[ Upstream commit 096fe9eaea40a17e125569f9e657e34cdb6d73bd ]
If a user key gets negatively instantiated, an error code is cached in the
payload area. A negatively instantiated key may be then be positively
instantiated by updating it with valid data. However, the ->update key
type method must be aware that the error code may be there.
The following may be used to trigger the bug in the user key type:
keyctl request2 user user "" @u
keyctl add user user "a" @u
which manifests itself as:
BUG: unable to handle kernel paging request at 00000000ffffff8a
IP: [<ffffffff810a376f>] __call_rcu.constprop.76+0x1f/0x280 kernel/rcu/tree.c:3046
PGD 7cc30067 PUD 0
Oops: 0002 [#1] SMP
Modules linked in:
CPU: 3 PID: 2644 Comm: a.out Not tainted 4.3.0+ #49
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff88003ddea700 ti: ffff88003dd88000 task.ti: ffff88003dd88000
RIP: 0010:[<ffffffff810a376f>] [<ffffffff810a376f>] __call_rcu.constprop.76+0x1f/0x280
RSP: 0018:ffff88003dd8bdb0 EFLAGS: 00010246
RAX: 00000000ffffff82 RBX: 0000000000000000 RCX: 0000000000000001
RDX: ffffffff81e3fe40 RSI: 0000000000000000 RDI: 00000000ffffff82
RBP: ffff88003dd8bde0 R08: ffff88007d2d2da0 R09: 0000000000000000
R10: 0000000000000000 R11: ffff88003e8073c0 R12: 00000000ffffff82
R13: ffff88003dd8be68 R14: ffff88007d027600 R15: ffff88003ddea700
FS: 0000000000b92880(0063) GS:ffff88007fd00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000ffffff8a CR3: 000000007cc5f000 CR4: 00000000000006e0
Stack:
ffff88003dd8bdf0 ffffffff81160a8a 0000000000000000 00000000ffffff82
ffff88003dd8be68 ffff88007d027600 ffff88003dd8bdf0 ffffffff810a39e5
ffff88003dd8be20 ffffffff812a31ab ffff88007d027600 ffff88007d027620
Call Trace:
[<ffffffff810a39e5>] kfree_call_rcu+0x15/0x20 kernel/rcu/tree.c:3136
[<ffffffff812a31ab>] user_update+0x8b/0xb0 security/keys/user_defined.c:129
[< inline >] __key_update security/keys/key.c:730
[<ffffffff8129e5c1>] key_create_or_update+0x291/0x440 security/keys/key.c:908
[< inline >] SYSC_add_key security/keys/keyctl.c:125
[<ffffffff8129fc21>] SyS_add_key+0x101/0x1e0 security/keys/keyctl.c:60
[<ffffffff8185f617>] entry_SYSCALL_64_fastpath+0x12/0x6a arch/x86/entry/entry_64.S:185
Note the error code (-ENOKEY) in EDX.
A similar bug can be tripped by:
keyctl request2 trusted user "" @u
keyctl add trusted user "a" @u
This should also affect encrypted keys - but that has to be correctly
parameterised or it will fail with EINVAL before getting to the bit that
will crashes.
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
[ Upstream commit 3dfb7d8cdbc7ea0c2970450e60818bb3eefbad69 ]
It looks like smack and yama weren't aware that the ptrace mode
can have flags ORed into it - PTRACE_MODE_NOAUDIT until now, but
only for /proc/$pid/stat, and with the PTRACE_MODE_*CREDS patch,
all modes have flags ORed into them.
Signed-off-by: Jann Horn <jann@thejh.net>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Willy Tarreau <w@1wt.eu>
[ Upstream commit caaee6234d05a58c5b4d05e7bf766131b810a657 ]
By checking the effective credentials instead of the real UID / permitted
capabilities, ensure that the calling process actually intended to use its
credentials.
To ensure that all ptrace checks use the correct caller credentials (e.g.
in case out-of-tree code or newly added code omits the PTRACE_MODE_*CREDS
flag), use two new flags and require one of them to be set.
