[ Upstream commit a5cd1ab7ab679d252a6d2f483eee7d45ebf2040c ]
Remove inappropriate use of ntohs() and assign the
port value directly.
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
[ Upstream commit b97df7c098c531010e445da88d02b7bf7bf59ef6 ]
security_sid_to_context() expects a pointer to an u32 as the address
where to store the length of the computed context.
Reported by sparse:
security/selinux/xfrm.c:359:39: warning: incorrect type in arg 4
(different signedness)
security/selinux/xfrm.c:359:39: expected unsigned int
[usertype] *scontext_len
security/selinux/xfrm.c:359:39: got int *
Signed-off-by: Christian Göttsche <cgzones@googlemail.com>
[PM: wrapped commit description]
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit ecff30575b5ad0eda149aadad247b7f75411fd47 ]
The usual LSM hook "bail on fail" scheme doesn't work for cases where
a security module may return an error code indicating that it does not
recognize an input. In this particular case Smack sees a mount option
that it recognizes, and returns 0. A call to a BPF hook follows, which
returns -ENOPARAM, which confuses the caller because Smack has processed
its data.
The SELinux hook incorrectly returns 1 on success. There was a time
when this was correct, however the current expectation is that it
return 0 on success. This is repaired.
Reported-by: syzbot+d1e3b1d92d25abf97943@syzkaller.appspotmail.com
Acked-by: James Morris <jamorris@linux.microsoft.com>
[ Upstream commit 39844b7e3084baecef52d1498b5fa81afa2cefa9 ]
__setup() handlers should return 1 if the parameter is handled.
Returning 0 causes the entire string to be added to init's
environment strings (limited to 32 strings), unnecessarily polluting it.
Using the documented strings "TOMOYO_loader=string1" and
"TOMOYO_trigger=string2" causes an Unknown parameter message:
Unknown kernel command line parameters
"BOOT_IMAGE=/boot/bzImage-517rc5 TOMOYO_loader=string1 \
TOMOYO_trigger=string2", will be passed to user space.
and these strings are added to init's environment string space:
Run /sbin/init as init process
with arguments:
/sbin/init
with environment:
HOME=/
TERM=linux
With this change, these __setup handlers act as expected,
and init's environment is not polluted with these strings.
Fixes: 0e4ae0e0dec63 ("TOMOYO: Make several options configurable.")
Reported-by: Igor Zhbanov <i.zhbanov@omprussia.ru>
Link: https://lore.kernel.org/r/64644a2f-4a20-bab3-1e15-3b2cdd0defe3@omprussia.ru
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: tomoyo-dev-en@lists.osdn.me
Cc: "Serge E. Hallyn" <serge@hallyn.com>
commit c51abd96837f600d8fd940b6ab8e2da578575504 upstream.
In many cases, keyctl_pkey_params_get_2() is validating the user buffer
lengths against the wrong algorithm properties. Fix it to check against
the correct properties.
Probably this wasn't noticed before because for all asymmetric keys of
the "public_key" subtype, max_data_size == max_sig_size == max_enc_size
== max_dec_size. However, this isn't necessarily true for the
"asym_tpm" subtype (it should be, but it's not strictly validated). Of
course, future key types could have different values as well.
Fixes: 00d60fd3b932 ("KEYS: Provide keyctls to drive the new key type ops for asymmetric keys [ver #2]")
Cc: <stable@vger.kernel.org> # v4.20+
Reviewed-by: Jarkko Sakkinen <jarkko@kernel.org>
Signed-off-by: Jarkko Sakkinen <jarkko@kernel.org>
commit 89677197ae709eb1ab3646952c44f6a171c9e74c upstream.
Before printing a policy rule scan for inactive LSM labels in the policy
rule. Inactive LSM labels are identified by args_p != NULL and
rule == NULL.
Fixes: 483ec26eed42 ("ima: ima/lsm policy rule loading logic bug fixes")
Signed-off-by: Stefan Berger <stefanb@linux.ibm.com>
Cc: <stable@vger.kernel.org> # v5.6+
Acked-by: Christian Brauner <brauner@kernel.org>
[zohar@linux.ibm.com: Updated "Fixes" tag]
Signed-off-by: Mimi Zohar <zohar@linux.ibm.com>
commit bb8e52e4906f148c2faf6656b5106cf7233e9301 upstream.
Commit c2426d2ad5027 ("ima: added support for new kernel cmdline parameter
ima_template_fmt") introduced an additional check on the ima_template
variable to avoid multiple template selection.
Unfortunately, ima_template could be also set by the setup function of the
ima_hash= parameter, when it calls ima_template_desc_current(). This causes
attempts to choose a new template with ima_template= or with
ima_template_fmt=, after ima_hash=, to be ignored.
Achieve the goal of the commit mentioned with the new static variable
template_setup_done, so that template selection requests after ima_hash=
are not ignored.
Finally, call ima_init_template_list(), if not already done, to initialize
the list of templates before lookup_template_desc() is called.
Reported-by: Guo Zihua <guozihua@huawei.com>
Signed-off-by: Roberto Sassu <roberto.sassu@huawei.com>
Cc: stable@vger.kernel.org
Fixes: c2426d2ad5027 ("ima: added support for new kernel cmdline parameter ima_template_fmt")
commit f7333b9572d0559e00352a926c92f29f061b4569 upstream.
The removal of ima_dir currently fails since ima_policy still exists, so
remove the ima_policy file before removing the directory.
