path: root/security
2015-08-04Adding YAMA hooks also when YAMA is not stacked.Salvatore Mesoraca
Without this patch YAMA will not work at all if it is chosen as the primary LSM instead of being "stacked". Signed-off-by: Salvatore Mesoraca <s.mesoraca16@gmail.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-07-28KEYS: ensure we free the assoc array edit if edit is validColin Ian King
__key_link_end is not freeing the associated array edit structure and this leads to a 512 byte memory leak each time an identical existing key is added with add_key(). The reason the add_key() system call returns okay is that key_create_or_update() calls __key_link_begin() before checking to see whether it can update a key directly rather than adding/replacing - which it turns out it can. Thus __key_link() is not called through __key_instantiate_and_link() and __key_link_end() must cancel the edit. CVE-2015-1333 Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-07-11Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/selinux ↵James Morris
into for-linus2
2015-07-10selinux: fix mprotect PROT_EXEC regression caused by mm changeStephen Smalley
commit 66fc13039422ba7df2d01a8ee0873e4ef965b50b ("mm: shmem_zero_setup skip security check and lockdep conflict with XFS") caused a regression for SELinux by disabling any SELinux checking of mprotect PROT_EXEC on shared anonymous mappings. However, even before that regression, the checking on such mprotect PROT_EXEC calls was inconsistent with the checking on a mmap PROT_EXEC call for a shared anonymous mapping. On a mmap, the security hook is passed a NULL file and knows it is dealing with an anonymous mapping and therefore applies an execmem check and no file checks. On a mprotect, the security hook is passed a vma with a non-NULL vm_file (as this was set from the internally-created shmem file during mmap) and therefore applies the file-based execute check and no execmem check. Since the aforementioned commit now marks the shmem zero inode with the S_PRIVATE flag, the file checks are disabled and we have no checking at all on mprotect PROT_EXEC. Add a test to the mprotect hook logic for such private inodes, and apply an execmem check in that case. This makes the mmap and mprotect checking consistent for shared anonymous mappings, as well as for /dev/zero and ashmem. Cc: <stable@vger.kernel.org> # 4.1.x Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-07-09selinux: don't waste ebitmap space when importing NetLabel categoriesPaul Moore
At present we don't create efficient ebitmaps when importing NetLabel category bitmaps. This can present a problem when comparing ebitmaps since ebitmap_cmp() is very strict about these things and considers these wasteful ebitmaps not equal when compared to their more efficient counterparts, even if their values are the same. This isn't likely to cause problems on 64-bit systems due to a bit of luck on how NetLabel/CIPSO works and the default ebitmap size, but it can be a problem on 32-bit systems. This patch fixes this problem by being a bit more intelligent when importing NetLabel category bitmaps by skipping over empty sections which should result in a nice, efficient ebitmap. Cc: stable@vger.kernel.org # 3.17 Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace updates from Eric Biederman: "Long ago and far away when user namespaces where young it was realized that allowing fresh mounts of proc and sysfs with only user namespace permissions could violate the basic rule that only root gets to decide if proc or sysfs should be mounted at all. Some hacks were put in place to reduce the worst of the damage could be done, and the common sense rule was adopted that fresh mounts of proc and sysfs should allow no more than bind mounts of proc and sysfs. Unfortunately that rule has not been fully enforced. There are two kinds of gaps in that enforcement. Only filesystems mounted on empty directories of proc and sysfs should be ignored but the test for empty directories was insufficient. So in my tree directories on proc, sysctl and sysfs that will always be empty are created specially. Every other technique is imperfect as an ordinary directory can have entries added even after a readdir returns and shows that the directory is empty. Special creation of directories for mount points makes the code in the kernel a smidge clearer about it's