Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
commit 154c50ca4eb9ae472f50b6a481213e21ead4457d upstream.
We reset the bool names and values array to NULL, but do not reset the
number of entries in these arrays to 0. If we error out and then get back
into this function we will walk these NULL pointers based on the belief
that they are non-zero length.
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 51b79bee627d526199b2f6a6bef8ee0c0739b6d1 upstream.
Add missing "personality.h"
security/commoncap.c: In function 'cap_bprm_set_creds':
security/commoncap.c:510: error: 'PER_CLEAR_ON_SETID' undeclared (first use in this function)
security/commoncap.c:510: error: (Each undeclared identifier is reported only once
security/commoncap.c:510: error: for each function it appears in.)
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Cc: Eric Paris <eparis@redhat.com>
commit d52fc5dde171f030170a6cb78034d166b13c9445 upstream.
If a process increases permissions using fcaps all of the dangerous
personality flags which are cleared for suid apps should also be cleared.
Thus programs given priviledge with fcaps will continue to have address space
randomization enabled even if the parent tried to disable it to make it
easier to attack.
Reviewed-by: Serge Hallyn <serge.hallyn@canonical.com>
commit df91e49477a9be15921cb2854e1d12a3bdb5e425 upstream.
Userspace can pass in arbitrary combinations of MS_* flags to mount().
If both MS_BIND and one of MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE are
passed, device name which should be checked for MS_BIND was not checked because
MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE had higher priority than MS_BIND.
If both one of MS_BIND/MS_MOVE and MS_REMOUNT are passed, device name which
should not be checked for MS_REMOUNT was checked because MS_BIND/MS_MOVE had
higher priority than MS_REMOUNT.
Fix these bugs by changing priority to MS_REMOUNT -> MS_BIND ->
MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE -> MS_MOVE as with do_mount() does.
Also, unconditionally return -EINVAL if more than one of
MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE is passed so that TOMOYO will not
generate inaccurate audit logs, for commit 7a2e8a8f "VFS: Sanity check mount
flags passed to change_mnt_propagation()" clarified that these flags must be
exclusively passed.
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
commit 7b7e5916aa2f46e57f8bd8cb89c34620ebfda5da upstream.
Don't free a valid measurement entry on TPM PCR extend failure.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
commit 45fae7493970d7c45626ccd96d4a74f5f1eea5a9 upstream.
Info about new measurements are cached in the iint for performance. When
the inode is flushed from cache, the associated iint is flushed as well.
Subsequent access to the inode will cause the inode to be re-measured and
will attempt to add a duplicate entry to the measurement list.
This patch frees the duplicate measurement memory, fixing a memory leak.
commit 50345f1ea9cda4618d9c26e590a97ecd4bc7ac75 upstream.
Fix the following bug in sel_netport_insert() where rcu_dereference() should
be rcu_dereference_protected() as sel_netport_lock is held.
[ INFO: suspicious rcu_dereference_check() usage. ]
security/selinux/netport.c:127 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 0
1 lock held by ossec-rootcheck/3323:
#0: (sel_netport_lock){+.....}, at: [<ffffffff8117d775>] sel_netport_sid+0xbb/0x226
stack backtrace:
Pid: 3323, comm: ossec-rootcheck Not tainted 3.1.0-rc8-fsdevel+ #1095
Call Trace:
[<ffffffff8105cfb7>] lockdep_rcu_dereference+0xa7/0xb0
[<ffffffff8117d871>] sel_netport_sid+0x1b7/0x226
[<ffffffff8117d6ba>] ? sel_netport_avc_callback+0xbc/0xbc
[<ffffffff8117556c>] selinux_socket_bind+0x115/0x230
[<ffffffff810a5388>] ? might_fault+0x4e/0x9e
[<ffffffff810a53d1>] ? might_fault+0x97/0x9e
[<ffffffff81171cf4>] security_socket_bind+0x11/0x13
[<ffffffff812ba967>] sys_bind+0x56/0x95
[<ffffffff81380dac>] ? sysret_check+0x27/0x62
[<ffffffff8105b767>] ? trace_hardirqs_on_caller+0x11e/0x155
[<ffffffff81076fcd>] ? audit_syscall_entry+0x17b/0x1ae
[<ffffffff811b5eae>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff81380d7b>] system_call_fastpath+0x16/0x1b
Acked-by: Paul Moore <paul@paul-moore.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit 02125a826459a6ad142f8d91c5b6357562f96615 upstream.
