path: root/security
2018-04-13selinux: do not check open permission on socketsStephen Smalley
[ Upstream commit ccb544781d34afdb73a9a73ae53035d824d193bf ] open permission is currently only defined for files in the kernel (COMMON_FILE_PERMS rather than COMMON_FILE_SOCK_PERMS). Construction of an artificial test case that tries to open a socket via /proc/pid/fd will generate a recvfrom avc denial because recvfrom and open happen to map to the same permission bit in socket vs file classes. open of a socket via /proc/pid/fd is not supported by the kernel regardless and will ultimately return ENXIO. But we hit the permission check first and can thus produce these odd/misleading denials. Omit the open check when operating on a socket. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08selinux: Remove redundant check for unknown labeling behaviorMatthias Kaehlcke
commit 270e8573145a26de924e2dc644596332d400445b upstream. The check is already performed in ocontext_read() when the policy is loaded. Removing the array also fixes the following warning when building with clang: security/selinux/hooks.c:338:20: error: variable 'labeling_behaviors' is not needed and will not be emitted [-Werror,-Wunneeded-internal-declaration] Signed-off-by: Matthias Kaehlcke <mka@chromium.org> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <paul@paul-moore.com> [natechancellor: inode_doinit_with_dentry still present] Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08selinux: Remove unnecessary check of array base in selinux_set_mapping()Matthias Kaehlcke
commit 342e91578eb6909529bc7095964cd44b9c057c4e upstream. 'perms' will never be NULL since it isn't a plain pointer but an array of u32 values. This fixes the following warning when building with clang: security/selinux/ss/services.c:158:16: error: address of array 'p_in->perms' will always evaluate to 'true' [-Werror,-Wpointer-bool-conversion] while (p_in->perms && p_in->perms[k]) { Signed-off-by: Matthias Kaehlcke <mka@chromium.org> Signed-off-by: Paul Moore <paul@paul-moore.com> Cc: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-22ima: relax requiring a file signature for new files with zero lengthMimi Zohar
[ Upstream commit b7e27bc1d42e8e0cc58b602b529c25cd0071b336 ] Custom policies can require file signatures based on LSM labels. These files are normally created and only afterwards labeled, requiring them to be signed. Instead of requiring file signatures based on LSM labels, entire filesystems could require file signatures. In this case, we need the ability of writing new files without requiring file signatures. The definition of a "new" file was originally defined as any file with a length of zero. Subsequent patches redefined a "new" file to be based on the FILE_CREATE open flag. By combining the open flag with a file size of zero, this patch relaxes the file signature requirement. Fixes: 1ac202e978e1 ima: accept previously set IMA_NEW_FILE Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-22apparmor: Make path_max parameter readonlyJohn Johansen
[ Upstream commit 622f6e3265707ebf02ba776ac6e68003bcc31213 ] The path_max parameter determines the max size of buffers allocated but it should not be setable at run time. If can be used to cause an oops root@ubuntu:~# echo 16777216 > /sys/module/apparmor/parameters/path_max root@ubuntu:~# cat /sys/module/apparmor/parameters/path_max Killed [ 122.141911] BUG: unable to handle kernel paging request at ffff880080945fff [ 122.143497] IP: [<ffffffff81228844>] d_absolute_path+0x44/0xa0 [ 122.144742] PGD 220c067 PUD 0 [ 122.145453] Oops: 0002 [#1] SMP [ 122.146204] Modules linked in: vmw_vsock_vmci_transport vsock ppdev vmw_balloon snd_ens1371 btusb snd_ac97_codec gameport snd_rawmidi btrtl snd_seq_device ac97_bus btbcm btintel snd_pcm input_leds bluetooth snd_timer snd joydev soundcore serio_raw coretemp shpchp nfit parport_pc i2c_piix4 8250_fintek vmw_vmci parport mac_hid ib_iser rdma_cm iw_cm ib_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 btrfs raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 multipath linear hid_generic usbhid hid crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd vmwgfx psmouse mptspi ttm mptscsih drm_kms_helper mptbase syscopyarea scsi_transport_spi sysfillrect [ 122.163365] ahci sysimgblt e1000 fb_sys_fops libahci drm pata_acpi fjes [ 122.164747] CPU: 3 PID: 1501 Comm: bash Not tainted 4.4.0-59-generic #80-Ubuntu [ 122.166250] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015 [ 122.168611] task: ffff88003496aa00 ti: ffff880076474000 task.ti: ffff880076474000 [ 122.170018] RIP: 0010:[<ffffffff81228844>] [<ffffffff81228844>] d_absolute_path+0x44/0xa0 [ 122.171525] RSP: 0018:ffff880076477b90 EFLAGS: 00010206 [ 122.172462] RAX: ffff880080945fff RBX: 0000000000000000 RCX: 0000000001000000 [ 122.173709] RDX: 0000000000ffffff RSI: ffff880080946000 RDI: ffff8800348a1010 [ 122.174978] RBP: ffff880076477bb8 R08: ffff880076477c80 R09: 0000000000000000 [ 122.176227] R10: 00007ffffffff000 R11: ffff88007f946000 R12: ffff88007f946000 [ 122.177496] R13: ffff880076477c80 R14: ffff8800348a1010 R15: ffff8800348a2400 [ 122.178745] FS: 00007fd459eb4700(0000) GS:ffff88007b6c0000(0000) knlGS:0000000000000000 [ 122.180176] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 122.181186] CR2: ffff880080945fff CR3: 0000000073422000 CR4: 00000000001406e0 [ 122.182469] Stack: [ 122.182843] 00ffffff00000001 ffff880080946000 0000000000000000 0000000000000000 [ 122.184409] 00000000570f789c ffff880076477c30 ffffffff81385671 ffff88007a2e7a58 [ 122.185810] 0000000000000000 ffff880076477c88 01000000008a1000 0000000000000000 [ 122.187231] Call Trace: [ 122.187680] [<ffffffff81385671>] aa_path_name+0x81/0x370 [ 122.188637] [<ffffffff813875dd>] profile_transition+0xbd/0xb80 [ 122.190181] [<ffffffff811af9bc>] ? zone_statistics+0x7c/0xa0 [ 122.191674] [<ffffffff81389b20>] apparmor_bprm_set_creds+0x9b0/0xac0 [ 122.193288] [<ffffffff812e1971>] ? ext4_xattr_get+0x81/0x220 [ 122.194793] [<ffffffff812e800c>] ? ext4_xattr_security_get+0x1c/0x30 [ 122.196392] [<ffffffff813449b9>] ? get_vfs_caps_from_disk+0x69/0x110 [ 122.198004] [<ffffffff81232d4f>] ? mnt_may_suid+0x3f/0x50 [ 122.199737] [<ffffffff81344b03>] ? cap_bprm_set_creds+0xa3/0x600 [ 122.201377] [<ffffffff81346e53>] security_bprm_set_creds+0x33/0x50 [ 122.203024] [<ffffffff81214ce5>] prepare_binprm+0x85/0x190 [ 122.204515] [<ffffffff81216545>] do_execveat_common.isra.33+0x485/0x710 [ 122.206200] [<ffffffff81216a6a>] SyS_execve+0x3a/0x50 [ 122.207615] [<ffffffff81838795>] stub_execve+0x5/0x5 [ 122.208978] [<ffffffff818384f2>] ? entry_SYSCALL_64_fastpath+0x16/0x71 [ 122.210615] Code: f8 31 c0 48 63 c2 83 ea 01 48 c7 45 e8 00 00 00 00 48 01 c6 85 d2 48 c7 45 f0 00 00 00 00 48 89 75 e0 89 55 dc 78 0c 48 8d 46 ff <c6> 46 ff 00 48 89 45 e0 48 8d 55 e0 48 8d 4d dc 48 8d 75 e8 e8 [ 122.217320] RIP [<ffffffff81228844>] d_absolute_path+0x44/0xa0 [ 122.218860] RSP <ffff880076477b90> [ 122.219919] CR2: ffff880080945fff [ 122.220936] ---[ end trace 506cdbd85eb6c55e ]--- Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-22selinux: check for address length in selinux_socket_bind()Alexander Potapenko
