commit 3dc91d4338d698ce77832985f9cb183d8eeaf6be upstream.
While running stress tests on adding and deleting ftrace instances I hit
this bug:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: selinux_inode_permission+0x85/0x160
PGD 63681067 PUD 7ddbe067 PMD 0
Oops: 0000 [#1] PREEMPT
CPU: 0 PID: 5634 Comm: ftrace-test-mki Not tainted 3.13.0-rc4-test-00033-gd2a6dde-dirty #20
Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006
task: ffff880078375800 ti: ffff88007ddb0000 task.ti: ffff88007ddb0000
RIP: 0010:[<ffffffff812d8bc5>] [<ffffffff812d8bc5>] selinux_inode_permission+0x85/0x160
RSP: 0018:ffff88007ddb1c48 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000800000 RCX: ffff88006dd43840
RDX: 0000000000000001 RSI: 0000000000000081 RDI: ffff88006ee46000
RBP: ffff88007ddb1c88 R08: 0000000000000000 R09: ffff88007ddb1c54
R10: 6e6576652f6f6f66 R11: 0000000000000003 R12: 0000000000000000
R13: 0000000000000081 R14: ffff88006ee46000 R15: 0000000000000000
FS: 00007f217b5b6700(0000) GS:ffffffff81e21000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033^M
CR2: 0000000000000020 CR3: 000000006a0fe000 CR4: 00000000000007f0
Call Trace:
security_inode_permission+0x1c/0x30
__inode_permission+0x41/0xa0
inode_permission+0x18/0x50
link_path_walk+0x66/0x920
path_openat+0xa6/0x6c0
do_filp_open+0x43/0xa0
do_sys_open+0x146/0x240
SyS_open+0x1e/0x20
system_call_fastpath+0x16/0x1b
Code: 84 a1 00 00 00 81 e3 00 20 00 00 89 d8 83 c8 02 40 f6 c6 04 0f 45 d8 40 f6 c6 08 74 71 80 cf 02 49 8b 46 38 4c 8d 4d cc 45 31 c0 <0f> b7 50 20 8b 70 1c 48 8b 41 70 89 d9 8b 78 04 e8 36 cf ff ff
RIP selinux_inode_permission+0x85/0x160
Investigating, I found that the inode->i_security was NULL, and the
dereference of it caused the oops.
in selinux_inode_permission():
isec = inode->i_security;
rc = avc_has_perm_noaudit(sid, isec->sid, isec->sclass, perms, 0, &avd);
Note, the crash came from stressing the deletion and reading of debugfs
files. I was not able to recreate this via normal files. But I'm not
sure they are safe. It may just be that the race window is much harder
to hit.
What seems to have happened (and what I have traced), is the file is
being opened at the same time the file or directory is being deleted.
As the dentry and inode locks are not held during the path walk, nor is
the inodes ref counts being incremented, there is nothing saving these
structures from being discarded except for an rcu_read_lock().
The rcu_read_lock() protects against freeing of the inode, but it does
not protect freeing of the inode_security_struct. Now if the freeing of
the i_security happens with a call_rcu(), and the i_security field of
the inode is not changed (it gets freed as the inode gets freed) then
there will be no issue here. (Linus Torvalds suggested not setting the
field to NULL such that we do not need to check if it is NULL in the
permission check).
Note, this is a hack, but it fixes the problem at hand. A real fix is
to restructure the destroy_inode() to call all the destructor handlers
from the RCU callback. But that is a major job to do, and requires a
lot of work. For now, we just band-aid this bug with this fix (it
works), and work on a more maintainable solution in the future.
Link: http://lkml.kernel.org/r/20140109101932.0508dec7@gandalf.local.home
Link: http://lkml.kernel.org/r/20140109182756.17abaaa8@gandalf.local.home
commit c0c1439541f5305b57a83d599af32b74182933fe upstream.
selinux_setprocattr() does ptrace_parent(p) under task_lock(p),
but task_struct->alloc_lock doesn't pin ->parent or ->ptrace,
this looks confusing and triggers the "suspicious RCU usage"
warning because ptrace_parent() does rcu_dereference_check().
And in theory this is wrong, spin_lock()->preempt_disable()
doesn't necessarily imply rcu_read_lock() we need to access
the ->parent.
Reported-by: Evan McNabb <emcnabb@redhat.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit 46d01d63221c3508421dd72ff9c879f61053cffc upstream.
Fix a broken networking check. Return an error if peer recv fails. If
secmark is active and the packet recv succeeds the peer recv error is
ignored.
Signed-off-by: Chad Hanson <chanson@trustedcs.com>
commit 446b802437f285de68ffb8d6fac3c44c3cab5b04 upstream.
