commit 9f35a33b8d06263a165efe3541d9aa0cdbd70b3b upstream.
Fix a NULL pointer deref in the user-defined key type whereby updating a
negative key into a fully instantiated key will cause an oops to occur
when the code attempts to free the non-existent old payload.
This results in an oops that looks something like the following:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
PGD 3391d067 PUD 3894a067 PMD 0
Oops: 0002 [#1] SMP
CPU 1
Pid: 4354, comm: keyctl Not tainted 3.1.0-fsdevel+ #1140 /DG965RY
RIP: 0010:[<ffffffff81085fa1>] [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
RSP: 0018:ffff88003d591df8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000006e
RDX: ffffffff8161d0c0 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88003d591e18 R08: 0000000000000000 R09: ffffffff8152fa6c
R10: 0000000000000000 R11: 0000000000000300 R12: ffff88003b8f9538
R13: ffffffff8161d0c0 R14: ffff88003b8f9d50 R15: ffff88003c69f908
FS: 00007f97eb18c720(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CR2: 0000000000000008 CR3: 000000003d47a000 CR4: 00000000000006e0
Process keyctl (pid: 4354, threadinfo ffff88003d590000, task ffff88003c78a040)
Stack:
ffff88003e0ffde0 ffff88003b8f9538 0000000000000001 ffff88003b8f9d50
ffff88003d591e28 ffffffff810860f0 ffff88003d591e68 ffffffff8117bfea
ffff88003d591e68 ffffffff00000000 ffff88003e0ffde1 ffff88003e0ffde0
Call Trace:
[<ffffffff810860f0>] call_rcu_sched+0x10/0x12
[<ffffffff8117bfea>] user_update+0x8d/0xa2
[<ffffffff8117723a>] key_create_or_update+0x236/0x270
[<ffffffff811789b1>] sys_add_key+0x123/0x17e
[<ffffffff813b84bb>] system_call_fastpath+0x16/0x1b
Acked-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Neil Horman <nhorman@redhat.com>
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: James Morris <jmorris@namei.org>
The Bluetooth stack has internal connection handlers for all of the various
Bluetooth protocols, and unfortunately, they are currently lacking the LSM
hooks found in the core network stack's connection handlers. I say
unfortunately, because this can cause problems for users who have have an
LSM enabled and are using certain Bluetooth devices. See one problem
report below:
* http://bugzilla.redhat.com/show_bug.cgi?id=741703
In order to keep things simple at this point in time, this patch fixes the
problem by cloning the parent socket's LSM attributes to the newly created
child socket. If we decide we need a more elaborate LSM marking mechanism
for Bluetooth (I somewhat doubt this) we can always revisit this decision
in the future.
Reported-by: James M. Cape <jcape@ignore-your.tv>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Commit bd03a3e4 "TOMOYO: Add policy namespace support." forgot to set EOF flag
and forgot to print namespace at PREFERENCE line.
Signed-off-by: James Morris <jmorris@namei.org>
My @hp.com will no longer be valid starting August 5, 2011 so an update is
necessary. My new email address is employer independent so we don't have
to worry about doing this again any time soon.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits)
tpm_nsc: Fix bug when loading multiple TPM drivers
tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block
tpm: Fix compilation warning when CONFIG_PNP is not defined
TOMOYO: Update kernel-doc.
tpm: Fix a typo
tpm_tis: Probing function for Intel iTPM bug
tpm_tis: Fix the probing for interrupts
tpm_tis: Delay ACPI S3 suspend while the TPM is busy
tpm_tis: Re-enable interrupts upon (S3) resume
tpm: Fix display of data in pubek sysfs entry
tpm_tis: Add timeouts sysfs entry
tpm: Adjust interface timeouts if they are too small
tpm: Use interface timeouts returned from the TPM
tpm_tis: Introduce durations sysfs entry
tpm: Adjust the durations if they are too small
tpm: Use durations returned from TPM
TOMOYO: Enable conditional ACL.
