commit c9f838d104fed6f2f61d68164712e3204bf5271b upstream.
This fixes CVE-2017-7472.
Running the following program as an unprivileged user exhausts kernel
memory by leaking thread keyrings:
#include <keyutils.h>
int main()
for (;;)
keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_THREAD_KEYRING);
Fix it by only creating a new thread keyring if there wasn't one before.
To make things more consistent, make install_thread_keyring_to_cred()
and install_process_keyring_to_cred() both return 0 if the corresponding
keyring is already present.
Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials")
commit c1644fe041ebaf6519f6809146a77c3ead9193af upstream.
This fixes CVE-2017-6951.
Userspace should not be able to do things with the "dead" key type as it
doesn't have some of the helper functions set upon it that the kernel
needs. Attempting to use it may cause the kernel to crash.
Fix this by changing the name of the type to ".dead" so that it's rejected
up front on userspace syscalls by key_get_type_from_user().
Though this doesn't seem to affect recent kernels, it does affect older
ones, certainly those prior to:
commit c06cfb08b88dfbe13be44a69ae2fdc3a7c902d81
Author: David Howells <dhowells@redhat.com>
Date: Tue Sep 16 17:36:06 2014 +0100
KEYS: Remove key_type::match in favour of overriding default by match_preparse
which went in before 3.18-rc1.
commit ee8f844e3c5a73b999edf733df1c529d6503ec2f upstream.
This fixes CVE-2016-9604.
Keyrings whose name begin with a '.' are special internal keyrings and so
userspace isn't allowed to create keyrings by this name to prevent
shadowing. However, the patch that added the guard didn't fix
KEYCTL_JOIN_SESSION_KEYRING. Not only can that create dot-named keyrings,
it can also subscribe to them as a session keyring if they grant SEARCH
permission to the user.
This, for example, allows a root process to set .builtin_trusted_keys as
its session keyring, at which point it has full access because now the
possessor permissions are added. This permits root to add extra public
keys, thereby bypassing module verification.
This also affects kexec and IMA.
This can be tested by (as root):
keyctl session .builtin_trusted_keys
keyctl add user a a @s
keyctl list @s
which on my test box gives me:
2 keys in keyring:
180010936: ---lswrv 0 0 asymmetric: Build time autogenerated kernel key: ae3d4a31b82daa8e1a75b49dc2bba949fd992a05
801382539: --alswrv 0 0 user: a
Fix this by rejecting names beginning with a '.' in the keyctl.
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
cc: linux-ima-devel@lists.sourceforge.net
commit bc15ed663e7e53ee4dc3e60f8d09c93a0528c694 upstream.
On failure to return a pathname from ima_d_path(), a pointer to
dname is returned, which is subsequently used in the IMA measurement
list, the IMA audit records, and other audit logging. Saving the
pointer to dname for later use has the potential to race with rename.
Intead of returning a pointer to dname on failure, this patch returns
a pointer to a copy of the filename.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 0c461cb727d146c9ef2d3e86214f498b78b7d125 upstream.
SELinux tries to support setting/clearing of /proc/pid/attr attributes
from the shell by ignoring terminating newlines and treating an
attribute value that begins with a NUL or newline as an attempt to
clear the attribute. However, the test for clearing attributes has
always been wrong; it has an off-by-one error, and this could further
lead to reading past the end of the allocated buffer since commit
bb646cdb12e75d82258c2f2e7746d5952d3e321a ("proc_pid_attr_write():
switch to memdup_user()"). Fix the off-by-one error.
Even with this fix, setting and clearing /proc/pid/attr attributes
from the shell is not straightforward since the interface does not
support multiple write() calls (so shells that write the value and
newline separately will set and then immediately clear the attribute,
requiring use of echo -n to set the attribute), whereas trying to use
echo -n "" to clear the attribute causes the shell to skip the
write() call altogether since POSIX says that a zero-length write
causes no side effects. Thus, one must use echo -n to set and echo
without -n to clear, as in the following example:
$ echo -n unconfined_u:object_r:user_home_t:s0 > /proc/$$/attr/fscreate
$ cat /proc/$$/attr/fscreate
$ echo "" > /proc/$$/attr/fscreate
Note the use of /proc/$$ rather than /proc/self, as otherwise
the cat command will read its own attribute value, not that of the shell.