[ Upstream commit e2f586bd83177d22072b275edd4b8b872daba924 ] KMSAN (KernelMemorySanitizer, a new error detection tool) reports use of uninitialized memory in selinux_socket_bind(): ================================================================== BUG: KMSAN: use of unitialized memory inter: 0 CPU: 3 PID: 1074 Comm: packet2 Tainted: G B 4.8.0-rc6+ #1916 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 0000000000000000 ffff8800882ffb08 ffffffff825759c8 ffff8800882ffa48 ffffffff818bf551 ffffffff85bab870 0000000000000092 ffffffff85bab550 0000000000000000 0000000000000092 00000000bb0009bb 0000000000000002 Call Trace: [< inline >] __dump_stack lib/dump_stack.c:15 [<ffffffff825759c8>] dump_stack+0x238/0x290 lib/dump_stack.c:51 [<ffffffff818bdee6>] kmsan_report+0x276/0x2e0 mm/kmsan/kmsan.c:1008 [<ffffffff818bf0fb>] __msan_warning+0x5b/0xb0 mm/kmsan/kmsan_instr.c:424 [<ffffffff822dae71>] selinux_socket_bind+0xf41/0x1080 security/selinux/hooks.c:4288 [<ffffffff8229357c>] security_socket_bind+0x1ec/0x240 security/security.c:1240 [<ffffffff84265d98>] SYSC_bind+0x358/0x5f0 net/socket.c:1366 [<ffffffff84265a22>] SyS_bind+0x82/0xa0 net/socket.c:1356 [<ffffffff81005678>] do_syscall_64+0x58/0x70 arch/x86/entry/common.c:292 [<ffffffff8518217c>] entry_SYSCALL64_slow_path+0x25/0x25 arch/x86/entry/entry_64.o:? chained origin: 00000000ba6009bb [<ffffffff810bb7a7>] save_stack_trace+0x27/0x50 arch/x86/kernel/stacktrace.c:67 [< inline >] kmsan_save_stack_with_flags mm/kmsan/kmsan.c:322 [< inline >] kmsan_save_stack mm/kmsan/kmsan.c:337 [<ffffffff818bd2b8>] kmsan_internal_chain_origin+0x118/0x1e0 mm/kmsan/kmsan.c:530 [<ffffffff818bf033>] __msan_set_alloca_origin4+0xc3/0x130 mm/kmsan/kmsan_instr.c:380 [<ffffffff84265b69>] SYSC_bind+0x129/0x5f0 net/socket.c:1356 [<ffffffff84265a22>] SyS_bind+0x82/0xa0 net/socket.c:1356 [<ffffffff81005678>] do_syscall_64+0x58/0x70 arch/x86/entry/common.c:292 [<ffffffff8518217c>] return_from_SYSCALL_64+0x0/0x6a arch/x86/entry/entry_64.o:? origin description: ----address@SYSC_bind (origin=00000000b8c00900) ================================================================== (the line numbers are relative to 4.8-rc6, but the bug persists upstream) , when I run the following program as root: ======================================================= #include <string.h> #include <sys/socket.h> #include <netinet/in.h> int main(int argc, char *argv[]) { struct sockaddr addr; int size = 0; if (argc > 1) { size = atoi(argv[1]); } memset(&addr, 0, sizeof(addr)); int fd = socket(PF_INET6, SOCK_DGRAM, IPPROTO_IP); bind(fd, &addr, size); return 0; } ======================================================= (for different values of |size| other error reports are printed). This happens because bind() unconditionally copies |size| bytes of |addr| to the kernel, leaving the rest uninitialized. Then security_socket_bind() reads the IP address bytes, including the uninitialized ones, to determine the port, or e.g. pass them further to sel_netnode_find(), which uses them to calculate a hash. Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Eric Dumazet <edumazet@google.com> [PM: fixed some whitespace damage] Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25selinux: skip bounded transition processing if the policy isn't loadedPaul Moore
commit 4b14752ec4e0d87126e636384cf37c8dd9df157c upstream. We can't do anything reasonable in security_bounded_transition() if we don't have a policy loaded, and in fact we could run into problems with some of the code inside expecting a policy. Fix these problems like we do many others in security/selinux/ss/services.c by checking to see if the policy is loaded (ss_initialized) and returning quickly if it isn't. Reported-by: syzbot <syzkaller-bugs@googlegroups.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25selinux: ensure the context is NUL terminated in security_context_to_sid_core()Paul Moore
commit ef28df55ac27e1e5cd122e19fa311d886d47a756 upstream. The syzbot/syzkaller automated tests found a problem in security_context_to_sid_core() during early boot (before we load the SELinux policy) where we could potentially feed context strings without NUL terminators into the strcmp() function. We already guard against this during normal operation (after the SELinux policy has been loaded) by making a copy of the context strings and explicitly adding a NUL terminator to the end. The patch extends this protection to the early boot case (no loaded policy) by moving the context copy earlier in security_context_to_sid_core(). Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Reviewed-By: William Roberts <william.c.roberts@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16KEYS: encrypted: fix buffer overread in valid_master_desc()Eric Biggers
commit 794b4bc292f5d31739d89c0202c54e7dc9bc3add upstream. With the 'encrypted' key type it was possible for userspace to provide a data blob ending with a master key description shorter than expected, e.g. 'keyctl add encrypted desc "new x" @s'. When validating such a master key description, validate_master_desc() could read beyond the end of the buffer. Fix this by using strncmp() instead of memcmp(). [Also clean up the code to deduplicate some logic.] Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Jin Qian <jinqian@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03selinux: general protection fault in sock_has_permMark Salyzyn
In the absence of commit a4298e4522d6 ("net: add SOCK_RCU_FREE socket flag") and all the associated infrastructure changes to take advantage of a RCU grace period before freeing, there is a heightened possibility that a security check is performed while an ill-timed setsockopt call races in from user space. It then is prudent to null check sk_security, and if the case, reject the permissions. Because of the nature of this problem, hard to duplicate, no clear path, this patch is a simplified band-aid for stable trees lacking the infrastructure for the series of commits leading up to providing a suitable RCU grace period. This adjustment is orthogonal to infrastructure improvements that may nullify the needed check, but could be added as good code hygiene in all trees. general protection fault: 0000 [#1] PREEMPT SMP KASAN CPU: 1 PID: 14233 Comm: syz-executor2 Not tainted 4.4.112-g5f6325b #28 task: ffff8801d1095f00 task.stack: ffff8800b5950000 RIP: 0010:[<ffffffff81b69b7e>] [<ffffffff81b69b7e>] sock_has_perm+0x1fe/0x3e0 security/selinux/hooks.c:4069 RSP: 0018:ffff8800b5957ce0 EFLAGS: 00010202 RAX: dffffc0000000000 RBX: 1ffff10016b2af9f RCX: ffffffff81b69b51 RDX: 0000000000000002 RSI: 0000000000000000 RDI: 0000000000000010 RBP: ffff8800b5957de0 R08: 0000000000000001 R09: 0000000000000001 R10: 0000000000000000 R11: 1ffff10016b2af68 R12: ffff8800b5957db8 R13: 0000000000000000 R14: ffff8800b7259f40 R15: 00000000000000d7 FS: 00007f72f5ae2700(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000a2fa38 CR3: 00000001d7980000 CR4: 0000000000160670 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 Stack: ffffffff81b69a1f ffff8800b5957d58 00008000b5957d30 0000000041b58ab3 ffffffff83fc82f2 ffffffff81b69980 0000000000000246 ffff8801d1096770 ffff8801d3165668 ffffffff8157844b ffff8801d1095f00 ffff880000000001 Call Trace: [<ffffffff81b6a19d>] selinux_socket_setsockopt+0x4d/0x80 security/selinux/hooks.c:4338 [<ffffffff81b4873d>] security_socket_setsockopt+0x7d/0xb0 security/security.c:1257 [<ffffffff82df1ac8>] SYSC_setsockopt net/socket.c:1757 [inline] [<ffffffff82df1ac8>] SyS_setsockopt+0xe8/0x250 net/socket.c:1746 [<ffffffff83776499>] entry_SYSCALL_64_fastpath+0x16/0x92 Code: c2 42 9b b6 81 be 01 00 00 00 48 c7 c7 a0 cb 2b 84 e8 f7 2f 6d ff 49 8d 7d 10 48 b8 00 00 00 00 00 fc ff df 48 89 fa 48 c1 ea 03 <0f> b6 04 02 84 c0 74 08 3c 03 0f 8e 83 01 00 00 41 8b 75 10 31 RIP [<ffffffff81b69b7e>] sock_has_perm+0x1fe/0x3e0 security/selinux/hooks.c:4069 RSP <ffff8800b5957ce0> ---[ end trace 7b5aaf788fef6174 ]--- Signed-off-by: Mark Salyzyn <salyzyn@android.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: selinux@tycho.nsa.gov Cc: linux-security-module@vger.kernel.org Cc: Eric Paris <eparis@parisplace.org> Cc: Serge E. Hallyn <serge@hallyn.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KPTI: Rename to PAGE_TABLE_ISOLATIONKees Cook
This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05x86/kaiser: Reenable PARAVIRTBorislav Petkov
Now that the required bits have been addressed, reenable PARAVIRT. Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: delete KAISER_REAL_SWITCH optionHugh Dickins
We fail to see what CONFIG_KAISER_REAL_SWITCH is for: it seems to be left over from early development, and now just obscures tricky parts of the code. Delete it before adding PCIDs, or nokaiser boot option. (Or if there is some good reason to keep the option, then it needs a help text - and a "depends on KAISER", so that all those without KAISER are not asked the question.) Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: KAISER depends on SMPHugh Dickins
