path: root/security
2014-05-13Merge branch 'for-3.15-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fixes from Tejun Heo: "During recent restructuring, device_cgroup unified config input check and enforcement logic; unfortunately, it turned out to share too much. Aristeu's patches fix the breakage and marked for -stable backport. The other two patches are fallouts from kernfs conversion. The blkcg change is temporary and will go away once kernfs internal locking gets simplified (patches pending)" * 'for-3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: blkcg: use trylock on blkcg_pol_mutex in blkcg_reset_stats() device_cgroup: check if exception removal is allowed device_cgroup: fix the comment format for recently added functions device_cgroup: rework device access check and exception checking cgroup: fix the retry path of cgroup_mount()
2014-05-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "dcache fixes + kvfree() (uninlined, exported by mm/util.c) + posix_acl bugfix from hch" The dcache fixes are for a subtle LRU list corruption bug reported by Miklos Szeredi, where people inside IBM saw list corruptions with the LTP/host01 test. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nick kvfree() from apparmor posix_acl: handle NULL ACL in posix_acl_equiv_mode dcache: don't need rcu in shrink_dentry_list() more graceful recovery in umount_collect() don't remove from shrink list in select_collect() dentry_kill(): don't try to remove from shrink list expand the call of dentry_lru_del() in dentry_kill() new helper: dentry_free() fold try_prune_one_dentry() fold d_kill() and d_free() fix races between __d_instantiate() and checks of dentry flags
2014-05-06nick kvfree() from apparmorAl Viro
too many places open-code it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-05device_cgroup: check if exception removal is allowedAristeu Rozanski
[PATCH v3 1/2] device_cgroup: check if exception removal is allowed When the device cgroup hierarchy was introduced in bd2953ebbb53 - devcg: propagate local changes down the hierarchy a specific case was overlooked. Consider the hierarchy bellow: A default policy: ALLOW, exceptions will deny access \ B default policy: ALLOW, exceptions will deny access There's no need to verify when an new exception is added to B because in this case exceptions will deny access to further devices, which is always fine. Hierarchy in device cgroup only makes sure B won't have more access than A. But when an exception is removed (by writing devices.allow), it isn't checked if the user is in fact removing an inherited exception from A, thus giving more access to B. Example: # echo 'a' >A/devices.allow # echo 'c 1:3 rw' >A/devices.deny # echo $$ >A/B/tasks # echo >/dev/null -bash: /dev/null: Operation not permitted # echo 'c 1:3 w' >A/B/devices.allow # echo >/dev/null # This shouldn't be allowed and this patch fixes it by making sure to never allow exceptions in this case to be removed if the exception is partially or fully present on the parent. v3: missing '*' in function description v2: improved log message and formatting fixes Cc: cgroups@vger.kernel.org Cc: Li Zefan <lizefan@huawei.com> Cc: stable@vger.kernel.org Signed-off-by: Aristeu Rozanski <arozansk@redhat.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-04device_cgroup: fix the comment format for recently added functionsAristeu Rozanski
Moving more extensive explanations to the end of the comment. Cc: Li Zefan <lizefan@huawei.com> Signed-off-by: Aristeu Rozanski <arozansk@redhat.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-04-22locks: rename file-private locks to "open file description locks"Jeff Layton
File-private locks have been merged into Linux for v3.15, and *now* people are commenting that the name and macro definitions for the new file-private locks suck. ...and I can't even disagree. The names and command macros do suck. We're going to have to live with these for a long time, so it's important that we be happy with the names before we're stuck with them. The consensus on the lists so far is that they should be rechristened as "open file description locks". The name isn't a big deal for the kernel, but the command macros are not visually distinct enough from the traditional POSIX lock macros. The glibc and documentation folks are recommending that we change them to look like F_OFD_{GETLK|SETLK|SETLKW}. That lessens the chance that a programmer will typo one of the commands wrong, and also makes it easier to spot this difference when reading code. This patch makes the following changes that I think are necessary before v3.15 ships: 1) rename the command macros to their new names. These end up in the uapi headers and so are part of the external-facing API. It turns out that glibc doesn't actually use the fcntl.h uapi header, but it's hard to be sure that something else won't. Changing it now is safest. 2) make the the /proc/locks output display these as type "OFDLCK" Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Carlos O'Donell <carlos@redhat.com> Cc: Stefan Metzmacher <metze@samba.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Frank Filz <ffilzlnx@mindspring.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2014-04-21device_cgroup: rework device access check and exception checkingAristeu Rozanski
