path: root/security/lsm_audit.c
2019-03-19missing barriers in some of unix_sock ->addr and ->path accessesAl Viro
[ Upstream commit ae3b564179bfd06f32d051b9e5d72ce4b2a07c37 ] Several u->addr and u->path users are not holding any locks in common with unix_bind(). unix_state_lock() is useless for those purposes. u->addr is assign-once and *(u->addr) is fully set up by the time we set u->addr (all under unix_table_lock). u->path is also set in the same critical area, also before setting u->addr, and any unix_sock with ->path filled will have non-NULL ->addr. So setting ->addr with smp_store_release() is all we need for those "lockless" users - just have them fetch ->addr with smp_load_acquire() and don't even bother looking at ->path if they see NULL ->addr. Users of ->addr and ->path fall into several classes now: 1) ones that do smp_load_acquire(u->addr) and access *(u->addr) and u->path only if smp_load_acquire() has returned non-NULL. 2) places holding unix_table_lock. These are guaranteed that *(u->addr) is seen fully initialized. If unix_sock is in one of the "bound" chains, so's ->path. 3) unix_sock_destructor() using ->addr is safe. All places that set u->addr are guaranteed to have seen all stores *(u->addr) while holding a reference to u and unix_sock_destructor() is called when (atomic) refcount hits zero. 4) unix_release_sock() using ->path is safe. unix_bind() is serialized wrt unix_release() (normally - by struct file refcount), and for the instances that had ->path set by unix_bind() unix_release_sock() comes from unix_release(), so they are fine. Instances that had it set in unix_stream_connect() either end up attached to a socket (in unix_accept()), in which case the call chain to unix_release_sock() and serialization are the same as in the previous case, or they never get accept'ed and unix_release_sock() is called when the listener is shut down and its queue gets purged. In that case the listener's queue lock provides the barriers needed - unix_stream_connect() shoves our unix_sock into listener's queue under that lock right after having set ->path and eventual unix_release_sock() caller picks them from that queue under the same lock right before calling unix_release_sock(). 5) unix_find_other() use of ->path is pointless, but safe - it happens with successful lookup by (abstract) name, so ->path.dentry is guaranteed to be NULL there. earlier-variant-reviewed-by: "Paul E. McKenney" <paulmck@linux.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-14audit: use inline function to get audit contextRichard Guy Briggs
Recognizing that the audit context is an internal audit value, use an access function to retrieve the audit context pointer for the task rather than reaching directly into the task struct to get it. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: merge fuzz in auditsc.c and selinuxfs.c, checkpatch.pl fixes] Signed-off-by: Paul Moore <paul@paul-moore.com>
2017-08-17lsm_audit: update my email addressStephen Smalley
Update my email address since epoch.ncsc.mil no longer exists. MAINTAINERS and CREDITS are already correct. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <paul@paul-moore.com>
2017-05-23selinux: Add IB Port SMP access vectorDaniel Jurgens
Add a type for Infiniband ports and an access vector for subnet management packets. Implement the ib_port_smp hook to check that the caller has permission to send and receive SMPs on the end port specified by the device name and port. Add interface to query the SID for a IB port, which walks the IB_PORT ocontexts to find an entry for the given name and port. Signed-off-by: Daniel Jurgens <danielj@mellanox.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Acked-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2017-05-23selinux: Implement Infiniband PKey "Access" access vectorDaniel Jurgens
Add a type and access vector for PKeys. Implement the ib_pkey_access hook to check that the caller has permission to access the PKey on the given subnet prefix. Add an interface to get the PKey SID. Walk the PKey ocontexts to find an entry for the given subnet prefix and pkey. Signed-off-by: Daniel Jurgens <danielj@mellanox.