[ Upstream commit 747cadeb108665b0474624a374aa9e13f12c9274 ]
commit 4351c294b8c1028077280f761e158d167b592974 upstream.
The current "mask" policy option matches files opened as MAY_READ,
MAY_WRITE, MAY_APPEND or MAY_EXEC. This patch extends the "mask"
option to match files opened containing one of these modes. For
example, "mask=^MAY_READ" would match files opened read-write.
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org>
[ Upstream commit 139069eff7388407f19794384c42a534d618ccd7 ]
The new "euid" policy condition measures files with the specified
effective uid (euid). In addition, for CAP_SETUID files it measures
files with the specified uid or suid.
Changelog:
- fixed checkpatch.pl warnings
- fixed avc denied {setuid} messages - based on Roberto's feedback
Cc: stable@vger.kernel.org
[ Upstream commit 5101a1850bb7ccbf107929dee9af0cd2f400940f ]
To prevent offline stripping of existing file xattrs and relabeling of
them at runtime, EVM allows only newly created files to be labeled. As
pseudo filesystems are not persistent, stripping of xattrs is not a
concern.
Some LSMs defer file labeling on pseudo filesystems. This patch
permits the labeling of existing files on pseudo files systems.
[ Upstream commit HEAD ]
commit ca4da5dd1f99fe9c59f1709fb43e818b18ad20e0 upstream.
__key_link_end is not freeing the associated array edit structure
and this leads to a 512 byte memory leak each time an identical
existing key is added with add_key().
The reason the add_key() system call returns okay is that
key_create_or_update() calls __key_link_begin() before checking to see
whether it can update a key directly rather than adding/replacing - which
it turns out it can. Thus __key_link() is not called through
__key_instantiate_and_link() and __key_link_end() must cancel the edit.
CVE-2015-1333
Signed-off-by: James Morris <james.l.morris@oracle.com>
(cherry picked from commit c9cd9b18dac801040ada16562dc579d5ac366d75)
[ Upstream commit 9fc2b4b436cff7d8403034676014f1be9d534942 ]
Before calling into the filesystem, vfs_setxattr calls
security_inode_setxattr, which ends up calling selinux_inode_setxattr in
our case. That returns -EOPNOTSUPP whenever SBLABEL_MNT is not set.
SBLABEL_MNT was supposed to be set by sb_finish_set_opts, which sets it
only if selinux_is_sblabel_mnt returns true.
The selinux_is_sblabel_mnt logic was broken by eadcabc697e9 "SELinux: do
all flags twiddling in one place", which didn't take into the account
the SECURITY_FS_USE_NATIVE behavior that had been introduced for nfs
with eb9ae686507b "SELinux: Add new labeling type native labels".
This caused setxattr's of security labels over NFSv4.2 to fail.
Cc: stable@kernel.org # 3.13
Cc: Eric Paris <eparis@redhat.com>
Cc: David Quigley <dpquigl@davequigley.com>
Reported-by: Richard Chan <rc556677@outlook.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
[PM: added the stable dependency]
Signed-off-by: Paul Moore <pmoore@redhat.com>
[ Upstream commit 45b26133b97871896b8c5241d59f4ff7839db7b2 ]
This patch fixes a bug introduced in "4d7aeee ima: define new template
ima-ng and template fields d-ng and n-ng".
Changelog:
- change int to uint32 (Roberto Sassu's suggestion)
Signed-off-by: Roberto Sassu <rsassu@suse.de>
Cc: stable@vger.kernel.org # 3.13
[ Upstream commit bd2cba07381a6dba60bc1c87ed8b37931d244da1 ]
This command is missing.
Fixes: 3a2dfbe8acb1 ("xfrm: Notify changes in UDP encapsulation via netlink")
CC: Martin Willi <martin@strongswan.org>
Reported-by: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit 8d465bb777179c4bea731b828ec484088cc9fbc1 ]
Fixes: 5c79de6e79cd ("[XFRM]: User interface for handling XFRM_MSG_MIGRATE")
[ Upstream commit b0b59b0056acd6f157a04cc895f7e24692fb08aa ]
Fixes: 97a64b4577ae ("[XFRM]: Introduce XFRM_MSG_REPORT.")
[ Upstream commit 5b5800fad072133e4a9c2efbf735baaac83dec86 ]
These commands are missing.
Fixes: 28d8909bc790 ("[XFRM]: Export SAD info.")