Whenever a device file is opened and checked against current device cgroup rules, it uses the same function (may_access()) as when a new exception rule is added by writing devices.{allow,deny}. And in both cases, the algorithm is the same, doesn't matter the behavior. First problem is having device access to be considered the same as rule checking. Consider the following structure: A (default behavior: allow, exceptions disallow access) \ B (default behavior: allow, exceptions disallow access) A new exception is added to B by writing devices.deny: c 12:34 rw When checking if that exception is allowed in may_access(): if (dev_cgroup->behavior == DEVCG_DEFAULT_ALLOW) { if (behavior == DEVCG_DEFAULT_ALLOW) { /* the exception will deny access to certain devices */ return true; Which is ok, since B is not getting more privileges than A, it doesn't matter and the rule is accepted Now, consider it's a device file open check and the process belongs to cgroup B. The access will be generated as: behavior: allow exception: c 12:34 rw The very same chunk of code will allow it, even if there's an explicit exception telling to do otherwise. A simple test case: # mkdir new_group # cd new_group # echo $$ >tasks # echo "c 1:3 w" >devices.deny # echo >/dev/null # echo $? 0 This is a serious bug and was introduced on c39a2a3018f8 devcg: prepare may_access() for hierarchy support To solve this problem, the device file open function was split from the new exception check. Second problem is how exceptions are processed by may_access(). The first part of the said function tries to match fully with an existing exception: list_for_each_entry_rcu(ex, &dev_cgroup->exceptions, list) { if ((refex->type & DEV_BLOCK) && !(ex->type & DEV_BLOCK)) continue; if ((refex->type & DEV_CHAR) && !(ex->type & DEV_CHAR)) continue; if (ex->major != ~0 && ex->major != refex->major) continue; if (ex->minor != ~0 && ex->minor != refex->minor) continue; if (refex->access & (~ex->access)) continue; match = true; break; } That means the new exception should be contained into an existing one to be considered a match: New exception Existing match? notes b 12:34 rwm b 12:34 rwm yes b 12:34 r b *:34 rw yes b 12:34 rw b 12:34 w no extra "r" b *:34 rw b 12:34 rw no too broad "*" b *:34 rw b *:34 rwm yes Which is fine in some cases. Consider: A (default behavior: deny, exceptions allow access) \ B (default behavior: deny, exceptions allow access) In this case the full match makes sense, the new exception cannot add more access than the parent allows But this doesn't always work, consider: A (default behavior: allow, exceptions disallow access) \ B (default behavior: deny, exceptions allow access) In this case, a new exception in B shouldn't match any of the exceptions in A, after all you can't allow something that was forbidden by A. But consider this scenario: New exception Existing in A match? outcome b 12:34 rw b 12:34 r no exception is accepted Because the new exception has "w" as extra, it doesn't match, so it'll be added to B's exception list. The same problem can happen during a file access check. Consider a cgroup with allow as default behavior: Access Exception match? b 12:34 rw b 12:34 r no In this case, the access didn't match any of the exceptions in the cgroup, which is required since exceptions will disallow access. To solve this problem, two new functions were created to match an exception either fully or partially. In the example above, a partial check will be performed and it'll produce a match since at least "b 12:34 r" from "b 12:34 rw" access matches. Cc: cgroups@vger.kernel.org Cc: Tejun Heo <tj@kernel.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: Li Zefan <lizefan@huawei.com> Cc: stable@vger.kernel.org Signed-off-by: Aristeu Rozanski <arozansk@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-04-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The first vfs pile, with deep apologies for being very late in this window. Assorted cleanups and fixes, plus a large preparatory part of iov_iter work. There's a lot more of that, but it'll probably go into the next merge window - it *does* shape up nicely, removes a lot of boilerplate, gets rid of locking inconsistencie between aio_write and splice_write and I hope to get Kent's direct-io rewrite merged into the same queue, but some of the stuff after this point is having (mostly trivial) conflicts with the things already merged into mainline and with some I want more testing. This one passes LTP and xfstests without regressions, in addition to usual beating. BTW, readahead02 in ltp syscalls testsuite has started giving failures since "mm/readahead.c: fix readahead failure for memoryless NUMA nodes and limit readahead pages" - might be a false positive, might be a real regression..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) missing bits of "splice: fix racy pipe->buffers uses" cifs: fix the race in cifs_writev() ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure kill generic_file_buffered_write() ocfs2_file_aio_write(): switch to generic_perform_write() ceph_aio_write(): switch to generic_perform_write() xfs_file_buffered_aio_write(): switch to generic_perform_write() export generic_perform_write(), start getting rid of generic_file_buffer_write() generic_file_direct_write(): get rid of ppos argument btrfs_file_aio_write(): get rid of ppos kill the 5th argument of generic_file_buffered_write() kill the 4th argument of __generic_file_aio_write() lustre: don't open-code kernel_recvmsg() ocfs2: don't open-code kernel_recvmsg() drbd: don't open-code kernel_recvmsg() constify blk_rq_map_user_iov() and friends lustre: switch to kernel_sendmsg() ocfs2: don't open-code kernel_sendmsg() take iov_iter stuff to mm/iov_iter.c process_vm_access: tidy up a bit ...
