selinux_ip_postroute()
commit c0828e50485932b7e019df377a6b0a8d1ebd3080 upstream.
Due to difficulty in arriving at the proper security label for
TCP SYN-ACK packets in selinux_ip_postroute(), we need to check packets
while/before they are undergoing XFRM transforms instead of waiting
until afterwards so that we can determine the correct security label.
Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu>
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit 817eff718dca4e54d5721211ddde0914428fbb7c upstream.
Previously selinux_skb_peerlbl_sid() would only check for labeled
IPsec security labels on inbound packets, this patch enables it to
check both inbound and outbound traffic for labeled IPsec security
labels.
commit c0c1439541f5305b57a83d599af32b74182933fe upstream.
selinux_setprocattr() does ptrace_parent(p) under task_lock(p),
but task_struct->alloc_lock doesn't pin ->parent or ->ptrace,
this looks confusing and triggers the "suspicious RCU usage"
warning because ptrace_parent() does rcu_dereference_check().
And in theory this is wrong, spin_lock()->preempt_disable()
doesn't necessarily imply rcu_read_lock() we need to access
the ->parent.
Reported-by: Evan McNabb <emcnabb@redhat.com>
commit 46d01d63221c3508421dd72ff9c879f61053cffc upstream.
Fix a broken networking check. Return an error if peer recv fails. If
secmark is active and the packet recv succeeds the peer recv error is
ignored.
Signed-off-by: Chad Hanson <chanson@trustedcs.com>
commit 446b802437f285de68ffb8d6fac3c44c3cab5b04 upstream.
In selinux_ip_postroute() we perform access checks based on the
packet's security label. For locally generated traffic we get the
packet's security label from the associated socket; this works in all
cases except for TCP SYN-ACK packets. In the case of SYN-ACK packet's
the correct security label is stored in the connection's request_sock,
not the server's socket. Unfortunately, at the point in time when
selinux_ip_postroute() is called we can't query the request_sock
directly, we need to recreate the label using the same logic that
originally labeled the associated request_sock.
See the inline comments for more explanation.
Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu>
commit 47180068276a04ed31d24fe04c673138208b07a9 upstream.
In selinux_ip_output() we always label packets based on the parent
socket. While this approach works in almost all cases, it doesn't
work in the case of TCP SYN-ACK packets when the correct label is not
the label of the parent socket, but rather the label of the larval
socket represented by the request_sock struct.
Unfortunately, since the request_sock isn't queued on the parent
socket until *after* the SYN-ACK packet is sent, we can't lookup the
request_sock to determine the correct label for the packet; at this
point in time the best we can do is simply pass/NF_ACCEPT the packet.
It must be said that simply passing the packet without any explicit
labeling action, while far from ideal, is not terrible as the SYN-ACK
packet will inherit any IP option based labeling from the initial
connection request so the label *should* be correct and all our
access controls remain in place so we shouldn't have to worry about
information leaks.
commit 42d64e1add3a1ce8a787116036163b8724362145 upstream.
The SELinux/NetLabel glue code has a locking bug that affects systems
with NetLabel enabled, see the kernel error message below. This patch
corrects this problem by converting the bottom half socket lock to a
more conventional, and correct for this call-path, lock_sock() call.
[ INFO: suspicious RCU usage. ]
3.11.0-rc3+ #19 Not tainted
net/ipv4/cipso_ipv4.c:1928 suspicious rcu_dereference_protected() usage!
rcu_scheduler_active = 1, debug_locks = 0
2 locks held by ping/731:
#0: (slock-AF_INET/1){+.-...}, at: [...] selinux_netlbl_socket_connect
#1: (rcu_read_lock){.+.+..}, at: [<...>] netlbl_conn_setattr
stack backtrace:
CPU: 1 PID: 731 Comm: ping Not tainted 3.11.0-rc3+ #19
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
0000000000000001 ffff88006f659d28 ffffffff81726b6a ffff88003732c500
ffff88006f659d58 ffffffff810e4457 ffff88006b845a00 0000000000000000
000000000000000c ffff880075aa2f50 ffff88006f659d90 ffffffff8169bec7
Call Trace:
[<ffffffff81726b6a>] dump_stack+0x54/0x74
[<ffffffff810e4457>] lockdep_rcu_suspicious+0xe7/0x120
[<ffffffff8169bec7>] cipso_v4_sock_setattr+0x187/0x1a0
[<ffffffff8170f317>] netlbl_conn_setattr+0x187/0x190
[<ffffffff8170f195>] ? netlbl_conn_setattr+0x5/0x190
[<ffffffff8131ac9e>] selinux_netlbl_socket_connect+0xae/0xc0
[<ffffffff81303025>] selinux_socket_connect+0x135/0x170
[<ffffffff8119d127>] ? might_fault+0x57/0xb0
[<ffffffff812fb146>] security_socket_connect+0x16/0x20
[<ffffffff815d3ad3>] SYSC_connect+0x73/0x130
[<ffffffff81739a85>] ? sysret_check+0x22/0x5d
[<ffffffff810e5e2d>] ? trace_hardirqs_on_caller+0xfd/0x1c0
[<ffffffff81373d4e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff815d52be>] SyS_connect+0xe/0x10
[<ffffffff81739a59>] system_call_fastpath+0x16/0x1b
commit 08de59eb144d7c41351a467442f898d720f0f15f upstream.
