path: root/security
2012-04-22security: fix compile error in commoncap.cJonghwan Choi
commit 51b79bee627d526199b2f6a6bef8ee0c0739b6d1 upstream. Add missing "personality.h" security/commoncap.c: In function 'cap_bprm_set_creds': security/commoncap.c:510: error: 'PER_CLEAR_ON_SETID' undeclared (first use in this function) security/commoncap.c:510: error: (Each undeclared identifier is reported only once security/commoncap.c:510: error: for each function it appears in.) Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-22fcaps: clear the same personality flags as suid when fcaps are usedEric Paris
commit d52fc5dde171f030170a6cb78034d166b13c9445 upstream. If a process increases permissions using fcaps all of the dangerous personality flags which are cleared for suid apps should also be cleared. Thus programs given priviledge with fcaps will continue to have address space randomization enabled even if the parent tried to disable it to make it easier to attack. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13TOMOYO: Fix mount flags checking order.Tetsuo Handa
commit df91e49477a9be15921cb2854e1d12a3bdb5e425 upstream. Userspace can pass in arbitrary combinations of MS_* flags to mount(). If both MS_BIND and one of MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE are passed, device name which should be checked for MS_BIND was not checked because MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE had higher priority than MS_BIND. If both one of MS_BIND/MS_MOVE and MS_REMOUNT are passed, device name which should not be checked for MS_REMOUNT was checked because MS_BIND/MS_MOVE had higher priority than MS_REMOUNT. Fix these bugs by changing priority to MS_REMOUNT -> MS_BIND -> MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE -> MS_MOVE as with do_mount() does. Also, unconditionally return -EINVAL if more than one of MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE is passed so that TOMOYO will not generate inaccurate audit logs, for commit 7a2e8a8f "VFS: Sanity check mount flags passed to change_mnt_propagation()" clarified that these flags must be exclusively passed. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ima: fix Kconfig dependenciesFabio Estevam
commit f4a0391dfa91155bd961673b31eb42d9d45c799d upstream. Fix the following build warning: warning: (IMA) selects TCG_TPM which has unmet direct dependencies (HAS_IOMEM && EXPERIMENTAL) Suggested-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29Security: tomoyo: add .gitignore fileGreg Kroah-Hartman
commit 735e93c70434614bffac4a914ca1da72e37d43c0 upstream. This adds the .gitignore file for the autogenerated TOMOYO files to keep git from complaining after building things. Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: James Morris <jmorris@namei.org> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-25TOMOYO: Accept \000 as a valid character.Tetsuo Handa
commit 25add8cf99c9ec8b8dc0acd8b9241e963fc0d29c upstream. TOMOYO 2.5 in Linux 3.2 and later handles Unix domain socket's address. Thus, tomoyo_correct_word2() needs to accept \000 as a valid character, or TOMOYO 2.5 cannot handle Unix domain's abstract socket address. Reported-by: Steven Allen <steven@stebalien.com> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25ima: fix invalid memory referenceRoberto Sassu
commit 7b7e5916aa2f46e57f8bd8cb89c34620ebfda5da upstream. Don't free a valid measurement entry on TPM PCR extend failure. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25ima: free duplicate measurement memoryRoberto Sassu
commit 45fae7493970d7c45626ccd96d4a74f5f1eea5a9 upstream. Info about new measurements are cached in the iint for performance. When the inode is flushed from cache, the associated iint is flushed as well. Subsequent access to the inode will cause the inode to be re-measured and will attempt to add a duplicate entry to the measurement list. This patch frees the duplicate measurement memory, fixing a memory leak. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-03security: Fix security_old_inode_init_security() when CONFIG_SECURITY is not setJan Kara
Commit 1e39f384bb01 ("evm: fix build problems") makes the stub version of security_old_inode_init_security() return 0 when CONFIG_SECURITY is not set. But that makes callers such as reiserfs_security_init() assume that security_old_inode_init_security() has set name, value, and len arguments properly - but security_old_inode_init_security() left them uninitialized which then results in interesting failures. Revert security_old_inode_init_security() to the old behavior of returning EOPNOTSUPP since both callers (reiserfs and ocfs2) handle this just fine. [ Also fixed the S_PRIVATE(inode) case of the actual non-stub security_old_inode_init_security() function to return EOPNOTSUPP for the same reason, as pointed out by Mimi Zohar. It got incorrectly changed to match the new function in commit fb88c2b6cbb1: "evm: fix security/security_old_init_security return code". - Linus ] Reported-by: Jorge Bastos <mysql.jorge@decimal.pt> Acked-by: James Morris <jmorris@namei.org> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-21SELinux: Fix RCU deref check warning in sel_netport_insert()David Howells