purpose. I asked container developers from the various container projects to help test this and no holes were found in the set of mount points on proc and sysfs that are created specially. This set of changes also starts enforcing the mount flags of fresh mounts of proc and sysfs are consistent with the existing mount of proc and sysfs. I expected this to be the boring part of the work but unfortunately unprivileged userspace winds up mounting fresh copies of proc and sysfs with noexec and nosuid clear when root set those flags on the previous mount of proc and sysfs. So for now only the atime, read-only and nodev attributes which userspace happens to keep consistent are enforced. Dealing with the noexec and nosuid attributes remains for another time. This set of changes also addresses an issue with how open file descriptors from /proc/<pid>/ns/* are displayed. Recently readlink of /proc/<pid>/fd has been triggering a WARN_ON that has not been meaningful since it was added (as all of the code in the kernel was converted) and is not now actively wrong. There is also a short list of issues that have not been fixed yet that I will mention briefly. It is possible to rename a directory from below to above a bind mount. At which point any directory pointers below the renamed directory can be walked up to the root directory of the filesystem. With user namespaces enabled a bind mount of the bind mount can be created allowing the user to pick a directory whose children they can rename to outside of the bind mount. This is challenging to fix and doubly so because all obvious solutions must touch code that is in the performance part of pathname resolution. As mentioned above there is also a question of how to ensure that developers by accident or with purpose do not introduce exectuable files on sysfs and proc and in doing so introduce security regressions in the current userspace that will not be immediately obvious and as such are likely to require breaking userspace in painful ways once they are recognized" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: vfs: Remove incorrect debugging WARN in prepend_path mnt: Update fs_fully_visible to test for permanently empty directories sysfs: Create mountpoints with sysfs_create_mount_point sysfs: Add support for permanently empty directories to serve as mount points. kernfs: Add support for always empty directories. proc: Allow creating permanently empty directories that serve as mount points sysctl: Allow creating permanently empty directories that serve as mountpoints. fs: Add helper functions for permanently empty directories. vfs: Ignore unlocked mounts in fs_fully_visible mnt: Modify fs_fully_visible to deal with locked ro nodev and atime mnt: Refactor the logic for mounting sysfs and proc in a user namespace
2015-07-01Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Main excitement here is Peter Zijlstra's lockless rbtree optimization to speed module address lookup. He found some abusers of the module lock doing that too. A little bit of parameter work here too; including Dan Streetman's breaking up the big param mutex so writing a parameter can load another module (yeah, really). Unfortunately that broke the usual suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were appended too" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits) modules: only use mod->param_lock if CONFIG_MODULES param: fix module param locks when !CONFIG_SYSFS. rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE() module: add per-module param_lock module: make perm const params: suppress unused variable error, warn once just in case code changes. modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'. kernel/module.c: avoid ifdefs for sig_enforce declaration kernel/workqueue.c: remove ifdefs over wq_power_efficient kernel/params.c: export param_ops_bool_enable_only kernel/params.c: generalize bool_enable_only kernel/module.c: use generic module param operaters for sig_enforce kernel/params: constify struct kernel_param_ops uses sysfs: tightened sysfs permission checks module: Rework module_addr_{min,max} module: Use __module_address() for module_address_lookup() module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING module: Optimize __module_address() using a latched RB-tree rbtree: Implement generic latch_tree seqlock: Introduce raw_read_seqcount_latch() ...