There are no users of this facility to my knowledge; possibly we
should just get rid of it.
UPDATE: Upon further investigation it appears that a local process
with the process:setfscreate permission can cause a kernel panic as a
result of this bug. This patch fixes CVE-2017-2618.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
[PM: added the update about CVE-2017-2618 to the commit description]
Signed-off-by: Paul Moore <paul@paul-moore.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 9a11a18902bc3b904353063763d06480620245a6 upstream.
When the "policy" securityfs file is opened for read, it is opened as a
sequential file. However, when it is eventually released, there is no
cleanup for the sequential file, therefore some memory is leaked.
This patch adds a call to seq_release() in ima_release_policy() to clean up
the memory when the file is opened for read.
Fixes: 80eae209d63a IMA: allow reading back the current policy
Reported-by: Colin Ian King <colin.king@canonical.com>
Signed-off-by: Eric Richter <erichte@linux.vnet.ibm.com>
Tested-by: Colin Ian King <colin.king@canonical.com>
After a policy replacement, the task cred may be out of date and need
to be updated. However change_hat is using the stale profiles from
the out of date cred resulting in either: a stale profile being applied
or, incorrect failure when searching for a hat profile as it has been
migrated to the new parent profile.
Fixes: 01e2b670aa898a39259bc85c78e3d74820f4d3b6 (failure to find hat)
Fixes: 898127c34ec03291c86f4ff3856d79e9e18952bc (stale policy being applied)
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1000287
Cc: stable@vger.kernel.org
Signed-off-by: John Johansen <john.johansen@canonical.com>
Since BIG_KEYS can't be compiled as module it requires one of the "stdrng"
providers to be compiled into kernel. Otherwise big_key_crypto_init() fails
on crypto_alloc_rng step and next dereference of big_key_skcipher (e.g. in
big_key_preparse()) results in a NULL pointer dereference.
Fixes: 13100a72f40f5748a04017e0ab3df4cf27c809ef ('Security: Keys: Big keys stored encrypted')
Signed-off-by: Artem Savkov <asavkov@redhat.com>
cc: Stephan Mueller <smueller@chronox.de>
cc: Kirill Marinushkin <k.marinushkin@gmail.com>
cc: stable@vger.kernel.org
big_key has two separate initialisation functions, one that registers the
key type and one that registers the crypto. If the key type fails to
register, there's no problem if the crypto registers successfully because
there's no way to reach the crypto except through the key type.
However, if the key type registers successfully but the crypto does not,
big_key_rng and big_key_blkcipher may end up set to NULL - but the code
neither checks for this nor unregisters the big key key type.
Furthermore, since the key type is registered before the crypto, it is
theoretically possible for the kernel to try adding a big_key before the
crypto is set up, leading to the same effect.
Fix this by merging big_key_crypto_init() and big_key_init() and calling
the resulting function late. If they're going to be encrypted, we
shouldn't be creating big_keys before we have the facilities to do the
encryption available. The key type registration is also moved after the
crypto initialisation.
The fix also includes message printing on failure.
If the big_key type isn't correctly set up, simply doing:
dd if=/dev/zero bs=4096 count=1 | keyctl padd big_key a @s
ought to cause an oops.
cc: Peter Hlavaty <zer0mem@yahoo.com>
cc: Artem Savkov <asavkov@redhat.com>
This fixes CVE-2016-7042.
Fix a short sprintf buffer in proc_keys_show(). If the gcc stack protector
is turned on, this can cause a panic due to stack corruption.
The problem is that xbuf[] is not big enough to hold a 64-bit timeout
rendered as weeks:
(gdb) p 0xffffffffffffffffULL/(60*60*24*7)
$2 = 30500568904943
That's 14 chars plus NUL, not 11 chars plus NUL.
Expand the buffer to 16 chars.
I think the unpatched code apparently works if the stack-protector is not
enabled because on a 32-bit machine the buffer won't be overflowed and on a
64-bit machine there's a 64-bit aligned pointer at one side and an int that
isn't checked again on the other side.
