cap_inode_need_killpriv returns 1 if security.capability exists and
has a value and inode_killpriv() is required, 0 otherwise. Fix the
description of the return value to reflect this.
Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com>
Reviewed-by: Serge Hallyn <serge@hallyn.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jj/linux-apparmor
Pull apparmor updates from John Johansen:
"This is the apparmor pull request, similar to SELinux and seccomp.
It's the same series that I was sent to James' security tree + one
regression fix that was found after the series was sent to James and
would have been sent for v4.14-rc2.
Features:
- in preparation for secid mapping add support for absolute root view
based labels
- add base infastructure for socket mediation
- add mount mediation
- add signal mediation
minor cleanups and changes:
- be defensive, ensure unconfined profiles have dfas initialized
- add more debug asserts to apparmorfs
- enable policy unpacking to audit different reasons for failure
- cleanup conditional check for label in label_print
- Redundant condition: prev_ns. in [label.c:1498]
Bug Fixes:
- fix regression in apparmorfs DAC access permissions
- fix build failure on sparc caused by undeclared signals
- fix sparse report of incorrect type assignment when freeing label proxies
- fix race condition in null profile creation
- Fix an error code in aafs_create()
- Fix logical error in verify_header()
- Fix shadowed local variable in unpack_trans_table()"
* tag 'apparmor-pr-2017-09-22' of git://git.kernel.org/pub/scm/linux/kernel/git/jj/linux-apparmor:
apparmor: fix apparmorfs DAC access permissions
apparmor: fix build failure on sparc caused by undeclared signals
apparmor: fix incorrect type assignment when freeing proxies
apparmor: ensure unconfined profiles have dfas initialized
apparmor: fix race condition in null profile creation
apparmor: move new_null_profile to after profile lookup fns()
apparmor: add base infastructure for socket mediation
apparmor: add more debug asserts to apparmorfs
apparmor: make policy_unpack able to audit different info messages
apparmor: add support for absolute root view based labels
apparmor: cleanup conditional check for label in label_print
apparmor: add mount mediation
apparmor: add the ability to mediate signals
apparmor: Redundant condition: prev_ns. in [label.c:1498]
apparmor: Fix an error code in aafs_create()
apparmor: Fix logical error in verify_header()
apparmor: Fix shadowed local variable in unpack_trans_table()
The DAC access permissions for several apparmorfs files are wrong.
.access - needs to be writable by all tasks to perform queries
the others in the set only provide a read fn so should be read only.
With policy namespace virtualization all apparmor needs to control
the permission and visibility checks directly which means DAC
access has to be allowed for all user, group, and other.
BugLink: http://bugs.launchpad.net/bugs/1713103
Fixes: c97204baf840b ("apparmor: rename apparmor file fns and data to indicate use")
Signed-off-by: John Johansen <john.johansen@canonical.com>
In file included from security/apparmor/ipc.c:23:0:
security/apparmor/include/sig_names.h:26:3: error: 'SIGSTKFLT' undeclared here (not in a function)
[SIGSTKFLT] = 16, /* -, 16, - */
security/apparmor/include/sig_names.h:26:3: error: array index in initializer not of integer type
security/apparmor/include/sig_names.h:26:3: note: (near initialization for 'sig_map')
security/apparmor/include/sig_names.h:51:3: error: 'SIGUNUSED' undeclared here (not in a function)
[SIGUNUSED] = 34, /* -, 31, - */
security/apparmor/include/sig_names.h:51:3: error: array index in initializer not of integer type
security/apparmor/include/sig_names.h:51:3: note: (near initialization for 'sig_map')
Fixes: c6bf1adaecaa ("apparmor: add the ability to mediate signals")
sparse reports
poisoning the proxy->label before freeing the struct is resulting in
a sparse build warning.
../security/apparmor/label.c:52:30: warning: incorrect type in assignment (different address spaces)
../security/apparmor/label.c:52:30: expected struct aa_label [noderef] <asn:4>*label
../security/apparmor/label.c:52:30: got struct aa_label *<noident>
fix with RCU_INIT_POINTER as this is one of those cases where
rcu_assign_pointer() is not needed.
