Kconfig change in tf_driver to select CRYPTO_SHA1
Change-Id: Id5e9f6b82fd4f54606b1588e9883dbc1ab842225
Reviewed-on: http://git-master/r/47253
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: John Gamble <jgamble@nvidia.com>
Tested-by: John Gamble <jgamble@nvidia.com>
New version of tf_driver supplied by Trusted Logic
Change-Id: I57d28e467346e055d1c4c4f9ad75a49f670d646d
Reviewed-on: http://git-master/r/46803
Change-Id: I318afbe66efa346b71e82413ac6442672cef4d36
Reviewed-on: http://git-master/r/21196
Reviewed-by: Jonathan B White (Engrg-Mobile) <jwhite@nvidia.com>
Tested-by: Jonathan B White (Engrg-Mobile) <jwhite@nvidia.com>
Reviewed-by: Maria Gutowski <mgutowski@nvidia.com>
arch/arm/mm/cache-v6.S
Change-Id: I1a2063218dd705a762a40f4a9dfe504ce1a1d491
commit 867c20265459d30a01b021a9c1e81fb4c5832aa9 upstream.
If security_filter_rule_init() doesn't return a rule, then not everything
is as fine as the return code implies.
This bug only occurs when the LSM (eg. SELinux) is disabled at runtime.
Adding an empty LSM rule causes ima_match_rules() to always succeed,
ignoring any remaining rules.
default IMA TCB policy:
# PROC_SUPER_MAGIC
dont_measure fsmagic=0x9fa0
# SYSFS_MAGIC
dont_measure fsmagic=0x62656572
# DEBUGFS_MAGIC
dont_measure fsmagic=0x64626720
# TMPFS_MAGIC
dont_measure fsmagic=0x01021994
# SECURITYFS_MAGIC
dont_measure fsmagic=0x73636673
< LSM specific rule >
dont_measure obj_type=var_log_t
measure func=BPRM_CHECK
measure func=FILE_MMAP mask=MAY_EXEC
measure func=FILE_CHECK mask=MAY_READ uid=0
Thus without the patch, with the boot parameters 'tcb selinux=0', adding
the above 'dont_measure obj_type=var_log_t' rule to the default IMA TCB
measurement policy, would result in nothing being measured. The patch
prevents the default TCB policy from being replaced.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: David Safford <safford@watson.ibm.com>
Signed-off-by: Chia-chi Yeh <chiachi@android.com>
System call entry functions sys_*() are never to be called from
general kernel code. The fact that they aren't declared in header
files should have been a clue. These functions also don't exist on
Alpha since it has sys_getxpid() instead.
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: James Morris <jmorris@namei.org>
Fix a bug in keyctl_session_to_parent() whereby it tries to check the ownership
of the parent process's session keyring whether or not the parent has a session
keyring [CVE-2010-2960].
This results in the following oops:
BUG: unable to handle kernel NULL pointer dereference at 00000000000000a0
IP: [<ffffffff811ae4dd>] keyctl_session_to_parent+0x251/0x443
Call Trace:
[<ffffffff811ae2f3>] ? keyctl_session_to_parent+0x67/0x443
[<ffffffff8109d286>] ? __do_fault+0x24b/0x3d0
[<ffffffff811af98c>] sys_keyctl+0xb4/0xb8
[<ffffffff81001eab>] system_call_fastpath+0x16/0x1b
if the parent process has no session keyring.
If the system is using pam_keyinit then it mostly protected against this as all
processes derived from a login will have inherited the session keyring created
by pam_keyinit during the log in procedure.
To test this, pam_keyinit calls need to be commented out in /etc/pam.d/.
Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com>
Acked-by: Tavis Ormandy <taviso@cmpxchg8b.com>
There's an protected access to the parent process's credentials in the middle
of keyctl_session_to_parent(). This results in the following RCU warning:
[ INFO: suspicious rcu_dereference_check() usage. ]
security/keys/keyctl.c:1291 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 0
1 lock held by keyctl-session-/2137:
#0: (tasklist_lock){.+.+..}, at: [<ffffffff811ae2ec>] keyctl_session_to_parent+0x60/0x236
stack backtrace:
Pid: 2137, comm: keyctl-session- Not tainted 2.6.36-rc2-cachefs+ #1
Call Trace:
[<ffffffff8105606a>] lockdep_rcu_dereference+0xaa/0xb3
[<ffffffff811ae379>] keyctl_session_to_parent+0xed/0x236
[<ffffffff811af77e>] sys_keyctl+0xb4/0xb6
The code should take the RCU read lock to make sure the parents credentials
don't go away, even though it's holding a spinlock and has IRQ disabled.
commit 8262bb85da allocated the inode integrity struct (iint) before any
inodes were created. Only after IMA was initialized in late_initcall were
the counters updated. This patch updates the counters, whether or not IMA
has been initialized, to resolve 'imbalance' messages.
This patch fixes the bug as reported in bugzilla: 15673. When the i915
is builtin, the ring_buffer is initialized before IMA, causing the
imbalance message on suspend.
Reported-by: Thomas Meyer <thomas@m3y3r.de>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Tested-by: Thomas Meyer <thomas@m3y3r.de>
Tested-by: David Safford<safford@watson.ibm.com>
Cc: Stable Kernel <stable@kernel.org>
The locking for profile namespace removal is wrong, when removing a
profile namespace, it needs to be removed from its parent's list.
Lock the parent of namespace list instead of the namespace being removed.
Signed-off-by: John Johansen <john.johansen@canonical.com>
As per Dan Carpenter <error27@gmail.com>
If we have a ns name without a following profile then in the original
code it did "*ns_name = &name[1];". "name" is NULL so "*ns_name" is
0x1. That isn't useful and could cause an oops when this function is
called from aa_remove_profiles().
Beyond this the assignment of the namespace name was wrong in the case
where the profile name was provided as it was being set to &name[1]
after name = skip_spaces(split + 1);
Move the ns_name assignment before updating name for the split and
also add skip_spaces, making the interface more robust.
2.6.36 introduced the abilitiy to specify the task that is having its
rlimits set. Update mediation to ensure that confined tasks can only
set their own group_leader as expected by current policy.
Add TODO note about extending policy to support setting other tasks
rlimits.
The 2.6.36 kernel has refactored __d_path() so that it no longer appends
" (deleted)" to unlinked paths. So drop the hack that was used to detect
and remove the appended string.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs: brlock vfsmount_lock
fs: scale files_lock
lglock: introduce special lglock and brlock spin locks
tty: fix fu_list abuse
fs: cleanup files_lock locking
fs: remove extra lookup in __lookup_hash
fs: fs_struct rwlock to spinlock
apparmor: use task path helpers
fs: dentry allocation consolidation
fs: fix do_lookup false negative
mbcache: Limit the maximum number of cache entries
hostfs ->follow_link() braino
hostfs: dumb (and usually harmless) tpyo - strncpy instead of strlcpy
remove SWRITE* I/O types
kill BH_Ordered flag
vfs: update ctime when changing the file's permission by setfacl
cramfs: only unlock new inodes
fix reiserfs_evict_inode end_writeback second call
tty code abuses fu_list, which causes a bug in remount,ro handling.
If a tty device node is opened on a filesystem, then the last link to the inode
removed, the filesystem will be allowed to be remounted readonly. This is
because fs_may_remount_ro does not find the 0 link tty inode on the file sb
list (because the tty code incorrectly removed it to use for its own purpose).
This can result in a filesystem with errors after it is marked "clean".
Taking idea from Christoph's initial patch, allocate a tty private struct
at file->private_data and put our required list fields in there, linking
file and tty. This makes tty nodes behave the same way as other device nodes
and avoid meddling with the vfs, and avoids this bug.
The error handling is not trivial in the tty code, so for this bugfix, I take
the simple approach of using __GFP_NOFAIL and don't worry about memory errors.
