git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris.
Mostly ima, selinux, smack and key handling updates.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits)
integrity: do zero padding of the key id
KEYS: output last portion of fingerprint in /proc/keys
KEYS: strip 'id:' from ca_keyid
KEYS: use swapped SKID for performing partial matching
KEYS: Restore partial ID matching functionality for asymmetric keys
X.509: If available, use the raw subjKeyId to form the key description
KEYS: handle error code encoded in pointer
selinux: normalize audit log formatting
selinux: cleanup error reporting in selinux_nlmsg_perm()
KEYS: Check hex2bin()'s return when generating an asymmetric key ID
ima: detect violations for mmaped files
ima: fix race condition on ima_rdwr_violation_check and process_measurement
ima: added ima_policy_flag variable
ima: return an error code from ima_add_boot_aggregate()
ima: provide 'ima_appraise=log' kernel option
ima: move keyring initialization to ima_init()
PKCS#7: Handle PKCS#7 messages that contain no X.509 certs
PKCS#7: Better handling of unsupported crypto
KEYS: Overhaul key identification when searching for asymmetric keys
KEYS: Implement binary asymmetric key ID handling
security_file_set_fowner always returns 0, so make it f_setown and
__f_setown void return functions and fix up the error handling in the
callers.
Cc: linux-security-module@vger.kernel.org
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
Smack used to use a mix of smack_known struct and char* throughout its
APIs and implementation. This patch unifies the behaviour and makes it
store and operate exclusively on smack_known struct pointers when managing
labels.
Signed-off-by: Lukasz Pawelczyk <l.pawelczyk@samsung.com>
security/smack/smack_access.c
security/smack/smack_lsm.c
The 54e70ec5eb090193b03e69d551fa6771a5a217c4 commit introduced a
bidirectional check that should have checked for mutual WRITE access
between two labels. Due to a typo the second check was incorrect.
People keep asking me for permissive mode, and I keep saying "no".
Permissive mode is wrong for more reasons than I can enumerate,
but the compelling one is that it's once on, never off.
Nonetheless, there is an argument to be made for running a
process with lots of permissions, logging which are required,
and then locking the process down. There wasn't a way to do
that with Smack, but this provides it.
The notion is that you start out by giving the process an
appropriate Smack label, such as "ATBirds". You create rules
with a wide range of access and the "b" mode. On Tizen it
might be:
ATBirds System rwxalb
ATBirds User rwxalb
ATBirds _ rwxalb
User ATBirds wb
System ATBirds wb
Accesses that fail will generate audit records. Accesses
that succeed because of rules marked with a "b" generate
log messages identifying the rule, the program and as much
object information as is convenient.
When the system is properly configured and the programs
brought in line with the labeling scheme the "b" mode can
be removed from the rules. When the system is ready for
production the facility can be configured out.
This provides the developer the convenience of permissive
mode without creating a system that looks like it is
enforcing a policy while it is not.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
While opening with CAP_MAC_OVERRIDE file label is not set.
Other calls may access it after CAP_MAC_OVERRIDE is dropped from process.
Signed-off-by: Marcin Niesluchowski <m.niesluchow@samsung.com>
Values of extended attributes are stored as binary blobs. NULL-termination
of them isn't required. It just wastes disk space and confuses command-line
tools like getfattr because they have to print that zero byte at the end.
This patch removes terminating zero byte from initial security label in
smack_inode_init_security and cuts it out in function smack_inode_getsecurity
which is used by syscall getxattr. This change seems completely safe, because
function smk_parse_smack ignores everything after first zero byte.
Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com>
Zero-length security labels are invalid but kernel should handle them.
This patch fixes kernel panic after setting zero-length security labels:
# attr -S -s "SMACK64" -V "" file
And after writing zero-length string into smackfs files syslog and onlycp:
# python -c 'import os; os.write(1, "")' > /smack/syslog
The problem is caused by brain-damaged logic in function smk_parse_smack()
which takes pointer to buffer and its length but if length below or equal zero
it thinks that the buffer is zero-terminated. Unfortunately callers of this
function are widely used and proper fix requires serious refactoring.
Security operation ->inode_listsecurity is used for generating list of
available extended attributes for syscall listxattr. Currently it's used
only in nfs4 or if filesystem doesn't provide i_op->listxattr.
