path: root/security
2014-10-14security, crypto: LLVMLinux: Remove VLAIS from ima_crypto.cBehan Webster
Replaced the use of a Variable Length Array In Struct (VLAIS) with a C99 compliant equivalent. This patch allocates the appropriate amount of memory using a char array using the SHASH_DESC_ON_STACK macro. The new code can be compiled with both gcc and clang. Signed-off-by: Behan Webster <behanw@converseincode.com> Reviewed-by: Mark Charlebois <charlebm@gmail.com> Reviewed-by: Jan-Simon Möller <dl9pf@gmx.de> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Cc: tglx@linutronix.de
2014-10-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris. Mostly ima, selinux, smack and key handling updates. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits) integrity: do zero padding of the key id KEYS: output last portion of fingerprint in /proc/keys KEYS: strip 'id:' from ca_keyid KEYS: use swapped SKID for performing partial matching KEYS: Restore partial ID matching functionality for asymmetric keys X.509: If available, use the raw subjKeyId to form the key description KEYS: handle error code encoded in pointer selinux: normalize audit log formatting selinux: cleanup error reporting in selinux_nlmsg_perm() KEYS: Check hex2bin()'s return when generating an asymmetric key ID ima: detect violations for mmaped files ima: fix race condition on ima_rdwr_violation_check and process_measurement ima: added ima_policy_flag variable ima: return an error code from ima_add_boot_aggregate() ima: provide 'ima_appraise=log' kernel option ima: move keyring initialization to ima_init() PKCS#7: Handle PKCS#7 messages that contain no X.509 certs PKCS#7: Better handling of unsupported crypto KEYS: Overhaul key identification when searching for asymmetric keys KEYS: Implement binary asymmetric key ID handling ...
2014-10-11Merge tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking related changes from Jeff Layton: "This release is a little more busy for file locking changes than the last: - a set of patches from Kinglong Mee to fix the lockowner handling in knfsd - a pile of cleanups to the internal file lease API. This should get us a bit closer to allowing for setlease methods that can block. There are some dependencies between mine and Bruce's trees this cycle, and I based my tree on top of the requisite patches in Bruce's tree" * tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linux: (26 commits) locks: fix fcntl_setlease/getlease return when !CONFIG_FILE_LOCKING locks: flock_make_lock should return a struct file_lock (or PTR_ERR) locks: set fl_owner for leases to filp instead of current->files locks: give lm_break a return value locks: __break_lease cleanup in preparation of allowing direct removal of leases locks: remove i_have_this_lease check from __break_lease locks: move freeing of leases outside of i_lock locks: move i_lock acquisition into generic_*_lease handlers locks: define a lm_setup handler for leases locks: plumb a "priv" pointer into the setlease routines nfsd: don't keep a pointer to the lease in nfs4_file locks: clean up vfs_setlease kerneldoc comments locks: generic_delete_lease doesn't need a file_lock at all nfsd: fix potential lease memory leak in nfs4_setlease locks: close potential race in lease_get_mtime security: make security_file_set_fowner, f_setown and __f_setown void return locks: consolidate "nolease" routines locks: remove lock_may_read and lock_may_write lockd: rip out deferred lock handling from testlock codepath NFSD: Get reference of lockowner when coping file_lock ...
2014-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull "trivial tree" updates from Jiri Kosina: "Usual pile from trivial tree everyone is so eagerly waiting for" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Remove MN10300_PROC_MN2WS0038 mei: fix comments treewide: Fix typos in Kconfig kprobes: update jprobe_example.c for do_fork() change Documentation: change "&" to "and" in Documentation/applying-patches.txt Documentation: remove obsolete pcmcia-cs from Changes Documentation: update links in Changes Documentation: Docbook: Fix generated DocBook/kernel-api.xml score: Remove GENERIC_HAS_IOMAP gpio: fix 'CONFIG_GPIO_IRQCHIP' comments tty: doc: Fix grammar in serial/tty dma-debug: modify check_for_stack output treewide: fix errors in printk genirq: fix reference in devm_request_threaded_irq comment treewide: fix synchronize_rcu() in comments checkstack.pl: port to AArch64 doc: queue-sysfs: minor fixes init/do_mounts: better syntax description MIPS: fix comment spelling powerpc/simpleboot: fix comment ...