2015-07-01sysfs: Create mountpoints with sysfs_create_mount_pointEric W. Biederman
This allows for better documentation in the code and it allows for a simpler and fully correct version of fs_fully_visible to be written. The mount points converted and their filesystems are: /sys/hypervisor/s390/ s390_hypfs /sys/kernel/config/ configfs /sys/kernel/debug/ debugfs /sys/firmware/efi/efivars/ efivarfs /sys/fs/fuse/connections/ fusectl /sys/fs/pstore/ pstore /sys/kernel/tracing/ tracefs /sys/fs/cgroup/ cgroup /sys/kernel/security/ securityfs /sys/fs/selinux/ selinuxfs /sys/fs/smackfs/ smackfs Cc: stable@vger.kernel.org Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2015-06-27Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Four small audit patches for v4.2, all bug fixes. Only 10 lines of change this time so very unremarkable, the patch subject lines pretty much tell the whole story" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: Fix check of return value of strnlen_user() audit: obsolete audit_context check is removed in audit_filter_rules() audit: fix for typo in comment to function audit_log_link_denied() lsm: rename duplicate labels in LSM_AUDIT_DATA_TASK audit message type
2015-06-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "The main change in this kernel is Casey's generalized LSM stacking work, which removes the hard-coding of Capabilities and Yama stacking, allowing multiple arbitrary "small" LSMs to be stacked with a default monolithic module (e.g. SELinux, Smack, AppArmor). See https://lwn.net/Articles/636056/ This will allow smaller, simpler LSMs to be incorporated into the mainline kernel and arbitrarily stacked by users. Also, this is a useful cleanup of the LSM code in its own right" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) tpm, tpm_crb: fix le64_to_cpu conversions in crb_acpi_add() vTPM: set virtual device before passing to ibmvtpm_reset_crq tpm_ibmvtpm: remove unneccessary message level. ima: update builtin policies ima: extend "mask" policy matching support ima: add support for new "euid" policy condition ima: fix ima_show_template_data_ascii() Smack: freeing an error pointer in smk_write_revoke_subj() selinux: fix setting of security labels on NFS selinux: Remove unused permission definitions selinux: enable genfscon labeling for sysfs and pstore files selinux: enable per-file labeling for debugfs files. selinux: update netlink socket classes signals: don't abuse __flush_signals() in selinux_bprm_committed_creds() selinux: Print 'sclass' as string when unrecognized netlink message occurs Smack: allow multiple labels in onlycap Smack: fix seq operations in smackfs ima: pass iint to ima_add_violation() ima: wrap event related data to the new ima_event_data structure integrity: add validity checks for 'path' parameter ...
2015-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Add TX fast path in mac80211, from Johannes Berg. 2) Add TSO/GRO support to ibmveth, from Thomas Falcon 3) Move away from cached routes in ipv6, just like ipv4, from Martin KaFai Lau. 4) Lots of new rhashtable tests, from Thomas Graf. 5) Run ingress qdisc lockless, from Alexei Starovoitov. 6) Allow servers to fetch TCP packet headers for SYN packets of new connections, for fingerprinting. From Eric Dumazet. 7) Add mode parameter to pktgen, for testing receive. From Alexei Starovoitov. 8) Cache access optimizations via simplifications of build_skb(), from Alexander Duyck. 9) Move page frag allocator under mm/, also from Alexander. 10) Add xmit_more support to hv_netvsc, from KY Srinivasan. 11) Add a counter guard in case we try to perform endless reclassify loops in the packet scheduler. 12) Extern flow dissector to be programmable and use it in new "Flower" classifier. From Jiri Pirko. 13) AF_PACKET fanout rollover fixes, performance improvements, and new statistics. From Willem de Bruijn. 14) Add netdev driver for GENEVE tunnels, from John W Linville. 15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso. 16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet. 17) Add an ECN retry fallback for the initial TCP handshake, from Daniel Borkmann. 18) Add tail call support to BPF, from Alexei Starovoitov. 19) Add several pktgen helper scripts, from Jesper Dangaard Brouer. 20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa. 21) Favor even port numbers for allocation to connect() requests, and odd port numbers for bind(0), in an effort to help avoid ip_local_port_range exhaustion. From Eric Dumazet. 22) Add Cavium ThunderX driver, from Sunil Goutham. 23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata, from Alexei Starovoitov. 24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai. 25) Double TCP Small Queues default to 256K to accomodate situations like the XEN driver and wireless aggregation. From Wei Liu. 26) Add more entropy inputs to flow dissector, from Tom Herbert. 27) Add CDG congestion control algorithm to TCP, from Kenneth Klette Jonassen. 28) Convert ipset over to RCU locking, from Jozsef Kadlecsik. 29) Track and act upon link status of ipv4 route nexthops, from Andy Gospodarek. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits) bridge: vlan: flush the dynamically learned entries on port vlan delete bridge: multicast: add a comment to br_port_state_selection about blocking state net: inet_diag: export IPV6_V6ONLY sockopt stmmac: troubleshoot unexpected bits in des0 & des1 net: ipv4 sysctl option to ignore routes when nexthop link is down net: track link-status of ipv4 nexthops net: switchdev: ignore unsupported bridge flags net: Cavium: Fix MAC address setting in shutdown state drivers: net: xgene: fix for ACPI support without ACPI ip: report the original address of ICMP messages net/mlx5e: Prefetch skb data on RX net/mlx5e: Pop cq outside mlx5e_get_cqe net/mlx5e: Remove mlx5e_cq.sqrq back-pointer net/mlx5e: Remove extra spaces net/mlx5e: Avoid TX CQE generation if more xmit packets expected net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq() net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device ...