The list is the set of NULL-terminated names, one after the other.
This method must include zero byte at the and into result.
Also this function must return length even if string does not fit into
output buffer or it is NULL, see similar method in selinux and man listxattr.
Historically the NetLabel LSM secattr catmap functions and data
structures have had very long names which makes a mess of the NetLabel
code and anyone who uses NetLabel. This patch renames the catmap
functions and structures from "*_secattr_catmap_*" to just "*_catmap_*"
which improves things greatly.
There are no substantial code or logic changes in this patch.
Signed-off-by: Paul Moore <pmoore@redhat.com>
Tested-by: Casey Schaufler <casey@schaufler-ca.com>
into next
The cgroup filesystem isn't ready for an LSM to
properly use extented attributes. This patch makes
files created in the cgroup filesystem usable by
a system running Smack and systemd.
Targeted for git://git.gitorious.org/smack-next/kernel.git
Smack believes that many of the operatons that can
be performed on an open file descriptor are read operations.
The fstat and lseek system calls are examples.
An implication of this is that files shouldn't be open
if the task doesn't have read access even if it has
write access and the file is being opened write only.
Smack IPC policy requires that the sender have write access
to the receiver. UDS streams don't do per-packet checks. The
only check is done at connect time. The existing code checks
if the connecting process can write to the other, but not the
other way around. This change adds a check that the other end
can write to the connecting process.
Signed-off-by: Casey Schuafler <casey@schaufler-ca.com>
Sam Henderson points out that removing the SMACK64TRANSMUTE
attribute from a directory does not result in the directory
transmuting. This is because the inode flag indicating that
the directory is transmuting isn't cleared. The fix is a tad
less than trivial because smk_task and smk_mmap should have
been broken out, too.
The function `smack_inode_post_setxattr` is called each
time that a setxattr is done, for any value of name.
The kernel allow to put value==NULL when size==0
to set an empty attribute value. The systematic
call to smk_import_entry was causing the dereference
of a NULL pointer hence a KERNEL PANIC!
The problem can be produced easily by issuing the
command `setfattr -n user.data file` under bash prompt
when SMACK is active.
Moving the call to smk_import_entry as proposed by this
patch is correcting the behaviour because the function
smack_inode_post_setxattr is called for the SMACK's
attributes only if the function smack_inode_setxattr validated
the value and its size (what will not be the case when size==0).
It also has a benefical effect to not fill the smack hash
with garbage values coming from any extended attribute
write.
Change-Id: Iaf0039c2be9bccb6cee11c24a3b44d209101fe47
Signed-off-by: José Bollo <jose.bollo@open.eurogiciel.org>
1. In order to remove any SMACK extended attribute from a file, a user
should have CAP_MAC_ADMIN capability. But user without having this
capability is able to remove SMACK64MMAP security attribute.
2. While validating size and value of smack extended attribute in
smack_inode_setsecurity hook, wrong error code is returned.
Signed-off-by: Pankaj Kumar <pamkaj.k2@samsung.com>
Signed-off-by: Himanshu Shukla <himanshu.sh@samsung.com>
This allows to limit ptrace beyond the regular smack access rules.
It adds a smackfs/ptrace interface that allows smack to be configured
to require equal smack labels for PTRACE_MODE_ATTACH access.
See the changes in Documentation/security/Smack.txt below for details.
Signed-off-by: Lukasz Pawelczyk <l.pawelczyk@partner.samsung.com>
Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
The decision whether we can trace a process is made in the following
functions:
smack_ptrace_traceme()
smack_ptrace_access_check()
smack_bprm_set_creds() (in case the proces is traced)
This patch unifies all those decisions by introducing one function that
checks whether ptrace is allowed: smk_ptrace_rule_check().
This makes possible to actually trace with TRACEME where first the
TRACEME itself must be allowed and then exec() on a traced process.
Additional bugs fixed:
- The decision is made according to the mode parameter that is now correctly
translated from PTRACE_MODE_* to MAY_* instead of being treated 1:1.
PTRACE_MODE_READ requires MAY_READ.
PTRACE_MODE_ATTACH requires MAY_READWRITE.
- Add a smack audit log in case of exec() refused by bprm_set_creds().
- Honor the PTRACE_MODE_NOAUDIT flag and don't put smack audit info
in case this flag is set.