TOMOYO: Allow using argv[]/envp[] of execve() as conditions.
TOMOYO: Allow using executable's realpath and symlink's target as conditions.
TOMOYO: Allow using owner/group etc. of file objects as conditions.
Fix up trivial conflict in security/tomoyo/realpath.c
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
merge fchmod() and fchmodat() guts, kill ancient broken kludge
xfs: fix misspelled S_IS...()
xfs: get rid of open-coded S_ISREG(), etc.
vfs: document locking requirements for d_move, __d_move and d_materialise_unique
omfs: fix (mode & S_IFDIR) abuse
btrfs: S_ISREG(mode) is not mode & S_IFREG...
ima: fmode_t misspelled as mode_t...
pci-label.c: size_t misspelled as mode_t
jffs2: S_ISLNK(mode & S_IFMT) is pointless
snd_msnd ->mode is fmode_t, not mode_t
v9fs_iop_get_acl: get rid of unused variable
vfs: dont chain pipe/anon/socket on superblock s_inodes list
Documentation: Exporting: update description of d_splice_alias
fs: add missing unlock in default_llseek()
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
For a number of file systems that don't have a mount point (e.g. sockfs
and pipefs), they are not marked as long term. Therefore in
mntput_no_expire, all locks in vfs_mount lock are taken instead of just
local cpu's lock to aggregate reference counts when we release
reference to file objects. In fact, only local lock need to have been
taken to update ref counts as these file systems are in no danger of
going away until we are ready to unregister them.
The attached patch marks file systems using kern_mount without
mount point as long term. The contentions of vfs_mount lock
is now eliminated. Before un-registering such file system,
kern_unmount should be called to remove the long term flag and
make the mount point ready to be freed.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits)
vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp
isofs: Remove global fs lock
jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory
fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.
mm/truncate.c: fix build for CONFIG_BLOCK not enabled
fs:update the NOTE of the file_operations structure
Remove dead code in dget_parent()
AFS: Fix silly characters in a comment
switch d_add_ci() to d_splice_alias() in "found negative" case as well
simplify gfs2_lookup()
jfs_lookup(): don't bother with . or ..
get rid of useless dget_parent() in btrfs rename() and link()
get rid of useless dget_parent() in fs/btrfs/ioctl.c
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
drivers: fix up various ->llseek() implementations
fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek
Ext4: handle SEEK_HOLE/SEEK_DATA generically
Btrfs: implement our own ->llseek
fs: add SEEK_HOLE and SEEK_DATA flags
reiserfs: make reiserfs default to barrier=flush
Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new
shrinker callout for the inode cache, that clashed with the xfs code to
start the periodic workers later.
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: Fix wrong check in list_splice_init_rcu()
net,rcu: Convert call_rcu(xt_rateest_free_rcu) to kfree_rcu()
sysctl,rcu: Convert call_rcu(free_head) to kfree
vmalloc,rcu: Convert call_rcu(rcu_free_vb) to kfree_rcu()
vmalloc,rcu: Convert call_rcu(rcu_free_va) to kfree_rcu()
ipc,rcu: Convert call_rcu(ipc_immediate_free) to kfree_rcu()
ipc,rcu: Convert call_rcu(free_un) to kfree_rcu()
security,rcu: Convert call_rcu(sel_netport_free) to kfree_rcu()
security,rcu: Convert call_rcu(sel_netnode_free) to kfree_rcu()
ia64,rcu: Convert call_rcu(sn_irq_info_free) to kfree_rcu()
block,rcu: Convert call_rcu(disk_free_ptbl_rcu_cb) to kfree_rcu()
scsi,rcu: Convert call_rcu(fc_rport_free_rcu) to kfree_rcu()
audit_tree,rcu: Convert call_rcu(__put_tree) to kfree_rcu()
security,rcu: Convert call_rcu(whitelist_item_free) to kfree_rcu()
md,rcu: Convert call_rcu(free_conf) to kfree_rcu()
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (39 commits)
ptrace: do_wait(traced_leader_killed_by_mt_exec) can block forever
ptrace: fix ptrace_signal() && STOP_DEQUEUED interaction
connector: add an event for monitoring process tracers