This is not a problem because our allocator doesn't fail small allocs as a rule
anyway. So proper error handling is left as an exercise for tty hackers.
[ Arguably filesystem's device inode would ideally be divorced from the
driver's pseudo inode when it is opened, but in practice it's not clear whether
that will ever be worth implementing. ]
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Lock tty_files with a new spinlock, tty_files_lock; provide helpers to
manipulate the per-sb files list; unexport the files_lock spinlock.
Acked-by: Andi Kleen <ak@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
AppArmor: fix task_setrlimit prototype
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
After rlimits tree was merged we get the following errors:
security/apparmor/lsm.c:663:2: warning: initialization from incompatible pointer type
It is because AppArmor was merged in the meantime, but uses the old
prototype. So fix it by adding struct task_struct as a first parameter
of apparmor_task_setrlimit.
NOTE that this is ONLY a compilation warning fix (and crashes caused
by that). It needs proper handling in AppArmor depending on who is the
'task'.
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus
* 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits)
param: don't deref arg in __same_type() checks
param: update drivers/acpi/debug.c to new scheme
param: use module_param in drivers/message/fusion/mptbase.c
ide: use module_param_named rather than module_param_call
param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme
param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes.
param: lock myri10ge_fw_name against sysfs changes.
param: simple locking for sysfs-writable charp parameters
param: remove unnecessary writable charp
param: add kerneldoc to moduleparam.h
param: locking for kernel parameters
param: make param sections const.
param: use free hook for charp (fix leak of charp parameters)
param: add a free hook to kernel_param_ops.
param: silence .init.text references from param ops
Add param ops struct for hvc_iucv driver.
nfs: update for module_param_named API change
AppArmor: update for module_param_named API change
param: use ops in struct kernel_param, rather than get and set fns directly
param: move the EXPORT_SYMBOL to after the definitions.
Add a dummy printk function for the maintenance of unused printks through gcc
format checking, and also so that side-effect checking is maintained too.
Fixes these build errors:
security/apparmor/lsm.c:701: error: 'param_ops_aabool' undeclared here (not in a function)
security/apparmor/lsm.c:721: error: 'param_ops_aalockpolicy' undeclared here (not in a function)
security/apparmor/lsm.c:729: error: 'param_ops_aauint' undeclared here (not in a function)
* 'writable_limits' of git://decibel.fi.muni.cz/~xslaby/linux:
unistd: add __NR_prlimit64 syscall numbers
rlimits: implement prlimit64 syscall
rlimits: switch more rlimit syscalls to do_prlimit
rlimits: redo do_setrlimit to more generic do_prlimit
rlimits: add rlimit64 structure
rlimits: do security check under task_lock
rlimits: allow setrlimit to non-current tasks
rlimits: split sys_setrlimit
rlimits: selinux, do rlimits changes under task_lock
rlimits: make sure ->rlim_max never grows in sys_setrlimit
rlimits: add task_struct to update_rlimit_cpu
rlimits: security, add task_struct to setrlimit
Fix up various system call number conflicts. We not only added fanotify
system calls in the meantime, but asm-generic/unistd.h added a wait4
along with a range of reserved per-architecture system calls.
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits)
fanotify: use both marks when possible
fsnotify: pass both the vfsmount mark and inode mark
fsnotify: walk the inode and vfsmount lists simultaneously
fsnotify: rework ignored mark flushing
fsnotify: remove global fsnotify groups lists
fsnotify: remove group->mask
fsnotify: remove the global masks
fsnotify: cleanup should_send_event
fanotify: use the mark in handler functions
audit: use the mark in handler functions
dnotify: use the mark in handler functions
inotify: use the mark in handler functions
fsnotify: send fsnotify_mark to groups in event handling functions
fsnotify: Exchange list heads instead of moving elements
fsnotify: srcu to protect read side of inode and vfsmount locks
fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called
fsnotify: use _rcu functions for mark list traversal
fsnotify: place marks on object in order of group memory address
vfs/fsnotify: fsnotify_close can delay the final work in fput
fsnotify: store struct file not struct path
Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
SELINUX: Fix build error.
