commit 1418a3e5ad4d01b1d4abf2c479c50b0cedd59e3f upstream.
Current tomoyo_realpath_from_path() implementation returns strange pathname
when calculating pathname of a file which belongs to lazy unmounted tree.
Use local pathname rather than strange absolute pathname in that case.
Also, this patch fixes a regression by commit 02125a82 "fix apparmor
dereferencing potentially freed dentry, sanitize __d_path() API".
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
commit 02125a826459a6ad142f8d91c5b6357562f96615 upstream.
__d_path() API is asking for trouble and in case of apparmor d_namespace_path()
getting just that. The root cause is that when __d_path() misses the root
it had been told to look for, it stores the location of the most remote ancestor
in *root. Without grabbing references. Sure, at the moment of call it had
been pinned down by what we have in *path. And if we raced with umount -l, we
could have very well stopped at vfsmount/dentry that got freed as soon as
prepend_path() dropped vfsmount_lock.
It is safe to compare these pointers with pre-existing (and known to be still
alive) vfsmount and dentry, as long as all we are asking is "is it the same
address?". Dereferencing is not safe and apparmor ended up stepping into
that. d_namespace_path() really wants to examine the place where we stopped,
even if it's not connected to our namespace. As the result, it looked
at ->d_sb->s_magic of a dentry that might've been already freed by that point.
All other callers had been careful enough to avoid that, but it's really
a bad interface - it invites that kind of trouble.
The fix is fairly straightforward, even though it's bigger than I'd like:
* prepend_path() root argument becomes const.
* __d_path() is never called with NULL/NULL root. It was a kludge
to start with. Instead, we have an explicit function - d_absolute_root().
Same as __d_path(), except that it doesn't get root passed and stops where
it stops. apparmor and tomoyo are using it.
* __d_path() returns NULL on path outside of root. The main
caller is show_mountinfo() and that's precisely what we pass root for - to
skip those outside chroot jail. Those who don't want that can (and do)
use d_path().
* __d_path() root argument becomes const. Everyone agrees, I hope.
* apparmor does *NOT* try to use __d_path() or any of its variants
when it sees that path->mnt is an internal vfsmount. In that case it's
definitely not mounted anywhere and dentry_path() is exactly what we want
there. Handling of sysctl()-triggered weirdness is moved to that place.
* if apparmor is asked to do pathname relative to chroot jail
and __d_path() tells it we it's not in that jail, the sucker just calls
d_absolute_path() instead. That's the other remaining caller of __d_path(),
BTW.
* seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway -
the normal seq_file logics will take care of growing the buffer and redoing
the call of ->show() just fine). However, if it gets path not reachable
from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped
ignoring the return value as it used to do).
Reviewed-by: John Johansen <john.johansen@canonical.com>
ACKed-by: John Johansen <john.johansen@canonical.com>
Update comments for scripts/kernel-doc and fix some of errors reported by
scripts/checkpatch.pl .
Signed-off-by: James Morris <jmorris@namei.org>
TOMOYO wants to use /proc/self/ rather than /proc/$PID/ if $PID matches current
thread's process ID in order to prevent current thread from accessing other
process's information unless needed.
But since procfs can be mounted on various locations (e.g. /proc/ /proc2/ /p/
/tmp/foo/100/p/ ), TOMOYO cannot tell that whether the numeric part in the
string returned by __d_path() represents process ID or not.
Therefore, to be able to convert from $PID to self no matter where procfs is
mounted, this patch changes pathname representations for filesystems which do
not support rename() operation (e.g. proc, sysfs, securityfs).
Examples:
/proc/self/mounts => proc:/self/mounts
/sys/kernel/security/ => sys:/kernel/security/
/dev/pts/0 => devpts:/0
Protect d_unhashed(dentry) condition with d_lock. This means keeping
DCACHE_UNHASHED bit in synch with hash manipulations.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
All callers take dcache_lock just around the call to __d_path, so
take the lock into it in preparation of getting rid of dcache_lock.
Some programs behave differently depending on argv[0] passed to execve().
TOMOYO has "alias" keyword in order to allow administrators to define different
domains if requested pathname passed to execve() is a symlink. But "alias"
keyword is incomplete because this keyword assumes that requested pathname and
argv[0] are identical. Thus, remove "alias" keyword (by this patch) and add
syntax for checking argv[0] (by future patches).
Allow pathnames longer than 4000 bytes.
security/tomoyo/common.c became too large to read.
