path: root/security
2010-07-05KEYS: find_keyring_by_name() can gain access to a freed keyringToshiyuki Okajima
commit cea7daa3589d6b550546a8c8963599f7c1a3ae5c upstream. find_keyring_by_name() can gain access to a keyring that has had its reference count reduced to zero, and is thus ready to be freed. This then allows the dead keyring to be brought back into use whilst it is being destroyed. The following timeline illustrates the process: |(cleaner) (user) | | free_user(user) sys_keyctl() | | | | key_put(user->session_keyring) keyctl_get_keyring_ID() | || //=> keyring->usage = 0 | | |schedule_work(&key_cleanup_task) lookup_user_key() | || | | kmem_cache_free(,user) | | . |[KEY_SPEC_USER_KEYRING] | . install_user_keyrings() | . || | key_cleanup() [<= worker_thread()] || | | || | [spin_lock(&key_serial_lock)] |[mutex_lock(&key_user_keyr..mutex)] | | || | atomic_read() == 0 || | |{ rb_ease(&key->serial_node,) } || | | || | [spin_unlock(&key_serial_lock)] |find_keyring_by_name() | | ||| | keyring_destroy(keyring) ||[read_lock(&keyring_name_lock)] | || ||| | |[write_lock(&keyring_name_lock)] ||atomic_inc(&keyring->usage) | |. ||| *** GET freeing keyring *** | |. ||[read_unlock(&keyring_name_lock)] | || || | |list_del() |[mutex_unlock(&key_user_k..mutex)] | || | | |[write_unlock(&keyring_name_lock)] ** INVALID keyring is returned ** | | . | kmem_cache_free(,keyring) . | . | atomic_dec(&keyring->usage) v *** DESTROYED *** TIME If CONFIG_SLUB_DEBUG=y then we may see the following message generated: ============================================================================= BUG key_jar: Poison overwritten ----------------------------------------------------------------------------- INFO: 0xffff880197a7e200-0xffff880197a7e200. First byte 0x6a instead of 0x6b INFO: Allocated in key_alloc+0x10b/0x35f age=25 cpu=1 pid=5086 INFO: Freed in key_cleanup+0xd0/0xd5 age=12 cpu=1 pid=10 INFO: Slab 0xffffea000592cb90 objects=16 used=2 fp=0xffff880197a7e200 flags=0x200000000000c3 INFO: Object 0xffff880197a7e200 @offset=512 fp=0xffff880197a7e300 Bytes b4 0xffff880197a7e1f0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ Object 0xffff880197a7e200: 6a 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b jkkkkkkkkkkkkkkk Alternatively, we may see a system panic happen, such as: BUG: unable to handle kernel NULL pointer dereference at 0000000000000001 IP: [<ffffffff810e61a3>] kmem_cache_alloc+0x5b/0xe9 PGD 6b2b4067 PUD 6a80d067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/kernel/kexec_crash_loaded CPU 1 ... Pid: 31245, comm: su Not tainted 2.6.34-rc5-nofixed-nodebug #2 D2089/PRIMERGY RIP: 0010:[<ffffffff810e61a3>] [<ffffffff810e61a3>] kmem_cache_alloc+0x5b/0xe9 RSP: 0018:ffff88006af3bd98 EFLAGS: 00010002 RAX: 0000000000000000 RBX: 0000000000000001 RCX: ffff88007d19900b RDX: 0000000100000000 RSI: 00000000000080d0 RDI: ffffffff81828430 RBP: ffffffff81828430 R08: ffff88000a293750 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000100000 R12: 00000000000080d0 R13: 00000000000080d0 R14: 0000000000000296 R15: ffffffff810f20ce FS: 00007f97116bc700(0000) GS:ffff88000a280000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000001 CR3: 000000006a91c000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process su (pid: 31245, threadinfo ffff88006af3a000, task ffff8800374414c0) Stack: 0000000512e0958e 0000000000008000 ffff880037f8d180 0000000000000001 0000000000000000 0000000000008001 ffff88007d199000 ffffffff810f20ce 0000000000008000 ffff88006af3be48 0000000000000024 ffffffff810face3 Call Trace: [<ffffffff810f20ce>] ? get_empty_filp+0x70/0x12f [<ffffffff810face3>] ? do_filp_open+0x145/0x590 [<ffffffff810ce208>] ? tlb_finish_mmu+0x2a/0x33 [<ffffffff810ce43c>] ? unmap_region+0xd3/0xe2 [<ffffffff810e4393>] ? virt_to_head_page+0x9/0x2d [<ffffffff81103916>] ? alloc_fd+0x69/0x10e [<ffffffff810ef4ed>] ? do_sys_open+0x56/0xfc [<ffffffff81008a02>] ? system_call_fastpath+0x16/0x1b Code: 0f 1f 44 00 00 49 89 c6 fa 66 0f 1f 44 00 00 65 4c 8b 04 25 60 e8 00 00 48 8b 45 00 49 01 c0 49 8b 18 48 85 db 74 0d 48 63 45 18 <48> 8b 04 03 49 89 00 eb 14 4c 89 f9 83 ca ff 44 89 e6 48 89 ef RIP [<ffffffff810e61a3>] kmem_cache_alloc+0x5b/0xe9 This problem is that find_keyring_by_name does not confirm that the keyring is valid before accepting it. Skipping keyrings that have been reduced to a zero count seems the way to go. To this end, use atomic_inc_not_zero() to increment the usage count and skip the candidate keyring if that returns false. The following script _may_ cause the bug to happen, but there's no guarantee as the window of opportunity is small: #!