__d_path() API is asking for trouble and in case of apparmor d_namespace_path()
getting just that. The root cause is that when __d_path() misses the root
it had been told to look for, it stores the location of the most remote ancestor
in *root. Without grabbing references. Sure, at the moment of call it had
been pinned down by what we have in *path. And if we raced with umount -l, we
could have very well stopped at vfsmount/dentry that got freed as soon as
prepend_path() dropped vfsmount_lock.
It is safe to compare these pointers with pre-existing (and known to be still
alive) vfsmount and dentry, as long as all we are asking is "is it the same
address?". Dereferencing is not safe and apparmor ended up stepping into
that. d_namespace_path() really wants to examine the place where we stopped,
even if it's not connected to our namespace. As the result, it looked
at ->d_sb->s_magic of a dentry that might've been already freed by that point.
All other callers had been careful enough to avoid that, but it's really
a bad interface - it invites that kind of trouble.
The fix is fairly straightforward, even though it's bigger than I'd like:
* prepend_path() root argument becomes const.
* __d_path() is never called with NULL/NULL root. It was a kludge
to start with. Instead, we have an explicit function - d_absolute_root().
Same as __d_path(), except that it doesn't get root passed and stops where
it stops. apparmor and tomoyo are using it.
* __d_path() returns NULL on path outside of root. The main
caller is show_mountinfo() and that's precisely what we pass root for - to
skip those outside chroot jail. Those who don't want that can (and do)
use d_path().
* __d_path() root argument becomes const. Everyone agrees, I hope.
* apparmor does *NOT* try to use __d_path() or any of its variants
when it sees that path->mnt is an internal vfsmount. In that case it's
definitely not mounted anywhere and dentry_path() is exactly what we want
there. Handling of sysctl()-triggered weirdness is moved to that place.
* if apparmor is asked to do pathname relative to chroot jail
and __d_path() tells it we it's not in that jail, the sucker just calls
d_absolute_path() instead. That's the other remaining caller of __d_path(),
BTW.
* seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway -
the normal seq_file logics will take care of growing the buffer and redoing
the call of ->show() just fine). However, if it gets path not reachable
from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped
ignoring the return value as it used to do).
Reviewed-by: John Johansen <john.johansen@canonical.com>
ACKed-by: John Johansen <john.johansen@canonical.com>
commit 9f35a33b8d06263a165efe3541d9aa0cdbd70b3b upstream.
Fix a NULL pointer deref in the user-defined key type whereby updating a
negative key into a fully instantiated key will cause an oops to occur
when the code attempts to free the non-existent old payload.