In selinux_ip_postroute() we perform access checks based on the
packet's security label. For locally generated traffic we get the
packet's security label from the associated socket; this works in all
cases except for TCP SYN-ACK packets. In the case of SYN-ACK packet's
the correct security label is stored in the connection's request_sock,
not the server's socket. Unfortunately, at the point in time when
selinux_ip_postroute() is called we can't query the request_sock
directly, we need to recreate the label using the same logic that
originally labeled the associated request_sock.
See the inline comments for more explanation.
Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu>
Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu>
commit 47180068276a04ed31d24fe04c673138208b07a9 upstream.
In selinux_ip_output() we always label packets based on the parent
socket. While this approach works in almost all cases, it doesn't
work in the case of TCP SYN-ACK packets when the correct label is not
the label of the parent socket, but rather the label of the larval
socket represented by the request_sock struct.
Unfortunately, since the request_sock isn't queued on the parent
socket until *after* the SYN-ACK packet is sent, we can't lookup the
request_sock to determine the correct label for the packet; at this
point in time the best we can do is simply pass/NF_ACCEPT the packet.
It must be said that simply passing the packet without any explicit
labeling action, while far from ideal, is not terrible as the SYN-ACK
packet will inherit any IP option based labeling from the initial
connection request so the label *should* be correct and all our
access controls remain in place so we shouldn't have to worry about
information leaks.
commit 42d64e1add3a1ce8a787116036163b8724362145 upstream.
The SELinux/NetLabel glue code has a locking bug that affects systems
with NetLabel enabled, see the kernel error message below. This patch
corrects this problem by converting the bottom half socket lock to a
more conventional, and correct for this call-path, lock_sock() call.
[ INFO: suspicious RCU usage. ]
3.11.0-rc3+ #19 Not tainted
net/ipv4/cipso_ipv4.c:1928 suspicious rcu_dereference_protected() usage!
rcu_scheduler_active = 1, debug_locks = 0
2 locks held by ping/731:
#0: (slock-AF_INET/1){+.-...}, at: [...] selinux_netlbl_socket_connect
#1: (rcu_read_lock){.+.+..}, at: [<...>] netlbl_conn_setattr
stack backtrace:
CPU: 1 PID: 731 Comm: ping Not tainted 3.11.0-rc3+ #19
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
0000000000000001 ffff88006f659d28 ffffffff81726b6a ffff88003732c500
ffff88006f659d58 ffffffff810e4457 ffff88006b845a00 0000000000000000
000000000000000c ffff880075aa2f50 ffff88006f659d90 ffffffff8169bec7
Call Trace:
[<ffffffff81726b6a>] dump_stack+0x54/0x74
[<ffffffff810e4457>] lockdep_rcu_suspicious+0xe7/0x120
[<ffffffff8169bec7>] cipso_v4_sock_setattr+0x187/0x1a0
[<ffffffff8170f317>] netlbl_conn_setattr+0x187/0x190
[<ffffffff8170f195>] ? netlbl_conn_setattr+0x5/0x190
[<ffffffff8131ac9e>] selinux_netlbl_socket_connect+0xae/0xc0
[<ffffffff81303025>] selinux_socket_connect+0x135/0x170
[<ffffffff8119d127>] ? might_fault+0x57/0xb0
[<ffffffff812fb146>] security_socket_connect+0x16/0x20
[<ffffffff815d3ad3>] SYSC_connect+0x73/0x130
[<ffffffff81739a85>] ? sysret_check+0x22/0x5d
[<ffffffff810e5e2d>] ? trace_hardirqs_on_caller+0xfd/0x1c0
[<ffffffff81373d4e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff815d52be>] SyS_connect+0xe/0x10
[<ffffffff81739a59>] system_call_fastpath+0x16/0x1b
commit a84a921978b7d56e0e4b87ffaca6367429b4d8ff upstream.
On an error iov may still have been reallocated and need freeing
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 4502403dcf8f5c76abd4dbab8726c8e4ecb5cd34 upstream.
The call tree here is:
sk_clone_lock() <- takes bh_lock_sock(newsk);
xfrm_sk_clone_policy()
__xfrm_sk_clone_policy()
clone_policy() <- uses GFP_ATOMIC for allocations
security_xfrm_policy_clone()
security_ops->xfrm_policy_clone_security()
selinux_xfrm_policy_clone()
Signed-off-by: James Morris <james.l.morris@oracle.com>
security keys
commit 8aec0f5d4137532de14e6554fd5dd201ff3a3c49 upstream.
Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to
compat_process_vm_rw() shows that the compatibility code requires an
explicit "access_ok()" check before calling
compat_rw_copy_check_uvector(). The same difference seems to appear when
we compare fs/read_write.c:do_readv_writev() to
fs/compat.c:compat_do_readv_writev().
This subtle difference between the compat and non-compat requirements
should probably be debated, as it seems to be error-prone. In fact,
there are two others sites that use this function in the Linux kernel,
and they both seem to get it wrong:
Now shifting our attention to fs/aio.c, we see that aio_setup_iocb()
also ends up calling compat_rw_copy_check_uvector() through
aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to
be missing. Same situation for
security/keys/compat.c:compat_keyctl_instantiate_key_iov().
I propose that we add the access_ok() check directly into
compat_rw_copy_check_uvector(), so callers don't have to worry about it,
and it therefore makes the compat call code similar to its non-compat
counterpart. Place the access_ok() check in the same location where
copy_from_user() can trigger a -EFAULT error in the non-compat code, so
the ABI behaviors are alike on both compat and non-compat.
While we are here, fix compat_do_readv_writev() so it checks for
compat_rw_copy_check_uvector() negative return values.
And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error
handling.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
[bwh: Backported to 3.2: adjust context]
commit 0da9dfdd2cd9889201bc6f6f43580c99165cd087 upstream.
This fixes CVE-2013-1792.
There is a race in install_user_keyrings() that can cause a NULL pointer
dereference when called concurrently for the same user if the uid and
uid-session keyrings are not yet created. It might be possible for an
unprivileged user to trigger this by calling keyctl() from userspace in
parallel immediately after logging in.
Assume that we have two threads both executing lookup_user_key(), both
looking for KEY_SPEC_USER_SESSION_KEYRING.
THREAD A THREAD B
==>call install_user_keyrings();
if (!cred->user->session_keyring)
user->uid_keyring = uid_keyring;
if (user->uid_keyring)
return 0;
key = cred->user->session_keyring [== NULL]
user->session_keyring = session_keyring;
atomic_inc(&key->usage); [oops]
At the point thread A dereferences cred->user->session_keyring, thread B
hasn't updated user->session_keyring yet, but thread A assumes it is
populated because install_user_keyrings() returned ok.
The race window is really small but can be exploited if, for example,
thread B is interrupted or preempted after initializing uid_keyring, but
before doing setting session_keyring.
This couldn't be reproduced on a stock kernel. However, after placing
systemtap probe on 'user->session_keyring = session_keyring;' that
introduced some delay, the kernel could be crashed reliably.
Fix this by checking both pointers before deciding whether to return.
Alternatively, the test could be done away with entirely as it is checked
inside the mutex - but since the mutex is global, that may not be the best
way.
Reported-by: Mateusz Guzik <mguzik@redhat.com>
commit a67adb997419fb53540d4a4f79c6471c60bc69b6 upstream.
The following lines of code produce a kernel oops.
fd = socket(PF_FILE, SOCK_STREAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0);
fchmod(fd, 0666);
[ 139.922364] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 139.924982] IP: [< (null)>] (null)
[ 139.924982] *pde = 00000000
[ 139.924982] Oops: 0000 [#5] SMP
[ 139.924982] Modules linked in: fuse dm_crypt dm_mod i2c_piix4 serio_raw evdev binfmt_misc button
[ 139.924982] Pid: 3070, comm: acpid Tainted: G D 3.8.0-rc2-kds+ #465 Bochs Bochs
[ 139.924982] EIP: 0060:[<00000000>] EFLAGS: 00010246 CPU: 0
[ 139.924982] EIP is at 0x0
[ 139.924982] EAX: cf5ef000 EBX: cf5ef000 ECX: c143d600 EDX: c15225f2
[ 139.924982] ESI: cf4d2a1c EDI: cf4d2a1c EBP: cc02df10 ESP: cc02dee4
[ 139.924982] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 139.924982] CR0: 80050033 CR2: 00000000 CR3: 0c059000 CR4: 000006d0
[ 139.924982] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 139.924982] DR6: ffff0ff0 DR7: 00000400
[ 139.924982] Process acpid (pid: 3070, ti=cc02c000 task=d7705340 task.ti=cc02c000)
[ 139.924982] Stack:
[ 139.924982] c1203c88 00000000 cc02def4 cf4d2a1c ae21eefa 471b60d5 1083c1ba c26a5940
[ 139.924982] e891fb5e 00000041 00000004 cc02df1c c1203964 00000000 cc02df4c c10e20c3
[ 139.924982] 00000002 00000000 00000000 22222222 c1ff2222 cf5ef000 00000000 d76efb08
[ 139.924982] Call Trace:
[ 139.924982] [<c1203c88>] ? evm_update_evmxattr+0x5b/0x62
[ 139.924982] [<c1203964>] evm_inode_post_setattr+0x22/0x26
[ 139.924982] [<c10e20c3>] notify_change+0x25f/0x281
[ 139.924982] [<c10cbf56>] chmod_common+0x59/0x76
[ 139.924982] [<c10e27a1>] ? put_unused_fd+0x33/0x33
[ 139.924982] [<c10cca09>] sys_fchmod+0x39/0x5c
[ 139.924982] [<c13f4f30>] syscall_call+0x7/0xb
[ 139.924982] Code: Bad EIP value.
