path: root/security/selinux
2005-09-30[PATCH] SELinux - fix SCTP socket bug and general IP protocol handlingJames Morris
The following patch updates the way SELinux classifies and handles IP based protocols. Currently, IP sockets are classified by SELinux as being either TCP, UDP or 'Raw', the latter being a default for IP socket that is not TCP or UDP. The classification code is out of date and uses only the socket type parameter to socket(2) to determine the class of IP socket. So, any socket created with SOCK_STREAM will be classified by SELinux as TCP, and SOCK_DGRAM as UDP. Also, other socket types such as SOCK_SEQPACKET and SOCK_DCCP are currently ignored by SELinux, which classifies them as generic sockets, which means they don't even get basic IP level checking. This patch changes the SELinux IP socket classification logic, so that only an IPPROTO_IP protocol value passed to socket(2) classify the socket as TCP or UDP. The patch also drops the check for SOCK_RAW and converts it into a default, so that socket types like SOCK_DCCP and SOCK_SEQPACKET are classified as SECCLASS_RAWIP_SOCKET (instead of generic sockets). Note that protocol-specific support for SCTP, DCCP etc. is not addressed here, we're just getting these protocols checked at the IP layer. This fixes a reported problem where SCTP sockets were being recognized as generic SELinux sockets yet still being passed in one case to an IP level check, which then fails for generic sockets. It will also fix bugs where any SOCK_STREAM socket is classified as TCP or any SOCK_DGRAM socket is classified as UDP. This patch also unifies the way IP sockets classes are determined in selinux_socket_bind(), so we use the already calculated value instead of trying to recalculate it. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/dwmw2/audit-2.6 Linus Torvalds
2005-09-09[PATCH] files: lock-free fd look-upDipankar Sarma
With the use of RCU in files structure, the look-up of files using fds can now be lock-free. The lookup is protected by rcu_read_lock()/rcu_read_unlock(). This patch changes the readers to use lock-free lookup. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Ravikiran Thirumalai <kiran_th@gmail.com> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: break up files structDipankar Sarma
In order for the RCU to work, the file table array, sets and their sizes must be updated atomically. Instead of ensuring this through too many memory barriers, we put the arrays and their sizes in a separate structure. This patch takes the first step of putting the file table elements in a separate structure fdtable that is embedded withing files_struct. It also changes all the users to refer to the file table using files_fdtable() macro. Subsequent applciation of RCU becomes easier after this. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] remove the inode_post_link and inode_post_rename LSM hooksStephen Smalley
This patch removes the inode_post_link and inode_post_rename LSM hooks as they are unused (and likely useless). Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] Remove security_inode_post_create/mkdir/symlink/mknod hooksStephen Smalley
This patch removes the inode_post_create/mkdir/mknod/symlink LSM hooks as they are obsoleted by the new inode_init_security hook that enables atomic inode security labeling. If anyone sees any reason to retain these hooks, please speak now. Also, is anyone using the post_rename/link hooks; if not, those could also be removed. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] tmpfs: Enable atomic inode security labelingStephen Smalley
This patch modifies tmpfs to call the inode_init_security LSM hook to set up the incore inode security state for new inodes before the inode becomes accessible via the dcache. As there is no underlying storage of security xattrs in this case, it is not necessary for the hook to return the (name, value, len) triple to the tmpfs code, so this patch also modifies the SELinux hook function to correctly handle the case where the (name, value, len) pointers are NULL. The hook call is needed in tmpfs in order to support proper security labeling of tmpfs inodes (e.g. for udev with tmpfs /dev in Fedora). With this change in place, we should then be able to remove the security_inode_post_create/mkdir/... hooks safely. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] security: enable atomic inode security labelingStephen Smalley
