path: root/security
2011-05-13Merge branch 'for-linus' of git://git.infradead.org/users/eparis/selinux ↵James Morris
into for-linus
2011-05-12SELinux: delete debugging printks from filename_trans rule processingEric Paris
The filename_trans rule processing has some printk(KERN_ERR ) messages which were intended as debug aids in creating the code but weren't removed before it was submitted. Remove them. Reported-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-05-04Merge branch 'for-linus' of git://git.infradead.org/users/eparis/selinux ↵James Morris
into for-linus
2011-04-28flex_array: flex_array_prealloc takes a number of elements, not an endEric Paris
Change flex_array_prealloc to take the number of elements for which space should be allocated instead of the last (inclusive) element. Users and documentation are updated accordingly. flex_arrays got introduced before they had users. When folks started using it, they ended up needing a different API than was coded up originally. This swaps over to the API that folks apparently need. Based-on-patch-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Paris <eparis@redhat.com> Tested-by: Chris Richards <gizmo@giz-works.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Cc: stable@kernel.org [2.6.38+]
2011-04-28SELinux: pass last path component in may_createEric Paris
New inodes are created in a two stage process. We first will compute the label on a new inode in security_inode_create() and check if the operation is allowed. We will then actually re-compute that same label and apply it in security_inode_init_security(). The change to do new label calculations based in part on the last component of the path name only passed the path component information all the way down the security_inode_init_security hook. Down the security_inode_create hook the path information did not make it past may_create. Thus the two calculations came up differently and the permissions check might not actually be against the label that is created. Pass and use the same information in both places to harmonize the calculations and checks. Reported-by: Dominick Grift <domg472@gmail.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-04-25SELINUX: Make selinux cache VFS RCU walks safeEric Paris
Now that the security modules can decide whether they support the dcache RCU walk or not it's possible to make selinux a bit more RCU friendly. The SELinux AVC and security server access decision code is RCU safe. A specific piece of the LSM audit code may not be RCU safe. This patch makes the VFS RCU walk retry if it would hit the non RCU safe chunk of code. It will normally just work under RCU. This is done simply by passing the VFS RCU state as a flag down into the avc_audit() code and returning ECHILD there if it would have an issue. Based-on-patch-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-22SECURITY: Move exec_permission RCU checks into security modulesAndi Kleen
Right now all RCU walks fall back to reference walk when CONFIG_SECURITY is enabled, even though just the standard capability module is active. This is because security_inode_exec_permission unconditionally fails RCU walks. Move this decision to the low level security module. This requires passing the RCU flags down the security hook. This way at least the capability module and a few easy cases in selinux/smack work with RCU walks with CONFIG_SECURITY=y Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-29selinux: Fix regression for XorgStephen Smalley
Commit 6f5317e730505d5cbc851c435a2dfe3d5a21d343 introduced a bug in the handling of userspace object classes that is causing breakage for Xorg when XSELinux is enabled. Fix the bug by changing map_class() to return SECCLASS_NULL when the class cannot be mapped to a kernel object class. Reported-by: "Justin P. Mattock" <justinmattock@gmail.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: allow ptrace from non-init user namespacesSerge E. Hallyn