Fixes: 4af4662fa4a9 ("integrity: IMA policy")
commit 83230351c523b04ff8a029a4bdf97d881ecb96fc upstream.
audit_log_start() returns audit_buffer pointer on success or NULL on
error, so it is better to check the return value of it.
Fixes: 3323eec921ef ("integrity: IMA as an integrity service provider")
Signed-off-by: Xiaoke Wang <xkernel.wang@foxmail.com>
Reviewed-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 2e08df3c7c4e4e74e3dd5104c100f0bf6288aaa8 ]
This patch try to fix potential memleak in error branch.
Fixes: ba6418623385 ("selinux: new helper - selinux_add_opt()")
Signed-off-by: Bernard Zhao <bernard@vivo.com>
[PM: tweak the subject line, add Fixes tag]
commit 732bc2ff080c447f8524f40c970c481f5da6eed3 upstream.
Clang static analysis reports this warning
hooks.c:5765:6: warning: 4th function call argument is an uninitialized
value
if (selinux_xfrm_postroute_last(sksec->sid, skb, &ad, proto))
selinux_parse_skb() can return ok without setting proto. The later call
to selinux_xfrm_postroute_last() does an early check of proto and can
return ok if the garbage proto value matches. So initialize proto.
Fixes: eef9b41622f2 ("selinux: cleanup selinux_xfrm_sock_rcv_skb() and selinux_xfrm_postroute_last()")
Signed-off-by: Tom Rix <trix@redhat.com>
[PM: typo/spelling and checkpatch.pl description fixes]
[ Upstream commit 04e57a2d952bbd34bc45744e72be3eecdc344294 ]
If tomoyo is used in a testing/fuzzing environment in learning mode,
for lots of domains the quota will be exceeded and stay exceeded
for prolonged periods of time. In such cases it's pointless (and slow)
to walk the whole acl list again and again just to rediscover that
the quota is exceeded. We already have the TOMOYO_DIF_QUOTA_WARNED flag
that notes the overflow condition. Check it early to avoid the slowdown.
[penguin-kernel]
This patch causes a user visible change that the learning mode will not be
automatically resumed after the quota is increased. To resume the learning
mode, administrator will need to explicitly clear TOMOYO_DIF_QUOTA_WARNED
flag after increasing the quota. But I think that this change is generally
preferable, for administrator likely wants to optimize the acl list for
that domain before increasing the quota, or that domain likely hits the
quota again. Therefore, don't try to care to clear TOMOYO_DIF_QUOTA_WARNED
flag automatically when the quota for that domain changed.
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
commit cbfcd13be5cb2a07868afe67520ed181956579a7 upstream.
Current code contains a lot of racy patterns when converting an
ocontext's context structure to an SID. This is being done in a "lazy"
fashion, such that the SID is looked up in the SID table only when it's
first needed and then cached in the "sid" field of the ocontext
structure. However, this is done without any locking or memory barriers
and is thus unsafe.
Between commits 24ed7fdae669 ("selinux: use separate table for initial
SID lookup") and 66f8e2f03c02 ("selinux: sidtab reverse lookup hash
table"), this race condition lead to an actual observable bug, because a
pointer to the shared sid field was passed directly to
sidtab_context_to_sid(), which was using this location to also store an
intermediate value, which could have been read by other threads and
interpreted as an SID. In practice this caused e.g. new mounts to get a
wrong (seemingly random) filesystem context, leading to strange denials.
This bug has been spotted in the wild at least twice, see [1] and [2].
Fix the race condition by making all the racy functions use a common
helper that ensures the ocontext::sid accesses are made safely using the
appropriate SMP constructs.
Note that security_netif_sid() was populating the sid field of both
contexts stored in the ocontext, but only the first one was actually
used. The SELinux wiki's documentation on the "netifcon" policy
statement [3] suggests that using only the first context is intentional.
I kept only the handling of the first context here, as there is really
no point in doing the SID lookup for the unused one.
I wasn't able to reproduce the bug mentioned above on any kernel that
includes commit 66f8e2f03c02, even though it has been reported that the
issue occurs with that commit, too, just less frequently. Thus, I wasn't
able to verify that this patch fixes the issue, but it makes sense to
avoid the race condition regardless.
[1] https://github.com/containers/container-selinux/issues/89
[2] https://lists.fedoraproject.org/archives/list/selinux@lists.fedoraproject.org/thread/6DMTAMHIOAOEMUAVTULJD45JZU7IBAFM/
[3] https://selinuxproject.org/page/NetworkStatements#netifcon
Cc: Xinjie Zheng <xinjie@google.com>
Reported-by: Sujithra Periasamy <sujithra@google.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com>
[vijayb: Backport contextual differences are due to v5.10 RCU related
changes are not in 5.4]
Signed-off-by: Vijay Balakrishna <vijayb@linux.microsoft.com>
commit a52f8a59aef46b59753e583bf4b28fccb069ce64 upstream.
Clang has never correctly compiled the FORTIFY_SOURCE defenses due to
a couple bugs:
Eliding inlines with matching __builtin_* names
https://bugs.llvm.org/show_bug.cgi?id=50322
Incorrect __builtin_constant_p() of some globals
https://bugs.llvm.org/show_bug.cgi?id=41459
In the process of making improvements to the FORTIFY_SOURCE defenses, the
first (silent) bug (coincidentally) becomes worked around, but exposes
the latter which breaks the build. As such, Clang must not be used with
CONFIG_FORTIFY_SOURCE until at least latter bug is fixed (in Clang 13),
and the fortify routines have been rearranged.
