path: root/security
2018-02-25security/keys: BIG_KEY requires CONFIG_CRYPTOArnd Bergmann
commit 3cd18d1981731d5f74b8e437009124ac99905d14 upstream. The recent rework introduced a possible randconfig build failure when CONFIG_CRYPTO configured to only allow modules: security/keys/big_key.o: In function `big_key_crypt': big_key.c:(.text+0x29f): undefined reference to `crypto_aead_setkey' security/keys/big_key.o: In function `big_key_init': big_key.c:(.init.text+0x1a): undefined reference to `crypto_alloc_aead' big_key.c:(.init.text+0x45): undefined reference to `crypto_aead_setauthsize' big_key.c:(.init.text+0x77): undefined reference to `crypto_destroy_tfm' crypto/gcm.o: In function `gcm_hash_crypt_remain_continue': gcm.c:(.text+0x167): undefined reference to `crypto_ahash_finup' crypto/gcm.o: In function `crypto_gcm_exit_tfm': gcm.c:(.text+0x847): undefined reference to `crypto_destroy_tfm' When we 'select CRYPTO' like the other users, we always get a configuration that builds. Fixes: 428490e38b2e ("security/keys: rewrite all of big_key crypto") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25selinux: skip bounded transition processing if the policy isn't loadedPaul Moore
commit 4b14752ec4e0d87126e636384cf37c8dd9df157c upstream. We can't do anything reasonable in security_bounded_transition() if we don't have a policy loaded, and in fact we could run into problems with some of the code inside expecting a policy. Fix these problems like we do many others in security/selinux/ss/services.c by checking to see if the policy is loaded (ss_initialized) and returning quickly if it isn't. Reported-by: syzbot <syzkaller-bugs@googlegroups.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25selinux: ensure the context is NUL terminated in security_context_to_sid_core()Paul Moore
commit ef28df55ac27e1e5cd122e19fa311d886d47a756 upstream. The syzbot/syzkaller automated tests found a problem in security_context_to_sid_core() during early boot (before we load the SELinux policy) where we could potentially feed context strings without NUL terminators into the strcmp() function. We already guard against this during normal operation (after the SELinux policy has been loaded) by making a copy of the context strings and explicitly adding a NUL terminator to the end. The patch extends this protection to the early boot case (no loaded policy) by moving the context copy earlier in security_context_to_sid_core(). Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Reviewed-By: William Roberts <william.c.roberts@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13KEYS: encrypted: fix buffer overread in valid_master_desc()Eric Biggers
commit 794b4bc292f5d31739d89c0202c54e7dc9bc3add upstream. With the 'encrypted' key type it was possible for userspace to provide a data blob ending with a master key description shorter than expected, e.g. 'keyctl add encrypted desc "new x" @s'. When validating such a master key description, validate_master_desc() could read beyond the end of the buffer. Fix this by using strncmp() instead of memcmp(). [Also clean up the code to deduplicate some logic.] Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Jin Qian <jinqian@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KPTI: Rename to PAGE_TABLE_ISOLATIONKees Cook
This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05x86/kaiser: Reenable PARAVIRTBorislav Petkov
Now that the required bits have been addressed, reenable PARAVIRT. Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: delete KAISER_REAL_SWITCH optionHugh Dickins
We fail to see what CONFIG_KAISER_REAL_SWITCH is for: it seems to be left over from early development, and now just obscures tricky parts of the code. Delete it before adding PCIDs, or nokaiser boot option. (Or if there is some good reason to keep the option, then it needs a help text - and a "depends on KAISER", so that all those without KAISER are not asked the question. But we'd much rather delete it.) Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: KAISER depends on SMPHugh Dickins
It is absurd that KAISER should depend on SMP, but apparently nobody has tried a UP build before: which breaks on implicit declaration of function 'per_cpu_offset' in arch/x86/mm/kaiser.c. Now, you would expect that to be trivially fixed up; but looking at the System.map when that block is #ifdef'ed out of kaiser_init(), I see that in a UP build __per_cpu_user_mapped_end is precisely at __per_cpu_user_mapped_start, and the items carefully gathered into that section for user-mapping on SMP, dispersed elsewhere on UP. So, some other kind of section assignment will be needed on UP, but implementing that is not a priority: just make KAISER depend on SMP for now. Also inserted a blank line before the option, tidied up the brief Kconfig help message, and added an "If unsure, Y". Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: merged updateDave Hansen
Merged fixes and cleanups, rebased to 4.9.51 tree (no 5-level paging). Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KAISER: Kernel Address IsolationRichard Fellner
This patch introduces our implementation of KAISER (Kernel Address Isolation to have Side-channels Efficiently Removed), a kernel isolation technique to close hardware side channels on kernel address information. More information about the patch can be found on: https://github.com/IAIK/KAISER From: Richard Fellner <richard.fellner@student.tugraz.at> From: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode Date: Thu, 4 May 2017 14:26:50 +0200 Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2 Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5 To: <linux-kernel@vger.kernel.org> To: <kernel-hardening@lists.openwall.com> Cc: <clementine.maurice@iaik.tugraz.at> Cc: <moritz.lipp@iaik.tugraz.at> Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Cc: Richard Fellner <richard.fellner@student.tugraz.at> Cc: Ingo Molnar <mingo@kernel.org> Cc: <kirill.shutemov@linux.intel.com> Cc: <anders.fogh@gdata-adan.de> After several recent works [1,2,3] KASLR on x86_64 was basically considered dead by many researchers. We have been working on an efficient but effective fix for this problem and found that not mapping the kernel space when running in user mode is the solution to this problem [4] (the corresponding paper [5] will be presented at ESSoS17). With this RFC patch we allow anybody to configure their kernel with the flag CONFIG_KAISER to add our defense mechanism. If there are any questions we would love to answer them. We also appreciate any comments! Cheers, Daniel (+ the KAISER team from Graz University of Technology) [1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf [2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf [3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf [4] https://github.com/IAIK/KAISER [5] https://gruss.cc/files/kaiser.pdf [patch based also on https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch] Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at> Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at> Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14KEYS: add missing permission check for request_key() destinationEric Biggers