2014-04-12Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris. * git://git.infradead.org/users/eparis/audit: (28 commits) AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range audit: do not cast audit_rule_data pointers pointlesly AUDIT: Allow login in non-init namespaces audit: define audit_is_compat in kernel internal header kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c sched: declare pid_alive as inline audit: use uapi/linux/audit.h for AUDIT_ARCH declarations syscall_get_arch: remove useless function arguments audit: remove stray newline from audit_log_execve_info() audit_panic() call audit: remove stray newlines from audit_log_lost messages audit: include subject in login records audit: remove superfluous new- prefix in AUDIT_LOGIN messages audit: allow user processes to log from another PID namespace audit: anchor all pid references in the initial pid namespace audit: convert PPIDs to the inital PID namespace. pid: get pid_t ppid of task in init_pid_ns audit: rename the misleading audit_get_context() to audit_take_context() audit: Add generic compat syscall support audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL ...
2014-04-04Merge branch 'locks-3.15' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking updates from Jeff Layton: "Highlights: - maintainership change for fs/locks.c. Willy's not interested in maintaining it these days, and is OK with Bruce and I taking it. - fix for open vs setlease race that Al ID'ed - cleanup and consolidation of file locking code - eliminate unneeded BUG() call - merge of file-private lock implementation" * 'locks-3.15' of git://git.samba.org/jlayton/linux: locks: make locks_mandatory_area check for file-private locks locks: fix locks_mandatory_locked to respect file-private locks locks: require that flock->l_pid be set to 0 for file-private locks locks: add new fcntl cmd values for handling file private locks locks: skip deadlock detection on FL_FILE_PVT locks locks: pass the cmd value to fcntl_getlk/getlk64 locks: report l_pid as -1 for FL_FILE_PVT locks locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT" locks: rename locks_remove_flock to locks_remove_file locks: consolidate checks for compatible filp->f_mode values in setlk handlers locks: fix posix lock range overflow handling locks: eliminate BUG() call when there's an unexpected lock on file close locks: add __acquires and __releases annotations to locks_start and locks_stop locks: remove "inline" qualifier from fl_link manipulation functions locks: clean up comment typo locks: close potential race between setlease and open MAINTAINERS: update entry for fs/locks.c
2014-04-04Merge branch 'cross-rename' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs Pull renameat2 system call from Miklos Szeredi: "This adds a new syscall, renameat2(), which is the same as renameat() but with a flags argument. The purpose of extending rename is to add cross-rename, a symmetric variant of rename, which exchanges the two files. This allows interesting things, which were not possible before, for example atomically replacing a directory tree with a symlink, etc... This also allows overlayfs and friends to operate on whiteouts atomically. Andy Lutomirski also suggested a "noreplace" flag, which disables the overwriting behavior of rename. These two flags, RENAME_EXCHANGE and RENAME_NOREPLACE are only implemented for ext4 as an example and for testing" * 'cross-rename' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: ext4: add cross rename support ext4: rename: split out helper functions ext4: rename: move EMLINK check up ext4: rename: create ext4_renament structure for local vars vfs: add cross-rename vfs: lock_two_nondirectories: allow directory args security: add flags to rename hooks vfs: add RENAME_NOREPLACE flag vfs: add renameat2 syscall vfs: rename: use common code for dir and non-dir vfs: rename: move d_move() up vfs: add d_is_dir()
2014-04-03Merge branch 'for-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot updates for cgroup: - The biggest one is cgroup's conversion to kernfs. cgroup took after the long abandoned vfs-entangled sysfs implementation and made it even more convoluted over time. cgroup's internal objects were fused with vfs objects which also brought in vfs locking and object lifetime rules. Naturally, there are places where vfs rules don't fit and nasty hacks, such as credential switching or lock dance interleaving inode mutex and cgroup_mutex with object serial number comparison thrown in to decide whether the operation is actually necessary, needed to be employed. After conversion to kernfs, internal object lifetime and locking rules are mostly isolated from vfs interactions allowing shedding of several nasty hacks and overall simplification. This will also allow implmentation of operations which may affect multiple cgroups which weren't possible before as it would have required nesting i_mutexes. - Various simplifications including dropping of module support, easier cgroup name/path handling, simplified cgroup file type handling and task_cg_lists optimization. - Prepatory changes for the planned unified hierarchy, which is still a patchset away from being actually operational. The dummy hierarchy is updated to serve as the default unified hierarchy. Controllers which aren't claimed by other hierarchies are associated with it, which BTW was what the dummy hierarchy was for anyway. - Various fixes from Li and others. This pull request includes some patches to add missing slab.h to various subsystems. This was triggered xattr.h include removal from cgroup.h. cgroup.h indirectly got included a lot of files which brought in xattr.h which brought in slab.h. There are several merge commits - one to pull in kernfs updates necessary for converting cgroup (already in upstream through driver-core), others for interfering changes in the fixes branch" * 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (74 commits) cgroup: remove useless argument from cgroup_exit() cgroup: fix spurious lockdep warning in cgroup_exit() cgroup: Use RCU_INIT_POINTER(x, NULL) in cgroup.c cgroup: break kernfs active_ref protection in cgroup directory operations cgroup: fix cgroup_taskset walking order cgroup: implement CFTYPE_ONLY_ON_DFL cgroup: make cgrp_dfl_root mountable cgroup: drop const from @buffer of cftype->write_string() cgroup: rename cgroup_dummy_root and related names cgroup: move ->subsys_mask from cgroupfs_root to cgroup cgroup: treat cgroup_dummy_root as an equivalent hierarchy during rebinding cgroup: remove NULL checks from [pr_cont_]cgroup_{name|path}() cgroup: use cgroup_setup_root() to initialize cgroup_dummy_root cgroup: reorganize cgroup bootstrapping cgroup: relocate setting of CGRP_DEAD cpuset: use rcu_read_lock() to protect task_cs() cgroup_freezer: document freezer_fork() subtleties cgroup: update cgroup_transfer_tasks() to either succeed or fail cgroup: drop task_lock() protection around task->cgroups cgroup: update how a newly forked task gets associated with css_set ...