Generally unconfined has early bailout tests and does not need the
dfas initialized, however if an early bailout test is ever missed
it will result in an oops.
Be defensive and initialize the unconfined profile to have null dfas
(no permission) so if an early bailout test is missed we fail
closed (no perms granted) instead of oopsing.
There is a race when null- profile is being created between the
initial lookup/creation of the profile and lock/addition of the
profile. This could result in multiple version of a profile being
added to the list which need to be removed/replaced.
Since these are learning profile their is no affect on mediation.
new_null_profile will need to use some of the profile lookup fns()
so move instead of doing forward fn declarations.
Provide a basic mediation of sockets. This is not a full net mediation
but just whether a spcific family of socket can be used by an
application, along with setting up some basic infrastructure for
network mediation to follow.
the user space rule hav the basic form of
NETWORK RULE = [ QUALIFIERS ] 'network' [ DOMAIN ]
[ TYPE | PROTOCOL ]
DOMAIN = ( 'inet' | 'ax25' | 'ipx' | 'appletalk' | 'netrom' |
'bridge' | 'atmpvc' | 'x25' | 'inet6' | 'rose' |
'netbeui' | 'security' | 'key' | 'packet' | 'ash' |
'econet' | 'atmsvc' | 'sna' | 'irda' | 'pppox' |
'wanpipe' | 'bluetooth' | 'netlink' | 'unix' | 'rds' |
'llc' | 'can' | 'tipc' | 'iucv' | 'rxrpc' | 'isdn' |
'phonet' | 'ieee802154' | 'caif' | 'alg' | 'nfc' |
'vsock' | 'mpls' | 'ib' | 'kcm' ) ','
TYPE = ( 'stream' | 'dgram' | 'seqpacket' | 'rdm' | 'raw' |
'packet' )
PROTOCOL = ( 'tcp' | 'udp' | 'icmp' )
eg.
network,
network inet,
Acked-by: Seth Arnold <seth.arnold@canonical.com>
Switch unpack auditing to using the generic name field in the audit
struct and make it so we can start adding new info messages about
why an unpack failed.
With apparmor policy virtualization based on policy namespace View's
we don't generally want/need absolute root based views, however there
are cases like debugging and some secid based conversions where
using a root based view is important.
Add basic mount mediation. That allows controlling based on basic
mount parameters. It does not include special mount parameters for
apparmor, super block labeling, or any triggers for apparmor namespace
parameter modifications on pivot root.
default userspace policy rules have the form of
MOUNT RULE = ( MOUNT | REMOUNT | UMOUNT )
MOUNT = [ QUALIFIERS ] 'mount' [ MOUNT CONDITIONS ] [ SOURCE FILEGLOB ]
[ '->' MOUNTPOINT FILEGLOB ]
REMOUNT = [ QUALIFIERS ] 'remount' [ MOUNT CONDITIONS ]
MOUNTPOINT FILEGLOB
UMOUNT = [ QUALIFIERS ] 'umount' [ MOUNT CONDITIONS ] MOUNTPOINT FILEGLOB
MOUNT CONDITIONS = [ ( 'fstype' | 'vfstype' ) ( '=' | 'in' )
MOUNT FSTYPE EXPRESSION ]
[ 'options' ( '=' | 'in' ) MOUNT FLAGS EXPRESSION ]
MOUNT FSTYPE EXPRESSION = ( MOUNT FSTYPE LIST | MOUNT EXPRESSION )
MOUNT FSTYPE LIST = Comma separated list of valid filesystem and
virtual filesystem types (eg ext4, debugfs, etc)
MOUNT FLAGS EXPRESSION = ( MOUNT FLAGS LIST | MOUNT EXPRESSION )
MOUNT FLAGS LIST = Comma separated list of MOUNT FLAGS.