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Acked-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-10-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: SELinux/LSM: - overlayfs support, necessary for container filesystems LSM: - finally remove the kernel_module_from_file hook Smack: - treat signal delivery as an 'append' operation TPM: - lots of bugfixes & updates Audit: - new audit data type: LSM_AUDIT_DATA_FILE * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (47 commits) Revert "tpm/tpm_crb: implement tpm crb idle state" Revert "tmp/tpm_crb: fix Intel PTT hw bug during idle state" Revert "tpm/tpm_crb: open code the crb_init into acpi_add" Revert "tmp/tpm_crb: implement runtime pm for tpm_crb" lsm,audit,selinux: Introduce a new audit data type LSM_AUDIT_DATA_FILE tmp/tpm_crb: implement runtime pm for tpm_crb tpm/tpm_crb: open code the crb_init into acpi_add tmp/tpm_crb: fix Intel PTT hw bug during idle state tpm/tpm_crb: implement tpm crb idle state tpm: add check for minimum buffer size in tpm_transmit() tpm: constify TPM 1.x header structures tpm/tpm_crb: fix the over 80 characters checkpatch warring tpm/tpm_crb: drop useless cpu_to_le32 when writing to registers tpm/tpm_crb: cache cmd_size register value. tmp/tpm_crb: drop include to platform_device tpm/tpm_tis: remove unused itpm variable tpm_crb: fix incorrect values of cmdReady and goIdle bits tpm_crb: refine the naming of constants tpm_crb: remove wmb()'s tpm_crb: fix crb_req_canceled behavior ...
2016-09-19lsm,audit,selinux: Introduce a new audit data type LSM_AUDIT_DATA_FILEVivek Goyal
Right now LSM_AUDIT_DATA_PATH type contains "struct path" in union "u" of common_audit_data. This information is used to print path of file at the same time it is also used to get to dentry and inode. And this inode information is used to get to superblock and device and print device information. This does not work well for layered filesystems like overlay where dentry contained in path is overlay dentry and not the real dentry of underlying file system. That means inode retrieved from dentry is also overlay inode and not the real inode. SELinux helpers like file_path_has_perm() are doing checks on inode retrieved from file_inode(). This returns the real inode and not the overlay inode. That means we are doing check on real inode but for audit purposes we are printing details of overlay inode and that can be confusing while debugging. Hence, introduce a new type LSM_AUDIT_DATA_FILE which carries file information and inode retrieved is real inode using file_inode(). That way right avc denied information is given to user. For example, following is one example avc before the patch. type=AVC msg=audit(1473360868.399:214): avc: denied { read open } for pid=1765 comm="cat" path="/root/.../overlay/container1/merged/readfile" dev="overlay" ino=21443 scontext=unconfined_u:unconfined_r:test_overlay_client_t:s0:c10,c20 tcontext=unconfined_u:object_r:test_overlay_files_ro_t:s0 tclass=file permissive=0 It looks as follows after the patch. type=AVC msg=audit(1473360017.388:282): avc: denied { read open } for pid=2530 comm="cat" path="/root/.../overlay/container1/merged/readfile" dev="dm-0" ino=2377915 scontext=unconfined_u:unconfined_r:test_overlay_client_t:s0:c10,c20 tcontext=unconfined_u:object_r:test_overlay_files_ro_t:s0 tclass=file permissive=0 Notice that now dev information points to "dm-0" device instead of "overlay" device. This makes it clear that check failed on underlying inode and not on the overlay inode. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> [PM: slight tweaks to the description to make checkpatch.pl happy] Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-30audit: consistently record PIDs with task_tgid_nr()Paul Moore
Unfortunately we record PIDs in audit records using a variety of methods despite the correct way being the use of task_tgid_nr(). This patch converts all of these callers, except for the case of AUDIT_SET in audit_receive_msg() (see the comment in the code). Reported-by: Jeff Vander Stoep <jeffv@google.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08selinux: print leading 0x on ioctlcmd auditsWilliam Roberts
ioctlcmd is currently printing hex numbers, but their is no leading 0x. Thus things like ioctlcmd=1234 are misleading, as the base is not evident. Correct this by adding 0x as a prefix, so ioctlcmd=1234 becomes ioctlcmd=0x1234. Signed-off-by: William Roberts <william.c.roberts@intel.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08security: Use IS_ENABLED() instead of checking for built-in or moduleJavier Martinez Canillas
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled either built-in or as a module, use that macro instead of open coding the same. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2015-08-15Merge branch 'next' of git://git.infradead.org/users/pcmoore/selinux into nextJames Morris