commit 4dca6ea1d9432052afb06baf2e3ae78188a4410b upstream. When the request_key() syscall is not passed a destination keyring, it links the requested key (if constructed) into the "default" request-key keyring. This should require Write permission to the keyring. However, there is actually no permission check. This can be abused to add keys to any keyring to which only Search permission is granted. This is because Search permission allows joining the keyring. keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_SESSION_KEYRING) then will set the default request-key keyring to the session keyring. Then, request_key() can be used to add keys to the keyring. Both negatively and positively instantiated keys can be added using this method. Adding negative keys is trivial. Adding a positive key is a bit trickier. It requires that either /sbin/request-key positively instantiates the key, or that another thread adds the key to the process keyring at just the right time, such that request_key() misses it initially but then finds it in construct_alloc_key(). Fix this bug by checking for Write permission to the keyring in construct_get_dest_keyring() when the default keyring is being used. We don't do the permission check for non-default keyrings because that was already done by the earlier call to lookup_user_key(). Also, request_key_and_link() is currently passed a 'struct key *' rather than a key_ref_t, so the "possessed" bit is unavailable. We also don't do the permission check for the "requestor keyring", to continue to support the use case described by commit 8bbf4976b59f ("KEYS: Alter use of key instantiation link-to-keyring argument") where /sbin/request-key recursively calls request_key() to add keys to the original requestor's destination keyring. (I don't know of any users who actually do that, though...) Fixes: 3e30148c3d52 ("[PATCH] Keys: Make request-key create an authorisation key") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09ima: fix hash algorithm initializationBoshi Wang
[ Upstream commit ebe7c0a7be92bbd34c6ff5b55810546a0ee05bee ] The hash_setup function always sets the hash_setup_done flag, even when the hash algorithm is invalid. This prevents the default hash algorithm defined as CONFIG_IMA_DEFAULT_HASH from being used. This patch sets hash_setup_done flag only for valid hash algorithms. Fixes: e7a2ad7eb6f4 "ima: enable support for larger default filedata hash algorithms" Signed-off-by: Boshi Wang <wangboshi@huawei.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-24ima: do not update security.ima if appraisal status is not INTEGRITY_PASSRoberto Sassu
commit 020aae3ee58c1af0e7ffc4e2cc9fe4dc630338cb upstream. Commit b65a9cfc2c38 ("Untangling ima mess, part 2: deal with counters") moved the call of ima_file_check() from may_open() to do_filp_open() at a point where the file descriptor is already opened. This breaks the assumption made by IMA that file descriptors being closed belong to files whose access was granted by ima_file_check(). The consequence is that security.ima and security.evm are updated with good values, regardless of the current appraisal status. For example, if a file does not have security.ima, IMA will create it after opening the file for writing, even if access is denied. Access to the file will be allowed afterwards. Avoid this issue by checking the appraisal status before updating security.ima. Signed-off-by: Roberto Sassu <roberto.sassu@huawei.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-18security/keys: add CONFIG_KEYS_COMPAT to KconfigBilal Amarni
commit 47b2c3fff4932e6fc17ce13d51a43c6969714e20 upstream. CONFIG_KEYS_COMPAT is defined in arch-specific Kconfigs and is missing for several 64-bit architectures : mips, parisc, tile. At the moment and for those architectures, calling in 32-bit userspace the keyctl syscall would return an ENOSYS error. This patch moves the CONFIG_KEYS_COMPAT option to security/keys/Kconfig, to make sure the compatibility wrapper is registered by default for any 64-bit architecture as long as it is configured with CONFIG_COMPAT. [DH: Modified to remove arm64 compat enablement also as requested by Eric Biggers] Signed-off-by: Bilal Amarni <bilal.amarni@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> cc: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Cc: James Cowgill <james.cowgill@mips.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15KEYS: trusted: fix writing past end of buffer in trusted_read()Eric Biggers
commit a3c812f7cfd80cf51e8f5b7034f7418f6beb56c1 upstream. When calling keyctl_read() on a key of type "trusted", if the user-supplied buffer was too small, the kernel ignored the buffer length and just wrote past the end of the buffer, potentially corrupting userspace memory. Fix it by instead returning the size required, as per the documentation for keyctl_read(). We also don't even fill the buffer at all in this case, as this is slightly easier to implement than doing a short read, and either behavior appears to be permitted. It also makes it match the behavior of the "encrypted" key type. Fixes: d00a1c72f7f4 ("keys: add new trusted key-type") Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15KEYS: trusted: sanitize all key materialEric Biggers
commit ee618b4619b72527aaed765f0f0b74072b281159 upstream. As the previous patch did for encrypted-keys, zero sensitive any potentially sensitive data related to the "trusted" key type before it is freed. Notably, we were not zeroing the tpm_buf structures in which the actual key is stored for TPM seal and unseal, nor were we zeroing the trusted_key_payload in certain error paths. Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: David Safford <safford@us.ibm.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15apparmor: fix undefined reference to `aa_g_hash_policy'John Johansen