MOUNT FLAGS = ( 'ro' | 'rw' | 'nosuid' | 'suid' | 'nodev' | 'dev' |
'noexec' | 'exec' | 'sync' | 'async' | 'remount' |
'mand' | 'nomand' | 'dirsync' | 'noatime' | 'atime' |
'nodiratime' | 'diratime' | 'bind' | 'rbind' | 'move' |
'verbose' | 'silent' | 'loud' | 'acl' | 'noacl' |
'unbindable' | 'runbindable' | 'private' | 'rprivate' |
'slave' | 'rslave' | 'shared' | 'rshared' |
'relatime' | 'norelatime' | 'iversion' | 'noiversion' |
'strictatime' | 'nouser' | 'user' )
MOUNT EXPRESSION = ( ALPHANUMERIC | AARE ) ...
PIVOT ROOT RULE = [ QUALIFIERS ] pivot_root [ oldroot=OLD PUT FILEGLOB ]
[ NEW ROOT FILEGLOB ]
SOURCE FILEGLOB = FILEGLOB
MOUNTPOINT FILEGLOB = FILEGLOB
eg.
mount,
mount /dev/foo,
mount options=ro /dev/foo -> /mnt/,
mount options in (ro,atime) /dev/foo -> /mnt/,
mount options=ro options=atime,
Add signal mediation where the signal can be mediated based on the
signal, direction, or the label or the peer/target. The signal perms
are verified on a cross check to ensure policy consistency in the case
of incremental policy load/replacement.
The optimization of skipping the cross check when policy is guaranteed
to be consistent (single compile unit) remains to be done.
SIGNAL_RULE = [ QUALIFIERS ] 'signal' [ SIGNAL ACCESS PERMISSIONS ]
[ SIGNAL SET ] [ SIGNAL PEER ]
SIGNAL ACCESS PERMISSIONS = SIGNAL ACCESS | SIGNAL ACCESS LIST
SIGNAL ACCESS LIST = '(' Comma or space separated list of SIGNAL
ACCESS ')'
SIGNAL ACCESS = ( 'r' | 'w' | 'rw' | 'read' | 'write' | 'send' |
'receive' )
SIGNAL SET = 'set' '=' '(' SIGNAL LIST ')'
SIGNAL LIST = Comma or space separated list of SIGNALS
SIGNALS = ( 'hup' | 'int' | 'quit' | 'ill' | 'trap' | 'abrt' |
'bus' | 'fpe' | 'kill' | 'usr1' | 'segv' | 'usr2' |
'pipe' | 'alrm' | 'term' | 'stkflt' | 'chld' | 'cont' |
'stop' | 'stp' | 'ttin' | 'ttou' | 'urg' | 'xcpu' |
'xfsz' | 'vtalrm' | 'prof' | 'winch' | 'io' | 'pwr' |
'sys' | 'emt' | 'exists' | 'rtmin+0' ... 'rtmin+32'
SIGNAL PEER = 'peer' '=' AARE
eg.
signal, # allow all signals
signal send set=(hup, kill) peer=foo,
Reported-by: David Binderman <dcb314@hotmail.com>
We accidentally forgot to set the error code on this path. It means we
return NULL instead of an error pointer. I looked through a bunch of
callers and I don't think it really causes a big issue, but the
documentation says we're supposed to return error pointers here.
Acked-by: Serge Hallyn <serge@hallyn.com>
verify_header() is currently checking whether interface version is less
than 5 *and* greater than 7, which always evaluates to false. Instead it
should check whether it is less than 5 *or* greater than 7.
Signed-off-by: Christos Gkekas <chris.gekas@gmail.com>
with W=2:
security/apparmor/policy_unpack.c: In function ‘unpack_trans_table’:
security/apparmor/policy_unpack.c:469: warning: declaration of ‘pos’ shadows a previous local
security/apparmor/policy_unpack.c:451: warning: shadowed declaration is here
Rename the old "pos" to "saved_pos" to fix this.