This results in an oops that looks something like the following:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
PGD 3391d067 PUD 3894a067 PMD 0
Oops: 0002 [#1] SMP
CPU 1
Pid: 4354, comm: keyctl Not tainted 3.1.0-fsdevel+ #1140 /DG965RY
RIP: 0010:[<ffffffff81085fa1>] [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
RSP: 0018:ffff88003d591df8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000006e
RDX: ffffffff8161d0c0 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88003d591e18 R08: 0000000000000000 R09: ffffffff8152fa6c
R10: 0000000000000000 R11: 0000000000000300 R12: ffff88003b8f9538
R13: ffffffff8161d0c0 R14: ffff88003b8f9d50 R15: ffff88003c69f908
FS: 00007f97eb18c720(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CR2: 0000000000000008 CR3: 000000003d47a000 CR4: 00000000000006e0
Process keyctl (pid: 4354, threadinfo ffff88003d590000, task ffff88003c78a040)
Stack:
ffff88003e0ffde0 ffff88003b8f9538 0000000000000001 ffff88003b8f9d50
ffff88003d591e28 ffffffff810860f0 ffff88003d591e68 ffffffff8117bfea
ffff88003d591e68 ffffffff00000000 ffff88003e0ffde1 ffff88003e0ffde0
Call Trace:
[<ffffffff810860f0>] call_rcu_sched+0x10/0x12
[<ffffffff8117bfea>] user_update+0x8d/0xa2
[<ffffffff8117723a>] key_create_or_update+0x236/0x270
[<ffffffff811789b1>] sys_add_key+0x123/0x17e
[<ffffffff813b84bb>] system_call_fastpath+0x16/0x1b
Acked-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Neil Horman <nhorman@redhat.com>
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: James Morris <jmorris@namei.org>
commit 25e75dff519bcce2cb35023105e7df51d7b9e691 upstream.
AppArmor is masking the capabilities returned by capget against the
capabilities mask in the profile. This is wrong, in complain mode the
profile has effectively all capabilities, as the profile restrictions are
not being enforced, merely tested against to determine if an access is
known by the profile.
This can result in the wrong behavior of security conscience applications
like sshd which examine their capability set, and change their behavior
accordingly. In this case because of the masked capability set being
returned sshd fails due to DAC checks, even when the profile is in complain
mode.
Kernels affected: 2.6.36 - 3.0.
Signed-off-by: John Johansen <john.johansen@canonical.com>
commit 04fdc099f9c80c7775dbac388fc97e156d4d47e7 upstream.
The pointer returned from tracehook_tracer_task() is only valid inside
the rcu_read_lock. However the tracer pointer obtained is being passed
to aa_may_ptrace outside of the rcu_read_lock critical section.
Mover the aa_may_ptrace test into the rcu_read_lock critical section, to
fix this.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Fix error handling in construct_key_and_link().
If construct_alloc_key() returns an error, it shouldn't pass out through
the normal path as the key_serial() called by the kleave() statement
will oops when it gets an error code in the pointer:
BUG: unable to handle kernel paging request at ffffffffffffff84
IP: [<ffffffff8120b401>] request_key_and_link+0x4d7/0x52f
Call Trace:
[<ffffffff8120b52c>] request_key+0x41/0x75
[<ffffffffa00ed6e8>] cifs_get_spnego_key+0x206/0x226 [cifs]
[<ffffffffa00eb0c9>] CIFS_SessSetup+0x511/0x1234 [cifs]
[<ffffffffa00d9799>] cifs_setup_session+0x90/0x1ae [cifs]
[<ffffffffa00d9c02>] cifs_get_smb_ses+0x34b/0x40f [cifs]
[<ffffffffa00d9e05>] cifs_mount+0x13f/0x504 [cifs]
[<ffffffffa00caabb>] cifs_do_mount+0xc4/0x672 [cifs]
[<ffffffff8113ae8c>] mount_fs+0x69/0x155
[<ffffffff8114ff0e>] vfs_kern_mount+0x63/0xa0
[<ffffffff81150be2>] do_kern_mount+0x4d/0xdf
[<ffffffff81152278>] do_mount+0x63c/0x69f
[<ffffffff8115255c>] sys_mount+0x88/0xc2
[<ffffffff814fbdc2>] system_call_fastpath+0x16/0x1b
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
devcgroup_inode_permission: take "is it a device node" checks to inlined wrapper
fix comment in generic_permission()
kill obsolete comment for follow_down()
proc_sys_permission() is OK in RCU mode
reiserfs_permission() doesn't need to bail out in RCU mode
proc_fd_permission() is doesn't need to bail out in RCU mode
nilfs2_permission() doesn't need to bail out in RCU mode
logfs doesn't need ->permission() at all
coda_ioctl_permission() is safe in RCU mode
cifs_permission() doesn't need to bail out in RCU mode
bad_inode_permission() is safe from RCU mode
ubifs: dereferencing an ERR_PTR in ubifs_mount()
inode_permission() calls devcgroup_inode_permission() and almost all such
calls are _not_ for device nodes; let's at least keep the common path
straight...