The panic incurred looks something like:
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff81352ebe
CPU: 0 PID: 1692 Comm: reproducer Not tainted 4.7.2-201.fc24.x86_64 #1
Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011
0000000000000086 00000000fbbd2679 ffff8800a044bc00 ffffffff813d941f
ffffffff81a28d58 ffff8800a044bc98 ffff8800a044bc88 ffffffff811b2cb6
ffff880000000010 ffff8800a044bc98 ffff8800a044bc30 00000000fbbd2679
Call Trace:
[<ffffffff813d941f>] dump_stack+0x63/0x84
[<ffffffff811b2cb6>] panic+0xde/0x22a
[<ffffffff81352ebe>] ? proc_keys_show+0x3ce/0x3d0
[<ffffffff8109f7f9>] __stack_chk_fail+0x19/0x30
[<ffffffff81352ebe>] proc_keys_show+0x3ce/0x3d0
[<ffffffff81350410>] ? key_validate+0x50/0x50
[<ffffffff8134db30>] ? key_default_cmp+0x20/0x20
[<ffffffff8126b31c>] seq_read+0x2cc/0x390
[<ffffffff812b6b12>] proc_reg_read+0x42/0x70
[<ffffffff81244fc7>] __vfs_read+0x37/0x150
[<ffffffff81357020>] ? security_file_permission+0xa0/0xc0
[<ffffffff81246156>] vfs_read+0x96/0x130
[<ffffffff81247635>] SyS_read+0x55/0xc0
[<ffffffff817eb872>] entry_SYSCALL_64_fastpath+0x1a/0xa4
Reported-by: Ondrej Kozina <okozina@redhat.com>
Tested-by: Ondrej Kozina <okozina@redhat.com>
Pull vmap stack fixes from Ingo Molnar:
"This is fallout from CONFIG_HAVE_ARCH_VMAP_STACK=y on x86: stack
accesses that used to be just somewhat questionable are now totally
buggy.
These changes try to do it without breaking the ABI: the fields are
left there, they are just reporting zero, or reporting narrower
information (the maps file change)"
* 'mm-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
mm: Change vm_is_stack_for_task() to vm_is_stack_for_current()
fs/proc: Stop trying to report thread stacks
fs/proc: Stop reporting eip and esp in /proc/PID/stat
mm/numa: Remove duplicated include from mprotect.c
Asking for a non-current task's stack can't be done without races
unless the task is frozen in kernel mode. As far as I know,
vm_is_stack_for_task() never had a safe non-current use case.
The __unused annotation is because some KSTK_ESP implementations
ignore their parameter, which IMO is further justification for this
patch.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Jann Horn <jann@thejh.net>
Cc: Linux API <linux-api@vger.kernel.org>
Cc: Tycho Andersen <tycho.andersen@canonical.com>
Link: http://lkml.kernel.org/r/4c3f68f426e6c061ca98b4fc7ef85ffbb0a25b0c.1475257877.git.luto@kernel.org
This removes the 'write' and 'force' from get_user_pages_remote() and
replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in
callers as use of this flag can result in surprising behaviour (and
hence bugs) within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
Pull misc vfs updates from Al Viro:
"Assorted misc bits and pieces.
There are several single-topic branches left after this (rename2
series from Miklos, current_time series from Deepa Dinamani, xattr
series from Andreas, uaccess stuff from from me) and I'd prefer to
send those separately"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (39 commits)
proc: switch auxv to use of __mem_open()
hpfs: support FIEMAP
cifs: get rid of unused arguments of CIFSSMBWrite()
posix_acl: uapi header split
posix_acl: xattr representation cleanups
fs/aio.c: eliminate redundant loads in put_aio_ring_file
fs/internal.h: add const to ns_dentry_operations declaration
compat: remove compat_printk()
fs/buffer.c: make __getblk_slow() static
proc: unsigned file descriptors
fs/file: more unsigned file descriptors
fs: compat: remove redundant check of nr_segs
cachefiles: Fix attempt to read i_blocks after deleting file [ver #2]
cifs: don't use memcpy() to copy struct iov_iter
get rid of separate multipage fault-in primitives
fs: Avoid premature clearing of capabilities
fs: Give dentry to inode_change_ok() instead of inode
fuse: Propagate dentry down to inode_change_ok()
ceph: Propagate dentry down to inode_change_ok()
xfs: Propagate dentry down to inode_change_ok()
Merge my system logging cleanups, triggered by the broken '\n' patches.