It is absurd that KAISER should depend on SMP, but apparently nobody has tried a UP build before: which breaks on implicit declaration of function 'per_cpu_offset' in arch/x86/mm/kaiser.c. Now, you would expect that to be trivially fixed up; but looking at the System.map when that block is #ifdef'ed out of kaiser_init(), I see that in a UP build __per_cpu_user_mapped_end is precisely at __per_cpu_user_mapped_start, and the items carefully gathered into that section for user-mapping on SMP, dispersed elsewhere on UP. So, some other kind of section assignment will be needed on UP, but implementing that is not a priority: just make KAISER depend on SMP for now. Also inserted a blank line before the option, tidied up the brief Kconfig help message, and added an "If unsure, Y". Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: merged updateDave Hansen
Merged fixes and cleanups, rebased to 4.4.89 tree (no 5-level paging). Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KAISER: Kernel Address IsolationRichard Fellner
This patch introduces our implementation of KAISER (Kernel Address Isolation to have Side-channels Efficiently Removed), a kernel isolation technique to close hardware side channels on kernel address information. More information about the patch can be found on: https://github.com/IAIK/KAISER From: Richard Fellner <richard.fellner@student.tugraz.at> From: Daniel Gruss <daniel.gruss@iaik.tugraz.at> X-Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode Date: Thu, 4 May 2017 14:26:50 +0200 Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2 Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5 To: <linux-kernel@vger.kernel.org> To: <kernel-hardening@lists.openwall.com> Cc: <clementine.maurice@iaik.tugraz.at> Cc: <moritz.lipp@iaik.tugraz.at> Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Cc: Richard Fellner <richard.fellner@student.tugraz.at> Cc: Ingo Molnar <mingo@kernel.org> Cc: <kirill.shutemov@linux.intel.com> Cc: <anders.fogh@gdata-adan.de> After several recent works [1,2,3] KASLR on x86_64 was basically considered dead by many researchers. We have been working on an efficient but effective fix for this problem and found that not mapping the kernel space when running in user mode is the solution to this problem [4] (the corresponding paper [5] will be presented at ESSoS17). With this RFC patch we allow anybody to configure their kernel with the flag CONFIG_KAISER to add our defense mechanism. If there are any questions we would love to answer them. We also appreciate any comments! Cheers, Daniel (+ the KAISER team from Graz University of Technology) [1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf [2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf [3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf [4] https://github.com/IAIK/KAISER [5] https://gruss.cc/files/kaiser.pdf [patch based also on https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch] Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at> Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at> Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20KEYS: add missing permission check for request_key() destinationEric Biggers
commit 4dca6ea1d9432052afb06baf2e3ae78188a4410b upstream. When the request_key() syscall is not passed a destination keyring, it links the requested key (if constructed) into the "default" request-key keyring. This should require Write permission to the keyring. However, there is actually no permission check. This can be abused to add keys to any keyring to which only Search permission is granted. This is because Search permission allows joining the keyring. keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_SESSION_KEYRING) then will set the default request-key keyring to the session keyring. Then, request_key() can be used to add keys to the keyring. Both negatively and positively instantiated keys can be added using this method. Adding negative keys is trivial. Adding a positive key is a bit trickier. It requires that either /sbin/request-key positively instantiates the key, or that another thread adds the key to the process keyring at just the right time, such that request_key() misses it initially but then finds it in construct_alloc_key(). Fix this bug by checking for Write permission to the keyring in construct_get_dest_keyring() when the default keyring is being used. We don't do the permission check for non-default keyrings because that was already done by the earlier call to lookup_user_key(). Also, request_key_and_link() is currently passed a 'struct key *' rather than a key_ref_t, so the "possessed" bit is unavailable. We also don't do the permission check for the "requestor keyring", to continue to support the use case described by commit 8bbf4976b59f ("KEYS: Alter use of key instantiation link-to-keyring argument") where /sbin/request-key recursively calls request_key() to add keys to the original requestor's destination keyring. (I don't know of any users who actually do that, though...) Fixes: 3e30148c3d52 ("[PATCH] Keys: Make request-key create an authorisation key") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09ima: fix hash algorithm initializationBoshi Wang
[ Upstream commit ebe7c0a7be92bbd34c6ff5b55810546a0ee05bee ] The hash_setup function always sets the hash_setup_done flag, even when the hash algorithm is invalid. This prevents the default hash algorithm defined as CONFIG_IMA_DEFAULT_HASH from being used. This patch sets hash_setup_done flag only for valid hash algorithms. Fixes: e7a2ad7eb6f4 "ima: enable support for larger default filedata hash algorithms" Signed-off-by: Boshi Wang <wangboshi@huawei.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-24ima: do not update security.ima if appraisal status is not INTEGRITY_PASSRoberto Sassu
commit 020aae3ee58c1af0e7ffc4e2cc9fe4dc630338cb upstream. Commit b65a9cfc2c38 ("Untangling ima mess, part 2: deal with counters") moved the call of ima_file_check() from may_open() to do_filp_open() at a point where the file descriptor is already opened. This breaks the assumption made by IMA that file descriptors being closed belong to files whose access was granted by ima_file_check(). The consequence is that security.ima and security.evm are updated with good values, regardless of the current appraisal status. For example, if a file does not have security.ima, IMA will create it after opening the file for writing, even if access is denied. Access to the file will be allowed afterwards. Avoid this issue by checking the appraisal status before updating security.ima. Signed-off-by: Roberto Sassu <roberto.sassu@huawei.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-18security/keys: add CONFIG_KEYS_COMPAT to KconfigBilal Amarni
commit 47b2c3fff4932e6fc17ce13d51a43c6969714e20 upstream. CONFIG_KEYS_COMPAT is defined in arch-specific Kconfigs and is missing for several 64-bit architectures : mips, parisc, tile. At the moment and for those architectures, calling in 32-bit userspace the keyctl syscall would return an ENOSYS error. This patch moves the CONFIG_KEYS_COMPAT option to security/keys/Kconfig, to make sure the compatibility wrapper is registered by default for any 64-bit architecture as long as it is configured with CONFIG_COMPAT. [DH: Modified to remove arm64 compat enablement also as requested by Eric Biggers] Signed-off-by: Bilal Amarni <bilal.amarni@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> cc: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Cc: James Cowgill <james.cowgill@mips.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15KEYS: trusted: fix writing past end of buffer in trusted_read()Eric Biggers