ptrace: dont send SIGSTOP on auto-attach if PT_SEIZED
ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task()
ptrace_init_task: initialize child->jobctl explicitly
has_stopped_jobs: s/task_is_stopped/SIGNAL_STOP_STOPPED/
ptrace: make former thread ID available via PTRACE_GETEVENTMSG after PTRACE_EVENT_EXEC stop
ptrace: wait_consider_task: s/same_thread_group/ptrace_reparented/
ptrace: kill real_parent_is_ptracer() in in favor of ptrace_reparented()
ptrace: ptrace_reparented() should check same_thread_group()
redefine thread_group_leader() as exit_signal >= 0
do not change dead_task->exit_signal
kill task_detached()
reparent_leader: check EXIT_DEAD instead of task_detached()
make do_notify_parent() __must_check, update the callers
__ptrace_detach: avoid task_detached(), check do_notify_parent()
kill tracehook_notify_death()
make do_notify_parent() return bool
ptrace: s/tracehook_tracer_task()/ptrace_parent()/
The rcu callback sel_netport_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(sel_netport_free).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Eric Paris <eparis@parisplace.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The rcu callback sel_netnode_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(sel_netnode_free).
The rcu callback whitelist_item_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(whitelist_item_free).
it never is...
pass mask instead; kill security_inode_exec_permission() since we can use
security_inode_permission() instead.
pass that via mask instead.
Update comments for scripts/kernel-doc and fix some of errors reported by
scripts/checkpatch.pl .
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Enable conditional ACL by passing object's pointers.
This patch adds support for permission checks using argv[]/envp[] of execve()
request. Hooks are in the last patch of this pathset.
This patch adds support for permission checks using executable file's realpath
upon execve() and symlink's target upon symlink(). Hooks are in the last patch
of this pathset.
This patch adds support for permission checks using file object's DAC
attributes (e.g. owner/group) when checking file's pathnames. Hooks for passing
file object's pointers are in the last patch of this pathset.
This patch adds support for permission checks using current thread's UID/GID
etc. in addition to pathnames.
Since ca5ecddf (rcu: define __rcu address space modifier for sparse)
rcu_dereference_check use rcu_read_lock_held as a part of condition
automatically so callers do not have to do that as well.
/sys/kernel/security/tomoyo/.domain_status can be easily emulated using
/sys/kernel/security/tomoyo/domain_policy . We can remove this interface by
updating /usr/sbin/tomoyo-setprofile utility.
Commit eadd99cc "TOMOYO: Add auditing interface." by error replaced
"struct tomoyo_request_info"->domain with tomoyo_domain().
Sort by alphabetic order.
I forgot to add #ifndef in commit 0e4ae0e0 "TOMOYO: Make several options
configurable.", resulting
security/built-in.o: In function `tomoyo_bprm_set_creds':
tomoyo.c:(.text+0x4698e): undefined reference to `tomoyo_load_policy'
error.
git://git.kernel.org/pub/scm/linux/kernel/git/jj/apparmor-dev into next
AppArmor is masking the capabilities returned by capget against the
capabilities mask in the profile. This is wrong, in complain mode the
profile has effectively all capabilities, as the profile restrictions are
not being enforced, merely tested against to determine if an access is
known by the profile.
This can result in the wrong behavior of security conscience applications
like sshd which examine their capability set, and change their behavior
accordingly. In this case because of the masked capability set being
returned sshd fails due to DAC checks, even when the profile is in complain
mode.
Kernels affected: 2.6.36 - 3.0.
Signed-off-by: John Johansen <john.johansen@canonical.com>
The pointer returned from tracehook_tracer_task() is only valid inside
the rcu_read_lock. However the tracer pointer obtained is being passed
to aa_may_ptrace outside of the rcu_read_lock critical section.