The problem was that when a privileged task had temporarily dropped its
privileges, e.g. by calling setreuid(0, user_uid), with the intent to
perform following syscalls with the credentials of a user, it still passed
ptrace access checks that the user would not be able to pass.
While an attacker should not be able to convince the privileged task to
perform a ptrace() syscall, this is a problem because the ptrace access
check is reused for things in procfs.
In particular, the following somewhat interesting procfs entries only rely
on ptrace access checks:
/proc/$pid/stat - uses the check for determining whether pointers
should be visible, useful for bypassing ASLR
/proc/$pid/maps - also useful for bypassing ASLR
/proc/$pid/cwd - useful for gaining access to restricted
directories that contain files with lax permissions, e.g. in
this scenario:
lrwxrwxrwx root root /proc/13020/cwd -> /root/foobar
drwx------ root root /root
drwxr-xr-x root root /root/foobar
-rw-r--r-- root root /root/foobar/secret
Therefore, on a system where a root-owned mode 6755 binary changes its
effective credentials as described and then dumps a user-specified file,
this could be used by an attacker to reveal the memory layout of root's
processes or reveal the contents of files he is not allowed to access
(through /proc/$pid/cwd).
[akpm@linux-foundation.org: fix warning]
Cc: Casey Schaufler <casey@schaufler-ca.com>
[ Upstream commit 613317bd212c585c20796c10afe5daaa95d4b0a1 ]
This patch fixes vulnerability CVE-2016-2085. The problem exists
because the vm_verify_hmac() function includes a use of memcmp().
Unfortunately, this allows timing side channel attacks; specifically
a MAC forgery complexity drop from 2^128 to 2^12. This patch changes
the memcmp() to the cryptographically safe crypto_memneq().
Reported-by: Xiaofei Rex Guo <xiaofei.rex.guo@intel.com>
Signed-off-by: Ryan Ware <ware@linux.intel.com>
Cc: stable@vger.kernel.org
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 23567fd052a9abb6d67fe8e7a9ccdd9800a540f2 upstream.
This fixes CVE-2016-0728.
If a thread is asked to join as a session keyring the keyring that's already
set as its session, we leak a keyring reference.
This can be tested with the following program:
#include <stddef.h>
#include <stdio.h>
#include <sys/types.h>
#include <keyutils.h>
int main(int argc, const char *argv[])
int i = 0;
key_serial_t serial;
serial = keyctl(KEYCTL_JOIN_SESSION_KEYRING,
"leaked-keyring");
if (serial < 0) {
perror("keyctl");
return -1;
if (keyctl(KEYCTL_SETPERM, serial,
KEY_POS_ALL | KEY_USR_ALL) < 0) {
perror("keyctl");
return -1;
for (i = 0; i < 100; i++) {
"leaked-keyring");
if (serial < 0) {
perror("keyctl");
return -1;
return 0;
If, after the program has run, there something like the following line in
/proc/keys:
3f3d898f I--Q--- 100 perm 3f3f0000 0 0 keyring leaked-keyring: empty
with a usage count of 100 * the number of times the program has been run,
then the kernel is malfunctioning. If leaked-keyring has zero usages or
has been garbage collected, then the problem is fixed.
Reported-by: Yevgeny Pats <yevgeny@perception-point.io>
Acked-by: Don Zickus <dzickus@redhat.com>
Acked-by: Prarit Bhargava <prarit@redhat.com>
Acked-by: Jarod Wilson <jarod@redhat.com>
commit b4a1b4f5047e4f54e194681125c74c0aa64d637d upstream.
This fixes CVE-2015-7550.
There's a race between keyctl_read() and keyctl_revoke(). If the revoke
happens between keyctl_read() checking the validity of a key and the key's
semaphore being taken, then the key type read method will see a revoked key.
This causes a problem for the user-defined key type because it assumes in
its read method that there will always be a payload in a non-revoked key
and doesn't check for a NULL pointer.