commit a3c812f7cfd80cf51e8f5b7034f7418f6beb56c1 upstream. When calling keyctl_read() on a key of type "trusted", if the user-supplied buffer was too small, the kernel ignored the buffer length and just wrote past the end of the buffer, potentially corrupting userspace memory. Fix it by instead returning the size required, as per the documentation for keyctl_read(). We also don't even fill the buffer at all in this case, as this is slightly easier to implement than doing a short read, and either behavior appears to be permitted. It also makes it match the behavior of the "encrypted" key type. Fixes: d00a1c72f7f4 ("keys: add new trusted key-type") Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15KEYS: trusted: sanitize all key materialEric Biggers
commit ee618b4619b72527aaed765f0f0b74072b281159 upstream. As the previous patch did for encrypted-keys, zero sensitive any potentially sensitive data related to the "trusted" key type before it is freed. Notably, we were not zeroing the tpm_buf structures in which the actual key is stored for TPM seal and unseal, nor were we zeroing the trusted_key_payload in certain error paths. Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: David Safford <safford@us.ibm.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08KEYS: return full count in keyring_read() if buffer is too smallEric Biggers
commit 3239b6f29bdfb4b0a2ba59df995fc9e6f4df7f1f upstream. Commit e645016abc80 ("KEYS: fix writing past end of user-supplied buffer in keyring_read()") made keyring_read() stop corrupting userspace memory when the user-supplied buffer is too small. However it also made the return value in that case be the short buffer size rather than the size required, yet keyctl_read() is actually documented to return the size required. Therefore, switch it over to the documented behavior. Note that for now we continue to have it fill the short buffer, since it did that before (pre-v3.13) and dump_key_tree_aux() in keyutils arguably relies on it. Fixes: e645016abc80 ("KEYS: fix writing past end of user-supplied buffer in keyring_read()") Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: Fix race between updating and finding a negative keyDavid Howells
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream. Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection error into one field such that: (1) The instantiation state can be modified/read atomically. (2) The error can be accessed atomically with the state. (3) The error isn't stored unioned with the payload pointers. This deals with the problem that the state is spread over three different objects (two bits and a separate variable) and reading or updating them atomically isn't practical, given that not only can uninstantiated keys change into instantiated or rejected keys, but rejected keys can also turn into instantiated keys - and someone accessing the key might not be using any locking. The main side effect of this problem is that what was held in the payload may change, depending on the state. For instance, you might observe the key to be in the rejected state. You then read the cached error, but if the key semaphore wasn't locked, the key might've become instantiated between the two reads - and you might now have something in hand that isn't actually an error code. The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error code if the key is negatively instantiated. The key_is_instantiated() function is replaced with key_is_positive() to avoid confusion as negative keys are also 'instantiated'. Additionally, barriering is included: (1) Order payload-set before state-set during instantiation. (2) Order state-read before payload-read when using the key. Further separate barriering is necessary if RCU is being used to access the payload content after reading the payload pointers. Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data") Reported-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: don't let add_key() update an uninstantiated keyDavid Howells
commit 60ff5b2f547af3828aebafd54daded44cfb0807a upstream. Currently, when passed a key that already exists, add_key() will call the key's ->update() method if such exists. But this is heavily broken in the case where the key is uninstantiated because it doesn't call __key_instantiate_and_link(). Consequently, it doesn't do most of the things that are supposed to happen when the key is instantiated, such as setting the instantiation state, clearing KEY_FLAG_USER_CONSTRUCT and awakening tasks waiting on it, and incrementing key->user->nikeys. It also never takes key_construction_mutex, which means that ->instantiate() can run concurrently with ->update() on the same key. In the case of the "user" and "logon" key types this causes a memory leak, at best. Maybe even worse, the ->update() methods of the "encrypted" and "trusted" key types actually just dereference a NULL pointer when passed an uninstantiated key. Change key_create_or_update() to wait interruptibly for the key to finish construction before continuing. This patch only affects *uninstantiated* keys. For now we still allow a negatively instantiated key to be updated (thereby positively instantiating it), although that's broken too (the next patch fixes it) and I'm not sure that anyone actually uses that functionality either. Here is a simple reproducer for the bug using the "encrypted" key type (requires CONFIG_ENCRYPTED_KEYS=y), though as noted above the bug pertained to more than just the "encrypted" key type: #include <stdlib.h> #include <unistd.h> #include <keyutils.h> int main(void) { int ringid = keyctl_join_session_keyring(NULL); if (fork()) { for (;;) { const char payload[] = "update user:foo 32"; usleep(rand() % 10000); add_key("encrypted", "desc", payload, sizeof(payload), ringid); keyctl_clear(ringid); } } else { for (;;) request_key("encrypted", "desc", "callout_info", ringid); } } It causes: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: encrypted_update+0xb0/0x170 PGD 7a178067 P4D 7a178067 PUD 77269067 PMD 0 PREEMPT SMP CPU: 0 PID: 340 Comm: reproduce Tainted: G D 4.14.0-rc1-00025-g428490e38b2e #796 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff8a467a39a340 task.stack: ffffb15c40770000 RIP: 0010:encrypted_update+0xb0/0x170 RSP: 0018:ffffb15c40773de8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff8a467a275b00 RCX: 0000000000000000 RDX: 0000000000000005 RSI: ffff8a467a275b14 RDI: ffffffffb742f303 RBP: ffffb15c40773e20 R08: 0000000000000000 R09: ffff8a467a275b17 R10: 0000000000000020 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: ffff8a4677057180 R15: ffff8a467a275b0f FS: 00007f5d7fb08700(0000) GS:ffff8a467f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000018 CR3: 0000000077262005 CR4: 00000000001606f0 Call Trace: key_create_or_update+0x2bc/0x460 SyS_add_key+0x10c/0x1d0 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x7f5d7f211259 RSP: 002b:00007ffed03904c8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 000000003b2a7955 RCX: 00007f5d7f211259 RDX: 00000000004009e4 RSI: 00000000004009ff RDI: 0000000000400a04 RBP: 0000000068db8bad R08: 000000003b2a7955 R09: 0000000000000004 R10: 000000000000001a R11: 0000000000000246 R12: 0000000000400868 R13: 00007ffed03905d0 R14: 0000000000000000 R15: 0000000000000000 Code: 77 28 e8 64 34 1f 00 45 31 c0 31 c9 48 8d 55 c8 48 89 df 48 8d 75 d0 e8 ff f9 ff ff 85 c0 41 89 c4 0f 88 84 00 00 00 4c 8b 7d c8 <49> 8b 75 18 4c 89 ff e8 24 f8 ff ff 85 c0 41 89 c4 78 6d 49 8b RIP: encrypted_update+0xb0/0x170 RSP: ffffb15c40773de8 CR2: 0000000000000018 Reported-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Eric Biggers <ebiggers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: encrypted: fix dereference of NULL user_key_payloadEric Biggers