Update the Kconfig to reflect the reality of the current situation.
Acked-by: Nick Desaulniers <ndesaulniers@google.com>
Link: https://lore.kernel.org/lkml/CAKwvOd=A+ueGV2ihdy5GtgR2fQbcXjjAtVxv3=cPjffpebZB7A@mail.gmail.com
Cc: Nathan Chancellor <nathan@kernel.org>
[ Upstream commit d108370c644b153382632b3e5511ade575c91c86 ]
clang static analysis reports this representative problem:
label.c:1463:16: warning: Assigned value is garbage or undefined
label->hname = name;
In aa_update_label_name(), this the problem block of code
if (aa_label_acntsxprint(&name, ...) == -1)
return res;
On failure, aa_label_acntsxprint() has a more complicated return
that just -1. So check for a negative return.
It was also noted that the aa_label_acntsxprint() main comment refers
to a nonexistent parameter, so clean up the comment.
Fixes: f1bd904175e8 ("apparmor: add the base fns() for domain labels")
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: John Johansen <john.johansen@canonical.com>
[ Upstream commit 0934ad42bb2c5df90a1b9de690f93de735b622fe ]
syzbot is reporting UAF at cipso_v4_doi_search() [1], for smk_cipso_doi()
is calling kfree() without removing from the cipso_v4_doi_list list after
netlbl_cfg_cipsov4_map_add() returned an error. We need to use
netlbl_cfg_cipsov4_del() in order to remove from the list and wait for
RCU grace period before kfree().
Link: https://syzkaller.appspot.com/bug?extid=93dba5b91f0fed312cbd [1]
Reported-by: syzbot <syzbot+93dba5b91f0fed312cbd@syzkaller.appspotmail.com>
Fixes: 6c2e8ac0953fccdd ("netlabel: Update kernel configuration API")
[ Upstream commit f91488ee15bd3cac467e2d6a361fc2d34d1052ae ]
syzbot is reporting kernel panic at smk_cipso_doi() due to memory
allocation fault injection [1]. The reason for need to use panic() was
not explained. But since no fix was proposed for 18 months, for now
let's use __GFP_NOFAIL for utilizing syzbot resource on other bugs.
Link: https://syzkaller.appspot.com/bug?extid=89731ccb6fec15ce1c22 [1]
Reported-by: syzbot <syzbot+89731ccb6fec15ce1c22@syzkaller.appspotmail.com>
[ Upstream commit 0817534ff9ea809fac1322c5c8c574be8483ea57 ]
Syzkaller reported use-after-free bug as described in [1]. The bug is
triggered when smk_set_cipso() tries to free stale category bitmaps
while there are concurrent reader(s) using the same bitmaps.
Wait for RCU grace period to finish before freeing the category bitmaps
in smk_set_cipso(). This makes sure that there are no more readers using
the stale bitmaps and freeing them should be safe.
[1] https://lore.kernel.org/netdev/000000000000a814c505ca657a4e@google.com/
Reported-by: syzbot+3f91de0b813cc3d19a80@syzkaller.appspotmail.com
Signed-off-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
commit 32ba540f3c2a7ef61ed5a577ce25069a3d714fc9 upstream.
The evm_fixmode is only configurable by command-line option and it is never
modified outside initcalls, so declaring it with __ro_after_init is better.
Signed-off-by: Austin Kim <austin.kim@lge.com>
commit 52f88693378a58094c538662ba652aff0253c4fe upstream.
Since binder was integrated with selinux, it has passed
'struct task_struct' associated with the binder_proc
to represent the source and target of transactions.
The conversion of task to SID was then done in the hook
implementations. It turns out that there are race conditions
which can result in an incorrect security context being used.
Fix by using the 'struct cred' saved during binder_open and pass
it to the selinux subsystem.
Cc: stable@vger.kernel.org # 5.14 (need backport for earlier stables)
Fixes: 79af73079d75 ("Add security hooks to binder and implement the hooks for SELinux.")
Suggested-by: Jann Horn <jannh@google.com>
Signed-off-by: Todd Kjos <tkjos@google.com>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
commit 9801ca279ad37f72f71234fa81722afd95a3f997 upstream.
Strangely I hadn't had noticed the existence of the list_entry_is_head()
in apparmor code when added the same one in the list.h. Luckily it's
fully identical and didn't break builds. In any case we don't need a
duplicate anymore, thus remove it from apparmor code.
Link: https://lkml.kernel.org/r/20201208100639.88182-1-andriy.shevchenko@linux.intel.com
Fixes: e130816164e244 ("include/linux/list.h: add a macro to test if entry is pointing to the head")
Acked-by: John Johansen <john.johansen@canonical.com>
Cc: "Serge E . Hallyn " <serge@hallyn.com>
Signed-off-by: Nobuhiro Iwamatsu (CIP) <nobuhiro1.iwamatsu@toshiba.co.jp>
[ Upstream commit 6d14f5c7028eea70760df284057fe198ce7778dd ]
In the smk_access_entry() function, if no matching rule is found
in the rust_list, a negative error code will be used to perform bit
operations with the MAY_ enumeration value. This is semantically
wrong. This patch fixes this issue.
Signed-off-by: Tianjia Zhang <tianjia.zhang@linux.alibaba.com>
commit 8510505d55e194d3f6c9644c9f9d12c4f6b0395a upstream.
MD5 is a weak digest algorithm that shouldn't be used for cryptographic
operation. It hinders the efficiency of a patch set that aims to limit
the digests allowed for the extended file attribute namely security.ima.