____call_usermodehelper() now erases any credentials set by the
subprocess_inf::init() function. The problem is that commit
17f60a7da150 ("capabilites: allow the application of capability limits
to usermode helpers") creates and commits new credentials with
prepare_kernel_cred() after the call to the init() function. This wipes
all keyrings after umh_keys_init() is called.
The best way to deal with this is to put the init() call just prior to
the commit_creds() call, and pass the cred pointer to init(). That
means that umh_keys_init() and suchlike can modify the credentials
_before_ they are published and potentially in use by the rest of the
system.
This prevents request_key() from working as it is prevented from passing
the session keyring it set up with the authorisation token to
/sbin/request-key, and so the latter can't assume the authority to
instantiate the key. This causes the in-kernel DNS resolver to fail
with ENOKEY unconditionally.
Acked-by: Eric Paris <eparis@redhat.com>
Tested-by: Jeff Layton <jlayton@redhat.com>
into for-linus
When policy version is less than POLICYDB_VERSION_FILENAME_TRANS,
skip file_name_trans_write().
Signed-off-by: Roy.Li <rongqing.li@windriver.com>
In tomoyo_mount_acl() since 2.6.36, kern_path() was called without checking
dev_name != NULL. As a result, an unprivileged user can trigger oops by issuing
mount(NULL, "/", "ext3", 0, NULL) request.
Fix this by checking dev_name != NULL before calling kern_path(dev_name).
Cc: stable@kernel.org
Affected kernels 2.6.36 - 3.0
AppArmor may do a GFP_KERNEL memory allocation with task_lock(tsk->group_leader);
held when called from security_task_setrlimit. This will only occur when the
task's current policy has been replaced, and the task's creds have not been
updated before entering the LSM security_task_setrlimit() hook.
BUG: sleeping function called from invalid context at mm/slub.c:847
in_atomic(): 1, irqs_disabled(): 0, pid: 1583, name: cupsd
2 locks held by cupsd/1583:
#0: (tasklist_lock){.+.+.+}, at: [<ffffffff8104dafa>] do_prlimit+0x61/0x189
#1: (&(&p->alloc_lock)->rlock){+.+.+.}, at: [<ffffffff8104db2d>]
do_prlimit+0x94/0x189
Pid: 1583, comm: cupsd Not tainted 3.0.0-rc2-git1 #7
Call Trace:
[<ffffffff8102ebf2>] __might_sleep+0x10d/0x112
[<ffffffff810e6f46>] slab_pre_alloc_hook.isra.49+0x2d/0x33
[<ffffffff810e7bc4>] kmem_cache_alloc+0x22/0x132
[<ffffffff8105b6e6>] prepare_creds+0x35/0xe4
[<ffffffff811c0675>] aa_replace_current_profile+0x35/0xb2
[<ffffffff811c4d2d>] aa_current_profile+0x45/0x4c
[<ffffffff811c4d4d>] apparmor_task_setrlimit+0x19/0x3a
[<ffffffff811beaa5>] security_task_setrlimit+0x11/0x13
[<ffffffff8104db6b>] do_prlimit+0xd2/0x189
[<ffffffff8104dea9>] sys_setrlimit+0x3b/0x48
[<ffffffff814062bb>] system_call_fastpath+0x16/0x1b
Reported-by: Miles Lane <miles.lane@gmail.com>
This is a rather hot function that is called with a potentially NULL
"struct common_audit_data" pointer argument. And in that case it has to
provide and initialize its own dummy common_audit_data structure.
However, all the _common_ cases already pass it a real audit-data
structure, so that uncommon NULL case not only creates a silly run-time
test, more importantly it causes that function to have a big stack frame
for the dummy variable that isn't even used in the common case!