This reverts commit 4c2c392763a682354fac65b6a569adec4e4b5387.
Everything in the initramfs should be measured and appraised,
but until the initramfs has extended attribute support, at
least measured.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
commit a84a921978b7d56e0e4b87ffaca6367429b4d8ff upstream.
On an error iov may still have been reallocated and need freeing
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 4502403dcf8f5c76abd4dbab8726c8e4ecb5cd34 upstream.
The call tree here is:
sk_clone_lock() <- takes bh_lock_sock(newsk);
xfrm_sk_clone_policy()
__xfrm_sk_clone_policy()
clone_policy() <- uses GFP_ATOMIC for allocations
security_xfrm_policy_clone()
security_ops->xfrm_policy_clone_security()
selinux_xfrm_policy_clone()
Signed-off-by: James Morris <james.l.morris@oracle.com>
security keys
commit 8aec0f5d4137532de14e6554fd5dd201ff3a3c49 upstream.
Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to
compat_process_vm_rw() shows that the compatibility code requires an
explicit "access_ok()" check before calling
compat_rw_copy_check_uvector(). The same difference seems to appear when
we compare fs/read_write.c:do_readv_writev() to
fs/compat.c:compat_do_readv_writev().
This subtle difference between the compat and non-compat requirements
should probably be debated, as it seems to be error-prone. In fact,
there are two others sites that use this function in the Linux kernel,
and they both seem to get it wrong:
Now shifting our attention to fs/aio.c, we see that aio_setup_iocb()
also ends up calling compat_rw_copy_check_uvector() through
aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to
be missing. Same situation for
security/keys/compat.c:compat_keyctl_instantiate_key_iov().
I propose that we add the access_ok() check directly into
compat_rw_copy_check_uvector(), so callers don't have to worry about it,
and it therefore makes the compat call code similar to its non-compat
counterpart. Place the access_ok() check in the same location where
copy_from_user() can trigger a -EFAULT error in the non-compat code, so
the ABI behaviors are alike on both compat and non-compat.
While we are here, fix compat_do_readv_writev() so it checks for
compat_rw_copy_check_uvector() negative return values.
And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error
handling.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit 0da9dfdd2cd9889201bc6f6f43580c99165cd087 upstream.
This fixes CVE-2013-1792.
There is a race in install_user_keyrings() that can cause a NULL pointer
dereference when called concurrently for the same user if the uid and
uid-session keyrings are not yet created. It might be possible for an
unprivileged user to trigger this by calling keyctl() from userspace in
parallel immediately after logging in.
Assume that we have two threads both executing lookup_user_key(), both
looking for KEY_SPEC_USER_SESSION_KEYRING.
THREAD A THREAD B
==>call install_user_keyrings();
if (!cred->user->session_keyring)
user->uid_keyring = uid_keyring;
if (user->uid_keyring)
return 0;
key = cred->user->session_keyring [== NULL]
user->session_keyring = session_keyring;
atomic_inc(&key->usage); [oops]
At the point thread A dereferences cred->user->session_keyring, thread B
hasn't updated user->session_keyring yet, but thread A assumes it is
populated because install_user_keyrings() returned ok.
The race window is really small but can be exploited if, for example,
thread B is interrupted or preempted after initializing uid_keyring, but
before doing setting session_keyring.
This couldn't be reproduced on a stock kernel. However, after placing
systemtap probe on 'user->session_keyring = session_keyring;' that
introduced some delay, the kernel could be crashed reliably.
