path: root/security
2005-09-30[PATCH] SELinux - fix SCTP socket bug and general IP protocol handlingJames Morris
The following patch updates the way SELinux classifies and handles IP based protocols. Currently, IP sockets are classified by SELinux as being either TCP, UDP or 'Raw', the latter being a default for IP socket that is not TCP or UDP. The classification code is out of date and uses only the socket type parameter to socket(2) to determine the class of IP socket. So, any socket created with SOCK_STREAM will be classified by SELinux as TCP, and SOCK_DGRAM as UDP. Also, other socket types such as SOCK_SEQPACKET and SOCK_DCCP are currently ignored by SELinux, which classifies them as generic sockets, which means they don't even get basic IP level checking. This patch changes the SELinux IP socket classification logic, so that only an IPPROTO_IP protocol value passed to socket(2) classify the socket as TCP or UDP. The patch also drops the check for SOCK_RAW and converts it into a default, so that socket types like SOCK_DCCP and SOCK_SEQPACKET are classified as SECCLASS_RAWIP_SOCKET (instead of generic sockets). Note that protocol-specific support for SCTP, DCCP etc. is not addressed here, we're just getting these protocols checked at the IP layer. This fixes a reported problem where SCTP sockets were being recognized as generic SELinux sockets yet still being passed in one case to an IP level check, which then fails for generic sockets. It will also fix bugs where any SOCK_STREAM socket is classified as TCP or any SOCK_DGRAM socket is classified as UDP. This patch also unifies the way IP sockets classes are determined in selinux_socket_bind(), so we use the already calculated value instead of trying to recalculate it. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] Keys: Add possessor permissions to keys [try #3]David Howells
The attached patch adds extra permission grants to keys for the possessor of a key in addition to the owner, group and other permissions bits. This makes SUID binaries easier to support without going as far as labelling keys and key targets using the LSM facilities. This patch adds a second "pointer type" to key structures (struct key_ref *) that can have the bottom bit of the address set to indicate the possession of a key. This is propagated through searches from the keyring to the discovered key. It has been made a separate type so that the compiler can spot attempts to dereference a potentially incorrect pointer. The "possession" attribute can't be attached to a key structure directly as it's not an intrinsic property of a key. Pointers to keys have been replaced with struct key_ref *'s wherever possession information needs to be passed through. This does assume that the bottom bit of the pointer will always be zero on return from kmem_cache_alloc(). The key reference type has been made into a typedef so that at least it can be located in the sources, even though it's basically a pointer to an undefined type. I've also renamed the accessor functions to be more useful, and all reference variables should now end in "_ref". Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] seclvl: use securityfs (fix)Serge Hallyn
That should be -EINVAL for both. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] seclvl-use-securityfs tidyAndrew Morton
We don't put braces around single statements, thanks. Cc: Serge Hallyn <serue@us.ibm.com> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@osdl.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/chrisw/lsm-2.6 Linus Torvalds
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/dwmw2/audit-2.6 Linus Torvalds
2005-09-09[PATCH] files: lock-free fd look-upDipankar Sarma
With the use of RCU in files structure, the look-up of files using fds can now be lock-free. The lookup is protected by rcu_read_lock()/rcu_read_unlock(). This patch changes the readers to use lock-free lookup. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Ravikiran Thirumalai <kiran_th@gmail.com> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: break up files structDipankar Sarma
In order for the RCU to work, the file table array, sets and their sizes must be updated atomically. Instead of ensuring this through too many memory barriers, we put the arrays and their sizes in a separate structure. This patch takes the first step of putting the file table elements in a separate structure fdtable that is embedded withing files_struct. It also changes all the users to refer to the file table using files_fdtable() macro. Subsequent applciation of RCU becomes easier after this. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] remove the inode_post_link and inode_post_rename LSM hooksStephen Smalley
This patch removes the inode_post_link and inode_post_rename LSM hooks as they are unused (and likely useless). Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] Remove security_inode_post_create/mkdir/symlink/mknod hooksStephen Smalley
This patch removes the inode_post_create/mkdir/mknod/symlink LSM hooks as they are obsoleted by the new inode_init_security hook that enables atomic inode security labeling. If anyone sees any reason to retain these hooks, please speak now. Also, is anyone using the post_rename/link hooks; if not, those could also be removed. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] tmpfs: Enable atomic inode security labelingStephen Smalley