So get rid of that stupid run-time behavior, and make the (few)
functions that currently call with a NULL pointer just call a new helper
function instead (naturally called inode_has_perm_noapd(), since it has
no adp argument).
This makes the run-time test be a static code generation issue instead,
and allows for a much denser stack since none of the common callers need
the dummy structure. And a denser stack not only means less stack space
usage, it means better cache behavior. So we have a win-win-win from
this simplification: less code executed, smaller stack footprint, and
When invalid parameters are passed to apparmor_setprocattr a NULL deref
oops occurs when it tries to record an audit message. This is because
it is passing NULL for the profile parameter for aa_audit. But aa_audit
now requires that the profile passed is not NULL.
Fix this by passing the current profile on the task that is trying to
setprocattr.
Signed-off-by: Kees Cook <kees@ubuntu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs
* 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs:
Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
Right now security_get_user_sids() will pass in a NULL avd pointer to
avc_has_perm_noaudit(), which then forces that function to have a dummy
entry for that case and just generally test it.
Don't do it. The normal callers all pass a real avd pointer, and this
helper function is incredibly hot. So don't make avc_has_perm_noaudit()
do conditional stuff that isn't needed for the common case.
This also avoids some duplicated stack space.
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts
Add can_attach_task(), pre_attach(), and attach_task() as new callbacks
for cgroups's subsystem interface. Unlike can_attach and attach, these
are for per-thread operations, to be called potentially many times when
attaching an entire threadgroup.
Also, the old "bool threadgroup" interface is removed, as replaced by
this. All subsystems are modified for the new interface - of note is
cpuset, which requires from/to nodemasks for attach to be globally scoped
(though per-cpuset would work too) to persist from its pre_attach to
attach_task and attach.
This is a pre-patch for cgroup-procs-writable.patch.
Signed-off-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Matt Helsley <matthltc@us.ibm.com>
Reviewed-by: Paul Menage <menage@google.com>
Cc: Miao Xie <miaox@cn.fujitsu.com>
I submit the patch again, according to patch submission convension.
This patch enables to accept percent-encoded object names as forth
argument of /selinux/create interface to avoid possible bugs when we
give an object name including whitespace or multibutes.
E.g) if and when a userspace object manager tries to create a new object
named as "resolve.conf but fake", it shall give this name as the forth
argument of the /selinux/create. But sscanf() logic in kernel space
fetches only the part earlier than the first whitespace.
In this case, selinux may unexpectedly answer a default security context
configured to "resolve.conf", but it is bug.
Although I could not test this patch on named TYPE_TRANSITION rules
actually, But debug printk() message seems to me the logic works
correctly.
I assume the libselinux provides an interface to apply this logic
transparently, so nothing shall not be changed from the viewpoint of
application.
Signed-off-by: KaiGai Kohei <kohei.kaigai@emea.nec.com>
lib/flex_array.c
security/selinux/avc.c
security/selinux/hooks.c
security/selinux/ss/policydb.c
security/smack/smack_lsm.c
Since this cred was not created with copy_creds(), it needs to get
initialized. Otherwise use of syscall(__NR_keyctl, KEYCTL_SESSION_TO_PARENT);
can lead to a NULL deref. Thanks to Robert for finding this.
But introduced by commit 47a150edc2a ("Cache user_ns in struct cred").
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Reported-by: Robert Święcki <robert@swiecki.net>
Cc: stable@kernel.org (2.6.39)
for-linus
lib/flex_array.c
Manually resolve conflicts.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
There is no point in counting hits - we can calculate it from the number
of lookups and misses.
This makes the avc statistics a bit smaller, and makes the code
generation better too.
You can turn off the avc cache stats, but distributions seem to not do
that (perhaps because several performance tuning how-to's talk about the
avc cache statistics).