MD5 is no longer a requirement for IMA, nor should it be used there.
The sole place where we still use the MD5 algorithm inside IMA is setting
the ima_hash algorithm to MD5, if the user supplies 'ima_hash=md5'
parameter on the command line. With commit ab60368ab6a4 ("ima: Fallback
to the builtin hash algorithm"), setting "ima_hash=md5" fails gracefully
when CRYPTO_MD5 is not set:
ima: Can not allocate md5 (reason: -2)
ima: Allocating md5 failed, going to use default hash algorithm sha256
Remove the CRYPTO_MD5 dependency for IMA.
Signed-off-by: THOBY Simon <Simon.THOBY@viveris.fr>
Reviewed-by: Lakshmi Ramasubramanian <nramas@linux.microsoft.com>
[zohar@linux.ibm.com: include commit number in patch description for
stable.]
Cc: stable@vger.kernel.org # 4.17
commit a32ad90426a9c8eb3915eed26e08ce133bd9e0da upstream.
With W=1 build, the compiler throws warning message as below:
security/integrity/ima/ima_mok.c:24:12: warning:
no previous prototype for ‘ima_mok_init’ [-Wmissing-prototypes]
__init int ima_mok_init(void)
Silence the warning by adding static keyword to ima_mok_init().
Fixes: 41c89b64d718 ("IMA: create machine owner and blacklist keyrings")
commit 49ec114a6e62d8d320037ce71c1aaf9650b3cafd upstream.
Oops, I failed to update subject line.
From 07571157c91b98ce1a4aa70967531e64b78e8346 Mon Sep 17 00:00:00 2001
From: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Date: Mon, 12 Apr 2021 22:25:06 +0900
Subject: smackfs: restrict bytes count in smk_set_cipso()
Commit 7ef4c19d245f3dc2 ("smackfs: restrict bytes count in smackfs write
functions") missed that count > SMK_CIPSOMAX check applies to only
format == SMK_FIXED24_FMT case.
Reported-by: syzbot <syzbot+77c53db50c9fff774e8e@syzkaller.appspotmail.com>
[ Upstream commit 648f2c6100cfa18e7dfe43bc0b9c3b73560d623c ]
In the field, we have seen lots of allocation failure from the call
path below.
06-03 13:29:12.999 1010315 31557 31557 W Binder : 31542_2: page allocation failure: order:0, mode:0x800(GFP_NOWAIT), nodemask=(null),cpuset=background,mems_allowed=0
06-03 13:29:12.999 1010315 31557 31557 W Call trace:
06-03 13:29:12.999 1010315 31557 31557 W : dump_backtrace.cfi_jt+0x0/0x8
06-03 13:29:12.999 1010315 31557 31557 W : dump_stack+0xc8/0x14c
06-03 13:29:12.999 1010315 31557 31557 W : warn_alloc+0x158/0x1c8
06-03 13:29:12.999 1010315 31557 31557 W : __alloc_pages_slowpath+0x9d8/0xb80
06-03 13:29:12.999 1010315 31557 31557 W : __alloc_pages_nodemask+0x1c4/0x430
06-03 13:29:12.999 1010315 31557 31557 W : allocate_slab+0xb4/0x390
06-03 13:29:12.999 1010315 31557 31557 W : ___slab_alloc+0x12c/0x3a4
06-03 13:29:12.999 1010315 31557 31557 W : kmem_cache_alloc+0x358/0x5e4
06-03 13:29:12.999 1010315 31557 31557 W : avc_alloc_node+0x30/0x184
06-03 13:29:12.999 1010315 31557 31557 W : avc_update_node+0x54/0x4f0
06-03 13:29:12.999 1010315 31557 31557 W : avc_has_extended_perms+0x1a4/0x460
06-03 13:29:12.999 1010315 31557 31557 W : selinux_file_ioctl+0x320/0x3d0
06-03 13:29:12.999 1010315 31557 31557 W : __arm64_sys_ioctl+0xec/0x1fc
06-03 13:29:12.999 1010315 31557 31557 W : el0_svc_common+0xc0/0x24c
06-03 13:29:12.999 1010315 31557 31557 W : el0_svc+0x28/0x88
06-03 13:29:12.999 1010315 31557 31557 W : el0_sync_handler+0x8c/0xf0
06-03 13:29:12.999 1010315 31557 31557 W : el0_sync+0x1a4/0x1c0
06-03 13:29:12.999 1010315 31557 31557 W SLUB : Unable to allocate memory on node -1, gfp=0x900(GFP_NOWAIT|__GFP_ZERO)
06-03 13:29:12.999 1010315 31557 31557 W cache : avc_node, object size: 72, buffer size: 80, default order: 0, min order: 0
06-03 13:29:12.999 1010315 31557 31557 W node 0 : slabs: 57, objs: 2907, free: 0
06-03 13:29:12.999 1010161 10686 10686 W SLUB : Unable to allocate memory on node -1, gfp=0x900(GFP_NOWAIT|__GFP_ZERO)
06-03 13:29:12.999 1010161 10686 10686 W cache : avc_node, object size: 72, buffer size: 80, default order: 0, min order: 0
06-03 13:29:12.999 1010161 10686 10686 W node 0 : slabs: 57, objs: 2907, free: 0
06-03 13:29:13.000 1010161 10686 10686 W SLUB : Unable to allocate memory on node -1, gfp=0x900(GFP_NOWAIT|__GFP_ZERO)
06-03 13:29:13.000 1010161 10686 10686 W cache : avc_node, object size: 72, buffer size: 80, default order: 0, min order: 0
06-03 13:29:13.000 1010161 10686 10686 W node 0 : slabs: 57, objs: 2907, free: 0
06-03 13:29:13.000 10230 30892 30892 W SLUB : Unable to allocate memory on node -1, gfp=0x900(GFP_NOWAIT|__GFP_ZERO)
06-03 13:29:13.000 10230 30892 30892 W cache : avc_node, object size: 72, buffer size: 80, default order: 0, min order: 0
06-03 13:29:13.000 10230 30892 30892 W node 0 : slabs: 57, objs: 2907, free: 0
Based on [1], selinux is tolerate for failure of memory allocation.
