path: root/security
2015-02-22Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted stuff from this cycle. The big ones here are multilayer overlayfs from Miklos and beginning of sorting ->d_inode accesses out from David" * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (51 commits) autofs4 copy_dev_ioctl(): keep the value of ->size we'd used for allocation procfs: fix race between symlink removals and traversals debugfs: leave freeing a symlink body until inode eviction Documentation/filesystems/Locking: ->get_sb() is long gone trylock_super(): replacement for grab_super_passive() fanotify: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions Cachefiles: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry) SELinux: Use d_is_positive() rather than testing dentry->d_inode Smack: Use d_is_positive() rather than testing dentry->d_inode TOMOYO: Use d_is_dir() rather than d_inode and S_ISDIR() Apparmor: Use d_is_positive/negative() rather than testing dentry->d_inode Apparmor: mediated_filesystem() should use dentry->d_sb not inode->i_sb VFS: Split DCACHE_FILE_TYPE into regular and special types VFS: Add a fallthrough flag for marking virtual dentries VFS: Add a whiteout dentry type VFS: Introduce inode-getting helpers for layered/unioned fs environments Infiniband: Fix potential NULL d_inode dereference posix_acl: fix reference leaks in posix_acl_create autofs4: Wrong format for printing dentry ...
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22SELinux: Use d_is_positive() rather than testing dentry->d_inodeDavid Howells
Use d_is_positive() rather than testing dentry->d_inode in SELinux to get rid of direct references to d_inode outside of the VFS. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22Smack: Use d_is_positive() rather than testing dentry->d_inodeDavid Howells
Use d_is_positive() rather than testing dentry->d_inode in Smack to get rid of direct references to d_inode outside of the VFS. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22TOMOYO: Use d_is_dir() rather than d_inode and S_ISDIR()David Howells
Use d_is_dir() rather than d_inode and S_ISDIR(). Note that this will include fake directories such as automount triggers. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22Apparmor: Use d_is_positive/negative() rather than testing dentry->d_inodeDavid Howells
Use d_is_positive(dentry) or d_is_negative(dentry) rather than testing dentry->d_inode as the dentry may cover another layer that has an inode when the top layer doesn't or may hold a 0,0 chardev that's actually a whiteout. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22Apparmor: mediated_filesystem() should use dentry->d_sb not inode->i_sbDavid Howells
mediated_filesystem() should use dentry->d_sb not dentry->d_inode->i_sb and should avoid file_inode() also since it is really dealing with the path. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-19Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig updates from Michal Marek: "Yann E Morin was supposed to take over kconfig maintainership, but this hasn't happened. So I'm sending a few kconfig patches that I collected: - Fix for missing va_end in kconfig - merge_config.sh displays used if given too few arguments - s/boolean/bool/ in Kconfig files for consistency, with the plan to only support bool in the future" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: use va_end to match corresponding va_start merge_config.sh: Display usage if given too few arguments kconfig: use bool instead of boolean for type definition attributes
2015-02-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc VFS updates from Al Viro: "This cycle a lot of stuff sits on topical branches, so I'll be sending more or less one pull request per branch. This is the first pile; more to follow in a few. In this one are several misc commits from early in the cycle (before I went for separate branches), plus the rework of mntput/dput ordering on umount, switching to use of fs_pin instead of convoluted games in namespace_unlock()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: switch the IO-triggering parts of umount to fs_pin new fs_pin killing logics allow attaching fs_pin to a group not associated with some superblock get rid of the second argument of acct_kill() take count and rcu_head out of fs_pin dcache: let the dentry count go down to zero without taking d_lock pull bumping refcount into ->kill() kill pin_put() mode_t whack-a-mole: chelsio file->f_path.dentry is pinned down for as long as the file is open... get rid of lustre_dump_dentry() gut proc_register() a bit kill d_validate() ncpfs: get rid of d_validate() nonsense selinuxfs: don't open-code d_genocide()
2015-02-16Merge branch 'smack-for-3.20-rebased' of ↵James Morris
git://git.gitorious.org/smack-next/kernel into for-linus
2015-02-16Don't leak a key reference if request_key() tries to use a revoked keyringDavid Jeffery