The following patch set enables atomic security labeling of newly created inodes by altering the fs code to invoke a new LSM hook to obtain the security attribute to apply to a newly created inode and to set up the incore inode security state during the inode creation transaction. This parallels the existing processing for setting ACLs on newly created inodes. Otherwise, it is possible for new inodes to be accessed by another thread via the dcache prior to complete security setup (presently handled by the post_create/mkdir/... LSM hooks in the VFS) and a newly created inode may be left unlabeled on the disk in the event of a crash. SELinux presently works around the issue by ensuring that the incore inode security label is initialized to a special SID that is inaccessible to unprivileged processes (in accordance with policy), thereby preventing inappropriate access but potentially causing false denials on legitimate accesses. A simple test program demonstrates such false denials on SELinux, and the patch solves the problem. Similar such false denials have been encountered in real applications. This patch defines a new inode_init_security LSM hook to obtain the security attribute to apply to a newly created inode and to set up the incore inode security state for it, and adds a corresponding hook function implementation to SELinux. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] selinux: endian notationsAlexey Dobriyan
This patch adds endian notations to the SELinux code. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] selinux: Reduce memory use by avtabStephen Smalley
This patch improves memory use by SELinux by both reducing the avtab node size and reducing the number of avtab nodes. The memory savings are substantial, e.g. on a 64-bit system after boot, James Morris reported the following data for the targeted and strict policies: #objs objsize kernmem Targeted: Before: 237888 40 9.1MB After: 19968 24 468KB Strict: Before: 571680 40 21.81MB After: 221052 24 5.06MB The improvement in memory use comes at a cost in the speed of security server computations of access vectors, but these computations are only required on AVC cache misses, and performance measurements by James Morris using a number of benchmarks have shown that the change does not cause any significant degradation. Note that a rebuilt policy via an updated policy toolchain (libsepol/checkpolicy) is required in order to gain the full benefits of this patch, although some memory savings benefits are immediately applied even to older policies (in particular, the reduction in avtab node size). Sources for the updated toolchain are presently available from the sourceforge CVS tree (http://sourceforge.net/cvs/?group_id=21266), and tarballs are available from http://www.flux.utah.edu/~sds. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[SELINUX]: Update for tcp_diag rename to inet_diag.James Morris
Also, support dccp sockets. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add "groups" argument to netlink_kernel_createPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
2005-08-29[NETLINK]: Fix missing dst_groups initializations in netlink_broadcast usersPatrick McHardy
netlink_broadcast users must initialize NETLINK_CB(skb).dst_groups to the destination group mask for netlink_recvmsg. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add properly module refcounting for kernel netlink sockets.Harald Welte
- Remove bogus code for compiling netlink as module - Add module refcounting support for modules implementing a netlink protocol - Add support for autoloading modules that implement a netlink protocol as soon as someone opens a socket for that protocol Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-09Merge with /shiny/git/linux-2.6/.gitDavid Woodhouse
2005-07-28[PATCH] selinux: Fix address length checks in connect hookStephen Smalley
This patch fixes the address length checks in the selinux_socket_connect hook to be no more restrictive than the underlying ipv4 and ipv6 code; otherwise, this hook can reject valid connect calls. This patch is in response to a bug report where an application was calling connect on an INET6 socket with an address that didn't include the optional scope id and failing due to these checks. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] SELinux: default labeling of MLS fieldJames Morris
Implement kernel labeling of the MLS (multilevel security) field of security contexts for files which have no existing MLS field. This is to enable upgrades of a system from non-MLS to MLS without performing a full filesystem relabel including all of the mountpoints, which would be quite painful for users. With this patch, with MLS enabled, if a file has no MLS field, the kernel internally adds an MLS field to the in-core inode (but not to the on-disk file). This MLS field added is the default for the superblock, allowing per-mountpoint control over the values via fixed policy or mount options. This patch has been tested by enabling MLS without relabeling its filesystem, and seems to be working correctly. Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Stephen Smalley <sds@epoch.ncsc.mil> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-02Merge with master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
2005-06-30[PATCH] selinux_sb_copy_data() should not require a whole pageEric Paris