Fixes: 5379a3312024a8be ("apparmor: support v7 transition format compatible with label_parse")
Pull more set_fs removal from Al Viro:
"Christoph's 'use kernel_read and friends rather than open-coding
set_fs()' series"
* 'work.set_fs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: unexport vfs_readv and vfs_writev
fs: unexport vfs_read and vfs_write
fs: unexport __vfs_read/__vfs_write
lustre: switch to kernel_write
gadget/f_mass_storage: stop messing with the address limit
mconsole: switch to kernel_read
btrfs: switch write_buf to kernel_write
net/9p: switch p9_fd_read to kernel_write
mm/nommu: switch do_mmap_private to kernel_read
serial2002: switch serial2002_tty_write to kernel_{read/write}
fs: make the buf argument to __kernel_write a void pointer
fs: fix kernel_write prototype
fs: fix kernel_read prototype
fs: move kernel_read to fs/read_write.c
fs: move kernel_write to fs/read_write.c
autofs4: switch autofs4_write to __kernel_write
ashmem: switch to ->read_iter
git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/selinux
Pull selinux updates from Paul Moore:
"A relatively quiet period for SELinux, 11 patches with only two/three
having any substantive changes.
These noteworthy changes include another tweak to the NNP/nosuid
handling, per-file labeling for cgroups, and an object class fix for
AF_UNIX/SOCK_RAW sockets; the rest of the changes are minor tweaks or
administrative updates (Stephen's email update explains the file
explosion in the diffstat).
Everything passes the selinux-testsuite"
[ Also a couple of small patches from the security tree from Tetsuo
Handa for Tomoyo and LSM cleanup. The separation of security policy
updates wasn't all that clean - Linus ]
* tag 'selinux-pr-20170831' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/selinux:
selinux: constify nf_hook_ops
selinux: allow per-file labeling for cgroupfs
lsm_audit: update my email address
selinux: update my email address
MAINTAINERS: update the NetLabel and Labeled Networking information
selinux: use GFP_NOWAIT in the AVC kmem_caches
selinux: Generalize support for NNP/nosuid SELinux domain transitions
selinux: genheaders should fail if too many permissions are defined
selinux: update the selinux info in MAINTAINERS
credits: update Paul Moore's info
selinux: Assign proper class to PF_UNIX/SOCK_RAW sockets
tomoyo: Update URLs in Documentation/admin-guide/LSM/tomoyo.rst
LSM: Remove security_task_create() hook.
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"Life has been busy and I have not gotten half as much done this round
as I would have liked. I delayed it so that a minor conflict
resolution with the mips tree could spend a little time in linux-next
before I sent this pull request.
This includes two long delayed user namespace changes from Kirill
Tkhai. It also includes a very useful change from Serge Hallyn that
allows the security capability attribute to be used inside of user
namespaces. The practical effect of this is people can now untar
tarballs and install rpms in user namespaces. It had been suggested to
generalize this and encode some of the namespace information
information in the xattr name. Upon close inspection that makes the
things that should be hard easy and the things that should be easy
more expensive.
Then there is my bugfix/cleanup for signal injection that removes the
magic encoding of the siginfo union member from the kernel internal
si_code. The mips folks reported the case where I had used FPE_FIXME
me is impossible so I have remove FPE_FIXME from mips, while at the
same time including a return statement in that case to keep gcc from
complaining about unitialized variables.
I almost finished the work to get make copy_siginfo_to_user a trivial
copy to user. The code is available at:
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace.git neuter-copy_siginfo_to_user-v3
But I did not have time/energy to get the code posted and reviewed
before the merge window opened.
I was able to see that the security excuse for just copying fields
that we know are initialized doesn't work in practice there are buggy
initializations that don't initialize the proper fields in siginfo. So
we still sometimes copy unitialized data to userspace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
Introduce v3 namespaced file capabilities
mips/signal: In force_fcr31_sig return in the impossible case
signal: Remove kernel interal si_code magic
fcntl: Don't use ambiguous SIG_POLL si_codes
prctl: Allow local CAP_SYS_ADMIN changing exe_file
security: Use user_namespace::level to avoid redundant iterations in cap_capable()
userns,pidns: Verify the userns for new pid namespaces
signal/testing: Don't look for __SI_FAULT in userspace
signal/mips: Document a conflict with SI_USER with SIGFPE
signal/sparc: Document a conflict with SI_USER with SIGFPE
signal/ia64: Document a conflict with SI_USER with SIGFPE
signal/alpha: Document a conflict with SI_USER for SIGTRAP
git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit
Pull audit updates from Paul Moore:
"A small pull request for audit this time, only four patches and only
two with any real code changes.