ptrace is allowed to tasks in the same user namespace according to the usual rules (i.e. the same rules as for two tasks in the init user namespace). ptrace is also allowed to a user namespace to which the current task the has CAP_SYS_PTRACE capability. Changelog: Dec 31: Address feedback by Eric: . Correct ptrace uid check . Rename may_ptrace_ns to ptrace_capable . Also fix the cap_ptrace checks. Jan 1: Use const cred struct Jan 11: use task_ns_capable() in place of ptrace_capable(). Feb 23: same_or_ancestore_user_ns() was not an appropriate check to constrain cap_issubset. Rather, cap_issubset() only is meaningful when both capsets are in the same user_ns. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: security: make capabilities relative to the user namespaceSerge E. Hallyn
- Introduce ns_capable to test for a capability in a non-default user namespace. - Teach cap_capable to handle capabilities in a non-default user namespace. The motivation is to get to the unprivileged creation of new namespaces. It looks like this gets us 90% of the way there, with only potential uid confusion issues left. I still need to handle getting all caps after creation but otherwise I think I have a good starter patch that achieves all of your goals. Changelog: 11/05/2010: [serge] add apparmor 12/14/2010: [serge] fix capabilities to created user namespaces Without this, if user serge creates a user_ns, he won't have capabilities to the user_ns he created. THis is because we were first checking whether his effective caps had the caps he needed and returning -EPERM if not, and THEN checking whether he was the creator. Reverse those checks. 12/16/2010: [serge] security_real_capable needs ns argument in !security case 01/11/2011: [serge] add task_ns_capable helper 01/11/2011: [serge] add nsown_capable() helper per Bastian Blank suggestion 02/16/2011: [serge] fix a logic bug: the root user is always creator of init_user_ns, but should not always have capabilities to it! Fix the check in cap_capable(). 02/21/2011: Add the required user_ns parameter to security_capable, fixing a compile failure. 02/23/2011: Convert some macros to functions as per akpm comments. Some couldn't be converted because we can't easily forward-declare them (they are inline if !SECURITY, extern if SECURITY). Add a current_user_ns function so we can use it in capability.h without #including cred.h. Move all forward declarations together to the top of the #ifdef __KERNEL__ section, and use kernel-doc format. 02/23/2011: Per dhowells, clean up comment in cap_capable(). 02/23/2011: Per akpm, remove unreachable 'return -EPERM' in cap_capable. (Original written and signed off by Eric; latest, modified version acked by him) [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: export current_user_ns() for ecryptfs] [serge.hallyn@canonical.com: remove unneeded extra argument in selinux's task_has_capability] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits) AppArmor: kill unused macros in lsm.c AppArmor: cleanup generated files correctly KEYS: Add an iovec version of KEYCTL_INSTANTIATE KEYS: Add a new keyctl op to reject a key with a specified error code KEYS: Add a key type op to permit the key description to be vetted KEYS: Add an RCU payload dereference macro AppArmor: Cleanup make file to remove cruft and make it easier to read SELinux: implement the new sb_remount LSM hook LSM: Pass -o remount options to the LSM SELinux: Compute SID for the newly created socket SELinux: Socket retains creator role and MLS attribute SELinux: Auto-generate security_is_socket_class TOMOYO: Fix memory leak upon file open. Revert "selinux: simplify ioctl checking" selinux: drop unused packet flow permissions selinux: Fix packet forwarding checks on postrouting selinux: Fix wrong checks for selinux_policycap_netpeer selinux: Fix check for xfrm selinux context algorithm ima: remove unnecessary call to ima_must_measure IMA: remove IMA imbalance checking ...