The line continuation handling has been broken basically forever, and
the code to handle the system log records was both confusing and
dubious. And it would do entirely the wrong thing unless you always had
a terminating newline, partly because it couldn't actually see whether a
message was marked KERN_CONT or not (but partly because the LOG_CONT
handling in the recording code was rather confusing too).
This re-introduces a real semantically meaningful KERN_CONT, and fixes
the few places I noticed where it was missing. There are probably more
missing cases, since KERN_CONT hasn't actually had any semantic meaning
for at least four years (other than the checkpatch meaning of "no log
level necessary, this is a continuation line").
This also allows the combination of KERN_CONT and a log level. In that
case the log level will be ignored if the merging with a previous line
is successful, but if a new record is needed, that new record will now
get the right log level.
That also means that you can at least in theory combine KERN_CONT with
the "pr_info()" style helpers, although any use of pr_fmt() prefixing
would make that just result in a mess, of course (the prefix would end
up in the middle of a continuing line).
* printk-cleanups:
printk: make reading the kernel log flush pending lines
printk: re-organize log_output() to be more legible
printk: split out core logging code into helper function
printk: reinstate KERN_CONT for printing continuation lines
Long long ago the kernel log buffer was a buffered stream of bytes, very
much like stdio in user space. It supported log levels by scanning the
stream and noticing the log level markers at the beginning of each line,
but if you wanted to print a partial line in multiple chunks, you just
did multiple printk() calls, and it just automatically worked.
Except when it didn't, and you had very confusing output when different
lines got all mixed up with each other. Then you got fragment lines
mixing with each other, or with non-fragment lines, because it was
traditionally impossible to tell whether a printk() call was a
continuation or not.
To at least help clarify the issue of continuation lines, we added a
KERN_CONT marker back in 2007 to mark continuation lines:
474925277671 ("printk: add KERN_CONT annotation").
That continuation marker was initially an empty string, and didn't
actuall make any semantic difference. But it at least made it possible
to annotate the source code, and have check-patch notice that a printk()
didn't need or want a log level marker, because it was a continuation of
a previous line.
To avoid the ambiguity between a continuation line that had that
KERN_CONT marker, and a printk with no level information at all, we then
in 2009 made KERN_CONT be a real log level marker which meant that we
could now reliably tell the difference between the two cases.
5fd29d6ccbc9 ("printk: clean up handling of log-levels and newlines")
and we could take advantage of that to make sure we didn't mix up
continuation lines with lines that just didn't have any loglevel at all.
Then, in 2012, the kernel log buffer was changed to be a "record" based
log, where each line was a record that has a loglevel and a timestamp.
You can see the beginning of that conversion in commits
e11fea92e13f ("kmsg: export printk records to the /dev/kmsg interface")
7ff9554bb578 ("printk: convert byte-buffer to variable-length record buffer")
with a number of follow-up commits to fix some painful fallout from that
conversion. Over all, it took a couple of months to sort out most of
it. But the upside was that you could have concurrent readers (and
writers) of the kernel log and not have lines with mixed output in them.
And one particular pain-point for the record-based kernel logging was
exactly the fragmentary lines that are generated in smaller chunks. In
order to still log them as one recrod, the continuation lines need to be
attached to the previous record properly.
However the explicit continuation record marker that is actually useful
for this exact case was actually removed in aroundm the same time by commit
61e99ab8e35a ("printk: remove the now unnecessary "C" annotation for KERN_CONT")
due to the incorrect belief that KERN_CONT wasn't meaningful. The
ambiguity between "is this a continuation line" or "is this a plain
printk with no log level information" was reintroduced, and in fact
became an even bigger pain point because there was now the whole
record-level merging of kernel messages going on.