Fix this by making keyctl_read() check the validity of a key after taking
semaphore instead of before.
I think the bug was introduced with the original keyrings code.
This was discovered by a multithreaded test program generated by syzkaller
(http://github.com/google/syzkaller). Here's a cleaned up version:
#include <pthread.h>
void *thr0(void *arg)
key_serial_t key = (unsigned long)arg;
keyctl_revoke(key);
return 0;
void *thr1(void *arg)
char buffer[16];
keyctl_read(key, buffer, 16);
return 0;
int main()
key_serial_t key = add_key("user", "%", "foo", 3, KEY_SPEC_USER_KEYRING);
pthread_t th[5];
pthread_create(&th[0], 0, thr0, (void *)(unsigned long)key);
pthread_create(&th[1], 0, thr1, (void *)(unsigned long)key);
pthread_create(&th[2], 0, thr0, (void *)(unsigned long)key);
pthread_create(&th[3], 0, thr1, (void *)(unsigned long)key);
pthread_join(th[0], 0);
pthread_join(th[1], 0);
pthread_join(th[2], 0);
pthread_join(th[3], 0);
return 0;
Build as:
cc -o keyctl-race keyctl-race.c -lkeyutils -lpthread
Run as:
while keyctl-race; do :; done
as it may need several iterations to crash the kernel. The crash can be
summarised as:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: [<ffffffff81279b08>] user_read+0x56/0xa3
Call Trace:
[<ffffffff81276aa9>] keyctl_read_key+0xb6/0xd7
[<ffffffff81277815>] SyS_keyctl+0x83/0xe0
[<ffffffff815dbb97>] entry_SYSCALL_64_fastpath+0x12/0x6f
Tested-by: Dmitry Vyukov <dvyukov@google.com>
commit f05819df10d7b09f6d1eb6f8534a8f68e5a4fe61 upstream.
The following sequence of commands:
i=`keyctl add user a a @s`
keyctl request2 keyring foo bar @t
keyctl unlink $i @s
tries to invoke an upcall to instantiate a keyring if one doesn't already
exist by that name within the user's keyring set. However, if the upcall
fails, the code sets keyring->type_data.reject_error to -ENOKEY or some
other error code. When the key is garbage collected, the key destroy
function is called unconditionally and keyring_destroy() uses list_empty()
on keyring->type_data.link - which is in a union with reject_error.
Subsequently, the kernel tries to unlink the keyring from the keyring names
list - which oopses like this:
IP: [<ffffffff8126e051>] keyring_destroy+0x3d/0x88
Workqueue: events key_garbage_collector
RIP: 0010:[<ffffffff8126e051>] keyring_destroy+0x3d/0x88
RSP: 0018:ffff88003e2f3d30 EFLAGS: 00010203
RAX: 00000000ffffff82 RBX: ffff88003bf1a900 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 000000003bfc6901 RDI: ffffffff81a73a40
RBP: ffff88003e2f3d38 R08: 0000000000000152 R09: 0000000000000000
R10: ffff88003e2f3c18 R11: 000000000000865b R12: ffff88003bf1a900
R13: 0000000000000000 R14: ffff88003bf1a908 R15: ffff88003e2f4000
CR2: 00000000ffffff8a CR3: 000000003e3ec000 CR4: 00000000000006f0
Call Trace:
[<ffffffff8126c756>] key_gc_unused_keys.constprop.1+0x5d/0x10f
[<ffffffff8126ca71>] key_garbage_collector+0x1fa/0x351
[<ffffffff8105ec9b>] process_one_work+0x28e/0x547
[<ffffffff8105fd17>] worker_thread+0x26e/0x361
[<ffffffff8105faa9>] ? rescuer_thread+0x2a8/0x2a8
[<ffffffff810648ad>] kthread+0xf3/0xfb
[<ffffffff810647ba>] ? kthread_create_on_node+0x1c2/0x1c2
[<ffffffff815f2ccf>] ret_from_fork+0x3f/0x70
Note the value in RAX. This is a 32-bit representation of -ENOKEY.
