commit 4b14752ec4e0d87126e636384cf37c8dd9df157c upstream.
We can't do anything reasonable in security_bounded_transition() if we
don't have a policy loaded, and in fact we could run into problems
with some of the code inside expecting a policy. Fix these problems
like we do many others in security/selinux/ss/services.c by checking
to see if the policy is loaded (ss_initialized) and returning quickly
if it isn't.
Reported-by: syzbot <syzkaller-bugs@googlegroups.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Reviewed-by: James Morris <james.l.morris@oracle.com>
commit ef28df55ac27e1e5cd122e19fa311d886d47a756 upstream.
The syzbot/syzkaller automated tests found a problem in
security_context_to_sid_core() during early boot (before we load the
SELinux policy) where we could potentially feed context strings without
NUL terminators into the strcmp() function.
We already guard against this during normal operation (after the SELinux
policy has been loaded) by making a copy of the context strings and
explicitly adding a NUL terminator to the end. The patch extends this
protection to the early boot case (no loaded policy) by moving the context
copy earlier in security_context_to_sid_core().
Reported-by: syzbot <syzkaller@googlegroups.com>
Reviewed-By: William Roberts <william.c.roberts@intel.com>
commit 794b4bc292f5d31739d89c0202c54e7dc9bc3add upstream.
With the 'encrypted' key type it was possible for userspace to provide a
data blob ending with a master key description shorter than expected,
e.g. 'keyctl add encrypted desc "new x" @s'. When validating such a
master key description, validate_master_desc() could read beyond the end
of the buffer. Fix this by using strncmp() instead of memcmp(). [Also
clean up the code to deduplicate some logic.]
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Signed-off-by: Jin Qian <jinqian@google.com>
In the absence of commit a4298e4522d6 ("net: add SOCK_RCU_FREE socket
flag") and all the associated infrastructure changes to take advantage
of a RCU grace period before freeing, there is a heightened
possibility that a security check is performed while an ill-timed
setsockopt call races in from user space. It then is prudent to null
check sk_security, and if the case, reject the permissions.
Because of the nature of this problem, hard to duplicate, no clear
path, this patch is a simplified band-aid for stable trees lacking the
infrastructure for the series of commits leading up to providing a
suitable RCU grace period. This adjustment is orthogonal to
infrastructure improvements that may nullify the needed check, but
could be added as good code hygiene in all trees.
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 14233 Comm: syz-executor2 Not tainted 4.4.112-g5f6325b #28
task: ffff8801d1095f00 task.stack: ffff8800b5950000
RIP: 0010:[<ffffffff81b69b7e>] [<ffffffff81b69b7e>] sock_has_perm+0x1fe/0x3e0 security/selinux/hooks.c:4069
RSP: 0018:ffff8800b5957ce0 EFLAGS: 00010202
RAX: dffffc0000000000 RBX: 1ffff10016b2af9f RCX: ffffffff81b69b51
RDX: 0000000000000002 RSI: 0000000000000000 RDI: 0000000000000010
RBP: ffff8800b5957de0 R08: 0000000000000001 R09: 0000000000000001
R10: 0000000000000000 R11: 1ffff10016b2af68 R12: ffff8800b5957db8
R13: 0000000000000000 R14: ffff8800b7259f40 R15: 00000000000000d7
FS: 00007f72f5ae2700(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000
CR2: 0000000000a2fa38 CR3: 00000001d7980000 CR4: 0000000000160670
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Stack:
ffffffff81b69a1f ffff8800b5957d58 00008000b5957d30 0000000041b58ab3
ffffffff83fc82f2 ffffffff81b69980 0000000000000246 ffff8801d1096770
ffff8801d3165668 ffffffff8157844b ffff8801d1095f00
ffff880000000001
Call Trace:
[<ffffffff81b6a19d>] selinux_socket_setsockopt+0x4d/0x80 security/selinux/hooks.c:4338
[<ffffffff81b4873d>] security_socket_setsockopt+0x7d/0xb0 security/security.c:1257
[<ffffffff82df1ac8>] SYSC_setsockopt net/socket.c:1757 [inline]
[<ffffffff82df1ac8>] SyS_setsockopt+0xe8/0x250 net/socket.c:1746
[<ffffffff83776499>] entry_SYSCALL_64_fastpath+0x16/0x92
Code: c2 42 9b b6 81 be 01 00 00 00 48 c7 c7 a0 cb 2b 84 e8
f7 2f 6d ff 49 8d 7d 10 48 b8 00 00 00 00 00 fc ff df 48 89
fa 48 c1 ea 03 <0f> b6 04 02 84 c0 74 08 3c 03 0f 8e 83 01 00
00 41 8b 75 10 31
RIP [<ffffffff81b69b7e>] sock_has_perm+0x1fe/0x3e0 security/selinux/hooks.c:4069
RSP <ffff8800b5957ce0>
---[ end trace 7b5aaf788fef6174 ]---
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: selinux@tycho.nsa.gov
Cc: linux-security-module@vger.kernel.org
Cc: Eric Paris <eparis@parisplace.org>
Cc: Serge E. Hallyn <serge@hallyn.com>
This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION.
Now that the required bits have been addressed, reenable
PARAVIRT.
We fail to see what CONFIG_KAISER_REAL_SWITCH is for: it seems to be
left over from early development, and now just obscures tricky parts
of the code. Delete it before adding PCIDs, or nokaiser boot option.
(Or if there is some good reason to keep the option, then it needs
a help text - and a "depends on KAISER", so that all those without
KAISER are not asked the question.)
Acked-by: Jiri Kosina <jkosina@suse.cz>
It is absurd that KAISER should depend on SMP, but apparently nobody
has tried a UP build before: which breaks on implicit declaration of
function 'per_cpu_offset' in arch/x86/mm/kaiser.c.
Now, you would expect that to be trivially fixed up; but looking at
the System.map when that block is #ifdef'ed out of kaiser_init(),
I see that in a UP build __per_cpu_user_mapped_end is precisely at
__per_cpu_user_mapped_start, and the items carefully gathered into
that section for user-mapping on SMP, dispersed elsewhere on UP.
So, some other kind of section assignment will be needed on UP,
but implementing that is not a priority: just make KAISER depend
on SMP for now.
Also inserted a blank line before the option, tidied up the
brief Kconfig help message, and added an "If unsure, Y".
Merged fixes and cleanups, rebased to 4.4.89 tree (no 5-level paging).
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
This patch introduces our implementation of KAISER (Kernel Address Isolation to
have Side-channels Efficiently Removed), a kernel isolation technique to close
hardware side channels on kernel address information.