/bin/sh LOOP=100000 USER=dummy_user /bin/su -c "exit;" $USER || { /usr/sbin/adduser -m $USER; add=1; } for ((i=0; i<LOOP; i++)) do /bin/su -c "echo '$i' > /dev/null" $USER done (( add == 1 )) && /usr/sbin/userdel -r $USER exit Note that the nominated user must not be in use. An alternative way of testing this may be: for ((i=0; i<100000; i++)) do keyctl session foo /bin/true || break done >&/dev/null as that uses a keyring named "foo" rather than relying on the user and user-session named keyrings. Reported-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05KEYS: Return more accurate error codesDan Carpenter
commit 4d09ec0f705cf88a12add029c058b53f288cfaa2 upstream. We were using the wrong variable here so the error codes weren't being returned properly. The original code returns -ENOKEY. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26mmap_min_addr check CAP_SYS_RAWIO only for writeKees Cook
commit 4ae69e6b718589abe97c9625ccbb1e0bc95a8c0e upstream. Redirecting directly to lsm, here's the patch discussed on lkml: http://lkml.org/lkml/2010/4/22/219 The mmap_min_addr value is useful information for an admin to see without being root ("is my system vulnerable to kernel NULL pointer attacks?") and its setting is trivially easy for an attacker to determine by calling mmap() in PAGE_SIZE increments starting at 0, so trying to keep it private has no value. Only require CAP_SYS_RAWIO if changing the value, not reading it. Comment from Serge : Me, I like to write my passwords with light blue pen on dark blue paper, pasted on my window - if you're going to get my password, you're gonna get a headache. Signed-off-by: Kees Cook <kees.cook@canonical.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org> (cherry picked from commit 822cceec7248013821d655545ea45d1c6a9d15b3) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12security: testing the wrong variable in create_by_name()Dan Carpenter
commit b338cc8207eae46640a8d534738fda7b5e48511d upstream. There is a typo here. We should be testing "*dentry" instead of "dentry". If "*dentry" is an ERR_PTR, it gets dereferenced in either mkdir() or create() which would cause an OOPs. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-12keys: the request_key() syscall should link an existing key to the dest keyringDavid Howells
commit 03449cd9eaa4fa3a7faa4a59474bafe2e90bd143 upstream. The request_key() system call and request_key_and_link() should make a link from an existing key to the destination keyring (if supplied), not just from a new key to the destination keyring. This can be tested by: ring=`keyctl newring fred @s` keyctl request2 user debug:a a keyctl request user debug:a $ring keyctl list $ring If it says: keyring is empty then it didn't work. If it shows something like: 1 key in keyring: 1070462727: --alswrv 0 0 user: debug:a then it did. request_key() system call is meant to recursively search all your keyrings for the key you desire, and, optionally, if it doesn't exist, call out to userspace to create one for you. If request_key() finds or creates a key, it should, optionally, create a link to that key from the destination keyring specified. Therefore, if, after a successful call to request_key() with a desination keyring specified, you see the destination keyring empty, the code didn't work correctly. If you see the found key in the keyring, then it did - which is what the patch is required for. Signed-off-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01sysctl: require CAP_SYS_RAWIO to set mmap_min_addrKees Cook
commit 0e1a6ef2dea88101b056b6d9984f3325c5efced3 upstream. Currently the mmap_min_addr value can only be bypassed during mmap when the task has CAP_SYS_RAWIO. However, the mmap_min_addr sysctl value itself can be adjusted to 0 if euid == 0, allowing a bypass without CAP_SYS_RAWIO. This patch adds a check for the capability before allowing mmap_min_addr to be changed. Signed-off-by: Kees Cook <kees.cook@canonical.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15netlabel: fix export of SELinux categories > 127Joshua Roys