The solution is to only call ->destroy() if the key was successfully
instantiated.
commit 94c4554ba07adbdde396748ee7ae01e86cf2d8d7 upstream.
There appears to be a race between:
(1) key_gc_unused_keys() which frees key->security and then calls
keyring_destroy() to unlink the name from the name list
(2) find_keyring_by_name() which calls key_permission(), thus accessing
key->security, on a key before checking to see whether the key usage is 0
(ie. the key is dead and might be cleaned up).
Fix this by calling ->destroy() before cleaning up the core key data -
including key->security.
Reported-by: Petr Matousek <pmatouse@redhat.com>
commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream.
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
commit 892e8cac99a71f6254f84fc662068d912e1943bf upstream.
commit 66fc13039422ba7df2d01a8ee0873e4ef965b50b ("mm: shmem_zero_setup
skip security check and lockdep conflict with XFS") caused a regression
for SELinux by disabling any SELinux checking of mprotect PROT_EXEC on
shared anonymous mappings. However, even before that regression, the
checking on such mprotect PROT_EXEC calls was inconsistent with the
checking on a mmap PROT_EXEC call for a shared anonymous mapping. On a
mmap, the security hook is passed a NULL file and knows it is dealing
with an anonymous mapping and therefore applies an execmem check and no
file checks. On a mprotect, the security hook is passed a vma with a
non-NULL vm_file (as this was set from the internally-created shmem
file during mmap) and therefore applies the file-based execute check
and no execmem check. Since the aforementioned commit now marks the
shmem zero inode with the S_PRIVATE flag, the file checks are disabled
and we have no checking at all on mprotect PROT_EXEC. Add a test to
the mprotect hook logic for such private inodes, and apply an execmem
check in that case. This makes the mmap and mprotect checking
consistent for shared anonymous mappings, as well as for /dev/zero and
ashmem.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit 3324603524925c7727207027d1c15e597412d15e upstream.
At present we don't create efficient ebitmaps when importing NetLabel
category bitmaps. This can present a problem when comparing ebitmaps
since ebitmap_cmp() is very strict about these things and considers
these wasteful ebitmaps not equal when compared to their more
efficient counterparts, even if their values are the same. This isn't
likely to cause problems on 64-bit systems due to a bit of luck on
how NetLabel/CIPSO works and the default ebitmap size, but it can be
a problem on 32-bit systems.
This patch fixes this problem by being a bit more intelligent when
importing NetLabel category bitmaps by skipping over empty sections
which should result in a nice, efficient ebitmap.
commit 24fd03c87695a76f0517df42a37e51b1597d2c8a upstream.
This patch defines a builtin measurement policy "tcb", similar to the
existing "ima_tcb", but with additional rules to also measure files
based on the effective uid and to measure files opened with the "read"
mode bit set (eg. read, read-write).
Changing the builtin "ima_tcb" policy could potentially break existing
users. Instead of defining a new separate boot command line option each
time the builtin measurement policy is modified, this patch defines a
single generic boot command line option "ima_policy=" to specify the
builtin policy and deprecates the use of the builtin ima_tcb policy.
[The "ima_policy=" boot command line option is based on Roberto Sassu's
"ima: added new policy type exec" patch.]
Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org>
commit 4351c294b8c1028077280f761e158d167b592974 upstream.
The current "mask" policy option matches files opened as MAY_READ,
MAY_WRITE, MAY_APPEND or MAY_EXEC. This patch extends the "mask"
option to match files opened containing one of these modes. For
example, "mask=^MAY_READ" would match files opened read-write.
commit 139069eff7388407f19794384c42a534d618ccd7 upstream.
The new "euid" policy condition measures files with the specified
effective uid (euid). In addition, for CAP_SETUID files it measures
files with the specified uid or suid.
Changelog:
- fixed checkpatch.pl warnings
- fixed avc denied {setuid} messages - based on Roberto's feedback
commit 45b26133b97871896b8c5241d59f4ff7839db7b2 upstream.