More information about the patch can be found on:
https://github.com/IAIK/KAISER
From: Richard Fellner <richard.fellner@student.tugraz.at>
X-Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode
Date: Thu, 4 May 2017 14:26:50 +0200
Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2
Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5
To: <linux-kernel@vger.kernel.org>
To: <kernel-hardening@lists.openwall.com>
Cc: <clementine.maurice@iaik.tugraz.at>
Cc: <moritz.lipp@iaik.tugraz.at>
Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Cc: Richard Fellner <richard.fellner@student.tugraz.at>
Cc: <kirill.shutemov@linux.intel.com>
Cc: <anders.fogh@gdata-adan.de>
After several recent works [1,2,3] KASLR on x86_64 was basically
considered dead by many researchers. We have been working on an
efficient but effective fix for this problem and found that not mapping
the kernel space when running in user mode is the solution to this
problem [4] (the corresponding paper [5] will be presented at ESSoS17).
With this RFC patch we allow anybody to configure their kernel with the
flag CONFIG_KAISER to add our defense mechanism.
If there are any questions we would love to answer them.
We also appreciate any comments!
Cheers,
Daniel (+ the KAISER team from Graz University of Technology)
[1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf
[2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf
[3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf
[4] https://github.com/IAIK/KAISER
[5] https://gruss.cc/files/kaiser.pdf
[patch based also on
https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch]
Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at>
Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at>
Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at>
Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
commit 4dca6ea1d9432052afb06baf2e3ae78188a4410b upstream.
When the request_key() syscall is not passed a destination keyring, it
links the requested key (if constructed) into the "default" request-key
keyring. This should require Write permission to the keyring. However,
there is actually no permission check.
This can be abused to add keys to any keyring to which only Search
permission is granted. This is because Search permission allows joining
the keyring. keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_SESSION_KEYRING)
then will set the default request-key keyring to the session keyring.
Then, request_key() can be used to add keys to the keyring.
Both negatively and positively instantiated keys can be added using this
method. Adding negative keys is trivial. Adding a positive key is a
bit trickier. It requires that either /sbin/request-key positively
instantiates the key, or that another thread adds the key to the process
keyring at just the right time, such that request_key() misses it
initially but then finds it in construct_alloc_key().
Fix this bug by checking for Write permission to the keyring in
construct_get_dest_keyring() when the default keyring is being used.
We don't do the permission check for non-default keyrings because that
was already done by the earlier call to lookup_user_key(). Also,
request_key_and_link() is currently passed a 'struct key *' rather than
a key_ref_t, so the "possessed" bit is unavailable.
We also don't do the permission check for the "requestor keyring", to
continue to support the use case described by commit 8bbf4976b59f
("KEYS: Alter use of key instantiation link-to-keyring argument") where
/sbin/request-key recursively calls request_key() to add keys to the
original requestor's destination keyring. (I don't know of any users
who actually do that, though...)
Fixes: 3e30148c3d52 ("[PATCH] Keys: Make request-key create an authorisation key")
[ Upstream commit ebe7c0a7be92bbd34c6ff5b55810546a0ee05bee ]
The hash_setup function always sets the hash_setup_done flag, even
when the hash algorithm is invalid. This prevents the default hash
algorithm defined as CONFIG_IMA_DEFAULT_HASH from being used.
This patch sets hash_setup_done flag only for valid hash algorithms.
Fixes: e7a2ad7eb6f4 "ima: enable support for larger default filedata hash algorithms"
Signed-off-by: Boshi Wang <wangboshi@huawei.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 020aae3ee58c1af0e7ffc4e2cc9fe4dc630338cb upstream.
Commit b65a9cfc2c38 ("Untangling ima mess, part 2: deal with counters")
moved the call of ima_file_check() from may_open() to do_filp_open() at a
point where the file descriptor is already opened.
This breaks the assumption made by IMA that file descriptors being closed
belong to files whose access was granted by ima_file_check(). The
consequence is that security.ima and security.evm are updated with good
values, regardless of the current appraisal status.
For example, if a file does not have security.ima, IMA will create it after
opening the file for writing, even if access is denied. Access to the file
will be allowed afterwards.
Avoid this issue by checking the appraisal status before updating
security.ima.
Signed-off-by: Roberto Sassu <roberto.sassu@huawei.com>
commit 47b2c3fff4932e6fc17ce13d51a43c6969714e20 upstream.
CONFIG_KEYS_COMPAT is defined in arch-specific Kconfigs and is missing for
several 64-bit architectures : mips, parisc, tile.
At the moment and for those architectures, calling in 32-bit userspace the
keyctl syscall would return an ENOSYS error.
This patch moves the CONFIG_KEYS_COMPAT option to security/keys/Kconfig, to
make sure the compatibility wrapper is registered by default for any 64-bit
architecture as long as it is configured with CONFIG_COMPAT.
[DH: Modified to remove arm64 compat enablement also as requested by Eric
Biggers]
Signed-off-by: Bilal Amarni <bilal.amarni@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
cc: Eric Biggers <ebiggers3@gmail.com>
Cc: James Cowgill <james.cowgill@mips.com>
commit a3c812f7cfd80cf51e8f5b7034f7418f6beb56c1 upstream.
When calling keyctl_read() on a key of type "trusted", if the
user-supplied buffer was too small, the kernel ignored the buffer length
and just wrote past the end of the buffer, potentially corrupting
userspace memory. Fix it by instead returning the size required, as per
the documentation for keyctl_read().
We also don't even fill the buffer at all in this case, as this is
slightly easier to implement than doing a short read, and either
behavior appears to be permitted. It also makes it match the behavior
of the "encrypted" key type.
Fixes: d00a1c72f7f4 ("keys: add new trusted key-type")
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit ee618b4619b72527aaed765f0f0b74072b281159 upstream.
As the previous patch did for encrypted-keys, zero sensitive any
potentially sensitive data related to the "trusted" key type before it
is freed. Notably, we were not zeroing the tpm_buf structures in which
the actual key is stored for TPM seal and unseal, nor were we zeroing
the trusted_key_payload in certain error paths.
Cc: David Safford <safford@us.ibm.com>
commit 3239b6f29bdfb4b0a2ba59df995fc9e6f4df7f1f upstream.
Commit e645016abc80 ("KEYS: fix writing past end of user-supplied buffer
in keyring_read()") made keyring_read() stop corrupting userspace memory
when the user-supplied buffer is too small. However it also made the
return value in that case be the short buffer size rather than the size
required, yet keyctl_read() is actually documented to return the size
required. Therefore, switch it over to the documented behavior.
Note that for now we continue to have it fill the short buffer, since it
did that before (pre-v3.13) and dump_key_tree_aux() in keyutils arguably
relies on it.
Fixes: e645016abc80 ("KEYS: fix writing past end of user-supplied buffer in keyring_read()")
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream.
Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection
error into one field such that:
(1) The instantiation state can be modified/read atomically.
(2) The error can be accessed atomically with the state.
(3) The error isn't stored unioned with the payload pointers.
This deals with the problem that the state is spread over three different
objects (two bits and a separate variable) and reading or updating them
atomically isn't practical, given that not only can uninstantiated keys
change into instantiated or rejected keys, but rejected keys can also turn
into instantiated keys - and someone accessing the key might not be using
any locking.