[ Upstream commit 5e6deebafb45fb271ae6939d48832e920b8fb74e ]
Fixes: ecfd6b183780 ("[XFRM]: Export SPD info")
[ Upstream commit 2b7834d3e1b828429faa5dc41a480919e52d3f31 ]
This new command is missing.
Fixes: 880a6fab8f6b ("xfrm: configure policy hash table thresholds by netlink")
Reported-by: Christophe Gouault <christophe.gouault@6wind.com>
[ Upstream commit 6436a123a147db51a0b06024a8350f4c230e73ff ]
Return a negative error value like the rest of the entries in this function.
Cc: <stable@vger.kernel.org>
[PM: tweaked subject line]
commit 6d1cff2a885850b78b40c34777b46cf5da5d1050 upstream.
We hit use after free on dereferncing pointer to task_smack struct in
smk_of_task() called from smack_task_to_inode().
task_security() macro uses task_cred_xxx() to get pointer to the task_smack.
task_cred_xxx() could be used only for non-pointer members of task's
credentials. It cannot be used for pointer members since what they point
to may disapper after dropping RCU read lock.
Mainly task_security() used this way:
smk_of_task(task_security(p))
Intead of this introduce function smk_of_task_struct() which
takes task_struct as argument and returns pointer to smk_known struct
and do this under RCU read lock.
Bogus task_security() macro is not used anymore, so remove it.
KASan's report for this:
AddressSanitizer: use after free in smack_task_to_inode+0x50/0x70 at addr c4635600
BUG kmalloc-64 (Tainted: PO): kasan error
Disabling lock debugging due to kernel taint
INFO: Allocated in new_task_smack+0x44/0xd8 age=39 cpu=0 pid=1866
kmem_cache_alloc_trace+0x88/0x1bc
smack_cred_prepare+0x48/0x21c
security_prepare_creds+0x44/0x4c
prepare_creds+0xdc/0x110
smack_setprocattr+0x104/0x150
security_setprocattr+0x4c/0x54
proc_pid_attr_write+0x12c/0x194
vfs_write+0x1b0/0x370
SyS_write+0x5c/0x94
ret_fast_syscall+0x0/0x48
INFO: Freed in smack_cred_free+0xc4/0xd0 age=27 cpu=0 pid=1564
kfree+0x270/0x290
security_cred_free+0x34/0x3c
put_cred_rcu+0x58/0xcc
rcu_process_callbacks+0x738/0x998
__do_softirq+0x264/0x4cc
do_softirq+0x94/0xf4
irq_exit+0xbc/0x120
handle_IRQ+0x104/0x134
gic_handle_irq+0x70/0xac
__irq_svc+0x44/0x78
_raw_spin_unlock+0x18/0x48
sync_inodes_sb+0x17c/0x1d8
sync_filesystem+0xac/0xfc
vdfs_file_fsync+0x90/0xc0
vfs_fsync_range+0x74/0x7c
INFO: Slab 0xd3b23f50 objects=32 used=31 fp=0xc4635600 flags=0x4080
INFO: Object 0xc4635600 @offset=5632 fp=0x (null)
Bytes b4 c46355f0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ
Object c4635600: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object c4635610: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object c4635620: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object c4635630: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5 kkkkkkkkkkkkkkk.
Redzone c4635640: bb bb bb bb ....