This patch fixes a bug introduced in "4d7aeee ima: define new template
ima-ng and template fields d-ng and n-ng".
Changelog:
- change int to uint32 (Roberto Sassu's suggestion)
Signed-off-by: Roberto Sassu <rsassu@suse.de>
commit 5101a1850bb7ccbf107929dee9af0cd2f400940f upstream.
To prevent offline stripping of existing file xattrs and relabeling of
them at runtime, EVM allows only newly created files to be labeled. As
pseudo filesystems are not persistent, stripping of xattrs is not a
concern.
Some LSMs defer file labeling on pseudo filesystems. This patch
permits the labeling of existing files on pseudo files systems.
commit cd025f7f94108995383edddfb61fc8afea6c66a9 upstream.
Include don't appraise or measure rules for the NSFS filesystem
in the builtin ima_tcb and ima_appraise_tcb policies.
Changelog:
- Update documentation
commit 5577857f8e26e9027271f10daf96361640907300 upstream.
It's a bit easier to read this if we split it up into two for loops.
commit 6438de9f3fb5180d78a0422695d0b88c687757d3 upstream.
This patch adds a rule in the default measurement policy to skip inodes
in the cgroupfs filesystem. Measurements for this filesystem can be
avoided, as all the digests collected have the same value of the digest of
an empty file.
Furthermore, this patch updates the documentation of IMA policies in
Documentation/ABI/testing/ima_policy to make it consistent with
the policies set in security/integrity/ima/ima_policy.c.
commit ca4da5dd1f99fe9c59f1709fb43e818b18ad20e0 upstream.
__key_link_end is not freeing the associated array edit structure
and this leads to a 512 byte memory leak each time an identical
existing key is added with add_key().
The reason the add_key() system call returns okay is that
key_create_or_update() calls __key_link_begin() before checking to see
whether it can update a key directly rather than adding/replacing - which
it turns out it can. Thus __key_link() is not called through
__key_instantiate_and_link() and __key_link_end() must cancel the edit.
CVE-2015-1333
commit f9bb48825a6b5d02f4cabcc78967c75db903dcdc upstream.
This allows for better documentation in the code and
it allows for a simpler and fully correct version of
fs_fully_visible to be written.
The mount points converted and their filesystems are:
/sys/hypervisor/s390/ s390_hypfs
/sys/kernel/config/ configfs
/sys/kernel/debug/ debugfs
/sys/firmware/efi/efivars/ efivarfs
/sys/fs/fuse/connections/ fusectl
/sys/fs/pstore/ pstore
/sys/kernel/tracing/ tracefs
/sys/fs/cgroup/ cgroup
/sys/kernel/security/ securityfs
/sys/fs/selinux/ selinuxfs
/sys/fs/smackfs/ smackfs
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 9fc2b4b436cff7d8403034676014f1be9d534942 upstream.
Before calling into the filesystem, vfs_setxattr calls
security_inode_setxattr, which ends up calling selinux_inode_setxattr in
our case. That returns -EOPNOTSUPP whenever SBLABEL_MNT is not set.
SBLABEL_MNT was supposed to be set by sb_finish_set_opts, which sets it
only if selinux_is_sblabel_mnt returns true.
The selinux_is_sblabel_mnt logic was broken by eadcabc697e9 "SELinux: do
all flags twiddling in one place", which didn't take into the account
the SECURITY_FS_USE_NATIVE behavior that had been introduced for nfs
with eb9ae686507b "SELinux: Add new labeling type native labels".
This caused setxattr's of security labels over NFSv4.2 to fail.
