path: root/security/smack
2011-02-09Smack: correct final mmap check comparisonCasey Schaufler
The mmap policy enforcement checks the access of the SMACK64MMAP subject against the current subject incorrectly. The check as written works correctly only if the access rules involved have the same access. This is the common case, so initial testing did not find a problem. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-02-09security:smack: kill unused SMACK_LIST_MAX, MAY_ANY and MAY_ANYWRITEShan Wei
Kill unused macros of SMACK_LIST_MAX, MAY_ANY and MAY_ANYWRITE. v2: As Casey Schaufler's advice, also remove MAY_ANY. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-02-09Smack: correct behavior in the mmap hookCasey Schaufler
The mmap policy enforcement was not properly handling the interaction between the global and local rule lists. Instead of going through one and then the other, which missed the important case where a rule specified that there should be no access, combine the access limitations where there is a rule in each list. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-17Subject: [PATCH] Smack: mmap controls for library containmentCasey Schaufler
In the embedded world there are often situations where libraries are updated from a variety of sources, for a variety of reasons, and with any number of security characteristics. These differences might include privilege required for a given library provided interface to function properly, as occurs from time to time in graphics libraries. There are also cases where it is important to limit use of libraries based on the provider of the library and the security aware application may make choices based on that criteria. These issues are addressed by providing an additional Smack label that may optionally be assigned to an object, the SMACK64MMAP attribute. An mmap operation is allowed if there is no such attribute. If there is a SMACK64MMAP attribute the mmap is permitted only if a subject with that label has all of the access permitted a subject with the current task label. Security aware applications may from time to time wish to reduce their "privilege" to avoid accidental use of privilege. One case where this arises is the environment in which multiple sources provide libraries to perform the same functions. An application may know that it should eschew services made available from a particular vendor, or of a particular version. In support of this a secondary list of Smack rules has been added that is local to the task. This list is consulted only in the case where the global list has approved access. It can only further restrict access. Unlike the global last, if no entry is found on the local list access is granted. An application can add entries to its own list by writing to /smack/load-self. The changes appear large as they involve refactoring the list handling to accomodate there being more than one rule list. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-01-10Merge branch 'master' into nextJames Morris
Conflicts: security/smack/smack_lsm.c Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au> Ok'd by Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-05af_unix: Avoid socket->sk NULL OOPS in stream connect security hooks.David S. Miller
unix_release() can asynchornously set socket->sk to NULL, and it does so without holding the unix_state_lock() on "other" during stream connects. However, the reverse mapping, sk->sk_socket, is only transitioned to NULL under the unix_state_lock(). Therefore make the security hooks follow the reverse mapping instead of the forward mapping. Reported-by: Jeremy Fitzhardinge <jeremy@goop.org> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-07Smack: Transmute labels on specified directoriesJarkko Sakkinen
In a situation where Smack access rules allow processes with multiple labels to write to a directory it is easy to get into a situation where the directory gets cluttered with files that the owner can't deal with because while they could be written to the directory a process at the label of the directory can't write them. This is generally the desired behavior, but when it isn't it is a real issue. This patch introduces a new attribute SMACK64TRANSMUTE that instructs Smack to create the file with the label of the directory under certain circumstances. A new access mode, "t" for transmute, is made available to Smack access rules, which are expanded from "rwxa" to "rwxat". If a file is created in a directory marked as transmutable and if access was granted to perform the operation by a rule that included the transmute mode, then the file gets the Smack label of the directory instead of the Smack label of the creating process. Note that this is equivalent to creating an empty file at the label of the directory and then having the other process write to it. The transmute scheme requires that both the access rule allows transmutation and that the directory be explicitly marked. Signed-off-by: Jarkko Sakkinen <ext-jarkko.2.sakkinen@nokia.com> Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2010-12-02This patch adds a new security attribute to Smack calledCasey Schaufler
