path: root/security/lsm_audit.c
2013-11-21Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris: "Nothing amazing. Formatting, small bug fixes, couple of fixes where we didn't get records due to some old VFS changes, and a change to how we collect execve info..." Fixed conflict in fs/exec.c as per Eric and linux-next. * git://git.infradead.org/users/eparis/audit: (28 commits) audit: fix type of sessionid in audit_set_loginuid() audit: call audit_bprm() only once to add AUDIT_EXECVE information audit: move audit_aux_data_execve contents into audit_context union audit: remove unused envc member of audit_aux_data_execve audit: Kill the unused struct audit_aux_data_capset audit: do not reject all AUDIT_INODE filter types audit: suppress stock memalloc failure warnings since already managed audit: log the audit_names record type audit: add child record before the create to handle case where create fails audit: use given values in tty_audit enable api audit: use nlmsg_len() to get message payload length audit: use memset instead of trying to initialize field by field audit: fix info leak in AUDIT_GET requests audit: update AUDIT_INODE filter rule to comparator function audit: audit feature to set loginuid immutable audit: audit feature to only allow unsetting the loginuid audit: allow unsetting the loginuid (with priv) audit: remove CONFIG_AUDIT_LOGINUID_IMMUTABLE audit: loginuid functions coding style selinux: apply selinux checks on new audit message types ...
2013-11-05audit: suppress stock memalloc failure warnings since already managedRichard Guy Briggs
Supress the stock memory allocation failure warnings for audit buffers since audit alreay takes care of memory allocation failure warnings, including rate-limiting, in audit_log_start(). Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-10-09net: fix build errors if ipv6 is disabledEric Dumazet
CONFIG_IPV6=n is still a valid choice ;) It appears we can remove dead code. Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-09ipv6: make lookups simpler and fasterEric Dumazet
TCP listener refactoring, part 4 : To speed up inet lookups, we moved IPv4 addresses from inet to struct sock_common Now is time to do the same for IPv6, because it permits us to have fast lookups for all kind of sockets, including upcoming SYN_RECV. Getting IPv6 addresses in TCP lookups currently requires two extra cache lines, plus a dereference (and memory stall). inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6 This patch is way bigger than its IPv4 counter part, because for IPv4, we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6, it's not doable easily. inet6_sk(sk)->daddr becomes sk->sk_v6_daddr inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr at the same offset. We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic macro. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-09LSM: BUILD_BUG_ON if the common_audit_data union ever growsEric Paris
We did a lot of work to shrink the common_audit_data. Add a BUILD_BUG_ON so future programers (let's be honest, probably me) won't do something foolish like make it large again! Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-09LSM: remove the task field from common_audit_dataEric Paris
There are no legitimate users. Always use current and get back some stack space for the common_audit_data. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-03lsm_audit: don't specify the audit pre/post callbacks in 'struct ↵Linus Torvalds
common_audit_data' It just bloats the audit data structure for no good reason, since the only time those fields are filled are just before calling the common_lsm_audit() function, which is also the only user of those fields. So just make them be the arguments to common_lsm_audit(), rather than bloating that structure that is passed around everywhere, and is initialized in hot paths. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03LSM: shrink the common_audit_data data unionEric Paris
After shrinking the common_audit_data stack usage for private LSM data I'm not going to shrink the data union. To do this I'm going to move anything larger than 2 void * ptrs to it's own structure and require it to be declared separately on the calling stack. Thus hot paths which don't need more than a couple pointer don't have to declare space to hold large unneeded structures. I could get this down to one void * by dealing with the key struct and the struct path. We'll see if that is helpful after taking care of networking. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20switch unix_sock to struct pathAl Viro
2012-01-17audit: no leading space in audit_log_d_path prefixKees Cook
audit_log_d_path() injects an additional space before the prefix, which serves no purpose and doesn't mix well with other audit_log*() functions that do not sneak extra characters into the log. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: treat s_id as an untrusted stringKees Cook