Those two changes are the removal of a pointless SELinux AVC
initialization audit event and a fix to improve the audit timestamp
overhead.
The other two patches are comment cleanup and administrative updates,
nothing very exciting.
Everything passes our tests"
* tag 'audit-pr-20170907' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit:
audit: update the function comments
selinux: remove AVC init audit log message
audit: update the audit info in MAINTAINERS
audit: Reduce overhead using a coarse clock
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull secureexec update from Kees Cook:
"This series has the ultimate goal of providing a sane stack rlimit
when running set*id processes.
To do this, the bprm_secureexec LSM hook is collapsed into the
bprm_set_creds hook so the secureexec-ness of an exec can be
determined early enough to make decisions about rlimits and the
resulting memory layouts. Other logic acting on the secureexec-ness of
an exec is similarly consolidated. Capabilities needed some special
handling, but the refactoring removed other special handling, so that
was a wash"
* tag 'secureexec-v4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
exec: Consolidate pdeath_signal clearing
exec: Use sane stack rlimit under secureexec
exec: Consolidate dumpability logic
smack: Remove redundant pdeath_signal clearing
exec: Use secureexec for clearing pdeath_signal
exec: Use secureexec for setting dumpability
LSM: drop bprm_secureexec hook
commoncap: Move cap_elevated calculation into bprm_set_creds
commoncap: Refactor to remove bprm_secureexec hook
smack: Refactor to remove bprm_secureexec hook
selinux: Refactor to remove bprm_secureexec hook
apparmor: Refactor to remove bprm_secureexec hook
binfmt: Introduce secureexec flag
exec: Correct comments about "point of no return"
exec: Rename bprm->cred_prepared to called_set_creds
In the process of normalizing audit log messages, it was noticed that the AVC
initialization code registered an audit log KERNEL record that didn't fit the
standard format. In the process of attempting to normalize it it was
determined that this record was not even necessary. Remove it.
Ref: http://marc.info/?l=selinux&m=149614868525826&w=2
See: https://github.com/linux-audit/audit-kernel/issues/48
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Steve Grubb <sgrubb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
Make the position an in/out argument like all the other read/write
helpers and and make the buf argument a void pointer.
Use proper ssize_t and size_t types for the return value and count
argument, move the offset last and make it an in/out argument like
all other read/write helpers, and make the buf argument a void pointer
to get rid of lots of casts in the callers.
Root in a non-initial user ns cannot be trusted to write a traditional
security.capability xattr. If it were allowed to do so, then any
unprivileged user on the host could map his own uid to root in a private
namespace, write the xattr, and execute the file with privilege on the
host.
However supporting file capabilities in a user namespace is very
desirable. Not doing so means that any programs designed to run with
limited privilege must continue to support other methods of gaining and
dropping privilege. For instance a program installer must detect
whether file capabilities can be assigned, and assign them if so but set
setuid-root otherwise. The program in turn must know how to drop
partial capabilities, and do so only if setuid-root.
This patch introduces v3 of the security.capability xattr. It builds a
vfs_ns_cap_data struct by appending a uid_t rootid to struct
vfs_cap_data. This is the absolute uid_t (that is, the uid_t in user
namespace which mounted the filesystem, usually init_user_ns) of the
root id in whose namespaces the file capabilities may take effect.
When a task asks to write a v2 security.capability xattr, if it is
privileged with respect to the userns which mounted the filesystem, then
nothing should change. Otherwise, the kernel will transparently rewrite
the xattr as a v3 with the appropriate rootid. This is done during the
execution of setxattr() to catch user-space-initiated capability writes.
Subsequently, any task executing the file which has the noted kuid as
its root uid, or which is in a descendent user_ns of such a user_ns,
will run the file with capabilities.
Similarly when asking to read file capabilities, a v3 capability will
be presented as v2 if it applies to the caller's namespace.