The order of subject/object is currently reversed in
smack_ptrace_traceme(). It is currently checked if the tracee has a
capability to trace tracer and according to this rule a decision is made
whether the tracer will be allowed to trace tracee.
Fix a possible memory access fault when transmute is true and isp is NULL.
For any keyring access type SMACK always used MAY_READWRITE access check.
It prevents reading the key with label "_", which should be allowed for anyone.
This patch changes default access check to MAY_READ and use MAY_READWRITE in only
appropriate cases.
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Move the flags representing required permission to linux/key.h as the perm
parameter of security_key_permission() is in terms of them - and not the
permissions mask flags used in key->perm.
Whilst we're at it:
(1) Rename them to be KEY_NEED_xxx rather than KEY_xxx to avoid collisions
with symbols in uapi/linux/input.h.
(2) Don't use key_perm_t for a mask of required permissions, but rather limit
it to the permissions mask attached to the key and arguments related
directly to that.
Tested-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Pull audit update from Eric Paris:
"Again we stayed pretty well contained inside the audit system.
Venturing out was fixing a couple of function prototypes which were
inconsistent (didn't hurt anything, but we used the same value as an
int, uint, u32, and I think even a long in a couple of places).
We also made a couple of minor changes to when a couple of LSMs called
the audit system. We hoped to add aarch64 audit support this go
round, but it wasn't ready.
I'm disappearing on vacation on Thursday. I should have internet
access, but it'll be spotty. If anything goes wrong please be sure to
cc rgb@redhat.com. He'll make fixing things his top priority"
* git://git.infradead.org/users/eparis/audit: (50 commits)
audit: whitespace fix in kernel-parameters.txt
audit: fix location of __net_initdata for audit_net_ops
audit: remove pr_info for every network namespace
audit: Modify a set of system calls in audit class definitions
audit: Convert int limit uses to u32
audit: Use more current logging style
audit: Use hex_byte_pack_upper
audit: correct a type mismatch in audit_syscall_exit()
audit: reorder AUDIT_TTY_SET arguments
audit: rework AUDIT_TTY_SET to only grab spin_lock once
audit: remove needless switch in AUDIT_SET
audit: use define's for audit version
audit: documentation of audit= kernel parameter
audit: wait_for_auditd rework for readability
audit: update MAINTAINERS
audit: log task info on feature change
audit: fix incorrect set of audit_sock
audit: print error message when fail to create audit socket
audit: fix dangling keywords in audit_log_set_loginuid() output
audit: log on errors from filter user rules
Remove the call to audit_log() (which call audit_log_start()) and deal with
the errors in the caller, logging only once if the condition is met. Calling
audit_log_start() in this location makes buffer allocation and locking more
complicated in the calling tree (audit_filter_user()).
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Eric Paris politely points out:
Inside smack_file_receive() it seems like you are initting the audit
field with LSM_AUDIT_DATA_TASK. And then use
smk_ad_setfield_u_fs_path().
Seems like LSM_AUDIT_DATA_PATH would make more sense. (and depending
on how it's used fix a crash...)
He is correct. This puts things in order.
The mount restrictions imposed by Smack rely heavily on the
use of the filesystem "floor", which is the label that all
processes writing to the filesystem must have access to. It
turns out that while the "floor" notion is sound, it has yet
to be fully implemented and has never been used.
The sb_mount and sb_umount hooks only make sense if the
filesystem floor is used actively, and it isn't. They can
be reintroduced if a rational restriction comes up. Until
then, they get removed.
The sb_kern_mount hook is required for the option processing.
It is too permissive in the case of unprivileged mounts,
effectively bypassing the CAP_MAC_ADMIN restrictions if
any of the smack options are specified. Unprivileged mounts
are no longer allowed to set Smack filesystem options.
Additionally, the root and default values are set to the
label of the caller, in keeping with the policy that objects
get the label of their creator.
The syslog control requires that the calling proccess
have the floor ("_") Smack label. Tizen does not run any
processes except for kernel helpers with the floor label.
This changes allows the admin to configure a specific
label for syslog. The default value is the star ("*")
label, effectively removing the restriction. The value
can be set using smackfs/syslog for anyone who wants
a more restrictive behavior.
Smack prohibits processes from using the star ("*") and web ("@") labels
because we don't want files with those labels getting created implicitly.