2014-10-07Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing major: support for compressing modules, and auto-tainting params. PS. My virtio-next tree is empty: DaveM took the patches I had. There might be a virtio-rng starvation fix, but so far it's a bit voodoo so I will get to that in the next two days or it will wait" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: moduleparam: Resolve missing-field-initializer warning kbuild: handle module compression while running 'make modules_install'. modinst: wrap long lines in order to enhance cmd_modules_install modsign: lookup lines ending in .ko in .mod files modpost: simplify file name generation of *.mod.c files modpost: reduce visibility of symbols and constify r/o arrays param: check for tainting before calling set op. drm/i915: taint the kernel if unsafe module parameters are set module: add module_param_unsafe and module_param_named_unsafe module: make it possible to have unsafe, tainting module params module: rename KERNEL_PARAM_FL_NOARG to avoid confusion
2014-10-06integrity: do zero padding of the key idDmitry Kasatkin
Latest KEYS code return error if hexadecimal string length id odd. Fix it. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: David Howells <dhowells@redhat.com>
2014-10-02Merge branch 'next' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into next
2014-10-01Merge branch 'next' of git://git.infradead.org/users/pcmoore/selinux into nextJames Morris
2014-09-22selinux: normalize audit log formattingRichard Guy Briggs
Restructure to keyword=value pairs without spaces. Drop superfluous words in text. Make invalid_context a keyword. Change result= keyword to seresult=. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [Minor rewrite to the patch subject line] Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-09-22selinux: cleanup error reporting in selinux_nlmsg_perm()Richard Guy Briggs
Convert audit_log() call to WARN_ONCE(). Rename "type=" to nlmsg_type=" to avoid confusion with the audit record type. Added "protocol=" to help track down which protocol (NETLINK_AUDIT?) was used within the netlink protocol family. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [Rewrote the patch subject line] Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-09-22Merge tag 'keys-next-20140922' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into next
2014-09-18ima: detect violations for mmaped filesRoberto Sassu
This patch fixes the detection of the 'open_writers' violation for mmaped files. before) an 'open_writers' violation is detected if the policy contains a rule with the criteria: func=FILE_CHECK mask=MAY_READ after) an 'open_writers' violation is detected if the current event matches one of the policy rules. With the old behaviour, the 'open_writers' violation is not detected in the following case: policy: measure func=FILE_MMAP mask=MAY_EXEC steps: 1) open a shared library for writing 2) execute a binary that links that shared library 3) during the binary execution, modify the shared library and save the change result: the 'open_writers' violation measurement is not present in the IMA list. Only binaries executed are protected from writes. For libraries mapped in memory there is the flag MAP_DENYWRITE for this purpose, but according to the output of 'man mmap', the mmap flag is ignored. Since ima_rdwr_violation_check() is now called by process_measurement() the information about if the inode must be measured is already provided by ima_get_action(). Thus the unnecessary function ima_must_measure() has been removed. Changes in v3 (Dmitry Kasatkin): - Violation for MMAP_CHECK function are verified since this patch - Changed patch description a bit Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-18ima: fix race condition on ima_rdwr_violation_check and process_measurementRoberto Sassu
This patch fixes a race condition between two functions that try to access the same inode. Since the i_mutex lock is held and released separately in the two functions, there may be the possibility that a violation is not correctly detected. Suppose there are two processes, A (reader) and B (writer), if the following sequence happens: A: ima_rdwr_violation_check() B: ima_rdwr_violation_check() B: process_measurement() B: starts writing the inode A: process_measurement() the ToMToU violation (a reader may be accessing a content different from that measured, due to a concurrent modification by a writer) will not be detected. To avoid this issue, the violation check and the measurement must be done atomically. This patch fixes