This patch modifies tmpfs to call the inode_init_security LSM hook to set up the incore inode security state for new inodes before the inode becomes accessible via the dcache. As there is no underlying storage of security xattrs in this case, it is not necessary for the hook to return the (name, value, len) triple to the tmpfs code, so this patch also modifies the SELinux hook function to correctly handle the case where the (name, value, len) pointers are NULL. The hook call is needed in tmpfs in order to support proper security labeling of tmpfs inodes (e.g. for udev with tmpfs /dev in Fedora). With this change in place, we should then be able to remove the security_inode_post_create/mkdir/... hooks safely. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] security: enable atomic inode security labelingStephen Smalley
The following patch set enables atomic security labeling of newly created inodes by altering the fs code to invoke a new LSM hook to obtain the security attribute to apply to a newly created inode and to set up the incore inode security state during the inode creation transaction. This parallels the existing processing for setting ACLs on newly created inodes. Otherwise, it is possible for new inodes to be accessed by another thread via the dcache prior to complete security setup (presently handled by the post_create/mkdir/... LSM hooks in the VFS) and a newly created inode may be left unlabeled on the disk in the event of a crash. SELinux presently works around the issue by ensuring that the incore inode security label is initialized to a special SID that is inaccessible to unprivileged processes (in accordance with policy), thereby preventing inappropriate access but potentially causing false denials on legitimate accesses. A simple test program demonstrates such false denials on SELinux, and the patch solves the problem. Similar such false denials have been encountered in real applications. This patch defines a new inode_init_security LSM hook to obtain the security attribute to apply to a newly created inode and to set up the incore inode security state for it, and adds a corresponding hook function implementation to SELinux. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Linus Torvalds
2005-09-05[PATCH] selinux: endian notationsAlexey Dobriyan
This patch adds endian notations to the SELinux code. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] selinux: Reduce memory use by avtabStephen Smalley
This patch improves memory use by SELinux by both reducing the avtab node size and reducing the number of avtab nodes. The memory savings are substantial, e.g. on a 64-bit system after boot, James Morris reported the following data for the targeted and strict policies: #objs objsize kernmem Targeted: Before: 237888 40 9.1MB After: 19968 24 468KB Strict: Before: 571680 40 21.81MB After: 221052 24 5.06MB The improvement in memory use comes at a cost in the speed of security server computations of access vectors, but these computations are only required on AVC cache misses, and performance measurements by James Morris using a number of benchmarks have shown that the change does not cause any significant degradation. Note that a rebuilt policy via an updated policy toolchain (libsepol/checkpolicy) is required in order to gain the full benefits of this patch, although some memory savings benefits are immediately applied even to older policies (in particular, the reduction in avtab node size). Sources for the updated toolchain are presently available from the sourceforge CVS tree (http://sourceforge.net/cvs/?group_id=21266), and tarballs are available from http://www.flux.utah.edu/~sds. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01[CRYPTO]: Use CRYPTO_TFM_REQ_MAY_SLEEP where appropriateHerbert Xu
This patch goes through the current users of the crypto layer and sets CRYPTO_TFM_REQ_MAY_SLEEP at crypto_alloc_tfm() where all crypto operations are performed in process context. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SELINUX]: Update for tcp_diag rename to inet_diag.James Morris
Also, support dccp sockets. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add "groups" argument to netlink_kernel_createPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
2005-08-29[NETLINK]: Fix missing dst_groups initializations in netlink_broadcast usersPatrick McHardy
netlink_broadcast users must initialize NETLINK_CB(skb).dst_groups to the destination group mask for netlink_recvmsg. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add properly module refcounting for kernel netlink sockets.Harald Welte
- Remove bogus code for compiling netlink as module - Add module refcounting support for modules implementing a netlink protocol - Add support for autoloading modules that implement a netlink protocol as soon as someone opens a socket for that protocol Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-22[PATCH] SECURITY must depend on SYSFSAdrian Bunk
CONFIG_SECURITY=y and CONFIG_SYSFS=n results in the following compile error: <-- snip --> ... LD vmlinux security/built-in.o: In function `securityfs_init': inode.c:(.init.text+0x1c2): undefined reference to `kernel_subsys' make: *** [vmlinux] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Chris Wright <chrisw@osdl.org>
2005-08-09Merge with /shiny/git/linux-2.6/.gitDavid Woodhouse
2005-08-04[PATCH] Destruction of failed keyring oopsesDavid Howells