Padding c46356e8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ
Padding c46356f8: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ
CPU: 5 PID: 834 Comm: launchpad_prelo Tainted: PBO 3.10.30 #1
Backtrace:
[<c00233a4>] (dump_backtrace+0x0/0x158) from [<c0023dec>] (show_stack+0x20/0x24)
r7:c4634010 r6:d3b23f50 r5:c4635600 r4:d1002140
[<c0023dcc>] (show_stack+0x0/0x24) from [<c06d6d7c>] (dump_stack+0x20/0x28)
[<c06d6d5c>] (dump_stack+0x0/0x28) from [<c01c1d50>] (print_trailer+0x124/0x144)
[<c01c1c2c>] (print_trailer+0x0/0x144) from [<c01c1e88>] (object_err+0x3c/0x44)
r7:c4635600 r6:d1002140 r5:d3b23f50 r4:c4635600
[<c01c1e4c>] (object_err+0x0/0x44) from [<c01cac18>] (kasan_report_error+0x2b8/0x538)
r6:d1002140 r5:d3b23f50 r4:c6429cf8 r3:c09e1aa7
[<c01ca960>] (kasan_report_error+0x0/0x538) from [<c01c9430>] (__asan_load4+0xd4/0xf8)
[<c01c935c>] (__asan_load4+0x0/0xf8) from [<c031e168>] (smack_task_to_inode+0x50/0x70)
r5:c4635600 r4:ca9da000
[<c031e118>] (smack_task_to_inode+0x0/0x70) from [<c031af64>] (security_task_to_inode+0x3c/0x44)
r5:cca25e80 r4:c0ba9780
[<c031af28>] (security_task_to_inode+0x0/0x44) from [<c023d614>] (pid_revalidate+0x124/0x178)
r6:00000000 r5:cca25e80 r4:cbabe3c0 r3:00008124
[<c023d4f0>] (pid_revalidate+0x0/0x178) from [<c01db98c>] (lookup_fast+0x35c/0x43y4)
r9:c6429efc r8:00000101 r7:c079d940 r6:c6429e90 r5:c6429ed8 r4:c83c4148
[<c01db630>] (lookup_fast+0x0/0x434) from [<c01deec8>] (do_last.isra.24+0x1c0/0x1108)
[<c01ded08>] (do_last.isra.24+0x0/0x1108) from [<c01dff04>] (path_openat.isra.25+0xf4/0x648)
[<c01dfe10>] (path_openat.isra.25+0x0/0x648) from [<c01e1458>] (do_filp_open+0x3c/0x88)
[<c01e141c>] (do_filp_open+0x0/0x88) from [<c01ccb28>] (do_sys_open+0xf0/0x198)
r7:00000001 r6:c0ea2180 r5:0000000b r4:00000000
[<c01cca38>] (do_sys_open+0x0/0x198) from [<c01ccc00>] (SyS_open+0x30/0x34)
[<c01ccbd0>] (SyS_open+0x0/0x34) from [<c001db80>] (ret_fast_syscall+0x0/0x48)
Read of size 4 by thread T834:
Memory state around the buggy address:
c4635380: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
c4635400: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc
c4635480: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
c4635500: 00 00 00 00 00 fc fc fc fc fc fc fc fc fc fc fc
c4635580: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>c4635600: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
c4635680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
c4635700: 00 00 00 00 04 fc fc fc fc fc fc fc fc fc fc fc
c4635780: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
c4635800: 00 00 00 00 00 00 04 fc fc fc fc fc fc fc fc fc
c4635880: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
commit a3a8784454692dd72e5d5d34dcdab17b4420e74c upstream.
When a key is being garbage collected, it's key->user would get put before
the ->destroy() callback is called, where the key is removed from it's
respective tracking structures.
This leaves a key hanging in a semi-invalid state which leaves a window open
for a different task to try an access key->user. An example is
find_keyring_by_name() which would dereference key->user for a key that is
in the process of being garbage collected (where key->user was freed but
->destroy() wasn't called yet - so it's still present in the linked list).
This would cause either a panic, or corrupt memory.
Fixes CVE-2014-9529.
commit b26bdde5bb27f3f900e25a95e33a0c476c8c2c48 upstream.
When loading encrypted-keys module, if the last check of
aes_get_sizes() in init_encrypted() fails, the driver just returns an
error without unregistering its key type. This results in the stale
entry in the list. In addition to memory leaks, this leads to a kernel
crash when registering a new key type later.
This patch fixes the problem by swapping the calls of aes_get_sizes()
and register_key_type(), and releasing resources properly at the error
paths.
Bugzilla: https://bugzilla.opensuse.org/show_bug.cgi?id=908163
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
Since the keyring facility can be viewed as a cache (at least in some
applications), the local expiration time on the key should probably be viewed
as a 'needs updating after this time' property rather than an absolute 'anyone
now wanting to use this object is out of luck' property.
Since request_key() is the main interface for the usage of keys, this should
update or replace an expired key rather than issuing EKEYEXPIRED if the local
expiration has been reached (ie. it should refresh the cache).
For absolute conditions where refreshing the cache probably doesn't help, the
key can be negatively instantiated using KEYCTL_REJECT_KEY with EKEYEXPIRED
given as the error to issue. This will still cause request_key() to return
EKEYEXPIRED as that was explicitly set.
In the future, if the key type has an update op available, we might want to
upcall with the expired key and allow the upcall to update it. We would pass
a different operation name (the first column in /etc/request-key.conf) to the
request-key program.
request_key() returning EKEYEXPIRED is causing an NFS problem which Chuck
Lever describes thusly:
After about 10 minutes, my NFSv4 functional tests fail because the
ownership of the test files goes to "-2". Looking at /proc/keys
shows that the id_resolv keys that map to my test user ID have
expired. The ownership problem persists until the expired keys are
purged from the keyring, and fresh keys are obtained.