If a task writes a v3 security.capability, then it can provide a uid for
the xattr so long as the uid is valid in its own user namespace, and it
is privileged with CAP_SETFCAP over its namespace. The kernel will
translate that rootid to an absolute uid, and write that to disk. After
this, a task in the writer's namespace will not be able to use those
capabilities (unless rootid was 0), but a task in a namespace where the
given uid is root will.
Only a single security.capability xattr may exist at a time for a given
file. A task may overwrite an existing xattr so long as it is
privileged over the inode. Note this is a departure from previous
semantics, which required privilege to remove a security.capability
xattr. This check can be re-added if deemed useful.
This allows a simple setxattr to work, allows tar/untar to work, and
allows us to tar in one namespace and untar in another while preserving
the capability, without risking leaking privilege into a parent
namespace.
Example using tar:
$ cp /bin/sleep sleepx
$ mkdir b1 b2
$ lxc-usernsexec -m b:0:100000:1 -m b:1:$(id -u):1 -- chown 0:0 b1
$ lxc-usernsexec -m b:0:100001:1 -m b:1:$(id -u):1 -- chown 0:0 b2
$ lxc-usernsexec -m b:0:100000:1000 -- tar --xattrs-include=security.capability --xattrs -cf b1/sleepx.tar sleepx
$ lxc-usernsexec -m b:0:100001:1000 -- tar --xattrs-include=security.capability --xattrs -C b2 -xf b1/sleepx.tar
$ lxc-usernsexec -m b:0:100001:1000 -- getcap b2/sleepx
b2/sleepx = cap_sys_admin+ep
# /opt/ltp/testcases/bin/getv3xattr b2/sleepx
v3 xattr, rootid is 100001
A patch to linux-test-project adding a new set of tests for this
functionality is in the nsfscaps branch at github.com/hallyn/ltp
Changelog:
Nov 02 2016: fix invalid check at refuse_fcap_overwrite()
Nov 07 2016: convert rootid from and to fs user_ns
(From ebiederm: mar 28 2017)
commoncap.c: fix typos - s/v4/v3
get_vfs_caps_from_disk: clarify the fs_ns root access check
nsfscaps: change the code split for cap_inode_setxattr()
Apr 09 2017:
don't return v3 cap for caps owned by current root.
return a v2 cap for a true v2 cap in non-init ns
Apr 18 2017:
. Change the flow of fscap writing to support s_user_ns writing.
. Remove refuse_fcap_overwrite(). The value of the previous
xattr doesn't matter.
Apr 24 2017:
. incorporate Eric's incremental diff
. move cap_convert_nscap to setxattr and simplify its usage
May 8, 2017:
. fix leaking dentry refcount in cap_inode_getsecurity
Signed-off-by: Serge Hallyn <serge@hallyn.com>
nf_hook_ops are not supposed to change at runtime. nf_register_net_hooks
and nf_unregister_net_hooks are working with const nf_hook_ops.
So mark the non-const nf_hook_ops structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
This patch allows genfscon per-file labeling for cgroupfs. For instance,
this allows to label the "release_agent" file within each
cgroup mount and limit writes to it.
Signed-off-by: Antonio Murdaca <amurdaca@redhat.com>
[PM: subject line and merge tweaks]
Update my email address since epoch.ncsc.mil no longer exists.
MAINTAINERS and CREDITS are already correct.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
There is a strange __GFP_NOMEMALLOC usage pattern in SELinux,
specifically GFP_ATOMIC | __GFP_NOMEMALLOC which doesn't make much
sense. GFP_ATOMIC on its own allows to access memory reserves while
__GFP_NOMEMALLOC dictates we cannot use memory reserves. Replace this
with the much more sane GFP_NOWAIT in the AVC code as we can tolerate
memory allocation failures in that code.
Signed-off-by: Michal Hocko <mhocko@kernel.org>
As systemd ramps up enabling NNP (NoNewPrivileges) for system services,
it is increasingly breaking SELinux domain transitions for those services
and their descendants. systemd enables NNP not only for services whose
unit files explicitly specify NoNewPrivileges=yes but also for services
whose unit files specify any of the following options in combination with
running without CAP_SYS_ADMIN (e.g. specifying User= or a
CapabilityBoundingSet= without CAP_SYS_ADMIN): SystemCallFilter=,
SystemCallArchitectures=, RestrictAddressFamilies=, RestrictNamespaces=,
PrivateDevices=, ProtectKernelTunables=, ProtectKernelModules=,
MemoryDenyWriteExecute=, or RestrictRealtime= as per the systemd.exec(5)
man page.