2015-06-23make simple_positive() publicAl Viro
2015-06-18netfilter: Remove spurios included of netfilter.hEric W Biederman
While testing my netfilter changes I noticed several files where recompiling unncessarily because they unncessarily included netfilter.h. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-06-16ima: update builtin policiesMimi Zohar
This patch defines a builtin measurement policy "tcb", similar to the existing "ima_tcb", but with additional rules to also measure files based on the effective uid and to measure files opened with the "read" mode bit set (eg. read, read-write). Changing the builtin "ima_tcb" policy could potentially break existing users. Instead of defining a new separate boot command line option each time the builtin measurement policy is modified, this patch defines a single generic boot command line option "ima_policy=" to specify the builtin policy and deprecates the use of the builtin ima_tcb policy. [The "ima_policy=" boot command line option is based on Roberto Sassu's "ima: added new policy type exec" patch.] Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org> Cc: stable@vger.kernel.org
2015-06-16ima: extend "mask" policy matching supportMimi Zohar
The current "mask" policy option matches files opened as MAY_READ, MAY_WRITE, MAY_APPEND or MAY_EXEC. This patch extends the "mask" option to match files opened containing one of these modes. For example, "mask=^MAY_READ" would match files opened read-write. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org> Cc: stable@vger.kernel.org
2015-06-16ima: add support for new "euid" policy conditionMimi Zohar
The new "euid" policy condition measures files with the specified effective uid (euid). In addition, for CAP_SETUID files it measures files with the specified uid or suid. Changelog: - fixed checkpatch.pl warnings - fixed avc denied {setuid} messages - based on Roberto's feedback Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org> Cc: stable@vger.kernel.org
2015-06-16ima: fix ima_show_template_data_ascii()Mimi Zohar
This patch fixes a bug introduced in "4d7aeee ima: define new template ima-ng and template fields d-ng and n-ng". Changelog: - change int to uint32 (Roberto Sassu's suggestion) Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Roberto Sassu <rsassu@suse.de> Cc: stable@vger.kernel.org # 3.13
2015-06-13Merge branch 'smack-for-4.2-stacked' of ↵James Morris
https://github.com/cschaufler/smack-next into next
2015-06-12Smack: freeing an error pointer in smk_write_revoke_subj()Dan Carpenter
This code used to rely on the fact that kfree(NULL) was a no-op, but then we changed smk_parse_smack() to return error pointers on failure instead of NULL. Calling kfree() on an error pointer will oops. I have re-arranged things a bit so that we only free things if they have been allocated. Fixes: e774ad683f42 ('smack: pass error code through pointers') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com>
2015-06-05selinux: fix setting of security labels on NFSJ. Bruce Fields
Before calling into the filesystem, vfs_setxattr calls security_inode_setxattr, which ends up calling selinux_inode_setxattr in our case. That returns -EOPNOTSUPP whenever SBLABEL_MNT is not set. SBLABEL_MNT was supposed to be set by sb_finish_set_opts, which sets it only if selinux_is_sblabel_mnt returns true. The selinux_is_sblabel_mnt logic was broken by eadcabc697e9 "SELinux: do all flags twiddling in one place", which didn't take into the account the SECURITY_FS_USE_NATIVE behavior that had been introduced for nfs with eb9ae686507b "SELinux: Add new labeling type native labels". This caused setxattr's of security labels over NFSv4.2 to fail. Cc: stable@kernel.org # 3.13 Cc: Eric Paris <eparis@redhat.com> Cc: David Quigley <dpquigl@davequigley.com> Reported-by: Richard Chan <rc556677@outlook.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> [PM: added the stable dependency] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-06-04selinux: Remove unused permission definitionsStephen Smalley