2014-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Apart from reordering the SELinux mmap code to ensure DAC is called before MAC, these are minor maintenance updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits) selinux: correctly label /proc inodes in use before the policy is loaded selinux: put the mmap() DAC controls before the MAC controls selinux: fix the output of ./scripts/get_maintainer.pl for SELinux evm: enable key retention service automatically ima: skip memory allocation for empty files evm: EVM does not use MD5 ima: return d_name.name if d_path fails integrity: fix checkpatch errors ima: fix erroneous removal of security.ima xattr security: integrity: Use a more current logging style MAINTAINERS: email updates and other misc. changes ima: reduce memory usage when a template containing the n field is used ima: restore the original behavior for sending data with ima template Integrity: Pass commname via get_task_comm() fs: move i_readcount ima: use static const char array definitions security: have cap_dentry_init_security return error ima: new helper: file_inode(file) kernel: Mark function as static in kernel/seccomp.c capability: Use current logging styles ...
2014-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Here is my initial pull request for the networking subsystem during this merge window: 1) Support for ESN in AH (RFC 4302) from Fan Du. 2) Add full kernel doc for ethtool command structures, from Ben Hutchings. 3) Add BCM7xxx PHY driver, from Florian Fainelli. 4) Export computed TCP rate information in netlink socket dumps, from Eric Dumazet. 5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas Dichtel. 6) Convert many drivers to pci_enable_msix_range(), from Alexander Gordeev. 7) Record SKB timestamps more efficiently, from Eric Dumazet. 8) Switch to microsecond resolution for TCP round trip times, also from Eric Dumazet. 9) Clean up and fix 6lowpan fragmentation handling by making use of the existing inet_frag api for it's implementation. 10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss. 11) Auto size SKB lengths when composing netlink messages based upon past message sizes used, from Eric Dumazet. 12) qdisc dumps can take a long time, add a cond_resched(), From Eric Dumazet. 13) Sanitize netpoll core and drivers wrt. SKB handling semantics. Get rid of never-used-in-tree netpoll RX handling. From Eric W Biederman. 14) Support inter-address-family and namespace changing in VTI tunnel driver(s). From Steffen Klassert. 15) Add Altera TSE driver, from Vince Bridgers. 16) Optimizing csum_replace2() so that it doesn't adjust the checksum by checksumming the entire header, from Eric Dumazet. 17) Expand BPF internal implementation for faster interpreting, more direct translations into JIT'd code, and much cleaner uses of BPF filtering in non-socket ocntexts. From Daniel Borkmann and Alexei Starovoitov" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits) netpoll: Use skb_irq_freeable to make zap_completion_queue safe. net: Add a test to see if a skb is freeable in irq context qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port' net: ptp: move PTP classifier in its own file net: sxgbe: make "core_ops" static net: sxgbe: fix logical vs bitwise operation net: sxgbe: sxgbe_mdio_register() frees the bus Call efx_set_channels() before efx->type->dimension_resources() xen-netback: disable rogue vif in kthread context net/mlx4: Set proper build dependancy with vxlan be2net: fix build dependency on VxLAN mac802154: make csma/cca parameters per-wpan mac802154: allow only one WPAN to be up at any given time net: filter: minor: fix kdoc in __sk_run_filter netlink: don't compare the nul-termination in nla_strcmp can: c_can: Avoid led toggling for every packet. can: c_can: Simplify TX interrupt cleanup can: c_can: Store dlc private can: c_can: Reduce register access can: c_can: Make the code readable ...