The end result is bad for the security of both SELinux-disabled and
SELinux-enabled systems. Packagers have to turn off these
options in the unit files to preserve SELinux domain transitions. For
users who choose to disable SELinux, this means that they miss out on
at least having the systemd-supported protections. For users who keep
SELinux enabled, they may still be missing out on some protections
because it isn't necessarily guaranteed that the SELinux policy for
that service provides the same protections in all cases.
commit 7b0d0b40cd78 ("selinux: Permit bounded transitions under
NO_NEW_PRIVS or NOSUID.") allowed bounded transitions under NNP in
order to support limited usage for sandboxing programs. However,
defining typebounds for all of the affected service domains
is impractical to implement in policy, since typebounds requires us
to ensure that each domain is allowed everything all of its descendant
domains are allowed, and this has to be repeated for the entire chain
of domain transitions. There is no way to clone all allow rules from
descendants to their ancestors in policy currently, and doing so would
be undesirable even if it were practical, as it requires leaking
permissions to objects and operations into ancestor domains that could
weaken their own security in order to allow them to the descendants
(e.g. if a descendant requires execmem permission, then so do all of
its ancestors; if a descendant requires execute permission to a file,
then so do all of its ancestors; if a descendant requires read to a
symbolic link or temporary file, then so do all of its ancestors...).
SELinux domains are intentionally not hierarchical / bounded in this
manner normally, and making them so would undermine their protections
and least privilege.
We have long had a similar tension with SELinux transitions and nosuid
mounts, albeit not as severe. Users often have had to choose between
retaining nosuid on a mount and allowing SELinux domain transitions on
files within those mounts. This likewise leads to unfortunate tradeoffs
in security.
Decouple NNP/nosuid from SELinux transitions, so that we don't have to
make a choice between them. Introduce a nnp_nosuid_transition policy
capability that enables transitions under NNP/nosuid to be based on
a permission (nnp_transition for NNP; nosuid_transition for nosuid)
between the old and new contexts in addition to the current support
for bounded transitions. Domain transitions can then be allowed in
policy without requiring the parent to be a strict superset of all of
its children.
With this change, systemd unit files can be left unmodified from upstream.
SELinux-disabled and SELinux-enabled users will benefit from retaining any
of the systemd-provided protections. SELinux policy will only need to
be adapted to enable the new policy capability and to allow the
new permissions between domain pairs as appropriate.
NB: Allowing nnp_transition between two contexts opens up the potential
for the old context to subvert the new context by installing seccomp
filters before the execve. Allowing nosuid_transition between two contexts
opens up the potential for a context transition to occur on a file from
an untrusted filesystem (e.g. removable media or remote filesystem). Use
with care.
This removes the redundant pdeath_signal clearing in Smack: the check in
smack_bprm_committing_creds() matches the check in smack_bprm_set_creds()
(which used to be in the now-removed smack_bprm_securexec() hook) and
since secureexec is now being checked for clearing pdeath_signal, this
is redundant to the common exec code.
Reviewed-by: James Morris <james.l.morris@oracle.com>
Reviewed-by: Casey Schaufler <casey@schaufler-ca.com>
This removes the bprm_secureexec hook since the logic has been folded into
the bprm_set_creds hook for all LSMs now.
Cc: Eric W. Biederman <ebiederm@xmission.com>
Reviewed-by: John Johansen <john.johansen@canonical.com>
Acked-by: James Morris <james.l.morris@oracle.com>
Instead of a separate function, open-code the cap_elevated test, which
lets us entirely remove bprm->cap_effective (to use the local "effective"
variable instead), and more accurately examine euid/egid changes via the
existing local "is_setid".
The following LTP tests were run to validate the changes:
# ./runltp -f syscalls -s cap
# ./runltp -f securebits
# ./runltp -f cap_bounds
# ./runltp -f filecaps
All kernel selftests for capabilities and exec continue to pass as well.