This happens because sockets do not define the removexattr operation.
Before removing the xattr, verify the removexattr function pointer is
not NULL.
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
This reverts commit c5ee58688baa98bc3a4f6095a1acf6fd7fd9e967,
which was commit 201e72acb2d3821e2de9ce6091e98859c316b29a upstream.
Herton Ronaldo Krzesinski pointed out that the race condition this
dealt with does not exist in 3.2.y.
commit 88a693b5c1287be4da937699cb82068ce9db0135 upstream.
3.5.0-rc1+ #63 Not tainted
security/selinux/netnode.c:178 suspicious rcu_dereference_check() usage!
1 lock held by trinity-child1/8750:
#0: (sel_netnode_lock){+.....}, at: [<ffffffff812d8f8a>] sel_netnode_sid+0x16a/0x3e0
stack backtrace:
Pid: 8750, comm: trinity-child1 Not tainted 3.5.0-rc1+ #63
Call Trace:
[<ffffffff810cec2d>] lockdep_rcu_suspicious+0xfd/0x130
[<ffffffff812d91d1>] sel_netnode_sid+0x3b1/0x3e0
[<ffffffff812d8e20>] ? sel_netnode_find+0x1a0/0x1a0
[<ffffffff812d24a6>] selinux_socket_bind+0xf6/0x2c0
[<ffffffff810cd1dd>] ? trace_hardirqs_off+0xd/0x10
[<ffffffff810cdb55>] ? lock_release_holdtime.part.9+0x15/0x1a0
[<ffffffff81093841>] ? lock_hrtimer_base+0x31/0x60
[<ffffffff812c9536>] security_socket_bind+0x16/0x20
[<ffffffff815550ca>] sys_bind+0x7a/0x100
[<ffffffff816c03d5>] ? sysret_check+0x22/0x5d
[<ffffffff810d392d>] ? trace_hardirqs_on_caller+0x10d/0x1a0
[<ffffffff8133b09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff816c03a9>] system_call_fastpath+0x16/0x1b
This patch below does what Paul McKenney suggested in the previous thread.
Signed-off-by: Dave Jones <davej@redhat.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: Eric Paris <eparis@parisplace.org>
dev_cgroup->exceptions is protected with devcgroup_mutex for writes
and RCU for reads; however, RCU usage isn't correct.
* dev_exception_clean() doesn't use RCU variant of list_del() and
kfree(). The function can race with may_access() and may_access()
may end up dereferencing already freed memory. Use list_del_rcu()
and kfree_rcu() instead.
* may_access() may be called only with RCU read locked but doesn't use
RCU safe traversal over ->exceptions. Use list_for_each_entry_rcu().
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Cc: Aristeu Rozanski <aris@redhat.com>
Cc: Li Zefan <lizefan@huawei.com>
- Adjust context
- Exception list is called whitelist]
commit 154c50ca4eb9ae472f50b6a481213e21ead4457d upstream.
We reset the bool names and values array to NULL, but do not reset the
number of entries in these arrays to 0. If we error out and then get back
into this function we will walk these NULL pointers based on the belief
that they are non-zero length.
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 51b79bee627d526199b2f6a6bef8ee0c0739b6d1 upstream.
Add missing "personality.h"
security/commoncap.c: In function 'cap_bprm_set_creds':
security/commoncap.c:510: error: 'PER_CLEAR_ON_SETID' undeclared (first use in this function)
security/commoncap.c:510: error: (Each undeclared identifier is reported only once
security/commoncap.c:510: error: for each function it appears in.)
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Eric Paris <eparis@redhat.com>
commit d52fc5dde171f030170a6cb78034d166b13c9445 upstream.
If a process increases permissions using fcaps all of the dangerous
personality flags which are cleared for suid apps should also be cleared.
Thus programs given priviledge with fcaps will continue to have address space
randomization enabled even if the parent tried to disable it to make it
easier to attack.
Reviewed-by: Serge Hallyn <serge.hallyn@canonical.com>
commit df91e49477a9be15921cb2854e1d12a3bdb5e425 upstream.