Which is sad, because the code it generates is truly horrendous, with
the statistics update being sandwitched between get_cpu/put_cpu which in
turn causes preemption disables etc. We're talking ten+ instructions
just to increment a per-cpu variable in some pretty hot code.
Fix the craziness by just using 'this_cpu_inc()' instead. Suddenly we
only need a single 'inc' instruction to increment the statistics. This
is quite noticeable in the incredibly hot avc_has_perm_noaudit()
function (which triggers all the statistics by virtue of doing an
avc_lookup() call).
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits)
Revert "rcu: Decrease memory-barrier usage based on semi-formal proof"
net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree
batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu
batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree()
batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu
net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu()
net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu()
net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu()
perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu()
perf,rcu: convert call_rcu(free_ctx) to kfree_rcu()
net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(net_generic_release) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu()
security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu()
net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu()
net,rcu: convert call_rcu(xps_map_release) to kfree_rcu()
net,rcu: convert call_rcu(rps_map_release) to kfree_rcu()
include/linux/capability.h
Manually resolve merge conflict w/ thanks to Stephen Rothwell.
into for-linus
The filename_trans rule processing has some printk(KERN_ERR ) messages
which were intended as debug aids in creating the code but weren't removed
before it was submitted. Remove them.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
In tomoyo_correct_domain() since 2.6.36, TOMOYO was by error validating
"<kernel>" + "/foo/\" + "/bar" when "<kernel> /foo/\* /bar" was given.
As a result, legal domainnames like "<kernel> /foo/\* /bar" are rejected.
Reported-by: Hayama Yossihiro <yossi@yedo.src.co.jp>
In the interest of keeping userspace from having to create new root
filesystems all the time, let's follow the lead of the other in-kernel
filesystems and provide a proper mount point for it in sysfs.
For selinuxfs, this mount point should be in /sys/fs/selinux/
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Eric Paris <eparis@parisplace.org>
Cc: Lennart Poettering <mzerqung@0pointer.de>
Cc: Daniel J Walsh <dwalsh@redhat.com>
[include kobject.h - Eric Paris]
[use selinuxfs_obj throughout - Eric Paris]
The rcu callback sel_netif_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(sel_netif_free).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The rcu callback user_update_rcu_disposal() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(user_update_rcu_disposal).
into for-linus
Change flex_array_prealloc to take the number of elements for which space
should be allocated instead of the last (inclusive) element. Users
and documentation are updated accordingly. flex_arrays got introduced before
they had users. When folks started using it, they ended up needing a
different API than was coded up originally. This swaps over to the API that
folks apparently need.
Based-on-patch-by: Steffen Klassert <steffen.klassert@secunet.com>
Tested-by: Chris Richards <gizmo@giz-works.com>
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: stable@kernel.org [2.6.38+]
New inodes are created in a two stage process. We first will compute the
label on a new inode in security_inode_create() and check if the
operation is allowed. We will then actually re-compute that same label and
apply it in security_inode_init_security(). The change to do new label
calculations based in part on the last component of the path name only
passed the path component information all the way down the
security_inode_init_security hook. Down the security_inode_create hook the
path information did not make it past may_create. Thus the two calculations
came up differently and the permissions check might not actually be against
the label that is created. Pass and use the same information in both places
to harmonize the calculations and checks.
Reported-by: Dominick Grift <domg472@gmail.com>
We currently have inode_has_perm and dentry_has_perm. dentry_has_perm just
calls inode_has_perm with additional audit data. But dentry_has_perm can
take either a dentry or a path. Split those to make the code obvious and
to fix the previous problem where I thought dentry_has_perm always had a
valid dentry and mnt.
To shorten the list we need to run if filename trans rules exist for the type
of the given parent directory I put them in a hashtable. Given the policy we
are expecting to use in Fedora this takes the worst case list run from about
5,000 entries to 17.
Reviewed-by: James Morris <jmorris@namei.org>
Instead of a hashtab entry counter function only useful for range
transition rules make a function generic for any hashtable to use.