If a request_key() call to allocate and fill out a key attempts to insert the key structure into a revoked keyring, the key will leak, using memory and part of the user's key quota until the system reboots. This is from a failure of construct_alloc_key() to decrement the key's reference count after the attempt to insert into the requested keyring is rejected. key_put() needs to be called in the link_prealloc_failed callpath to ensure the unused key is released. Signed-off-by: David Jeffery <djeffery@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-02-15Merge tag 'char-misc-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char / misc patches from Greg KH: "Here's the big char/misc driver update for 3.20-rc1. Lots of little things in here, all described in the changelog. Nothing major or unusual, except maybe the binder selinux stuff, which was all acked by the proper selinux people and they thought it best to come through this tree. All of this has been in linux-next with no reported issues for a while" * tag 'char-misc-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (90 commits) coresight: fix function etm_writel_cp14() parameter order coresight-etm: remove check for unknown Kconfig macro coresight: fixing CPU hwid lookup in device tree coresight: remove the unnecessary function coresight_is_bit_set() coresight: fix the debug AMBA bus name coresight: remove the extra spaces coresight: fix the link between orphan connection and newly added device coresight: remove the unnecessary replicator property coresight: fix the replicator subtype value pdfdocs: Fix 'make pdfdocs' failure for 'uio-howto.tmpl' mcb: Fix error path of mcb_pci_probe virtio/console: verify device has config space ti-st: clean up data types (fix harmless memory corruption) mei: me: release hw from reset only during the reset flow mei: mask interrupt set bit on clean reset bit extcon: max77693: Constify struct regmap_config extcon: adc-jack: Release IIO channel on driver remove extcon: Remove duplicated include from extcon-class.c Drivers: hv: vmbus: hv_process_timer_expiration() can be static Drivers: hv: vmbus: serialize Offer and Rescind offer ...
2015-02-12Merge branch 'for-3.20/bdi' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull backing device changes from Jens Axboe: "This contains a cleanup of how the backing device is handled, in preparation for a rework of the life time rules. In this part, the most important change is to split the unrelated nommu mmap flags from it, but also removing a backing_dev_info pointer from the address_space (and inode), and a cleanup of other various minor bits. Christoph did all the work here, I just fixed an oops with pages that have a swap backing. Arnd fixed a missing export, and Oleg killed the lustre backing_dev_info from staging. Last patch was from Al, unexporting parts that are now no longer needed outside" * 'for-3.20/bdi' of git://git.kernel.dk/linux-block: Make super_blocks and sb_lock static mtd: export new mtd_mmap_capabilities fs: make inode_to_bdi() handle NULL inode staging/lustre/llite: get rid of backing_dev_info fs: remove default_backing_dev_info fs: don't reassign dirty inodes to default_backing_dev_info nfs: don't call bdi_unregister ceph: remove call to bdi_unregister fs: remove mapping->backing_dev_info fs: export inode_to_bdi and use it in favor of mapping->backing_dev_info nilfs2: set up s_bdi like the generic mount_bdev code block_dev: get bdev inode bdi directly from the block device block_dev: only write bdev inode on close fs: introduce f_op->mmap_capabilities for nommu mmap support fs: kill BDI_CAP_SWAP_BACKED fs: deduplicate noop_backing_dev_info
2015-02-11Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security layer updates from James Morris: "Highlights: - Smack adds secmark support for Netfilter - /proc/keys is now mandatory if CONFIG_KEYS=y - TPM gets its own device class - Added TPM 2.0 support - Smack file hook rework (all Smack users should review this!)" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (64 commits) cipso: don't use IPCB() to locate the CIPSO IP option SELinux: fix error code in policydb_init() selinux: add security in-core xattr support for pstore and debugfs selinux: quiet the filesystem labeling behavior message selinux: Remove unused function avc_sidcmp() ima: /proc/keys is now mandatory Smack: Repair netfilter dependency X.509: silence asn1 compiler debug output X.509: shut up about included cert for silent build KEYS: Make /proc/keys unconditional if CONFIG_KEYS=y MAINTAINERS: email update tpm/tpm_tis: Add missing ifdef CONFIG_ACPI for pnp_acpi_device smack: fix possible use after frees in task_security() callers smack: Add missing logging in bidirectional UDS connect check Smack: secmark support for netfilter Smack: Rework file hooks tpm: fix format string error in tpm-chip.c char/tpm/tpm_crb: fix build error smack: Fix a bidirectional UDS connect check typo smack: introduce a special case for tmpfs in smack_d_instantiate() ...