2014-04-01get rid of pointless checks for NULL ->i_opAl Viro
2014-04-01vfs: add cross-renameMiklos Szeredi
If flags contain RENAME_EXCHANGE then exchange source and destination files. There's no restriction on the type of the files; e.g. a directory can be exchanged with a symlink. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reviewed-by: Jan Kara <jack@suse.cz> Reviewed-by: J. Bruce Fields <bfields@redhat.com>
2014-04-01security: add flags to rename hooksMiklos Szeredi
Add flags to security_path_rename() and security_inode_rename() hooks. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reviewed-by: J. Bruce Fields <bfields@redhat.com>
2014-03-31Merge branch 'compat' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 compat wrapper rework from Heiko Carstens: "S390 compat system call wrapper simplification work. The intention of this work is to get rid of all hand written assembly compat system call wrappers on s390, which perform proper sign or zero extension, or pointer conversion of compat system call parameters. Instead all of this should be done with C code eg by using Al's COMPAT_SYSCALL_DEFINEx() macro. Therefore all common code and s390 specific compat system calls have been converted to the COMPAT_SYSCALL_DEFINEx() macro. In order to generate correct code all compat system calls may only have eg compat_ulong_t parameters, but no unsigned long parameters. Those patches which change parameter types from unsigned long to compat_ulong_t parameters are separate in this series, but shouldn't cause any harm. The only compat system calls which intentionally have 64 bit parameters (preadv64 and pwritev64) in support of the x86/32 ABI haven't been changed, but are now only available if an architecture defines __ARCH_WANT_COMPAT_SYS_PREADV64/PWRITEV64. System calls which do not have a compat variant but still need proper zero extension on s390, like eg "long sys_brk(unsigned long brk)" will get a proper wrapper function with the new s390 specific COMPAT_SYSCALL_WRAPx() macro: COMPAT_SYSCALL_WRAP1(brk, unsigned long, brk); which generates the following code (simplified): asmlinkage long sys_brk(unsigned long brk); asmlinkage long compat_sys_brk(long brk) { return sys_brk((u32)brk); } Given that the C file which contains all the COMPAT_SYSCALL_WRAP lines includes both linux/syscall.h and linux/compat.h, it will generate build errors, if the declaration of sys_brk() doesn't match, or if there exists a non-matching compat_sys_brk() declaration. In addition this will intentionally result in a link error if somewhere else a compat_sys_brk() function exists, which probably should have been used instead. Two more BUILD_BUG_ONs make sure the size and type of each compat syscall parameter can be handled correctly with the s390 specific macros. I converted the compat system calls step by step to verify the generated code is correct and matches the previous code. In fact it did not always match, however that was always a bug in the hand written asm code. In result we get less code, less bugs, and much more sanity checking" * 'compat' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (44 commits) s390/compat: add copyright statement compat: include linux/unistd.h within linux/compat.h s390/compat: get rid of compat wrapper assembly code s390/compat: build error for large compat syscall args mm/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types kexec/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types net/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types ipc/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types fs/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types ipc/compat: convert to COMPAT_SYSCALL_DEFINE fs/compat: convert to COMPAT_SYSCALL_DEFINE security/compat: convert to COMPAT_SYSCALL_DEFINE mm/compat: convert to COMPAT_SYSCALL_DEFINE net/compat: convert to COMPAT_SYSCALL_DEFINE kernel/compat: convert to COMPAT_SYSCALL_DEFINE fs/compat: optional preadv64/pwrite64 compat system calls ipc/compat_sys_msgrcv: change msgtyp type from long to compat_long_t s390/compat: partial parameter conversion within syscall wrappers s390/compat: automatic zero, sign and pointer conversion of syscalls s390/compat: add sync_file_range and fallocate compat syscalls ...