2015-07-13security: add ioctl specific auditing to lsm_auditJeff Vander Stoep
Add information about ioctl calls to the LSM audit data. Log the file path and command number. Signed-off-by: Jeff Vander Stoep <jeffv@google.com> Acked-by: Nick Kralevich <nnk@google.com> [PM: subject line tweak] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-06-27Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Four small audit patches for v4.2, all bug fixes. Only 10 lines of change this time so very unremarkable, the patch subject lines pretty much tell the whole story" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: Fix check of return value of strnlen_user() audit: obsolete audit_context check is removed in audit_filter_rules() audit: fix for typo in comment to function audit_log_link_denied() lsm: rename duplicate labels in LSM_AUDIT_DATA_TASK audit message type
2015-05-29lsm: rename duplicate labels in LSM_AUDIT_DATA_TASK audit message typeRichard Guy Briggs
The LSM_AUDIT_DATA_TASK pid= and comm= labels are duplicates of those at the start of this function with different values. Rename them to their object counterparts opid= and ocomm= to disambiguate. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: minor merging needed due to differences in the tree] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-15VFS: security/: d_backing_inode() annotationsDavid Howells
most of the ->d_inode uses there refer to the same inode IO would go to, i.e. d_backing_inode() Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-15lsm: copy comm before calling audit_log to avoid race in string printingRichard Guy Briggs
When task->comm is passed directly to audit_log_untrustedstring() without getting a copy or using the task_lock, there is a race that could happen that would output a NULL (\0) in the middle of the output string that would effectively truncate the rest of the report text after the comm= field in the audit log message, losing fields. Using get_task_comm() to get a copy while acquiring the task_lock to prevent this and to prevent the result from being a mixture of old and new values of comm would incur potentially unacceptable overhead, considering that the value can be influenced by userspace and therefore untrusted anyways. Copy the value before passing it to audit_log_untrustedstring() ensures that a local copy is used to calculate the length *and* subsequently printed. Even if this value contains a mix of old and new values, it will only calculate and copy up to the first NULL, preventing the rest of the audit log message being truncated. Use a second local copy of comm to avoid a race between the first and second calls to audit_log_untrustedstring() with comm. Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-03-20audit: anchor all pid references in the initial pid namespaceRichard Guy Briggs
Store and log all PIDs with reference to the initial PID namespace and use the access functions task_pid_nr() and task_tgid_nr() for task->pid and task->tgid. Cc: "Eric W. Biederman" <ebiederm@xmission.com> (informed by ebiederman's c776b5d2) Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2013-11-21Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris: "Nothing amazing. Formatting, small bug fixes, couple of fixes where we didn't get records due to some old VFS changes, and a change to how we collect execve info..." Fixed conflict in fs/exec.c as per Eric and linux-next. * git://git.infradead.org/users/eparis/audit: (28 commits) audit: fix type of sessionid in audit_set_loginuid() audit: call audit_bprm() only once to add AUDIT_EXECVE information audit: move audit_aux_data_execve contents into audit_context union audit: remove unused envc member of audit_aux_data_execve audit: Kill the unused struct audit_aux_data_capset audit: do not reject all AUDIT_INODE filter types audit: suppress stock memalloc failure warnings since already managed audit: log the audit_names record type audit: add child record before the create to handle case where create fails audit: use given values in tty_audit enable api audit: use nlmsg_len() to get message payload length audit: use memset instead of trying to initialize field by field audit: fix info leak in AUDIT_GET requests audit: update AUDIT_INODE filter rule to comparator function audit: audit feature to set loginuid immutable audit: audit feature to only allow unsetting the loginuid audit: allow unsetting the loginuid (with priv) audit: remove CONFIG_AUDIT_LOGINUID_IMMUTABLE audit: loginuid functions coding style selinux: apply selinux checks on new audit message types ...