2015-02-11Smack: secmark connectionsCasey Schaufler
If the secmark is available us it on connection as well as packet delivery. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2015-02-04SELinux: fix error code in policydb_init()Dan Carpenter
If hashtab_create() returns a NULL pointer then we should return -ENOMEM but instead the current code returns success. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-04selinux: add security in-core xattr support for pstore and debugfsMark Salyzyn
- add "pstore" and "debugfs" to list of in-core exceptions - change fstype checks to boolean equation - change from strncmp to strcmp for checking Signed-off-by: Mark Salyzyn <salyzyn@android.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> [PM: tweaked the subject line prefix to "selinux"] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-04selinux: quiet the filesystem labeling behavior messagePaul Moore
While the filesystem labeling method is only printed at the KERN_DEBUG level, this still appears in dmesg and on modern Linux distributions that create a lot of tmpfs mounts for session handling, the dmesg can easily be filled with a lot of "SELinux: initialized (dev X ..." messages. This patch removes this notification for the normal case but leaves the error message intact (displayed when mounting a filesystem with an unknown labeling behavior). Reported-by: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-04selinux: Remove unused function avc_sidcmp()Rickard Strandqvist
Remove the function avc_sidcmp() that is not used anywhere. This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> [PM: rewrite the patch subject line] Signed-off-by: Paul Moore <pmoore@redhat.com>
2015-02-02ima: /proc/keys is now mandatoryDavid Howells
/proc/keys is now mandatory and its config option no longer exists, so it doesn't need selecting. Reported-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-01-29Merge tag 'keys-next-20150123' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into next
2015-01-25file->f_path.dentry is pinned down for as long as the file is open...Al Viro
2015-01-25selinuxfs: don't open-code d_genocide()Al Viro
2015-01-25Add security hooks to binder and implement the hooks for SELinux.Stephen Smalley
Add security hooks to the binder and implement the hooks for SELinux. The security hooks enable security modules such as SELinux to implement controls over binder IPC. The security hooks include support for controlling what process can become the binder context manager (binder_set_context_mgr), controlling the ability of a process to invoke a binder transaction/IPC to another process (binder_transaction), controlling the ability of a process to transfer a binder reference to another process (binder_transfer_binder), and controlling the ability of a process to transfer an open file to another process (binder_transfer_file). These hooks have been included in the Android kernel trees since Android 4.3. (Updated to reflect upstream relocation and changes to the binder driver, changes to the LSM audit data structures, coding style cleanups, and to add inline documentation for the hooks). Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Nick Kralevich <nnk@google.com> Acked-by: Jeffrey Vander Stoep <jeffv@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-23Smack: Repair netfilter dependencyCasey Schaufler
On 1/23/2015 8:20 AM, Jim Davis wrote: > Building with the attached random configuration file, > > security/smack/smack_netfilter.c: In function ‘smack_ipv4_output’: > security/smack/smack_netfilter.c:55:6: error: ‘struct sk_buff’ has no > member named ‘secmark’ > skb->secmark = skp->smk_secid; > ^ > make[2]: *** [security/smack/smack_netfilter.o] Error 1 The existing Makefile used the wrong configuration option to determine if smack_netfilter should be built. This sets it right. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2015-01-22KEYS: Make /proc/keys unconditional if CONFIG_KEYS=yDavid Howells
Now that /proc/keys is used by libkeyutils to look up a key by type and description, we should make it unconditional and remove CONFIG_DEBUG_PROC_KEYS. Reported-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Jiri Kosina <jkosina@suse.cz>
2015-01-21smack: fix possible use after frees in task_security() callersAndrey Ryabinin