2014-03-31locks: add new fcntl cmd values for handling file private locksJeff Layton
Due to some unfortunate history, POSIX locks have very strange and unhelpful semantics. The thing that usually catches people by surprise is that they are dropped whenever the process closes any file descriptor associated with the inode. This is extremely problematic for people developing file servers that need to implement byte-range locks. Developers often need a "lock management" facility to ensure that file descriptors are not closed until all of the locks associated with the inode are finished. Additionally, "classic" POSIX locks are owned by the process. Locks taken between threads within the same process won't conflict with one another, which renders them useless for synchronization between threads. This patchset adds a new type of lock that attempts to address these issues. These locks conflict with classic POSIX read/write locks, but have semantics that are more like BSD locks with respect to inheritance and behavior on close. This is implemented primarily by changing how fl_owner field is set for these locks. Instead of having them owned by the files_struct of the process, they are instead owned by the filp on which they were acquired. Thus, they are inherited across fork() and are only released when the last reference to a filp is put. These new semantics prevent them from being merged with classic POSIX locks, even if they are acquired by the same process. These locks will also conflict with classic POSIX locks even if they are acquired by the same process or on the same file descriptor. The new locks are managed using a new set of cmd values to the fcntl() syscall. The initial implementation of this converts these values to "classic" cmd values at a fairly high level, and the details are not exposed to the underlying filesystem. We may eventually want to push this handing out to the lower filesystem code but for now I don't see any need for it. Also, note that with this implementation the new cmd values are only available via fcntl64() on 32-bit arches. There's little need to add support for legacy apps on a new interface like this. Signed-off-by: Jeff Layton <jlayton@redhat.com>
2014-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: Documentation/devicetree/bindings/net/micrel-ks8851.txt net/core/netpoll.c The net/core/netpoll.c conflict is a bug fix in 'net' happening to code which is completely removed in 'net-next'. In micrel-ks8851.txt we simply have overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20audit: anchor all pid references in the initial pid namespaceRichard Guy Briggs
Store and log all PIDs with reference to the initial PID namespace and use the access functions task_pid_nr() and task_tgid_nr() for task->pid and task->tgid. Cc: "Eric W. Biederman" <ebiederm@xmission.com> (informed by ebiederman's c776b5d2) Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
2014-03-19selinux: correctly label /proc inodes in use before the policy is loadedPaul Moore
This patch is based on an earlier patch by Eric Paris, he describes the problem below: "If an inode is accessed before policy load it will get placed on a list of inodes to be initialized after policy load. After policy load we call inode_doinit() which calls inode_doinit_with_dentry() on all inodes accessed before policy load. In the case of inodes in procfs that means we'll end up at the bottom where it does: /* Default to the fs superblock SID. */ isec->sid = sbsec->sid; if ((sbsec->flags & SE_SBPROC) && !S_ISLNK(inode->i_mode)) { if (opt_dentry) { isec->sclass = inode_mode_to_security_class(...) rc = selinux_proc_get_sid(opt_dentry, isec->sclass, &sid); if (rc) goto out_unlock; isec->sid = sid; } } Since opt_dentry is null, we'll never call selinux_proc_get_sid() and will leave the inode labeled with the label on the superblock. I believe a fix would be to mimic the behavior of xattrs. Look for an alias of the inode. If it can't be found, just leave the inode uninitialized (and pick it up later) if it can be found, we should be able to call selinux_proc_get_sid() ..." On a system exhibiting this problem, you will notice a lot of files in /proc with the generic "proc_t" type (at least the ones that were accessed early in the boot), for example: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:proc_t:s0 /proc/sys/kernel/shmmax However, with this patch in place we see the expected result: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:sysctl_kernel_t:s0 /proc/sys/kernel/shmmax Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Eric Paris <eparis@redhat.com>
2014-03-19selinux: put the mmap() DAC controls before the MAC controlsPaul Moore
It turns out that doing the SELinux MAC checks for mmap() before the DAC checks was causing users and the SELinux policy folks headaches as users were seeing a lot of SELinux AVC denials for the memprotect:mmap_zero permission that would have also been denied by the normal DAC capability checks (CAP_SYS_RAWIO). Example: # cat mmap_test.c #include <stdlib.h> #include <stdio.h> #include <errno.h> #include <sys/mman.h> int main(int argc, char *argv[]) { int rc; void *mem; mem = mmap(0x0, 4096, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0); if (mem == MAP_FAILED) return errno; printf("mem = %p\n", mem); munmap(mem, 4096); return 0; } # gcc -g -O0 -o mmap_test mmap_test.c # ./mmap_test mem = (nil) # ausearch -m AVC | grep mmap_zero type=AVC msg=audit(...): avc: denied { mmap_zero } for pid=1025 comm="mmap_test" scontext=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 tcontext=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 tclass=memprotect This patch corrects things so that when the above example is run by a user without CAP_SYS_RAWIO the SELinux AVC is no longer generated as the DAC capability check fails before the SELinux permission check. Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
2014-03-19cgroup: drop const from @buffer of cftype->write_string()Tejun Heo
cftype->write_string() just passes on the writeable buffer from kernfs and there's no reason to add const restriction on the buffer. The only thing const achieves is unnecessarily complicating parsing of the buffer. Drop const from @buffer. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