Fix the following bug in sel_netport_insert() where rcu_dereference() should be rcu_dereference_protected() as sel_netport_lock is held. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- security/selinux/netport.c:127 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 1 lock held by ossec-rootcheck/3323: #0: (sel_netport_lock){+.....}, at: [<ffffffff8117d775>] sel_netport_sid+0xbb/0x226 stack backtrace: Pid: 3323, comm: ossec-rootcheck Not tainted 3.1.0-rc8-fsdevel+ #1095 Call Trace: [<ffffffff8105cfb7>] lockdep_rcu_dereference+0xa7/0xb0 [<ffffffff8117d871>] sel_netport_sid+0x1b7/0x226 [<ffffffff8117d6ba>] ? sel_netport_avc_callback+0xbc/0xbc [<ffffffff8117556c>] selinux_socket_bind+0x115/0x230 [<ffffffff810a5388>] ? might_fault+0x4e/0x9e [<ffffffff810a53d1>] ? might_fault+0x97/0x9e [<ffffffff81171cf4>] security_socket_bind+0x11/0x13 [<ffffffff812ba967>] sys_bind+0x56/0x95 [<ffffffff81380dac>] ? sysret_check+0x27/0x62 [<ffffffff8105b767>] ? trace_hardirqs_on_caller+0x11e/0x155 [<ffffffff81076fcd>] ? audit_syscall_entry+0x17b/0x1ae [<ffffffff811b5eae>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff81380d7b>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: stable@kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2011-12-20evm: prevent racing during tfm allocationDmitry Kasatkin
There is a small chance of racing during tfm allocation. This patch fixes it. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-12-20evm: key must be set once during initializationDmitry Kasatkin
On multi-core systems, setting of the key before every caclculation, causes invalid HMAC calculation for other tfm users, because internal state (ipad, opad) can be invalid before set key call returns. It needs to be set only once during initialization. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-12-08TOMOYO: Fix pathname handling of disconnected paths.Tetsuo Handa
Current tomoyo_realpath_from_path() implementation returns strange pathname when calculating pathname of a file which belongs to lazy unmounted tree. Use local pathname rather than strange absolute pathname in that case. Also, this patch fixes a regression by commit 02125a82 "fix apparmor dereferencing potentially freed dentry, sanitize __d_path() API". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-06fix apparmor dereferencing potentially freed dentry, sanitize __d_path() APIAl Viro
__d_path() API is asking for trouble and in case of apparmor d_namespace_path() getting just that. The root cause is that when __d_path() misses the root it had been told to look for, it stores the location of the most remote ancestor in *root. Without grabbing references. Sure, at the moment of call it had been pinned down by what we have in *path. And if we raced with umount -l, we could have very well stopped at vfsmount/dentry that got freed as soon as prepend_path() dropped vfsmount_lock. It is safe to compare these pointers with pre-existing (and known to be still alive) vfsmount and dentry, as long as all we are asking is "is it the same address?". Dereferencing is not safe and apparmor ended up stepping into that. d_namespace_path() really wants to examine the place where we stopped, even if it's not connected to our namespace. As the result, it looked at ->d_sb->s_magic of a dentry that might've been already freed by that point. All other callers had been careful enough to avoid that, but it's really a bad interface - it invites that kind of trouble. The fix is fairly straightforward, even though it's bigger than I'd like: * prepend_path() root argument becomes const. * __d_path() is never called with NULL/NULL root. It was a kludge to start with. Instead, we have an explicit function - d_absolute_root(). Same as __d_path(), except that it doesn't get root passed and stops where it stops. apparmor and tomoyo are using it. * __d_path() returns NULL on path outside of root. The main caller is show_mountinfo() and that's precisely what we pass root for - to skip those outside chroot jail. Those who don't want that can (and do) use d_path(). * __d_path() root argument becomes const. Everyone agrees, I hope. * apparmor does *NOT* try to use __d_path() or any of its variants when it sees that path->mnt is an internal vfsmount. In that case it's definitely not mounted anywhere and dentry_path() is exactly what we want there. Handling of sysctl()-triggered weirdness is moved to that place. * if apparmor is asked to do pathname relative to chroot jail and __d_path() tells it we it's not in that jail, the sucker just calls d_absolute_path() instead. That's the other remaining caller of __d_path(), BTW. * seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway - the normal seq_file logics will take care of growing the buffer and redoing the call of ->show() just fine). However, if it gets path not reachable from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped ignoring the return value as it used to do). Reviewed-by: John Johansen <john.johansen@canonical.com> ACKed-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@vger.kernel.org
2011-11-18Merge branch 'encrypted-key-fixes' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into for-linus