I bisected the problem to 3.13 commit b2a4df200d57 ("KEYS: Expand
the capacity of a keyring"). This commit inadvertantly changes the
API contract of the internal function keyring_search_aux().
The root cause appears to be that b2a4df200d57 made "no state check"
the default behavior. "No state check" means the keyring search
iterator function skips checking the key's expiry timeout, and
returns expired keys. request_key_and_link() depends on getting
an -EAGAIN result code to know when to perform an upcall to refresh
an expired key.
This patch can be tested directly by:
keyctl request2 user debug:fred a @s
keyctl timeout %user:debug:fred 3
sleep 4
Without the patch, the last command gives error EKEYEXPIRED, but with the
command it gives a new key.
Reported-by: Carl Hetherington <cth@carlh.net>
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Chuck Lever <chuck.lever@oracle.com>
Simplify KEYRING_SEARCH_{NO,DO}_STATE_CHECK flags to be two variations of the
same flag. They are effectively mutually exclusive and one or the other
should be provided, but not both.
Keyring cycle detection and key possession determination are the only things
that set NO_STATE_CHECK, except that neither flag really does anything there
because neither purpose makes use of the keyring_search_iterator() function,
but rather provides their own.
For cycle detection we definitely want to check inside of expired keyrings,
just so that we don't create a cycle we can't get rid of. Revoked keyrings
are cleared at revocation time and can't then be reused, so shouldn't be a
problem either way.
For possession determination, we *might* want to validate each keyring before
searching it: do you possess a key that's hidden behind an expired or just
plain inaccessible keyring? Currently, the answer is yes. Note that you
cannot, however, possess a key behind a revoked keyring because they are
cleared on revocation.
keyring_search() sets DO_STATE_CHECK, which is correct.
request_key_and_link() currently doesn't specify whether to check the key
state or not - but it should set DO_STATE_CHECK.
key_get_instantiation_authkey() also currently doesn't specify whether to
check the key state or not - but it probably should also set DO_STATE_CHECK.
When a key description argument is imported into the kernel from userspace, as
happens in add_key(), request_key(), KEYCTL_JOIN_SESSION_KEYRING,
KEYCTL_SEARCH, the description is copied into a buffer up to PAGE_SIZE in size.
PAGE_SIZE, however, is a variable quantity, depending on the arch. Fix this at
4096 instead (ie. 4095 plus a NUL termination) and define a constant
(KEY_MAX_DESC_SIZE) to this end.
When reading the description back with KEYCTL_DESCRIBE, a PAGE_SIZE internal
buffer is allocated into which the information and description will be
rendered. This means that the description will get truncated if an extremely
long description it has to be crammed into the buffer with the stringified
information. There is no particular need to copy the description into the
buffer, so just copy it directly to userspace in a separate operation.
Reported-by: Christian Kastner <debian@kvr.at>
Tested-by: Christian Kastner <debian@kvr.at>
into for-linus
Convert WARN_ONCE() to printk() in selinux_nlmsg_perm().
After conversion from audit_log() in commit e173fb26, WARN_ONCE() was
deemed too alarmist, so switch it to printk().
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
[PM: Changed to printk(WARNING) so we catch all of the different
invalid netlink messages. In Richard's defense, he brought this
point up earlier, but I didn't understand his point at the time.]
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into for-linus
evm_inode_setxattr() can be called with no value. The function does not
check the length so that following command can be used to produce the
kernel oops: setfattr -n security.evm FOO. This patch fixes it.
Changes in v3:
* there is no reason to return different error codes for EVM_XATTR_HMAC
and non EVM_XATTR_HMAC. Remove unnecessary test then.
