM is enabled by automatically if both
CONFIG_KEYS and CONFIG_SECURITY are enabled.
This should be applied on top of the patch ensubjected:
[PATCH] Keys: Possessor permissions should be additive
Signed-off-by: Chris Wright <chrisw@osdl.org>
Export user-defined key operations so that those who wish to define their
own key type based on the user-defined key operations may do so (as has
been requested).
The header file created has been placed into include/keys/user-type.h, thus
creating a directory where other key types may also be placed. Any
objections to doing this?
Signed-Off-By: Arjan van de Ven <arjan@infradead.org>
This patch makes the possessor permissions on a key additive with
user/group/other permissions on the same key.
This permits extra rights to be granted to the possessor of a key without
taking away any rights conferred by them owning the key or having common group
membership.
The attached patch splits key permissions checking out of key-ui.h and
moves it into a .c file. It's quite large and called quite a lot, and
it's about to get bigger with the addition of LSM support for keys...
key_any_permission() is also discarded as it's no longer used.
The attached patch adds documentation for the process by which request-key
works, including how it permits helper processes to gain access to the
requestor's keyrings.
Plug request_key_auth memleak. This can be triggered by unprivileged
users, so is local DoS.
The attached patch adds extra permission grants to keys for the possessor of a
key in addition to the owner, group and other permissions bits. This makes
SUID binaries easier to support without going as far as labelling keys and key
targets using the LSM facilities.
This patch adds a second "pointer type" to key structures (struct key_ref *)
that can have the bottom bit of the address set to indicate the possession of
a key. This is propagated through searches from the keyring to the discovered
key. It has been made a separate type so that the compiler can spot attempts
to dereference a potentially incorrect pointer.
The "possession" attribute can't be attached to a key structure directly as
it's not an intrinsic property of a key.
Pointers to keys have been replaced with struct key_ref *'s wherever
possession information needs to be passed through.
This does assume that the bottom bit of the pointer will always be zero on
return from kmem_cache_alloc().
The key reference type has been made into a typedef so that at least it can be
located in the sources, even though it's basically a pointer to an undefined
type. I've also renamed the accessor functions to be more useful, and all
reference variables should now end in "_ref".
The attached patch makes sure that a keyring that failed to instantiate
properly is destroyed without oopsing [CAN-2005-2099].
The problem occurs in three stages:
(1) The key allocator initialises the type-specific data to all zeroes. In
the case of a keyring, this will become a link in the keyring name list
when the keyring is instantiated.
(2) If a user (any user) attempts to add a keyring with anything other than
an empty payload, the keyring instantiation function will fail with an
error and won't add the keyring to the name list.
(3) The keyring's destructor then sees that the keyring has a description
(name) and tries to remove the keyring from the name list, which oopses
because the link pointers are both zero.
This bug permits any user to take down a box trivially.
semaphore pinned
The attached patch prevents an error during the key session joining operation
from hanging future joins in the D state [CAN-2005-2098].
The problem is that the error handling path for the KEYCTL_JOIN_SESSION_KEYRING
operation has one error path that doesn't release the session management
semaphore. Further attempts to get the semaphore will then sleep for ever in
the D state.
This can happen in four situations, all involving an attempt to allocate a new
session keyring:
(1) ENOMEM.
(2) The users key quota being reached.
(3) A keyring name that is an empty string.
(4) A keyring name that is too long.
Any user may attempt this operation, and so any user can cause the problem to
occur.
This fixes five bugs in the key management syscall interface:
(1) add_key() returns 0 rather than EINVAL if the key type is "".
Checking the key type isn't "" should be left to lookup_user_key().
(2) request_key() returns ENOKEY rather than EPERM if the key type begins
with a ".".
lookup_user_key() can't do this because internal key types begin with a
(3) Key revocation always returns 0, even if it fails.
(4) Key read can return EAGAIN rather than EACCES under some circumstances.
A key is permitted to by read by a process if it doesn't grant read
access, but it does grant search access and it is in the process's
keyrings. That search returns EAGAIN if it fails, and this needs
translating to EACCES.
(5) request_key() never adds the new key to the destination keyring if one is
supplied.
The wrong macro was being used to test for an error condition: PTR_ERR()
will always return true, whether or not there's an error; this should've
been IS_ERR().
Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
The attached patch makes the keyring functions calculate the new size of a
keyring's payload based on the size of pointer to the key struct, not the size
of the key struct itself.
2.6.12-rc6-mm1 has a few remaining synchronize_kernel()s, some (but not
all) in comments. This patch changes these synchronize_kernel() calls (and
comments) to synchronize_rcu() or synchronize_sched() as follows:
- arch/x86_64/kernel/mce.c mce_read(): change to synchronize_sched() to
handle races with machine-check exceptions (synchronize_rcu() would not cut
it given RCU implementations intended for hardcore realtime use.