Fix this by checking both pointers before deciding whether to return.
Alternatively, the test could be done away with entirely as it is checked
inside the mutex - but since the mutex is global, that may not be the best
way.
Reported-by: Mateusz Guzik <mguzik@redhat.com>
commit a67adb997419fb53540d4a4f79c6471c60bc69b6 upstream.
The following lines of code produce a kernel oops.
fd = socket(PF_FILE, SOCK_STREAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0);
fchmod(fd, 0666);
[ 139.922364] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 139.924982] IP: [< (null)>] (null)
[ 139.924982] *pde = 00000000
[ 139.924982] Oops: 0000 [#5] SMP
[ 139.924982] Modules linked in: fuse dm_crypt dm_mod i2c_piix4 serio_raw evdev binfmt_misc button
[ 139.924982] Pid: 3070, comm: acpid Tainted: G D 3.8.0-rc2-kds+ #465 Bochs Bochs
[ 139.924982] EIP: 0060:[<00000000>] EFLAGS: 00010246 CPU: 0
[ 139.924982] EIP is at 0x0
[ 139.924982] EAX: cf5ef000 EBX: cf5ef000 ECX: c143d600 EDX: c15225f2
[ 139.924982] ESI: cf4d2a1c EDI: cf4d2a1c EBP: cc02df10 ESP: cc02dee4
[ 139.924982] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 139.924982] CR0: 80050033 CR2: 00000000 CR3: 0c059000 CR4: 000006d0
[ 139.924982] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 139.924982] DR6: ffff0ff0 DR7: 00000400
[ 139.924982] Process acpid (pid: 3070, ti=cc02c000 task=d7705340 task.ti=cc02c000)
[ 139.924982] Stack:
[ 139.924982] c1203c88 00000000 cc02def4 cf4d2a1c ae21eefa 471b60d5 1083c1ba c26a5940
[ 139.924982] e891fb5e 00000041 00000004 cc02df1c c1203964 00000000 cc02df4c c10e20c3
[ 139.924982] 00000002 00000000 00000000 22222222 c1ff2222 cf5ef000 00000000 d76efb08
[ 139.924982] Call Trace:
[ 139.924982] [<c1203c88>] ? evm_update_evmxattr+0x5b/0x62
[ 139.924982] [<c1203964>] evm_inode_post_setattr+0x22/0x26
[ 139.924982] [<c10e20c3>] notify_change+0x25f/0x281
[ 139.924982] [<c10cbf56>] chmod_common+0x59/0x76
[ 139.924982] [<c10e27a1>] ? put_unused_fd+0x33/0x33
[ 139.924982] [<c10cca09>] sys_fchmod+0x39/0x5c
[ 139.924982] [<c13f4f30>] syscall_call+0x7/0xb
[ 139.924982] Code: Bad EIP value.
This happens because sockets do not define the removexattr operation.
Before removing the xattr, verify the removexattr function pointer is
not NULL.
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 88a693b5c1287be4da937699cb82068ce9db0135 upstream.
3.5.0-rc1+ #63 Not tainted
security/selinux/netnode.c:178 suspicious rcu_dereference_check() usage!
1 lock held by trinity-child1/8750:
#0: (sel_netnode_lock){+.....}, at: [<ffffffff812d8f8a>] sel_netnode_sid+0x16a/0x3e0
stack backtrace:
Pid: 8750, comm: trinity-child1 Not tainted 3.5.0-rc1+ #63
Call Trace:
[<ffffffff810cec2d>] lockdep_rcu_suspicious+0xfd/0x130
[<ffffffff812d91d1>] sel_netnode_sid+0x3b1/0x3e0
[<ffffffff812d8e20>] ? sel_netnode_find+0x1a0/0x1a0
[<ffffffff812d24a6>] selinux_socket_bind+0xf6/0x2c0
[<ffffffff810cd1dd>] ? trace_hardirqs_off+0xd/0x10
[<ffffffff810cdb55>] ? lock_release_holdtime.part.9+0x15/0x1a0
[<ffffffff81093841>] ? lock_hrtimer_base+0x31/0x60
[<ffffffff812c9536>] security_socket_bind+0x16/0x20
[<ffffffff815550ca>] sys_bind+0x7a/0x100
[<ffffffff816c03d5>] ? sysret_check+0x22/0x5d
[<ffffffff810d392d>] ? trace_hardirqs_on_caller+0x10d/0x1a0
[<ffffffff8133b09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff816c03a9>] system_call_fastpath+0x16/0x1b
This patch below does what Paul McKenney suggested in the previous thread.