The main side effect of this problem is that what was held in the payload
may change, depending on the state. For instance, you might observe the
key to be in the rejected state. You then read the cached error, but if
the key semaphore wasn't locked, the key might've become instantiated
between the two reads - and you might now have something in hand that isn't
actually an error code.
The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error
code if the key is negatively instantiated. The key_is_instantiated()
function is replaced with key_is_positive() to avoid confusion as negative
keys are also 'instantiated'.
Additionally, barriering is included:
(1) Order payload-set before state-set during instantiation.
(2) Order state-read before payload-read when using the key.
Further separate barriering is necessary if RCU is being used to access the
payload content after reading the payload pointers.
Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data")
Reported-by: Eric Biggers <ebiggers@google.com>
Reviewed-by: Eric Biggers <ebiggers@google.com>
commit 60ff5b2f547af3828aebafd54daded44cfb0807a upstream.
Currently, when passed a key that already exists, add_key() will call the
key's ->update() method if such exists. But this is heavily broken in the
case where the key is uninstantiated because it doesn't call
__key_instantiate_and_link(). Consequently, it doesn't do most of the
things that are supposed to happen when the key is instantiated, such as
setting the instantiation state, clearing KEY_FLAG_USER_CONSTRUCT and
awakening tasks waiting on it, and incrementing key->user->nikeys.
It also never takes key_construction_mutex, which means that
->instantiate() can run concurrently with ->update() on the same key. In
the case of the "user" and "logon" key types this causes a memory leak, at
best. Maybe even worse, the ->update() methods of the "encrypted" and
"trusted" key types actually just dereference a NULL pointer when passed an
uninstantiated key.
Change key_create_or_update() to wait interruptibly for the key to finish
construction before continuing.
This patch only affects *uninstantiated* keys. For now we still allow a
negatively instantiated key to be updated (thereby positively
instantiating it), although that's broken too (the next patch fixes it)
and I'm not sure that anyone actually uses that functionality either.
Here is a simple reproducer for the bug using the "encrypted" key type
(requires CONFIG_ENCRYPTED_KEYS=y), though as noted above the bug
pertained to more than just the "encrypted" key type:
#include <stdlib.h>
#include <unistd.h>
#include <keyutils.h>
int main(void)
int ringid = keyctl_join_session_keyring(NULL);
if (fork()) {
for (;;) {
const char payload[] = "update user:foo 32";
usleep(rand() % 10000);
add_key("encrypted", "desc", payload, sizeof(payload), ringid);
keyctl_clear(ringid);
} else {
for (;;)
request_key("encrypted", "desc", "callout_info", ringid);
It causes:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: encrypted_update+0xb0/0x170
PGD 7a178067 P4D 7a178067 PUD 77269067 PMD 0
PREEMPT SMP
CPU: 0 PID: 340 Comm: reproduce Tainted: G D 4.14.0-rc1-00025-g428490e38b2e #796
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff8a467a39a340 task.stack: ffffb15c40770000
RIP: 0010:encrypted_update+0xb0/0x170
RSP: 0018:ffffb15c40773de8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff8a467a275b00 RCX: 0000000000000000
RDX: 0000000000000005 RSI: ffff8a467a275b14 RDI: ffffffffb742f303
RBP: ffffb15c40773e20 R08: 0000000000000000 R09: ffff8a467a275b17
R10: 0000000000000020 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: ffff8a4677057180 R15: ffff8a467a275b0f
FS: 00007f5d7fb08700(0000) GS:ffff8a467f200000(0000) knlGS:0000000000000000
CR2: 0000000000000018 CR3: 0000000077262005 CR4: 00000000001606f0
Call Trace:
key_create_or_update+0x2bc/0x460
SyS_add_key+0x10c/0x1d0
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x7f5d7f211259
RSP: 002b:00007ffed03904c8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8
RAX: ffffffffffffffda RBX: 000000003b2a7955 RCX: 00007f5d7f211259
RDX: 00000000004009e4 RSI: 00000000004009ff RDI: 0000000000400a04
RBP: 0000000068db8bad R08: 000000003b2a7955 R09: 0000000000000004
R10: 000000000000001a R11: 0000000000000246 R12: 0000000000400868
R13: 00007ffed03905d0 R14: 0000000000000000 R15: 0000000000000000
Code: 77 28 e8 64 34 1f 00 45 31 c0 31 c9 48 8d 55 c8 48 89 df 48 8d 75 d0 e8 ff f9 ff ff 85 c0 41 89 c4 0f 88 84 00 00 00 4c 8b 7d c8 <49> 8b 75 18 4c 89 ff e8 24 f8 ff ff 85 c0 41 89 c4 78 6d 49 8b
RIP: encrypted_update+0xb0/0x170 RSP: ffffb15c40773de8
cc: Eric Biggers <ebiggers@google.com>
commit 13923d0865ca96312197962522e88bc0aedccd74 upstream.
A key of type "encrypted" references a "master key" which is used to
encrypt and decrypt the encrypted key's payload. However, when we
accessed the master key's payload, we failed to handle the case where
the master key has been revoked, which sets the payload pointer to NULL.
Note that request_key() *does* skip revoked keys, but there is still a
window where the key can be revoked before we acquire its semaphore.
Fix it by checking for a NULL payload, treating it like a key which was
already revoked at the time it was requested.
This was an issue for master keys of type "user" only. Master keys can
also be of type "trusted", but those cannot be revoked.
Fixes: 7e70cb497850 ("keys: add new key-type encrypted")
commit 57e7ba04d422c3d41c8426380303ec9b7533ded9 upstream.
security_inode_getsecurity() provides the text string value
of a security attribute. It does not provide a "secctx".
The code in xattr_getsecurity() that calls security_inode_getsecurity()
and then calls security_release_secctx() happened to work because
SElinux and Smack treat the attribute and the secctx the same way.
It fails for cap_inode_getsecurity(), because that module has no
secctx that ever needs releasing. It turns out that Smack is the
one that's doing things wrong by not allocating memory when instructed
to do so by the "alloc" parameter.
The fix is simple enough. Change the security_release_secctx() to
kfree() because it isn't a secctx being returned by
security_inode_getsecurity(). Change Smack to allocate the string when
told to do so.
Note: this also fixes memory leaks for LSMs which implement
inode_getsecurity but not release_secctx, such as capabilities.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
commit 37863c43b2c6464f252862bf2e9768264e961678 upstream.
Because keyctl_read_key() looks up the key with no permissions
requested, it may find a negatively instantiated key. If the key is
also possessed, we went ahead and called ->read() on the key. But the
key payload will actually contain the ->reject_error rather than the
normal payload. Thus, the kernel oopses trying to read the
user_key_payload from memory address (int)-ENOKEY = 0x00000000ffffff82.
Fortunately the payload data is stored inline, so it shouldn't be
possible to abuse this as an arbitrary memory read primitive...