This patch reinstates the KERN_CONT as a real non-empty string marker,
so that the ambiguity is fixed once again.
But it's not a plain revert of that original removal: in the four years
since we made KERN_CONT an empty string again, not only has the format
of the log level markers changed, we've also had some usage changes in
this area.
For example, some ACPI code seems to use KERN_CONT _together_ with a log
level, and now uses both the KERN_CONT marker and (for example) a
KERN_INFO marker to show that it's an informational continuation of a
line.
Which is actually not a bad idea - if the continuation line cannot be
attached to its predecessor, without the log level information we don't
know what log level to assign to it (and we traditionally just assigned
it the default loglevel). So having both a log level and the KERN_CONT
marker is not necessarily a bad idea, but it does mean that we need to
actually iterate over potentially multiple markers, rather than just a
single one.
Also, since KERN_CONT was still conceptually needed, and encouraged, but
didn't actually _do_ anything, we've also had the reverse problem:
rather than having too many annotations it has too few, and there is bit
rot with code that no longer marks the continuation lines with the
KERN_CONT marker.
So this patch not only re-instates the non-empty KERN_CONT marker, it
also fixes up the cases of bit-rot I noticed in my own logs.
There are probably other cases where KERN_CONT will be needed to be
added, either because it is new code that never dealt with the need for
KERN_CONT, or old code that has bitrotted without anybody noticing.
That said, we should strive to avoid the need for KERN_CONT. It does
result in real problems for logging, and should generally not be seen as
a good feature. If we some day can get rid of the feature entirely,
because nobody does any fragmented printk calls, that would be lovely.
But until that point, let's at mark the code that relies on the hacky
multi-fragment kernel printk's. Not only does it avoid the ambiguity,
it also annotates code as "maybe this would be good to fix some day".
(That said, particularly during single-threaded bootup, the downsides of
KERN_CONT are very limited. Things get much hairier when you have
multiple threads going on and user level reading and writing logs too).
Right now, various places in the kernel check for the existence of
getxattr, setxattr, and removexattr inode operations and directly call
those operations. Switch to helper functions and test for the IOP_XATTR
flag instead.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Acked-by: James Morris <james.l.morris@oracle.com>
Pull trivial updates from Jiri Kosina:
"The usual rocket science from the trivial tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
tracing/syscalls: fix multiline in error message text
lib/Kconfig.debug: fix DEBUG_SECTION_MISMATCH description
doc: vfs: fix fadvise() sycall name
x86/entry: spell EBX register correctly in documentation
securityfs: fix securityfs_create_dir comment
irq: Fix typo in tracepoint.xml
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
SELinux/LSM:
- overlayfs support, necessary for container filesystems
LSM:
- finally remove the kernel_module_from_file hook
Smack:
- treat signal delivery as an 'append' operation
TPM:
- lots of bugfixes & updates
Audit:
- new audit data type: LSM_AUDIT_DATA_FILE
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (47 commits)
Revert "tpm/tpm_crb: implement tpm crb idle state"
Revert "tmp/tpm_crb: fix Intel PTT hw bug during idle state"
Revert "tpm/tpm_crb: open code the crb_init into acpi_add"
Revert "tmp/tpm_crb: implement runtime pm for tpm_crb"
lsm,audit,selinux: Introduce a new audit data type LSM_AUDIT_DATA_FILE
tpm: add check for minimum buffer size in tpm_transmit()
tpm: constify TPM 1.x header structures
tpm/tpm_crb: fix the over 80 characters checkpatch warring
tpm/tpm_crb: drop useless cpu_to_le32 when writing to registers
tpm/tpm_crb: cache cmd_size register value.
tmp/tpm_crb: drop include to platform_device
tpm/tpm_tis: remove unused itpm variable
tpm_crb: fix incorrect values of cmdReady and goIdle bits
tpm_crb: refine the naming of constants
tpm_crb: remove wmb()'s
tpm_crb: fix crb_req_canceled behavior
Pull audit updates from Paul Moore:
"Another relatively small pull request for v4.9 with just two patches.
The patch from Richard updates the list of features we support and
report back to userspace; this should have been sent earlier with the
rest of the v4.8 patches but it got lost in my inbox.