2011-03-15Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits) posix-clocks: Check write permissions in posix syscalls hrtimer: Remove empty hrtimer_init_hres_timer() hrtimer: Update hrtimer->state documentation hrtimer: Update base[CLOCK_BOOTTIME].offset correctly timers: Export CLOCK_BOOTTIME via the posix timers interface timers: Add CLOCK_BOOTTIME hrtimer base time: Extend get_xtime_and_monotonic_offset() to also return sleep time: Introduce get_monotonic_boottime and ktime_get_boottime hrtimers: extend hrtimer base code to handle more then 2 clockids ntp: Remove redundant and incorrect parameter check mn10300: Switch do_timer() to xtimer_update() posix clocks: Introduce dynamic clocks posix-timers: Cleanup namespace posix-timers: Add support for fd based clocks x86: Add clock_adjtime for x86 posix-timers: Introduce a syscall for clock tuning. time: Splitout compat timex accessors ntp: Add ADJ_SETOFFSET mode bit time: Introduce timekeeping_inject_offset posix-timer: Update comment ... Fix up new system-call-related conflicts in arch/x86/ia32/ia32entry.S arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/syscall_table_32.S (name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some due to movement of get_jiffies_64() in: kernel/time.c
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Merge branch 'security-next' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/jj/apparmor-dev into next
2011-03-08AppArmor: kill unused macros in lsm.cShan Wei
Remove unused macros. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: John Johansen <john.johansen@canonical.com>
2011-03-08AppArmor: cleanup generated files correctlyMichal Hocko
clean-files should be defined as a variable not a target. Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: John Johansen <john.johansen@canonical.com>
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-03-08KEYS: Add an iovec version of KEYCTL_INSTANTIATEDavid Howells
Add a keyctl op (KEYCTL_INSTANTIATE_IOV) that is like KEYCTL_INSTANTIATE, but takes an iovec array and concatenates the data in-kernel into one buffer. Since the KEYCTL_INSTANTIATE copies the data anyway, this isn't too much of a problem. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08KEYS: Add a new keyctl op to reject a key with a specified error codeDavid Howells
Add a new keyctl op to reject a key with a specified error code. This works much the same as negating a key, and so keyctl_negate_key() is made a special case of keyctl_reject_key(). The difference is that keyctl_negate_key() selects ENOKEY as the error to be reported. Typically the key would be rejected with EKEYEXPIRED, EKEYREVOKED or EKEYREJECTED, but this is not mandatory. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08KEYS: Add a key type op to permit the key description to be vettedDavid Howells
Add a key type operation to permit the key type to vet the description of a new key that key_alloc() is about to allocate. The operation may reject the description if it wishes with an error of its choosing. If it does this, the key will not be allocated. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08KEYS: Add an RCU payload dereference macroDavid Howells
Add an RCU payload dereference macro as this seems to be a common piece of code amongst key types that use RCU referenced payloads. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08Merge branch 'master'; commit 'v2.6.38-rc7' into nextJames Morris
2011-03-05AppArmor: Cleanup make file to remove cruft and make it easier to readJohn Johansen
Cleanups based on comments from Sam Ravnborg, * remove references to the currently unused af_names.h * add rlim_names.h to clean-files: * rework cmd_make-XXX to make them more readable by adding comments, reworking the expressions to put logical components on individual lines, and keep lines < 80 characters. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2011-03-03netlink: kill eff_cap from struct netlink_skb_parmsPatrick McHardy
Netlink message processing in the kernel is synchronous these days, capabilities can be checked directly in security_netlink_recv() from the current process. Signed-off-by: Patrick McHardy <kaber@trash.net> Reviewed-by: James Morris <jmorris@namei.org> [chrisw: update to include pohmelfs and uvesafb] Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-03SELinux: implement the new sb_remount LSM hookEric Paris
For SELinux we do not allow security information to change during a remount operation. Thus this hook simply strips the security module options from the data and verifies that those are the same options as exist on the current superblock. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-03-03LSM: Pass -o remount options to the LSMEric Paris