Signed-off-by: Dave Jones <davej@redhat.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: Eric Paris <eparis@parisplace.org>
commit 2e4930eb7c8fb20a39dfb5f8a8f80402710dcea8 upstream.
When running a 64-bit kernel and receiving prctls from a 32-bit
userspace, the "-1" used as an unsigned long will end up being
misdetected. The kernel is looking for 0xffffffffffffffff instead of
0xffffffff. Since prctl lacks a distinct compat interface, Yama needs
to handle this translation itself. As such, support either value as
meaning PR_SET_PTRACER_ANY, to avoid breaking the ABI for 64-bit.
Acked-by: John Johansen <john.johansen@canonical.com>
commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream.
Recently, glibc made a change to suppress sign-conversion warnings in
FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the
kernel's definition of __NFDBITS if applications #include
<linux/types.h> after including <sys/select.h>. A build failure would
be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2
flags to gcc.
It was suggested that the kernel should either match the glibc
definition of __NFDBITS or remove that entirely. The current in-kernel
uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no
uses of the related __FDELT and __FDMASK defines. Given that, we'll
continue the cleanup that was started with commit 8b3d1cda4f5f
("posix_types: Remove fd_set macros") and drop the remaining unused
macros.
Additionally, linux/time.h has similar macros defined that expand to
nothing so we'll remove those at the same time.
Reported-by: Jeff Law <law@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
[ .. and fix up whitespace as per akpm ]
commit 154c50ca4eb9ae472f50b6a481213e21ead4457d upstream.
We reset the bool names and values array to NULL, but do not reset the
number of entries in these arrays to 0. If we error out and then get back
into this function we will walk these NULL pointers based on the belief
that they are non-zero length.
Signed-off-by: Eric Paris <eparis@redhat.com>
Add missing "personality.h"
security/commoncap.c: In function 'cap_bprm_set_creds':
security/commoncap.c:510: error: 'PER_CLEAR_ON_SETID' undeclared (first use in this function)
security/commoncap.c:510: error: (Each undeclared identifier is reported only once
security/commoncap.c:510: error: for each function it appears in.)
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
If a process increases permissions using fcaps all of the dangerous
personality flags which are cleared for suid apps should also be cleared.
Thus programs given priviledge with fcaps will continue to have address space
randomization enabled even if the parent tried to disable it to make it
easier to attack.
Reviewed-by: Serge Hallyn <serge.hallyn@canonical.com>
A kernel with Smack enabled will fail if tmpfs has xattr support.
Move the initialization of predefined Smack label
list entries to the LSM initialization from the
smackfs setup. This became an issue when tmpfs
acquired xattr support, but was never correct.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
This fixes builds where CONFIG_AUDIT is not defined and
CONFIG_SECURITY_SMACK=y.
This got introduced by the stack-usage reducation commit 48c62af68a40
("LSM: shrink the common_audit_data data union").
Acked-by: Eric Paris <eparis@redhat.com>
common_audit_data'
It just bloats the audit data structure for no good reason, since the
only time those fields are filled are just before calling the
common_lsm_audit() function, which is also the only user of those
fields.
So just make them be the arguments to common_lsm_audit(), rather than
bloating that structure that is passed around everywhere, and is
initialized in hot paths.
Instead of declaring the entire selinux_audit_data on the stack when we
start an operation on declare it on the stack if we are going to use it.
We know it's usefulness at the end of the security decision and can declare
it there.
We don't use the argument, so remove it.
We do not use it. Remove it.
After shrinking the common_audit_data stack usage for private LSM data I'm
not going to shrink the data union. To do this I'm going to move anything
larger than 2 void * ptrs to it's own structure and require it to be declared
separately on the calling stack. Thus hot paths which don't need more than
a couple pointer don't have to declare space to hold large unneeded
structures. I could get this down to one void * by dealing with the key
struct and the struct path. We'll see if that is helpful after taking care of
networking.
Linus found that the gigantic size of the common audit data caused a big
perf hit on something as simple as running stat() in a loop. This patch
requires LSMs to declare the LSM specific portion separately rather than
doing it in a union. Thus each LSM can be responsible for shrinking their
portion and don't have to pay a penalty just because other LSMs have a
bigger space requirement.