Then, use __GFP_NOWARN together.
[1] 476accbe2f6e ("selinux: use GFP_NOWAIT in the AVC kmem_caches")
Signed-off-by: Minchan Kim <minchan@kernel.org>
[PM: subj fix, line wraps, normalized commit refs]
[ Upstream commit 49219d9b8785ba712575c40e48ce0f7461254626 ]
EVM_SETUP_COMPLETE is defined as 0x80000000, which is larger than INT_MAX.
The "-fno-strict-overflow" compiler option properly prevents signaling
EVM that the EVM policy setup is complete. Define and read an unsigned
int.
Fixes: f00d79750712 ("EVM: Allow userspace to signal an RSA key has been loaded")
commit 9acc89d31f0c94c8e573ed61f3e4340bbd526d0c upstream.
EVM_ALLOW_METADATA_WRITES is an EVM initialization flag that can be set to
temporarily disable metadata verification until all xattrs/attrs necessary
to verify an EVM portable signature are copied to the file. This flag is
cleared when EVM is initialized with an HMAC key, to avoid that the HMAC is
calculated on unverified xattrs/attrs.
Currently EVM unnecessarily denies setting this flag if EVM is initialized
with a public key, which is not a concern as it cannot be used to trust
xattrs/attrs updates. This patch removes this limitation.
Fixes: ae1ba1676b88e ("EVM: Allow userland to permit modification of EVM-protected metadata")
Cc: stable@vger.kernel.org # 4.16.x
commit 9eea2904292c2d8fa98df141d3bf7c41ec9dc1b5 upstream.
evm_inode_init_security() requires an HMAC key to calculate the HMAC on
initial xattrs provided by LSMs. However, it checks generically whether a
key has been loaded, including also public keys, which is not correct as
public keys are not suitable to calculate the HMAC.
Originally, support for signature verification was introduced to verify a
possibly immutable initial ram disk, when no new files are created, and to
switch to HMAC for the root filesystem. By that time, an HMAC key should
have been loaded and usable to calculate HMACs for new files.
More recently support for requiring an HMAC key was removed from the
kernel, so that signature verification can be used alone. Since this is a
legitimate use case, evm_inode_init_security() should not return an error
when no HMAC key has been loaded.
This patch fixes this problem by replacing the evm_key_loaded() check with
a check of the EVM_INIT_HMAC flag in evm_initialized.
Fixes: 26ddabfe96b ("evm: enable EVM when X509 certificate is loaded")
Cc: stable@vger.kernel.org # 4.5.x
[ Upstream commit 6f090192f8225f52ba95d08785989688cb768cca ]
commit ad723674d675 ("x86/efi: move common keyring handler functions
to new file") leave this unused.
Fixes: ad723674d675 ("x86/efi: move common keyring handler functions to new file")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Link: https://lore.kernel.org/r/20191115130830.13320-1-yuehaibing@huawei.com
[ Upstream commit 56c5812623f95313f6a46fbf0beee7fa17c68bbf ]
This fixes CVE-2020-26541.
The Secure Boot Forbidden Signature Database, dbx, contains a list of now
revoked signatures and keys previously approved to boot with UEFI Secure
Boot enabled. The dbx is capable of containing any number of
EFI_CERT_X509_SHA256_GUID, EFI_CERT_SHA256_GUID, and EFI_CERT_X509_GUID
entries.
Currently when EFI_CERT_X509_GUID are contained in the dbx, the entries are
skipped.
Add support for EFI_CERT_X509_GUID dbx entries. When a EFI_CERT_X509_GUID
is found, it is added as an asymmetrical key to the .blacklist keyring.
Anytime the .platform keyring is used, the keys in the .blacklist keyring
are referenced, if a matching key is found, the key will be rejected.
[DH: Made the following changes:
- Added to have a config option to enable the facility. This allows a
Kconfig solution to make sure that pkcs7_validate_trust() is
enabled.[1][2]
- Moved the functions out from the middle of the blacklist functions.
- Added kerneldoc comments.]