Userspace can pass in arbitrary combinations of MS_* flags to mount().
If both MS_BIND and one of MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE are
passed, device name which should be checked for MS_BIND was not checked because
MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE had higher priority than MS_BIND.
If both one of MS_BIND/MS_MOVE and MS_REMOUNT are passed, device name which
should not be checked for MS_REMOUNT was checked because MS_BIND/MS_MOVE had
higher priority than MS_REMOUNT.
Fix these bugs by changing priority to MS_REMOUNT -> MS_BIND ->
MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE -> MS_MOVE as with do_mount() does.
Also, unconditionally return -EINVAL if more than one of
MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE is passed so that TOMOYO will not
generate inaccurate audit logs, for commit 7a2e8a8f "VFS: Sanity check mount
flags passed to change_mnt_propagation()" clarified that these flags must be
exclusively passed.
commit f4a0391dfa91155bd961673b31eb42d9d45c799d upstream.
Fix the following build warning:
warning: (IMA) selects TCG_TPM which has unmet direct dependencies
(HAS_IOMEM && EXPERIMENTAL)
Suggested-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
commit 735e93c70434614bffac4a914ca1da72e37d43c0 upstream.
This adds the .gitignore file for the autogenerated TOMOYO files to keep
git from complaining after building things.
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: James Morris <jmorris@namei.org>
commit 25add8cf99c9ec8b8dc0acd8b9241e963fc0d29c upstream.
TOMOYO 2.5 in Linux 3.2 and later handles Unix domain socket's address.
Thus, tomoyo_correct_word2() needs to accept \000 as a valid character, or
TOMOYO 2.5 cannot handle Unix domain's abstract socket address.
Reported-by: Steven Allen <steven@stebalien.com>
commit 7b7e5916aa2f46e57f8bd8cb89c34620ebfda5da upstream.
Don't free a valid measurement entry on TPM PCR extend failure.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
commit 45fae7493970d7c45626ccd96d4a74f5f1eea5a9 upstream.
Info about new measurements are cached in the iint for performance. When
the inode is flushed from cache, the associated iint is flushed as well.
Subsequent access to the inode will cause the inode to be re-measured and
will attempt to add a duplicate entry to the measurement list.
This patch frees the duplicate measurement memory, fixing a memory leak.
Commit 1e39f384bb01 ("evm: fix build problems") makes the stub version
of security_old_inode_init_security() return 0 when CONFIG_SECURITY is
not set.
But that makes callers such as reiserfs_security_init() assume that
security_old_inode_init_security() has set name, value, and len
arguments properly - but security_old_inode_init_security() left them
uninitialized which then results in interesting failures.
Revert security_old_inode_init_security() to the old behavior of
returning EOPNOTSUPP since both callers (reiserfs and ocfs2) handle this
just fine.
[ Also fixed the S_PRIVATE(inode) case of the actual non-stub
security_old_inode_init_security() function to return EOPNOTSUPP
for the same reason, as pointed out by Mimi Zohar.
It got incorrectly changed to match the new function in commit
fb88c2b6cbb1: "evm: fix security/security_old_init_security return
code". - Linus ]
Reported-by: Jorge Bastos <mysql.jorge@decimal.pt>
Acked-by: James Morris <jmorris@namei.org>
Acked-by: Mimi Zohar <zohar@us.ibm.com>
Fix the following bug in sel_netport_insert() where rcu_dereference() should
be rcu_dereference_protected() as sel_netport_lock is held.
[ INFO: suspicious rcu_dereference_check() usage. ]
security/selinux/netport.c:127 invoked rcu_dereference_check() without protection!
1 lock held by ossec-rootcheck/3323:
#0: (sel_netport_lock){+.....}, at: [<ffffffff8117d775>] sel_netport_sid+0xbb/0x226
stack backtrace:
Pid: 3323, comm: ossec-rootcheck Not tainted 3.1.0-rc8-fsdevel+ #1095
Call Trace:
[<ffffffff8105cfb7>] lockdep_rcu_dereference+0xa7/0xb0
[<ffffffff8117d871>] sel_netport_sid+0x1b7/0x226
[<ffffffff8117d6ba>] ? sel_netport_avc_callback+0xbc/0xbc
[<ffffffff8117556c>] selinux_socket_bind+0x115/0x230
[<ffffffff810a5388>] ? might_fault+0x4e/0x9e
[<ffffffff810a53d1>] ? might_fault+0x97/0x9e
[<ffffffff81171cf4>] security_socket_bind+0x11/0x13
[<ffffffff812ba967>] sys_bind+0x56/0x95
[<ffffffff81380dac>] ? sysret_check+0x27/0x62
[<ffffffff8105b767>] ? trace_hardirqs_on_caller+0x11e/0x155
[<ffffffff81076fcd>] ? audit_syscall_entry+0x17b/0x1ae
[<ffffffff811b5eae>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff81380d7b>] system_call_fastpath+0x16/0x1b
Cc: stable@kernel.org
There is a small chance of racing during tfm allocation.