SMACK64EXEC. It defines label that is used while task is running. Exception: in smack_task_wait() child task is checked for write access to parent task using label inherited from the task that forked it. Fixed issues from previous submit: - SMACK64EXEC was not read when SMACK64 was not set. - inode security blob was not updated after setting SMACK64EXEC - inode security blob was not updated when removing SMACK64EXEC
2010-11-29Smack: UDS revisionCasey Schaufler
This patch addresses a number of long standing issues with the way Smack treats UNIX domain sockets. All access control was being done based on the label of the file system object. This is inconsistant with the internet domain, in which access is done based on the IPIN and IPOUT attributes of the socket. As a result of the inode label policy it was not possible to use a UDS socket for label cognizant services, including dbus and the X11 server. Support for SCM_PEERSEC on UDS sockets is also provided. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-15capabilities/syslog: open code cap_syslog logic to fix build failureEric Paris
The addition of CONFIG_SECURITY_DMESG_RESTRICT resulted in a build failure when CONFIG_PRINTK=n. This is because the capabilities code which used the new option was built even though the variable in question didn't exist. The patch here fixes this by moving the capabilities checks out of the LSM and into the caller. All (known) LSMs should have been calling the capabilities hook already so it actually makes the code organization better to eliminate the hook altogether. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29convert get_sb_single() usersAl Viro
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-21security: secid_to_secctx returns len when data is NULLEric Paris
With the (long ago) interface change to have the secid_to_secctx functions do the string allocation instead of having the caller do the allocation we lost the ability to query the security server for the length of the upcoming string. The SECMARK code would like to allocate a netlink skb with enough length to hold the string but it is just too unclean to do the string allocation twice or to do the allocation the first time and hold onto the string and slen. This patch adds the ability to call security_secid_to_secctx() with a NULL data pointer and it will just set the slen pointer. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-10-21security: remove unused parameter from security_task_setscheduler()KOSAKI Motohiro
All security modules shouldn't change sched_param parameter of security_task_setscheduler(). This is not only meaningless, but also make a harmful result if caller pass a static variable. This patch remove policy and sched_param parameter from security_task_setscheduler() becuase none of security module is using it. Cc: James Morris <jmorris@namei.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: James Morris <jmorris@namei.org>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-02security: make LSMs explicitly mask off permissionsEric Paris
SELinux needs to pass the MAY_ACCESS flag so it can handle auditting correctly. Presently the masking of MAY_* flags is done in the VFS. In order to allow LSMs to decide what flags they care about and what flags they don't just pass them all and the each LSM mask off what they don't need. This patch should contain no functional changes to either the VFS or any LSM. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02security: move LSM xattrnames to xattr.hMimi Zohar
Make the security extended attributes names global. Updated to move the remaining Smack xattrs. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02smack: opt_dentry is never null in in smack_d_instantiate()Dan Carpenter
This patch removes some unneeded code for if opt_dentry is null because that can never happen. The function dereferences "opt_dentry" earlier when it checks "if (opt_dentry->d_parent == opt_dentry) {". That code was added in 2008. This function called from security_d_instantiate(). I checked all the places which call security_d_instantiate() and dentry is always non-null. I also checked the selinux version of this hook and there is a comment which says that dentry should be non-null if called from d_instantiate(). Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-06Merge branch 'master' into nextJames Morris
2010-04-27SMACK: Don't #include Ext2 headersDavid Howells
Don't #include Ext2 headers into Smack unnecessarily. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-08SMACK: remove dead cred_commit hookEric Paris