Cc: Eric Paris <eparis@redhat.com>
Cc: David Quigley <dpquigl@davequigley.com>
Reported-by: Richard Chan <rc556677@outlook.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
[PM: added the stable dependency]
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
The mm->exe_file is currently serialized with mmap_sem (shared) in order
to both safely (1) read the file and (2) compute the realpath by calling
tomoyo_realpath_from_path, making it an absolute overkill. Good users
will, on the other hand, make use of the more standard get_mm_exe_file(),
requiring only holding the mmap_sem to read the value, and relying on
reference
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Merge second patchbomb from Andrew Morton:
- the rest of MM
- various misc bits
- add ability to run /sbin/reboot at reboot time
- printk/vsprintf changes
- fiddle with seq_printf() return value
* akpm: (114 commits)
parisc: remove use of seq_printf return value
lru_cache: remove use of seq_printf return value
tracing: remove use of seq_printf return value
cgroup: remove use of seq_printf return value
proc: remove use of seq_printf return value
s390: remove use of seq_printf return value
cris fasttimer: remove use of seq_printf return value
cris: remove use of seq_printf return value
openrisc: remove use of seq_printf return value
ARM: plat-pxa: remove use of seq_printf return value
nios2: cpuinfo: remove use of seq_printf return value
microblaze: mb: remove use of seq_printf return value
ipc: remove use of seq_printf return value
rtc: remove use of seq_printf return value
power: wakeup: remove use of seq_printf return value
x86: mtrr: if: remove use of seq_printf return value
linux/bitmap.h: improve BITMAP_{LAST,FIRST}_WORD_MASK
MAINTAINERS: CREDITS: remove Stefano Brivio from B43
.mailmap: add Ricardo Ribalda
CREDITS: add Ricardo Ribalda Delgado
There are a lot of embedded systems that run most or all of their
functionality in init, running as root:root. For these systems,
supporting multiple users is not necessary.
This patch adds a new symbol, CONFIG_MULTIUSER, that makes support for
non-root users, non-root groups, and capabilities optional. It is enabled
under CONFIG_EXPERT menu.
When this symbol is not defined, UID and GID are zero in any possible case
and processes always have all capabilities.
The following syscalls are compiled out: setuid, setregid, setgid,
setreuid, setresuid, getresuid, setresgid, getresgid, setgroups,
getgroups, setfsuid, setfsgid, capget, capset.
Also, groups.c is compiled out completely.
In kernel/capability.c, capable function was moved in order to avoid
adding two ifdef blocks.
This change saves about 25 KB on a defconfig build. The most minimal
kernels have total text sizes in the high hundreds of kB rather than
low MB. (The 25k goes down a bit with allnoconfig, but not that much.
The kernel was booted in Qemu. All the common functionalities work.
Adding users/groups is not possible, failing with -ENOSYS.
Bloat-o-meter output:
add/remove: 7/87 grow/shrink: 19/397 up/down: 1675/-26325 (-24650)
Signed-off-by: Iulia Manda <iulia.manda21@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
... except where that code acts as a filesystem driver, rather than
working with dentries given to it.
most of the ->d_inode uses there refer to the same inode IO would
go to, i.e. d_backing_inode()
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights for this window:
- improved AVC hashing for SELinux by John Brooks and Stephen Smalley
- addition of an unconfined label to Smack
- Smack documentation update
- TPM driver updates"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (28 commits)
lsm: copy comm before calling audit_log to avoid race in string printing
tomoyo: Do not generate empty policy files
tomoyo: Use if_changed when generating builtin-policy.h
tomoyo: Use bin2c to generate builtin-policy.h
selinux: increase avtab max buckets
selinux: Use a better hash function for avtab
selinux: convert avtab hash table to flex_array
selinux: reconcile security_netlbl_secattr_to_sid() and mls_import_netlbl_cat()
selinux: remove unnecessary pointer reassignment
Smack: Updates for Smack documentation
tpm/st33zp24/spi: Add missing device table for spi phy.
tpm/st33zp24: Add proper wait for ordinal duration in case of irq mode
smack: Fix gcc warning from unused smack_syslog_lock mutex in smackfs.c
Smack: Allow an unconfined label in bringup mode
Smack: getting the Smack security context of keys
Smack: Assign smack_known_web as default smk_in label for kernel thread's socket
tpm/tpm_infineon: Use struct dev_pm_ops for power management
MAINTAINERS: Add Jason as designated reviewer for TPM
tpm: Update KConfig text to include TPM2.0 FIFO chips
tpm/st33zp24/dts/st33zp24-spi: Add dts documentation for st33zp24 spi phy
Pull networking updates from David Miller:
1) Add BQL support to via-rhine, from Tino Reichardt.