All setting of those labels should be done explicitly. The trouble is that
there is no check for these labels in the processing of SMACK64EXEC. That
is repaired.
When the ptrace security hooks were split the addition of
a mode parameter was not taken advantage of in the Smack
ptrace access check. This changes the access check from
always looking for read and write access to using the
passed mode. This will make use of /proc much happier.
Linux file locking does not follow the same rules
as other mechanisms. Even though it is a write operation
a process can set a read lock on files which it has open
only for read access. Two programs with read access to
a file can use read locks to communicate.
This is not acceptable in a Mandatory Access Control
environment. Smack treats setting a read lock as the
write operation that it is. Unfortunately, many programs
assume that setting a read lock is a read operation.
These programs are unhappy in the Smack environment.
This patch introduces a new access mode (lock) to address
this problem. A process with lock access to a file can
set a read lock. A process with write access to a file can
set a read lock or a write lock. This prevents a situation
where processes are granted write access just so they can
set read locks.
Pull security subsystem updates from James Morris:
"Nothing major for this kernel, just maintenance updates"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits)
apparmor: add the ability to report a sha1 hash of loaded policy
apparmor: export set of capabilities supported by the apparmor module
apparmor: add the profile introspection file to interface
apparmor: add an optional profile attachment string for profiles
apparmor: add interface files for profiles and namespaces
apparmor: allow setting any profile into the unconfined state
apparmor: make free_profile available outside of policy.c
apparmor: rework namespace free path
apparmor: update how unconfined is handled
apparmor: change how profile replacement update is done
apparmor: convert profile lists to RCU based locking
apparmor: provide base for multiple profiles to be replaced at once
apparmor: add a features/policy dir to interface
apparmor: enable users to query whether apparmor is enabled
apparmor: remove minimum size check for vmalloc()
Smack: parse multiple rules per write to load2, up to PAGE_SIZE-1 bytes
Smack: network label match fix
security: smack: add a hash table to quicken smk_find_entry()
security: smack: fix memleak in smk_write_rules_list()
xattr: Constify ->name member of "struct xattr".
into ra-next
The original implementation of the Smack IPv6 port based
local controls works most of the time using a sockaddr as
a temporary variable, but not always as it overflows in
some circumstances. The correct data is a sockaddr_in6.
A struct sockaddr isn't as large as a struct sockaddr_in6.
There would need to be casting one way or the other. This
patch gets it the right way.
Signed-off-by: James Morris <james.l.morris@oracle.com>
The Smack code that matches incoming CIPSO tags with Smack labels
reaches through the NetLabel interfaces and compares the network
data with the CIPSO header associated with a Smack label. This was
done in a ill advised attempt to optimize performance. It works
so long as the categories fit in a single capset, but this isn't
always the case.
This patch changes the Smack code to use the appropriate NetLabel
interfaces to compare the incoming CIPSO header with the CIPSO
header associated with a label. It will always match the CIPSO
headers correctly.
Accepted for the smack-next tree after changing the number of
slots from 128 to 16.
This patch adds a hash table to quicken searching of a smack label by its name.
Basically, the patch improves performance of SMACK initialization. Parsing of
rules involves translation from a string to a smack_known (aka label) entity
which is done in smk_find_entry().
The current implementation of the function iterates over a global list of
smack_known resulting in O(N) complexity for smk_find_entry(). The total
complexity of SMACK initialization becomes O(rules * labels). Therefore it
scales quadratically with a complexity of a system.
Applying the patch reduced the complexity of smk_find_entry() to O(1) as long
as number of label is in hundreds. If the number of labels is increased please
update SMACK_HASH_SLOTS constant defined in security/smack/smack.h. Introducing
the configuration of this constant with Kconfig or cmdline might be a good
idea.
The size of the hash table was adjusted experimentally. The rule set used by
TIZEN contains circa 17K rules for 500 labels. The table above contains
results of SMACK initialization using 'time smackctl apply' bash command.