Remove unused permission definitions from SELinux. Many of these were only ever used in pre-mainline versions of SELinux, prior to Linux 2.6.0. Some of them were used in the legacy network or compat_net=1 checks that were disabled by default in Linux 2.6.18 and fully removed in Linux 2.6.30. Permissions never used in mainline Linux: file swapon filesystem transition tcp_socket { connectto newconn acceptfrom } node enforce_dest unix_stream_socket { newconn acceptfrom } Legacy network checks, removed in 2.6.30: socket { recv_msg send_msg } node { tcp_recv tcp_send udp_recv udp_send rawip_recv rawip_send dccp_recv dccp_send } netif { tcp_recv tcp_send udp_recv udp_send rawip_recv rawip_send dccp_recv dccp_send } Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-06-04selinux: enable genfscon labeling for sysfs and pstore filesStephen Smalley
Support per-file labeling of sysfs and pstore files based on genfscon policy entries. This is safe because the sysfs and pstore directory tree cannot be manipulated by userspace, except to unlink pstore entries. This provides an alternative method of assigning per-file labeling to sysfs or pstore files without needing to set the labels from userspace on each boot. The advantages of this approach are that the labels are assigned as soon as the dentry is first instantiated and userspace does not need to walk the sysfs or pstore tree and set the labels on each boot. The limitations of this approach are that the labels can only be assigned based on pathname prefix matching. You can initially assign labels using this mechanism and then change them at runtime via setxattr if allowed to do so by policy. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Suggested-by: Dominick Grift <dac.override@gmail.com> Acked-by: Jeff Vander Stoep <jeffv@google.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-06-04selinux: enable per-file labeling for debugfs files.Stephen Smalley
Add support for per-file labeling of debugfs files so that we can distinguish them in policy. This is particularly important in Android where certain debugfs files have to be writable by apps and therefore the debugfs directory tree can be read and searched by all. Since debugfs is entirely kernel-generated, the directory tree is immutable by userspace, and the inodes are pinned in memory, we can simply use the same approach as with proc and label the inodes from policy based on pathname from the root of the debugfs filesystem. Generalize the existing labeling support used for proc and reuse it for debugfs too. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-06-04selinux: update netlink socket classesStephen Smalley
Update the set of SELinux netlink socket class definitions to match the set of netlink protocols implemented by the kernel. The ip_queue implementation for the NETLINK_FIREWALL and NETLINK_IP6_FW protocols was removed in d16cf20e2f2f13411eece7f7fb72c17d141c4a84, so we can remove the corresponding class definitions as this is dead code. Add new classes for NETLINK_ISCSI, NETLINK_FIB_LOOKUP, NETLINK_CONNECTOR, NETLINK_NETFILTER, NETLINK_GENERIC, NETLINK_SCSITRANSPORT, NETLINK_RDMA, and NETLINK_CRYPTO so that we can distinguish among sockets created for each of these protocols. This change does not define the finer-grained nlsmsg_read/write permissions or map specific nlmsg_type values to those permissions in the SELinux nlmsgtab; if finer-grained control of these sockets is desired/required, that can be added as a follow-on change. We do not define a SELinux class for NETLINK_ECRYPTFS as the implementation was removed in 624ae5284516870657505103ada531c64dba2a9a. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-06-04signals: don't abuse __flush_signals() in selinux_bprm_committed_creds()Oleg Nesterov
selinux_bprm_committed_creds()->__flush_signals() is not right, we shouldn't clear TIF_SIGPENDING unconditionally. There can be other reasons for signal_pending(): freezing(), JOBCTL_PENDING_MASK, and potentially more. Also change this code to check fatal_signal_pending() rather than SIGNAL_GROUP_EXIT, it looks a bit better. Now we can kill __flush_signals() before it finds another buggy user. Note: this code looks racy, we can flush a signal which was sent after the task SID has been updated. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-06-04selinux: Print 'sclass' as string when unrecognized netlink message occursMarek Milkovic
This prints the 'sclass' field as string instead of index in unrecognized netlink message. The textual representation makes it easier to distinguish the right class. Signed-off-by: Marek Milkovic <mmilkovi@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> [PM: 80-char width fixes] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-06-03Merge branch 'smack-for-4.2-stacked' of ↵James Morris