Pull second try at vfs part d#2 from Al Viro:
"Miklos' first series (with do_lookup() rewrite split into edible
chunks) + assorted bits and pieces.
The 'untangling of do_lookup()' series is is a splitup of what used to
be a monolithic patch from Miklos, so this series is basically "how do
I convince myself that his patch is correct (or find a hole in it)".
No holes found and I like the resulting cleanup, so in it went..."
Changes from try 1: Fix a boot problem with selinux, and commit messages
prettied up a bit.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (24 commits)
vfs: fix out-of-date dentry_unhash() comment
vfs: split __lookup_hash
untangling do_lookup() - take __lookup_hash()-calling case out of line.
untangling do_lookup() - switch to calling __lookup_hash()
untangling do_lookup() - merge d_alloc_and_lookup() callers
untangling do_lookup() - merge failure exits in !dentry case
untangling do_lookup() - massage !dentry case towards __lookup_hash()
untangling do_lookup() - get rid of need_reval in !dentry case
untangling do_lookup() - eliminate a loop.
untangling do_lookup() - expand the area under ->i_mutex
untangling do_lookup() - isolate !dentry stuff from the rest of it.
vfs: move MAY_EXEC check from __lookup_hash()
vfs: don't revalidate just looked up dentry
vfs: fix d_need_lookup/d_revalidate order in do_lookup
ext3: move headers to fs/ext3/
migrate ext2_fs.h guts to fs/ext2/ext2.h
new helper: ext2_image_size()
get rid of pointless includes of ext2_fs.h
ext2: No longer export ext2_fs.h to user space
mtdchar: kill persistently held vfsmount
Now that all the slow-path code is gone from these functions, we can
inline them into the main caller - avc_has_perm_flags().
Now the compiler can see that 'avc' is allocated on the stack for this
case, which helps register pressure a bit. It also actually shrinks the
total stack frame, because the stack frame that avc_has_perm_flags()
always needed (for that 'avc' allocation) is now sufficient for the
inlined functions too.
Inlining isn't bad - but mindless inlining of cold code (see the
previous commit) is.
The selinux AVC paths remain some of the hottest (and deepest) codepaths
at filename lookup time, and we make it worse by having the slow path
cases take up I$ and stack space even when they don't trigger. Gcc
tends to always want to inline functions that are just called once -
never mind that this might make for slower and worse code in the caller.
So this tries to improve on it a bit by making the slow-path cases
explicitly separate functions that are marked noinline, causing gcc to
at least no longer allocate stack space for them unless they are
actually called. It also seems to help register allocation a tiny bit,
since gcc now doesn't take the slow case code into account.
Uninlining the slow path may also allow us to inline the remaining hot
path into the one caller that actually matters: avc_has_perm_flags().
I'll have to look at that separately, but both avc_audit() and
avc_has_perm_noaudit() are now small and lean enough that inlining them
may make sense.
Pull x32 support for x86-64 from Ingo Molnar:
"This tree introduces the X32 binary format and execution mode for x86:
32-bit data space binaries using 64-bit instructions and 64-bit kernel
syscalls.
This allows applications whose working set fits into a 32 bits address
space to make use of 64-bit instructions while using a 32-bit address
space with shorter pointers, more compressed data structures, etc."
Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c}
* 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
x32: Fix alignment fail in struct compat_siginfo
x32: Fix stupid ia32/x32 inversion in the siginfo format
x32: Add ptrace for x32
x32: Switch to a 64-bit clock_t
x32: Provide separate is_ia32_task() and is_x32_task() predicates
x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls
x86/x32: Fix the binutils auto-detect
x32: Warn and disable rather than error if binutils too old
x32: Only clear TIF_X32 flag once
x32: Make sure TS_COMPAT is cleared for x32 tasks
fs: Remove missed ->fds_bits from cessation use of fd_set structs internally
fs: Fix close_on_exec pointer in alloc_fdtable
x32: Drop non-__vdso weak symbols from the x32 VDSO
x32: Fix coding style violations in the x32 VDSO code
x32: Add x32 VDSO support
x32: Allow x32 to be configured
x32: If configured, add x32 system calls to system call tables
x32: Handle process creation
x32: Signal-related system calls
x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Fix failure in aa_change_onexec api when the request is made from a confined
task. This failure was caused by two problems
The AA_MAY_ONEXEC perm was not being mapped correctly for this case.