The second patch fixes a problem reported by our Android friends where
we weren't very consistent in recording PIDs"
* 'stable-4.9' of git://git.infradead.org/users/pcmoore/audit:
audit: add exclude filter extension to feature bitmap
audit: consistently record PIDs with task_tgid_nr()
If there is an error creating a directory with securityfs_create_dir,
the error is propagated via ERR_PTR but the function comment claims that
NULL is returned.
This is a similar commit to 88e6c94cda322ff2b32f72bb8d96f9675cdad8aa
("fix long-broken securityfs_create_file comment") that did not fix
securityfs_create_dir comment at the same time.
Signed-off-by: Laurent Georget <laurent.georget@supelec.fr>
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
No in-tree uses remain.
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto fixes from Herbert Xu:
"This fixes a regression in RSA that was only half-fixed earlier in the
cycle. It also fixes an older regression that breaks the keyring
subsystem"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: rsa-pkcs1pad - Handle leading zero for decryption
KEYS: Fix skcipher IV clobbering
The IV must not be modified by the skcipher operation so we need
to duplicate it.
Fixes: c3917fd9dfbc ("KEYS: Use skcipher")
Reported-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
into next
Right now LSM_AUDIT_DATA_PATH type contains "struct path" in union "u"
of common_audit_data. This information is used to print path of file
at the same time it is also used to get to dentry and inode. And this
inode information is used to get to superblock and device and print
device information.
This does not work well for layered filesystems like overlay where dentry
contained in path is overlay dentry and not the real dentry of underlying
file system. That means inode retrieved from dentry is also overlay
inode and not the real inode.
SELinux helpers like file_path_has_perm() are doing checks on inode
retrieved from file_inode(). This returns the real inode and not the
overlay inode. That means we are doing check on real inode but for audit
purposes we are printing details of overlay inode and that can be
confusing while debugging.
Hence, introduce a new type LSM_AUDIT_DATA_FILE which carries file
information and inode retrieved is real inode using file_inode(). That
way right avc denied information is given to user.
For example, following is one example avc before the patch.
type=AVC msg=audit(1473360868.399:214): avc: denied { read open } for
pid=1765 comm="cat"
path="/root/.../overlay/container1/merged/readfile"
dev="overlay" ino=21443
scontext=unconfined_u:unconfined_r:test_overlay_client_t:s0:c10,c20
tcontext=unconfined_u:object_r:test_overlay_files_ro_t:s0
tclass=file permissive=0
It looks as follows after the patch.
type=AVC msg=audit(1473360017.388:282): avc: denied { read open } for
pid=2530 comm="cat"
dev="dm-0" ino=2377915
Notice that now dev information points to "dm-0" device instead of
"overlay" device. This makes it clear that check failed on underlying
inode and not on the overlay inode.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
[PM: slight tweaks to the description to make checkpatch.pl happy]
into next
Ima tries to call ->setxattr() on overlayfs dentry after having locked
underlying inode, which results in a deadlock.
Reported-by: Krisztian Litkey <kli@iki.fi>
Fixes: 4bacc9c9234c ("overlayfs: Make f_path always point to the overlay and f_inode to the underlay")
Cc: <stable@vger.kernel.org> # v4.2
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Fix to return error code -EINVAL from the error handling case instead
of 0 (rc is overwrite to 0 when policyvers >=
POLICYDB_VERSION_ROLETRANS), as done elsewhere in this function.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
[PM: normalize "selinux" in patch subject, description line wrap]
Under a strict subject/object security policy delivering a
signal or delivering network IPC could be considered either
a write or an append operation. The original choice to make
both write operations leads to an issue where IPC delivery
is desired under policy, but delivery of signals is not.
This patch provides the option of making signal delivery
an append operation, allowing Smack rules that deny signal
delivery while allowing IPC. This was requested for Tizen.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull more hardened usercopyfixes from Kees Cook:
- force check_object_size() to be inline too
- move page-spanning check behind a CONFIG since it's triggering false
positives
[ Changed the page-spanning config option to depend on EXPERT in the
merge. That way it still gets build testing, and you can enable it if
you want to, but is never enabled for "normal" configurations ]
* tag 'usercopy-v4.8-rc6-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
usercopy: remove page-spanning test for now
usercopy: force check_object_size() inline
A custom allocator without __GFP_COMP that copies to userspace has been
found in vmw_execbuf_process[1], so this disables the page-span checker
by placing it behind a CONFIG for future work where such things can be
tracked down later.