commit c36f74e67fa12202dbcb4ad92c5ac844f9d36b98 upstream. This fixes corrupted CIPSO packets when SELinux categories greater than 127 are used. The bug occured on the second (and later) loops through the while; the inner for loop through the ebitmap->maps array used the same index as the NetLabel catmap->bitmap array, even though the NetLabel bitmap is twice as long as the SELinux bitmap. Signed-off-by: Joshua Roys <joshua.roys@gtri.gatech.edu> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-09SECURITY: selinux, fix update_rlimit_cpu parameterJiri Slaby
commit 17740d89785aeb4143770923d67c293849414710 upstream. Don't pass current RLIMIT_RTTIME to update_rlimit_cpu() in selinux_bprm_committing_creds, since update_rlimit_cpu expects RLIMIT_CPU limit. Use proper rlim[RLIMIT_CPU].rlim_cur instead to fix that. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Eric Paris <eparis@parisplace.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06Keys: KEYCTL_SESSION_TO_PARENT needs TIF_NOTIFY_RESUME architecture supportGeert Uytterhoeven
commit a00ae4d21b2fa9379914f270ffffd8d3bec55430 upstream. As of commit ee18d64c1f632043a02e6f5ba5e045bb26a5465f ("KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]"), CONFIG_KEYS=y fails to build on architectures that haven't implemented TIF_NOTIFY_RESUME yet: security/keys/keyctl.c: In function 'keyctl_session_to_parent': security/keys/keyctl.c:1312: error: 'TIF_NOTIFY_RESUME' undeclared (first use in this function) security/keys/keyctl.c:1312: error: (Each undeclared identifier is reported only once security/keys/keyctl.c:1312: error: for each function it appears in.) Make KEYCTL_SESSION_TO_PARENT depend on TIF_NOTIFY_RESUME until m68k, and xtensa have implemented it. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06NOMMU: Optimise away the {dac_,}mmap_min_addr testsDavid Howells
commit 6e1415467614e854fee660ff6648bd10fa976e95 upstream. In NOMMU mode clamp dac_mmap_min_addr to zero to cause the tests on it to be skipped by the compiler. We do this as the minimum mmap address doesn't make any sense in NOMMU mode. mmap_min_addr and round_hint_to_min() can be discarded entirely in NOMMU mode. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-19ima: replace GFP_KERNEL with GFP_NOFSMimi Zohar
While running fsstress tests on the NFSv4 mounted ext3 and ext4 filesystem, the following call trace was generated on the nfs server machine. Replace GFP_KERNEL with GFP_NOFS in ima_iint_insert() to avoid a potential deadlock. ================================= [ INFO: inconsistent lock state ] 2.6.31-31.el6.x86_64 #1 --------------------------------- inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage. kswapd2/75 [HC0[0]:SC0[0]:HE1:SE1] takes: (jbd2_handle){+.+.?.}, at: [<ffffffff811edd5e>] jbd2_journal_start+0xfe/0x13f {RECLAIM_FS-ON-W} state was registered at: [<ffffffff81091e40>] mark_held_locks+0x65/0x99 [<ffffffff81091f31>] lockdep_trace_alloc+0xbd/0xf5 [<ffffffff81126fdd>] kmem_cache_alloc+0x40/0x185 [<ffffffff812344d7>] ima_iint_insert+0x3d/0xf1 [<ffffffff812345b0>] ima_inode_alloc+0x25/0x44 [<ffffffff811484ac>] inode_init_always+0xec/0x271 [<ffffffff81148682>] alloc_inode+0x51/0xa1 [<ffffffff81148700>] new_inode+0x2e/0x94 [<ffffffff811b2f08>] ext4_new_inode+0xb8/0xdc9 [<ffffffff811be611>] ext4_create+0xcf/0x175 [<ffffffff8113e2cd>] vfs_create+0x82/0xb8 [<ffffffff8113f337>] do_filp_open+0x32c/0x9ee [<ffffffff811309b9>] do_sys_open+0x6c/0x12c [<ffffffff81130adc>] sys_open+0x2e/0x44 [<ffffffff81011e42>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 90371 hardirqs last enabled at (90371): [<ffffffff8112708d>] kmem_cache_alloc+0xf0/0x185 hardirqs last disabled at (90370): [<ffffffff81127026>] kmem_cache_alloc+0x89/0x185 softirqs last enabled at (89492): [<ffffffff81068ecf>] __do_softirq+0x1bf/0x1eb softirqs last disabled at (89477): [<ffffffff8101312c>] call_softirq+0x1c/0x30 other info that might help us debug this: 2 locks held by kswapd2/75: #0: (shrinker_rwsem){++++..}, at: [<ffffffff810f98ba>] shrink_slab+0x44/0x177 #1: (&type->s_umount_key#25){++++..}, at: [<ffffffff811450ba>] Reported-by: Muni P. Beerakam <mbeeraka@in.ibm.com> Reported-by: Amit K. Arora <amitarora@in.ibm.com> Cc: stable@kernel.org Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-10-15KEYS: get_instantiation_keyring() should inc the keyring refcount in all casesDavid Howells