Signed-off-by: Eric Snowberg <eric.snowberg@oracle.com>
cc: Randy Dunlap <rdunlap@infradead.org>
cc: Mickaël Salaün <mic@digikod.net>
cc: Arnd Bergmann <arnd@kernel.org>
cc: keyrings@vger.kernel.org
Link: https://lore.kernel.org/r/20200901165143.10295-1-eric.snowberg@oracle.com/ # rfc
Link: https://lore.kernel.org/r/20200909172736.73003-1-eric.snowberg@oracle.com/ # v2
Link: https://lore.kernel.org/r/20200911182230.62266-1-eric.snowberg@oracle.com/ # v3
Link: https://lore.kernel.org/r/20200916004927.64276-1-eric.snowberg@oracle.com/ # v4
Link: https://lore.kernel.org/r/20210122181054.32635-2-eric.snowberg@oracle.com/ # v5
Link: https://lore.kernel.org/r/161428672051.677100.11064981943343605138.stgit@warthog.procyon.org.uk/
Link: https://lore.kernel.org/r/161433310942.902181.4901864302675874242.stgit@warthog.procyon.org.uk/ # v2
Link: https://lore.kernel.org/r/161529605075.163428.14625520893961300757.stgit@warthog.procyon.org.uk/ # v3
Link: https://lore.kernel.org/r/bc2c24e3-ed68-2521-0bf4-a1f6be4a895d@infradead.org/ [1]
Link: https://lore.kernel.org/r/20210225125638.1841436-1-arnd@kernel.org/ [2]
[ Upstream commit ad723674d6758478829ee766e3f1a2a24d56236f ]
The handlers to add the keys to the .platform keyring and blacklisted
hashes to the .blacklist keyring is common for both the uefi and powerpc
mechanisms of loading the keys/hashes from the firmware.
This patch moves the common code from load_uefi.c to keyring_handler.c
Signed-off-by: Nayna Jain <nayna@linux.ibm.com>
Acked-by: Mimi Zohar <zohar@linux.ibm.com>
Signed-off-by: Eric Richter <erichte@linux.ibm.com>
Link: https://lore.kernel.org/r/1573441836-3632-4-git-send-email-nayna@linux.ibm.com
commit 82e5d8cc768b0c7b03c551a9ab1f8f3f68d5f83f upstream.
gcc-11 introdces a harmless warning for cap_inode_getsecurity:
security/commoncap.c: In function ‘cap_inode_getsecurity’:
security/commoncap.c:440:33: error: ‘memcpy’ reading 16 bytes from a region of size 0 [-Werror=stringop-overread]
440 | memcpy(&nscap->data, &cap->data, sizeof(__le32) * 2 * VFS_CAP_U32);
The problem here is that tmpbuf is initialized to NULL, so gcc assumes
it is not accessible unless it gets set by vfs_getxattr_alloc(). This is
a legitimate warning as far as I can tell, but the code is correct since
it correctly handles the error when that function fails.
Add a separate NULL check to tell gcc about it as well.
Acked-by: Christian Brauner <christian.brauner@ubuntu.com>
Signed-off-by: James Morris <jamorris@linux.microsoft.com>
Cc: Andrey Zhizhikin <andrey.z@gmail.com>
commit 92063f3ca73aab794bd5408d3361fd5b5ea33079 upstream.
The kernel may be built with multiple LSMs, but only a subset may be
enabled on the boot command line by specifying "lsm=". Not including
"integrity" on the ordered LSM list may result in a NULL deref.
As reported by Dmitry Vyukov:
in qemu:
qemu-system-x86_64 -enable-kvm -machine q35,nvdimm -cpu
max,migratable=off -smp 4 -m 4G,slots=4,maxmem=16G -hda
wheezy.img -kernel arch/x86/boot/bzImage -nographic -vga std
-soundhw all -usb -usbdevice tablet -bt hci -bt device:keyboard
-net user,host=10.0.2.10,hostfwd=tcp::10022-:22 -net
nic,model=virtio-net-pci -object
memory-backend-file,id=pmem1,share=off,mem-path=/dev/zero,size=64M
-device nvdimm,id=nvdimm1,memdev=pmem1 -append "console=ttyS0
root=/dev/sda earlyprintk=serial rodata=n oops=panic panic_on_warn=1
panic=86400 lsm=smack numa=fake=2 nopcid dummy_hcd.num=8" -pidfile
vm_pid -m 2G -cpu host
But it crashes on NULL deref in integrity_inode_get during boot:
BUG: kernel NULL pointer dereference, address: 000000000000001c
PGD 0 P4D 0
Oops: 0000 [#1] PREEMPT SMP KASAN
CPU: 3 PID: 1 Comm: swapper/0 Not tainted 5.12.0-rc2+ #97
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS
rel-1.13.0-44-g88ab0c15525c-prebuilt.qemu.org 04/01/2014
RIP: 0010:kmem_cache_alloc+0x2b/0x370 mm/slub.c:2920
Code: 57 41 56 41 55 41 54 41 89 f4 55 48 89 fd 53 48 83 ec 10 44 8b
3d d9 1f 90 0b 65 48 8b 04 25 28 00 00 00 48 89 44 24 08 31 c0 <8b> 5f
1c 4cf
RSP: 0000:ffffc9000032f9d8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff888017fc4f00 RCX: 0000000000000000
RDX: ffff888040220000 RSI: 0000000000000c40 RDI: 0000000000000000
RBP: 0000000000000000 R08: 0000000000000000 R09: ffff888019263627
R10: ffffffff83937cd1 R11: 0000000000000000 R12: 0000000000000c40
R13: ffff888019263538 R14: 0000000000000000 R15: 0000000000ffffff
FS: 0000000000000000(0000) GS:ffff88802d180000(0000) knlGS:0000000000000000
CR2: 000000000000001c CR3: 000000000b48e000 CR4: 0000000000750ee0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
PKRU: 55555554
Call Trace:
integrity_inode_get+0x47/0x260 security/integrity/iint.c:105
process_measurement+0x33d/0x17e0 security/integrity/ima/ima_main.c:237
ima_bprm_check+0xde/0x210 security/integrity/ima/ima_main.c:474
security_bprm_check+0x7d/0xa0 security/security.c:845
search_binary_handler fs/exec.c:1708 [inline]
exec_binprm fs/exec.c:1761 [inline]
bprm_execve fs/exec.c:1830 [inline]
bprm_execve+0x764/0x19a0 fs/exec.c:1792
kernel_execve+0x370/0x460 fs/exec.c:1973
try_to_run_init_process+0x14/0x4e init/main.c:1366
kernel_init+0x11d/0x1b8 init/main.c:1477
ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:294
Modules linked in:
---[ end trace 22d601a500de7d79 ]---
Since LSMs and IMA may be configured at build time, but not enabled at
run time, panic the system if "integrity" was not initialized before use.