The executable name was being checked as second time instead of using the
requested onexec profile name, which may not be the same as the exec
profile name. This mistake can not be exploited to grant extra permission
because of the above flaw where the ONEXEC permission was not being mapped
so it will not be granted.
BugLink: http://bugs.launchpad.net/bugs/963756
Signed-off-by: John Johansen <john.johansen@canonical.com>
selinux/xfrm.h needs to #include net/flow.h or else suffer:
In file included from security/selinux/ss/services.c:69:0:
security/selinux/include/xfrm.h: In function 'selinux_xfrm_notify_policyload':
security/selinux/include/xfrm.h:53:14: error: 'flow_cache_genid' undeclared (first use in this function)
security/selinux/include/xfrm.h:53:14: note: each undeclared identifier is reported only once for each function it appears in
No functional changes. It is not sane to use UMH_KILLABLE with enum
umh_wait, but obviously we do not want another argument in
call_usermodehelper_* helpers. Kill this enum, use the plain int.
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Tejun Heo <tj@kernel.org>
A few call_usermodehelper() callers use the hardcoded constant instead of
the proper UMH_WAIT_PROC, fix them.
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: Lars Ellenberg <drbd-dev@lists.linbit.com>
Cc: Michal Januszewski <spock@gentoo.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Pull NFS client updates for Linux 3.4 from Trond Myklebust:
"New features include:
- Add NFS client support for containers.
This should enable most of the necessary functionality, including
lockd support, and support for rpc.statd, NFSv4 idmapper and
RPCSEC_GSS upcalls into the correct network namespace from which
the mount system call was issued.
- NFSv4 idmapper scalability improvements
Base the idmapper cache on the keyring interface to allow
concurrent access to idmapper entries. Start the process of
migrating users from the single-threaded daemon-based approach to
the multi-threaded request-key based approach.
- NFSv4.1 implementation id.
Allows the NFSv4.1 client and server to mutually identify each
other for logging and debugging purposes.
- Support the 'vers=4.1' mount option for mounting NFSv4.1 instead of
having to use the more counterintuitive 'vers=4,minorversion=1'.
- SUNRPC tracepoints.
Start the process of adding tracepoints in order to improve
debugging of the RPC layer.
- pNFS object layout support for autologin.
Important bugfixes include:
- Fix a bug in rpc_wake_up/rpc_wake_up_status that caused them to
fail to wake up all tasks when applied to priority waitqueues.
- Ensure that we handle read delegations correctly, when we try to
truncate a file.
- A number of fixes for NFSv4 state manager loops (mostly to do with
delegation recovery)."
* tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (224 commits)
NFS: fix sb->s_id in nfs debug prints
xprtrdma: Remove assumption that each segment is <= PAGE_SIZE
xprtrdma: The transport should not bug-check when a dup reply is received
pnfs-obj: autologin: Add support for protocol autologin
NFS: Remove nfs4_setup_sequence from generic rename code
NFS: Remove nfs4_setup_sequence from generic unlink code
NFS: Remove nfs4_setup_sequence from generic read code
NFS: Remove nfs4_setup_sequence from generic write code
NFS: Fix more NFS debug related build warnings
SUNRPC/LOCKD: Fix build warnings when CONFIG_SUNRPC_DEBUG is undefined
nfs: non void functions must return a value
SUNRPC: Kill compiler warning when RPC_DEBUG is unset
SUNRPC/NFS: Add Kbuild dependencies for NFS_DEBUG/RPC_DEBUG
NFS: Use cond_resched_lock() to reduce latencies in the commit scans
NFSv4: It is not safe to dereference lsp->ls_state in release_lockowner
NFS: ncommit count is being double decremented
SUNRPC: We must not use list_for_each_entry_safe() in rpc_wake_up()
Try using machine credentials for RENEW calls
NFSv4.1: Fix a few issues in filelayout_commit_pagelist
NFSv4.1: Clean ups and bugfixes for the pNFS read/writeback/commit code
avc_audit() did a lot of jumping around and had a big stack frame, all
for the uncommon case.
Split up the uncommon case (which we really can't make go fast anyway)
into its own slow function, and mark the conditional branches
appropriately for the common likely case.
This causes avc_audit() to no longer show up as one of the hottest
functions on the branch profiles (the new "perf -b" thing), and makes
the cycle profiles look really nice and dense too.