- drivers/input/serio/i8042.c i8042_stop(): change to synchronize_sched() to
handle races with i8042_interrupt() interrupt handler. Again,
synchronize_rcu() would not cut it given RCU implementations intended for
- include/*/kdebug.h comments: change to synchronize_sched() to handle races
with NMIs. As before, synchronize_rcu() would not cut it...
- include/linux/list.h comment: change to synchronize_rcu(), since this
comment is for list_del_rcu().
- security/keys/key.c unregister_key_type(): change to synchronize_rcu(),
since this is interacting with RCU read side.
- security/keys/process_keys.c install_session_keyring(): change to
synchronize_rcu(), since this is interacting with RCU read side.
Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com>
Export this symbol to GPL modules for eCryptfs: an out-of-tree GPL'ed
filesystem.
Signed off by: Michael Halcrow <mhalcrow@us.ibm.com>
The attached patch makes the following changes:
(1) There's a new special key type called ".request_key_auth".
This is an authorisation key for when one process requests a key and
another process is started to construct it. This type of key cannot be
created by the user; nor can it be requested by kernel services.
Authorisation keys hold two references:
(a) Each refers to a key being constructed. When the key being
constructed is instantiated the authorisation key is revoked,
rendering it of no further use.
(b) The "authorising process". This is either:
(i) the process that called request_key(), or:
(ii) if the process that called request_key() itself had an
authorisation key in its session keyring, then the authorising
process referred to by that authorisation key will also be
referred to by the new authorisation key.
This means that the process that initiated a chain of key requests
will authorise the lot of them, and will, by default, wind up with
the keys obtained from them in its keyrings.
(2) request_key() creates an authorisation key which is then passed to
/sbin/request-key in as part of a new session keyring.
(3) When request_key() is searching for a key to hand back to the caller, if
it comes across an authorisation key in the session keyring of the
calling process, it will also search the keyrings of the process
specified therein and it will use the specified process's credentials
(fsuid, fsgid, groups) to do that rather than the calling process's
credentials.
This allows a process started by /sbin/request-key to find keys belonging
to the authorising process.
(4) A key can be read, even if the process executing KEYCTL_READ doesn't have
direct read or search permission if that key is contained within the
keyrings of a process specified by an authorisation key found within the
calling process's session keyring, and is searchable using the
credentials of the authorising process.
This allows a process started by /sbin/request-key to read keys belonging
(5) The magic KEY_SPEC_*_KEYRING key IDs when passed to KEYCTL_INSTANTIATE or
KEYCTL_NEGATE will specify a keyring of the authorising process, rather
than the process doing the instantiation.
(6) One of the process keyrings can be nominated as the default to which
request_key() should attach new keys if not otherwise specified. This is
done with KEYCTL_SET_REQKEY_KEYRING and one of the KEY_REQKEY_DEFL_*
constants. The current setting can also be read using this call.
(7) request_key() is partially interruptible. If it is waiting for another
process to finish constructing a key, it can be interrupted. This permits
a request-key cycle to be broken without recourse to rebooting.
Signed-Off-By: Benoit Boissinot <benoit.boissinot@ens-lyon.org>
The attached patch uses RCU to manage the session keyring pointer in struct
signal_struct. This means that searching need not disable interrupts and get
a the sighand spinlock to access this pointer. Furthermore, by judicious use
of rcu_read_(un)lock(), this patch also avoids the need to take and put
refcounts on the session keyring itself, thus saving on even more atomic ops.
The attached patch makes it possible to pass a session keyring through to the
process spawned by call_usermodehelper(). This allows patch 3/3 to pass an
authorisation key through to /sbin/request-key, thus permitting better access
controls when doing just-in-time key creation.
The attached patch changes the key implementation in a number of ways:
(1) It removes the spinlock from the key structure.
(2) The key flags are now accessed using atomic bitops instead of
write-locking the key spinlock and using C bitwise operators.
The three instantiation flags are dealt with with the construction
semaphore held during the request_key/instantiate/negate sequence, thus
rendering the spinlock superfluous.
The key flags are also now bit numbers not bit masks.
(3) The key payload is now accessed using RCU. This permits the recursive
keyring search algorithm to be simplified greatly since no locks need be
taken other than the usual RCU preemption disablement. Searching now does
not require any locks or semaphores to be held; merely that the starting
keyring be pinned.
(4) The keyring payload now includes an RCU head so that it can be disposed
of by call_rcu(). This requires that the payload be copied on unlink to
prevent introducing races in copy-down vs search-up.
(5) The user key payload is now a structure with the data following it. It
includes an RCU head like the keyring payload and for the same reason. It
also contains a data length because the data length in the key may be
changed on another CPU whilst an RCU protected read is in progress on the
payload. This would then see the supposed RCU payload and the on-key data
length getting out of sync.
I'm tempted to drop the key's datalen entirely, except that it's used in
conjunction with quota management and so is a little tricky to get rid
of.
(6) Update the keys documentation.
infrastructure for it.
Let it rip!