Changes in v2:
* testing for validity of xattr type
[ 1106.396921] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1106.398192] IP: [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.399244] PGD 29048067 PUD 290d7067 PMD 0
[ 1106.399953] Oops: 0000 [#1] SMP
[ 1106.400020] Modules linked in: bridge stp llc evdev serio_raw i2c_piix4 button fuse
[ 1106.400020] CPU: 0 PID: 3635 Comm: setxattr Not tainted 3.16.0-kds+ #2936
[ 1106.400020] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 1106.400020] task: ffff8800291a0000 ti: ffff88002917c000 task.ti: ffff88002917c000
[ 1106.400020] RIP: 0010:[<ffffffff812af7b8>] [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.400020] RSP: 0018:ffff88002917fd50 EFLAGS: 00010246
[ 1106.400020] RAX: 0000000000000000 RBX: ffff88002917fdf8 RCX: 0000000000000000
[ 1106.400020] RDX: 0000000000000000 RSI: ffffffff818136d3 RDI: ffff88002917fdf8
[ 1106.400020] RBP: ffff88002917fd68 R08: 0000000000000000 R09: 00000000003ec1df
[ 1106.400020] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8800438a0a00
[ 1106.400020] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 1106.400020] FS: 00007f7dfa7d7740(0000) GS:ffff88005da00000(0000) knlGS:0000000000000000
[ 1106.400020] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1106.400020] CR2: 0000000000000000 CR3: 000000003763e000 CR4: 00000000000006f0
[ 1106.400020] Stack:
[ 1106.400020] ffff8800438a0a00 ffff88002917fdf8 0000000000000000 ffff88002917fd98
[ 1106.400020] ffffffff812a1030 ffff8800438a0a00 ffff88002917fdf8 0000000000000000
[ 1106.400020] 0000000000000000 ffff88002917fde0 ffffffff8116d08a ffff88002917fdc8
[ 1106.400020] Call Trace:
[ 1106.400020] [<ffffffff812a1030>] security_inode_setxattr+0x5d/0x6a
[ 1106.400020] [<ffffffff8116d08a>] vfs_setxattr+0x6b/0x9f
[ 1106.400020] [<ffffffff8116d1e0>] setxattr+0x122/0x16c
[ 1106.400020] [<ffffffff811687e8>] ? mnt_want_write+0x21/0x45
[ 1106.400020] [<ffffffff8114d011>] ? __sb_start_write+0x10f/0x143
[ 1106.400020] [<ffffffff811687c0>] ? __mnt_want_write+0x48/0x4f
[ 1106.400020] [<ffffffff8116d3e6>] SyS_setxattr+0x6e/0xb0
[ 1106.400020] [<ffffffff81529da9>] system_call_fastpath+0x16/0x1b
[ 1106.400020] Code: c3 0f 1f 44 00 00 55 48 89 e5 41 55 49 89 d5 41 54 49 89 fc 53 48 89 f3 48 c7 c6 d3 36 81 81 48 89 df e8 18 22 04 00 85 c0 75 07 <41> 80 7d 00 02 74 0d 48 89 de 4c 89 e7 e8 5a fe ff ff eb 03 83
[ 1106.400020] RIP [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.400020] RSP <ffff88002917fd50>
[ 1106.428061] ---[ end trace ae08331628ba3050 ]---
Reported-by: Jan Kara <jack@suse.cz>
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
ima_inode_setxattr() can be called with no value. Function does not
kernel oops: setfattr -n security.ima FOO. This patch fixes it.
Changes in v3:
* for stable reverted "allow setting hash only in fix or log mode"
It will be a separate patch.
Changes in v2:
* testing validity of xattr type
* allow setting hash only in fix or log mode (Mimi)
[ 261.562522] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 261.564109] IP: [<ffffffff812af272>] ima_inode_setxattr+0x3e/0x5a
[ 261.564109] PGD 3112f067 PUD 42965067 PMD 0
[ 261.564109] Oops: 0000 [#1] SMP
[ 261.564109] Modules linked in: bridge stp llc evdev serio_raw i2c_piix4 button fuse
[ 261.564109] CPU: 0 PID: 3299 Comm: setxattr Not tainted 3.16.0-kds+ #2924
[ 261.564109] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 261.564109] task: ffff8800428c2430 ti: ffff880042be0000 task.ti: ffff880042be0000
[ 261.564109] RIP: 0010:[<ffffffff812af272>] [<ffffffff812af272>] ima_inode_setxattr+0x3e/0x5a
[ 261.564109] RSP: 0018:ffff880042be3d50 EFLAGS: 00010246
[ 261.564109] RAX: 0000000000000001 RBX: 0000000000000000 RCX: 0000000000000015
[ 261.564109] RDX: 0000001500000000 RSI: 0000000000000000 RDI: ffff8800375cc600
[ 261.564109] RBP: ffff880042be3d68 R08: 0000000000000000 R09: 00000000004d6256
[ 261.564109] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88002149ba00
[ 261.564109] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 261.564109] FS: 00007f6c1e219740(0000) GS:ffff88005da00000(0000) knlGS:0000000000000000
[ 261.564109] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 261.564109] CR2: 0000000000000000 CR3: 000000003b35a000 CR4: 00000000000006f0
[ 261.564109] Stack:
[ 261.564109] ffff88002149ba00 ffff880042be3df8 0000000000000000 ffff880042be3d98