Currently selinux_sb_copy_data requires an entire page be allocated to *orig when the function is called. This "requirement" is based on the fact that we call copy_page(in_save, nosec_save) and in_save = orig when the data is not FS_BINARY_MOUNTDATA. This means that if a caller were to call do_kern_mount with only about 10 bytes of options, they would get passed here and then we would corrupt PAGE_SIZE - 10 bytes of memory (with all zeros.) Currently it appears all in kernel FS's use one page of data so this has not been a problem. An out of kernel FS did just what is described above and it would almost always panic shortly after they tried to mount. From looking else where in the kernel it is obvious that this string of data must always be null terminated. (See example in do_mount where it always zeros the last byte.) Thus I suggest we use strcpy in place of copy_page. In this way we make sure the amount we copy is always less than or equal to the amount we received and since do_mount is zeroing the last byte this should be safe for all. Signed-off-by: Eric Paris <eparis@parisplace.org> Cc: Stephen Smalley <sds@epoch.ncsc.mil> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] selinux: kfree cleanupJesper Juhl
kfree(NULL) is legal. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] selinux: add executable heap checkLorenzo Hernández García-Hierro
This patch,based on sample code by Roland McGrath, adds an execheap permission check that controls the ability to make the heap executable so that this can be prevented in almost all cases (the X server is presently an exception, but this will hopefully be resolved in the future) so that even programs with execmem permission will need to have the anonymous memory mapped in order to make it executable. The only reason that we use a permission check for such restriction (vs. making it unconditional) is that the X module loader presently needs it; it could possibly be made unconditional in the future when X is changed. The policy patch for the execheap permission is available at: http://pearls.tuxedo-es.org/patches/selinux/policy-execheap.patch Signed-off-by: Lorenzo Hernandez Garcia-Hierro <lorenzo@gnu.org> Acked-by: James Morris <jmorris@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] selinux: add executable stack checkLorenzo Hernandez García-Hierro
This patch adds an execstack permission check that controls the ability to make the main process stack executable so that attempts to make the stack executable can still be prevented even if the process is allowed the existing execmem permission in order to e.g. perform runtime code generation. Note that this does not yet address thread stacks. Note also that unlike the execmem check, the execstack check is only applied on mprotect calls, not mmap calls, as the current security_file_mmap hook is not passed the necessary information presently. The original author of the code that makes the distinction of the stack region, is Ingo Molnar, who wrote it within his patch for /proc/<pid>/maps markers. (http://marc.theaimsgroup.com/?l=linux-kernel&m=110719881508591&w=2) The patches also can be found at: http://pearls.tuxedo-es.org/patches/selinux/policy-execstack.patch http://pearls.tuxedo-es.org/patches/selinux/kernel-execstack.patch policy-execstack.patch is the patch that needs to be applied to the policy in order to support the execstack permission and exclude it from general_domain_access within macros/core_macros.te. kernel-execstack.patch adds such permission to the SELinux code within the kernel and adds the proper permission check to the selinux_file_mprotect() hook. Signed-off-by: Lorenzo Hernandez Garcia-Hierro <lorenzo@gnu.org> Acked-by: James Morris <jmorris@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22AUDIT: Wait for backlog to clear when generating messages.David Woodhouse
Add a gfp_mask to audit_log_start() and audit_log(), to reduce the amount of GFP_ATOMIC allocation -- most of it doesn't need to be GFP_ATOMIC. Also if the mask includes __GFP_WAIT, then wait up to 60 seconds for the auditd backlog to clear instead of immediately abandoning the message. The timeout should probably be made configurable, but for now it'll suffice that it only happens if auditd is actually running. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-06-21[PATCH] SELinux: memory leak in selinux_sb_copy_data()Gerald Schaefer
There is a memory leak during mount when SELinux is active and mount options are specified. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Acked-by: Stephen Smalley <sds@epoch.ncsc.mil> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-18[NETLINK]: Neighbour table configuration and statistics via rtnetlinkThomas Graf