The destination keyring specified to request_key() and co. is made available to the process that instantiates the key (the slave process started by /sbin/request-key typically). This is passed in the request_key_auth struct as the dest_keyring member. keyctl_instantiate_key and keyctl_negate_key() call get_instantiation_keyring() to get the keyring to attach the newly constructed key to at the end of instantiation. This may be given a specific keyring into which a link will be made later, or it may be asked to find the keyring passed to request_key(). In the former case, it returns a keyring with the refcount incremented by lookup_user_key(); in the latter case, it returns the keyring from the request_key_auth struct - and does _not_ increment the refcount. The latter case will eventually result in an oops when the keyring prematurely runs out of references and gets destroyed. The effect may take some time to show up as the key is destroyed lazily. To fix this, the keyring returned by get_instantiation_keyring() must always have its refcount incremented, no matter where it comes from. This can be tested by setting /etc/request-key.conf to: #OP TYPE DESCRIPTION CALLOUT INFO PROGRAM ARG1 ARG2 ARG3 ... #====== ======= =============== =============== =============================== create * test:* * |/bin/false %u %g %d %{user:_display} negate * * * /bin/keyctl negate %k 10 @u and then doing: keyctl add user _display aaaaaaaa @u while keyctl request2 user test:x test:x @u && keyctl list @u; do keyctl request2 user test:x test:x @u; sleep 31; keyctl list @u; done which will oops eventually. Changing the negate line to have @u rather than %S at the end is important as that forces the latter case by passing a special keyring ID rather than an actual keyring ID. Reported-by: Alexander Zangerl <az@bond.edu.au> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Alexander Zangerl <az@bond.edu.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-currentLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: lsm: Use a compressed IPv6 string format in audit events Audit: send signal info if selinux is disabled Audit: rearrange audit_context to save 16 bytes per struct Audit: reorganize struct audit_watch to save 8 bytes
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24do_wait() wakeup optimization: change __wake_up_parent() to use filtered wakeupOleg Nesterov
Ratan Nalumasu reported that in a process with many threads doing unnecessary wakeups. Every waiting thread in the process wakes up to loop through the children and see that the only ones it cares about are still not ready. Now that we have struct wait_opts we can change do_wait/__wake_up_parent to use filtered wakeups. We can make child_wait_callback() more clever later, right now it only checks eligible_child(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Ratan Nalumasu <rnalumasu@gmail.com> Cc: Vitaly Mayatskikh <vmayatsk@redhat.com> Acked-by: James Morris <jmorris@namei.org> Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cgroups: let ss->can_attach and ss->attach do whole threadgroups at a timeBen Blum
Alter the ss->can_attach and ss->attach functions to be able to deal with a whole threadgroup at a time, for use in cgroup_attach_proc. (This is a pre-patch to cgroup-procs-writable.patch.) Currently, new mode of the attach function can only tell the subsystem about the old cgroup of the threadgroup leader. No subsystem currently needs that information for each thread that's being moved, but if one were to be added (for example, one that counts tasks within a group) this bit would need to be reworked a bit to tell the subsystem the right information. [hidave.darkstar@gmail.com: fix build] Signed-off-by: Ben Blum <bblum@google.com> Signed-off-by: Paul Menage <menage@google.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: Matt Helsley <matthltc@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24lsm: Use a compressed IPv6 string format in audit eventsPaul Moore