[ 261.564109] ffffffff812a101b ffff88002149ba00 ffff880042be3df8 0000000000000000
[ 261.564109] 0000000000000000 ffff880042be3de0 ffffffff8116d08a ffff880042be3dc8
[ 261.564109] Call Trace:
[ 261.564109] [<ffffffff812a101b>] security_inode_setxattr+0x48/0x6a
[ 261.564109] [<ffffffff8116d08a>] vfs_setxattr+0x6b/0x9f
[ 261.564109] [<ffffffff8116d1e0>] setxattr+0x122/0x16c
[ 261.564109] [<ffffffff811687e8>] ? mnt_want_write+0x21/0x45
[ 261.564109] [<ffffffff8114d011>] ? __sb_start_write+0x10f/0x143
[ 261.564109] [<ffffffff811687c0>] ? __mnt_want_write+0x48/0x4f
[ 261.564109] [<ffffffff8116d3e6>] SyS_setxattr+0x6e/0xb0
[ 261.564109] [<ffffffff81529da9>] system_call_fastpath+0x16/0x1b
[ 261.564109] Code: 48 89 f7 48 c7 c6 58 36 81 81 53 31 db e8 73 27 04 00 85 c0 75 28 bf 15 00 00 00 e8 8a a5 d9 ff 84 c0 75 05 83 cb ff eb 15 31 f6 <41> 80 7d 00 03 49 8b 7c 24 68 40 0f 94 c6 e8 e1 f9 ff ff 89 d8
[ 261.564109] RIP [<ffffffff812af272>] ima_inode_setxattr+0x3e/0x5a
[ 261.564109] RSP <ffff880042be3d50>
[ 261.599998] ---[ end trace 39a89a3fc267e652 ]---
into for-linus2
sb_finish_set_opts() can race with inode_free_security()
when initializing inode security structures for inodes
created prior to initial policy load or by the filesystem
during ->mount(). This appears to have always been
a possible race, but commit 3dc91d4 ("SELinux: Fix possible
NULL pointer dereference in selinux_inode_permission()")
made it more evident by immediately reusing the unioned
list/rcu element of the inode security structure for call_rcu()
upon an inode_free_security(). But the underlying issue
was already present before that commit as a possible use-after-free
of isec.
Shivnandan Kumar reported the list corruption and proposed
a patch to split the list and rcu elements out of the union
as separate fields of the inode_security_struct so that setting
the rcu element would not affect the list element. However,
this would merely hide the issue and not truly fix the code.
This patch instead moves up the deletion of the list entry
prior to dropping the sbsec->isec_lock initially. Then,
if the inode is dropped subsequently, there will be no further
references to the isec.
Reported-by: Shivnandan Kumar <shivnandan.k@samsung.com>
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Replaced the use of a Variable Length Array In Struct (VLAIS) with a C99
compliant equivalent. This patch allocates the appropriate amount of memory
using a char array using the SHASH_DESC_ON_STACK macro.
The new code can be compiled with both gcc and clang.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Reviewed-by: Mark Charlebois <charlebm@gmail.com>
Reviewed-by: Jan-Simon Möller <dl9pf@gmx.de>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Cc: tglx@linutronix.de
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris.
Mostly ima, selinux, smack and key handling updates.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits)
integrity: do zero padding of the key id
KEYS: output last portion of fingerprint in /proc/keys
KEYS: strip 'id:' from ca_keyid
KEYS: use swapped SKID for performing partial matching
KEYS: Restore partial ID matching functionality for asymmetric keys
X.509: If available, use the raw subjKeyId to form the key description
KEYS: handle error code encoded in pointer
selinux: normalize audit log formatting
selinux: cleanup error reporting in selinux_nlmsg_perm()
KEYS: Check hex2bin()'s return when generating an asymmetric key ID
ima: detect violations for mmaped files
ima: fix race condition on ima_rdwr_violation_check and process_measurement
ima: added ima_policy_flag variable
ima: return an error code from ima_add_boot_aggregate()
ima: provide 'ima_appraise=log' kernel option
ima: move keyring initialization to ima_init()
PKCS#7: Handle PKCS#7 messages that contain no X.509 certs
PKCS#7: Better handling of unsupported crypto
KEYS: Overhaul key identification when searching for asymmetric keys
KEYS: Implement binary asymmetric key ID handling
Pull file locking related changes from Jeff Layton:
"This release is a little more busy for file locking changes than the
last:
- a set of patches from Kinglong Mee to fix the lockowner handling in
knfsd
- a pile of cleanups to the internal file lease API. This should get
us a bit closer to allowing for setlease methods that can block.