commit 13923d0865ca96312197962522e88bc0aedccd74 upstream. A key of type "encrypted" references a "master key" which is used to encrypt and decrypt the encrypted key's payload. However, when we accessed the master key's payload, we failed to handle the case where the master key has been revoked, which sets the payload pointer to NULL. Note that request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we acquire its semaphore. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. This was an issue for master keys of type "user" only. Master keys can also be of type "trusted", but those cannot be revoked. Fixes: 7e70cb497850 ("keys: add new key-type encrypted") Reviewed-by: James Morris <james.l.morris@oracle.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: David Safford <safford@us.ibm.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12lsm: fix smack_inode_removexattr and xattr_getsecurity memleakCasey Schaufler
commit 57e7ba04d422c3d41c8426380303ec9b7533ded9 upstream. security_inode_getsecurity() provides the text string value of a security attribute. It does not provide a "secctx". The code in xattr_getsecurity() that calls security_inode_getsecurity() and then calls security_release_secctx() happened to work because SElinux and Smack treat the attribute and the secctx the same way. It fails for cap_inode_getsecurity(), because that module has no secctx that ever needs releasing. It turns out that Smack is the one that's doing things wrong by not allocating memory when instructed to do so by the "alloc" parameter. The fix is simple enough. Change the security_release_secctx() to kfree() because it isn't a secctx being returned by security_inode_getsecurity(). Change Smack to allocate the string when told to do so. Note: this also fixes memory leaks for LSMs which implement inode_getsecurity but not release_secctx, such as capabilities. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05KEYS: prevent KEYCTL_READ on negative keyEric Biggers
commit 37863c43b2c6464f252862bf2e9768264e961678 upstream. Because keyctl_read_key() looks up the key with no permissions requested, it may find a negatively instantiated key. If the key is also possessed, we went ahead and called ->read() on the key. But the key payload will actually contain the ->reject_error rather than the normal payload. Thus, the kernel oopses trying to read the user_key_payload from memory address (int)-ENOKEY = 0x00000000ffffff82. Fortunately the payload data is stored inline, so it shouldn't be possible to abuse this as an arbitrary memory read primitive... Reproducer: keyctl new_session keyctl request2 user desc '' @s keyctl read $(keyctl show | awk '/user: desc/ {print $1}') It causes a crash like the following: BUG: unable to handle kernel paging request at 00000000ffffff92 IP: user_read+0x33/0xa0 PGD 36a54067 P4D 36a54067 PUD 0 Oops: 0000 [#1] SMP CPU: 0 PID: 211 Comm: keyctl Not tainted 4.14.0-rc1 #337 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014 task: ffff90aa3b74c3c0 task.stack: ffff9878c0478000 RIP: 0010:user_read+0x33/0xa0 RSP: 0018:ffff9878c047bee8 EFLAGS: 00010246 RAX: 0000000000000001 RBX: ffff90aa3d7da340 RCX: 0000000000000017 RDX: 0000000000000000 RSI: 00000000ffffff82 RDI: ffff90aa3d7da340 RBP: ffff9878c047bf00 R08: 00000024f95da94f R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 00007f58ece69740(0000) GS:ffff90aa3e200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000ffffff92 CR3: 0000000036adc001 CR4: 00000000003606f0 Call Trace: keyctl_read_key+0xac/0xe0 SyS_keyctl+0x99/0x120 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x7f58ec787bb9 RSP: 002b:00007ffc8d401678 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa RAX: ffffffffffffffda RBX: 00007ffc8d402800 RCX: 00007f58ec787bb9 RDX: 0000000000000000 RSI: 00000000174a63ac RDI: 000000000000000b RBP: 0000000000000004 R08: 00007ffc8d402809 R09: 0000000000000020 R10: 0000000000000000 R11: 0000000000000206 R12: 00007ffc8d402800 R13: 00007ffc8d4016e0 R14: 0000000000000000 R15: 0000000000000000 Code: e5 41 55 49 89 f5 41 54 49 89 d4 53 48 89 fb e8 a4 b4 ad ff 85 c0 74 09 80 3d b9 4c 96 00 00 74 43 48 8b b3 20 01 00 00 4d 85 ed <0f> b7 5e 10 74 29 4d 85 e4 74 24 4c 39 e3 4c 89 e2 4c 89 ef 48 RIP: user_read+0x33/0xa0 RSP: ffff9878c047bee8 CR2: 00000000ffffff92 Fixes: 61ea0c0ba904 ("KEYS: Skip key state checks when checking for possession") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05KEYS: prevent creating a different user's keyringsEric Biggers
commit 237bbd29f7a049d310d907f4b2716a7feef9abf3 upstream. It was possible for an unprivileged user to create the user and user session keyrings for another user. For example: sudo -u '#3000' sh -c 'keyctl add keyring _uid.4000 "" @u keyctl add keyring _uid_ses.4000 "" @u sleep 15' & sleep 1 sudo -u '#4000' keyctl describe @u sudo -u '#4000' keyctl describe @us This is problematic because these "fake" keyrings won't have the right permissions. In particular, the user who created them first will own them and will have full access to them via the possessor permissions, which can be used to compromise the security of a user's keys: -4: alswrv-----v------------ 3000 0 keyring: _uid.4000 -5: alswrv-----v------------ 3000 0 keyring: _uid_ses.4000 Fix it by marking user and user session keyrings with a flag KEY_FLAG_UID_KEYRING. Then, when searching for a user or user session keyring by name, skip all keyrings that don't have the flag set. Fixes: 69664cf16af4 ("keys: don't generate user and user session keyrings unless they're accessed") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05KEYS: fix writing past end of user-supplied buffer in keyring_read()Eric Biggers
commit e645016abc803dafc75e4b8f6e4118f088900ffb upstream. Userspace can call keyctl_read() on a keyring to get the list of IDs of keys in the keyring. But if the user-supplied buffer is too small, the kernel would write the full list anyway --- which will corrupt whatever userspace memory happened to be past the end of the buffer. Fix it by only filling the space that is available. Fixes: b2a4df200d57 ("KEYS: Expand the capacity of a keyring") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15KEYS: Fix an error code in request_master_key()Dan Carpenter
commit 57cb17e764ba0aaa169d07796acce54ccfbc6cae upstream. This function has two callers and neither are able to handle a NULL return. Really, -EINVAL is the correct thing return here anyway. This fixes some static checker warnings like: security/keys/encrypted-keys/encrypted.c:709 encrypted_key_decrypt() error: uninitialized symbol 'master_key'. Fixes: 7e70cb497850 ("keys: add new key-type encrypted") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14KEYS: fix freeing uninitialized memory in key_update()Eric Biggers
commit 63a0b0509e700717a59f049ec6e4e04e903c7fe2 upstream. key_update() freed the key_preparsed_payload even if it was not initialized first. This would cause a crash if userspace called keyctl_update() on a key with type like "asymmetric" that has a ->preparse() method but not an ->update() method. Possibly it could even be triggered for other key types by racing with keyctl_setperm() to make the KEY_NEED_WRITE check fail (the permission was already checked, so normally it wouldn't fail there). Reproducer with key type "asymmetric", given a valid cert.der: keyctl new_session keyid=$(keyctl padd asymmetric desc @s < cert.der) keyctl setperm $keyid 0x3f000000 keyctl update $keyid data [ 150.686666] BUG: unable to handle kernel NULL pointer dereference at 0000000000000001 [ 150.687601] IP: asymmetric_key_free_kids+0x12/0x30 [ 150.688139] PGD 38a3d067 [ 150.688141] PUD 3b3de067 [ 150.688447] PMD 0 [ 150.688745] [ 150.689160] Oops: 0000 [#1] SMP [ 150.689455] Modules linked in: [ 150.689769] CPU: 1 PID: 2478 Comm: keyctl Not tainted 4.11.0-rc4-xfstests-00187-ga9f6b6b8cd2f #742 [ 150.690916] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014 [ 150.692199] task: ffff88003b30c480 task.stack: ffffc90000350000 [ 150.692952] RIP: 0010:asymmetric_key_free_kids+0x12/0x30 [ 150.693556] RSP: 0018:ffffc90000353e58 EFLAGS: 00010202 [ 150.694142] RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000004 [ 150.694845] RDX: ffffffff81ee3920 RSI: ffff88003d4b0700 RDI: 0000000000000001 [ 150.697569] RBP: ffffc90000353e60 R08: ffff88003d5d2140 R09: 0000000000000000 [ 150.702483] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000001 [ 150.707393] R13: 0000000000000004 R14: ffff880038a4d2d8 R15: 000000000040411f [ 150.709720] FS: 00007fcbcee35700(0000) GS:ffff88003fd00000(0000) knlGS:0000000000000000 [ 150.711504] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 150.712733] CR2: 0000000000000001 CR3: 0000000039eab000 CR4: 00000000003406e0 [ 150.714487] Call Trace: [ 150.714975] asymmetric_key_free_preparse+0x2f/0x40 [ 150.715907] key_update+0xf7/0x140 [ 150.716560] ? key_default_cmp+0x20/0x20 [ 150.717319] keyctl_update_key+0xb0/0xe0 [ 150.718066] SyS_keyctl+0x109/0x130 [ 150.718663] entry_SYSCALL_64_fastpath+0x1f/0xc2 [ 150.719440] RIP: 0033:0x7fcbce75ff19 [ 150.719926] RSP: 002b:00007ffd5d167088 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa [ 150.720918] RAX: ffffffffffffffda RBX: 0000000000404d80 RCX: 00007fcbce75ff19 [ 150.721874] RDX: 00007ffd5d16785e RSI: 000000002866cd36 RDI: 0000000000000002 [ 150.722827] RBP: 0000000000000006 R08: 000000002866cd36 R09: 00007ffd5d16785e [ 150.723781] R10: 0000000000000004 R11: 0000000000000206 R12: 0000000000404d80 [ 150.724650] R13: 00007ffd5d16784d R14: 00007ffd5d167238 R15: 000000000040411f [ 150.725447] Code: 83 c4 08 31 c0 5b 41 5c 41 5d 41 5e 41 5f 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 85 ff 74 23 55 48 89 e5 53 48 89 fb <48> 8b 3f e8 06 21 c5 ff 48 8b 7b 08 e8 fd 20 c5 ff 48 89 df e8 [ 150.727489] RIP: asymmetric_key_free_kids+0x12/0x30 RSP: ffffc90000353e58 [ 150.728117] CR2: 0000000000000001 [ 150.728430] ---[ end trace f7f8fe1da2d5ae8d ]--- Fixes: 4d8c0250b841 ("KEYS: Call ->free_preparse() even after ->preparse() returns an error") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14KEYS: fix dereferencing NULL payload with nonzero lengthEric Biggers
commit 5649645d725c73df4302428ee4e02c869248b4c5 upstream. sys_add_key() and the KEYCTL_UPDATE operation of sys_keyctl() allowed a NULL payload with nonzero length to be passed to the key type's ->preparse(), ->instantiate(), and/or ->update() methods. Various key types including asymmetric, cifs.idmap, cifs.spnego, and pkcs7_test did not handle this case, allowing an unprivileged user to trivially cause a NULL pointer dereference (kernel oops) if one of these key types was present. Fix it by doing the copy_from_user() when 'plen' is nonzero rather than when '_payload' is non-NULL, causing the syscall to fail with EFAULT as expected when an invalid buffer is specified. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25ima: accept previously set IMA_NEW_FILEDaniel Glöckner
commit 1ac202e978e18f045006d75bd549612620c6ec3a upstream. Modifying the attributes of a file makes ima_inode_post_setattr reset the IMA cache flags. So if the file, which has just been created, is opened a second time before the first file descriptor is closed, verification fails since the security.ima xattr has not been written yet. We therefore have to look at the IMA_NEW_FILE even if the file already existed. With this patch there should no longer be an error when cat tries to open testfile: $ rm -f testfile $ ( echo test >&3 ; touch testfile ; cat testfile ) 3>testfile A file being new is no reason to accept that it is missing a digital signature demanded by the policy. Signed-off-by: Daniel Glöckner <dg@emlix.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27KEYS: fix keyctl_set_reqkey_keyring() to not leak thread keyringsEric Biggers
commit c9f838d104fed6f2f61d68164712e3204bf5271b upstream. This fixes CVE-2017-7472. Running the following program as an unprivileged user exhausts kernel memory by leaking thread keyrings: #include <keyutils.h> int main() { for (;;) keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_THREAD_KEYRING); } Fix it by only creating a new thread keyring if there wasn't one before. To make things more consistent, make install_thread_keyring_to_cred() and install_process_keyring_to_cred() both return 0 if the corresponding keyring is already present. Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27KEYS: Change the name of the dead type to ".dead" to prevent user accessDavid Howells
commit c1644fe041ebaf6519f6809146a77c3ead9193af upstream. This fixes CVE-2017-6951. Userspace should not be able to do things with the "dead" key type as it doesn't have some of the helper functions set upon it that the kernel needs. Attempting to use it may cause the kernel to crash. Fix this by changing the name of the type to ".dead" so that it's rejected up front on userspace syscalls by key_get_type_from_user(). Though this doesn't seem to affect recent kernels, it does affect older ones, certainly those prior to: commit c06cfb08b88dfbe13be44a69ae2fdc3a7c902d81 Author: David Howells <dhowells@redhat.com> Date: Tue Sep 16 17:36:06 2014 +0100 KEYS: Remove key_type::match in favour of overriding default by match_preparse which went in before 3.18-rc1. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27KEYS: Disallow keyrings beginning with '.' to be joined as session keyringsDavid Howells
commit ee8f844e3c5a73b999edf733df1c529d6503ec2f upstream. This fixes CVE-2016-9604. Keyrings whose name begin with a '.' are special internal keyrings and so userspace isn't allowed to create keyrings by this name to prevent shadowing. However, the patch that added the guard didn't fix KEYCTL_JOIN_SESSION_KEYRING. Not only can that create dot-named keyrings, it can also subscribe to them as a session keyring if they grant SEARCH permission to the user. This, for example, allows a root process to set .builtin_trusted_keys as its session keyring, at which point it has full access because now the possessor permissions are added. This permits root to add extra public keys, thereby bypassing module verification. This also affects kexec and IMA. This can be tested by (as root): keyctl session .builtin_trusted_keys keyctl add user a a @s keyctl list @s which on my test box gives me: 2 keys in keyring: 180010936: ---lswrv 0 0 asymmetric: Build time autogenerated kernel key: ae3d4a31b82daa8e1a75b49dc2bba949fd992a05 801382539: --alswrv 0 0 user: a Fix this by rejecting names beginning with a '.' in the keyctl. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> cc: linux-ima-devel@lists.sourceforge.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14selinux: fix off-by-one in setprocattrStephen Smalley
commit 0c461cb727d146c9ef2d3e86214f498b78b7d125 upstream. SELinux tries to support setting/clearing of /proc/pid/attr attributes from the shell by ignoring terminating newlines and treating an attribute value that begins with a NUL or newline as an attempt to clear the attribute. However, the test for clearing attributes has always been wrong; it has an off-by-one error, and this could further lead to reading past the end of the allocated buffer since commit bb646cdb12e75d82258c2f2e7746d5952d3e321a ("proc_pid_attr_write(): switch to memdup_user()"). Fix the off-by-one error. Even with this fix, setting and clearing /proc/pid/attr attributes from the shell is not straightforward since the interface does not support multiple write() calls (so shells that write the value and newline separately will set and then immediately clear the attribute, requiring use of echo -n to set the attribute), whereas trying to use echo -n "" to clear the attribute causes the shell to skip the write() call altogether since POSIX says that a zero-length write causes no side effects. Thus, one must use echo -n to set and echo without -n to clear, as in the following example: $ echo -n unconfined_u:object_r:user_home_t:s0 > /proc/$$/attr/fscreate $ cat /proc/$$/attr/fscreate unconfined_u:object_r:user_home_t:s0 $ echo "" > /proc/$$/attr/fscreate $ cat /proc/$$/attr/fscreate Note the use of /proc/$$ rather than /proc/self, as otherwise the cat command will read its own attribute value, not that of the shell. There are no users of this facility to my knowledge; possibly we should just get rid of it. UPDATE: Upon further investigation it appears that a local process with the process:setfscreate permission can cause a kernel panic as a result of this bug. This patch fixes CVE-2017-2618. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> [PM: added the update about CVE-2017-2618 to the commit description] Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-12-02apparmor: fix change_hat not finding hat after policy replacementJohn Johansen