This patch fixes it.
On multi-core systems, setting of the key before every caclculation,
causes invalid HMAC calculation for other tfm users, because internal
state (ipad, opad) can be invalid before set key call returns.
It needs to be set only once during initialization.
Current tomoyo_realpath_from_path() implementation returns strange pathname
when calculating pathname of a file which belongs to lazy unmounted tree.
Use local pathname rather than strange absolute pathname in that case.
Also, this patch fixes a regression by commit 02125a82 "fix apparmor
dereferencing potentially freed dentry, sanitize __d_path() API".
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: stable@vger.kernel.org
__d_path() API is asking for trouble and in case of apparmor d_namespace_path()
getting just that. The root cause is that when __d_path() misses the root
it had been told to look for, it stores the location of the most remote ancestor
in *root. Without grabbing references. Sure, at the moment of call it had
been pinned down by what we have in *path. And if we raced with umount -l, we
could have very well stopped at vfsmount/dentry that got freed as soon as
prepend_path() dropped vfsmount_lock.
It is safe to compare these pointers with pre-existing (and known to be still
alive) vfsmount and dentry, as long as all we are asking is "is it the same
address?". Dereferencing is not safe and apparmor ended up stepping into
that. d_namespace_path() really wants to examine the place where we stopped,
even if it's not connected to our namespace. As the result, it looked
at ->d_sb->s_magic of a dentry that might've been already freed by that point.
All other callers had been careful enough to avoid that, but it's really
a bad interface - it invites that kind of trouble.
The fix is fairly straightforward, even though it's bigger than I'd like:
* prepend_path() root argument becomes const.
* __d_path() is never called with NULL/NULL root. It was a kludge
to start with. Instead, we have an explicit function - d_absolute_root().
Same as __d_path(), except that it doesn't get root passed and stops where
it stops. apparmor and tomoyo are using it.
* __d_path() returns NULL on path outside of root. The main
caller is show_mountinfo() and that's precisely what we pass root for - to
skip those outside chroot jail. Those who don't want that can (and do)
use d_path().
* __d_path() root argument becomes const. Everyone agrees, I hope.
* apparmor does *NOT* try to use __d_path() or any of its variants
when it sees that path->mnt is an internal vfsmount. In that case it's
definitely not mounted anywhere and dentry_path() is exactly what we want
there. Handling of sysctl()-triggered weirdness is moved to that place.
* if apparmor is asked to do pathname relative to chroot jail
and __d_path() tells it we it's not in that jail, the sucker just calls
d_absolute_path() instead. That's the other remaining caller of __d_path(),
BTW.
* seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway -
the normal seq_file logics will take care of growing the buffer and redoing
the call of ->show() just fine). However, if it gets path not reachable
from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped
ignoring the return value as it used to do).
Reviewed-by: John Johansen <john.johansen@canonical.com>
ACKed-by: John Johansen <john.johansen@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into for-linus
Encrypted keys are encrypted/decrypted using either a trusted or
user-defined key type, which is referred to as the 'master' key.
The master key may be of type trusted iff the trusted key is
builtin or both the trusted key and encrypted keys are built as
modules. This patch resolves the build dependency problem.
- Use "masterkey-$(CONFIG_TRUSTED_KEYS)-$(CONFIG_ENCRYPTED_KEYS)" construct
to encapsulate the above logic. (Suggested by Dimtry Kasatkin.)
- Fixing the encrypted-keys Makefile, results in a module name change
from encrypted.ko to encrypted-keys.ko.
- Add module dependency for request_trusted_key() definition
Fix request_master_key() error return code.
Fix a NULL pointer deref in the user-defined key type whereby updating a
negative key into a fully instantiated key will cause an oops to occur
when the code attempts to free the non-existent old payload.