the problem by moving the violation check inside process_measurement() when the i_mutex lock is held. Differently from the old code, the violation check is executed also for the MMAP_CHECK hook (other than for FILE_CHECK). This allows to detect ToMToU violations that are possible because shared libraries can be opened for writing while they are in use (according to the output of 'man mmap', the mmap() flag MAP_DENYWRITE is ignored). Changes in v5 (Roberto Sassu): * get iint if action is not zero * exit process_measurement() after the violation check if action is zero * reverse order process_measurement() exit cleanup (Mimi) Changes in v4 (Dmitry Kasatkin): * iint allocation is done before calling ima_rdrw_violation_check() (Suggested-by Mimi) * do not check for violations if the policy does not contain 'measure' rules (done by Roberto Sassu) Changes in v3 (Dmitry Kasatkin): * no violation checking for MMAP_CHECK function in this patch * remove use of filename from violation * removes checking if ima is enabled from ima_rdrw_violation_check * slight style change Suggested-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-18Merge branch 'smack-for-3.18' of git://git.gitorious.org/smack-next/kernel ↵James Morris
into next
2014-09-17ima: added ima_policy_flag variableRoberto Sassu
This patch introduces the new variable 'ima_policy_flag', whose bits are set depending on the action of the current policy rules. Only the flags IMA_MEASURE, IMA_APPRAISE and IMA_AUDIT are set. The new variable will be used to improve performance by skipping the unnecessary execution of IMA code if the policy does not contain rules with the above actions. Changes in v6 (Roberto Sassu) * do not check 'ima_initialized' before calling ima_update_policy_flag() in ima_update_policy() (suggested by Dmitry) * calling ima_update_policy_flag() moved to init_ima to co-locate with ima_initialized (Dmitry) * add/revise comments (Mimi) Changes in v5 (Roberto Sassu) * reset IMA_APPRAISE flag in 'ima_policy_flag' if 'ima_appraise' is set to zero (reported by Dmitry) * update 'ima_policy_flag' only if IMA initialization is successful (suggested by Mimi and Dmitry) * check 'ima_policy_flag' instead of 'ima_initialized' (suggested by Mimi and Dmitry) Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-17ima: return an error code from ima_add_boot_aggregate()Roberto Sassu
This patch modifies ima_add_boot_aggregate() to return an error code. This way we can determine if all the initialization procedures have been executed successfully. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-17ima: provide 'ima_appraise=log' kernel optionDmitry Kasatkin
The kernel boot parameter "ima_appraise" currently defines 'off', 'enforce' and 'fix' modes. When designing a policy and labeling the system, access to files are either blocked in the default 'enforce' mode or automatically fixed in the 'fix' mode. It is beneficial to be able to run the system in a logging only mode, without fixing it, in order to properly analyze the system. This patch adds a 'log' mode to run the system in a permissive mode and log the appraisal results. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-17ima: move keyring initialization to ima_init()Dmitry Kasatkin
ima_init() is used as a single place for all initializations. Experimental keyring patches used the 'late_initcall' which was co-located with the late_initcall(init_ima). When the late_initcall for the keyring initialization was abandoned, initialization moved to init_ima, though it would be more logical to move it to ima_init, where the rest of the initialization is done. This patch moves the keyring initialization to ima_init() as a preparatory step for loading the keys which will be added to ima_init() in following patches. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-16KEYS: Make the key matching functions return boolDavid Howells
Make the key matching functions pointed to by key_match_data::cmp return bool rather than int. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-09-16KEYS: Remove key_type::match in favour of overriding default by match_preparseDavid Howells
A previous patch added a ->match_preparse() method to the key type. This is allowed to override the function called by the iteration algorithm. Therefore, we can just set a default that simply checks for an exact match of the key description with the original criterion data and allow match_preparse to override it as needed. The key_type::match op is then redundant and can be removed, as can the user_match() function. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-09-16KEYS: Remove key_type::def_lookup_typeDavid Howells