We hit use after free on dereferncing pointer to task_smack struct in smk_of_task() called from smack_task_to_inode(). task_security() macro uses task_cred_xxx() to get pointer to the task_smack. task_cred_xxx() could be used only for non-pointer members of task's credentials. It cannot be used for pointer members since what they point to may disapper after dropping RCU read lock. Mainly task_security() used this way: smk_of_task(task_security(p)) Intead of this introduce function smk_of_task_struct() which takes task_struct as argument and returns pointer to smk_known struct and do this under RCU read lock. Bogus task_security() macro is not used anymore, so remove it. KASan's report for this: AddressSanitizer: use after free in smack_task_to_inode+0x50/0x70 at addr c4635600 ============================================================================= BUG kmalloc-64 (Tainted: PO): kasan error ----------------------------------------------------------------------------- Disabling lock debugging due to kernel taint INFO: Allocated in new_task_smack+0x44/0xd8 age=39 cpu=0 pid=1866 kmem_cache_alloc_trace+0x88/0x1bc new_task_smack+0x44/0xd8 smack_cred_prepare+0x48/0x21c security_prepare_creds+0x44/0x4c prepare_creds+0xdc/0x110 smack_setprocattr+0x104/0x150 security_setprocattr+0x4c/0x54 proc_pid_attr_write+0x12c/0x194 vfs_write+0x1b0/0x370 SyS_write+0x5c/0x94 ret_fast_syscall+0x0/0x48 INFO: Freed in smack_cred_free+0xc4/0xd0 age=27 cpu=0 pid=1564 kfree+0x270/0x290 smack_cred_free+0xc4/0xd0 security_cred_free+0x34/0x3c put_cred_rcu+0x58/0xcc rcu_process_callbacks+0x738/0x998 __do_softirq+0x264/0x4cc do_softirq+0x94/0xf4 irq_exit+0xbc/0x120 handle_IRQ+0x104/0x134 gic_handle_irq+0x70/0xac __irq_svc+0x44/0x78 _raw_spin_unlock+0x18/0x48 sync_inodes_sb+0x17c/0x1d8 sync_filesystem+0xac/0xfc vdfs_file_fsync+0x90/0xc0 vfs_fsync_range+0x74/0x7c INFO: Slab 0xd3b23f50 objects=32 used=31 fp=0xc4635600 flags=0x4080 INFO: Object 0xc4635600 @offset=5632 fp=0x (null) Bytes b4 c46355f0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ Object c4635600: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk Object c4635610: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk Object c4635620: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk Object c4635630: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5 kkkkkkkkkkkkkkk. Redzone c4635640: bb bb bb bb .... Padding c46356e8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ Padding c46356f8: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ CPU: 5 PID: 834 Comm: launchpad_prelo Tainted: PBO 3.10.30 #1 Backtrace: [<c00233a4>] (dump_backtrace+0x0/0x158) from [<c0023dec>] (show_stack+0x20/0x24) r7:c4634010 r6:d3b23f50 r5:c4635600 r4:d1002140 [<c0023dcc>] (show_stack+0x0/0x24) from [<c06d6d7c>] (dump_stack+0x20/0x28) [<c06d6d5c>] (dump_stack+0x0/0x28) from [<c01c1d50>] (print_trailer+0x124/0x144) [<c01c1c2c>] (print_trailer+0x0/0x144) from [<c01c1e88>] (object_err+0x3c/0x44) r7:c4635600 r6:d1002140 r5:d3b23f50 r4:c4635600 [<c01c1e4c>] (object_err+0x0/0x44) from [<c01cac18>] (kasan_report_error+0x2b8/0x538) r6:d1002140 r5:d3b23f50 r4:c6429cf8 r3:c09e1aa7 [<c01ca960>] (kasan_report_error+0x0/0x538) from [<c01c9430>] (__asan_load4+0xd4/0xf8) [<c01c935c>] (__asan_load4+0x0/0xf8) from [<c031e168>] (smack_task_to_inode+0x50/0x70) r5:c4635600 r4:ca9da000 [<c031e118>] (smack_task_to_inode+0x0/0x70) from [<c031af64>] (security_task_to_inode+0x3c/0x44) r5:cca25e80 r4:c0ba9780 [<c031af28>] (security_task_to_inode+0x0/0x44) from [<c023d614>] (pid_revalidate+0x124/0x178) r6:00000000 r5:cca25e80 r4:cbabe3c0 r3:00008124 [<c023d4f0>] (pid_revalidate+0x0/0x178) from [<c01db98c>] (lookup_fast+0x35c/0x43y4) r9:c6429efc r8:00000101 r7:c079d940 r6:c6429e90 r5:c6429ed8 r4:c83c4148 [<c01db630>] (lookup_fast+0x0/0x434) from [<c01deec8>] (do_last.isra.24+0x1c0/0x1108) [<c01ded08>] (do_last.isra.24+0x0/0x1108) from [<c01dff04>] (path_openat.isra.25+0xf4/0x648) [<c01dfe10>] (path_openat.isra.25+0x0/0x648) from [<c01e1458>] (do_filp_open+0x3c/0x88) [<c01e141c>] (do_filp_open+0x0/0x88) from [<c01ccb28>] (do_sys_open+0xf0/0x198) r7:00000001 r6:c0ea2180 r5:0000000b r4:00000000 [<c01cca38>] (do_sys_open+0x0/0x198) from [<c01ccc00>] (SyS_open+0x30/0x34) [<c01ccbd0>] (SyS_open+0x0/0x34) from [<c001db80>] (ret_fast_syscall+0x0/0x48) Read of size 4 by thread T834: Memory state around the buggy address: c4635380: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc c4635400: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc c4635480: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc c4635500: 00 00 00 00 00 fc fc fc fc fc fc fc fc fc fc fc c4635580: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc >c4635600: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ^ c4635680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb c4635700: 00 00 00 00 04 fc fc fc fc fc fc fc fc fc fc fc c4635780: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc c4635800: 00 00 00 00 00 00 04 fc fc fc fc fc fc fc fc fc c4635880: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ================================================================== Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: <stable@vger.kernel.org>