Fixes: 79f7865d844c ("LSM: Introduce "lsm=" for boottime LSM selection")
capabilities")
commit 3b0c2d3eaa83da259d7726192cf55a137769012f upstream.
It turns out that there are in fact userspace implementations that
care and this recent change caused a regression.
https://github.com/containers/buildah/issues/3071
As the motivation for the original change was future development,
and the impact is existing real world code just revert this change
and allow the ambiguity in v3 file caps.
Fixes: 95ebabde382c ("capabilities: Don't allow writing ambiguous v3 file capabilities")
commit 7ef4c19d245f3dc233fd4be5acea436edd1d83d8 upstream.
syzbot found WARNINGs in several smackfs write operations where
bytes count is passed to memdup_user_nul which exceeds
GFP MAX_ORDER. Check count size if bigger than PAGE_SIZE.
Per smackfs doc, smk_write_net4addr accepts any label or -CIPSO,
smk_write_net6addr accepts any label or -DELETE. I couldn't find
any general rule for other label lengths except SMK_LABELLEN,
SMK_LONGLABEL, SMK_CIPSOMAX which are documented.
Let's constrain, in general, smackfs label lengths for PAGE_SIZE.
Although fuzzer crashes write to smackfs/netlabel on 0x400000 length.
Here is a quick way to reproduce the WARNING:
python -c "print('A' * 0x400000)" > /sys/fs/smackfs/netlabel
Reported-by: syzbot+a71a442385a0b2815497@syzkaller.appspotmail.com
Signed-off-by: Sabyrzhan Tasbolatov <snovitoll@gmail.com>
commit 8da7520c80468c48f981f0b81fc1be6599e3b0ad upstream.
Consider the following transcript:
$ keyctl add trusted kmk "new 32 blobauth=helloworld keyhandle=80000000 migratable=1" @u
add_key: Invalid argument
The documentation has the following description:
migratable= 0|1 indicating permission to reseal to new PCR values,
default 1 (resealing allowed)
The consequence is that "migratable=1" should succeed. Fix this by
allowing this condition to pass instead of return -EINVAL.
[*] Documentation/security/keys/trusted-encrypted.rst
Cc: "James E.J. Bottomley" <jejb@linux.ibm.com>
Cc: Mimi Zohar <zohar@linux.ibm.com>
Fixes: d00a1c72f7f4 ("keys: add new trusted key-type")
[ Upstream commit 4993e1f9479a4161fd7d93e2b8b30b438f00cb0f ]
KEY_FLAG_KEEP is not meant to be passed to keyring_alloc() or key_alloc(),
as these only take KEY_ALLOC_* flags. KEY_FLAG_KEEP has the same value as
KEY_ALLOC_BYPASS_RESTRICTION, but fortunately only key_create_or_update()
uses it. LSMs using the key_alloc hook don't check that flag.
KEY_FLAG_KEEP is then ignored but fortunately (again) the root user cannot
write to the blacklist keyring, so it is not possible to remove a key/hash
from it.
Fix this by adding a KEY_ALLOC_SET_KEEP flag that tells key_alloc() to set
KEY_FLAG_KEEP on the new key. blacklist_init() can then, correctly, pass
this to keyring_alloc().
We can also use this in ima_mok_init() rather than setting the flag
manually.
Note that this doesn't fix an observable bug with the current
implementation but it is required to allow addition of new hashes to the
blacklist in the future without making it possible for them to be removed.
Fixes: 734114f8782f ("KEYS: Add a system blacklist keyring")
Reported-by: Mickaël Salaün <mic@linux.microsoft.com>
cc: Mickaël Salaün <mic@linux.microsoft.com>
cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
[ Upstream commit 95ebabde382c371572297915b104e55403674e73 ]
The v3 file capabilities have a uid field that records the filesystem
uid of the root user of the user namespace the file capabilities are
valid in.
When someone is silly enough to have the same underlying uid as the
root uid of multiple nested containers a v3 filesystem capability can
be ambiguous.
In the spirit of don't do that then, forbid writing a v3 filesystem
capability if it is ambiguous.
Fixes: 8db6c34f1dbc ("Introduce v3 namespaced file capabilities")
Reviewed-by: Andrew G. Morgan <morgan@kernel.org>
Reviewed-by: Serge Hallyn <serge@hallyn.com>
[ Upstream commit f31e3386a4e92ba6eda7328cb508462956c94c64 ]
IMA allocates kernel virtual memory to carry forward the measurement
list, from the current kernel to the next kernel on kexec system call,
in ima_add_kexec_buffer() function. This buffer is not freed before
completing the kexec system call resulting in memory leak.
Add ima_buffer field in "struct kimage" to store the virtual address
of the buffer allocated for the IMA measurement list.
Free the memory allocated for the IMA measurement list in
kimage_file_post_load_cleanup() function.
