path: root/security
2009-08-06Security/SELinux: seperate lsm specific mmap_min_addrEric Paris
Currently SELinux enforcement of controls on the ability to map low memory is determined by the mmap_min_addr tunable. This patch causes SELinux to ignore the tunable and instead use a seperate Kconfig option specific to how much space the LSM should protect. The tunable will now only control the need for CAP_SYS_RAWIO and SELinux permissions will always protect the amount of low memory designated by CONFIG_LSM_MMAP_MIN_ADDR. This allows users who need to disable the mmap_min_addr controls (usual reason being they run WINE as a non-root user) to do so and still have SELinux controls preventing confined domains (like a web server) from being able to map some area of low memory. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-06SELinux: call cap_file_mmap in selinux_file_mmapEric Paris
Currently SELinux does not check CAP_SYS_RAWIO in the file_mmap hook. This means there is no DAC check on the ability to mmap low addresses in the memory space. This function adds the DAC check for CAP_SYS_RAWIO while maintaining the selinux check on mmap_zero. This means that processes which need to mmap low memory will need CAP_SYS_RAWIO and mmap_zero but will NOT need the SELinux sys_rawio capability. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-06Capabilities: move cap_file_mmap to commoncap.cEric Paris
Currently we duplicate the mmap_min_addr test in cap_file_mmap and in security_file_mmap if !CONFIG_SECURITY. This patch moves cap_file_mmap into commoncap.c and then calls that function directly from security_file_mmap ifndef CONFIG_SECURITY like all of the other capability checks are done. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-06security/smack: Use AF_INET for sin_family fieldJulia Lawall
Elsewhere the sin_family field holds a value with a name of the form AF_..., so it seems reasonable to do so here as well. Also the values of PF_INET and AF_INET are the same. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ struct sockaddr_in sip; @@ ( sip.sin_family == - PF_INET + AF_INET | sip.sin_family != - PF_INET + AF_INET | sip.sin_family = - PF_INET + AF_INET ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-07-21x86, intel_txt: Intel TXT boot supportJoseph Cihula
This patch adds kernel configuration and boot support for Intel Trusted Execution Technology (Intel TXT). Intel's technology for safer computing, Intel Trusted Execution Technology (Intel TXT), defines platform-level enhancements that provide the building blocks for creating trusted platforms. Intel TXT was formerly known by the code name LaGrande Technology (LT). Intel TXT in Brief: o Provides dynamic root of trust for measurement (DRTM) o Data protection in case of improper shutdown o Measurement and verification of launched environment Intel TXT is part of the vPro(TM) brand and is also available some non-vPro systems. It is currently available on desktop systems based on the Q35, X38, Q45, and Q43 Express chipsets (e.g. Dell Optiplex 755, HP dc7800, etc.) and mobile systems based on the GM45, PM45, and GS45 Express chipsets. For more information, see http://www.intel.com/technology/security/. This site also has a link to the Intel TXT MLE Developers Manual, which has been updated for the new released platforms. A much more complete description of how these patches support TXT, how to configure a system for it, etc. is in the Documentation/intel_txt.txt file in this patch. This patch provides the TXT support routines for complete functionality, documentation for TXT support and for the changes to the boot_params structure, and boot detection of a TXT launch. Attempts to shutdown (reboot, Sx) the system will result in platform resets; subsequent patches will support these shutdown modes properly. Documentation/intel_txt.txt | 210 +++++++++++++++++++++ Documentation/x86/zero-page.txt | 1 arch/x86/include/asm/bootparam.h | 3 arch/x86/include/asm/fixmap.h | 3 arch/x86/include/asm/tboot.h | 197 ++++++++++++++++++++ arch/x86/kernel/Makefile | 1 arch/x86/kernel/setup.c | 4 arch/x86/kernel/tboot.c | 379 +++++++++++++++++++++++++++++++++++++++ security/Kconfig | 30 +++ 9 files changed, 827 insertions(+), 1 deletion(-) Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Gang Wei <gang.wei@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-17kernel: rename is_single_threaded(task) to current_is_single_threaded(void)Oleg Nesterov
- is_single_threaded(task) is not safe unless task == current, we can't use task->signal or task->mm. - it doesn't make sense unless task == current, the task can fork right after the check. Rename it to current_is_single_threaded() and kill the argument. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-07-13Revert "SELinux: Convert avc_audit to use lsm_audit.h"James Morris