The attached patch makes sure that a keyring that failed to instantiate properly is destroyed without oopsing [CAN-2005-2099]. The problem occurs in three stages: (1) The key allocator initialises the type-specific data to all zeroes. In the case of a keyring, this will become a link in the keyring name list when the keyring is instantiated. (2) If a user (any user) attempts to add a keyring with anything other than an empty payload, the keyring instantiation function will fail with an error and won't add the keyring to the name list. (3) The keyring's destructor then sees that the keyring has a description (name) and tries to remove the keyring from the name list, which oopses because the link pointers are both zero. This bug permits any user to take down a box trivially. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] Error during attempt to join key management session can leave ↵David Howells
semaphore pinned The attached patch prevents an error during the key session joining operation from hanging future joins in the D state [CAN-2005-2098]. The problem is that the error handling path for the KEYCTL_JOIN_SESSION_KEYRING operation has one error path that doesn't release the session management semaphore. Further attempts to get the semaphore will then sleep for ever in the D state. This can happen in four situations, all involving an attempt to allocate a new session keyring: (1) ENOMEM. (2) The users key quota being reached. (3) A keyring name that is an empty string. (4) A keyring name that is too long. Any user may attempt this operation, and so any user can cause the problem to occur. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] Keys: Fix key management syscall interface bugsDavid Howells
This fixes five bugs in the key management syscall interface: (1) add_key() returns 0 rather than EINVAL if the key type is "". Checking the key type isn't "" should be left to lookup_user_key(). (2) request_key() returns ENOKEY rather than EPERM if the key type begins with a ".". lookup_user_key() can't do this because internal key types begin with a ".". (3) Key revocation always returns 0, even if it fails. (4) Key read can return EAGAIN rather than EACCES under some circumstances. A key is permitted to by read by a process if it doesn't grant read access, but it does grant search access and it is in the process's keyrings. That search returns EAGAIN if it fails, and this needs translating to EACCES. (5) request_key() never adds the new key to the destination keyring if one is supplied. The wrong macro was being used to test for an error condition: PTR_ERR() will always return true, whether or not there's an error; this should've been IS_ERR(). Signed-Off-By: David Howells <dhowells@redhat.com> Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] selinux: Fix address length checks in connect hookStephen Smalley
This patch fixes the address length checks in the selinux_socket_connect hook to be no more restrictive than the underlying ipv4 and ipv6 code; otherwise, this hook can reject valid connect calls. This patch is in response to a bug report where an application was calling connect on an INET6 socket with an address that didn't include the optional scope id and failing due to these checks. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] SELinux: default labeling of MLS fieldJames Morris
Implement kernel labeling of the MLS (multilevel security) field of security contexts for files which have no existing MLS field. This is to enable upgrades of a system from non-MLS to MLS without performing a full filesystem relabel including all of the mountpoints, which would be quite painful for users. With this patch, with MLS enabled, if a file has no MLS field, the kernel internally adds an MLS field to the in-core inode (but not to the on-disk file). This MLS field added is the default for the superblock, allowing per-mountpoint control over the values via fixed policy or mount options. This patch has been tested by enabling MLS without relabeling its filesystem, and seems to be working correctly. Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Stephen Smalley <sds@epoch.ncsc.mil> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13Merge with /shiny/git/linux-2.6/.gitDavid Woodhouse
2005-07-08[PATCH] seclvl securityfsserue@us.ibm.com
Once again, the simple_attr in libfs was actually sufficient - I'd thought the __attribute__(format(printk(1,2))) was more mysterious than it really is. At last, here is the full patch to make seclvl use securityfs. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Chris Wright <chrisw@osdl.org> -- seclvl.c | 228 +++++++++++++++++++-------------------------------------------- 1 files changed, 70 insertions(+), 158 deletions(-) Index: linux-2.6.13-rc1/security/seclvl.c ===================================================================
2005-07-08[PATCH] add securityfs for all LSMs to useGreg KH
Here's a small patch against 2.6.13-rc2 that adds securityfs, a virtual fs that all LSMs can use instead of creating their own. The fs should be mounted at /sys/kernel/security, and the fs creates that mount point. This will make the LSB people happy that we aren't creating a new /my_lsm_fs directory in the root for every different LSM. It has changed a bit since the last version, thanks to comments from Mike Waychison. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@osdl.org>