To retrieve the neighbour tables send RTM_GETNEIGHTBL with the NLM_F_DUMP flag set. Every neighbour table configuration is spread over multiple messages to avoid running into message size limits on systems with many interfaces. The first message in the sequence transports all not device specific data such as statistics, configuration, and the default parameter set. This message is followed by 0..n messages carrying device specific parameter sets. Although the ordering should be sufficient, NDTA_NAME can be used to identify sequences. The initial message can be identified by checking for NDTA_CONFIG. The device specific messages do not contain this TLV but have NDTPA_IFINDEX set to the corresponding interface index. To change neighbour table attributes, send RTM_SETNEIGHTBL with NDTA_NAME set. Changeable attribute include NDTA_THRESH[1-3], NDTA_GC_INTERVAL, and all TLVs in NDTA_PARMS unless marked otherwise. Device specific parameter sets can be changed by setting NDTPA_IFINDEX to the interface index of the corresponding device. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-24AUDIT: Fix remaining cases of direct logging of untrusted strings by avc_auditStephen Smalley
Per Steve Grubb's observation that there are some remaining cases where avc_audit() directly logs untrusted strings without escaping them, here is a patch that changes avc_audit() to use audit_log_untrustedstring() or audit_log_hex() as appropriate. Note that d_name.name is nul- terminated by d_alloc(), and that sun_path is nul-terminated by unix_mkname(), so it is not necessary for the AVC to create nul- terminated copies or to alter audit_log_untrustedstring to take a length argument. In the case of an abstract name, we use audit_log_hex() with an explicit length. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-21Fix oops due to thinko in avc_audit()David Woodhouse
When I added the logging of pid= and comm= back to avc_audit() I screwed it up. Put it back how it should be. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-21AUDIT: Avoid sleeping function in SElinux AVC audit.Stephen Smalley
This patch changes the SELinux AVC to defer logging of paths to the audit framework upon syscall exit, by saving a reference to the (dentry,vfsmount) pair in an auxiliary audit item on the current audit context for processing by audit_log_exit. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-19Merge with master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
2005-05-19Restore logging of pid= and comm= in AVC audit messagesDavid Woodhouse
We turned this all off because the 'exe=' was causing deadlocks on dcache_lock. There's no need to leave the pid and comm out though. They'll all be logged correctly if full auditing is enabled, but we should still print them in case auditing _isn't_ enabled. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-18AUDIT: Treat all user messages identically.David Woodhouse
It's silly to have to add explicit entries for new userspace messages as we invent them. Just treat all messages in the user range the same. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-17[PATCH] selinux: fix avc_alloc_node() oom with no policy loadedStephen Smalley
This patch should fix the avc_alloc_node() oom condition that Andrew reported when no policy is loaded in SELinux. Prior to this patch, when no policy was loaded, the SELinux "security server" (policy engine) was only returning allowed decisions for the requested permissions for each access check. This caused the cache to thrash when trying to use SELinux for real work with no policy loaded (typically, the no policy loaded state is only for bootstrapping to the point where we can load an initial policy). This patch changes the SELinux security server to return the complete allowed access vector at once, and then to reset the cache after the initial policy load to flush the initial cache state created during bootstrapping. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-13AUDIT: Add message types to audit recordsSteve Grubb
This patch adds more messages types to the audit subsystem so that audit analysis is quicker, intuitive, and more useful. Signed-off-by: Steve Grubb <sgrubb@redhat.com> --- I forgot one type in the big patch. I need to add one for user space originating SE Linux avc messages. This is used by dbus and nscd. -Steve --- Updated to 2.6.12-rc4-mm1. -dwmw2 Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-11Add audit_log_typeChris Wright
Add audit_log_type to allow callers to specify type and pid when logging. Convert audit_log to wrapper around audit_log_type. Could have converted all audit_log callers directly, but common case is default of type AUDIT_KERNEL and pid 0. Update audit_log_start to take type and pid values when creating a new audit_buffer. Move sequences that did audit_log_start, audit_log_format, audit_set_type, audit_log_end, to simply call audit_log_type directly. This obsoletes audit_set_type and audit_set_pid, so remove them. Signed-off-by: Chris Wright <chrisw@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-06The attached patch addresses the problem with getting the audit daemon Steve Grubb