Signed-off-by: Lakshmi Ramasubramanian <nramas@linux.microsoft.com>
Suggested-by: Tyler Hicks <tyhicks@linux.microsoft.com>
Reviewed-by: Thiago Jung Bauermann <bauerman@linux.ibm.com>
Reviewed-by: Tyler Hicks <tyhicks@linux.microsoft.com>
Fixes: 7b8589cc29e7 ("ima: on soft reboot, save the measurement list")
[ Upstream commit 6d14c6517885fa68524238787420511b87d671df ]
in ima_add_kexec_buffer() function. In error code paths this memory
is not freed resulting in memory leak.
the error code paths in ima_add_kexec_buffer() function.
[ Upstream commit ccf11dbaa07b328fa469415c362d33459c140a37 ]
tmp_tfm is allocated, but not freed on subsequent kmalloc failure, which
leads to a memory leak. Free tmp_tfm.
Fixes: d46eb3699502b ("evm: crypto hash replaced by shash")
Signed-off-by: Dinghao Liu <dinghao.liu@zju.edu.cn>
[zohar@linux.ibm.com: formatted/reworded patch description]
[ Upstream commit f2b00be488730522d0fb7a8a5de663febdcefe0a ]
If a capability is stored on disk in v2 format cap_inode_getsecurity() will
currently return in v2 format unconditionally.
This is wrong: v2 cap should be equivalent to a v3 cap with zero rootid,
and so the same conversions performed on it.
If the rootid cannot be mapped, v3 is returned unconverted. Fix this so
that both v2 and v3 return -EOVERFLOW if the rootid (or the owner of the fs
user namespace in case of v2) cannot be mapped into the current user
namespace.
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
commit d36a1dd9f77ae1e72da48f4123ed35627848507d upstream.
We are not guaranteed the locking environment that would prevent
dentry getting renamed right under us. And it's possible for
old long name to be freed after rename, leading to UAF here.
Cc: stable@kernel.org # v2.6.2+
commit 207cdd565dfc95a0a5185263a567817b7ebf5467 upstream.
Commit a408e4a86b36b ("ima: open a new file instance if no read
permissions") already introduced a second open to measure a file when the
original file descriptor does not allow it. However, it didn't remove the
existing method of changing the mode of the original file descriptor, which
is still necessary if the current process does not have enough privileges
to open a new one.
Changing the mode isn't really an option, as the filesystem might need to
do preliminary steps to make the read possible. Thus, this patch removes
the code and keeps the second open as the only option to measure a file
when it is unreadable with the original file descriptor.
Cc: <stable@vger.kernel.org> # 4.20.x: 0014cc04e8ec0 ima: Set file->f_mode
Fixes: 2fe5d6def1672 ("ima: integrity appraisal extension")
[ Upstream commit 200ea5a2292dc444a818b096ae6a32ba3caa51b9 ]
A previous fix, commit 83370b31a915 ("selinux: fix error initialization
in inode_doinit_with_dentry()"), changed how failures were handled
before a SELinux policy was loaded. Unfortunately that patch was
potentially problematic for two reasons: it set the isec->initialized
state without holding a lock, and it didn't set the inode's SELinux
label to the "default" for the particular filesystem. The later can
be a problem if/when a later attempt to revalidate the inode fails
and SELinux reverts to the existing inode label.
This patch should restore the default inode labeling that existed
before the original fix, without affecting the LABEL_INVALID marking
such that revalidation will still be attempted in the future.
Fixes: 83370b31a915 ("selinux: fix error initialization in inode_doinit_with_dentry()")
Reported-by: Sven Schnelle <svens@linux.ibm.com>
Tested-by: Sven Schnelle <svens@linux.ibm.com>
Reviewed-by: Ondrej Mosnacek <omosnace@redhat.com>
[ Upstream commit 83370b31a915493231e5b9addc72e4bef69f8d31 ]
Mark the inode security label as invalid if we cannot find
a dentry so that we will retry later rather than marking it
initialized with the unlabeled SID.
Fixes: 9287aed2ad1f ("selinux: Convert isec->lock into a spinlock")
Signed-off-by: Tianyue Ren <rentianyue@kylinos.cn>
[PM: minor comment tweaks]
[ Upstream commit 20c59ce010f84300f6c655d32db2610d3433f85c ]
Registers 8-9 are used to store measurements of the kernel and its
command line (e.g., grub2 bootloader with tpm module enabled). IMA
should include them in the boot aggregate. Registers 8-9 should be
only included in non-SHA1 digests to avoid ambiguity.
Signed-off-by: Maurizio Drocco <maurizio.drocco@ibm.com>
Reviewed-by: Bruno Meneguele <bmeneg@redhat.com>
Tested-by: Bruno Meneguele <bmeneg@redhat.com> (TPM 1.2, TPM 2.0)
commit c350f8bea271782e2733419bd2ab9bf4ec2051ef upstream.
Fix to return a negative error code from the error handling case
instead of 0 in function sel_ib_pkey_sid_slow(), as done elsewhere
in this function.
Fixes: 409dcf31538a ("selinux: Add a cache for quicker retreival of PKey SIDs")
Signed-off-by: Chen Zhou <chenzhou10@huawei.com>
commit 455b6c9112eff8d249e32ba165742085678a80a4 upstream.
This patch checks the size for the EVM_IMA_XATTR_DIGSIG and
EVM_XATTR_PORTABLE_DIGSIG types to ensure that the algorithm is read from
the buffer returned by vfs_getxattr_alloc().
Cc: stable@vger.kernel.org # 4.19.x
Fixes: 5feeb61183dde ("evm: Allow non-SHA1 digital signatures")