This is an unused hook in SMACK so remove it. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) init: Open /dev/console from rootfs mqueue: fix typo "failues" -> "failures" mqueue: only set error codes if they are really necessary mqueue: simplify do_open() error handling mqueue: apply mathematics distributivity on mq_bytes calculation mqueue: remove unneeded info->messages initialization mqueue: fix mq_open() file descriptor leak on user-space processes fix race in d_splice_alias() set S_DEAD on unlink() and non-directory rename() victims vfs: add NOFOLLOW flag to umount(2) get rid of ->mnt_parent in tomoyo/realpath hppfs can use existing proc_mnt, no need for do_kern_mount() in there Mirror MS_KERNMOUNT in ->mnt_flags get rid of useless vfsmount_lock use in put_mnt_ns() Take vfsmount_lock to fs/internal.h get rid of insanity with namespace roots in tomoyo take check for new events in namespace (guts of mounts_poll()) to namespace.c Don't mess with generic_permission() under ->d_lock in hpfs sanitize const/signedness for udf nilfs: sanitize const/signedness in dealing with ->d_name.name ... Fix up fairly trivial (famous last words...) conflicts in drivers/infiniband/core/uverbs_main.c and security/tomoyo/realpath.c
2010-03-03fix mnt_mountpoint abuse in smackAl Viro
(mnt,mnt_mountpoint) pair is conceptually wrong; if you want to use it for generating pathname and for nothing else *and* if you know that vfsmount tree is unchanging, you can get away with that, but the right solution for that is (mnt,mnt_root). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-04syslog: distinguish between /proc/kmsg and syscallsKees Cook
This allows the LSM to distinguish between syslog functions originating from /proc/kmsg access and direct syscalls. By default, the commoncaps will now no longer require CAP_SYS_ADMIN to read an opened /proc/kmsg file descriptor. For example the kernel syslog reader can now drop privileges after opening /proc/kmsg, instead of staying privileged with CAP_SYS_ADMIN. MAC systems that implement security_syslog have unchanged behavior. Signed-off-by: Kees Cook <kees.cook@canonical.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-11-20net: rename skb->iif to skb->skb_iifEric Dumazet
To help grep games, rename iif to skb_iif Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Move magic numbers into magic.hNick Black
Move various magic-number definitions into magic.h. Signed-off-by: Nick Black <dank@qemfd.net> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-10sysfs: Add labeling support for sysfsDavid P. Quigley
This patch adds a setxattr handler to the file, directory, and symlink inode_operations structures for sysfs. The patch uses hooks introduced in the previous patch to handle the getting and setting of security information for the sysfs inodes. As was suggested by Eric Biederman the struct iattr in the sysfs_dirent structure has been replaced by a structure which contains the iattr, secdata and secdata length to allow the changes to persist in the event that the inode representing the sysfs_dirent is evicted. Because sysfs only stores this information when a change is made all the optional data is moved into one dynamically allocated field. This patch addresses an issue where SELinux was denying virtd access to the PCI configuration entries in sysfs. The lack of setxattr handlers for sysfs required that a single label be assigned to all entries in sysfs. Granting virtd access to every entry in sysfs is not an acceptable solution so fine grained labeling of sysfs is required such that individual entries can be labeled appropriately. [sds: Fixed compile-time warnings, coding style, and setting of inode security init flags.] Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov> Signed-off-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-10LSM/SELinux: inode_{get,set,notify}secctx hooks to access LSM security ↵David P. Quigley
context information. This patch introduces three new hooks. The inode_getsecctx hook is used to get all relevant information from an LSM about an inode. The inode_setsecctx is used to set both the in-core and on-disk state for the inode based on a context derived from inode_getsecctx.The final hook inode_notifysecctx will notify the LSM of a change for the in-core state of the inode in question. These hooks are for use in the labeled NFS code and addresses concerns of how to set security on an inode in a multi-xattr LSM. For historical reasons Stephen Smalley's explanation of the reason for these hooks is pasted below. Quote Stephen Smalley inode_setsecctx: Change the security context of an inode. Updates the in core security context managed by the security module and invokes the fs code as needed (via __vfs_setxattr_noperm) to update any backing xattrs that represent the context. Example usage: NFS server invokes this hook to change the security context in its incore inode and on the backing file system to a value provided by the client on a SETATTR operation. inode_notifysecctx: Notify the security module of what the security context of an inode should be. Initializes the incore security context managed by the security module for this inode. Example usage: NFS client invokes this hook to initialize the security context in its incore inode to the value provided by the server for the file when the server returned the file's attributes to the client. Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]David Howells