The 'Ref' is a kernel without this patch applied. The consecutive values
refers to value of SMACK_HASH_SLOTS. Every measurement was repeated three
times to reduce noise.
| Ref | 1 | 2 | 4 | 8 | 16 | 32 | 64 | 128 | 256 | 512
Run1 | 1.156 | 1.096 | 0.883 | 0.764 | 0.692 | 0.667 | 0.649 | 0.633 | 0.634 | 0.629 | 0.620
Run2 | 1.156 | 1.111 | 0.885 | 0.764 | 0.694 | 0.661 | 0.649 | 0.651 | 0.634 | 0.638 | 0.623
Run3 | 1.160 | 1.107 | 0.886 | 0.764 | 0.694 | 0.671 | 0.661 | 0.638 | 0.631 | 0.624 | 0.638
AVG | 1.157 | 1.105 | 0.885 | 0.764 | 0.693 | 0.666 | 0.653 | 0.641 | 0.633 | 0.630 | 0.627
Surprisingly, a single hlist is slightly faster than a double-linked list.
The speed-up saturates near 64 slots. Therefore I chose value 128 to provide
some margin if more labels were used.
It looks that IO becomes a new bottleneck.
Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
Since everybody sets kstrdup()ed constant string to "struct xattr"->name but
nobody modifies "struct xattr"->name , we can omit kstrdup() and its failure
checking by constifying ->name member of "struct xattr".
Reviewed-by: Joel Becker <jlbec@evilplan.org> [ocfs2]
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Reviewed-by: Paul Moore <paul@paul-moore.com>
Tested-by: Paul Moore <paul@paul-moore.com>
Acked-by: Eric Paris <eparis@redhat.com>
Pull NFS client updates from Trond Myklebust:
"Feature highlights include:
- Add basic client support for NFSv4.2
- Add basic client support for Labeled NFS (selinux for NFSv4.2)
- Fix the use of credentials in NFSv4.1 stateful operations, and add
support for NFSv4.1 state protection.
Bugfix highlights:
- Fix another NFSv4 open state recovery race
- Fix an NFSv4.1 back channel session regression
- Various rpc_pipefs races
- Fix another issue with NFSv3 auth negotiation
Please note that Labeled NFS does require some additional support from
the security subsystem. The relevant changesets have all been
reviewed and acked by James Morris."
* tag 'nfs-for-3.11-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (54 commits)
NFS: Set NFS_CS_MIGRATION for NFSv4 mounts
NFSv4.1 Refactor nfs4_init_session and nfs4_init_channel_attrs
nfs: have NFSv3 try server-specified auth flavors in turn
nfs: have nfs_mount fake up a auth_flavs list when the server didn't provide it
nfs: move server_authlist into nfs_try_mount_request
nfs: refactor "need_mount" code out of nfs_try_mount
SUNRPC: PipeFS MOUNT notification optimization for dying clients
SUNRPC: split client creation routine into setup and registration
SUNRPC: fix races on PipeFS UMOUNT notifications
SUNRPC: fix races on PipeFS MOUNT notifications
NFSv4.1 use pnfs_device maxcount for the objectlayout gdia_maxcount
NFSv4.1 use pnfs_device maxcount for the blocklayout gdia_maxcount
NFSv4.1 Fix gdia_maxcount calculation to fit in ca_maxresponsesize
NFS: Improve legacy idmapping fallback
NFSv4.1 end back channel session draining
NFS: Apply v4.1 capabilities to v4.2
NFSv4.1: Clean up layout segment comparison helper names
NFSv4.1: layout segment comparison helpers should take 'const' parameters
NFSv4: Move the DNS resolver into the NFSv4 module
rpc_pipefs: only set rpc_dentry_ops if d_op isn't already set
The interface to request security labels from user space is the xattr
interface. When requesting the security label from an NFS server it is
important to make sure the requested xattr actually is a MAC label. This allows
us to make sure that we get the desired semantics from the attribute instead of
something else such as capabilities or a time based LSM.
Acked-by: James Morris <james.l.morris@oracle.com>
Signed-off-by: Matthew N. Dodd <Matthew.Dodd@sparta.com>
Signed-off-by: Miguel Rodel Felipe <Rodel_FM@dsi.a-star.edu.sg>
Signed-off-by: Phua Eu Gene <PHUA_Eu_Gene@dsi.a-star.edu.sg>
Signed-off-by: Khin Mi Mi Aung <Mi_Mi_AUNG@dsi.a-star.edu.sg>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Suppliment the smkfsroot mount option with another, smkfstransmute,
that does the same thing but also marks the root inode as
transmutting. This allows a freshly created filesystem to
be mounted with a transmutting heirarchy.