Currently the audit subsystem prints uncompressed IPv6 addresses which not only differs from common usage but also results in ridiculously large audit strings which is not a good thing. This patch fixes this by simply converting audit to always print compressed IPv6 addresses. Old message example: audit(1253576792.161:30): avc: denied { ingress } for saddr=0000:0000:0000:0000:0000:0000:0000:0001 src=5000 daddr=0000:0000:0000:0000:0000:0000:0000:0001 dest=35502 netif=lo scontext=system_u:object_r:unlabeled_t:s15:c0.c1023 tcontext=system_u:object_r:lo_netif_t:s0-s15:c0.c1023 tclass=netif New message example: audit(1253576792.161:30): avc: denied { ingress } for saddr=::1 src=5000 daddr=::1 dest=35502 netif=lo scontext=system_u:object_r:unlabeled_t:s15:c0.c1023 tcontext=system_u:object_r:lo_netif_t:s0-s15:c0.c1023 tclass=netif Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: SELinux: do not destroy the avc_cache_nodep KEYS: Have the garbage collector set its timer for live expired keys tpm-fixup-pcrs-sysfs-file-update creds_are_invalid() needs to be exported for use by modules: include/linux/cred.h: fix build Fix trivial BUILD_BUG_ON-induced conflicts in drivers/char/tpm/tpm.c
2009-09-23SELinux: do not destroy the avc_cache_nodepEric Paris
The security_ops reset done when SELinux is disabled at run time is done after the avc cache is freed and after the kmem_cache for the avc is also freed. This means that between the time the selinux disable code destroys the avc_node_cachep another process could make a security request and could try to allocate from the cache. We are just going to leave the cachep around, like we always have. SELinux: Disabled at runtime. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81122537>] kmem_cache_alloc+0x9a/0x185 PGD 0 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC last sysfs file: CPU 1 Modules linked in: Pid: 12, comm: khelper Not tainted 2.6.31-tip-05525-g0eeacc6-dirty #14819 System Product Name RIP: 0010:[<ffffffff81122537>] [<ffffffff81122537>] kmem_cache_alloc+0x9a/0x185 RSP: 0018:ffff88003f9258b0 EFLAGS: 00010086 RAX: 0000000000000001 RBX: 0000000000000000 RCX: 0000000078c0129e RDX: 0000000000000000 RSI: ffffffff8130b626 RDI: ffffffff81122528 RBP: ffff88003f925900 R08: 0000000078c0129e R09: 0000000000000001 R10: 0000000000000000 R11: 0000000078c0129e R12: 0000000000000246 R13: 0000000000008020 R14: ffff88003f8586d8 R15: 0000000000000001 FS: 0000000000000000(0000) GS:ffff880002b00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: 0000000000000000 CR3: 0000000001001000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: ffffffff827bd420 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process khelper (pid: 12, threadinfo ffff88003f924000, task ffff88003f928000) Stack: 0000000000000246 0000802000000246 ffffffff8130b626 0000000000000001 <0> 0000000078c0129e 0000000000000000 ffff88003f925a70 0000000000000002 <0> 0000000000000001 0000000000000001 ffff88003f925960 ffffffff8130b626 Call Trace: [<ffffffff8130b626>] ? avc_alloc_node+0x36/0x273 [<ffffffff8130b626>] avc_alloc_node+0x36/0x273 [<ffffffff8130b545>] ? avc_latest_notif_update+0x7d/0x9e [<ffffffff8130b8b4>] avc_insert+0x51/0x18d [<ffffffff8130bcce>] avc_has_perm_noaudit+0x9d/0x128 [<ffffffff8130bf20>] avc_has_perm+0x45/0x88 [<ffffffff8130f99d>] current_has_perm+0x52/0x6d [<ffffffff8130fbb2>] selinux_task_create+0x2f/0x45 [<ffffffff81303bf7>] security_task_create+0x29/0x3f [<ffffffff8105c6ba>] copy_process+0x82/0xdf0 [<ffffffff81091578>] ? register_lock_class+0x2f/0x36c [<ffffffff81091a13>] ? mark_lock+0x2e/0x1e1 [<ffffffff8105d596>] do_fork+0x16e/0x382 [<ffffffff81091578>] ? register_lock_class+0x2f/0x36c [<ffffffff810d9166>] ? probe_workqueue_execution+0x57/0xf9 [<ffffffff81091a13>] ? mark_lock+0x2e/0x1e1 [<ffffffff810d9166>] ? probe_workqueue_execution+0x57/0xf9 [<ffffffff8100cdb2>] kernel_thread+0x82/0xe0 [<ffffffff81078b1f>] ? ____call_usermodehelper+0x0/0x139 [<ffffffff8100ce10>] ? child_rip+0x0/0x20 [<ffffffff81078aea>] ? __call_usermodehelper+0x65/0x9a [<ffffffff8107a5c7>] run_workqueue+0x171/0x27e [<ffffffff8107a573>] ? run_workqueue+0x11d/0x27e [<ffffffff81078a85>] ? __call_usermodehelper+0x0/0x9a [<ffffffff8107a7bc>] worker_thread+0xe8/0x10f [<ffffffff810808e2>] ? autoremove_wake_function+0x0/0x63 [<ffffffff8107a6d4>] ? worker_thread+0x0/0x10f [<ffffffff8108042e>] kthread+0x91/0x99 [<ffffffff8100ce1a>] child_rip+0xa/0x20 [<ffffffff8100c754>] ? restore_args+0x0/0x30 [<ffffffff8108039d>] ? kthread+0x0/0x99 [<ffffffff8100ce10>] ? child_rip+0x0/0x20 Code: 0f 85 99 00 00 00 9c 58 66 66 90 66 90 49 89 c4 fa 66 66 90 66 66 90 e8 83 34 fb ff e8 d7 e9 26 00 48 98 49 8b 94 c6 10 01 00 00 <48> 8b 1a 44 8b 7a 18 48 85 db 74 0f 8b 42 14 48 8b 04 c3 ff 42 RIP [<ffffffff81122537>] kmem_cache_alloc+0x9a/0x185 RSP <ffff88003f9258b0> CR2: 0000000000000000 ---[ end trace 42f41a982344e606 ]--- Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-23KEYS: Have the garbage collector set its timer for live expired keysDavid Howells