This reverts commit 8113a8d80f4c6a3dc3724b39b470f3fee9c426b6. The patch causes a stack overflow on my system during boot. Signed-off-by: James Morris <jmorris@namei.org>
2009-07-13SELinux: Convert avc_audit to use lsm_audit.hThomas Liu
Convert avc_audit in security/selinux/avc.c to use lsm_audit.h, for better maintainability and for less code duplication. - changed selinux to use common_audit_data instead of avc_audit_data - eliminated code in avc.c and used code from lsm_audit.h instead. I have tested to make sure that the avcs look the same before and after this patch. Signed-off-by: Thomas Liu <tliu@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-07-10security: Make lsm_priv union in lsm_audit.h anonymousThomas Liu
Made the lsm_priv union in include/linux/lsm_audit.h anonymous. Signed-off-by: Thomas Liu <tliu@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-07-10Move variable function in lsm_audit.h into SMACK private spaceThomas Liu
Moved variable function in include/linux/lsm_audit.h into the smack_audit_data struct since it is never used outside of it. Also removed setting of function in the COMMON_AUDIT_DATA_INIT macro because that variable is now private to SMACK. Signed-off-by: Thomas Liu <tliu@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> I-dont-see-any-problems-with-it: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-30Merge branch 'master' into nextJames Morris
2009-06-29integrity: add ima_counts_put (updated)Mimi Zohar
This patch fixes an imbalance message as reported by J.R. Okajima. The IMA file counters are incremented in ima_path_check. If the actual open fails, such as ETXTBSY, decrement the counters to prevent unnecessary imbalance messages. Reported-by: J.R. Okajima <hooanon05@yahoo.co.jp> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-29integrity: ima audit hash_exists fixMimi Zohar
Audit the file name, not the template name. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-25selinux: clean up avc node cache when disabling selinuxThomas Liu
Added a call to free the avc_node_cache when inside selinux_disable because it should not waste resources allocated during avc_init if SELinux is disabled and the cache will never be used. Signed-off-by: Thomas Liu <tliu@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-25security: rename ptrace_may_access => ptrace_access_checkIngo Molnar
The ->ptrace_may_access() methods are named confusingly - the real ptrace_may_access() returns a bool, while these security checks have a retval convention. Rename it to ptrace_access_check, to reduce the confusion factor. [ Impact: cleanup, no code changed ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-25keys: annotate seqfile ops with __releases and __acquiresJames Morris
Annotate seqfile ops with __releases and __acquires to stop sparse complaining about unbalanced locking. Signed-off-by: James Morris <jmorris@namei.org> Reviewed-by: Serge Hallyn <serue@us.ibm.com>
2009-06-23selinux: restore optimization to selinux_file_permissionStephen Smalley
Restore the optimization to skip revalidation in selinux_file_permission if nothing has changed since the dentry_open checks, accidentally removed by 389fb800. Also remove redundant test from selinux_revalidate_file_permission. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Reviewed-by: Paul Moore <paul.moore@hp.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-19TOMOYO: Remove next_domain from tomoyo_find_next_domain().Tetsuo Handa
We can update bprm->cred->security inside tomoyo_find_next_domain(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-19TOMOYO: Move tomoyo_delete_domain().Tetsuo Handa
We can mark tomoyo_delete_domain() as a "static" function by moving it from domain.c to common.c . Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-19Merge branch 'master' into nextJames Morris
2009-06-18devcgroup: skip superfluous checks when found the DEV_ALL elemLi Zefan
While walking through the whitelist, if the DEV_ALL item is found, no more check is needed. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-19Add audit messages on type boundary violationsKaiGai Kohei
The attached patch adds support to generate audit messages on two cases. The first one is a case when a multi-thread process tries to switch its performing security context using setcon(3), but new security context is not bounded by the old one. type=SELINUX_ERR msg=audit(1245311998.599:17): \ op=security_bounded_transition result=denied \ oldcontext=system_u:system_r:httpd_t:s0 \ newcontext=system_u:system_r:guest_webapp_t:s0 The other one is a case when security_compute_av() masked any permissions due to the type boundary violation. type=SELINUX_ERR msg=audit(1245312836.035:32): \ op=security_compute_av reason=bounds \ scontext=system_u:object_r:user_webapp_t:s0 \ tcontext=system_u:object_r:shadow_t:s0:c0 \ tclass=file perms=getattr,open Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-18cleanup in ss/services.cKaiGai Kohei