Mover the aa_may_ptrace test into the rcu_read_lock critical section, to
fix this.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Cc: stable@kernel.org
To be able to start using enforcing mode from the early stage of boot sequence,
this patch adds support for activating access control without calling external
policy loader program. This will be useful for systems where operations which
can lead to the hijacking of the boot sequence are needed before loading the
policy. For example, you can activate immediately after loading the fixed part
of policy which will allow only operations needed for mounting a partition
which contains the variant part of policy and verifying (e.g. running GPG
check) and loading the variant part of policy. Since you can start using
enforcing mode from the beginning, you can reduce the possibility of hijacking
the boot sequence.
This patch makes several variables configurable on build time. This patch also
adds TOMOYO_loader= and TOMOYO_trigger= kernel command line option to boot the
same kernel in two different init systems (BSD-style init and systemd).
this patch adds support for built-in policy configuration (and next patch adds
support for activating access control without calling external policy loader
program).
Show statistics such as last policy update time and last policy violation time
in addition to memory usage.
Gather string constants to one file in order to make the object size smaller.
Use unsigned type where appropriate.
read()/write() returns ssize_t.
Currently TOMOYO holds SRCU lock upon open() and releases it upon close()
because list elements stored in the "struct tomoyo_io_buffer" instances are
accessed until close() is called. However, such SRCU usage causes lockdep to
complain about leaving the kernel with SRCU lock held.
This patch solves the warning by holding/releasing SRCU upon each
read()/write(). This patch is doing something similar to calling kfree()
without calling synchronize_srcu(), by selectively deferring kfree() by keeping
track of the "struct tomoyo_io_buffer" instances.
TOMOYO wants to use /proc/self/ rather than /proc/$PID/ if $PID matches current
thread's process ID in order to prevent current thread from accessing other
process's information unless needed.
But since procfs can be mounted on various locations (e.g. /proc/ /proc2/ /p/
/tmp/foo/100/p/ ), TOMOYO cannot tell that whether the numeric part in the
string returned by __d_path() represents process ID or not.
Therefore, to be able to convert from $PID to self no matter where procfs is
mounted, this patch changes pathname representations for filesystems which do
not support rename() operation (e.g. proc, sysfs, securityfs).
Examples:
/proc/self/mounts => proc:/self/mounts
/sys/kernel/security/ => sys:/kernel/security/
/dev/pts/0 => devpts:/0
Mauras Olivier reported that it is difficult to use TOMOYO in LXC environments,
for TOMOYO cannot distinguish between environments outside the container and
environments inside the container since LXC environments are created using
pivot_root(). To address this problem, this patch introduces policy namespace.
Each policy namespace has its own set of domain policy, exception policy and
profiles, which are all independent of other namespaces. This independency
allows users to develop policy without worrying interference among namespaces.
ACL group allows administrator to globally grant not only "file read"
permission but also other permissions.
Add /sys/kernel/security/tomoyo/audit interface. This interface generates audit
logs in the form of domain policy so that /usr/sbin/tomoyo-auditd can reuse
audit logs for appending to /sys/kernel/security/tomoyo/domain_policy
interface.
Remove global preference from profile structure in order to make code simpler.
Due to this structure change, printk() warnings upon policy violation are
temporarily disabled. They will be replaced by
/sys/kernel/security/tomoyo/audit by next patch.
Convert "allow_..." style directives to "file ..." style directives.
By converting to the latter style, we can pack policy like
"file read/write/execute /path/to/file".
Use structure for passing ACL line, in preparation for supporting policy
namespace and conditional parameters.
Use common structure for ACL with "struct list_head" + "atomic_t".
Use array/struct where possible.
Remove is_group from "struct tomoyo_name_union"/"struct tomoyo_number_union".
Pass "struct file"->private_data rather than "struct file".
Update some of comments.
Bring tomoyo_same_acl_head() from common.h to domain.c .
Bring tomoyo_invalid()/tomoyo_valid() from common.h to util.c .