Add a keyctl to install a process's session keyring onto its parent. This replaces the parent's session keyring. Because the COW credential code does not permit one process to change another process's credentials directly, the change is deferred until userspace next starts executing again. Normally this will be after a wait*() syscall. To support this, three new security hooks have been provided: cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in the blank security creds and key_session_to_parent() - which asks the LSM if the process may replace its parent's session keyring. The replacement may only happen if the process has the same ownership details as its parent, and the process has LINK permission on the session keyring, and the session keyring is owned by the process, and the LSM permits it. Note that this requires alteration to each architecture's notify_resume path. This has been done for all arches barring blackfin, m68k* and xtensa, all of which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the replacement to be performed at the point the parent process resumes userspace execution. This allows the userspace AFS pioctl emulation to fully emulate newpag() and the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to alter the parent process's PAG membership. However, since kAFS doesn't use PAGs per se, but rather dumps the keys into the session keyring, the session keyring of the parent must be replaced if, for example, VIOCSETTOK is passed the newpag flag. This can be tested with the following program: #include <stdio.h> #include <stdlib.h> #include <keyutils.h> #define KEYCTL_SESSION_TO_PARENT 18 #define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0) int main(int argc, char **argv) { key_serial_t keyring, key; long ret; keyring = keyctl_join_session_keyring(argv[1]); OSERROR(keyring, "keyctl_join_session_keyring"); key = add_key("user", "a", "b", 1, keyring); OSERROR(key, "add_key"); ret = keyctl(KEYCTL_SESSION_TO_PARENT); OSERROR(ret, "KEYCTL_SESSION_TO_PARENT"); return 0; } Compiled and linked with -lkeyutils, you should see something like: [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 355907932 --alswrv 4043 -1 \_ keyring: _uid.4043 [dhowells@andromeda ~]$ /tmp/newpag [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 1055658746 --alswrv 4043 4043 \_ user: a [dhowells@andromeda ~]$ /tmp/newpag hello [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: hello 340417692 --alswrv 4043 4043 \_ user: a Where the test program creates a new session keyring, sticks a user key named 'a' into it and then installs it on its parent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-06security/smack: Use AF_INET for sin_family fieldJulia Lawall
Elsewhere the sin_family field holds a value with a name of the form AF_..., so it seems reasonable to do so here as well. Also the values of PF_INET and AF_INET are the same. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ struct sockaddr_in sip; @@ ( sip.sin_family == - PF_INET + AF_INET | sip.sin_family != - PF_INET + AF_INET | sip.sin_family = - PF_INET + AF_INET ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-07-10security: Make lsm_priv union in lsm_audit.h anonymousThomas Liu
Made the lsm_priv union in include/linux/lsm_audit.h anonymous. Signed-off-by: Thomas Liu <tliu@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-07-10Move variable function in lsm_audit.h into SMACK private spaceThomas Liu
Moved variable function in include/linux/lsm_audit.h into the smack_audit_data struct since it is never used outside of it. Also removed setting of function in the COMMON_AUDIT_DATA_INIT macro because that variable is now private to SMACK. Signed-off-by: Thomas Liu <tliu@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> I-dont-see-any-problems-with-it: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-25security: rename ptrace_may_access => ptrace_access_checkIngo Molnar
The ->ptrace_may_access() methods are named confusingly - the real ptrace_may_access() returns a bool, while these security checks have a retval convention. Rename it to ptrace_access_check, to reduce the confusion factor. [ Impact: cleanup, no code changed ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (44 commits) nommu: Provide mmap_min_addr definition. TOMOYO: Add description of lists and structures. TOMOYO: Remove unused field. integrity: ima audit dentry_open failure TOMOYO: Remove unused parameter. security: use mmap_min_addr indepedently of security models TOMOYO: Simplify policy reader. TOMOYO: Remove redundant markers. SELinux: define audit permissions for audit tree netlink messages TOMOYO: Remove unused mutex. tomoyo: avoid get+put of task_struct smack: Remove redundant initialization. integrity: nfsd imbalance bug fix rootplug: Remove redundant initialization. smack: do not beyond ARRAY_SIZE of data integrity: move ima_counts_get integrity: path_check update IMA: Add __init notation to ima functions IMA: Minimal IMA policy and boot param for TCB IMA policy selinux: remove obsolete read buffer limit from sel_read_bool ...