Reproducer:
keyctl new_session
keyctl request2 user desc '' @s
keyctl read $(keyctl show | awk '/user: desc/ {print $1}')
It causes a crash like the following:
BUG: unable to handle kernel paging request at 00000000ffffff92
IP: user_read+0x33/0xa0
PGD 36a54067 P4D 36a54067 PUD 0
Oops: 0000 [#1] SMP
CPU: 0 PID: 211 Comm: keyctl Not tainted 4.14.0-rc1 #337
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014
task: ffff90aa3b74c3c0 task.stack: ffff9878c0478000
RIP: 0010:user_read+0x33/0xa0
RSP: 0018:ffff9878c047bee8 EFLAGS: 00010246
RAX: 0000000000000001 RBX: ffff90aa3d7da340 RCX: 0000000000000017
RDX: 0000000000000000 RSI: 00000000ffffff82 RDI: ffff90aa3d7da340
RBP: ffff9878c047bf00 R08: 00000024f95da94f R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f58ece69740(0000) GS:ffff90aa3e200000(0000) knlGS:0000000000000000
CR2: 00000000ffffff92 CR3: 0000000036adc001 CR4: 00000000003606f0
Call Trace:
keyctl_read_key+0xac/0xe0
SyS_keyctl+0x99/0x120
RIP: 0033:0x7f58ec787bb9
RSP: 002b:00007ffc8d401678 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa
RAX: ffffffffffffffda RBX: 00007ffc8d402800 RCX: 00007f58ec787bb9
RDX: 0000000000000000 RSI: 00000000174a63ac RDI: 000000000000000b
RBP: 0000000000000004 R08: 00007ffc8d402809 R09: 0000000000000020
R10: 0000000000000000 R11: 0000000000000206 R12: 00007ffc8d402800
R13: 00007ffc8d4016e0 R14: 0000000000000000 R15: 0000000000000000
Code: e5 41 55 49 89 f5 41 54 49 89 d4 53 48 89 fb e8 a4 b4 ad ff 85 c0 74 09 80 3d b9 4c 96 00 00 74 43 48 8b b3 20 01 00 00 4d 85 ed <0f> b7 5e 10 74 29 4d 85 e4 74 24 4c 39 e3 4c 89 e2 4c 89 ef 48
RIP: user_read+0x33/0xa0 RSP: ffff9878c047bee8
Fixes: 61ea0c0ba904 ("KEYS: Skip key state checks when checking for possession")
commit 237bbd29f7a049d310d907f4b2716a7feef9abf3 upstream.
It was possible for an unprivileged user to create the user and user
session keyrings for another user. For example:
sudo -u '#3000' sh -c 'keyctl add keyring _uid.4000 "" @u
keyctl add keyring _uid_ses.4000 "" @u
sleep 15' &
sleep 1
sudo -u '#4000' keyctl describe @u
sudo -u '#4000' keyctl describe @us
This is problematic because these "fake" keyrings won't have the right
permissions. In particular, the user who created them first will own
them and will have full access to them via the possessor permissions,
which can be used to compromise the security of a user's keys:
-4: alswrv-----v------------ 3000 0 keyring: _uid.4000
-5: alswrv-----v------------ 3000 0 keyring: _uid_ses.4000
Fix it by marking user and user session keyrings with a flag
KEY_FLAG_UID_KEYRING. Then, when searching for a user or user session
keyring by name, skip all keyrings that don't have the flag set.
Fixes: 69664cf16af4 ("keys: don't generate user and user session keyrings unless they're accessed")
commit e645016abc803dafc75e4b8f6e4118f088900ffb upstream.
Userspace can call keyctl_read() on a keyring to get the list of IDs of
keys in the keyring. But if the user-supplied buffer is too small, the
kernel would write the full list anyway --- which will corrupt whatever
userspace memory happened to be past the end of the buffer. Fix it by
only filling the space that is available.
Fixes: b2a4df200d57 ("KEYS: Expand the capacity of a keyring")
commit 57cb17e764ba0aaa169d07796acce54ccfbc6cae upstream.
This function has two callers and neither are able to handle a NULL
return. Really, -EINVAL is the correct thing return here anyway. This
fixes some static checker warnings like:
security/keys/encrypted-keys/encrypted.c:709 encrypted_key_decrypt()
error: uninitialized symbol 'master_key'.
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 63a0b0509e700717a59f049ec6e4e04e903c7fe2 upstream.
key_update() freed the key_preparsed_payload even if it was not
initialized first. This would cause a crash if userspace called
keyctl_update() on a key with type like "asymmetric" that has a
->preparse() method but not an ->update() method. Possibly it could
even be triggered for other key types by racing with keyctl_setperm() to
make the KEY_NEED_WRITE check fail (the permission was already checked,
so normally it wouldn't fail there).
Reproducer with key type "asymmetric", given a valid cert.der:
keyctl new_session
keyid=$(keyctl padd asymmetric desc @s < cert.der)
keyctl setperm $keyid 0x3f000000
keyctl update $keyid data
[ 150.686666] BUG: unable to handle kernel NULL pointer dereference at 0000000000000001
[ 150.687601] IP: asymmetric_key_free_kids+0x12/0x30
[ 150.688139] PGD 38a3d067
[ 150.688141] PUD 3b3de067
[ 150.688447] PMD 0
[ 150.688745]
[ 150.689160] Oops: 0000 [#1] SMP
[ 150.689455] Modules linked in:
[ 150.689769] CPU: 1 PID: 2478 Comm: keyctl Not tainted 4.11.0-rc4-xfstests-00187-ga9f6b6b8cd2f #742
[ 150.690916] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014
[ 150.692199] task: ffff88003b30c480 task.stack: ffffc90000350000
[ 150.692952] RIP: 0010:asymmetric_key_free_kids+0x12/0x30
[ 150.693556] RSP: 0018:ffffc90000353e58 EFLAGS: 00010202
[ 150.694142] RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000004
[ 150.694845] RDX: ffffffff81ee3920 RSI: ffff88003d4b0700 RDI: 0000000000000001
[ 150.697569] RBP: ffffc90000353e60 R08: ffff88003d5d2140 R09: 0000000000000000
[ 150.702483] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000001
[ 150.707393] R13: 0000000000000004 R14: ffff880038a4d2d8 R15: 000000000040411f
[ 150.709720] FS: 00007fcbcee35700(0000) GS:ffff88003fd00000(0000) knlGS:0000000000000000
[ 150.711504] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 150.712733] CR2: 0000000000000001 CR3: 0000000039eab000 CR4: 00000000003406e0
[ 150.714487] Call Trace:
[ 150.714975] asymmetric_key_free_preparse+0x2f/0x40
[ 150.715907] key_update+0xf7/0x140
[ 150.716560] ? key_default_cmp+0x20/0x20
[ 150.717319] keyctl_update_key+0xb0/0xe0
[ 150.718066] SyS_keyctl+0x109/0x130
[ 150.718663] entry_SYSCALL_64_fastpath+0x1f/0xc2
[ 150.719440] RIP: 0033:0x7fcbce75ff19
[ 150.719926] RSP: 002b:00007ffd5d167088 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa
[ 150.720918] RAX: ffffffffffffffda RBX: 0000000000404d80 RCX: 00007fcbce75ff19
[ 150.721874] RDX: 00007ffd5d16785e RSI: 000000002866cd36 RDI: 0000000000000002
[ 150.722827] RBP: 0000000000000006 R08: 000000002866cd36 R09: 00007ffd5d16785e
[ 150.723781] R10: 0000000000000004 R11: 0000000000000206 R12: 0000000000404d80
[ 150.724650] R13: 00007ffd5d16784d R14: 00007ffd5d167238 R15: 000000000040411f
[ 150.725447] Code: 83 c4 08 31 c0 5b 41 5c 41 5d 41 5e 41 5f 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 85 ff 74 23 55 48 89 e5 53 48 89 fb <48> 8b 3f e8 06 21 c5 ff 48 8b 7b 08 e8 fd 20 c5 ff 48 89 df e8
[ 150.727489] RIP: asymmetric_key_free_kids+0x12/0x30 RSP: ffffc90000353e58
[ 150.728117] CR2: 0000000000000001
[ 150.728430] ---[ end trace f7f8fe1da2d5ae8d ]---
Fixes: 4d8c0250b841 ("KEYS: Call ->free_preparse() even after ->preparse() returns an error")
commit 5649645d725c73df4302428ee4e02c869248b4c5 upstream.