2011-11-18Merge branch 'for-1111' of git://gitorious.org/smack-next/kernel into for-linusJames Morris
2011-11-16encrypted-keys: module build fixesMimi Zohar
Encrypted keys are encrypted/decrypted using either a trusted or user-defined key type, which is referred to as the 'master' key. The master key may be of type trusted iff the trusted key is builtin or both the trusted key and encrypted keys are built as modules. This patch resolves the build dependency problem. - Use "masterkey-$(CONFIG_TRUSTED_KEYS)-$(CONFIG_ENCRYPTED_KEYS)" construct to encapsulate the above logic. (Suggested by Dimtry Kasatkin.) - Fixing the encrypted-keys Makefile, results in a module name change from encrypted.ko to encrypted-keys.ko. - Add module dependency for request_trusted_key() definition Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2011-11-16encrypted-keys: fix error return codeMimi Zohar
Fix request_master_key() error return code. Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2011-11-15KEYS: Fix a NULL pointer deref in the user-defined key typeDavid Howells
Fix a NULL pointer deref in the user-defined key type whereby updating a negative key into a fully instantiated key will cause an oops to occur when the code attempts to free the non-existent old payload. This results in an oops that looks something like the following: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: [<ffffffff81085fa1>] __call_rcu+0x11/0x13e PGD 3391d067 PUD 3894a067 PMD 0 Oops: 0002 [#1] SMP CPU 1 Pid: 4354, comm: keyctl Not tainted 3.1.0-fsdevel+ #1140 /DG965RY RIP: 0010:[<ffffffff81085fa1>] [<ffffffff81085fa1>] __call_rcu+0x11/0x13e RSP: 0018:ffff88003d591df8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000006e RDX: ffffffff8161d0c0 RSI: 0000000000000000 RDI: 0000000000000000 RBP: ffff88003d591e18 R08: 0000000000000000 R09: ffffffff8152fa6c R10: 0000000000000000 R11: 0000000000000300 R12: ffff88003b8f9538 R13: ffffffff8161d0c0 R14: ffff88003b8f9d50 R15: ffff88003c69f908 FS: 00007f97eb18c720(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000008 CR3: 000000003d47a000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process keyctl (pid: 4354, threadinfo ffff88003d590000, task ffff88003c78a040) Stack: ffff88003e0ffde0 ffff88003b8f9538 0000000000000001 ffff88003b8f9d50 ffff88003d591e28 ffffffff810860f0 ffff88003d591e68 ffffffff8117bfea ffff88003d591e68 ffffffff00000000 ffff88003e0ffde1 ffff88003e0ffde0 Call Trace: [<ffffffff810860f0>] call_rcu_sched+0x10/0x12 [<ffffffff8117bfea>] user_update+0x8d/0xa2 [<ffffffff8117723a>] key_create_or_update+0x236/0x270 [<ffffffff811789b1>] sys_add_key+0x123/0x17e [<ffffffff813b84bb>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Acked-by: Neil Horman <nhorman@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: James Morris <jmorris@namei.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-11Smack: smackfs cipso seq read repairCasey Schaufler
Commit 272cd7a8c67dd40a31ecff76a503bbb84707f757 introduced a change to the way rule lists are handled and reported in the smackfs filesystem. One of the issues addressed had to do with the termination of read requests on /smack/load. This change introduced a error in /smack/cipso, which shares some of the same list processing code. This patch updates all the file access list handling in smackfs to use the code introduced for /smack/load. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-02Merge branch 'for-linus' of git://git.selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'for-linus' of git://git.selinuxproject.org/~jmorris/linux-security: TOMOYO: Fix interactive judgment functionality.
2011-11-02Merge branch 'for-linus' of git://github.com/richardweinberger/linuxLinus Torvalds
* 'for-linus' of git://github.com/richardweinberger/linux: (90 commits) um: fix ubd cow size um: Fix kmalloc argument order in um/vdso/vma.c um: switch to use of drivers/Kconfig UserModeLinux-HOWTO.txt: fix a typo UserModeLinux-HOWTO.txt: remove ^H characters um: we need sys/user.h only on i386 um: merge delay_{32,64}.c um: distribute exports to where exported stuff is defined um: kill system-um.h um: generic ftrace.h will do... um: segment.h is x86-only and needed only there um: asm/pda.h is not needed anymore um: hw_irq.h can go generic as well um: switch to generic-y um: clean Kconfig up a bit um: a couple of missing dependencies... um: kill useless argument of free_chan() and free_one_chan() um: unify ptrace_user.h um: unify KSTK_... um: fix gcov build breakage ...