2015-06-02Smack: allow multiple labels in onlycapRafal Krypa
Smack onlycap allows limiting of CAP_MAC_ADMIN and CAP_MAC_OVERRIDE to processes running with the configured label. But having single privileged label is not enough in some real use cases. On a complex system like Tizen, there maybe few programs that need to configure Smack policy in run-time and running them all with a single label is not always practical. This patch extends onlycap feature for multiple labels. They are configured in the same smackfs "onlycap" interface, separated by spaces. Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
2015-06-02Smack: fix seq operations in smackfsRafal Krypa
Use proper RCU functions and read locking in smackfs seq_operations. Smack gets away with not using proper RCU functions in smackfs, because it never removes entries from these lists. But now one list will be needed (with interface in smackfs) that will have both elements added and removed to it. This change will also help any future changes implementing removal of unneeded entries from other Smack lists. The patch also fixes handling of pos argument in smk_seq_start and smk_seq_next. This fixes a bug in case when smackfs is read with a small buffer: Kernel panic - not syncing: Kernel mode fault at addr 0xfa0000011b CPU: 0 PID: 1292 Comm: dd Not tainted 4.1.0-rc1-00012-g98179b8 #13 Stack: 00000003 0000000d 7ff39e48 7f69fd00 7ff39ce0 601ae4b0 7ff39d50 600e587b 00000010 6039f690 7f69fd40 00612003 Call Trace: [<601ae4b0>] load2_seq_show+0x19/0x1d [<600e587b>] seq_read+0x168/0x331 [<600c5943>] __vfs_read+0x21/0x101 [<601a595e>] ? security_file_permission+0xf8/0x105 [<600c5ec6>] ? rw_verify_area+0x86/0xe2 [<600c5fc3>] vfs_read+0xa1/0x14c [<600c68e2>] SyS_read+0x57/0xa0 [<6001da60>] handle_syscall+0x60/0x80 [<6003087d>] userspace+0x442/0x548 [<6001aa77>] ? interrupt_end+0x0/0x80 [<6001daae>] ? copy_chunk_to_user+0x0/0x2b [<6002cb6b>] ? save_registers+0x1f/0x39 [<60032ef7>] ? arch_prctl+0xf5/0x170 [<6001a92d>] fork_handler+0x85/0x87 Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
2015-05-29lsm: rename duplicate labels in LSM_AUDIT_DATA_TASK audit message typeRichard Guy Briggs
The LSM_AUDIT_DATA_TASK pid= and comm= labels are duplicates of those at the start of this function with different values. Rename them to their object counterparts opid= and ocomm= to disambiguate. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: minor merging needed due to differences in the tree] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-05-28kernel/params: constify struct kernel_param_ops usesLuis R. Rodriguez
Most code already uses consts for the struct kernel_param_ops, sweep the kernel for the last offending stragglers. Other than include/linux/moduleparam.h and kernel/params.c all other changes were generated with the following Coccinelle SmPL patch. Merge conflicts between trees can be handled with Coccinelle. In the future git could get Coccinelle merge support to deal with patch --> fail --> grammar --> Coccinelle --> new patch conflicts automatically for us on patches where the grammar is available and the patch is of high confidence. Consider this a feature request. Test compiled on x86_64 against: * allnoconfig * allmodconfig * allyesconfig @ const_found @ identifier ops; @@ const struct kernel_param_ops ops = { }; @ const_not_found depends on !const_found @ identifier ops; @@ -struct kernel_param_ops ops = { +const struct kernel_param_ops ops = { }; Generated-by: Coccinelle SmPL Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Junio C Hamano <gitster@pobox.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Kees Cook <keescook@chromium.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: cocci@systeme.lip6.fr Cc: linux-kernel@vger.kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-05-21ima: pass iint to ima_add_violation()Roberto Sassu