2005-07-07[PATCH] Keys: Base keyring size on key pointer not key structDavid Howells
The attached patch makes the keyring functions calculate the new size of a keyring's payload based on the size of pointer to the key struct, not the size of the key struct itself. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-02Merge with master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
2005-06-30[PATCH] selinux_sb_copy_data() should not require a whole pageEric Paris
Currently selinux_sb_copy_data requires an entire page be allocated to *orig when the function is called. This "requirement" is based on the fact that we call copy_page(in_save, nosec_save) and in_save = orig when the data is not FS_BINARY_MOUNTDATA. This means that if a caller were to call do_kern_mount with only about 10 bytes of options, they would get passed here and then we would corrupt PAGE_SIZE - 10 bytes of memory (with all zeros.) Currently it appears all in kernel FS's use one page of data so this has not been a problem. An out of kernel FS did just what is described above and it would almost always panic shortly after they tried to mount. From looking else where in the kernel it is obvious that this string of data must always be null terminated. (See example in do_mount where it always zeros the last byte.) Thus I suggest we use strcpy in place of copy_page. In this way we make sure the amount we copy is always less than or equal to the amount we received and since do_mount is zeroing the last byte this should be safe for all. Signed-off-by: Eric Paris <eparis@parisplace.org> Cc: Stephen Smalley <sds@epoch.ncsc.mil> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] selinux: kfree cleanupJesper Juhl
kfree(NULL) is legal. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] RCU: clean up a few remaining synchronize_kernel() callsPaul E. McKenney
2.6.12-rc6-mm1 has a few remaining synchronize_kernel()s, some (but not all) in comments. This patch changes these synchronize_kernel() calls (and comments) to synchronize_rcu() or synchronize_sched() as follows: - arch/x86_64/kernel/mce.c mce_read(): change to synchronize_sched() to handle races with machine-check exceptions (synchronize_rcu() would not cut it given RCU implementations intended for hardcore realtime use. - drivers/input/serio/i8042.c i8042_stop(): change to synchronize_sched() to handle races with i8042_interrupt() interrupt handler. Again, synchronize_rcu() would not cut it given RCU implementations intended for hardcore realtime use. - include/*/kdebug.h comments: change to synchronize_sched() to handle races with NMIs. As before, synchronize_rcu() would not cut it... - include/linux/list.h comment: change to synchronize_rcu(), since this comment is for list_del_rcu(). - security/keys/key.c unregister_key_type(): change to synchronize_rcu(), since this is interacting with RCU read side. - security/keys/process_keys.c install_session_keyring(): change to synchronize_rcu(), since this is interacting with RCU read side. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] selinux: add executable heap checkLorenzo Hernández García-Hierro
This patch,based on sample code by Roland McGrath, adds an execheap permission check that controls the ability to make the heap executable so that this can be prevented in almost all cases (the X server is presently an exception, but this will hopefully be resolved in the future) so that even programs with execmem permission will need to have the anonymous memory mapped in order to make it executable. The only reason that we use a permission check for such restriction (vs. making it unconditional) is that the X module loader presently needs it; it could possibly be made unconditional in the future when X is changed. The policy patch for the execheap permission is available at: http://pearls.tuxedo-es.org/patches/selinux/policy-execheap.patch Signed-off-by: Lorenzo Hernandez Garcia-Hierro <lorenzo@gnu.org> Acked-by: James Morris <jmorris@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] selinux: add executable stack checkLorenzo Hernandez García-Hierro
This patch adds an execstack permission check that controls the ability to make the main process stack executable so that attempts to make the stack executable can still be prevented even if the process is allowed the existing execmem permission in order to e.g. perform runtime code generation. Note that this does not yet address thread stacks. Note also that unlike the execmem check, the execstack check is only applied on mprotect calls, not mmap calls, as the current security_file_mmap hook is not passed the necessary information presently. The original author of the code that makes the distinction of the stack region, is Ingo Molnar, who wrote it within his patch for /proc/<pid>/maps markers. (http://marc.theaimsgroup.com/?l=linux-kernel&m=110719881508591&w=2) The patches also can be found at: http://pearls.tuxedo-es.org/patches/selinux/policy-execstack.patch http://pearls.tuxedo-es.org/patches/selinux/kernel-execstack.patch policy-execstack.patch is the patch that needs to be applied to the policy in order to support the execstack permission and exclude it from general_domain_access within macros/core_macros.te. kernel-execstack.patch adds such permission to the SELinux code within the kernel and adds the proper permission check to the selinux_file_mprotect() hook. Signed-off-by: Lorenzo Hernandez Garcia-Hierro <lorenzo@gnu.org> Acked-by: James Morris <jmorris@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] eCryptfs: export user key typeMichael Halcrow