The key garbage collector sets a timer to start a new collection cycle at the point the earliest key to expire should be considered garbage. However, it currently only does this if the key it is considering hasn't yet expired. If the key being considering has expired, but hasn't yet reached the collection time then it is ignored, and won't be collected until some other key provokes a round of collection. Make the garbage collector set the timer for the earliest key that hasn't yet passed its collection time, rather than the earliest key that hasn't yet expired. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Move magic numbers into magic.hNick Black
Move various magic-number definitions into magic.h. Signed-off-by: Nick Black <dank@qemfd.net> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-15Merge branch 'x86-txt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-txt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, intel_txt: clean up the impact on generic code, unbreak non-x86 x86, intel_txt: Handle ACPI_SLEEP without X86_TRAMPOLINE x86, intel_txt: Fix typos in Kconfig help x86, intel_txt: Factor out the code for S3 setup x86, intel_txt: tboot.c needs <asm/fixmap.h> intel_txt: Force IOMMU on for Intel TXT launch x86, intel_txt: Intel TXT Sx shutdown support x86, intel_txt: Intel TXT reboot/halt shutdown support x86, intel_txt: Intel TXT boot support
2009-09-15KEYS: Fix garbage collectorDavid Howells
Fix a number of problems with the new key garbage collector: (1) A rogue semicolon in keyring_gc() was causing the initial count of dead keys to be miscalculated. (2) A missing return in keyring_gc() meant that under certain circumstances, the keyring semaphore would be unlocked twice. (3) The key serial tree iterator (key_garbage_collector()) part of the garbage collector has been modified to: (a) Complete each scan of the keyrings before setting the new timer. (b) Only set the new timer for keys that have yet to expire. This means that the new timer is now calculated correctly, and the gc doesn't get into a loop continually scanning for keys that have expired, and preventing other things from happening, like RCU cleaning up the old keyring contents. (c) Perform an extra scan if any keys were garbage collected in this one as a key might become garbage during a scan, and (b) could mean we don't set the timer again. (4) Made key_schedule_gc() take the time at which to do a collection run, rather than the time at which the key expires. This means the collection of dead keys (key type unregistered) can happen immediately. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-15KEYS: Unlock tasklist when exiting early from keyctl_session_to_parentMarc Dionne
When we exit early from keyctl_session_to_parent because of permissions or because the session keyring is the same as the parent, we need to unlock the tasklist. The missing unlock causes the system to hang completely when using keyctl(KEYCTL_SESSION_TO_PARENT) with a keyring shared with the parent. Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-14SELinux: flush the avc before disabling SELinuxEric Paris
Before SELinux is disabled at boot it can create AVC entries. This patch will flush those entries before disabling SELinux. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-14SELinux: seperate avc_cache flushingEric Paris
Move the avc_cache flushing into it's own function so it can be reused when disabling SELinux. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-14Creds: creds->security can be NULL is selinux is disabledEric Paris
__validate_process_creds should check if selinux is actually enabled before running tests on the selinux portion of the credentials struct. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-11Merge branch 'next' into for-linusJames Morris
2009-09-10sysfs: Add labeling support for sysfsDavid P. Quigley