[ Upstream commit 3ccb76c5dfe0d25c1d0168d5b726d0b43d19a485 ] The kernel build bot turned up a bad config combination when CONFIG_SECURITY_APPARMOR is y and CONFIG_SECURITY_APPARMOR_HASH is n, resulting in the build error security/built-in.o: In function `aa_unpack': (.text+0x841e2): undefined reference to `aa_g_hash_policy' Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08KEYS: return full count in keyring_read() if buffer is too smallEric Biggers
commit 3239b6f29bdfb4b0a2ba59df995fc9e6f4df7f1f upstream. Commit e645016abc80 ("KEYS: fix writing past end of user-supplied buffer in keyring_read()") made keyring_read() stop corrupting userspace memory when the user-supplied buffer is too small. However it also made the return value in that case be the short buffer size rather than the size required, yet keyctl_read() is actually documented to return the size required. Therefore, switch it over to the documented behavior. Note that for now we continue to have it fill the short buffer, since it did that before (pre-v3.13) and dump_key_tree_aux() in keyutils arguably relies on it. Fixes: e645016abc80 ("KEYS: fix writing past end of user-supplied buffer in keyring_read()") Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: Fix race between updating and finding a negative keyDavid Howells
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream. Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection error into one field such that: (1) The instantiation state can be modified/read atomically. (2) The error can be accessed atomically with the state. (3) The error isn't stored unioned with the payload pointers. This deals with the problem that the state is spread over three different objects (two bits and a separate variable) and reading or updating them atomically isn't practical, given that not only can uninstantiated keys change into instantiated or rejected keys, but rejected keys can also turn into instantiated keys - and someone accessing the key might not be using any locking. The main side effect of this problem is that what was held in the payload may change, depending on the state. For instance, you might observe the key to be in the rejected state. You then read the cached error, but if the key semaphore wasn't locked, the key might've become instantiated between the two reads - and you might now have something in hand that isn't actually an error code. The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error code if the key is negatively instantiated. The key_is_instantiated() function is replaced with key_is_positive() to avoid confusion as negative keys are also 'instantiated'. Additionally, barriering is included: (1) Order payload-set before state-set during instantiation. (2) Order state-read before payload-read when using the key. Further separate barriering is necessary if RCU is being used to access the payload content after reading the payload pointers. Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data") Reported-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: don't let add_key() update an uninstantiated keyDavid Howells
commit 60ff5b2f547af3828aebafd54daded44cfb0807a upstream. Currently, when passed a key that already exists, add_key() will call the key's ->update() method if such exists. But this is heavily broken in the case where the key is uninstantiated because it doesn't call __key_instantiate_and_link(). Consequently, it doesn't do most of the things that are supposed to happen when the key is instantiated, such as setting the instantiation state, clearing KEY_FLAG_USER_CONSTRUCT and awakening tasks waiting on it, and incrementing key->user->nikeys. It also never takes key_construction_mutex, which means that ->instantiate() can run concurrently with ->update() on the same key. In the case of the "user" and "logon" key types this causes a memory leak, at best. Maybe even worse, the ->update() methods of the "encrypted" and "trusted" key types actually just dereference a NULL pointer when passed an uninstantiated key. Change key_create_or_update() to wait interruptibly for the key to finish construction before continuing. This patch only affects *uninstantiated* keys. For now we still allow a negatively instantiated key to be updated (thereby positively instantiating it), although that's broken too (the next patch fixes it) and I'm not sure that anyone actually uses that functionality either. Here is a simple reproducer for the bug using the "encrypted" key type (requires CONFIG_ENCRYPTED_KEYS=y), though as noted above the bug pertained to more than just the "encrypted" key type: #include <stdlib.h> #include <unistd.h> #include <keyutils.h> int main(void) { int ringid = keyctl_join_session_keyring(NULL); if (fork()) { for (;;) { const char payload[] = "update user:foo 32"; usleep(rand() % 10000); add_key("encrypted", "desc", payload, sizeof(payload), ringid); keyctl_clear(ringid); } } else { for (;;) request_key("encrypted", "desc", "callout_info", ringid); } } It causes: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: encrypted_update+0xb0/0x170 PGD 7a178067 P4D 7a178067 PUD 77269067 PMD 0 PREEMPT SMP CPU: 0 PID: 340 Comm: reproduce Tainted: G D 4.14.0-rc1-00025-g428490e38b2e #796 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff8a467a39a340 task.stack: ffffb15c40770000 RIP: 0010:encrypted_update+0xb0/0x170 RSP: 0018:ffffb15c40773de8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff8a467a275b00 RCX: 0000000000000000 RDX: 0000000000000005 RSI: ffff8a467a275b14 RDI: ffffffffb742f303 RBP: ffffb15c40773e20 R08: 0000000000000000 R09: ffff8a467a275b17 R10: 0000000000000020 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: ffff8a4677057180 R15: ffff8a467a275b0f FS: 00007f5d7fb08700(0000) GS:ffff8a467f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000018 CR3: 0000000077262005 CR4: 00000000001606f0 Call Trace: key_create_or_update+0x2bc/0x460 SyS_add_key+0x10c/0x1d0 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x7f5d7f211259 RSP: 002b:00007ffed03904c8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 000000003b2a7955 RCX: 00007f5d7f211259 RDX: 00000000004009e4 RSI: 00000000004009ff RDI: 0000000000400a04 RBP: 0000000068db8bad R08: 000000003b2a7955 R09: 0000000000000004 R10: 000000000000001a R11: 0000000000000246 R12: 0000000000400868 R13: 00007ffed03905d0 R14: 0000000000000000 R15: 0000000000000000 Code: 77 28 e8 64 34 1f 00 45 31 c0 31 c9 48 8d 55 c8 48 89 df 48 8d 75 d0 e8 ff f9 ff ff 85 c0 41 89 c4 0f 88 84 00 00 00 4c 8b 7d c8 <49> 8b 75 18 4c 89 ff e8 24 f8 ff ff 85 c0 41 89 c4 78 6d 49 8b RIP: encrypted_update+0xb0/0x170 RSP: ffffb15c40773de8 CR2: 0000000000000018 Reported-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Eric Biggers <ebiggers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: encrypted: fix dereference of NULL user_key_payloadEric Biggers