Fix build error caused by a stale security/selinux/av_permissions.h in the $(src)
directory which will override a more recent version in $(obj) that is it
appears to strike only when building with a separate object directory.
Acked-by: Eric Paris <eparis@redhat.com>
request_key() should return -ENOKEY if the key it constructs has been
negatively instantiated.
Without this, request_key() can return an unusable key to its caller,
and if the caller then does key_validate() that won't catch the problem.
SECURITY_APPARMOR should depend on NET since AUDIT needs
(depends on) NET.
Fixes 70-80 errors that occur when CONFIG_NET is not enabled,
but APPARMOR selects AUDIT without qualification. E.g.:
audit.c:(.text+0x33361): undefined reference to `netlink_unicast'
(.text+0x333df): undefined reference to `netlink_unicast'
audit.c:(.text+0x3341d): undefined reference to `skb_queue_tail'
audit.c:(.text+0x33424): undefined reference to `kfree_skb'
audit.c:(.text+0x334cb): undefined reference to `kfree_skb'
audit.c:(.text+0x33597): undefined reference to `skb_put'
audit.c:(.text+0x3369b): undefined reference to `__alloc_skb'
audit.c:(.text+0x336d7): undefined reference to `kfree_skb'
(.text+0x3374c): undefined reference to `__alloc_skb'
auditfilter.c:(.text+0x35305): undefined reference to `skb_queue_tail'
lsm_audit.c:(.text+0x2873): undefined reference to `init_net'
lsm_audit.c:(.text+0x2878): undefined reference to `dev_get_by_index'
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits)
Documentation: update broken web addresses.
fix comment typo "choosed" -> "chosen"
hostap:hostap_hw.c Fix typo in comment
Fix spelling contorller -> controller in comments
Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault
fs/Kconfig: Fix typo Userpace -> Userspace
Removing dead MACH_U300_BS26
drivers/infiniband: Remove unnecessary casts of private_data
fs/ocfs2: Remove unnecessary casts of private_data
libfc: use ARRAY_SIZE
scsi: bfa: use ARRAY_SIZE
drm: i915: use ARRAY_SIZE
drm: drm_edid: use ARRAY_SIZE
synclink: use ARRAY_SIZE
block: cciss: use ARRAY_SIZE
comment typo fixes: charater => character
fix comment typos concerning "challenge"
arm: plat-spear: fix typo in kerneldoc
reiserfs: typo comment fix
update email address
Fix build warnings for non-const use of get_task_cred.
Current selinux policy can have over 3000 types. The type_attr_map in
policy is an array sized by the number of types times sizeof(struct ebitmap)
(12 on x86_64). Basic math tells us the array is going to be of length
3000 x 12 = 36,000 bytes. The largest 'safe' allocation on a long running
system is 16k. Most of the time a 32k allocation will work. But on long
running systems a 64k allocation (what we need) can fail quite regularly.
In order to deal with this I am converting the type_attr_map to use
flex_arrays. Let the library code deal with breaking this into PAGE_SIZE
pieces.
-v2
rework some of the if(!obj) BUG() to be BUG_ON(!obj)
drop flex_array_put() calls and just use a _get() object directly
-v3
make apply to James' tree (drop the policydb_write changes)
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov>
Kconfig and Makefiles to enable configuration and building of AppArmor.
Commit c9e69318 "TOMOYO: Allow wildcard for execute permission." changed execute
permission and domainname to accept wildcards. But tomoyo_find_next_domain()
was using pathname passed to execve() rather than pathname specified by the
execute permission. As a result, processes were not able to transit to domains
which contain wildcards in their domainnames.
This patch passes pathname specified by the execute permission back to
tomoyo_find_next_domain() so that processes can transit to domains which
Remove extraneous path_truncate arguments from the AppArmor hook,
as they've been removed from the LSM API.