2015-01-21Merge branch 'for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull RCU updates from Paul E. McKenney: - Documentation updates. - Miscellaneous fixes. - Preemptible-RCU fixes, including fixing an old bug in the interaction of RCU priority boosting and CPU hotplug. - SRCU updates. - RCU CPU stall-warning updates. - RCU torture-test updates. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-01-20smack: Add missing logging in bidirectional UDS connect checkRafal Krypa
During UDS connection check, both sides are checked for write access to the other side. But only the first check is performed with audit support. The second one didn't produce any audit logs. This simple patch fixes that. Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
2015-01-20Smack: secmark support for netfilterCasey Schaufler
Smack uses CIPSO to label internet packets and thus provide for access control on delivery of packets. The netfilter facility was not used to allow for Smack to work properly without netfilter configuration. Smack does not need netfilter, however there are cases where it would be handy. As a side effect, the labeling of local IPv4 packets can be optimized and the handling of local IPv6 packets is just all out better. The best part is that the netfilter tools use "contexts" that are just strings, and they work just as well for Smack as they do for SELinux. All of the conditional compilation for IPv6 was implemented by Rafal Krypa <r.krypa@samsung.com> Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2015-01-20Smack: Rework file hooksCasey Schaufler
This is one of those cases where you look at code you did years ago and wonder what you might have been thinking. There are a number of LSM hooks that work off of file pointers, and most of them really want the security data from the inode. Some, however, really want the security context that the process had when the file was opened. The difference went undetected in Smack until it started getting used in a real system with real testing. At that point it was clear that something was amiss. This patch corrects the misuse of the f_security value in several of the hooks. The behavior will not usually be any different, as the process had to be able to open the file in the first place, and the old check almost always succeeded, as will the new, but for different reasons. Thanks to the Samsung Tizen development team that identified this. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2015-01-20fs: introduce f_op->mmap_capabilities for nommu mmap supportChristoph Hellwig
Since "BDI: Provide backing device capability information [try #3]" the backing_dev_info structure also provides flags for the kind of mmap operation available in a nommu environment, which is entirely unrelated to it's original purpose. Introduce a new nommu-only file operation to provide this information to the nommu mmap code instead. Splitting this from the backing_dev_info structure allows to remove lots of backing_dev_info instance that aren't otherwise needed, and entirely gets rid of the concept of providing a backing_dev_info for a character device. It also removes the need for the mtd_inodefs filesystem. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-01-19smack: Fix a bidirectional UDS connect check typoZbigniew Jasinski
The 54e70ec5eb090193b03e69d551fa6771a5a217c4 commit introduced a bidirectional check that should have checked for mutual WRITE access between two labels. Due to a typo subject's OUT label is checked with object's OUT. Should be OUT to IN. Signed-off-by: Zbigniew Jasinski <z.jasinski@samsung.com>
2015-01-19smack: introduce a special case for tmpfs in smack_d_instantiate()Łukasz Stelmach
Files created with __shmem_file_stup() appear to have somewhat fake dentries which make them look like root directories and not get the label the current process or ("*") star meant for tmpfs files. Signed-off-by: Łukasz Stelmach <l.stelmach@samsung.com>