2014-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Steffen Klassert says: ==================== 1) Fix a sleep in atomic when pfkey_sadb2xfrm_user_sec_ctx() is called from pfkey_compile_policy(). Fix from Nikolay Aleksandrov. 2) security_xfrm_policy_alloc() can be called in process and atomic context. Add an argument to let the callers choose the appropriate way. Fix from Nikolay Aleksandrov. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c drivers/net/xen-netback/netback.c Both the r8152 and netback conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-12Merge branch 'next-fixes' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into next
2014-03-10selinux: add gfp argument to security_xfrm_policy_alloc and fix callersNikolay Aleksandrov
security_xfrm_policy_alloc can be called in atomic context so the allocation should be done with GFP_ATOMIC. Add an argument to let the callers choose the appropriate way. In order to do so a gfp argument needs to be added to the method xfrm_policy_alloc_security in struct security_operations and to the internal function selinux_xfrm_alloc_user. After that switch to GFP_ATOMIC in the atomic callers and leave GFP_KERNEL as before for the rest. The path that needed the gfp argument addition is: security_xfrm_policy_alloc -> security_ops.xfrm_policy_alloc_security -> all users of xfrm_policy_alloc_security (e.g. selinux_xfrm_policy_alloc) -> selinux_xfrm_alloc_user (here the allocation used to be GFP_KERNEL only) Now adding a gfp argument to selinux_xfrm_alloc_user requires us to also add it to security_context_to_sid which is used inside and prior to this patch did only GFP_KERNEL allocation. So add gfp argument to security_context_to_sid and adjust all of its callers as well. CC: Paul Moore <paul@paul-moore.com> CC: Dave Jones <davej@redhat.com> CC: Steffen Klassert <steffen.klassert@secunet.com> CC: Fan Du <fan.du@windriver.com> CC: David S. Miller <davem@davemloft.net> CC: LSM list <linux-security-module@vger.kernel.org> CC: SELinux list <selinux@tycho.nsa.gov> Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Acked-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2014-03-09KEYS: Make the keyring cycle detector ignore other keyrings of the same nameDavid Howells
This fixes CVE-2014-0102. The following command sequence produces an oops: keyctl new_session i=`keyctl newring _ses @s` keyctl link @s $i The problem is that search_nested_keyrings() sees two keyrings that have matching type and description, so keyring_compare_object() returns true. s_n_k() then passes the key to the iterator function - keyring_detect_cycle_iterator() - which *should* check to see whether this is the keyring of interest, not just one with the same name. Because assoc_array_find() will return one and only one match, I assumed that the iterator function would only see an exact match or never be called - but the iterator isn't only called from assoc_array_find()... The oops looks something like this: kernel BUG at /data/fs/linux-2.6-fscache/security/keys/keyring.c:1003! invalid opcode: 0000 [#1] SMP ... RIP: keyring_detect_cycle_iterator+0xe/0x1f ... Call Trace: search_nested_keyrings+0x76/0x2aa __key_link_check_live_key+0x50/0x5f key_link+0x4e/0x85 keyctl_keyring_link+0x60/0x81 SyS_keyctl+0x65/0xe4 tracesys+0xdd/0xe2 The fix is to make keyring_detect_cycle_iterator() check that the key it has is the key it was actually looking for rather than calling BUG_ON(). A testcase has been included in the keyutils testsuite for this: http://git.kernel.org/cgit/linux/kernel/git/dhowells/keyutils.git/commit/?id=891f3365d07f1996778ade0e3428f01878a1790b Reported-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-07evm: enable key retention service automaticallyDmitry Kasatkin
If keys are not enabled, EVM is not visible in the configuration menu. It may be difficult to figure out what to do unless you really know. Other subsystems as NFS, CIFS select keys automatically. This patch does the same. This patch also removes '(TRUSTED_KEYS=y || TRUSTED_KEYS=n)' dependency, which is unnecessary. EVM does not depend on trusted keys, but on encrypted keys. evm.h provides compile time dependency. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: skip memory allocation for empty filesDmitry Kasatkin
Memory allocation is unnecessary for empty files. This patch calculates the hash without memory allocation. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07evm: EVM does not use MD5Dmitry Kasatkin
EVM does not use MD5 HMAC. Selection of CRYPTO_MD5 can be safely removed. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: return d_name.name if d_path failsDmitry Kasatkin
This is a small refactoring so ima_d_path() returns dentry name if path reconstruction fails. It simplifies callers actions and removes code duplication. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07integrity: fix checkpatch errorsDmitry Kasatkin
Between checkpatch changes (eg. sizeof) and inconsistencies between Lindent and checkpatch, unfixed checkpatch errors make it difficult to see new errors. This patch fixes them. Some lines with over 80 chars remained unchanged to improve code readability. The "extern" keyword is removed from internal evm.h to make it consistent with internal ima.h. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: fix erroneous removal of security.ima xattrDmitry Kasatkin
ima_inode_post_setattr() calls ima_must_appraise() to check if the file needs to be appraised. If it does not then it removes security.ima xattr. With original policy matching code it might happen that even file needs to be appraised with FILE_CHECK hook, it might not be for POST_SETATTR hook. 'security.ima' might be erronously removed. This patch treats POST_SETATTR as special wildcard function and will cause ima_must_appraise() to be true if any of the hooks rules matches. security.ima will not be removed if any of the hooks would require appraisal. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07security: integrity: Use a more current logging styleJoe Perches
Convert printks to pr_<level>. Add pr_fmt. Remove embedded prefixes. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07Merge tag 'v3.13' into for-3.15Eric Paris
Linux 3.13 Conflicts: include/net/xfrm.h Simple merge where v3.13 removed 'extern' from definitions and the audit tree did s/u32/unsigned int/ to the same definitions.