The VFS mount code passes the mount options to the LSM. The LSM will remove options it understands from the data and the VFS will then pass the remaining options onto the underlying filesystem. This is how options like the SELinux context= work. The problem comes in that -o remount never calls into LSM code. So if you include an LSM specific option it will get passed to the filesystem and will cause the remount to fail. An example of where this is a problem is the 'seclabel' option. The SELinux LSM hook will print this word in /proc/mounts if the filesystem is being labeled using xattrs. If you pass this word on mount it will be silently stripped and ignored. But if you pass this word on remount the LSM never gets called and it will be passed to the FS. The FS doesn't know what seclabel means and thus should fail the mount. For example an ext3 fs mounted over loop # mount -o loop /tmp/fs /mnt/tmp # cat /proc/mounts | grep /mnt/tmp /dev/loop0 /mnt/tmp ext3 rw,seclabel,relatime,errors=continue,barrier=0,data=ordered 0 0 # mount -o remount /mnt/tmp mount: /mnt/tmp not mounted already, or bad option # dmesg EXT3-fs (loop0): error: unrecognized mount option "seclabel" or missing value This patch passes the remount mount options to an new LSM hook. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-03-03SELinux: Compute SID for the newly created socketHarry Ciao
The security context for the newly created socket shares the same user, role and MLS attribute as its creator but may have a different type, which could be specified by a type_transition rule in the relevant policy package. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> [fix call to security_transition_sid to include qstr, Eric Paris] Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
2011-03-03SELinux: Socket retains creator role and MLS attributeHarry Ciao
The socket SID would be computed on creation and no longer inherit its creator's SID by default. Socket may have a different type but needs to retain the creator's role and MLS attribute in order not to break labeled networking and network access control. The kernel value for a class would be used to determine if the class if one of socket classes. If security_compute_sid is called from userspace the policy value for a class would be mapped to the relevant kernel value first. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
2011-03-03SELinux: Auto-generate security_is_socket_classHarry Ciao
The security_is_socket_class() is auto-generated by genheaders based on classmap.h to reduce maintenance effort when a new class is defined in SELinux kernel. The name for any socket class should be suffixed by "socket" and doesn't contain more than one substr of "socket". Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
2011-03-03netlink: kill loginuid/sessionid/sid members from struct netlink_skb_parmsPatrick McHardy
Netlink message processing in the kernel is synchronous these days, the session information can be collected when needed. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-03TOMOYO: Fix memory leak upon file open.Tetsuo Handa
In tomoyo_check_open_permission() since 2.6.36, TOMOYO was by error recalculating already calculated pathname when checking allow_rewrite permission. As a result, memory will leak whenever a file is opened for writing without O_APPEND flag. Also, performance will degrade because TOMOYO is calculating pathname regardless of profile configuration. This patch fixes the leak and performance degrade. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-02-25Revert "selinux: simplify ioctl checking"Eric Paris
This reverts commit 242631c49d4cf39642741d6627750151b058233b. Conflicts: security/selinux/hooks.c SELinux used to recognize certain individual ioctls and check permissions based on the knowledge of the individual ioctl. In commit 242631c49d4cf396 the SELinux code stopped trying to understand individual ioctls and to instead looked at the ioctl access bits to determine in we should check read or write for that operation. This same suggestion was made to SMACK (and I believe copied into TOMOYO). But this suggestion is total rubbish. The ioctl access bits are actually the access requirements for the structure being passed into the ioctl, and are completely unrelated to the operation of the ioctl or the object the ioctl is being performed upon. Take FS_IOC_FIEMAP as an example. FS_IOC_FIEMAP is defined as: FS_IOC_FIEMAP _IOWR('f', 11, struct fiemap) So it has access bits R and W. What this really means is that the kernel is going to both read and write to the struct fiemap. It has nothing at all to do with the operations that this ioctl might perform on the file itself! Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
2011-02-25selinux: drop unused packet flow permissionsEric Paris
These permissions are not used and can be dropped in the kernel definitions. Suggested-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
2011-02-25selinux: Fix packet forwarding checks on postroutingSteffen Klassert
The IPSKB_FORWARDED and IP6SKB_FORWARDED flags are used only in the multicast forwarding case to indicate that a packet looped back after forward. So these flags are not a good indicator for packet forwarding. A better indicator is the incoming interface. If we have no socket context, but an incoming interface and we see the packet in the ip postroute hook, the packet is going to be forwarded. With this patch we use the incoming interface as an indicator on packet forwarding. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-02-25selinux: Fix wrong checks for selinux_policycap_netpeerSteffen Klassert