Since the behavior of the system is restricted by policy, we may need to update
policy when you update packages.
We need to update policy in the following cases.
* The pathname of files has changed.
* The dependency of files has changed.
* The access permissions required has increased.
The ideal way to update policy is to rebuild from the scratch using learning
mode. But it is not desirable to change from enforcing mode to other mode if
the system has once entered in production state. Suppose MAC could support
per-application enforcing mode, the MAC becomes useless if an application that
is not running in enforcing mode was cracked. For example, the whole system
becomes vulnerable if only HTTP server application is running in learning mode
to rebuild policy for the application. So, in TOMOYO Linux, updating policy is
done while the system is running in enforcing mode.
This patch implements "interactive enforcing mode" which allows administrators
to judge whether to accept policy violation in enforcing mode or not.
A demo movie is available at http://www.youtube.com/watch?v=b9q1Jo25LPA .
Use stack memory for pending entry to reduce kmalloc() which will be kfree()d.
Some of TOMOYO's functions may sleep after mutex_lock(). If OOM-killer selected
a process which is waiting at mutex_lock(), the to-be-killed process can't be
killed. Thus, replace mutex_lock() with mutex_lock_interruptible() so that the
to-be-killed process can immediately return from TOMOYO's functions.
In Ubuntu, security_path_*() hooks are exported to Unionfs. Thus, prepare for
being called from inside VFS functions because I'm not sure whether it is safe
to use GFP_KERNEL or not.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits)
init: Open /dev/console from rootfs
mqueue: fix typo "failues" -> "failures"
mqueue: only set error codes if they are really necessary
mqueue: simplify do_open() error handling
mqueue: apply mathematics distributivity on mq_bytes calculation
mqueue: remove unneeded info->messages initialization
mqueue: fix mq_open() file descriptor leak on user-space processes
fix race in d_splice_alias()
set S_DEAD on unlink() and non-directory rename() victims
vfs: add NOFOLLOW flag to umount(2)
get rid of ->mnt_parent in tomoyo/realpath
hppfs can use existing proc_mnt, no need for do_kern_mount() in there
Mirror MS_KERNMOUNT in ->mnt_flags
get rid of useless vfsmount_lock use in put_mnt_ns()
Take vfsmount_lock to fs/internal.h
get rid of insanity with namespace roots in tomoyo
take check for new events in namespace (guts of mounts_poll()) to namespace.c
Don't mess with generic_permission() under ->d_lock in hpfs
sanitize const/signedness for udf
nilfs: sanitize const/signedness in dealing with ->d_name.name
Fix up fairly trivial (famous last words...) conflicts in
drivers/infiniband/core/uverbs_main.c and security/tomoyo/realpath.c
passing *any* namespace root to __d_path() as root is equivalent
to just passing it {NULL, NULL}; no need to bother with finding
the root of our namespace in there.
This patch adds garbage collector support to TOMOYO.
Elements are protected by "struct srcu_struct tomoyo_ss".
Acked-by: Serge Hallyn <serue@us.ibm.com>
Gather structures and constants scattered around security/tomoyo/ directory.
This is for preparation for adding garbage collector since garbage collector
needs to know structures and constants which TOMOYO uses.
Add refcounter to "struct tomoyo_name_entry" and replace tomoyo_save_name()
with tomoyo_get_name()/tomoyo_put_name() pair so that we can kfree() when
garbage collector is added.
TOMOYO was using own memory usage counter for detecting memory leak.
But as kernel 2.6.31 introduced memory leak detection mechanism
( CONFIG_DEBUG_KMEMLEAK ), we no longer need to have own counter.
We remove usage counter for memory used for permission checks, but we keep
usage counter for memory used for policy so that we can apply quota.
Currently, TOMOYO allocates memory for list elements from memory pool allocated
by kmalloc(PAGE_SIZE). But that makes it difficult to kfree() when garbage
collector is added. Thus, remove memory pool and use kmalloc(sizeof()).
Currently, TOMOYO allocates memory for string data from memory pool allocated
collector is added. Thus, remove memory pool and use kmalloc(strlen()).
Replace list operation with RCU primitives and replace
down_read()/up_read() with srcu_read_lock()/srcu_read_unlock().
Please apply below one after merging 1557d33007f63dd96e5d15f33af389378e5f2e54
(Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6).
[PATCH for 2.6.33] TOMOYO: Compare filesystem by magic number rather than by name.
We can use magic number for checking whether the filesystem is procfs or not.