2011-11-02um: switch to use of drivers/KconfigAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-10-31security: follow rename pack_hex_byte() to hex_byte_pack()Andy Shevchenko
There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31Cross Memory AttachChristopher Yeoh
The basic idea behind cross memory attach is to allow MPI programs doing intra-node communication to do a single copy of the message rather than a double copy of the message via shared memory. The following patch attempts to achieve this by allowing a destination process, given an address and size from a source process, to copy memory directly from the source process into its own address space via a system call. There is also a symmetrical ability to copy from the current process's address space into a destination process's address space. - Use of /proc/pid/mem has been considered, but there are issues with using it: - Does not allow for specifying iovecs for both src and dest, assuming preadv or pwritev was implemented either the area read from or written to would need to be contiguous. - Currently mem_read allows only processes who are currently ptrace'ing the target and are still able to ptrace the target to read from the target. This check could possibly be moved to the open call, but its not clear exactly what race this restriction is stopping (reason appears to have been lost) - Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix domain socket is a bit ugly from a userspace point of view, especially when you may have hundreds if not (eventually) thousands of processes that all need to do this with each other - Doesn't allow for some future use of the interface we would like to consider adding in the future (see below) - Interestingly reading from /proc/pid/mem currently actually involves two copies! (But this could be fixed pretty easily) As mentioned previously use of vmsplice instead was considered, but has problems. Since you need the reader and writer working co-operatively if the pipe is not drained then you block. Which requires some wrapping to do non blocking on the send side or polling on the receive. In all to all communication it requires ordering otherwise you can deadlock. And in the example of many MPI tasks writing to one MPI task vmsplice serialises the copying. There are some cases of MPI collectives where even a single copy interface does not get us the performance gain we could. For example in an MPI_Reduce rather than copy the data from the source we would like to instead use it directly in a mathops (say the reduce is doing a sum) as this would save us doing a copy. We don't need to keep a copy of the data from the source. I haven't implemented this, but I think this interface could in the future do all this through the use of the flags - eg could specify the math operation and type and the kernel rather than just copying the data would apply the specified operation between the source and destination and store it in the destination. Although we don't have a "second user" of the interface (though I've had some nibbles from people who may be interested in using it for intra process messaging which is not MPI). This interface is something which hardware vendors are already doing for their custom drivers to implement fast local communication. And so in addition to this being useful for OpenMPI it would mean the driver maintainers don't have to fix things up when the mm changes. There was some discussion about how much faster a true zero copy would go. Here's a link back to the email with some testing I did on that: http://marc.info/?l=linux-mm&m=130105930902915&w=2 There is a basic man page for the proposed interface here: http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt This has been implemented for x86 and powerpc, other architecture should mainly (I think) just need to add syscall numbers for the process_vm_readv and process_vm_writev. There are 32 bit compatibility versions for 64-bit kernels. For arch maintainers there are some simple tests to be able to quickly verify that the syscalls are working correctly here: http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: <linux-man@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31selinux: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
The pervasive, but implicit presence of <linux/module.h> meant that things like this file would happily compile as-is. But with the desire to phase out the module.h being included everywhere, point this file at export.h which will give it THIS_MODULE and the EXPORT_SYMBOL variants. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-29TOMOYO: Fix interactive judgment functionality.Tetsuo Handa
Commit 17fcfbd9 "TOMOYO: Add interactive enforcing mode." introduced ability to query access decision using userspace programs. It was using global PID for reaching policy configuration of the process. However, use of PID returns stale policy configuration when the process's subjective credentials and objective credentials differ. Fix this problem by allowing reaching policy configuration via query id. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-10-25Merge branch 'next' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'next' of git://selinuxproject.org/~jmorris/linux-security: (95 commits) TOMOYO: Fix incomplete read after seek. Smack: allow to access /smack/access as normal user TOMOYO: Fix unused kernel config option. Smack: fix: invalid length set for the result of /smack/access Smack: compilation fix Smack: fix for /smack/access output, use string instead of byte Smack: domain transition protections (v3) Smack: Provide information for UDS getsockopt(SO_PEERCRED) Smack: Clean up comments Smack: Repair processing of fcntl Smack: Rule list lookup performance Smack: check permissions from user space (v2) TOMOYO: Fix quota and garbage collector. TOMOYO: Remove redundant tasklist_lock. TOMOYO: Fix domain transition failure warning. TOMOYO: Remove tomoyo_policy_memory_lock spinlock. TOMOYO: Simplify garbage collector. TOMOYO: Fix make namespacecheck warnings. target: check hex2bin result encrypted-keys: check hex2bin result ...