This patch adds the iint associated to the current inode as a new parameter of ima_add_violation(). The passed iint is always not NULL if a violation is detected. This modification will be used to determine the inode for which there is a violation. Since the 'd' and 'd-ng' template field init() functions were detecting a violation from the value of the iint pointer, they now check the new field 'violation', added to the 'ima_event_data' structure. Changelog: - v1: - modified an old comment (Roberto Sassu) Signed-off-by: Roberto Sassu <rsassu@suse.de> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-05-21ima: wrap event related data to the new ima_event_data structureRoberto Sassu
All event related data has been wrapped into the new 'ima_event_data' structure. The main benefit of this patch is that a new information can be made available to template fields initialization functions by simply adding a new field to the new structure instead of modifying the definition of those functions. Changelog: - v2: - f_dentry replaced with f_path.dentry (Roberto Sassu) - removed declaration of temporary variables in template field functions when possible (suggested by Dmitry Kasatkin) Signed-off-by: Roberto Sassu <rsassu@suse.de> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-05-21integrity: add validity checks for 'path' parameterDmitry Kasatkin
This patch adds validity checks for 'path' parameter and makes it const. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-05-21evm: fix potential race when removing xattrsDmitry Kasatkin
EVM needs to be atomically updated when removing xattrs. Otherwise concurrent EVM verification may fail in between. This patch fixes by moving i_mutex unlocking after calling EVM hook. fsnotify_xattr() is also now called while locked the same way as it is done in __vfs_setxattr_noperm. Changelog: - remove unused 'inode' variable. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-05-21evm: labeling pseudo filesystems exceptionMimi Zohar
To prevent offline stripping of existing file xattrs and relabeling of them at runtime, EVM allows only newly created files to be labeled. As pseudo filesystems are not persistent, stripping of xattrs is not a concern. Some LSMs defer file labeling on pseudo filesystems. This patch permits the labeling of existing files on pseudo files systems. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-05-21ima: remove definition of IMA_X509_PATHDmitry Kasatkin
CONFIG_IMA_X509_PATH is always defined. This patch removes the IMA_X509_PATH definition and uses CONFIG_IMA_X509_PATH. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-05-21ima: limit file hash setting by user to fix and log modesDmitry Kasatkin
File hashes are automatically set and updated and should not be manually set. This patch limits file hash setting to fix and log modes. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-05-21ima: do not measure or appraise the NSFS filesystemMimi Zohar
Include don't appraise or measure rules for the NSFS filesystem in the builtin ima_tcb and ima_appraise_tcb policies. Changelog: - Update documentation Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: stable@vger.kernel.org # 3.19
2015-05-21ima: skip measurement of cgroupfs files and update documentationRoberto Sassu
This patch adds a rule in the default measurement policy to skip inodes in the cgroupfs filesystem. Measurements for this filesystem can be avoided, as all the digests collected have the same value of the digest of an empty file. Furthermore, this patch updates the documentation of IMA policies in Documentation/ABI/testing/ima_policy to make it consistent with the policies set in security/integrity/ima/ima_policy.c. Signed-off-by: Roberto Sassu <rsassu@suse.de> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-05-15smack: pass error code through pointersLukasz Pawelczyk
This patch makes the following functions to use ERR_PTR() and related macros to pass the appropriate error code through returned pointers: smk_parse_smack() smk_import_entry() smk_fetch() It also makes all the other functions that use them to handle the error cases properly. This ways correct error codes from places where they happened can be propagated to the user space if necessary. Doing this it fixes a bug in onlycap and unconfined files handling. Previously their content was cleared on any error from smk_import_entry/smk_parse_smack, be it EINVAL (as originally intended) or ENOMEM. Right now it only reacts on EINVAL passing other codes properly to userspace. Comments have been updated accordingly. Signed-off-by: Lukasz Pawelczyk <l.pawelczyk@samsung.com>