commit 13923d0865ca96312197962522e88bc0aedccd74 upstream. A key of type "encrypted" references a "master key" which is used to encrypt and decrypt the encrypted key's payload. However, when we accessed the master key's payload, we failed to handle the case where the master key has been revoked, which sets the payload pointer to NULL. Note that request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we acquire its semaphore. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. This was an issue for master keys of type "user" only. Master keys can also be of type "trusted", but those cannot be revoked. Fixes: 7e70cb497850 ("keys: add new key-type encrypted") Reviewed-by: James Morris <james.l.morris@oracle.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: David Safford <safford@us.ibm.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12lsm: fix smack_inode_removexattr and xattr_getsecurity memleakCasey Schaufler
commit 57e7ba04d422c3d41c8426380303ec9b7533ded9 upstream. security_inode_getsecurity() provides the text string value of a security attribute. It does not provide a "secctx". The code in xattr_getsecurity() that calls security_inode_getsecurity() and then calls security_release_secctx() happened to work because SElinux and Smack treat the attribute and the secctx the same way. It fails for cap_inode_getsecurity(), because that module has no secctx that ever needs releasing. It turns out that Smack is the one that's doing things wrong by not allocating memory when instructed to do so by the "alloc" parameter. The fix is simple enough. Change the security_release_secctx() to kfree() because it isn't a secctx being returned by security_inode_getsecurity(). Change Smack to allocate the string when told to do so. Note: this also fixes memory leaks for LSMs which implement inode_getsecurity but not release_secctx, such as capabilities. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05KEYS: prevent KEYCTL_READ on negative keyEric Biggers
commit 37863c43b2c6464f252862bf2e9768264e961678 upstream. Because keyctl_read_key() looks up the key with no permissions requested, it may find a negatively instantiated key. If the key is also possessed, we went ahead and called ->read() on the key. But the key payload will actually contain the ->reject_error rather than the normal payload. Thus, the kernel oopses trying to read the user_key_payload from memory address (int)-ENOKEY = 0x00000000ffffff82. Fortunately the payload data is stored inline, so it shouldn't be possible to abuse this as an arbitrary memory read primitive... Reproducer: keyctl new_session keyctl request2 user desc '' @s keyctl read $(keyctl show | awk '/user: desc/ {print $1}') It causes a crash like the following: BUG: unable to handle kernel paging request at 00000000ffffff92 IP: user_read+0x33/0xa0 PGD 36a54067 P4D 36a54067 PUD 0 Oops: 0000 [#1] SMP CPU: 0 PID: 211 Comm: keyctl Not tainted 4.14.0-rc1 #337 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014 task: ffff90aa3b74c3c0 task.stack: ffff9878c0478000 RIP: 0010:user_read+0x33/0xa0 RSP: 0018:ffff9878c047bee8 EFLAGS: 00010246 RAX: 0000000000000001 RBX: ffff90aa3d7da340 RCX: 0000000000000017 RDX: 0000000000000000 RSI: 00000000ffffff82 RDI: ffff90aa3d7da340 RBP: ffff9878c047bf00 R08: 00000024f95da94f R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 00007f58ece69740(0000) GS:ffff90aa3e200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000ffffff92 CR3: 0000000036adc001 CR4: 00000000003606f0 Call Trace: keyctl_read_key+0xac/0xe0 SyS_keyctl+0x99/0x120 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x7f58ec787bb9 RSP: 002b:00007ffc8d401678 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa RAX: ffffffffffffffda RBX: 00007ffc8d402800 RCX: 00007f58ec787bb9 RDX: 0000000000000000 RSI: 00000000174a63ac RDI: 000000000000000b RBP: 0000000000000004 R08: 00007ffc8d402809 R09: 0000000000000020 R10: 0000000000000000 R11: 0000000000000206 R12: 00007ffc8d402800 R13: 00007ffc8d4016e0 R14: 0000000000000000 R15: 0000000000000000 Code: e5 41 55 49 89 f5 41 54 49 89 d4 53 48 89 fb e8 a4 b4 ad ff 85 c0 74 09 80 3d b9 4c 96 00 00 74 43 48 8b b3 20 01 00 00 4d 85 ed <0f> b7 5e 10 74 29 4d 85 e4 74 24 4c 39 e3 4c 89 e2 4c 89 ef 48 RIP: user_read+0x33/0xa0 RSP: ffff9878c047bee8 CR2: 00000000ffffff92 Fixes: 61ea0c0ba904 ("KEYS: Skip key state checks when checking for possession") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05KEYS: prevent creating a different user's keyringsEric Biggers
commit 237bbd29f7a049d310d907f4b2716a7feef9abf3 upstream. It was possible for an unprivileged user to create the user and user session keyrings for another user. For example: sudo -u '#3000' sh -c 'keyctl add keyring _uid.4000 "" @u keyctl add keyring _uid_ses.4000 "" @u sleep 15' & sleep 1 sudo -u '#4000' keyctl describe @u sudo -u '#4000' keyctl describe @us This is problematic because these "fake" keyrings won't have the right permissions. In particular, the user who created them first will own them and will have full access to them via the possessor permissions, which can be used to compromise the security of a user's keys: -4: alswrv-----v------------ 3000 0 keyring: _uid.4000 -5: alswrv-----v------------ 3000 0 keyring: _uid_ses.4000 Fix it by marking user and user session keyrings with a flag KEY_FLAG_UID_KEYRING. Then, when searching for a user or user session keyring by name, skip all keyrings that don't have the flag set. Fixes: 69664cf16af4 ("keys: don't generate user and user session keyrings unless they're accessed") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05KEYS: fix writing past end of user-supplied buffer in keyring_read()Eric Biggers
commit e645016abc803dafc75e4b8f6e4118f088900ffb upstream. Userspace can call keyctl_read() on a keyring to get the list of IDs of keys in the keyring. But if the user-supplied buffer is too small, the kernel would write the full list anyway --- which will corrupt whatever userspace memory happened to be past the end of the buffer. Fix it by only filling the space that is available. Fixes: b2a4df200d57 ("KEYS: Expand the capacity of a keyring") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05security/keys: rewrite all of big_key cryptoJason A. Donenfeld