sys_add_key() and the KEYCTL_UPDATE operation of sys_keyctl() allowed a
NULL payload with nonzero length to be passed to the key type's
->preparse(), ->instantiate(), and/or ->update() methods. Various key
types including asymmetric, cifs.idmap, cifs.spnego, and pkcs7_test did
not handle this case, allowing an unprivileged user to trivially cause a
NULL pointer dereference (kernel oops) if one of these key types was
present. Fix it by doing the copy_from_user() when 'plen' is nonzero
rather than when '_payload' is non-NULL, causing the syscall to fail
with EFAULT as expected when an invalid buffer is specified.
commit 1ac202e978e18f045006d75bd549612620c6ec3a upstream.
Modifying the attributes of a file makes ima_inode_post_setattr reset
the IMA cache flags. So if the file, which has just been created,
is opened a second time before the first file descriptor is closed,
verification fails since the security.ima xattr has not been written
yet. We therefore have to look at the IMA_NEW_FILE even if the file
already existed.
With this patch there should no longer be an error when cat tries to
open testfile:
$ rm -f testfile
$ ( echo test >&3 ; touch testfile ; cat testfile ) 3>testfile
A file being new is no reason to accept that it is missing a digital
signature demanded by the policy.
Signed-off-by: Daniel Glöckner <dg@emlix.com>
commit c9f838d104fed6f2f61d68164712e3204bf5271b upstream.
This fixes CVE-2017-7472.
Running the following program as an unprivileged user exhausts kernel
memory by leaking thread keyrings:
int main()
for (;;)
keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_THREAD_KEYRING);
Fix it by only creating a new thread keyring if there wasn't one before.
To make things more consistent, make install_thread_keyring_to_cred()
and install_process_keyring_to_cred() both return 0 if the corresponding
keyring is already present.
Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials")
commit c1644fe041ebaf6519f6809146a77c3ead9193af upstream.
This fixes CVE-2017-6951.
Userspace should not be able to do things with the "dead" key type as it
doesn't have some of the helper functions set upon it that the kernel
needs. Attempting to use it may cause the kernel to crash.
Fix this by changing the name of the type to ".dead" so that it's rejected
up front on userspace syscalls by key_get_type_from_user().
Though this doesn't seem to affect recent kernels, it does affect older
ones, certainly those prior to:
commit c06cfb08b88dfbe13be44a69ae2fdc3a7c902d81
Author: David Howells <dhowells@redhat.com>
Date: Tue Sep 16 17:36:06 2014 +0100
KEYS: Remove key_type::match in favour of overriding default by match_preparse
which went in before 3.18-rc1.
commit ee8f844e3c5a73b999edf733df1c529d6503ec2f upstream.
This fixes CVE-2016-9604.
Keyrings whose name begin with a '.' are special internal keyrings and so
userspace isn't allowed to create keyrings by this name to prevent
shadowing. However, the patch that added the guard didn't fix
KEYCTL_JOIN_SESSION_KEYRING. Not only can that create dot-named keyrings,
it can also subscribe to them as a session keyring if they grant SEARCH
permission to the user.
This, for example, allows a root process to set .builtin_trusted_keys as
its session keyring, at which point it has full access because now the
possessor permissions are added. This permits root to add extra public
keys, thereby bypassing module verification.
This also affects kexec and IMA.
This can be tested by (as root):
keyctl session .builtin_trusted_keys
keyctl add user a a @s
keyctl list @s
which on my test box gives me:
2 keys in keyring:
180010936: ---lswrv 0 0 asymmetric: Build time autogenerated kernel key: ae3d4a31b82daa8e1a75b49dc2bba949fd992a05
801382539: --alswrv 0 0 user: a
Fix this by rejecting names beginning with a '.' in the keyctl.
cc: linux-ima-devel@lists.sourceforge.net
commit 0c461cb727d146c9ef2d3e86214f498b78b7d125 upstream.
SELinux tries to support setting/clearing of /proc/pid/attr attributes
from the shell by ignoring terminating newlines and treating an
attribute value that begins with a NUL or newline as an attempt to
clear the attribute. However, the test for clearing attributes has
always been wrong; it has an off-by-one error, and this could further
lead to reading past the end of the allocated buffer since commit
bb646cdb12e75d82258c2f2e7746d5952d3e321a ("proc_pid_attr_write():
switch to memdup_user()"). Fix the off-by-one error.
Even with this fix, setting and clearing /proc/pid/attr attributes
from the shell is not straightforward since the interface does not
support multiple write() calls (so shells that write the value and
newline separately will set and then immediately clear the attribute,
requiring use of echo -n to set the attribute), whereas trying to use
echo -n "" to clear the attribute causes the shell to skip the
write() call altogether since POSIX says that a zero-length write
causes no side effects. Thus, one must use echo -n to set and echo
without -n to clear, as in the following example:
$ echo -n unconfined_u:object_r:user_home_t:s0 > /proc/$$/attr/fscreate
$ cat /proc/$$/attr/fscreate
$ echo "" > /proc/$$/attr/fscreate
Note the use of /proc/$$ rather than /proc/self, as otherwise
the cat command will read its own attribute value, not that of the shell.
There are no users of this facility to my knowledge; possibly we
should just get rid of it.
UPDATE: Upon further investigation it appears that a local process
with the process:setfscreate permission can cause a kernel panic as a
result of this bug. This patch fixes CVE-2017-2618.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
[PM: added the update about CVE-2017-2618 to the commit description]
commit 3d40658c977769ce2138f286cf131537bf68bdfe upstream.