It is a cleanup patch to cut down a line within 80 columns. Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> -- security/selinux/ss/services.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-) Signed-off-by: James Morris <jmorris@namei.org>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (44 commits) nommu: Provide mmap_min_addr definition. TOMOYO: Add description of lists and structures. TOMOYO: Remove unused field. integrity: ima audit dentry_open failure TOMOYO: Remove unused parameter. security: use mmap_min_addr indepedently of security models TOMOYO: Simplify policy reader. TOMOYO: Remove redundant markers. SELinux: define audit permissions for audit tree netlink messages TOMOYO: Remove unused mutex. tomoyo: avoid get+put of task_struct smack: Remove redundant initialization. integrity: nfsd imbalance bug fix rootplug: Remove redundant initialization. smack: do not beyond ARRAY_SIZE of data integrity: move ima_counts_get integrity: path_check update IMA: Add __init notation to ima functions IMA: Minimal IMA policy and boot param for TCB IMA policy selinux: remove obsolete read buffer limit from sel_read_bool ...
2009-06-10Merge branch 'rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: rcu_sched_grace_period(): kill the bogus flush_signals() rculist: use list_entry_rcu in places where it's appropriate rculist.h: introduce list_entry_rcu() and list_first_entry_rcu() rcu: Update RCU tracing documentation for __rcu_pending rcu: Add __rcu_pending tracing to hierarchical RCU RCU: make treercu be default
2009-06-09TOMOYO: Add description of lists and structures.Tetsuo Handa
This patch adds some descriptions of lists and structures. This patch contains no code changes. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-09TOMOYO: Remove unused field.Tetsuo Handa
TOMOYO 2.2.0 is not using total_len field of "struct tomoyo_path_info". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-09Merge branch 'master' into nextJames Morris
2009-06-05integrity: ima audit dentry_open failureMimi Zohar
Until we start appraising measurements, the ima_path_check() return code should always be 0. - Update the ima_path_check() return code comment - Instead of the pr_info, audit the dentry_open failure Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-04TOMOYO: Remove unused parameter.Tetsuo Handa
TOMOYO 2.2.0 does not check argv[] and envp[] upon execve(). We don't need to pass "struct tomoyo_page_buffer". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-04security: use mmap_min_addr indepedently of security modelsChristoph Lameter
This patch removes the dependency of mmap_min_addr on CONFIG_SECURITY. It also sets a default mmap_min_addr of 4096. mmapping of addresses below 4096 will only be possible for processes with CAP_SYS_RAWIO. Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Eric Paris <eparis@redhat.com> Looks-ok-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03TOMOYO: Simplify policy reader.Tetsuo Handa
We can directly assign the result of tomoyo_io_printf() to done flag. Signed-off-by: Kentaro Takeda <takedakn@nttdata.co.jp> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Toshiharu Harada <haradats@nttdata.co.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-03TOMOYO: Remove redundant markers.Tetsuo Handa
Remove '/***** START/STOP *****/' markers. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-03SELinux: define audit permissions for audit tree netlink messagesEric Paris
Audit trees defined 2 new netlink messages but the netlink mapping tables for selinux permissions were not set up. This patch maps these 2 new operations to AUDIT_WRITE. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-02TOMOYO: Remove unused mutex.Tetsuo Handa
I forgot to remove on TOMOYO's 15th posting. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-02tomoyo: avoid get+put of task_structSerge E. Hallyn
Use task_cred_xxx(task, security) in tomoyo_real_domain() to avoid a get+put of the target cred. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-28smack: Remove redundant initialization.Tetsuo Handa
We don't need to explicitly initialize to cap_* because it will be filled by security_fixup_ops(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-27rootplug: Remove redundant initialization.Tetsuo Handa
We don't need to explicitly initialize to cap_* because it will be filled by security_fixup_ops(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-27tomoyo: add missing call to cap_bprm_set_credsHerton Ronaldo Krzesinski