Each Smack label that the kernel has seen is added to a
list of labels. The list of access rules for a given subject
label hangs off of the label list entry for the label.
This patch changes the structures that contain subject
labels to point at the label list entry rather that the
label itself. Doing so removes a label list lookup in
smk_access() that was accounting for the largest single
chunk of Smack overhead.
Smack does not provide access controls on IPv6 communications.
This patch introduces a mechanism for maintaining Smack lables
for local IPv6 communications. It is based on labeling local ports.
The behavior should be compatible with any future "real" IPv6
support as it provides no interfaces for users to manipulate
the labeling. Remote IPv6 connections use the ambient label
the same way that unlabeled IPv4 packets are treated.
This patch fixes kernel Oops because of wrong common_audit_data type
in smack_inode_unlink() and smack_inode_rmdir().
When SMACK security module is enabled and SMACK logging is on (/smack/logging
is not zero) and you try to delete the file which
1) you cannot delete due to SMACK rules and logging of failures is on
or
2) you can delete and logging of success is on,
you will see following:
Unable to handle kernel NULL pointer dereference at virtual address 000002d7
[<...>] (strlen+0x0/0x28)
[<...>] (audit_log_untrustedstring+0x14/0x28)
[<...>] (common_lsm_audit+0x108/0x6ac)
[<...>] (smack_log+0xc4/0xe4)
[<...>] (smk_curacc+0x80/0x10c)
[<...>] (smack_inode_unlink+0x74/0x80)
[<...>] (security_inode_unlink+0x2c/0x30)
[<...>] (vfs_unlink+0x7c/0x100)
[<...>] (do_unlinkat+0x144/0x16c)
The function smack_inode_unlink() (and smack_inode_rmdir()) need
to log two structures of different types. First of all it does:
smk_ad_init(&ad, __func__, LSM_AUDIT_DATA_DENTRY);
smk_ad_setfield_u_fs_path_dentry(&ad, dentry);
This will set common audit data type to LSM_AUDIT_DATA_DENTRY
and store dentry for auditing (by function smk_curacc(), which in turn calls
dump_common_audit_data(), which is actually uses provided data and logs it).
* You need write access to the thing you're unlinking
rc = smk_curacc(smk_of_inode(ip), MAY_WRITE, &ad);
if (rc == 0) {
* You also need write access to the containing directory
Then this function wants to log anoter data:
smk_ad_setfield_u_fs_path_dentry(&ad, NULL);
smk_ad_setfield_u_fs_inode(&ad, dir);
The function sets inode field, but don't change common_audit_data type.
rc = smk_curacc(smk_of_inode(dir), MAY_WRITE, &ad);
So the dump_common_audit() function incorrectly interprets inode structure
as dentry, and Oops will happen.
This patch reinitializes common_audit_data structures with correct type.
Also I removed unneeded
initialization, because both dentry and inode pointers are stored
in the same union.
Signed-off-by: Igor Zhbanov <i.zhbanov@samsung.com>
The data structure allocations being done in prepare_creds
are duplicated in smack_setprocattr. This results in the
structure allocated in prepare_creds being orphaned and
never freed. The duplicate code is removed from
smack_setprocattr.
On 12/20/2011 11:20 PM, Jarkko Sakkinen wrote:
> Allow SIGCHLD to be passed to child process without
> explicit policy. This will help to keep the access
> control policy simple and easily maintainable with
> complex applications that require use of multiple
> security contexts. It will also help to keep them
> as isolated as possible.
> Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
I have a slightly different version that applies to the
current smack-next tree.
security/smack/smack_lsm.c | 37 ++++++++-----------------------------
1 files changed, 8 insertions(+), 29 deletions(-)
Smack is integrated with the POSIX capabilities scheme,
using the capabilities CAP_MAC_OVERRIDE and CAP_MAC_ADMIN to
determine if a process is allowed to ignore Smack checks or
change Smack related data respectively. Smack provides an
additional restriction that if an onlycap value is set
by writing to /smack/onlycap only tasks with that Smack
label are allowed to use CAP_MAC_OVERRIDE.
This change adds CAP_MAC_ADMIN as a capability that is affected
by the onlycap mechanism.