This results in an oops that looks something like the following:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
PGD 3391d067 PUD 3894a067 PMD 0
Oops: 0002 [#1] SMP
CPU 1
Pid: 4354, comm: keyctl Not tainted 3.1.0-fsdevel+ #1140 /DG965RY
RIP: 0010:[<ffffffff81085fa1>] [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
RSP: 0018:ffff88003d591df8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000006e
RDX: ffffffff8161d0c0 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88003d591e18 R08: 0000000000000000 R09: ffffffff8152fa6c
R10: 0000000000000000 R11: 0000000000000300 R12: ffff88003b8f9538
R13: ffffffff8161d0c0 R14: ffff88003b8f9d50 R15: ffff88003c69f908
FS: 00007f97eb18c720(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CR2: 0000000000000008 CR3: 000000003d47a000 CR4: 00000000000006e0
Process keyctl (pid: 4354, threadinfo ffff88003d590000, task ffff88003c78a040)
Stack:
ffff88003e0ffde0 ffff88003b8f9538 0000000000000001 ffff88003b8f9d50
ffff88003d591e28 ffffffff810860f0 ffff88003d591e68 ffffffff8117bfea
ffff88003d591e68 ffffffff00000000 ffff88003e0ffde1 ffff88003e0ffde0
Call Trace:
[<ffffffff810860f0>] call_rcu_sched+0x10/0x12
[<ffffffff8117bfea>] user_update+0x8d/0xa2
[<ffffffff8117723a>] key_create_or_update+0x236/0x270
[<ffffffff811789b1>] sys_add_key+0x123/0x17e
[<ffffffff813b84bb>] system_call_fastpath+0x16/0x1b
Acked-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Neil Horman <nhorman@redhat.com>
Acked-by: Steve Dickson <steved@redhat.com>
Commit 272cd7a8c67dd40a31ecff76a503bbb84707f757 introduced
a change to the way rule lists are handled and reported in
the smackfs filesystem. One of the issues addressed had to
do with the termination of read requests on /smack/load.
This change introduced a error in /smack/cipso, which shares
some of the same list processing code.
This patch updates all the file access list handling in
smackfs to use the code introduced for /smack/load.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
* 'for-linus' of git://git.selinuxproject.org/~jmorris/linux-security:
TOMOYO: Fix interactive judgment functionality.
* 'for-linus' of git://github.com/richardweinberger/linux: (90 commits)
um: fix ubd cow size
um: Fix kmalloc argument order in um/vdso/vma.c
um: switch to use of drivers/Kconfig
UserModeLinux-HOWTO.txt: fix a typo
UserModeLinux-HOWTO.txt: remove ^H characters
um: we need sys/user.h only on i386
um: merge delay_{32,64}.c
um: distribute exports to where exported stuff is defined
um: kill system-um.h
um: generic ftrace.h will do...
um: segment.h is x86-only and needed only there
um: asm/pda.h is not needed anymore
um: hw_irq.h can go generic as well
um: switch to generic-y
um: clean Kconfig up a bit
um: a couple of missing dependencies...
um: kill useless argument of free_chan() and free_one_chan()
um: unify ptrace_user.h
um: unify KSTK_...
um: fix gcov build breakage
Signed-off-by: Richard Weinberger <richard@nod.at>
There is no functional change.
Cc: Mimi Zohar <zohar@us.ibm.com>
The basic idea behind cross memory attach is to allow MPI programs doing
intra-node communication to do a single copy of the message rather than a
double copy of the message via shared memory.
The following patch attempts to achieve this by allowing a destination
process, given an address and size from a source process, to copy memory
directly from the source process into its own address space via a system
call. There is also a symmetrical ability to copy from the current
process's address space into a destination process's address space.
- Use of /proc/pid/mem has been considered, but there are issues with
using it:
- Does not allow for specifying iovecs for both src and dest, assuming
preadv or pwritev was implemented either the area read from or
written to would need to be contiguous.
- Currently mem_read allows only processes who are currently
ptrace'ing the target and are still able to ptrace the target to read
from the target. This check could possibly be moved to the open call,
but its not clear exactly what race this restriction is stopping
(reason appears to have been lost)
- Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix
domain socket is a bit ugly from a userspace point of view,
especially when you may have hundreds if not (eventually) thousands
of processes that all need to do this with each other
- Doesn't allow for some future use of the interface we would like to
consider adding in the future (see below)
- Interestingly reading from /proc/pid/mem currently actually
involves two copies! (But this could be fixed pretty easily)
As mentioned previously use of vmsplice instead was considered, but has
problems. Since you need the reader and writer working co-operatively if
the pipe is not drained then you block. Which requires some wrapping to
do non blocking on the send side or polling on the receive. In all to all
communication it requires ordering otherwise you can deadlock. And in the
example of many MPI tasks writing to one MPI task vmsplice serialises the
copying.
There are some cases of MPI collectives where even a single copy interface
does not get us the performance gain we could. For example in an
MPI_Reduce rather than copy the data from the source we would like to
instead use it directly in a mathops (say the reduce is doing a sum) as
this would save us doing a copy. We don't need to keep a copy of the data
from the source. I haven't implemented this, but I think this interface
could in the future do all this through the use of the flags - eg could
specify the math operation and type and the kernel rather than just
copying the data would apply the specified operation between the source
and destination and store it in the destination.