selinux_sock_rcv_skb_compat and selinux_ip_postroute_compat are just called if selinux_policycap_netpeer is not set. However in these functions we check if selinux_policycap_netpeer is set. This leads to some dead code and to the fact that selinux_xfrm_postroute_last is never executed. This patch removes the dead code and the checks for selinux_policycap_netpeer in the compatibility functions. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-02-25selinux: Fix check for xfrm selinux context algorithmSteffen Klassert
selinux_xfrm_sec_ctx_alloc accidentally checks the xfrm domain of interpretation against the selinux context algorithm. This patch fixes this by checking ctx_alg against the selinux context algorithm. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-02-23ima: remove unnecessary call to ima_must_measureMimi Zohar
The original ima_must_measure() function based its results on cached iint information, which required an iint be allocated for all files. Currently, an iint is allocated only for files in policy. As a result, for those files in policy, ima_must_measure() is now called twice: once to determine if the inode is in the measurement policy and, the second time, to determine if it needs to be measured/re-measured. The second call to ima_must_measure() unnecessarily checks to see if the file is in policy. As we already know the file is in policy, this patch removes the second unnecessary call to ima_must_measure(), removes the vestige iint parameter, and just checks the iint directly to determine if the inode has been measured or needs to be measured/re-measured. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com>
2011-02-22xfrm: Mark flowi arg to security_xfrm_state_pol_flow_match() const.David S. Miller
2011-02-11security: add cred argument to security_capable()Chris Wright
Expand security_capable() to include cred, so that it can be usable in a wider range of call sites. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-02-10IMA: remove IMA imbalance checkingMimi Zohar
Now that i_readcount is maintained by the VFS layer, remove the imbalance checking in IMA. Cleans up the IMA code nicely. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com>
2011-02-10IMA: maintain i_readcount in the VFS layerMimi Zohar
ima_counts_get() updated the readcount and invalidated the PCR, as necessary. Only update the i_readcount in the VFS layer. Move the PCR invalidation checks to ima_file_check(), where it belongs. Maintaining the i_readcount in the VFS layer, will allow other subsystems to use i_readcount. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com>
2011-02-10IMA: convert i_readcount to atomicMimi Zohar
Convert the inode's i_readcount from an unsigned int to atomic. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com>
2011-02-09Smack: correct final mmap check comparisonCasey Schaufler
The mmap policy enforcement checks the access of the SMACK64MMAP subject against the current subject incorrectly. The check as written works correctly only if the access rules involved have the same access. This is the common case, so initial testing did not find a problem. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-02-09security:smack: kill unused SMACK_LIST_MAX, MAY_ANY and MAY_ANYWRITEShan Wei
Kill unused macros of SMACK_LIST_MAX, MAY_ANY and MAY_ANYWRITE. v2: As Casey Schaufler's advice, also remove MAY_ANY. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-02-09Smack: correct behavior in the mmap hookCasey Schaufler
The mmap policy enforcement was not properly handling the interaction between the global and local rule lists. Instead of going through one and then the other, which missed the important case where a rule specified that there should be no access, combine the access limitations where there is a rule in each list. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-02-07CRED: Fix BUG() upon security_cred_alloc_blank() failureTetsuo Handa
In cred_alloc_blank() since 2.6.32, abort_creds(new) is called with new->security == NULL and new->magic == 0 when security_cred_alloc_blank() returns an error. As a result, BUG() will be triggered if SELinux is enabled or CONFIG_DEBUG_CREDENTIALS=y. If CONFIG_DEBUG_CREDENTIALS=y, BUG() is called from __invalid_creds() because cred->magic == 0. Failing that, BUG() is called from selinux_cred_free() because selinux_cred_free() is not expecting cred->security == NULL. This does not affect smack_cred_free(), tomoyo_cred_free() or apparmor_cred_free(). Fix these bugs by (1) Set new->magic before calling security_cred_alloc_blank(). (2) Handle null cred->security in creds_are_invalid() and selinux_cred_free(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-02time: Correct the *settime* parametersRichard Cochran
Both settimeofday() and clock_settime() promise with a 'const' attribute not to alter the arguments passed in. This patch adds the missing 'const' attribute into the various kernel functions implementing these calls. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Acked-by: John Stultz <johnstul@us.ibm.com> LKML-Reference: <20110201134417.545698637@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