2015-01-19smack: fix logic in smack_inode_init_security functionLukasz Pawelczyk
In principle if this function was called with "value" == NULL and "len" not NULL it could return different results for the "len" compared to a case where "name" was not NULL. This is a hypothetical case that does not exist in the kernel, but it's a logic bug nonetheless. Signed-off-by: Lukasz Pawelczyk <l.pawelczyk@samsung.com>
2015-01-19smack: miscellaneous small fixes in function commentsLukasz Pawelczyk
2015-01-07kconfig: use bool instead of boolean for type definition attributesChristoph Jaeger
Support for keyword 'boolean' will be dropped later on. No functional change. Reference: http://lkml.kernel.org/r/cover.1418003065.git.cj@linux.com Signed-off-by: Christoph Jaeger <cj@linux.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-01-06rcu: Make SRCU optional by using CONFIG_SRCUPranith Kumar
SRCU is not necessary to be compiled by default in all cases. For tinification efforts not compiling SRCU unless necessary is desirable. The current patch tries to make compiling SRCU optional by introducing a new Kconfig option CONFIG_SRCU which is selected when any of the components making use of SRCU are selected. If we do not select CONFIG_SRCU, srcu.o will not be compiled at all. text data bss dec hex filename 2007 0 0 2007 7d7 kernel/rcu/srcu.o Size of arch/powerpc/boot/zImage changes from text data bss dec hex filename 831552 64180 23944 919676 e087c arch/powerpc/boot/zImage : before 829504 64180 23952 917636 e0084 arch/powerpc/boot/zImage : after so the savings are about ~2000 bytes. Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com> CC: Josh Triplett <josh@joshtriplett.org> CC: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [ paulmck: resolve conflict due to removal of arch/ia64/kvm/Kconfig. ]
2015-01-05KEYS: close race between key lookup and freeingSasha Levin
When a key is being garbage collected, it's key->user would get put before the ->destroy() callback is called, where the key is removed from it's respective tracking structures. This leaves a key hanging in a semi-invalid state which leaves a window open for a different task to try an access key->user. An example is find_keyring_by_name() which would dereference key->user for a key that is in the process of being garbage collected (where key->user was freed but ->destroy() wasn't called yet - so it's still present in the linked list). This would cause either a panic, or corrupt memory. Fixes CVE-2014-9529. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com>
2014-12-16KEYS: remove a bogus NULL checkDan Carpenter
We already checked if "desc" was NULL at the beginning of the function and we've dereferenced it so this causes a static checker warning. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-12-16Merge branch 'next' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into for-linus
2014-12-14Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security layer updates from James Morris: "In terms of changes, there's general maintenance to the Smack, SELinux, and integrity code. The IMA code adds a new kconfig option, IMA_APPRAISE_SIGNED_INIT, which allows IMA appraisal to require signatures. Support for reading keys from rootfs before init is call is also added" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits) selinux: Remove security_ops extern security: smack: fix out-of-bounds access in smk_parse_smack() VFS: refactor vfs_read() ima: require signature based appraisal integrity: provide a hook to load keys when rootfs is ready ima: load x509 certificate from the kernel integrity: provide a function to load x509 certificate from the kernel integrity: define a new function integrity_read_file() Security: smack: replace kzalloc with kmem_cache for inode_smack Smack: Lock mode for the floor and hat labels ima: added support for new kernel cmdline parameter ima_template_fmt ima: allocate field pointers array on demand in template_desc_init_fields() ima: don't allocate a copy of template_fmt in template_desc_init_fields() ima: display template format in meas. list if template name length is zero ima: added error messages to template-related functions ima: use atomic bit operations to protect policy update interface ima: ignore empty and with whitespaces policy lines ima: no need to allocate entry for comment ima: report policy load status ima: use path names cache ...