Remove key_type::def_lookup_type as it's no longer used. The information now defaults to KEYRING_SEARCH_LOOKUP_DIRECT but may be overridden by type->match_preparse(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-09-16KEYS: Preparse match dataDavid Howells
Preparse the match data. This provides several advantages: (1) The preparser can reject invalid criteria up front. (2) The preparser can convert the criteria to binary data if necessary (the asymmetric key type really wants to do binary comparison of the key IDs). (3) The preparser can set the type of search to be performed. This means that it's not then a one-off setting in the key type. (4) The preparser can set an appropriate comparator function. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-09-16Merge tag 'keys-next-fixes-20140916' into keys-nextDavid Howells
Merge in keyrings fixes for next: (1) Insert some missing 'static' annotations. Signed-off-by: David Howells <dhowells@redhat.com>
2014-09-16Merge tag 'keys-fixes-20140916' into keys-nextDavid Howells
Merge in keyrings fixes, at least some of which later patches depend on: (1) Reinstate the production of EPERM for key types beginning with '.' in requests from userspace. (2) Tidy up the cleanup of PKCS#7 message signed information blocks and fix a bug this made more obvious. Signed-off-by: David Howells <dhowells@redhat.coM>
2014-09-16KEYS: Reinstate EPERM for a key type name beginning with a '.'David Howells
Reinstate the generation of EPERM for a key type name beginning with a '.' in a userspace call. Types whose name begins with a '.' are internal only. The test was removed by: commit a4e3b8d79a5c6d40f4a9703abf7fe3abcc6c3b8d Author: Mimi Zohar <zohar@linux.vnet.ibm.com> Date: Thu May 22 14:02:23 2014 -0400 Subject: KEYS: special dot prefixed keyring name bug fix I think we want to keep the restriction on type name so that userspace can't add keys of a special internal type. Note that removal of the test causes several of the tests in the keyutils testsuite to fail. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-16KEYS: Fix missing staticsDavid Howells
Fix missing statics (found by checker). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-09-10selinux: make the netif cache namespace awarePaul Moore
While SELinux largely ignores namespaces, for good reason, there are some places where it needs to at least be aware of namespaces in order to function correctly. Network namespaces are one example. Basic awareness of network namespaces are necessary in order to match a network interface's index number to an actual network device. This patch corrects a problem with network interfaces added to a non-init namespace, and can be reproduced with the following commands: [NOTE: the NetLabel configuration is here only to active the dynamic networking controls ] # netlabelctl unlbl add default address:0.0.0.0/0 \ label:system_u:object_r:unlabeled_t:s0 # netlabelctl unlbl add default address:::/0 \ label:system_u:object_r:unlabeled_t:s0 # netlabelctl cipsov4 add pass doi:100 tags:1 # netlabelctl map add domain:lspp_test_netlabel_t \ protocol:cipsov4,100 # ip link add type veth # ip netns add myns # ip link set veth1 netns myns # ip a add dev veth0 10.250.13.100/24 # ip netns exec myns ip a add dev veth1 10.250.13.101/24 # ip l set veth0 up # ip netns exec myns ip l set veth1 up # ping -c 1 10.250.13.101 # ip netns exec myns ping -c 1 10.250.13.100 Reported-by: Jiri Jaburek <jjaburek@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-09-09security: make security_file_set_fowner, f_setown and __f_setown void returnJeff Layton
security_file_set_fowner always returns 0, so make it f_setown and __f_setown void return functions and fix up the error handling in the callers. Cc: linux-security-module@vger.kernel.org Signed-off-by: Jeff Layton <jlayton@primarydata.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2014-09-09integrity: make integrity files as 'integrity' moduleDmitry Kasatkin
The kernel print macros use the KBUILD_MODNAME, which is initialized to the module name. The current integrity/Makefile makes every file as its own module, so pr_xxx messages are prefixed with the file name instead of the module. Similar to the evm/Makefile and ima/Makefile, this patch fixes the integrity/Makefile to use the single name 'integrity'. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09integrity: base integrity subsystem kconfig options on integrityDmitry Kasatkin