2013-11-05audit: suppress stock memalloc failure warnings since already managedRichard Guy Briggs
Supress the stock memory allocation failure warnings for audit buffers since audit alreay takes care of memory allocation failure warnings, including rate-limiting, in audit_log_start(). Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-10-09net: fix build errors if ipv6 is disabledEric Dumazet
CONFIG_IPV6=n is still a valid choice ;) It appears we can remove dead code. Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-09ipv6: make lookups simpler and fasterEric Dumazet
TCP listener refactoring, part 4 : To speed up inet lookups, we moved IPv4 addresses from inet to struct sock_common Now is time to do the same for IPv6, because it permits us to have fast lookups for all kind of sockets, including upcoming SYN_RECV. Getting IPv6 addresses in TCP lookups currently requires two extra cache lines, plus a dereference (and memory stall). inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6 This patch is way bigger than its IPv4 counter part, because for IPv4, we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6, it's not doable easily. inet6_sk(sk)->daddr becomes sk->sk_v6_daddr inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr at the same offset. We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic macro. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-09LSM: BUILD_BUG_ON if the common_audit_data union ever growsEric Paris
We did a lot of work to shrink the common_audit_data. Add a BUILD_BUG_ON so future programers (let's be honest, probably me) won't do something foolish like make it large again! Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-09LSM: remove the task field from common_audit_dataEric Paris
There are no legitimate users. Always use current and get back some stack space for the common_audit_data. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-03lsm_audit: don't specify the audit pre/post callbacks in 'struct ↵Linus Torvalds
common_audit_data' It just bloats the audit data structure for no good reason, since the only time those fields are filled are just before calling the common_lsm_audit() function, which is also the only user of those fields. So just make them be the arguments to common_lsm_audit(), rather than bloating that structure that is passed around everywhere, and is initialized in hot paths. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03LSM: shrink the common_audit_data data unionEric Paris
After shrinking the common_audit_data stack usage for private LSM data I'm not going to shrink the data union. To do this I'm going to move anything larger than 2 void * ptrs to it's own structure and require it to be declared separately on the calling stack. Thus hot paths which don't need more than a couple pointer don't have to declare space to hold large unneeded structures. I could get this down to one void * by dealing with the key struct and the struct path. We'll see if that is helpful after taking care of networking. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20switch unix_sock to struct pathAl Viro
2012-01-17audit: no leading space in audit_log_d_path prefixKees Cook
audit_log_d_path() injects an additional space before the prefix, which serves no purpose and doesn't mix well with other audit_log*() functions that do not sneak extra characters into the log. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-17audit: treat s_id as an untrusted stringKees Cook
The use of s_id should go through the untrusted string path, just to be extra careful. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-12-03ipv6: Add fragment reporting to ipv6_skip_exthdr().Jesse Gross
While parsing through IPv6 extension headers, fragment headers are skipped making them invisible to the caller. This reports the fragment offset of the last header in order to make it possible to determine whether the packet is fragmented and, if so whether it is a first or last fragment. Signed-off-by: Jesse Gross <jesse@nicira.com>
2011-11-22net: remove ipv6_addr_copy()Alexey Dobriyan
C assignment can handle struct in6_addr copying. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-25LSM: separate LSM_AUDIT_DATA_DENTRY from LSM_AUDIT_DATA_PATHEric Paris