Reviewed-by: Andy Lutomirski <luto@kernel.org>
The commoncap implementation of the bprm_secureexec hook is the only LSM
that depends on the final call to its bprm_set_creds hook (since it may
be called for multiple files, it ignores bprm->called_set_creds). As a
result, it cannot safely _clear_ bprm->secureexec since other LSMs may
have set it. Instead, remove the bprm_secureexec hook by introducing a
new flag to bprm specific to commoncap: cap_elevated. This is similar to
cap_effective, but that is used for a specific subset of elevated
privileges, and exists solely to track state from bprm_set_creds to
bprm_secureexec. As such, it will be removed in the next patch.
Here, set the new bprm->cap_elevated flag when setuid/setgid has happened
from bprm_fill_uid() or fscapabilities have been prepared. This temporarily
moves the bprm_secureexec hook to a static inline. The helper will be
removed in the next patch; this makes the step easier to review and bisect,
since this does not introduce any changes to inputs nor outputs to the
"elevated privileges" calculation.
The new flag is merged with the bprm->secureexec flag in setup_new_exec()
since this marks the end of any further prepare_binprm() calls.
The Smack bprm_secureexec hook can be merged with the bprm_set_creds
hook since it's dealing with the same information, and all of the details
are finalized during the first call to the bprm_set_creds hook via
prepare_binprm() (subsequent calls due to binfmt_script, etc, are ignored
via bprm->called_set_creds).
Here, the test can just happen at the end of the bprm_set_creds hook,
and the bprm_secureexec hook can be dropped.
The SELinux bprm_secureexec hook can be merged with the bprm_set_creds
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Paul Moore <paul@paul-moore.com>
Tested-by: Paul Moore <paul@paul-moore.com>
The AppArmor bprm_secureexec hook can be merged with the bprm_set_creds
Here, all the comments describe how secureexec is actually calculated
during bprm_set_creds, so this actually does it, drops the bprm flag that
was being used internally by AppArmor, and drops the bprm_secureexec hook.
Acked-by: John Johansen <john.johansen@canonical.com>
The cred_prepared bprm flag has a misleading name. It has nothing to do
with the bprm_prepare_cred hook, and actually tracks if bprm_set_creds has
been called. Rename this flag and improve its comment.
Cc: Casey Schaufler <casey@schaufler-ca.com>
We no longer place these on a list so they can be const.
For PF_UNIX, SOCK_RAW is synonymous with SOCK_DGRAM (cf.
net/unix/af_unix.c). This is a tad obscure, but libpcap uses it.
Signed-off-by: Luis Ressel <aranea@aixah.de>
cap_capable()
When ns->level is not larger then cred->user_ns->level,
then ns can't be cred->user_ns's descendant, and
there is no a sense to search in parents.
So, break the cycle earlier and skip needless iterations.
v2: Change comment on suggested by Andy Lutomirski.
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Pull structure randomization updates from Kees Cook:
"Now that IPC and other changes have landed, enable manual markings for
randstruct plugin, including the task_struct.
This is the rest of what was staged in -next for the gcc-plugins, and
comes in three patches, largest first:
- mark "easy" structs with __randomize_layout
- mark task_struct with an optional anonymous struct to isolate the
__randomize_layout section
- mark structs to opt _out_ of automated marking (which will come
later)
And, FWIW, this continues to pass allmodconfig (normal and patched to
enable gcc-plugins) builds of x86_64, i386, arm64, arm, powerpc, and
s390 for me"
* tag 'gcc-plugins-v4.13-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
randstruct: opt-out externally exposed function pointer structs
task_struct: Allow randomized layout
randstruct: Mark various structs for randomization
After rcu conversions performance degradation in forward tests isn't that
noticeable anymore.
See next patch for some numbers.
A followup patcg could then also remove genid from the policies
as we do not cache bundles anymore.
Since commit a79be238600d1a03 ("selinux: Use task_alloc hook rather than
task_create hook") changed to use task_alloc hook, task_create hook is
no longer used.