The use of s_id should go through the untrusted string path, just to be extra careful. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-12-03ipv6: Add fragment reporting to ipv6_skip_exthdr().Jesse Gross
While parsing through IPv6 extension headers, fragment headers are skipped making them invisible to the caller. This reports the fragment offset of the last header in order to make it possible to determine whether the packet is fragmented and, if so whether it is a first or last fragment. Signed-off-by: Jesse Gross <jesse@nicira.com>
2011-11-22net: remove ipv6_addr_copy()Alexey Dobriyan
C assignment can handle struct in6_addr copying. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-25LSM: separate LSM_AUDIT_DATA_DENTRY from LSM_AUDIT_DATA_PATHEric Paris
This patch separates and audit message that only contains a dentry from one that contains a full path. This allows us to make it harder to misuse the interfaces or for the interfaces to be implemented wrong. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com>
2011-04-25LSM: split LSM_AUDIT_DATA_FS into _PATH and _INODEEric Paris
The lsm common audit code has wacky contortions making sure which pieces of information are set based on if it was given a path, dentry, or inode. Split this into path and inode to get rid of some of the code complexity. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com>
2010-05-06Merge branch 'master' into nextJames Morris
2010-04-28LSM Audit: rename LSM_AUDIT_NO_AUDIT to LSM_AUDIT_DATA_NONEEric Paris
Most of the LSM common audit work uses LSM_AUDIT_DATA_* for the naming. This was not so for LSM_AUDIT_NO_AUDIT which means the generic initializer cannot be used. This patch just renames the flag so the generic initializer can be used. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-05Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/pcmcia/fmvj18x_cs.c drivers/net/pcmcia/nmclan_cs.c drivers/net/pcmcia/xirc2ps_cs.c drivers/net/wireless/ray_cs.c
2009-11-10security: report the module name to security_module_requestEric Paris
For SELinux to do better filtering in userspace we send the name of the module along with the AVC denial when a program is denied module_request. Example output: type=SYSCALL msg=audit(11/03/2009 10:59:43.510:9) : arch=x86_64 syscall=write success=yes exit=2 a0=3 a1=7fc28c0d56c0 a2=2 a3=7fffca0d7440 items=0 ppid=1727 pid=1729 auid=unset uid=root gid=root euid=root suid=root fsuid=root egid=root sgid=root fsgid=root tty=(none) ses=unset comm=rpc.nfsd exe=/usr/sbin/rpc.nfsd subj=system_u:system_r:nfsd_t:s0 key=(null) type=AVC msg=audit(11/03/2009 10:59:43.510:9) : avc: denied { module_request } for pid=1729 comm=rpc.nfsd kmod="net-pf-10" scontext=system_u:system_r:nfsd_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclass=system Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24lsm: Use a compressed IPv6 string format in audit eventsPaul Moore
Currently the audit subsystem prints uncompressed IPv6 addresses which not only differs from common usage but also results in ridiculously large audit strings which is not a good thing. This patch fixes this by simply converting audit to always print compressed IPv6 addresses. Old message example: audit(1253576792.161:30): avc: denied { ingress } for saddr=0000:0000:0000:0000:0000:0000:0000:0001 src=5000 daddr=0000:0000:0000:0000:0000:0000:0000:0001 dest=35502 netif=lo scontext=system_u:object_r:unlabeled_t:s15:c0.c1023 tcontext=system_u:object_r:lo_netif_t:s0-s15:c0.c1023 tclass=netif New message example: audit(1253576792.161:30): avc: denied { ingress } for saddr=::1 src=5000 daddr=::1 dest=35502 netif=lo scontext=system_u:object_r:unlabeled_t:s15:c0.c1023 tcontext=system_u:object_r:lo_netif_t:s0-s15:c0.c1023 tclass=netif Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-08-17SELinux: Convert avc_audit to use lsm_audit.hThomas Liu
Convert avc_audit in security/selinux/avc.c to use lsm_audit.h, for better maintainability. - changed selinux to use common_audit_data instead of avc_audit_data - eliminated code in avc.c and used code from lsm_audit.h instead. Had to add a LSM_AUDIT_NO_AUDIT to lsm_audit.h so that avc_audit can call common_lsm_audit and do the pre and post callbacks without doing the actual dump. This makes it so that the patched version behaves the same way as the unpatched version. Also added a denied field to the selinux_audit_data private space, once again to make it so that the patched version behaves like the unpatched. I've tested and confirmed that AVCs look the same before and after this patch. Signed-off-by: Thomas Liu <tliu@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-14smack: implement logging V3Etienne Basset
This patch creates auditing functions usable by LSM to audit security events. It provides standard dumping of FS, NET, task etc ... events (code borrowed from SELinux) and provides 2 callbacks to define LSM specific auditing, which should be flexible enough to convert SELinux too. Signed-off-by: Etienne Basset <etienne.basset@numericable.fr> Acked-by: Casey Schaufler <casey@schaufler-ca.com> cked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