2015-05-15Smack: ignore private inode for smack_file_receiveSeung-Woo Kim
The dmabuf fd can be shared between processes via unix domain socket. The file of dmabuf fd is came from anon_inode. The inode has no set and get xattr operations, so it can not be shared between processes with smack. This patch fixes just to ignore private inode including anon_inode for smack_file_receive. Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
2015-05-13ima: cleanup ima_init_policy() a littleDan Carpenter
It's a bit easier to read this if we split it up into two for loops. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-05-12LSM: Remove unused capability.cCasey Schaufler
The stub functions in capability.c are no longer required with the list based stacking mechanism. Remove the file. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: John Johansen <john.johansen@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-05-12LSM: Switch to lists of hooksCasey Schaufler
Instead of using a vector of security operations with explicit, special case stacking of the capability and yama hooks use lists of hooks with capability and yama hooks included as appropriate. The security_operations structure is no longer required. Instead, there is a union of the function pointers that allows all the hooks lists to use a common mechanism for list management while retaining typing. Each module supplies an array describing the hooks it provides instead of a sparsely populated security_operations structure. The description includes the element that gets put on the hook list, avoiding the issues surrounding individual element allocation. The method for registering security modules is changed to reflect the information available. The method for removing a module, currently only used by SELinux, has also changed. It should be generic now, however if there are potential race conditions based on ordering of hook removal that needs to be addressed by the calling module. The security hooks are called from the lists and the first failure is returned. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: John Johansen <john.johansen@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-05-12LSM: Add security module hook list headsCasey Schaufler
Add a list header for each security hook. They aren't used until later in the patch series. They are grouped together in a structure so that there doesn't need to be an external address for each. Macro-ize the initialization of the security_operations for each security module in anticipation of changing out the security_operations structure. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: John Johansen <john.johansen@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-05-12LSM: Introduce security hook calling MacrosCasey Schaufler
Introduce two macros around calling the functions in the security operations vector. The marco versions here do not change any behavior. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: John Johansen <john.johansen@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-05-12LSM: Split security.hCasey Schaufler
The security.h header file serves two purposes, interfaces for users of the security modules and interfaces for security modules. Users of the security modules don't need to know about what's in the security_operations structure, so pull it out into it's own header, lsm_hooks.h Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: John Johansen <john.johansen@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-05-11security: make inode_follow_link RCU-walk awareNeilBrown
inode_follow_link now takes an inode and rcu flag as well as the dentry. inode is used in preference to d_backing_inode(dentry), particularly in RCU-walk mode. selinux_inode_follow_link() gets dentry_has_perm() and inode_has_perm() open-coded into it so that it can call avc_has_perm_flags() in way that is safe if LOOKUP_RCU is set. Calling avc_has_perm_flags() with rcu_read_lock() held means that when avc_has_perm_noaudit calls avc_compute_av(), the attempt to rcu_read_unlock() before calling security_compute_av() will not actually drop the RCU read-lock. However as security_compute_av() is completely in a read_lock()ed region, it should be safe with the RCU read-lock held. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