After a policy replacement, the task cred may be out of date and need
to be updated. However change_hat is using the stale profiles from
the out of date cred resulting in either: a stale profile being applied
or, incorrect failure when searching for a hat profile as it has been
migrated to the new parent profile.
Fixes: 01e2b670aa898a39259bc85c78e3d74820f4d3b6 (failure to find hat)
Fixes: 898127c34ec03291c86f4ff3856d79e9e18952bc (stale policy being applied)
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1000287
Signed-off-by: John Johansen <john.johansen@canonical.com>
commit 03dab869b7b239c4e013ec82aea22e181e441cfc upstream.
This fixes CVE-2016-7042.
Fix a short sprintf buffer in proc_keys_show(). If the gcc stack protector
is turned on, this can cause a panic due to stack corruption.
The problem is that xbuf[] is not big enough to hold a 64-bit timeout
rendered as weeks:
(gdb) p 0xffffffffffffffffULL/(60*60*24*7)
$2 = 30500568904943
That's 14 chars plus NUL, not 11 chars plus NUL.
Expand the buffer to 16 chars.
I think the unpatched code apparently works if the stack-protector is not
enabled because on a 32-bit machine the buffer won't be overflowed and on a
64-bit machine there's a 64-bit aligned pointer at one side and an int that
isn't checked again on the other side.
The panic incurred looks something like:
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff81352ebe
CPU: 0 PID: 1692 Comm: reproducer Not tainted 4.7.2-201.fc24.x86_64 #1
Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011
0000000000000086 00000000fbbd2679 ffff8800a044bc00 ffffffff813d941f
ffffffff81a28d58 ffff8800a044bc98 ffff8800a044bc88 ffffffff811b2cb6
ffff880000000010 ffff8800a044bc98 ffff8800a044bc30 00000000fbbd2679
Call Trace:
[<ffffffff813d941f>] dump_stack+0x63/0x84
[<ffffffff811b2cb6>] panic+0xde/0x22a
[<ffffffff81352ebe>] ? proc_keys_show+0x3ce/0x3d0
[<ffffffff8109f7f9>] __stack_chk_fail+0x19/0x30
[<ffffffff81352ebe>] proc_keys_show+0x3ce/0x3d0
[<ffffffff81350410>] ? key_validate+0x50/0x50
[<ffffffff8134db30>] ? key_default_cmp+0x20/0x20
[<ffffffff8126b31c>] seq_read+0x2cc/0x390
[<ffffffff812b6b12>] proc_reg_read+0x42/0x70
[<ffffffff81244fc7>] __vfs_read+0x37/0x150
[<ffffffff81357020>] ? security_file_permission+0xa0/0xc0
[<ffffffff81246156>] vfs_read+0x96/0x130
[<ffffffff81247635>] SyS_read+0x55/0xc0
[<ffffffff817eb872>] entry_SYSCALL_64_fastpath+0x1a/0xa4
Reported-by: Ondrej Kozina <okozina@redhat.com>
Tested-by: Ondrej Kozina <okozina@redhat.com>
commit e71b9dff0634edb127f449e076e883ef24a8c76c upstream.
Ima tries to call ->setxattr() on overlayfs dentry after having locked
underlying inode, which results in a deadlock.
Reported-by: Krisztian Litkey <kli@iki.fi>
Fixes: 4bacc9c9234c ("overlayfs: Make f_path always point to the overlay and f_inode to the underlay")
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit 0b938a2e2cf0b0a2c8bac9769111545aff0fee97 upstream.
Acked-by: Seth Arnold <seth.arnold@canonical.com>
commit 38327424b40bcebe2de92d07312c89360ac9229a upstream.
If __key_link_begin() failed then "edit" would be uninitialized. I've
added a check to fix that.
This allows a random user to crash the kernel, though it's quite
difficult to achieve. There are three ways it can be done as the user
would have to cause an error to occur in __key_link():
(1) Cause the kernel to run out of memory. In practice, this is difficult
to achieve without ENOMEM cropping up elsewhere and aborting the
attempt.
(2) Revoke the destination keyring between the keyring ID being looked up
and it being tested for revocation. In practice, this is difficult to
time correctly because the KEYCTL_REJECT function can only be used
from the request-key upcall process. Further, users can only make use
of what's in /sbin/request-key.conf, though this does including a
rejection debugging test - which means that the destination keyring
has to be the caller's session keyring in practice.
(3) Have just enough key quota available to create a key, a new session
keyring for the upcall and a link in the session keyring, but not then
sufficient quota to create a link in the nominated destination keyring
so that it fails with EDQUOT.
The bug can be triggered using option (3) above using something like the
following:
echo 80 >/proc/sys/kernel/keys/root_maxbytes
keyctl request2 user debug:fred negate @t
The above sets the quota to something much lower (80) to make the bug
easier to trigger, but this is dependent on the system. Note also that
the name of the keyring created contains a random number that may be
between 1 and 10 characters in size, so may throw the test off by
changing the amount of quota used.
Assuming the failure occurs, something like the following will be seen:
kfree_debugcheck: out of range ptr 6b6b6b6b6b6b6b68h
kernel BUG at ../mm/slab.c:2821!
RIP: 0010:[<ffffffff811600f9>] kfree_debugcheck+0x20/0x25
RSP: 0018:ffff8804014a7de8 EFLAGS: 00010092
RAX: 0000000000000034 RBX: 6b6b6b6b6b6b6b68 RCX: 0000000000000000
RDX: 0000000000040001 RSI: 00000000000000f6 RDI: 0000000000000300
RBP: ffff8804014a7df0 R08: 0000000000000001 R09: 0000000000000000
R10: ffff8804014a7e68 R11: 0000000000000054 R12: 0000000000000202
R13: ffffffff81318a66 R14: 0000000000000000 R15: 0000000000000001
Call Trace:
kfree+0xde/0x1bc
assoc_array_cancel_edit+0x1f/0x36
__key_link_end+0x55/0x63
key_reject_and_link+0x124/0x155
keyctl_reject_key+0xb6/0xe0
keyctl_negate_key+0x10/0x12
SyS_keyctl+0x9f/0xe7
do_syscall_64+0x63/0x13a
entry_SYSCALL64_slow_path+0x25/0x25
Fixes: f70e2e06196a ('KEYS: Do preallocation for __key_link()')
commit 3dfb7d8cdbc7ea0c2970450e60818bb3eefbad69 upstream.
It looks like smack and yama weren't aware that the ptrace mode
can have flags ORed into it - PTRACE_MODE_NOAUDIT until now, but
only for /proc/$pid/stat, and with the PTRACE_MODE_*CREDS patch,
all modes have flags ORed into them.
Signed-off-by: Jann Horn <jann@thejh.net>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Willy Tarreau <w@1wt.eu>
commit caaee6234d05a58c5b4d05e7bf766131b810a657 upstream.
By checking the effective credentials instead of the real UID / permitted
capabilities, ensure that the calling process actually intended to use its
credentials.