The basic routines and defines for AppArmor policy. AppArmor policy
is defined by a few basic components.
profiles - the basic unit of confinement contain all the information
to enforce policy on a task
Profiles tend to be named after an executable that they
will attach to but this is not required.
namespaces - a container for a set of profiles that will be used
during attachment and transitions between profiles.
sids - which provide a unique id for each profile
AppArmor policy is loaded in a platform independent flattened binary
stream. Verify and unpack the data converting it to the internal
format needed for enforcement.
ipc:
AppArmor ipc is currently limited to mediation done by file mediation
and basic ptrace tests. Improved mediation is a wip.
rlimits:
AppArmor provides basic abilities to set and control rlimits at
a per profile level. Only resources specified in a profile are controled
or set. AppArmor rules set the hard limit to a value <= to the current
hard limit (ie. they can not currently raise hard limits), and if
necessary will lower the soft limit to the new hard limit value.
AppArmor does not track resource limits to reset them when a profile
is left so that children processes inherit the limits set by the
parent even if they are not confined by the same profile.
Capabilities: AppArmor provides a per profile mask of capabilities,
that will further restrict.
AppArmor hooks to interface with the LSM, module parameters and module
initialization.
AppArmor routines for controling domain transitions, which can occur at
exec or through self directed change_profile/change_hat calls.
Unconfined tasks are checked at exec against the profiles in the confining
profile namespace to determine if a profile should be attached to the task.
Confined tasks execs are controlled by the profile which provides rules
determining which execs are allowed and if so which profiles should be
transitioned to.
Self directed domain transitions allow a task to request transition
to a given profile. If the transition is allowed then the profile will
be applied, either immeditately or at exec time depending on the request.
Immeditate self directed transitions have several security limitations
but have uses in setting up stub transition profiles and other limited
cases.
AppArmor does files enforcement via pathname matching. Matching is done
at file open using a dfa match engine. Permission is against the final
file object not parent directories, ie. the traversal of directories
as part of the file match is implicitly allowed. In the case of nonexistant
files (creation) permissions are checked against the target file not the
directory. eg. In case of creating the file /dir/new, permissions are
checked against the match /dir/new not against /dir/.
The permissions for matches are currently stored in the dfa accept table,
but this will change to allow for dfa reuse and also to allow for sharing
of wider accept states.
The /proc/<pid>/attr/* interface is used for process introspection and
commands. While the apparmorfs interface is used for global introspection
and loading and removing policy.
The interface currently only contains the files necessary for loading
policy, and will be extended in the future to include sysfs style
single per file introspection inteface.
The old AppArmor 2.4 interface files have been removed into a compatibility
patch, that distros can use to maintain backwards compatibility.
A basic dfa matching engine based off the dfa engine in the Dragon
Book. It uses simple row comb compression with a check field.
This allows AppArmor to do pattern matching in linear time, and also
avoids stack issues that an nfa based engine may have. The dfa
engine uses a byte based comparison, with all values being valid.
Any potential character encoding are handled user side when the dfa
tables are created. By convention AppArmor uses \0 to separate two
dependent path matches since \0 is not a valid path character
(this is done in the link permission check).
The dfa tables are generated in user space and are verified at load
time to be internally consistent.
There are several future improvements planned for the dfa engine:
* The dfa engine may be converted to a hybrid nfa-dfa engine, with
a fixed size limited stack. This would allow for size time
tradeoffs, by inserting limited nfa states to help control
state explosion that can occur with dfas.
* The dfa engine may pickup the ability to do limited dynamic
variable matching, instead of fixing all variables at policy
load time.
AppArmor contexts attach profiles and state to tasks, files, etc. when
a direct profile reference is not sufficient.
Update lsm_audit for AppArmor specific data, and add the core routines for
AppArmor uses for auditing.
Miscellaneous functions and defines needed by AppArmor, including
the base path resolution routines.