commit 428490e38b2e352812e0b765d8bceafab0ec441d upstream. This started out as just replacing the use of crypto/rng with get_random_bytes_wait, so that we wouldn't use bad randomness at boot time. But, upon looking further, it appears that there were even deeper underlying cryptographic problems, and that this seems to have been committed with very little crypto review. So, I rewrote the whole thing, trying to keep to the conventions introduced by the previous author, to fix these cryptographic flaws. It makes no sense to seed crypto/rng at boot time and then keep using it like this, when in fact there's already get_random_bytes_wait, which can ensure there's enough entropy and be a much more standard way of generating keys. Since this sensitive material is being stored untrusted, using ECB and no authentication is simply not okay at all. I find it surprising and a bit horrifying that this code even made it past basic crypto review, which perhaps points to some larger issues. This patch moves from using AES-ECB to using AES-GCM. Since keys are uniquely generated each time, we can set the nonce to zero. There was also a race condition in which the same key would be reused at the same time in different threads. A mutex fixes this issue now. So, to summarize, this commit fixes the following vulnerabilities: * Low entropy key generation, allowing an attacker to potentially guess or predict keys. * Unauthenticated encryption, allowing an attacker to modify the cipher text in particular ways in order to manipulate the plaintext, which is is even more frightening considering the next point. * Use of ECB mode, allowing an attacker to trivially swap blocks or compare identical plaintext blocks. * Key re-use. * Faulty memory zeroing. [Note that in backporting this commit to 4.9, get_random_bytes_wait was replaced with get_random_bytes, since 4.9 does not have the former function. This might result in slightly worse entropy in key generation, but common use cases of big_keys makes that likely not a huge deal. And, this is the best we can do with this old kernel. Alas.] Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Reviewed-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Kirill Marinushkin <k.marinushkin@gmail.com> Cc: security@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05security/keys: properly zero out sensitive key material in big_keyJason A. Donenfeld
commit 910801809b2e40a4baedd080ef5d80b4a180e70e upstream. Error paths forgot to zero out sensitive material, so this patch changes some kfrees into a kzfrees. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Eric Biggers <ebiggers3@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Kirill Marinushkin <k.marinushkin@gmail.com> Cc: security@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-12KEYS: Fix an error code in request_master_key()Dan Carpenter
commit 57cb17e764ba0aaa169d07796acce54ccfbc6cae upstream. This function has two callers and neither are able to handle a NULL return. Really, -EINVAL is the correct thing return here anyway. This fixes some static checker warnings like: security/keys/encrypted-keys/encrypted.c:709 encrypted_key_decrypt() error: uninitialized symbol 'master_key'. Fixes: 7e70cb497850 ("keys: add new key-type encrypted") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14KEYS: encrypted: avoid encrypting/decrypting stack buffersEric Biggers
commit e9ff56ac352446f55141aaef1553cee662b2e310 upstream. Since v4.9, the crypto API cannot (normally) be used to encrypt/decrypt stack buffers because the stack may be virtually mapped. Fix this for the padding buffers in encrypted-keys by using ZERO_PAGE for the encryption padding and by allocating a temporary heap buffer for the decryption padding. Tested with CONFIG_DEBUG_SG=y: keyctl new_session keyctl add user master "abcdefghijklmnop" @s keyid=$(keyctl add encrypted desc "new user:master 25" @s) datablob="$(keyctl pipe $keyid)" keyctl unlink $keyid keyid=$(keyctl add encrypted desc "load $datablob" @s) datablob2="$(keyctl pipe $keyid)" [ "$datablob" = "$datablob2" ] && echo "Success!" Cc: Andy Lutomirski <luto@kernel.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14KEYS: fix freeing uninitialized memory in key_update()Eric Biggers
commit 63a0b0509e700717a59f049ec6e4e04e903c7fe2 upstream. key_update() freed the key_preparsed_payload even if it was not initialized first. This would cause a crash if userspace called keyctl_update() on a key with type like "asymmetric" that has a ->preparse() method but not an ->update() method. Possibly it could even be triggered for other key types by racing with keyctl_setperm() to make the KEY_NEED_WRITE check fail (the permission was already checked, so normally it wouldn't fail there). Reproducer with key type "asymmetric", given a valid cert.der: keyctl new_session keyid=$(keyctl padd asymmetric desc @s < cert.der) keyctl setperm $keyid 0x3f000000 keyctl update $keyid data [ 150.686666] BUG: unable to handle kernel NULL pointer dereference at 0000000000000001 [ 150.687601] IP: asymmetric_key_free_kids+0x12/0x30 [ 150.688139] PGD 38a3d067 [ 150.688141] PUD 3b3de067 [ 150.688447] PMD 0 [ 150.688745] [ 150.689160] Oops: 0000 [#1] SMP [ 150.689455] Modules linked in: [ 150.689769] CPU: 1 PID: 2478 Comm: keyctl Not tainted 4.11.0-rc4-xfstests-00187-ga9f6b6b8cd2f #742 [ 150.690916] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014 [ 150.692199] task: ffff88003b30c480 task.stack: ffffc90000350000 [ 150.692952] RIP: 0010:asymmetric_key_free_kids+0x12/0x30 [ 150.693556] RSP: 0018:ffffc90000353e58 EFLAGS: 00010202 [ 150.694142] RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000004 [ 150.694845] RDX: ffffffff81ee3920 RSI: ffff88003d4b0700 RDI: 0000000000000001 [ 150.697569] RBP: ffffc90000353e60 R08: ffff88003d5d2140 R09: 0000000000000000 [ 150.702483] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000001 [ 150.707393] R13: 0000000000000004 R14: ffff880038a4d2d8 R15: 000000000040411f [ 150.709720] FS: 00007fcbcee35700(0000) GS:ffff88003fd00000(0000) knlGS:0000000000000000 [ 150.711504] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 150.712733] CR2: 0000000000000001 CR3: 0000000039eab000 CR4: 00000000003406e0 [ 150.714487] Call Trace: [ 150.714975] asymmetric_key_free_preparse+0x2f/0x40 [ 150.715907] key_update+0xf7/0x140 [ 150.716560] ? key_default_cmp+0x20/0x20 [ 150.717319] keyctl_update_key+0xb0/0xe0 [ 150.718066] SyS_keyctl+0x109/0x130 [ 150.718663] entry_SYSCALL_64_fastpath+0x1f/0xc2 [ 150.719440] RIP: 0033:0x7fcbce75ff19 [ 150.719926] RSP: 002b:00007ffd5d167088 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa [ 150.720918] RAX: ffffffffffffffda RBX: 0000000000404d80 RCX: 00007fcbce75ff19 [ 150.721874] RDX: 00007ffd5d16785e RSI: 000000002866cd36 RDI: 0000000000000002 [ 150.722827] RBP: 0000000000000006 R08: 000000002866cd36 R09: 00007ffd5d16785e [ 150.723781] R10: 0000000000000004 R11: 0000000000000206 R12: 0000000000404d80 [ 150.724650] R13: 00007ffd5d16784d R14: 00007ffd5d167238 R15: 000000000040411f [ 150.725447] Code: 83 c4 08 31 c0 5b 41 5c 41 5d 41 5e 41 5f 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 85 ff 74 23 55 48 89 e5 53 48 89 fb <48> 8b 3f e8 06 21 c5 ff 48 8b 7b 08 e8 fd 20 c5 ff 48 89 df e8 [ 150.727489] RIP: asymmetric_key_free_kids+0x12/0x30 RSP: ffffc90000353e58 [ 150.728117] CR2: 0000000000000001 [ 150.728430] ---[ end trace f7f8fe1da2d5ae8d ]--- Fixes: 4d8c0250b841 ("KEYS: Call ->free_preparse() even after ->preparse() returns an error") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14KEYS: fix dereferencing NULL payload with nonzero lengthEric Biggers
commit 5649645d725c73df4302428ee4e02c869248b4c5 upstream. sys_add_key() and the KEYCTL_UPDATE operation of sys_keyctl() allowed a NULL payload with nonzero length to be passed to the key type's ->preparse(), ->instantiate(), and/or ->update() methods. Various key types including asymmetric, cifs.idmap, cifs.spnego, and pkcs7_test did not handle this case, allowing an unprivileged user to trivially cause a NULL pointer dereference (kernel oops) if one of these key types was present. Fix it by doing the copy_from_user() when 'plen' is nonzero rather than when '_payload' is non-NULL, causing the syscall to fail with EFAULT as expected when an invalid buffer is specified. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25ima: accept previously set IMA_NEW_FILEDaniel Glöckner
commit 1ac202e978e18f045006d75bd549612620c6ec3a upstream. Modifying the attributes of a file makes ima_inode_post_setattr reset the IMA cache flags. So if the file, which has just been created, is opened a second time before the first file descriptor is closed, verification fails since the security.ima xattr has not been written yet. We therefore have to look at the IMA_NEW_FILE even if the file already existed. With this patch there should no longer be an error when cat tries to open testfile: $ rm -f testfile $ ( echo test >&3 ; touch testfile ; cat testfile ) 3>testfile A file being new is no reason to accept that it is missing a digital signature demanded by the policy. Signed-off-by: Daniel Glöckner <dg@emlix.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27KEYS: fix keyctl_set_reqkey_keyring() to not leak thread keyringsEric Biggers
commit c9f838d104fed6f2f61d68164712e3204bf5271b upstream. This fixes CVE-2017-7472. Running the following program as an unprivileged user exhausts kernel memory by leaking thread keyrings: #include <keyutils.h> int main() { for (;;) keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_THREAD_KEYRING); } Fix it by only creating a new thread keyring if there wasn't one before. To make things more consistent, make install_thread_keyring_to_cred() and install_process_keyring_to_cred() both return 0 if the corresponding keyring is already present. Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27KEYS: Change the name of the dead type to ".dead" to prevent user accessDavid Howells
commit c1644fe041ebaf6519f6809146a77c3ead9193af upstream. This fixes CVE-2017-6951. Userspace should not be able to do things with the "dead" key type as it doesn't have some of the helper functions set upon it that the kernel needs. Attempting to use it may cause the kernel to crash. Fix this by changing the name of the type to ".dead" so that it's rejected up front on userspace syscalls by key_get_type_from_user(). Though this doesn't seem to affect recent kernels, it does affect older ones, certainly those prior to: commit c06cfb08b88dfbe13be44a69ae2fdc3a7c902d81 Author: David Howells <dhowells@redhat.com> Date: Tue Sep 16 17:36:06 2014 +0100 KEYS: Remove key_type::match in favour of overriding default by match_preparse which went in before 3.18-rc1. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27KEYS: Disallow keyrings beginning with '.' to be joined as session keyringsDavid Howells
commit ee8f844e3c5a73b999edf733df1c529d6503ec2f upstream. This fixes CVE-2016-9604. Keyrings whose name begin with a '.' are special internal keyrings and so userspace isn't allowed to create keyrings by this name to prevent shadowing. However, the patch that added the guard didn't fix KEYCTL_JOIN_SESSION_KEYRING. Not only can that create dot-named keyrings, it can also subscribe to them as a session keyring if they grant SEARCH permission to the user. This, for example, allows a root process to set .builtin_trusted_keys as its session keyring, at which point it has full access because now the possessor permissions are added. This permits root to add extra public keys, thereby bypassing module verification. This also affects kexec and IMA. This can be tested by (as root): keyctl session .builtin_trusted_keys keyctl add user a a @s keyctl list @s which on my test box gives me: 2 keys in keyring: 180010936: ---lswrv 0 0 asymmetric: Build time autogenerated kernel key: ae3d4a31b82daa8e1a75b49dc2bba949fd992a05 801382539: --alswrv 0 0 user: a Fix this by rejecting names beginning with a '.' in the keyctl. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> cc: linux-ima-devel@lists.sourceforge.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12ima: fix ima_d_path() possible race with renameMimi Zohar
commit bc15ed663e7e53ee4dc3e60f8d09c93a0528c694 upstream. On failure to return a pathname from ima_d_path(), a pointer to dname is returned, which is subsequently used in the IMA measurement list, the IMA audit records, and other audit logging. Saving the pointer to dname for later use has the potential to race with rename. Intead of returning a pointer to dname on failure, this patch returns a pointer to a copy of the filename. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14selinux: fix off-by-one in setprocattrStephen Smalley