The integrity subsystem has lots of options and takes more than half of the security menu. This patch consolidates the options under "integrity", which are hidden if not enabled. This change does not affect existing configurations. Re-configuration is not needed. Changes v4: - no need to change "integrity subsystem" to menuconfig as options are hidden, when not enabled. (Mimi) - add INTEGRITY Kconfig help description Changes v3: - dependency to INTEGRITY removed when behind 'if INTEGRITY' Changes v2: - previous patch moved integrity out of the 'security' menu. This version keeps integrity as a security option (Mimi). Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09integrity: move asymmetric keys config optionDmitry Kasatkin
For better visual appearance it is better to co-locate asymmetric key options together with signature support. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09ima: initialize only required templateDmitry Kasatkin
IMA uses only one template. This patch initializes only required template to avoid unnecessary memory allocations. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Reviewed-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09ima: remove usage of filename parameterDmitry Kasatkin
In all cases except ima_bprm_check() the filename was not defined and ima_d_path() was used to find the full path. Unfortunately, the bprm filename is a relative pathname (eg. ./<dir>/filename). ima_bprm_check() selects between bprm->interp and bprm->filename. The following dump demonstrates the differences between using filename and interp. bprm->filename filename: ./foo.sh, pathname: /root/bin/foo.sh filename: ./foo.sh, pathname: /bin/dash bprm->interp filename: ./foo.sh, pathname: /root/bin/foo.sh filename: /bin/sh, pathname: /bin/dash In both cases the pathnames are currently the same. This patch removes usage of filename and interp in favor of d_absolute_path. Changes v3: - 11 extra bytes for "deleted" not needed (Mimi) - purpose "replace relative bprm filename with full pathname" (Mimi) Changes v2: - use d_absolute_path() instead of d_path to work in chroot environments. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09ima: remove unnecessary appraisal testDmitry Kasatkin
ima_get_action() sets the "action" flags based on policy. Before collecting, measuring, appraising, or auditing the file, the "action" flag is updated based on the cached iint->flags. This patch removes the subsequent unnecessary appraisal test in ima_appraise_measurement(). Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09ima: add missing '__init' keywordsDmitry Kasatkin
Add missing keywords to the function definition to cleanup to discard initialization code. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Reviewed-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09ima: remove unnecessary extra variableDmitry Kasatkin
'function' variable value can be changed instead of allocating extra '_func' variable. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09ima: simplify conditional statement to improve performanceDmitry Kasatkin
Precede bit testing before string comparison makes code faster. Also refactor statement as a single line pointer assignment. Logic is following: we set 'xattr_ptr' to read xattr value when we will do appraisal or in any case when measurement template is other than 'ima'. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09integrity: remove declaration of non-existing functionsDmitry Kasatkin
Commit f381c27 "integrity: move ima inode integrity data management" (re)moved few functions but left their declarations in header files. This patch removes them and also removes duplicated declaration of integrity_iint_find(). Commit c7de7ad "ima: remove unused cleanup functions". This patch removes these definitions as well. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09integrity: prevent flooding with 'Request for unknown key'Dmitry Kasatkin
If file has IMA signature, IMA in enforce mode, but key is missing then file access is blocked and single error message is printed. If IMA appraisal is enabled in fix mode, then system runs as usual but might produce tons of 'Request for unknown key' messages. This patch switches 'pr_warn' to 'pr_err_ratelimited'. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-09ima: pass 'opened' flag to identify newly created filesDmitry Kasatkin
Empty files and missing xattrs do not guarantee that a file was just created. This patch passes FILE_CREATED flag to IMA to reliably identify new files. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> 3.14+