2014-12-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS changes from Al Viro: "First pile out of several (there _definitely_ will be more). Stuff in this one: - unification of d_splice_alias()/d_materialize_unique() - iov_iter rewrite - killing a bunch of ->f_path.dentry users (and f_dentry macro). Getting that completed will make life much simpler for unionmount/overlayfs, since then we'll be able to limit the places sensitive to file _dentry_ to reasonably few. Which allows to have file_inode(file) pointing to inode in a covered layer, with dentry pointing to (negative) dentry in union one. Still not complete, but much closer now. - crapectomy in lustre (dead code removal, mostly) - "let's make seq_printf return nothing" preparations - assorted cleanups and fixes There _definitely_ will be more piles" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) copy_from_iter_nocache() new helper: iov_iter_kvec() csum_and_copy_..._iter() iov_iter.c: handle ITER_KVEC directly iov_iter.c: convert copy_to_iter() to iterate_and_advance iov_iter.c: convert copy_from_iter() to iterate_and_advance iov_iter.c: get rid of bvec_copy_page_{to,from}_iter() iov_iter.c: convert iov_iter_zero() to iterate_and_advance iov_iter.c: convert iov_iter_get_pages_alloc() to iterate_all_kinds iov_iter.c: convert iov_iter_get_pages() to iterate_all_kinds iov_iter.c: convert iov_iter_npages() to iterate_all_kinds iov_iter.c: iterate_and_advance iov_iter.c: macros for iterating over iov_iter kill f_dentry macro dcache: fix kmemcheck warning in switch_names new helper: audit_file() nfsd_vfs_write(): use file_inode() ncpfs: use file_inode() kill f_dentry uses lockd: get rid of ->f_path.dentry->d_sb ...
2014-12-08Merge branch 'iov_iter' into for-nextAl Viro
2014-12-06ima: Fix build failure on powerpc when TCG_IBMVTPM dependencies are not metMichael Ellerman
On powerpc we can end up with IMA=y and PPC_PSERIES=n which leads to: warning: (IMA) selects TCG_IBMVTPM which has unmet direct dependencies (TCG_TPM && PPC_PSERIES) tpm_ibmvtpm.c:(.text+0x14f3e8): undefined reference to `.plpar_hcall_norets' I'm not sure why IMA needs to select those user-visible symbols, but if it must then the simplest fix is to just express the proper dependencies on the select. Tested-by: Hon Ching (Vicky) Lo <lo1@us.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-12-06KEYS: Fix stale key registration at error pathTakashi Iwai
When loading encrypted-keys module, if the last check of aes_get_sizes() in init_encrypted() fails, the driver just returns an error without unregistering its key type. This results in the stale entry in the list. In addition to memory leaks, this leads to a kernel crash when registering a new key type later. This patch fixes the problem by swapping the calls of aes_get_sizes() and register_key_type(), and releasing resources properly at the error paths. Bugzilla: https://bugzilla.opensuse.org/show_bug.cgi?id=908163 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-12-05Merge branch 'next' of git://git.infradead.org/users/pcmoore/selinux into nextJames Morris
2014-12-01KEYS: request_key() should reget expired keys rather than give EKEYEXPIREDDavid Howells
Since the keyring facility can be viewed as a cache (at least in some applications), the local expiration time on the key should probably be viewed as a 'needs updating after this time' property rather than an absolute 'anyone now wanting to use this object is out of luck' property. Since request_key() is the main interface for the usage of keys, this should update or replace an expired key rather than issuing EKEYEXPIRED if the local expiration has been reached (ie. it should refresh the cache). For absolute conditions where refreshing the cache probably doesn't help, the key can be negatively instantiated using KEYCTL_REJECT_KEY with EKEYEXPIRED given as the error to issue. This will still cause request_key() to return EKEYEXPIRED as that was explicitly set. In the future, if the key type has an update op available, we might want to upcall with the expired key and allow