There are some dependencies between mine and Bruce's trees this cycle,
and I based my tree on top of the requisite patches in Bruce's tree"
* tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linux: (26 commits)
locks: fix fcntl_setlease/getlease return when !CONFIG_FILE_LOCKING
locks: flock_make_lock should return a struct file_lock (or PTR_ERR)
locks: set fl_owner for leases to filp instead of current->files
locks: give lm_break a return value
locks: __break_lease cleanup in preparation of allowing direct removal of leases
locks: remove i_have_this_lease check from __break_lease
locks: move freeing of leases outside of i_lock
locks: move i_lock acquisition into generic_*_lease handlers
locks: define a lm_setup handler for leases
locks: plumb a "priv" pointer into the setlease routines
nfsd: don't keep a pointer to the lease in nfs4_file
locks: clean up vfs_setlease kerneldoc comments
locks: generic_delete_lease doesn't need a file_lock at all
nfsd: fix potential lease memory leak in nfs4_setlease
locks: close potential race in lease_get_mtime
security: make security_file_set_fowner, f_setown and __f_setown void return
locks: consolidate "nolease" routines
locks: remove lock_may_read and lock_may_write
lockd: rip out deferred lock handling from testlock codepath
NFSD: Get reference of lockowner when coping file_lock
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"Nothing major: support for compressing modules, and auto-tainting
params.
PS. My virtio-next tree is empty: DaveM took the patches I had. There
might be a virtio-rng starvation fix, but so far it's a bit voodoo
so I will get to that in the next two days or it will wait"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
moduleparam: Resolve missing-field-initializer warning
kbuild: handle module compression while running 'make modules_install'.
modinst: wrap long lines in order to enhance cmd_modules_install
modsign: lookup lines ending in .ko in .mod files
modpost: simplify file name generation of *.mod.c files
modpost: reduce visibility of symbols and constify r/o arrays
param: check for tainting before calling set op.
drm/i915: taint the kernel if unsafe module parameters are set
module: add module_param_unsafe and module_param_named_unsafe
module: make it possible to have unsafe, tainting module params
module: rename KERNEL_PARAM_FL_NOARG to avoid confusion
Latest KEYS code return error if hexadecimal string length id odd.
Fix it.
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into next
Restructure to keyword=value pairs without spaces. Drop superfluous words in
text. Make invalid_context a keyword. Change result= keyword to seresult=.
[Minor rewrite to the patch subject line]
Convert audit_log() call to WARN_ONCE().
Rename "type=" to nlmsg_type=" to avoid confusion with the audit record
type.
Added "protocol=" to help track down which protocol (NETLINK_AUDIT?) was used
within the netlink protocol family.
[Rewrote the patch subject line]
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into next
This patch fixes the detection of the 'open_writers' violation for mmaped
files.
before) an 'open_writers' violation is detected if the policy contains
a rule with the criteria: func=FILE_CHECK mask=MAY_READ
after) an 'open_writers' violation is detected if the current event
matches one of the policy rules.
With the old behaviour, the 'open_writers' violation is not detected
in the following case:
policy:
measure func=FILE_MMAP mask=MAY_EXEC
steps:
1) open a shared library for writing
2) execute a binary that links that shared library
3) during the binary execution, modify the shared library and save
the change
result:
the 'open_writers' violation measurement is not present in the IMA list.
Only binaries executed are protected from writes. For libraries mapped
in memory there is the flag MAP_DENYWRITE for this purpose, but according
to the output of 'man mmap', the mmap flag is ignored.
Since ima_rdwr_violation_check() is now called by process_measurement()
the information about if the inode must be measured is already provided
by ima_get_action(). Thus the unnecessary function ima_must_measure()
has been removed.
Changes in v3 (Dmitry Kasatkin):
- Violation for MMAP_CHECK function are verified since this patch
- Changed patch description a bit
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
This patch fixes a race condition between two functions that try to access
the same inode. Since the i_mutex lock is held and released separately
in the two functions, there may be the possibility that a violation is
not correctly detected.