commit 3d40658c977769ce2138f286cf131537bf68bdfe upstream. After a policy replacement, the task cred may be out of date and need to be updated. However change_hat is using the stale profiles from the out of date cred resulting in either: a stale profile being applied or, incorrect failure when searching for a hat profile as it has been migrated to the new parent profile. Fixes: 01e2b670aa898a39259bc85c78e3d74820f4d3b6 (failure to find hat) Fixes: 898127c34ec03291c86f4ff3856d79e9e18952bc (stale policy being applied) Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1000287 Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10KEYS: Fix short sprintf buffer in /proc/keys show functionDavid Howells
commit 03dab869b7b239c4e013ec82aea22e181e441cfc upstream. This fixes CVE-2016-7042. Fix a short sprintf buffer in proc_keys_show(). If the gcc stack protector is turned on, this can cause a panic due to stack corruption. The problem is that xbuf[] is not big enough to hold a 64-bit timeout rendered as weeks: (gdb) p 0xffffffffffffffffULL/(60*60*24*7) $2 = 30500568904943 That's 14 chars plus NUL, not 11 chars plus NUL. Expand the buffer to 16 chars. I think the unpatched code apparently works if the stack-protector is not enabled because on a 32-bit machine the buffer won't be overflowed and on a 64-bit machine there's a 64-bit aligned pointer at one side and an int that isn't checked again on the other side. The panic incurred looks something like: Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff81352ebe CPU: 0 PID: 1692 Comm: reproducer Not tainted 4.7.2-201.fc24.x86_64 #1 Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011 0000000000000086 00000000fbbd2679 ffff8800a044bc00 ffffffff813d941f ffffffff81a28d58 ffff8800a044bc98 ffff8800a044bc88 ffffffff811b2cb6 ffff880000000010 ffff8800a044bc98 ffff8800a044bc30 00000000fbbd2679 Call Trace: [<ffffffff813d941f>] dump_stack+0x63/0x84 [<ffffffff811b2cb6>] panic+0xde/0x22a [<ffffffff81352ebe>] ? proc_keys_show+0x3ce/0x3d0 [<ffffffff8109f7f9>] __stack_chk_fail+0x19/0x30 [<ffffffff81352ebe>] proc_keys_show+0x3ce/0x3d0 [<ffffffff81350410>] ? key_validate+0x50/0x50 [<ffffffff8134db30>] ? key_default_cmp+0x20/0x20 [<ffffffff8126b31c>] seq_read+0x2cc/0x390 [<ffffffff812b6b12>] proc_reg_read+0x42/0x70 [<ffffffff81244fc7>] __vfs_read+0x37/0x150 [<ffffffff81357020>] ? security_file_permission+0xa0/0xc0 [<ffffffff81246156>] vfs_read+0x96/0x130 [<ffffffff81247635>] SyS_read+0x55/0xc0 [<ffffffff817eb872>] entry_SYSCALL_64_fastpath+0x1a/0xa4 Reported-by: Ondrej Kozina <okozina@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ondrej Kozina <okozina@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16ima: use file_dentry()Miklos Szeredi
commit e71b9dff0634edb127f449e076e883ef24a8c76c upstream. Ima tries to call ->setxattr() on overlayfs dentry after having locked underlying inode, which results in a deadlock. Reported-by: Krisztian Litkey <kli@iki.fi> Fixes: 4bacc9c9234c ("overlayfs: Make f_path always point to the overlay and f_inode to the underlay") Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-16apparmor: fix ref count leak when profile sha1 hash is readJohn Johansen
commit 0b938a2e2cf0b0a2c8bac9769111545aff0fee97 upstream. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Seth Arnold <seth.arnold@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27KEYS: potential uninitialized variableDan Carpenter
commit 38327424b40bcebe2de92d07312c89360ac9229a upstream. If __key_link_begin() failed then "edit" would be uninitialized. I've added a check to fix that. This allows a random user to crash the kernel, though it's quite difficult to achieve. There are three ways it can be done as the user would have to cause an error to occur in __key_link(): (1) Cause the kernel to run out of memory. In practice, this is difficult to achieve without ENOMEM cropping up elsewhere and aborting the attempt. (2) Revoke the destination keyring between the keyring ID being looked up and it being tested for revocation. In practice, this is difficult to time correctly because the KEYCTL_REJECT function can only be used from the request-key upcall process. Further, users can only make use of what's in /sbin/request-key.conf, though this does including a rejection debugging test - which means that the destination keyring has to be the caller's session keyring in practice. (3) Have just enough key quota available to create a key, a new session keyring for the upcall and a link in the session keyring, but not then sufficient quota to create a link in the nominated destination keyring so that it fails with EDQUOT. The bug can be triggered using option (3) above using something like the following: echo 80 >/proc/sys/kernel/keys/root_maxbytes keyctl request2 user debug:fred negate @t The above sets the quota to something much lower (80) to make the bug easier to trigger, but this is dependent on the system. Note also that the name of the keyring created contains a random number that may be between 1 and 10 characters in size, so may throw the test off by changing the amount of quota used. Assuming the failure occurs, something like the following will be seen: kfree_debugcheck: out of range ptr 6b6b6b6b6b6b6b68h ------------[ cut here ]------------ kernel BUG at ../mm/slab.c:2821! ... RIP: 0010:[<ffffffff811600f9>] kfree_debugcheck+0x20/0x25 RSP: 0018:ffff8804014a7de8 EFLAGS: 00010092 RAX: 0000000000000034 RBX: 6b6b6b6b6b6b6b68 RCX: 0000000000000000 RDX: 0000000000040001 RSI: 00000000000000f6 RDI: 0000000000000300 RBP: ffff8804014a7df0 R08: 0000000000000001 R09: 0000000000000000 R10: ffff8804014a7e68 R11: 0000000000000054 R12: 0000000000000202 R13: ffffffff81318a66 R14: 0000000000000000 R15: 0000000000000001 ... Call Trace: kfree+0xde/0x1bc assoc_array_cancel_edit+0x1f/0x36 __key_link_end+0x55/0x63 key_reject_and_link+0x124/0x155 keyctl_reject_key+0xb6/0xe0 keyctl_negate_key+0x10/0x12 SyS_keyctl+0x9f/0xe7 do_syscall_64+0x63/0x13a entry_SYSCALL64_slow_path+0x25/0x25 Fixes: f70e2e06196a ('KEYS: Do preallocation for __key_link()') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03security: let security modules use PTRACE_MODE_* with bitmasksJann Horn
commit 3dfb7d8cdbc7ea0c2970450e60818bb3eefbad69 upstream. It looks like smack and yama weren't aware that the ptrace mode can have flags ORed into it - PTRACE_MODE_NOAUDIT until now, but only for /proc/$pid/stat, and with the PTRACE_MODE_*CREDS patch, all modes have flags ORed into them. Signed-off-by: Jann Horn <jann@thejh.net> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-25ptrace: use fsuid, fsgid, effective creds for fs access checksJann Horn