[1] https://bugzilla.redhat.com/show_bug.cgi?id=1373326
Reported-by: Vinson Lee <vlee@freedesktop.org>
Fixes: f5509cc18daa ("mm: Hardened usercopy")
Unfortunately we record PIDs in audit records using a variety of
methods despite the correct way being the use of task_tgid_nr().
This patch converts all of these callers, except for the case of
AUDIT_SET in audit_receive_msg() (see the comment in the code).
Reported-by: Jeff Vander Stoep <jeffv@google.com>
Throughout the SELinux LSM, values taken from sepolicy are
used in places where length == 0 or length == <saturated>
matter, find and fix these.
Signed-off-by: William Roberts <william.c.roberts@intel.com>
libsepol pointed out an issue where its possible to have
an unitialized jmp and invalid dereference, fix this.
While we're here, zero allocate all the *_val_to_struct
structures.
When count is 0 and the highbit is not zero, the ebitmap is not
valid and the internal node is not allocated. This causes issues
when routines, like mls_context_isvalid() attempt to use the
ebitmap_for_each_bit() and ebitmap_node_get_bit() as they assume
a highbit > 0 will have a node allocated.
Reuse existing functionality from memdup_user() instead of keeping
duplicate source code.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
The kernel test robot reported a usercopy failure in the new hardened
sanity checks, due to a page-crossing copy of the FPU state into the
task structure.
This happened because the kernel test robot was testing with SLOB, which
doesn't actually do the required book-keeping for slab allocations, and
as a result the hardening code didn't realize that the task struct
allocation was one single allocation - and the sanity checks fail.
Since SLOB doesn't even claim to support hardening (and you really
shouldn't use it), the straightforward solution is to just make the
usercopy hardening code depend on the allocator supporting it.
Reported-by: kernel test robot <xiaolong.ye@intel.com>
Remove the SECURITY_SELINUX_POLICYDB_VERSION_MAX Kconfig option
Per: https://github.com/SELinuxProject/selinux/wiki/Kernel-Todo
This was only needed on Fedora 3 and 4 and just causes issues now,
so drop it.
The MAX and MIN should just be whatever the kernel can support.
Calculate what would be the label of newly created file and set that
secid in the passed creds.
Context of the task which is actually creating file is retrieved from
set of creds passed in. (old->security).
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
During a new file creation we need to make sure new file is created with the
right label. New file is created in upper/ so effectively file should get
label as if task had created file in upper/.
We switched to mounter's creds for actual file creation. Also if there is a
whiteout present, then file will be created in work/ dir first and then
renamed in upper. In none of the cases file will be labeled as we want it to
be.
This patch introduces a new hook dentry_create_files_as(), which determines
the label/context dentry will get if it had been created by task in upper
and modify passed set of creds appropriately. Caller makes use of these new
creds for file creation.
[PM: fix whitespace issues found with checkpatch.pl]
[PM: changes to use stat->mode in ovl_create_or_link()]
Right now selinux_determine_inode_label() works on security pointer of
current task. Soon I need this to work on a security pointer retrieved
from a set of creds. So start passing in a pointer and caller can
decide where to fetch security pointer from.
When a file is copied up in overlay, we have already created file on
upper/ with right label and there is no need to copy up selinux
label/xattr from lower file to upper file. In fact in case of context
mount, we don't want to copy up label as newly created file got its label
from context= option.
Provide a security hook which is called when xattrs of a file are being
copied up. This hook is called once for each xattr and LSM can return
0 if the security module wants the xattr to be copied up, 1 if the
security module wants the xattr to be discarded on the copy, -EOPNOTSUPP
if the security module does not handle/manage the xattr, or a -errno
upon an error.
[PM: whitespace cleanup for checkpatch.pl]