Export this symbol to GPL modules for eCryptfs: an out-of-tree GPL'ed filesystem. Signed off by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] Keys: Make request-key create an authorisation keyDavid Howells
The attached patch makes the following changes: (1) There's a new special key type called ".request_key_auth". This is an authorisation key for when one process requests a key and another process is started to construct it. This type of key cannot be created by the user; nor can it be requested by kernel services. Authorisation keys hold two references: (a) Each refers to a key being constructed. When the key being constructed is instantiated the authorisation key is revoked, rendering it of no further use. (b) The "authorising process". This is either: (i) the process that called request_key(), or: (ii) if the process that called request_key() itself had an authorisation key in its session keyring, then the authorising process referred to by that authorisation key will also be referred to by the new authorisation key. This means that the process that initiated a chain of key requests will authorise the lot of them, and will, by default, wind up with the keys obtained from them in its keyrings. (2) request_key() creates an authorisation key which is then passed to /sbin/request-key in as part of a new session keyring. (3) When request_key() is searching for a key to hand back to the caller, if it comes across an authorisation key in the session keyring of the calling process, it will also search the keyrings of the process specified therein and it will use the specified process's credentials (fsuid, fsgid, groups) to do that rather than the calling process's credentials. This allows a process started by /sbin/request-key to find keys belonging to the authorising process. (4) A key can be read, even if the process executing KEYCTL_READ doesn't have direct read or search permission if that key is contained within the keyrings of a process specified by an authorisation key found within the calling process's session keyring, and is searchable using the credentials of the authorising process. This allows a process started by /sbin/request-key to read keys belonging to the authorising process. (5) The magic KEY_SPEC_*_KEYRING key IDs when passed to KEYCTL_INSTANTIATE or KEYCTL_NEGATE will specify a keyring of the authorising process, rather than the process doing the instantiation. (6) One of the process keyrings can be nominated as the default to which request_key() should attach new keys if not otherwise specified. This is done with KEYCTL_SET_REQKEY_KEYRING and one of the KEY_REQKEY_DEFL_* constants. The current setting can also be read using this call. (7) request_key() is partially interruptible. If it is waiting for another process to finish constructing a key, it can be interrupted. This permits a request-key cycle to be broken without recourse to rebooting. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-Off-By: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] Keys: Use RCU to manage session keyring pointerDavid Howells
The attached patch uses RCU to manage the session keyring pointer in struct signal_struct. This means that searching need not disable interrupts and get a the sighand spinlock to access this pointer. Furthermore, by judicious use of rcu_read_(un)lock(), this patch also avoids the need to take and put refcounts on the session keyring itself, thus saving on even more atomic ops. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] Keys: Pass session keyring to call_usermodehelper()David Howells
The attached patch makes it possible to pass a session keyring through to the process spawned by call_usermodehelper(). This allows patch 3/3 to pass an authorisation key through to /sbin/request-key, thus permitting better access controls when doing just-in-time key creation. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] keys: Discard key spinlock and use RCU for key payloadDavid Howells
The attached patch changes the key implementation in a number of ways: (1) It removes the spinlock from the key structure. (2) The key flags are now accessed using atomic bitops instead of write-locking the key spinlock and using C bitwise operators. The three instantiation flags are dealt with with the construction semaphore held during the request_key/instantiate/negate sequence, thus rendering the spinlock superfluous. The key flags are also now bit numbers not bit masks. (3) The key payload is now accessed using RCU. This permits the recursive keyring search algorithm to be simplified greatly since no locks need be taken other than the usual RCU preemption disablement. Searching now does not require any locks or semaphores to be held; merely that the starting keyring be pinned. (4) The keyring payload now includes an RCU head so that it can be disposed of by call_rcu(). This requires that the payload be copied on unlink to prevent introducing races in copy-down vs search-up. (5) The user key payload is now a structure with the data following it. It includes an RCU head like the keyring payload and for the same reason. It also contains a data length because the data length in the key may be changed on another CPU whilst an RCU protected read is in progress on the payload. This would then see the supposed RCU payload and the on-key data length getting out of sync. I'm tempted to drop the key's datalen entirely, except that it's used in conjunction with quota management and so is a little tricky to get rid of. (6) Update the keys documentation. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] setuid core dumpAlan Cox