To ensure that all ptrace checks use the correct caller credentials (e.g.
in case out-of-tree code or newly added code omits the PTRACE_MODE_*CREDS
flag), use two new flags and require one of them to be set.
The problem was that when a privileged task had temporarily dropped its
privileges, e.g. by calling setreuid(0, user_uid), with the intent to
perform following syscalls with the credentials of a user, it still passed
ptrace access checks that the user would not be able to pass.
While an attacker should not be able to convince the privileged task to
perform a ptrace() syscall, this is a problem because the ptrace access
check is reused for things in procfs.
In particular, the following somewhat interesting procfs entries only rely
on ptrace access checks:
/proc/$pid/stat - uses the check for determining whether pointers
should be visible, useful for bypassing ASLR
/proc/$pid/maps - also useful for bypassing ASLR
/proc/$pid/cwd - useful for gaining access to restricted
directories that contain files with lax permissions, e.g. in
this scenario:
lrwxrwxrwx root root /proc/13020/cwd -> /root/foobar
drwx------ root root /root
drwxr-xr-x root root /root/foobar
-rw-r--r-- root root /root/foobar/secret
Therefore, on a system where a root-owned mode 6755 binary changes its
effective credentials as described and then dumps a user-specified file,
this could be used by an attacker to reveal the memory layout of root's
processes or reveal the contents of files he is not allowed to access
(through /proc/$pid/cwd).
[akpm@linux-foundation.org: fix warning]
Cc: Casey Schaufler <casey@schaufler-ca.com>
commit 613317bd212c585c20796c10afe5daaa95d4b0a1 upstream.
This patch fixes vulnerability CVE-2016-2085. The problem exists
because the vm_verify_hmac() function includes a use of memcmp().
Unfortunately, this allows timing side channel attacks; specifically
a MAC forgery complexity drop from 2^128 to 2^12. This patch changes
the memcmp() to the cryptographically safe crypto_memneq().
Reported-by: Xiaofei Rex Guo <xiaofei.rex.guo@intel.com>
Signed-off-by: Ryan Ware <ware@linux.intel.com>
commit 23567fd052a9abb6d67fe8e7a9ccdd9800a540f2 upstream.
This fixes CVE-2016-0728.
If a thread is asked to join as a session keyring the keyring that's already
set as its session, we leak a keyring reference.
This can be tested with the following program:
#include <stddef.h>
#include <stdio.h>
#include <sys/types.h>
int main(int argc, const char *argv[])
int i = 0;
key_serial_t serial;
serial = keyctl(KEYCTL_JOIN_SESSION_KEYRING,
"leaked-keyring");
if (serial < 0) {
perror("keyctl");
return -1;
if (keyctl(KEYCTL_SETPERM, serial,
KEY_POS_ALL | KEY_USR_ALL) < 0) {
perror("keyctl");
return -1;
for (i = 0; i < 100; i++) {
"leaked-keyring");
if (serial < 0) {
perror("keyctl");
return -1;
return 0;
If, after the program has run, there something like the following line in
/proc/keys:
3f3d898f I--Q--- 100 perm 3f3f0000 0 0 keyring leaked-keyring: empty
with a usage count of 100 * the number of times the program has been run,
then the kernel is malfunctioning. If leaked-keyring has zero usages or
has been garbage collected, then the problem is fixed.
Reported-by: Yevgeny Pats <yevgeny@perception-point.io>
Acked-by: Don Zickus <dzickus@redhat.com>
Acked-by: Prarit Bhargava <prarit@redhat.com>
Acked-by: Jarod Wilson <jarod@redhat.com>
This fixes CVE-2015-7550.
There's a race between keyctl_read() and keyctl_revoke(). If the revoke
happens between keyctl_read() checking the validity of a key and the key's
semaphore being taken, then the key type read method will see a revoked key.
This causes a problem for the user-defined key type because it assumes in
its read method that there will always be a payload in a non-revoked key
and doesn't check for a NULL pointer.
Fix this by making keyctl_read() check the validity of a key after taking
semaphore instead of before.
I think the bug was introduced with the original keyrings code.
This was discovered by a multithreaded test program generated by syzkaller
(http://github.com/google/syzkaller). Here's a cleaned up version:
#include <pthread.h>
void *thr0(void *arg)
key_serial_t key = (unsigned long)arg;
keyctl_revoke(key);
return 0;
void *thr1(void *arg)
char buffer[16];
keyctl_read(key, buffer, 16);
return 0;
int main()
key_serial_t key = add_key("user", "%", "foo", 3, KEY_SPEC_USER_KEYRING);
pthread_t th[5];
pthread_create(&th[0], 0, thr0, (void *)(unsigned long)key);
pthread_create(&th[1], 0, thr1, (void *)(unsigned long)key);
pthread_create(&th[2], 0, thr0, (void *)(unsigned long)key);
pthread_create(&th[3], 0, thr1, (void *)(unsigned long)key);
pthread_join(th[0], 0);
pthread_join(th[1], 0);
pthread_join(th[2], 0);
pthread_join(th[3], 0);
return 0;
Build as:
cc -o keyctl-race keyctl-race.c -lkeyutils -lpthread
Run as:
while keyctl-race; do :; done
as it may need several iterations to crash the kernel. The crash can be
summarised as:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: [<ffffffff81279b08>] user_read+0x56/0xa3
Call Trace:
[<ffffffff81276aa9>] keyctl_read_key+0xb6/0xd7
[<ffffffff81277815>] SyS_keyctl+0x83/0xe0
[<ffffffff815dbb97>] entry_SYSCALL_64_fastpath+0x12/0x6f
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Cc: stable@vger.kernel.org
into for-linus2
If a user key gets negatively instantiated, an error code is cached in the
payload area. A negatively instantiated key may be then be positively
instantiated by updating it with valid data. However, the ->update key
type method must be aware that the error code may be there.