2011-10-22Merge branch 'master' of git://gitorious.org/smack-next/kernel into nextJames Morris
2011-10-22TOMOYO: Fix incomplete read after seek.Tetsuo Handa
Commit f23571e8 "TOMOYO: Copy directly to userspace buffer." introduced tomoyo_flush() that flushes data to be read as soon as possible. tomoyo_select_domain() (which is called by write()) enqueues data which meant to be read by next read(), but previous read()'s read buffer's size was not cleared. As a result, since 2.6.36, sequence like char *cp = "select global-pid=1\n"; read(fd, buf1, sizeof(buf1)); write(fd, cp, strlen(cp)); read(fd, buf2, sizeof(buf2)); causes enqueued data to be flushed to buf1 rather than buf2. Fix this bug by clearing read buffer's size upon write() request. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-10-20Smack: allow to access /smack/access as normal userJarkko Sakkinen
Allow query access as a normal user removing the need for CAP_MAC_ADMIN. Give RW access to /smack/access for UGO. Do not import smack labels in access check. Signed-off-by: Jarkko Sakkinen <jarkko.j.sakkinen@gmail.com> Signed-off-by: Casey Schaufler <cschaufler@cschaufler-intel.(none)>
2011-10-19TOMOYO: Fix unused kernel config option.Tetsuo Handa
CONFIG_SECURITY_TOMOYO_MAX_{ACCEPT_ENTRY,AUDIT_LOG} introduced by commit 0e4ae0e0 "TOMOYO: Make several options configurable." were by error not used. Reported-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-10-18bluetooth: Properly clone LSM attributes to newly created child connectionsPaul Moore
The Bluetooth stack has internal connection handlers for all of the various Bluetooth protocols, and unfortunately, they are currently lacking the LSM hooks found in the core network stack's connection handlers. I say unfortunately, because this can cause problems for users who have have an LSM enabled and are using certain Bluetooth devices. See one problem report below: * http://bugzilla.redhat.com/show_bug.cgi?id=741703 In order to keep things simple at this point in time, this patch fixes the problem by cloning the parent socket's LSM attributes to the newly created child socket. If we decide we need a more elaborate LSM marking mechanism for Bluetooth (I somewhat doubt this) we can always revisit this decision in the future. Reported-by: James M. Cape <jcape@ignore-your.tv> Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-18Smack: fix: invalid length set for the result of /smack/accessJarkko Sakkinen
Forgot to update simple_transaction_set() to take terminator character into account. Signed-off-by: Jarkko Sakkinen <jarkko.j.sakkinen@gmail.com> Signed-off-by: Casey Schaufler <cschaufler@cschaufler-intel.(none)>
2011-10-14Smack: compilation fixJarkko Sakkinen
On some build configurations PER_CLEAR_ON_SETID symbol was not found when compiling smack_lsm.c. This patch fixes the issue by explicitly doing #include <linux/personality.h>. Signed-off-by: Jarkko Sakkinen <jarkko.j.sakkinen@gmail.com> Signed-off-by: Casey Schaufler <cschaufler@cschaufler-intel.(none)>
2011-10-12Smack: fix for /smack/access output, use string instead of byteJarkko Sakkinen
Small fix for the output of access SmackFS file. Use string is instead of byte. Makes it easier to extend API if it is needed. Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
2011-10-12Smack: domain transition protections (v3)Jarkko Sakkinen
Protections for domain transition: - BPRM unsafe flags - Secureexec - Clear unsafe personality bits. - Clear parent death signal Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
2011-10-12Smack: Provide information for UDS getsockopt(SO_PEERCRED)Casey Schaufler
This patch is targeted for the smack-next tree. This patch takes advantage of the recent changes for performance and points the packet labels on UDS connect at the output label of the far side. This makes getsockopt(...SO_PEERCRED...) function properly. Without this change the getsockopt does not provide any information. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-10-12Smack: Clean up commentsCasey Schaufler
There are a number of comments in the Smack code that are either malformed or include code. This patch cleans them up. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-10-12Smack: Repair processing of fcntlCasey Schaufler
Al Viro pointed out that the processing of fcntl done by Smack appeared poorly designed. He was right. There are three things that required change. Most obviously, the list of commands that really imply writing is limited to those involving file locking and signal handling. The initialization if the file security blob was incomplete, requiring use of a heretofore unused LSM hook. Finally, the audit information coming from a helper masked the identity of the LSM hook. This patch corrects all three of these defects. This is targeted for the smack-next tree pending comments. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-10-12Smack: Rule list lookup performanceCasey Schaufler