2009-06-10Merge branch 'rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: rcu_sched_grace_period(): kill the bogus flush_signals() rculist: use list_entry_rcu in places where it's appropriate rculist.h: introduce list_entry_rcu() and list_first_entry_rcu() rcu: Update RCU tracing documentation for __rcu_pending rcu: Add __rcu_pending tracing to hierarchical RCU RCU: make treercu be default
2009-05-28smack: Remove redundant initialization.Tetsuo Handa
We don't need to explicitly initialize to cap_* because it will be filled by security_fixup_ops(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-22smack: do not beyond ARRAY_SIZE of dataRoel Kluin
Do not go beyond ARRAY_SIZE of data Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-08Merge branch 'master' into nextJames Morris
2009-04-18Smack: check for SMACK xattr validity in smack_inode_setxattrEtienne Basset
the following patch moves checks for SMACK xattr validity from smack_inode_post_setxattr (which cannot return an error to the user) to smack_inode_setxattr (which can return an error). Signed-off-by: Etienne Basset <etienne.basset@numericable.fr> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-15rculist: use list_entry_rcu in places where it's appropriateJiri Pirko
Use previously introduced list_entry_rcu instead of an open-coded list_entry + rcu_dereference combination. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: dipankar@in.ibm.com LKML-Reference: <20090414181715.GA3634@psychotron.englab.brq.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14smack: implement logging V3Etienne Basset
the following patch, add logging of Smack security decisions. This is of course very useful to understand what your current smack policy does. As suggested by Casey, it also now forbids labels with ', " or \ It introduces a '/smack/logging' switch : 0: no logging 1: log denied (default) 2: log accepted 3: log denied&accepted Signed-off-by: Etienne Basset <etienne.basset@numericable.fr> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-28smack: Add a new '-CIPSO' option to the network address label configurationEtienne Basset
This patch adds a new special option '-CIPSO' to the Smack subsystem. When used in the netlabel list, it means "use CIPSO networking". A use case is when your local network speaks CIPSO and you want also to connect to the unlabeled Internet. This patch also add some documentation describing that. The patch also corrects an oops when setting a '' SMACK64 xattr to a file. Signed-off-by: Etienne Basset <etienne.basset@numericable.fr> Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-28netlabel: Cleanup the Smack/NetLabel code to fix incoming TCP connectionsPaul Moore
This patch cleans up a lot of the Smack network access control code. The largest changes are to fix the labeling of incoming TCP connections in a manner similar to the recent SELinux changes which use the security_inet_conn_request() hook to label the request_sock and let the label move to the child socket via the normal network stack mechanisms. In addition to the incoming TCP connection fixes this patch also removes the smk_labled field from the socket_smack struct as the minor optimization advantage was outweighed by the difficulty in maintaining it's proper state. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-28netlabel: Label incoming TCP connections correctly in SELinuxPaul Moore
The current NetLabel/SELinux behavior for incoming TCP connections works but only through a series of happy coincidences that rely on the limited nature of standard CIPSO (only able to convey MLS attributes) and the write equality imposed by the SELinux MLS constraints. The problem is that network sockets created as the result of an incoming TCP connection were not on-the-wire labeled based on the security attributes of the parent socket but rather based on the wire label of the remote peer. The issue had to do with how IP options were managed as part of the network stack and where the LSM hooks were in relation to the code which set the IP options on these newly created child sockets. While NetLabel/SELinux did correctly set the socket's on-the-wire label it was promptly cleared by the network stack and reset based on the IP options of the remote peer. This patch, in conjunction with a prior patch that adjusted the LSM hook locations, works to set the correct on-the-wire label format for new incoming connections through the security_inet_conn_request() hook. Besides the correct behavior there are many advantages to this change, the most significant is that all of the NetLabel socket labeling code in SELinux now lives in hooks which can return error codes to the core stack which allows us to finally get ride of the selinux_netlbl_inode_permission() logic which greatly simplfies the NetLabel/SELinux glue code. In the process of developing this patch I also ran into a small handful of AF_INET6 cleanliness issues that have been fixed which should make the code safer and easier to extend in the future. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-26smack: convert smack to standard linux listsEtienne Basset
the following patch (on top of 2.6.29) converts Smack lists to standard linux lists Please review and consider for inclusion in 2.6.30-rc regards, Etienne Signed-off-by: Etienne Basset <etienne.basset@numericable.fr> Acked-by: Casey Schaufler <casey@schaufler-ca.com>
2009-03-24Merge branch 'master' into nextJames Morris