2) Integrate SWITCHDEV layer support into the DSA layer, so DSA drivers
can support hw switch offloading. From Floria Fainelli.
3) Allow 'ip address' commands to initiate multicast group join/leave,
from Madhu Challa.
4) Many ipv4 FIB lookup optimizations from Alexander Duyck.
5) Support EBPF in cls_bpf classifier and act_bpf action, from Daniel
Borkmann.
6) Remove the ugly compat support in ARP for ugly layers like ax25,
rose, etc. And use this to clean up the neigh layer, then use it to
implement MPLS support. All from Eric Biederman.
7) Support L3 forwarding offloading in switches, from Scott Feldman.
8) Collapse the LOCAL and MAIN ipv4 FIB tables when possible, to speed
up route lookups even further. From Alexander Duyck.
9) Many improvements and bug fixes to the rhashtable implementation,
from Herbert Xu and Thomas Graf. In particular, in the case where
an rhashtable user bulk adds a large number of items into an empty
table, we expand the table much more sanely.
10) Don't make the tcp_metrics hash table per-namespace, from Eric
Biederman.
11) Extend EBPF to access SKB fields, from Alexei Starovoitov.
12) Split out new connection request sockets so that they can be
established in the main hash table. Much less false sharing since
hash lookups go direct to the request sockets instead of having to
go first to the listener then to the request socks hashed
underneath. From Eric Dumazet.
13) Add async I/O support for crytpo AF_ALG sockets, from Tadeusz Struk.
14) Support stable privacy address generation for RFC7217 in IPV6. From
Hannes Frederic Sowa.
15) Hash network namespace into IP frag IDs, also from Hannes Frederic
Sowa.
16) Convert PTP get/set methods to use 64-bit time, from Richard
Cochran.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1816 commits)
fm10k: Bump driver version to 0.15.2
fm10k: corrected VF multicast update
fm10k: mbx_update_max_size does not drop all oversized messages
fm10k: reset head instead of calling update_max_size
fm10k: renamed mbx_tx_dropped to mbx_tx_oversized
fm10k: update xcast mode before synchronizing multicast addresses
fm10k: start service timer on probe
fm10k: fix function header comment
fm10k: comment next_vf_mbx flow
fm10k: don't handle mailbox events in iov_event path and always process mailbox
fm10k: use separate workqueue for fm10k driver
fm10k: Set PF queues to unlimited bandwidth during virtualization
fm10k: expose tx_timeout_count as an ethtool stat
fm10k: only increment tx_timeout_count in Tx hang path
fm10k: remove extraneous "Reset interface" message
fm10k: separate PF only stats so that VF does not display them
fm10k: use hw->mac.max_queues for stats
fm10k: only show actual queues, not the maximum in hardware
fm10k: allow creation of VLAN on default vid
fm10k: fix unused warnings
When task->comm is passed directly to audit_log_untrustedstring() without
getting a copy or using the task_lock, there is a race that could happen that
would output a NULL (\0) in the middle of the output string that would
effectively truncate the rest of the report text after the comm= field in the
audit log message, losing fields.
Using get_task_comm() to get a copy while acquiring the task_lock to prevent
this and to prevent the result from being a mixture of old and new values of
comm would incur potentially unacceptable overhead, considering that the value
can be influenced by userspace and therefore untrusted anyways.
Copy the value before passing it to audit_log_untrustedstring() ensures that a
local copy is used to calculate the length *and* subsequently printed. Even if
this value contains a mix of old and new values, it will only calculate and
copy up to the first NULL, preventing the rest of the audit log message being
truncated.