This patch separates and audit message that only contains a dentry from one that contains a full path. This allows us to make it harder to misuse the interfaces or for the interfaces to be implemented wrong. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com>
2011-04-25LSM: split LSM_AUDIT_DATA_FS into _PATH and _INODEEric Paris
The lsm common audit code has wacky contortions making sure which pieces of information are set based on if it was given a path, dentry, or inode. Split this into path and inode to get rid of some of the code complexity. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com>
2010-05-06Merge branch 'master' into nextJames Morris
2010-04-28LSM Audit: rename LSM_AUDIT_NO_AUDIT to LSM_AUDIT_DATA_NONEEric Paris
Most of the LSM common audit work uses LSM_AUDIT_DATA_* for the naming. This was not so for LSM_AUDIT_NO_AUDIT which means the generic initializer cannot be used. This patch just renames the flag so the generic initializer can be used. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-05Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/pcmcia/fmvj18x_cs.c drivers/net/pcmcia/nmclan_cs.c drivers/net/pcmcia/xirc2ps_cs.c drivers/net/wireless/ray_cs.c
2009-11-10security: report the module name to security_module_requestEric Paris
For SELinux to do better filtering in userspace we send the name of the module along with the AVC denial when a program is denied module_request. Example output: type=SYSCALL msg=audit(11/03/2009 10:59:43.510:9) : arch=x86_64 syscall=write success=yes exit=2 a0=3 a1=7fc28c0d56c0 a2=2 a3=7fffca0d7440 items=0 ppid=1727 pid=1729 auid=unset uid=root gid=root euid=root suid=root fsuid=root egid=root sgid=root fsgid=root tty=(none) ses=unset comm=rpc.nfsd exe=/usr/sbin/rpc.nfsd subj=system_u:system_r:nfsd_t:s0 key=(null) type=AVC msg=audit(11/03/2009 10:59:43.510:9) : avc: denied { module_request } for pid=1729 comm=rpc.nfsd kmod="net-pf-10" scontext=system_u:system_r:nfsd_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclass=system Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24lsm: Use a compressed IPv6 string format in audit eventsPaul Moore
Currently the audit subsystem prints uncompressed IPv6 addresses which not only differs from common usage but also results in ridiculously large audit strings which is not a good thing. This patch fixes this by simply converting audit to always print compressed IPv6 addresses. Old message example: audit(1253576792.161:30): avc: denied { ingress } for saddr=0000:0000:0000:0000:0000:0000:0000:0001 src=5000 daddr=0000:0000:0000:0000:0000:0000:0000:0001 dest=35502 netif=lo scontext=system_u:object_r:unlabeled_t:s15:c0.c1023 tcontext=system_u:object_r:lo_netif_t:s0-s15:c0.c1023 tclass=netif New message example: audit(1253576792.161:30): avc: denied { ingress } for saddr=::1 src=5000 daddr=::1 dest=35502 netif=lo scontext=system_u:object_r:unlabeled_t:s15:c0.c1023 tcontext=system_u:object_r:lo_netif_t:s0-s15:c0.c1023 tclass=netif Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-08-17SELinux: Convert avc_audit to use lsm_audit.hThomas Liu
Convert avc_audit in security/selinux/avc.c to use lsm_audit.h, for better maintainability. - changed selinux to use common_audit_data instead of avc_audit_data - eliminated code in avc.c and used code from lsm_audit.h instead. Had to add a LSM_AUDIT_NO_AUDIT to lsm_audit.h so that avc_audit can call common_lsm_audit and do the pre and post callbacks without doing the actual dump. This makes it so that the patched version behaves the same way as the unpatched version. Also added a denied field to the selinux_audit_data private space, once again to make it so that the patched version behaves like the unpatched. I've tested and confirmed that AVCs look the same before and after this patch. Signed-off-by: Thomas Liu <tliu@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-14smack: implement logging V3Etienne Basset
This patch creates auditing functions usable by LSM to audit security events. It provides standard dumping of FS, NET, task etc ... events (code borrowed from SELinux) and provides 2 callbacks to define LSM specific auditing, which should be flexible enough to convert SELinux too. Signed-off-by: Etienne Basset <etienne.basset@numericable.fr> Acked-by: Casey Schaufler <casey@schaufler-ca.com> cked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