The following may be used to trigger the bug in the user key type:
keyctl request2 user user "" @u
keyctl add user user "a" @u
which manifests itself as:
BUG: unable to handle kernel paging request at 00000000ffffff8a
IP: [<ffffffff810a376f>] __call_rcu.constprop.76+0x1f/0x280 kernel/rcu/tree.c:3046
PGD 7cc30067 PUD 0
Oops: 0002 [#1] SMP
Modules linked in:
CPU: 3 PID: 2644 Comm: a.out Not tainted 4.3.0+ #49
task: ffff88003ddea700 ti: ffff88003dd88000 task.ti: ffff88003dd88000
RIP: 0010:[<ffffffff810a376f>] [<ffffffff810a376f>] __call_rcu.constprop.76+0x1f/0x280
RSP: 0018:ffff88003dd8bdb0 EFLAGS: 00010246
RAX: 00000000ffffff82 RBX: 0000000000000000 RCX: 0000000000000001
RDX: ffffffff81e3fe40 RSI: 0000000000000000 RDI: 00000000ffffff82
RBP: ffff88003dd8bde0 R08: ffff88007d2d2da0 R09: 0000000000000000
R10: 0000000000000000 R11: ffff88003e8073c0 R12: 00000000ffffff82
R13: ffff88003dd8be68 R14: ffff88007d027600 R15: ffff88003ddea700
FS: 0000000000b92880(0063) GS:ffff88007fd00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000ffffff8a CR3: 000000007cc5f000 CR4: 00000000000006e0
Stack:
ffff88003dd8bdf0 ffffffff81160a8a 0000000000000000 00000000ffffff82
ffff88003dd8be68 ffff88007d027600 ffff88003dd8bdf0 ffffffff810a39e5
ffff88003dd8be20 ffffffff812a31ab ffff88007d027600 ffff88007d027620
Call Trace:
[<ffffffff810a39e5>] kfree_call_rcu+0x15/0x20 kernel/rcu/tree.c:3136
[<ffffffff812a31ab>] user_update+0x8b/0xb0 security/keys/user_defined.c:129
[< inline >] __key_update security/keys/key.c:730
[<ffffffff8129e5c1>] key_create_or_update+0x291/0x440 security/keys/key.c:908
[< inline >] SYSC_add_key security/keys/keyctl.c:125
[<ffffffff8129fc21>] SyS_add_key+0x101/0x1e0 security/keys/keyctl.c:60
[<ffffffff8185f617>] entry_SYSCALL_64_fastpath+0x12/0x6a arch/x86/entry/entry_64.S:185
Note the error code (-ENOKEY) in EDX.
A similar bug can be tripped by:
keyctl request2 trusted user "" @u
keyctl add trusted user "a" @u
This should also affect encrypted keys - but that has to be correctly
parameterised or it will fail with EINVAL before getting to the bit that
will crashes.
commit fa1aa143ac4a ("selinux: extended permissions for ioctls")
introduced a bug into the handling of conditional rules, skipping the
processing entirely when the caller does not provide an extended
permissions (xperms) structure. Access checks from userspace using
/sys/fs/selinux/access do not include such a structure since that
interface does not presently expose extended permission information.
As a result, conditional rules were being ignored entirely on userspace
access requests, producing denials when access was allowed by
conditional rules in the policy. Fix the bug by only skipping
computation of extended permissions in this situation, not the entire
conditional rules processing.
Reported-by: Laurent Bigonville <bigon@debian.org>
[PM: fixed long lines in patch description]
Cc: stable@vger.kernel.org # 4.3
Signed-off-by: Paul Moore <pmoore@redhat.com>
Pull networking fixes from David Miller:
1) Fix null deref in xt_TEE netfilter module, from Eric Dumazet.
2) Several spots need to get to the original listner for SYN-ACK
packets, most spots got this ok but some were not. Whilst covering
the remaining cases, create a helper to do this. From Eric Dumazet.
3) Missiing check of return value from alloc_netdev() in CAIF SPI code,
from Rasmus Villemoes.
4) Don't sleep while != TASK_RUNNING in macvtap, from Vlad Yasevich.
5) Use after free in mvneta driver, from Justin Maggard.
6) Fix race on dst->flags access in dst_release(), from Eric Dumazet.
7) Add missing ZLIB_INFLATE dependency for new qed driver. From Arnd
Bergmann.
8) Fix multicast getsockopt deadlock, from WANG Cong.
9) Fix deadlock in btusb, from Kuba Pawlak.
10) Some ipv6_add_dev() failure paths were not cleaning up the SNMP6
counter state. From Sabrina Dubroca.
11) Fix packet_bind() race, which can cause lost notifications, from
Francesco Ruggeri.
12) Fix MAC restoration in qlcnic driver during bonding mode changes,
from Jarod Wilson.
13) Revert bridging forward delay change which broke libvirt and other
userspace things, from Vlad Yasevich.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits)
Revert "bridge: Allow forward delay to be cfgd when STP enabled"
bpf_trace: Make dependent on PERF_EVENTS
qed: select ZLIB_INFLATE
net: fix a race in dst_release()
net: mvneta: Fix memory use after free.
net: Documentation: Fix default value tcp_limit_output_bytes
macvtap: Resolve possible __might_sleep warning in macvtap_do_read()
mvneta: add FIXED_PHY dependency
net: caif: check return value of alloc_netdev
net: hisilicon: NET_VENDOR_HISILICON should depend on HAS_DMA
drivers: net: xgene: fix RGMII 10/100Mb mode
netfilter: nft_meta: use skb_to_full_sk() helper
net_sched: em_meta: use skb_to_full_sk() helper
sched: cls_flow: use skb_to_full_sk() helper
netfilter: xt_owner: use skb_to_full_sk() helper
smack: use skb_to_full_sk() helper
net: add skb_to_full_sk() helper and use it in selinux_netlbl_skbuff_setsid()
bpf: doc: correct arch list for supported eBPF JIT
dwc_eth_qos: Delete an unnecessary check before the function call "of_node_put"
bonding: fix panic on non-ARPHRD_ETHER enslave failure
This module wants to access sk->sk_security, which is not
available for request sockets.
Fixes: ca6fb0651883 ("tcp: attach SYNACK messages to request sockets instead of listener")
Generalize selinux_skb_sk() added in commit 212cd0895330
("selinux: fix random read in selinux_ip_postroute_compat()")
so that we can use it other contexts.
Use it right away in selinux_netlbl_skbuff_setsid()
__GFP_WAIT was used to signal that the caller was in atomic context and
could not sleep. Now it is possible to distinguish between true atomic
context and callers that are not willing to sleep. The latter should
clear __GFP_DIRECT_RECLAIM so kswapd will still wake. As clearing
__GFP_WAIT behaves differently, there is a risk that people will clear the
wrong flags. This patch renames __GFP_WAIT to __GFP_RECLAIM to clearly
indicate what it does -- setting it allows all reclaim activity, clearing
them prevents it.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem update from James Morris:
"This is mostly maintenance updates across the subsystem, with a
notable update for TPM 2.0, and addition of Jarkko Sakkinen as a
maintainer of that"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (40 commits)
apparmor: clarify CRYPTO dependency
selinux: Use a kmem_cache for allocation struct file_security_struct
selinux: ioctl_has_perm should be static
selinux: use sprintf return value
selinux: use kstrdup() in security_get_bools()
selinux: use kmemdup in security_sid_to_context_core()
selinux: remove pointless cast in selinux_inode_setsecurity()
selinux: introduce security_context_str_to_sid
selinux: do not check open perm on ftruncate call
selinux: change CONFIG_SECURITY_SELINUX_CHECKREQPROT_VALUE default
KEYS: Provide a script to extract a module signature
KEYS: Provide a script to extract the sys cert list from a vmlinux file
keys: Be more consistent in selection of union members used
certs: add .gitignore to stop git nagging about x509_certificate_list
KEYS: use kvfree() in add_key
Smack: limited capability for changing process label
TPM: remove unnecessary little endian conversion
vTPM: support little endian guests
char: Drop owner assignment from i2c_driver