cap_bprm_set_creds() has to be called from security_bprm_set_creds(). TOMOYO forgot to call cap_bprm_set_creds() from tomoyo_bprm_set_creds() and suid executables were not being working. Make sure we call cap_bprm_set_creds() with TOMOYO, to set credentials properly inside tomoyo_bprm_set_creds(). Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-22Merge branch 'master' into nextJames Morris
Conflicts: fs/exec.c Removed IMA changes (the IMA checks are now performed via may_open()). Signed-off-by: James Morris <jmorris@namei.org>
2009-05-22smack: do not beyond ARRAY_SIZE of dataRoel Kluin
Do not go beyond ARRAY_SIZE of data Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-22integrity: path_check updateMimi Zohar
- Add support in ima_path_check() for integrity checking without incrementing the counts. (Required for nfsd.) - rename and export opencount_get to ima_counts_get - replace ima_shm_check calls with ima_counts_get - export ima_path_check Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-22IMA: Add __init notation to ima functionsEric Paris
A number of IMA functions only used during init are not marked with __init. Add those notations so they are freed automatically. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-22IMA: Minimal IMA policy and boot param for TCB IMA policyEric Paris
The IMA TCB policy is dangerous. A normal use can use all of a system's memory (which cannot be freed) simply by building and running lots of executables. The TCB policy is also nearly useless because logging in as root often causes a policy violation when dealing with utmp, thus rendering the measurements meaningless. There is no good fix for this in the kernel. A full TCB policy would need to be loaded in userspace using LSM rule matching to get both a protected and useful system. But, if too little is measured before userspace can load a real policy one again ends up with a meaningless set of measurements. One option would be to put the policy load inside the initrd in order to get it early enough in the boot sequence to be useful, but this runs into trouble with the LSM. For IMA to measure the LSM policy and the LSM policy loading mechanism it needs rules to do so, but we already talked about problems with defaulting to such broad rules.... IMA also depends on the files being measured to be on an FS which implements and supports i_version. Since the only FS with this support (ext4) doesn't even use it by default it seems silly to have any IMA rules by default. This should reduce the performance overhead of IMA to near 0 while still letting users who choose to configure their machine as such to inclue the ima_tcb kernel paramenter and get measurements during boot before they can load a customized, reasonable policy in userspace. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-19selinux: remove obsolete read buffer limit from sel_read_boolStephen Smalley
On Tue, 2009-05-19 at 00:05 -0400, Eamon Walsh wrote: > Recent versions of coreutils have bumped the read buffer size from 4K to > 32K in several of the utilities. > > This means that "cat /selinux/booleans/xserver_object_manager" no longer > works, it returns "Invalid argument" on F11. getsebool works fine. > > sel_read_bool has a check for "count > PAGE_SIZE" that doesn't seem to > be present in the other read functions. Maybe it could be removed? Yes, that check is obsoleted by the conversion of those functions to using simple_read_from_buffer(), which will reduce count if necessary to what is available in the buffer. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-19SELinux: move SELINUX_MAGIC into magic.hEric Paris
The selinuxfs superblock magic is used inside the IMA code, but is being defined in two places and could someday get out of sync. This patch moves the declaration into magic.h so it is only done once. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-15IMA: do not measure everything opened by root by defaultEric Paris
The IMA default policy measures every single file opened by root. This is terrible for most users. Consider a system (like mine) with virtual machine images. When those images are touched (which happens at boot for me) those images are measured. This is just way too much for the default case. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-15IMA: remove read permissions on the ima policy fileEric Paris
The IMA policy file does not implement read. Trying to just open/read/close the file will load a blank policy and you cannot then change the policy without a reboot. This removes the read permission from the file so one must at least be attempting to write... Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