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits)
security/tomoyo: Remove now unnecessary handling of security_sysctl.
security/tomoyo: Add a special case to handle accesses through the internal proc mount.
sysctl: Drop & in front of every proc_handler.
sysctl: Remove CTL_NONE and CTL_UNNUMBERED
sysctl: kill dead ctl_handler definitions.
sysctl: Remove the last of the generic binary sysctl support
sysctl net: Remove unused binary sysctl code
sysctl security/tomoyo: Don't look at ctl_name
sysctl arm: Remove binary sysctl support
sysctl x86: Remove dead binary sysctl support
sysctl sh: Remove dead binary sysctl support
sysctl powerpc: Remove dead binary sysctl support
sysctl ia64: Remove dead binary sysctl support
sysctl s390: Remove dead sysctl binary support
sysctl frv: Remove dead binary sysctl support
sysctl mips/lasat: Remove dead binary sysctl support
sysctl drivers: Remove dead binary sysctl support
sysctl crypto: Remove dead binary sysctl support
sysctl security/keys: Remove dead binary sysctl support
sysctl kernel: Remove binary sysctl logic
proc mount.
With the change of sys_sysctl going through the internal proc mount we no
longer need to handle security_sysctl in tomoyo as we have valid pathnames
for all sysctl accesses. There is one slight caveat to that in that
all of the paths from the internal mount look like
"/sys/net/ipv4/ip_local_port_range" instead of
"/proc/sys/net/ipv4/ip_local_port_range" so tomoyo needs to add the
"/proc" portion manually when resolving to full path names to get what it expects.
This change teaches tomoyo perform that modification.
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Acked-by: John Johansen <john.johansen@canonical.com>
When examining the network device name hash, it was discovered that
the low order bits of full_name_hash() are not very well dispersed
across the possible values. When used by filesystem code, this is handled
by folding with the function hash_long().
The only other non-filesystem usage of full_name_hash() at this time
appears to be in TOMOYO. This patch should fix that.
I do not use TOMOYO at this time, so this patch is build tested only.
This patch adds some descriptions of lists and structures.
This patch contains no code changes.
Remove '/***** START/STOP *****/' markers.
... use kern_path() where possible
[folded a fix from rdd]
Signed-off-by: Kentaro Takeda <takedakn@nttdata.co.jp>
Signed-off-by: Toshiharu Harada <haradats@nttdata.co.jp>
Don't pull it in sched.h; very few files actually need it and those
can include directly. sched.h itself only needs forward declaration
of struct fs_struct;
tomoyo_realpath_init() is unconditionally called by security_initcall().
But nobody will use realpath related functions if TOMOYO is not registered.
So, let tomoyo_init() call tomoyo_realpath_init().
This patch saves 4KB of memory allocation if TOMOYO is not registered.
TOMOYO Linux performs pathname based access control.
To remove factors that make pathname based access control difficult
(e.g. symbolic links, "..", "//" etc.), TOMOYO Linux derives realpath
of requested pathname from "struct dentry" and "struct vfsmount".
The maximum length of string data is limited to 4000 including trailing '\0'.
Since TOMOYO Linux uses '\ooo' style representation for non ASCII printable
characters, maybe TOMOYO Linux should be able to support 16336 (which means
(NAME_MAX * (PATH_MAX / (NAME_MAX + 1)) * 4 + (PATH_MAX / (NAME_MAX + 1)))
including trailing '\0'), but I think 4000 is enough for practical use.
TOMOYO uses only 0x21 - 0x7E (as printable characters) and 0x20 (as word
delimiter) and 0x0A (as line delimiter).
0x01 - 0x20 and 0x80 - 0xFF is handled in \ooo style representation.
The reason to use \ooo is to guarantee that "%s" won't damage logs.
Userland program can request
open("/tmp/file granted.\nAccess /tmp/file ", O_WRONLY | O_CREAT, 0600)
and logging such crazy pathname using "Access %s denied.\n" format will cause
"fabrication of logs" like
Access /tmp/file granted.
Access /tmp/file denied.
TOMOYO converts such characters to \ooo so that the logs will become
Access /tmp/file\040granted.\012Access\040/tmp/file denied.
and the administrator can read the logs safely using /bin/cat .
Likewise, a crazy request like
open("/tmp/\x01\x02\x03\x04\x05\x06\x07\x08\x09", O_WRONLY | O_CREAT, 0600)
will be processed safely by converting to
Access /tmp/\001\002\003\004\005\006\007\010\011 denied.