2014-03-07ima: reduce memory usage when a template containing the n field is usedRoberto Sassu
Before this change, to correctly calculate the template digest for the 'ima' template, the event name field (id: 'n') length was set to the fixed size of 256 bytes. This patch reduces the length of the event name field to the string length incremented of one (to make room for the termination character '\0') and handles the specific case of the digest calculation for the 'ima' template directly in ima_calc_field_array_hash_tfm(). Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: restore the original behavior for sending data with ima templateRoberto Sassu
With the new template mechanism introduced in IMA since kernel 3.13, the format of data sent through the binary_runtime_measurements interface is slightly changed. Now, for a generic measurement, the format of template data (after the template name) is: template_len | field1_len | field1 | ... | fieldN_len | fieldN In addition, fields containing a string now include the '\0' termination character. Instead, the format for the 'ima' template should be: SHA1 digest | event name length | event name It must be noted that while in the IMA 3.13 code 'event name length' is 'IMA_EVENT_NAME_LEN_MAX + 1' (256 bytes), so that the template digest is calculated correctly, and 'event name' contains '\0', in the pre 3.13 code 'event name length' is exactly the string length and 'event name' does not contain the termination character. The patch restores the behavior of the IMA code pre 3.13 for the 'ima' template so that legacy userspace tools obtain a consistent behavior when receiving data from the binary_runtime_measurements interface regardless of which kernel version is used. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Cc: <stable@vger.kernel.org> # 3.3.13: 3ce1217 ima: define template fields library Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07Integrity: Pass commname via get_task_comm()Tetsuo Handa
When we pass task->comm to audit_log_untrustedstring(), we need to pass it via get_task_comm() because task->comm can be changed to contain untrusted string by other threads after audit_log_untrustedstring() confirmed that task->comm does not contain untrusted string. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: use static const char array definitionsMimi Zohar
A const char pointer allocates memory for a pointer as well as for a string, This patch replaces a number of the const char pointers throughout IMA, with a static const char array. Suggested-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com>
2014-03-07security: have cap_dentry_init_security return errorJeff Layton
Currently, cap_dentry_init_security returns 0 without actually initializing the security label. This confuses its only caller (nfs4_label_init_security) which expects an error in that situation, and causes it to end up sending out junk onto the wire instead of simply suppressing the label in the attributes sent. When CONFIG_SECURITY is disabled, security_dentry_init_security returns -EOPNOTSUPP. Have cap_dentry_init_security do the same. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-03-06security/compat: convert to COMPAT_SYSCALL_DEFINEHeiko Carstens
Convert all compat system call functions where all parameter types have a size of four or less than four bytes, or are pointer types to COMPAT_SYSCALL_DEFINE. The implicit casts within COMPAT_SYSCALL_DEFINE will perform proper zero and sign extension to 64 bit of all parameters if needed. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2014-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/ath/ath9k/recv.c drivers/net/wireless/mwifiex/pcie.c net/ipv6/sit.c The SIT driver conflict consists of a bug fix being done by hand in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper was created (netdev_alloc_pcpu_stats()) which takes care of this. The two wireless conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-04ima: new helper: file_inode(file)Libo Chen
Replace "file->f_dentry->d_inode" with the new file_inode() helper function. Signed-off-by: Libo Chen <clbchenlibo.chen@huawei.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-02-24Merge branch 'stable-3.14' of git://git.infradead.org/users/pcmoore/selinux ↵James Morris
into for-linus
2014-02-20SELinux: bigendian problems with filename trans rulesEric Paris
When writing policy via /sys/fs/selinux/policy I wrote the type and class of filename trans rules in CPU endian instead of little endian. On x86_64 this works just fine, but it means that on big endian arch's like ppc64 and s390 userspace reads the policy and converts it from le32_to_cpu. So the values are all screwed up. Write the values in le format like it should have been to start. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-02-17security: cleanup Makefiles to use standard syntax for specifying ↵Sam Ravnborg
sub-directories The Makefiles in security/ uses a non-standard way to specify sub-directories for building. Fix it up so the normal (and documented) approach is used. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-02-12flowcache: Make flow cache name space awareFan Du
Inserting a entry into flowcache, or flushing flowcache should be based on per net scope. The reason to do so is flushing operation from fat netns crammed with flow entries will also making the slim netns with only a few flow cache entries go away in original implementation. Since flowcache is tightly coupled with IPsec, so it would be easier to put flow cache global parameters into xfrm namespace part. And one last thing needs to do is bumping flow cache genid, and flush flow cache should also be made in per net style. Signed-off-by: Fan Du <fan.du@windriver.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2014-02-10Merge branch 'stable-3.14' of git://git.infradead.org/users/pcmoore/selinux ↵James Morris
into for-linus