the upcall to update it. We would pass a different operation name (the first column in /etc/request-key.conf) to the request-key program. request_key() returning EKEYEXPIRED is causing an NFS problem which Chuck Lever describes thusly: After about 10 minutes, my NFSv4 functional tests fail because the ownership of the test files goes to "-2". Looking at /proc/keys shows that the id_resolv keys that map to my test user ID have expired. The ownership problem persists until the expired keys are purged from the keyring, and fresh keys are obtained. I bisected the problem to 3.13 commit b2a4df200d57 ("KEYS: Expand the capacity of a keyring"). This commit inadvertantly changes the API contract of the internal function keyring_search_aux(). The root cause appears to be that b2a4df200d57 made "no state check" the default behavior. "No state check" means the keyring search iterator function skips checking the key's expiry timeout, and returns expired keys. request_key_and_link() depends on getting an -EAGAIN result code to know when to perform an upcall to refresh an expired key. This patch can be tested directly by: keyctl request2 user debug:fred a @s keyctl timeout %user:debug:fred 3 sleep 4 keyctl request2 user debug:fred a @s Without the patch, the last command gives error EKEYEXPIRED, but with the command it gives a new key. Reported-by: Carl Hetherington <cth@carlh.net> Reported-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Chuck Lever <chuck.lever@oracle.com>
2014-12-01KEYS: Simplify KEYRING_SEARCH_{NO,DO}_STATE_CHECK flagsDavid Howells
Simplify KEYRING_SEARCH_{NO,DO}_STATE_CHECK flags to be two variations of the same flag. They are effectively mutually exclusive and one or the other should be provided, but not both. Keyring cycle detection and key possession determination are the only things that set NO_STATE_CHECK, except that neither flag really does anything there because neither purpose makes use of the keyring_search_iterator() function, but rather provides their own. For cycle detection we definitely want to check inside of expired keyrings, just so that we don't create a cycle we can't get rid of. Revoked keyrings are cleared at revocation time and can't then be reused, so shouldn't be a problem either way. For possession determination, we *might* want to validate each keyring before searching it: do you possess a key that's hidden behind an expired or just plain inaccessible keyring? Currently, the answer is yes. Note that you cannot, however, possess a key behind a revoked keyring because they are cleared on revocation. keyring_search() sets DO_STATE_CHECK, which is correct. request_key_and_link() currently doesn't specify whether to check the key state or not - but it should set DO_STATE_CHECK. key_get_instantiation_authkey() also currently doesn't specify whether to check the key state or not - but it probably should also set DO_STATE_CHECK. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Chuck Lever <chuck.lever@oracle.com>
2014-12-01KEYS: Fix the size of the key description passed to/from userspaceDavid Howells
When a key description argument is imported into the kernel from userspace, as happens in add_key(), request_key(), KEYCTL_JOIN_SESSION_KEYRING, KEYCTL_SEARCH, the description is copied into a buffer up to PAGE_SIZE in size. PAGE_SIZE, however, is a variable quantity, depending on the arch. Fix this at 4096 instead (ie. 4095 plus a NUL termination) and define a constant (KEY_MAX_DESC_SIZE) to this end. When reading the description back with KEYCTL_DESCRIBE, a PAGE_SIZE internal buffer is allocated into which the information and description will be rendered. This means that the description will get truncated if an extremely long description it has to be crammed into the buffer with the stringified information. There is no particular need to copy the description into the buffer, so just copy it directly to userspace in a separate operation. Reported-by: Christian Kastner <debian@kvr.at> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Christian Kastner <debian@kvr.at>