Add a new `suid_dumpable' sysctl: This value can be used to query and set the core dump mode for setuid or otherwise protected/tainted binaries. The modes are 0 - (default) - traditional behaviour. Any process which has changed privilege levels or is execute only will not be dumped 1 - (debug) - all processes dump core when possible. The core dump is owned by the current user and no security is applied. This is intended for system debugging situations only. Ptrace is unchecked. 2 - (suidsafe) - any binary which normally would not be dumped is dumped readable by root only. This allows the end user to remove such a dump but not access it directly. For security reasons core dumps in this mode will not overwrite one another or other files. This mode is appropriate when adminstrators are attempting to debug problems in a normal environment. (akpm: > > +EXPORT_SYMBOL(suid_dumpable); > > EXPORT_SYMBOL_GPL? No problem to me. > > if (current->euid == current->uid && current->egid == current->gid) > > current->mm->dumpable = 1; > > Should this be SUID_DUMP_USER? Actually the feedback I had from last time was that the SUID_ defines should go because its clearer to follow the numbers. They can go everywhere (and there are lots of places where dumpable is tested/used as a bool in untouched code) > Maybe this should be renamed to `dump_policy' or something. Doing that > would help us catch any code which isn't using the #defines, too. Fair comment. The patch was designed to be easy to maintain for Red Hat rather than for merging. Changing that field would create a gigantic diff because it is used all over the place. ) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22AUDIT: Wait for backlog to clear when generating messages.David Woodhouse
Add a gfp_mask to audit_log_start() and audit_log(), to reduce the amount of GFP_ATOMIC allocation -- most of it doesn't need to be GFP_ATOMIC. Also if the mask includes __GFP_WAIT, then wait up to 60 seconds for the auditd backlog to clear instead of immediately abandoning the message. The timeout should probably be made configurable, but for now it'll suffice that it only happens if auditd is actually running. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-06-21[PATCH] SELinux: memory leak in selinux_sb_copy_data()Gerald Schaefer
There is a memory leak during mount when SELinux is active and mount options are specified. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Acked-by: Stephen Smalley <sds@epoch.ncsc.mil> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] sysfs: (rest) if show/store is missing return -EIODmitry Torokhov
sysfs: fix the rest of the kernel so if an attribute doesn't implement show or store method read/write will return -EIO instead of 0 or -EINVAL or -EPERM. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-18[NETLINK]: Neighbour table configuration and statistics via rtnetlinkThomas Graf
To retrieve the neighbour tables send RTM_GETNEIGHTBL with the NLM_F_DUMP flag set. Every neighbour table configuration is spread over multiple messages to avoid running into message size limits on systems with many interfaces. The first message in the sequence transports all not device specific data such as statistics, configuration, and the default parameter set. This message is followed by 0..n messages carrying device specific parameter sets. Although the ordering should be sufficient, NDTA_NAME can be used to identify sequences. The initial message can be identified by checking for NDTA_CONFIG. The device specific messages do not contain this TLV but have NDTPA_IFINDEX set to the corresponding interface index. To change neighbour table attributes, send RTM_SETNEIGHTBL with NDTA_NAME set. Changeable attribute include NDTA_THRESH[1-3], NDTA_GC_INTERVAL, and all TLVs in NDTA_PARMS unless marked otherwise. Device specific parameter sets can be changed by setting NDTPA_IFINDEX to the interface index of the corresponding device. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-24AUDIT: Fix remaining cases of direct logging of untrusted strings by avc_auditStephen Smalley
Per Steve Grubb's observation that there are some remaining cases where avc_audit() directly logs untrusted strings without escaping them, here is a patch that changes avc_audit() to use audit_log_untrustedstring() or audit_log_hex() as appropriate. Note that d_name.name is nul- terminated by d_alloc(), and that sun_path is nul-terminated by unix_mkname(), so it is not necessary for the AVC to create nul- terminated copies or to alter audit_log_untrustedstring to take a length argument. In the case of an abstract name, we use audit_log_hex() with an explicit length. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-05-21Fix oops due to thinko in avc_audit()David Woodhouse
When I added the logging of pid= and comm= back to avc_audit() I screwed it up. Put it back how it should be. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