2014-09-09evm: properly handle INTEGRITY_NOXATTRS EVM statusDmitry Kasatkin
Unless an LSM labels a file during d_instantiate(), newly created files are not labeled with an initial security.evm xattr, until the file closes. EVM, before allowing a protected, security xattr to be written, verifies the existing 'security.evm' value is good. For newly created files without a security.evm label, this verification prevents writing any protected, security xattrs, until the file closes. Following is the example when this happens: fd = open("foo", O_CREAT | O_WRONLY, 0644); setxattr("foo", "security.SMACK64", value, sizeof(value), 0); close(fd); While INTEGRITY_NOXATTRS status is handled in other places, such as evm_inode_setattr(), it does not handle it in all cases in evm_protect_xattr(). By limiting the use of INTEGRITY_NOXATTRS to newly created files, we can now allow setting "protected" xattrs. Changelog: - limit the use of INTEGRITY_NOXATTRS to IMA identified new files Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> 3.14+
2014-09-09Documentation: Docbook: Fix generated DocBook/kernel-api.xmlMasanari Iida
This patch fix spelling typo found in DocBook/kernel-api.xml. It is because the file is generated from the source comments, I have to fix the comments in source codes. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-09-08selinux: register nf hooks with single nf_register_hooks callJiri Pirko
Push ipv4 and ipv6 nf hooks into single array and register/unregister them via single call. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-09-08ima: provide flag to identify new empty filesDmitry Kasatkin
On ima_file_free(), newly created empty files are not labeled with an initial security.ima value, because the iversion did not change. Commit dff6efc "fs: fix iversion handling" introduced a change in iversion behavior. To verify this change use the shell command: $ (exec >foo) $ getfattr -h -e hex -d -m security foo This patch defines the IMA_NEW_FILE flag. The flag is initially set, when IMA detects that a new file is created, and subsequently checked on the ima_file_free() hook to set the initial security.ima value. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> 3.14+
2014-09-08evm: prevent passing integrity check if xattr read failsDmitry Kasatkin
This patch fixes a bug, where evm_verify_hmac() returns INTEGRITY_PASS if inode->i_op->getxattr() returns an error in evm_find_protected_xattrs. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
2014-09-03selinux: fix a problem with IPv6 traffic denials in selinux_ip_postroute()Paul Moore
A previous commit c0828e50485932b7e019df377a6b0a8d1ebd3080 ("selinux: process labeled IPsec TCP SYN-ACK packets properly in selinux_ip_postroute()") mistakenly left out a 'break' from a switch statement which caused problems with IPv6 traffic. Thanks to Florian Westphal for reporting and debugging the issue. Reported-by: Florian Westphal <fwestpha@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-09-03KEYS: Increase root_maxkeys and root_maxbytes sizesSteve Dickson
Now that NFS client uses the kernel key ring facility to store the NFSv4 id/gid mappings, the defaults for root_maxkeys and root_maxbytes need to be substantially increased. These values have been soak tested: https://bugzilla.redhat.com/show_bug.cgi?id=1033708#c73 Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-09-02evm: fix checkpatch warningsDmitry Kasatkin
This patch fixes checkpatch 'return' warnings introduced with commit 9819cf2 "checkpatch: warn on unnecessary void function return statements". Use scripts/checkpatch.pl --file security/integrity/evm/evm_main.c to produce the warnings. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-09-02ima: fix fallback to use new_sync_read()Dmitry Kasatkin
3.16 commit aad4f8bb42af06371aa0e85bf0cd9d52c0494985 'switch simple generic_file_aio_read() users to ->read_iter()' replaced ->aio_read with ->read_iter in most of the file systems and introduced new_sync_read() as a replacement for do_sync_read(). Most of file systems set '->read' and ima_kernel_read is not affected. When ->read is not set, this patch adopts fallback call changes from the vfs_read. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> 3.16+
2014-09-02ima: prevent buffer overflow in ima_alloc_tfm()Dmitry Kasatkin
This patch fixes the case where the file's signature/hash xattr contains an invalid hash algorithm. Although we can not verify the xattr, we still need to measure the file. Use the default IMA hash algorithm. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