Use a second local copy of comm to avoid a race between the first and second
calls to audit_log_untrustedstring() with comm.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Pull vfs update from Al Viro:
"Part one:
- struct filename-related cleanups
- saner iov_iter_init() replacements (and switching the syscalls to
use of those)
- ntfs switch to ->write_iter() (Anton)
- aio cleanups and splitting iocb into common and async parts
(Christoph)
- assorted fixes (me, bfields, Andrew Elble)
There's a lot more, including the completion of switchover to
->{read,write}_iter(), d_inode/d_backing_inode annotations, f_flags
race fixes, etc, but that goes after #for-davem merge. David has
pulled it, and once it's in I'll send the next vfs pull request"
* 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (35 commits)
sg_start_req(): use import_iovec()
sg_start_req(): make sure that there's not too many elements in iovec
blk_rq_map_user(): use import_single_range()
sg_io(): use import_iovec()
process_vm_access: switch to {compat_,}import_iovec()
switch keyctl_instantiate_key_common() to iov_iter
switch {compat_,}do_readv_writev() to {compat_,}import_iovec()
aio_setup_vectored_rw(): switch to {compat_,}import_iovec()
vmsplice_to_user(): switch to import_iovec()
kill aio_setup_single_vector()
aio: simplify arguments of aio_setup_..._rw()
aio: lift iov_iter_init() into aio_setup_..._rw()
lift iov_iter into {compat_,}do_readv_writev()
NFS: fix BUG() crash in notify_change() with patch to chown_common()
dcache: return -ESTALE not -EBUSY on distributed fs race
NTFS: Version 2.1.32 - Update file write from aio_write to write_iter.
VFS: Add iov_iter_fault_in_multipages_readable()
drop bogus check in file_open_root()
switch security_inode_getattr() to struct path *
constify tomoyo_realpath_from_path()
When a new rtnl or xfrm command is added, this part of the code is frequently
missing. Let's help the developer with a build time test.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild into next
This command is missing.
Fixes: 3a2dfbe8acb1 ("xfrm: Notify changes in UDP encapsulation via netlink")
CC: Martin Willi <martin@strongswan.org>
Reported-by: Stephen Smalley <sds@tycho.nsa.gov>
Fixes: 5c79de6e79cd ("[XFRM]: User interface for handling XFRM_MSG_MIGRATE")
Fixes: 97a64b4577ae ("[XFRM]: Introduce XFRM_MSG_REPORT.")
These commands are missing.
Fixes: 28d8909bc790 ("[XFRM]: Export SAD info.")
Fixes: ecfd6b183780 ("[XFRM]: Export SPD info")
This new command is missing.
Fixes: 880a6fab8f6b ("xfrm: configure policy hash table thresholds by netlink")
Reported-by: Christophe Gouault <christophe.gouault@6wind.com>
Fixes: 9a9634545c70 ("netns: notify netns id events")
These new commands are missing.
Fixes: 0c7aecd4bde4 ("netns: add rtnl cmd to add and get peer netns ids")
The Makefile automatically generates the tomoyo policy files, which are
not removed by make clean (because they could have been provided by the
user). Instead of generating the missing files, use /dev/null if a
given file is not provided. Store the default exception_policy in
exception_policy.conf.default.
Combine the generation of builtin-policy.h into a single command and use
if_changed, so that the file is regenerated each time the command
changes. The next patch will make use of this.
Simplify the Makefile by using a readily available tool instead of a
custom sed script. The downside is that builtin-policy.h becomes
unreadable for humans, but it is only a generated file.
Now that we can safely increase the avtab max buckets without
triggering high order allocations and have a hash function that
will make better use of the larger number of buckets, increase
the max buckets to 2^16.
Original:
101421 entries and 2048/2048 buckets used, longest chain length 374
With new hash function:
101421 entries and 2048/2048 buckets used, longest chain length 81
With increased max buckets:
101421 entries and 31078/32768 buckets used, longest chain length 12