commit caaee6234d05a58c5b4d05e7bf766131b810a657 upstream. By checking the effective credentials instead of the real UID / permitted capabilities, ensure that the calling process actually intended to use its credentials. To ensure that all ptrace checks use the correct caller credentials (e.g. in case out-of-tree code or newly added code omits the PTRACE_MODE_*CREDS flag), use two new flags and require one of them to be set. The problem was that when a privileged task had temporarily dropped its privileges, e.g. by calling setreuid(0, user_uid), with the intent to perform following syscalls with the credentials of a user, it still passed ptrace access checks that the user would not be able to pass. While an attacker should not be able to convince the privileged task to perform a ptrace() syscall, this is a problem because the ptrace access check is reused for things in procfs. In particular, the following somewhat interesting procfs entries only rely on ptrace access checks: /proc/$pid/stat - uses the check for determining whether pointers should be visible, useful for bypassing ASLR /proc/$pid/maps - also useful for bypassing ASLR /proc/$pid/cwd - useful for gaining access to restricted directories that contain files with lax permissions, e.g. in this scenario: lrwxrwxrwx root root /proc/13020/cwd -> /root/foobar drwx------ root root /root drwxr-xr-x root root /root/foobar -rw-r--r-- root root /root/foobar/secret Therefore, on a system where a root-owned mode 6755 binary changes its effective credentials as described and then dumps a user-specified file, this could be used by an attacker to reveal the memory layout of root's processes or reveal the contents of files he is not allowed to access (through /proc/$pid/cwd). [akpm@linux-foundation.org: fix warning] Signed-off-by: Jann Horn <jann@thejh.net> Acked-by: Kees Cook <keescook@chromium.org> Cc: Casey Schaufler <casey@schaufler-ca.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17EVM: Use crypto_memneq() for digest comparisonsRyan Ware
commit 613317bd212c585c20796c10afe5daaa95d4b0a1 upstream. This patch fixes vulnerability CVE-2016-2085. The problem exists because the vm_verify_hmac() function includes a use of memcmp(). Unfortunately, this allows timing side channel attacks; specifically a MAC forgery complexity drop from 2^128 to 2^12. This patch changes the memcmp() to the cryptographically safe crypto_memneq(). Reported-by: Xiaofei Rex Guo <xiaofei.rex.guo@intel.com> Signed-off-by: Ryan Ware <ware@linux.intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-31KEYS: Fix keyring ref leak in join_session_keyring()Yevgeny Pats
commit 23567fd052a9abb6d67fe8e7a9ccdd9800a540f2 upstream. This fixes CVE-2016-0728. If a thread is asked to join as a session keyring the keyring that's already set as its session, we leak a keyring reference. This can be tested with the following program: #include <stddef.h> #include <stdio.h> #include <sys/types.h> #include <keyutils.h> int main(int argc, const char *argv[]) { int i = 0; key_serial_t serial; serial = keyctl(KEYCTL_JOIN_SESSION_KEYRING, "leaked-keyring"); if (serial < 0) { perror("keyctl"); return -1; } if (keyctl(KEYCTL_SETPERM, serial, KEY_POS_ALL | KEY_USR_ALL) < 0) { perror("keyctl"); return -1; } for (i = 0; i < 100; i++) { serial = keyctl(KEYCTL_JOIN_SESSION_KEYRING, "leaked-keyring"); if (serial < 0) { perror("keyctl"); return -1; } } return 0; } If, after the program has run, there something like the following line in /proc/keys: 3f3d898f I--Q--- 100 perm 3f3f0000 0 0 keyring leaked-keyring: empty with a usage count of 100 * the number of times the program has been run, then the kernel is malfunctioning. If leaked-keyring has zero usages or has been garbage collected, then the problem is fixed. Reported-by: Yevgeny Pats <yevgeny@perception-point.io> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Don Zickus <dzickus@redhat.com> Acked-by: Prarit Bhargava <prarit@redhat.com> Acked-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-12-19KEYS: Fix race between read and revokeDavid Howells
This fixes CVE-2015-7550. There's a race between keyctl_read() and keyctl_revoke(). If the revoke happens between keyctl_read() checking the validity of a key and the key's semaphore being taken, then the key type read method will see a revoked key. This causes a problem for the user-defined key type because it assumes in its read method that there will always be a payload in a non-revoked key and doesn't check for a NULL pointer. Fix this by making keyctl_read() check the validity of a key after taking semaphore instead of before. I think the bug was introduced with the original keyrings code. This was discovered by a multithreaded test program generated by syzkaller (http://github.com/google/syzkaller). Here's a cleaned up version: #include <sys/types.h> #include <keyutils.h> #include <pthread.h> void *thr0(void *arg) { key_serial_t key = (unsigned long)arg; keyctl_revoke(key); return 0; } void *thr1(void *arg) { key_serial_t key = (unsigned long)arg; char buffer[16]; keyctl_read(key, buffer, 16); return 0; } int main() { key_serial_t key = add_key("user", "%", "foo", 3, KEY_SPEC_USER_KEYRING); pthread_t th[5]; pthread_create(&th[0], 0, thr0, (void *)(unsigned long)key); pthread_create(&th[1], 0, thr1, (void *)(unsigned long)key); pthread_create(&th[2], 0, thr0, (void *)(unsigned long)key); pthread_create(&th[3], 0, thr1, (void *)(unsigned long)key); pthread_join(th[0], 0); pthread_join(th[1], 0); pthread_join(th[2], 0); pthread_join(th[3], 0); return 0; } Build as: cc -o keyctl-race keyctl-race.c -lkeyutils -lpthread Run as: while keyctl-race; do :; done as it may need several iterations to crash the kernel. The crash can be summarised as: BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 IP: [<ffffffff81279b08>] user_read+0x56/0xa3 ... Call Trace: [<ffffffff81276aa9>] keyctl_read_key+0xb6/0xd7 [<ffffffff81277815>] SyS_keyctl+0x83/0xe0 [<ffffffff815dbb97>] entry_SYSCALL_64_fastpath+0x12/0x6f Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Dmitry Vyukov <dvyukov@google.com> Cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-11-26Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/selinux ↵James Morris
into for-linus2
2015-11-25KEYS: Fix handling of stored error in a negatively instantiated user keyDavid Howells
If a user key gets negatively instantiated, an error code is cached in the payload area. A negatively instantiated key may be then be positively instantiated by updating it with valid data. However, the ->update key type method must be aware that the error code may be there. The following may be used to trigger the bug in the user key type: keyctl request2 user user "" @u keyctl add user user "a" @u which manifests itself as: BUG: unable to handle kernel paging request at 00000000ffffff8a IP: [<ffffffff810a376f>] __call_rcu.constprop.76+0x1f/0x280 kernel/rcu/tree.c:3046 PGD 7cc30067 PUD 0 Oops: 0002 [#1] SMP Modules linked in: CPU: 3 PID: 2644 Comm: a.out Not tainted 4.3.0+ #49 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff88003ddea700 ti: ffff88003dd88000 task.ti: ffff88003dd88000 RIP: 0010:[<ffffffff810a376f>] [<ffffffff810a376f>] __call_rcu.constprop.76+0x1f/0x280 [<ffffffff810a376f>] __call_rcu.constprop.76+0x1f/0x280 kernel/rcu/tree.c:3046 RSP: 0018:ffff88003dd8bdb0 EFLAGS: 00010246 RAX: 00000000ffffff82 RBX: 0000000000000000 RCX: 0000000000000001 RDX: ffffffff81e3fe40 RSI: 0000000000000000 RDI: 00000000ffffff82 RBP: ffff88003dd8bde0 R08: ffff88007d2d2da0 R09: 0000000000000000 R10: 0000000000000000 R11: ffff88003e8073c0 R12: 00000000ffffff82 R13: ffff88003dd8be68 R14: ffff88007d027600 R15: ffff88003ddea700 FS: 0000000000b92880(0063) GS:ffff88007fd00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000ffffff8a CR3: 000000007cc5f000 CR4: 00000000000006e0 Stack: ffff88003dd8bdf0 ffffffff81160a8a 0000000000000000 00000000ffffff82 ffff88003dd8be68 ffff88007d027600 ffff88003dd8bdf0 ffffffff810a39e5 ffff88003dd8be20 ffffffff812a31ab ffff88007d027600 ffff88007d027620 Call Trace: [<ffffffff810a39e5>] kfree_call_rcu+0x15/0x20 kernel/rcu/tree.c:3136 [<ffffffff812a31ab>] user_update+0x8b/0xb0 security/keys/user_defined.c:129 [< inline >] __key_update security/keys/key.c:730 [<ffffffff8129e5c1>] key_create_or_update+0x291/0x440 security/keys/key.c:908 [< inline >] SYSC_add_key security/keys/keyctl.c:125 [<ffffffff8129fc21>] SyS_add_key+0x101/0x1e0 security/keys/keyctl.c:60 [<ffffffff8185f617>] entry_SYSCALL_64_fastpath+0x12/0x6a arch/x86/entry/entry_64.S:185 Note the error code (-ENOKEY) in EDX. A similar bug can be tripped by: keyctl request2 trusted user "" @u keyctl add trusted user "a" @u This should also affect encrypted keys - but that has to be correctly parameterised or it will fail with EINVAL before getting to the bit that will crashes. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