commit 0c461cb727d146c9ef2d3e86214f498b78b7d125 upstream. SELinux tries to support setting/clearing of /proc/pid/attr attributes from the shell by ignoring terminating newlines and treating an attribute value that begins with a NUL or newline as an attempt to clear the attribute. However, the test for clearing attributes has always been wrong; it has an off-by-one error, and this could further lead to reading past the end of the allocated buffer since commit bb646cdb12e75d82258c2f2e7746d5952d3e321a ("proc_pid_attr_write(): switch to memdup_user()"). Fix the off-by-one error. Even with this fix, setting and clearing /proc/pid/attr attributes from the shell is not straightforward since the interface does not support multiple write() calls (so shells that write the value and newline separately will set and then immediately clear the attribute, requiring use of echo -n to set the attribute), whereas trying to use echo -n "" to clear the attribute causes the shell to skip the write() call altogether since POSIX says that a zero-length write causes no side effects. Thus, one must use echo -n to set and echo without -n to clear, as in the following example: $ echo -n unconfined_u:object_r:user_home_t:s0 > /proc/$$/attr/fscreate $ cat /proc/$$/attr/fscreate unconfined_u:object_r:user_home_t:s0 $ echo "" > /proc/$$/attr/fscreate $ cat /proc/$$/attr/fscreate Note the use of /proc/$$ rather than /proc/self, as otherwise the cat command will read its own attribute value, not that of the shell. There are no users of this facility to my knowledge; possibly we should just get rid of it. UPDATE: Upon further investigation it appears that a local process with the process:setfscreate permission can cause a kernel panic as a result of this bug. This patch fixes CVE-2017-2618. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> [PM: added the update about CVE-2017-2618 to the commit description] Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2017-01-12ima: fix memory leak in ima_release_policyEric Richter
commit 9a11a18902bc3b904353063763d06480620245a6 upstream. When the "policy" securityfs file is opened for read, it is opened as a sequential file. However, when it is eventually released, there is no cleanup for the sequential file, therefore some memory is leaked. This patch adds a call to seq_release() in ima_release_policy() to clean up the memory when the file is opened for read. Fixes: 80eae209d63a IMA: allow reading back the current policy Reported-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Eric Richter <erichte@linux.vnet.ibm.com> Tested-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-21apparmor: fix change_hat not finding hat after policy replacementJohn Johansen
After a policy replacement, the task cred may be out of date and need to be updated. However change_hat is using the stale profiles from the out of date cred resulting in either: a stale profile being applied or, incorrect failure when searching for a hat profile as it has been migrated to the new parent profile. Fixes: 01e2b670aa898a39259bc85c78e3d74820f4d3b6 (failure to find hat) Fixes: 898127c34ec03291c86f4ff3856d79e9e18952bc (stale policy being applied) Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1000287 Cc: stable@vger.kernel.org Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-10-27security/keys: make BIG_KEYS dependent on stdrng.Artem Savkov
Since BIG_KEYS can't be compiled as module it requires one of the "stdrng" providers to be compiled into kernel. Otherwise big_key_crypto_init() fails on crypto_alloc_rng step and next dereference of big_key_skcipher (e.g. in big_key_preparse()) results in a NULL pointer dereference. Fixes: 13100a72f40f5748a04017e0ab3df4cf27c809ef ('Security: Keys: Big keys stored encrypted') Signed-off-by: Artem Savkov <asavkov@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Stephan Mueller <smueller@chronox.de> cc: Kirill Marinushkin <k.marinushkin@gmail.com> cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-10-27KEYS: Sort out big_key initialisationDavid Howells
big_key has two separate initialisation functions, one that registers the key type and one that registers the crypto. If the key type fails to register, there's no problem if the crypto registers successfully because there's no way to reach the crypto except through the key type. However, if the key type registers successfully but the crypto does not, big_key_rng and big_key_blkcipher may end up set to NULL - but the code neither checks for this nor unregisters the big key key type. Furthermore, since the key type is registered before the crypto, it is theoretically possible for the kernel to try adding a big_key before the crypto is set up, leading to the same effect. Fix this by merging big_key_crypto_init() and big_key_init() and calling the resulting function late. If they're going to be encrypted, we shouldn't be creating big_keys before we have the facilities to do the encryption available. The key type registration is also moved after the crypto initialisation. The fix also includes message printing on failure. If the big_key type isn't correctly set up, simply doing: dd if=/dev/zero bs=4096 count=1 | keyctl padd big_key a @s ought to cause an oops. Fixes: 13100a72f40f5748a04017e0ab3df4cf27c809ef ('Security: Keys: Big keys stored encrypted') Signed-off-by: David Howells <dhowells@redhat.com> cc: Peter Hlavaty <zer0mem@yahoo.com> cc: Kirill Marinushkin <k.marinushkin@gmail.com> cc: Artem Savkov <asavkov@redhat.com> cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-10-27KEYS: Fix short sprintf buffer in /proc/keys show functionDavid Howells
This fixes CVE-2016-7042. Fix a short sprintf buffer in proc_keys_show(). If the gcc stack protector is turned on, this can cause a panic due to stack corruption. The problem is that xbuf[] is not big enough to hold a 64-bit timeout rendered as weeks: (gdb) p 0xffffffffffffffffULL/(60*60*24*7) $2 = 30500568904943 That's 14 chars plus NUL, not 11 chars plus NUL. Expand the buffer to 16 chars. I think the unpatched code apparently works if the stack-protector is not enabled because on a 32-bit machine the buffer won't be overflowed and on a 64-bit machine there's a 64-bit aligned pointer at one side and an int that isn't checked again on the other side. The panic incurred looks something like: Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff81352ebe CPU: 0 PID: 1692 Comm: reproducer Not tainted 4.7.2-201.fc24.x86_64 #1 Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011 0000000000000086 00000000fbbd2679 ffff8800a044bc00 ffffffff813d941f ffffffff81a28d58 ffff8800a044bc98 ffff8800a044bc88 ffffffff811b2cb6 ffff880000000010 ffff8800a044bc98 ffff8800a044bc30 00000000fbbd2679 Call Trace: [<ffffffff813d941f>] dump_stack+0x63/0x84 [<ffffffff811b2cb6>] panic+0xde/0x22a [<ffffffff81352ebe>] ? proc_keys_show+0x3ce/0x3d0 [<ffffffff8109f7f9>] __stack_chk_fail+0x19/0x30 [<ffffffff81352ebe>] proc_keys_show+0x3ce/0x3d0 [<ffffffff81350410>] ? key_validate+0x50/0x50 [<ffffffff8134db30>] ? key_default_cmp+0x20/0x20 [<ffffffff8126b31c>] seq_read+0x2cc/0x390 [<ffffffff812b6b12>] proc_reg_read+0x42/0x70 [<ffffffff81244fc7>] __vfs_read+0x37/0x150 [<ffffffff81357020>] ? security_file_permission+0xa0/0xc0 [<ffffffff81246156>] vfs_read+0x96/0x130 [<ffffffff81247635>] SyS_read+0x55/0xc0 [<ffffffff817eb872>] entry_SYSCALL_64_fastpath+0x1a/0xa4 Reported-by: Ondrej Kozina <okozina@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ondrej Kozina <okozina@redhat.com> cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-10-22Merge branch 'mm-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull vmap stack fixes from Ingo Molnar: "This is fallout from CONFIG_HAVE_ARCH_VMAP_STACK=y on x86: stack accesses that used to be just somewhat questionable are now totally buggy. These changes try to do it without breaking the ABI: the fields are left there, they are just reporting zero, or reporting narrower information (the maps file change)" * 'mm-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: mm: Change vm_is_stack_for_task() to vm_is_stack_for_current() fs/proc: Stop trying to report thread stacks fs/proc: Stop reporting eip and esp in /proc/PID/stat mm/numa: Remove duplicated include from mprotect.c
2016-10-20mm: Change vm_is_stack_for_task() to vm_is_stack_for_current()Andy Lutomirski
Asking for a non-current task's stack can't be done without races unless the task is frozen in kernel mode. As far as I know, vm_is_stack_for_task() never had a safe non-current use case. The __unused annotation is because some KSTK_ESP implementations ignore their parameter, which IMO is further justification for this patch. Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Jann Horn <jann@thejh.net> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Linux API <linux-api@vger.kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tycho Andersen <tycho.andersen@canonical.com> Link: http://lkml.kernel.org/r/4c3f68f426e6c061ca98b4fc7ef85ffbb0a25b0c.1475257877.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-19mm: replace get_user_pages_remote() write/force parameters with gup_flagsLorenzo Stoakes
This removes the 'write' and 'force' from get_user_pages_remote() and replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers as use of this flag can result in surprising behaviour (and hence bugs) within the mm subsystem. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-10-10Merge branch 'work.xattr' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs xattr updates from Al Viro: "xattr stuff from Andreas This completes the switch to xattr_handler ->get()/->set() from ->getxattr/->setxattr/->removexattr" * 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: Remove {get,set,remove}xattr inode operations xattr: Stop calling {get,set,remove}xattr inode operations vfs: Check for the IOP_XATTR flag in listxattr xattr: Add __vfs_{get,set,remove}xattr helpers libfs: Use IOP_XATTR flag for empty directory handling vfs: Use IOP_XATTR flag for bad-inode handling vfs: Add IOP_XATTR inode operations flag vfs: Move xattr_resolve_name to the front of fs/xattr.c ecryptfs: Switch to generic xattr handlers sockfs: Get rid of getxattr iop sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names kernfs: Switch to generic xattr handlers hfs: Switch to generic xattr handlers jffs2: Remove jffs2_{get,set,remove}xattr macros xattr: Remove unnecessary NULL attribute name check
2016-10-10Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "Assorted misc bits and pieces. There are several single-topic branches left after this (rename2 series from Miklos, current_time series from Deepa Dinamani, xattr series from Andreas, uaccess stuff from from me) and I'd prefer to send those separately" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (39 commits) proc: switch auxv to use of __mem_open() hpfs: support FIEMAP cifs: get rid of unused arguments of CIFSSMBWrite() posix_acl: uapi header split posix_acl: xattr representation cleanups fs/aio.c: eliminate redundant loads in put_aio_ring_file fs/internal.h: add const to ns_dentry_operations declaration compat: remove compat_printk() fs/buffer.c: make __getblk_slow() static proc: unsigned file descriptors fs/file: more unsigned file descriptors fs: compat: remove redundant check of nr_segs cachefiles: Fix attempt to read i_blocks after deleting file [ver #2] cifs: don't use memcpy() to copy struct iov_iter get rid of separate multipage fault-in primitives fs: Avoid premature clearing of capabilities fs: Give dentry to inode_change_ok() instead of inode fuse: Propagate dentry down to inode_change_ok() ceph: Propagate dentry down to inode_change_ok() xfs: Propagate dentry down to inode_change_ok() ...
2016-10-10Merge branch 'printk-cleanups'Linus Torvalds
Merge my system logging cleanups, triggered by the broken '\n' patches. The line continuation handling has been broken basically forever, and the code to handle the system log records was both confusing and dubious. And it would do entirely the wrong thing unless you always had a terminating newline, partly because it couldn't actually see whether a message was marked KERN_CONT or not (but partly because the LOG_CONT handling in the recording code was rather confusing too). This re-introduces a real semantically meaningful KERN_CONT, and fixes the few places I noticed where it was missing. There are probably more missing cases, since KERN_CONT hasn't actually had any semantic meaning for at least four years (other than the checkpatch meaning of "no log level necessary, this is a continuation line"). This also allows the combination of KERN_CONT and a log level. In that case the log level will be ignored if the merging with a previous line is successful, but if a new record is needed, that new record will now get the right log level. That also means that you can at least in theory combine KERN_CONT with the "pr_info()" style helpers, although any use of pr_fmt() prefixing would make that just result in a mess, of course (the prefix would end up in the middle of a continuing line). * printk-cleanups: printk: make reading the kernel log flush pending lines printk: re-organize log_output() to be more legible printk: split out core logging code into helper function printk: reinstate KERN_CONT for printing continuation lines