Although we don't have a "second user" of the interface (though I've had
some nibbles from people who may be interested in using it for intra
process messaging which is not MPI). This interface is something which
hardware vendors are already doing for their custom drivers to implement
fast local communication. And so in addition to this being useful for
OpenMPI it would mean the driver maintainers don't have to fix things up
when the mm changes.
There was some discussion about how much faster a true zero copy would
go. Here's a link back to the email with some testing I did on that:
http://marc.info/?l=linux-mm&m=130105930902915&w=2
There is a basic man page for the proposed interface here:
http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt
This has been implemented for x86 and powerpc, other architecture should
mainly (I think) just need to add syscall numbers for the process_vm_readv
and process_vm_writev. There are 32 bit compatibility versions for
64-bit kernels.
For arch maintainers there are some simple tests to be able to quickly
verify that the syscalls are working correctly here:
http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz
Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com>
Cc: <linux-man@vger.kernel.org>
Cc: <linux-arch@vger.kernel.org>
The pervasive, but implicit presence of <linux/module.h> meant
that things like this file would happily compile as-is. But
with the desire to phase out the module.h being included everywhere,
point this file at export.h which will give it THIS_MODULE and
the EXPORT_SYMBOL variants.
Commit 17fcfbd9 "TOMOYO: Add interactive enforcing mode." introduced ability
to query access decision using userspace programs. It was using global PID for
reaching policy configuration of the process. However, use of PID returns stale
policy configuration when the process's subjective credentials and objective
credentials differ. Fix this problem by allowing reaching policy configuration
via query id.
* 'next' of git://selinuxproject.org/~jmorris/linux-security: (95 commits)
TOMOYO: Fix incomplete read after seek.
Smack: allow to access /smack/access as normal user
TOMOYO: Fix unused kernel config option.
Smack: fix: invalid length set for the result of /smack/access
Smack: compilation fix
Smack: fix for /smack/access output, use string instead of byte
Smack: domain transition protections (v3)
Smack: Provide information for UDS getsockopt(SO_PEERCRED)
Smack: Clean up comments
Smack: Repair processing of fcntl
Smack: Rule list lookup performance
Smack: check permissions from user space (v2)
TOMOYO: Fix quota and garbage collector.
TOMOYO: Remove redundant tasklist_lock.
TOMOYO: Fix domain transition failure warning.
TOMOYO: Remove tomoyo_policy_memory_lock spinlock.
TOMOYO: Simplify garbage collector.
TOMOYO: Fix make namespacecheck warnings.
target: check hex2bin result
encrypted-keys: check hex2bin result
Commit f23571e8 "TOMOYO: Copy directly to userspace buffer." introduced
tomoyo_flush() that flushes data to be read as soon as possible.
tomoyo_select_domain() (which is called by write()) enqueues data which meant
to be read by next read(), but previous read()'s read buffer's size was not
cleared. As a result, since 2.6.36, sequence like
char *cp = "select global-pid=1\n";
read(fd, buf1, sizeof(buf1));
write(fd, cp, strlen(cp));
read(fd, buf2, sizeof(buf2));
causes enqueued data to be flushed to buf1 rather than buf2.
Fix this bug by clearing read buffer's size upon write() request.
Allow query access as a normal user removing the need
for CAP_MAC_ADMIN. Give RW access to /smack/access
for UGO. Do not import smack labels in access check.
Signed-off-by: Jarkko Sakkinen <jarkko.j.sakkinen@gmail.com>
Signed-off-by: Casey Schaufler <cschaufler@cschaufler-intel.(none)>
CONFIG_SECURITY_TOMOYO_MAX_{ACCEPT_ENTRY,AUDIT_LOG} introduced by commit
0e4ae0e0 "TOMOYO: Make several options configurable." were by error not used.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
The Bluetooth stack has internal connection handlers for all of the various
Bluetooth protocols, and unfortunately, they are currently lacking the LSM
hooks found in the core network stack's connection handlers. I say
unfortunately, because this can cause problems for users who have have an
LSM enabled and are using certain Bluetooth devices. See one problem
report below:
* http://bugzilla.redhat.com/show_bug.cgi?id=741703
In order to keep things simple at this point in time, this patch fixes the
problem by cloning the parent socket's LSM attributes to the newly created
child socket. If we decide we need a more elaborate LSM marking mechanism
for Bluetooth (I somewhat doubt this) we can always revisit this decision
in the future.
Reported-by: James M. Cape <jcape@ignore-your.tv>
Forgot to update simple_transaction_set() to take terminator
character into account.