shutdown credential information. It creates a new message type AUDIT_TERM_INFO, which is used by the audit daemon to query who issued the shutdown. It requires the placement of a hook function that gathers the information. The hook is after the DAC & MAC checks and before the function returns. Racing threads could overwrite the uid & pid - but they would have to be root and have policy that allows signalling the audit daemon. That should be a manageable risk. The userspace component will be released later in audit 0.7.2. When it receives the TERM signal, it queries the kernel for shutdown information. When it receives it, it writes the message and exits. The message looks like this: type=DAEMON msg=auditd(1114551182.000) auditd normal halt, sending pid=2650 uid=525, auditd pid=1685 Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-01[PATCH] SELinux: add finer grained permissions to Netlink audit processingJames Morris
This patch provides finer grained permissions for the audit family of Netlink sockets under SELinux. 1. We need a way to differentiate between privileged and unprivileged reads of kernel data maintained by the audit subsystem. The AUDIT_GET operation is unprivileged: it returns the current status of the audit subsystem (e.g. whether it's enabled etc.). The AUDIT_LIST operation however returns a list of the current audit ruleset, which is considered privileged by the audit folk. To deal with this, a new SELinux permission has been implemented and applied to the operation: nlmsg_readpriv, which can be allocated to appropriately privileged domains. Unprivileged domains would only be allocated nlmsg_read. 2. There is a requirement for certain domains to generate audit events from userspace. These events need to be collected by the kernel, collated and transmitted sequentially back to the audit daemon. An example is user level login, an auditable event under CAPP, where login-related domains generate AUDIT_USER messages via PAM which are relayed back to auditd via the kernel. To prevent handing out nlmsg_write permissions to such domains, a new permission has been added, nlmsg_relay, which is intended for this type of purpose: data is passed via the kernel back to userspace but no privileged information is written to the kernel. Also, AUDIT_LOGIN messages are now valid only for kernel->user messaging, so this value has been removed from the SELinux nlmsgtab (which is only used to check user->kernel messages). Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] SELinux: cleanup ipc_has_permStephen Smalley
This patch removes the sclass argument from ipc_has_perm in the SELinux module, as it can be obtained from the ipc security structure. The use of a separate argument was a legacy of the older precondition function handling in SELinux and is obsolete. Please apply. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[SELINUX]: Fix ipv6_skip_exthdr() invocation causing OOPS.Herbert Xu
The SELinux hooks invoke ipv6_skip_exthdr() with an incorrect length final argument. However, the length argument turns out to be superfluous. I was just reading ipv6_skip_exthdr and it occured to me that we can get rid of len altogether. The only place where len is used is to check whether the skb has two bytes for ipv6_opt_hdr. This check is done by skb_header_pointer/skb_copy_bits anyway. Now it might appear that we've made the code slower by deferring the check to skb_copy_bits. However, this check should not trigger in the common case so this is OK. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-18[PATCH] SELinux: fix deadlock on dcache lockStephen Smalley
This fixes a deadlock on the dcache lock detected during testing at IBM by moving the logging of the current executable information from the SELinux avc_audit function to audit_log_exit (via an audit_log_task_info helper) for processing upon syscall exit. For consistency, the patch also removes the logging of other task-related information from avc_audit, deferring handling to audit_log_exit instead. This allows simplification of the avc_audit code, allows the exe information to be obtained more reliably, always includes the comm information (useful for scripts), and avoids including bogus task information for checks performed from irq or softirq. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] SELinux: add support for NETLINK_KOBJECT_UEVENTJames Morris
This patch adds SELinux support for the KOBJECT_UEVENT Netlink family, so that SELinux can apply finer grained controls to it. For example, security policy for hald can be locked down to the KOBJECT_UEVENT Netlink family only. Currently, this family simply defaults to the default Netlink socket class. Note that some new permission definitions are added to sync with changes in the core userspace policy package, which auto-generates header files. Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] SELinux: fix bug in Netlink message type detectionJames Morris
This patch fixes a bug in the SELinux Netlink message type detection code, where the wrong constant was being used in a case statement. The incorrect value is not valid for this class of object so it would not have been reached, and fallen through to a default handler for all Netlink messages. Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