The whole audit path is still annoyingly very much one of the biggest
costs of name lookup, so these things are worth optimizing for. I wish
we could just tell people to turn it off, but realistically we do need
it: we just need to make sure that the overhead of the necessary evil is
as low as possible.
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates for 3.4 from James Morris:
"The main addition here is the new Yama security module from Kees Cook,
which was discussed at the Linux Security Summit last year. Its
purpose is to collect miscellaneous DAC security enhancements in one
place. This also marks a departure in policy for LSM modules, which
were previously limited to being standalone access control systems.
Chromium OS is using Yama, and I believe there are plans for Ubuntu,
at least.
This patchset also includes maintenance updates for AppArmor, TOMOYO
and others."
Fix trivial conflict in <net/sock.h> due to the jumo_label->static_key
rename.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits)
AppArmor: Fix location of const qualifier on generated string tables
TOMOYO: Return error if fails to delete a domain
AppArmor: add const qualifiers to string arrays
AppArmor: Add ability to load extended policy
TOMOYO: Return appropriate value to poll().
AppArmor: Move path failure information into aa_get_name and rename
AppArmor: Update dfa matching routines.
AppArmor: Minor cleanup of d_namespace_path to consolidate error handling
AppArmor: Retrieve the dentry_path for error reporting when path lookup fails
AppArmor: Add const qualifiers to generated string tables
AppArmor: Fix oops in policy unpack auditing
AppArmor: Fix error returned when a path lookup is disconnected
KEYS: testing wrong bit for KEY_FLAG_REVOKED
TOMOYO: Fix mount flags checking order.
security: fix ima kconfig warning
AppArmor: Fix the error case for chroot relative path name lookup
AppArmor: fix mapping of META_READ to audit and quiet flags
AppArmor: Fix underflow in xindex calculation
AppArmor: Fix dropping of allowed operations that are force audited
AppArmor: Add mising end of structure test to caps unpacking
Pull kmap_atomic cleanup from Cong Wang.
It's been in -next for a long time, and it gets rid of the (no longer
used) second argument to k[un]map_atomic().
Fix up a few trivial conflicts in various drivers, and do an "evil
merge" to catch some new uses that have come in since Cong's tree.
* 'kmap_atomic' of git://github.com/congwang/linux: (59 commits)
feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal
highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename]
drbd: remove the second argument of k[un]map_atomic()
zcache: remove the second argument of k[un]map_atomic()
gma500: remove the second argument of k[un]map_atomic()
dm: remove the second argument of k[un]map_atomic()
tomoyo: remove the second argument of k[un]map_atomic()
sunrpc: remove the second argument of k[un]map_atomic()
rds: remove the second argument of k[un]map_atomic()
net: remove the second argument of k[un]map_atomic()
mm: remove the second argument of k[un]map_atomic()
lib: remove the second argument of k[un]map_atomic()
power: remove the second argument of k[un]map_atomic()
kdb: remove the second argument of k[un]map_atomic()
udf: remove the second argument of k[un]map_atomic()
ubifs: remove the second argument of k[un]map_atomic()
squashfs: remove the second argument of k[un]map_atomic()
reiserfs: remove the second argument of k[un]map_atomic()
ocfs2: remove the second argument of k[un]map_atomic()
ntfs: remove the second argument of k[un]map_atomic()
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup changes from Tejun Heo:
"Out of the 8 commits, one fixes a long-standing locking issue around
tasklist walking and others are cleanups."
* 'for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: Walk task list under tasklist_lock in cgroup_enable_task_cg_list
cgroup: Remove wrong comment on cgroup_enable_task_cg_list()
cgroup: remove cgroup_subsys argument from callbacks
cgroup: remove extra calls to find_existing_css_set
cgroup: replace tasklist_lock with rcu_read_lock
cgroup: simplify double-check locking in cgroup_attach_proc
cgroup: move struct cgroup_pidlist out from the header file
cgroup: remove cgroup_attach_task_current_cg()
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: Cong Wang <amwang@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jj/linux-apparmor into next
Signed-off-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Call sequence:
tomoyo_write_domain() --> tomoyo_delete_domain()
In 'tomoyo_delete_domain', return -EINTR if locking attempt is
interrupted by signal.
At present it returns success to its caller 'tomoyo_write_domain()'
even though domain is not deleted. 'tomoyo_write_domain()' assumes
domain is deleted and returns success to its caller. This is wrong behaviour.
'tomoyo_write_domain' should return error from tomoyo_delete_domain() to its
caller.
Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com>