Suppose there are two processes, A (reader) and B (writer), if the
following sequence happens:
A: ima_rdwr_violation_check()
B: ima_rdwr_violation_check()
B: process_measurement()
B: starts writing the inode
A: process_measurement()
the ToMToU violation (a reader may be accessing a content different from
that measured, due to a concurrent modification by a writer) will not be
detected. To avoid this issue, the violation check and the measurement
must be done atomically.
This patch fixes the problem by moving the violation check inside
process_measurement() when the i_mutex lock is held. Differently from
the old code, the violation check is executed also for the MMAP_CHECK
hook (other than for FILE_CHECK). This allows to detect ToMToU violations
that are possible because shared libraries can be opened for writing
while they are in use (according to the output of 'man mmap', the mmap()
flag MAP_DENYWRITE is ignored).
Changes in v5 (Roberto Sassu):
* get iint if action is not zero
* exit process_measurement() after the violation check if action is zero
* reverse order process_measurement() exit cleanup (Mimi)
Changes in v4 (Dmitry Kasatkin):
* iint allocation is done before calling ima_rdrw_violation_check()
(Suggested-by Mimi)
* do not check for violations if the policy does not contain 'measure'
rules (done by Roberto Sassu)
* no violation checking for MMAP_CHECK function in this patch
* remove use of filename from violation
* removes checking if ima is enabled from ima_rdrw_violation_check
* slight style change
Suggested-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
into next
This patch introduces the new variable 'ima_policy_flag', whose bits
are set depending on the action of the current policy rules. Only the
flags IMA_MEASURE, IMA_APPRAISE and IMA_AUDIT are set.
The new variable will be used to improve performance by skipping the
unnecessary execution of IMA code if the policy does not contain rules
with the above actions.
Changes in v6 (Roberto Sassu)
* do not check 'ima_initialized' before calling ima_update_policy_flag()
in ima_update_policy() (suggested by Dmitry)
* calling ima_update_policy_flag() moved to init_ima to co-locate with
ima_initialized (Dmitry)
* add/revise comments (Mimi)
* reset IMA_APPRAISE flag in 'ima_policy_flag' if 'ima_appraise' is set
to zero (reported by Dmitry)
* update 'ima_policy_flag' only if IMA initialization is successful
(suggested by Mimi and Dmitry)
* check 'ima_policy_flag' instead of 'ima_initialized'
This patch modifies ima_add_boot_aggregate() to return an error code.
This way we can determine if all the initialization procedures have
been executed successfully.
The kernel boot parameter "ima_appraise" currently defines 'off',
'enforce' and 'fix' modes. When designing a policy and labeling
the system, access to files are either blocked in the default
'enforce' mode or automatically fixed in the 'fix' mode. It is
beneficial to be able to run the system in a logging only mode,
without fixing it, in order to properly analyze the system. This
patch adds a 'log' mode to run the system in a permissive mode and
log the appraisal results.
ima_init() is used as a single place for all initializations.
Experimental keyring patches used the 'late_initcall' which was
co-located with the late_initcall(init_ima). When the late_initcall
for the keyring initialization was abandoned, initialization moved
to init_ima, though it would be more logical to move it to ima_init,
where the rest of the initialization is done. This patch moves the
keyring initialization to ima_init() as a preparatory step for
loading the keys which will be added to ima_init() in following
patches.
Make the key matching functions pointed to by key_match_data::cmp return bool
rather than int.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
A previous patch added a ->match_preparse() method to the key type. This is
allowed to override the function called by the iteration algorithm.
Therefore, we can just set a default that simply checks for an exact match of
the key description with the original criterion data and allow match_preparse
to override it as needed.
The key_type::match op is then redundant and can be removed, as can the
user_match() function.
Remove key_type::def_lookup_type as it's no longer used. The information now
defaults to KEYRING_SEARCH_LOOKUP_DIRECT but may be overridden by
type->match_preparse().
Preparse the match data. This provides several advantages:
(1) The preparser can reject invalid criteria up front.
(2) The preparser can convert the criteria to binary data if necessary (the
asymmetric key type really wants to do binary comparison of the key IDs).
(3) The preparser can set the type of search to be performed. This means
that it's not then a one-off setting in the key type.
(4) The preparser can set an appropriate comparator function.
Merge in keyrings fixes for next:
(1) Insert some missing 'static' annotations.