This patch is targeted for the smack-next tree. Smack access checks suffer from two significant performance issues. In cases where there are large numbers of rules the search of the single list of rules is wasteful. Comparing the string values of the smack labels is less efficient than a numeric comparison would. These changes take advantage of the Smack label list, which maintains the mapping of Smack labels to secids and optional CIPSO labels. Because the labels are kept perpetually, an access check can be done strictly based on the address of the label in the list without ever looking at the label itself. Rather than keeping one global list of rules the rules with a particular subject label can be based off of that label list entry. The access check need never look at entries that do not use the current subject label. This requires that packets coming off the network with CIPSO direct Smack labels that have never been seen before be treated carefully. The only case where they could be delivered is where the receiving socket has an IPIN star label, so that case is explicitly addressed. On a system with 39,800 rules (200 labels in all permutations) a system with this patch runs an access speed test in 5% of the time of the old version. That should be a best case improvement. If all of the rules are associated with the same subject label and all of the accesses are for processes with that label (unlikely) the improvement is about 30%. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-10-12Smack: check permissions from user space (v2)Jarkko Sakkinen
Adds a new file into SmackFS called 'access'. Wanted Smack permission is written into /smack/access. After that result can be read from the opened file. If access applies result contains 1 and otherwise 0. File access is protected from race conditions by using simple_transaction_get()/set() API. Fixes from the previous version: - Removed smack.h changes, refactoring left-over from previous version. - Removed #include <linux/smack.h>, refactoring left-over from previous version. Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com> Signed-off-by: Casey Schaufler <cschaufler@cschaufler-intel.(none)>
2011-10-12TOMOYO: Fix quota and garbage collector.Tetsuo Handa
Commit 059d84db "TOMOYO: Add socket operation restriction support" and commit 731d37aa "TOMOYO: Allow domain transition without execve()." forgot to update tomoyo_domain_quota_is_ok() and tomoyo_del_acl() which results in incorrect quota counting and memory leak. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-10-12TOMOYO: Remove redundant tasklist_lock.Tetsuo Handa
rcu_read_lock() is sufficient for calling find_task_by_pid_ns()/find_task_by_vpid(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-28TOMOYO: Fix domain transition failure warning.Tetsuo Handa
Commit bd03a3e4 "TOMOYO: Add policy namespace support." introduced policy namespace. But as of /sbin/modprobe is executed from initramfs/initrd, profiles for target domain's namespace is not defined because /sbin/tomoyo-init is not yet called. Reported-by: Jamie Nguyen <jamie@tomoyolinux.co.uk> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-27Merge branch 'next-hex2bin' of git://github.com/mzohar/linux-evm into nextJames Morris
2011-09-26TOMOYO: Remove tomoyo_policy_memory_lock spinlock.Tetsuo Handa
tomoyo_policy_lock mutex already protects it. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-26TOMOYO: Simplify garbage collector.Tetsuo Handa
When TOMOYO started using garbage collector at commit 847b173e "TOMOYO: Add garbage collector.", we waited for close() before kfree(). Thus, elements to be kfree()d were queued up using tomoyo_gc_list list. But it turned out that tomoyo_element_linked_by_gc() tends to choke garbage collector when certain pattern of entries are queued. Since garbage collector is no longer waiting for close() since commit 2e503bbb "TOMOYO: Fix lockdep warning.", we can remove tomoyo_gc_list list and tomoyo_element_linked_by_gc() by doing sequential processing. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-26TOMOYO: Fix make namespacecheck warnings.Tetsuo Handa
Commit efe836ab "TOMOYO: Add built-in policy support." introduced tomoyo_load_builtin_policy() but was by error called from nowhere. Commit b22b8b9f "TOMOYO: Rename meminfo to stat and show more statistics." introduced tomoyo_update_stat() but was by error not called from tomoyo_assign_domain(). Also, mark tomoyo_io_printf() and tomoyo_path_permission() static functions, as reported by "make namespacecheck". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