This patch adds a setxattr handler to the file, directory, and symlink inode_operations structures for sysfs. The patch uses hooks introduced in the previous patch to handle the getting and setting of security information for the sysfs inodes. As was suggested by Eric Biederman the struct iattr in the sysfs_dirent structure has been replaced by a structure which contains the iattr, secdata and secdata length to allow the changes to persist in the event that the inode representing the sysfs_dirent is evicted. Because sysfs only stores this information when a change is made all the optional data is moved into one dynamically allocated field. This patch addresses an issue where SELinux was denying virtd access to the PCI configuration entries in sysfs. The lack of setxattr handlers for sysfs required that a single label be assigned to all entries in sysfs. Granting virtd access to every entry in sysfs is not an acceptable solution so fine grained labeling of sysfs is required such that individual entries can be labeled appropriately. [sds: Fixed compile-time warnings, coding style, and setting of inode security init flags.] Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov> Signed-off-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-10LSM/SELinux: inode_{get,set,notify}secctx hooks to access LSM security ↵David P. Quigley
context information. This patch introduces three new hooks. The inode_getsecctx hook is used to get all relevant information from an LSM about an inode. The inode_setsecctx is used to set both the in-core and on-disk state for the inode based on a context derived from inode_getsecctx.The final hook inode_notifysecctx will notify the LSM of a change for the in-core state of the inode in question. These hooks are for use in the labeled NFS code and addresses concerns of how to set security on an inode in a multi-xattr LSM. For historical reasons Stephen Smalley's explanation of the reason for these hooks is pasted below. Quote Stephen Smalley inode_setsecctx: Change the security context of an inode. Updates the in core security context managed by the security module and invokes the fs code as needed (via __vfs_setxattr_noperm) to update any backing xattrs that represent the context. Example usage: NFS server invokes this hook to change the security context in its incore inode and on the backing file system to a value provided by the client on a SETATTR operation. inode_notifysecctx: Notify the security module of what the security context of an inode should be. Initializes the incore security context managed by the security module for this inode. Example usage: NFS client invokes this hook to initialize the security context in its incore inode to the value provided by the server for the file when the server returned the file's attributes to the client. Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-07IMA: update ima_counts_putMimi Zohar
- As ima_counts_put() may be called after the inode has been freed, verify that the inode is not NULL, before dereferencing it. - Maintain the IMA file counters in may_open() properly, decrementing any counter increments on subsequent errors. Reported-by: Ciprian Docan <docan@eden.rutgers.edu> Reported-by: J.R. Okajima <hooanon05@yahoo.co.jp> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]David Howells
Add a keyctl to install a process's session keyring onto its parent. This replaces the parent's session keyring. Because the COW credential code does not permit one process to change another process's credentials directly, the change is deferred until userspace next starts executing again. Normally this will be after a wait*() syscall. To support this, three new security hooks have been provided: cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in the blank security creds and key_session_to_parent() - which asks the LSM if the process may replace its parent's session keyring. The replacement may only happen if the process has the same ownership details as its parent, and the process has LINK permission on the session keyring, and the session keyring is owned by the process, and the LSM permits it. Note that this requires alteration to each architecture's notify_resume path. This has been done for all arches barring blackfin, m68k* and xtensa, all of which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the replacement to be performed at the point the parent process resumes userspace execution. This allows the userspace AFS pioctl emulation to fully emulate newpag() and the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to alter the parent process's PAG membership. However, since kAFS doesn't use PAGs per se, but rather dumps the keys into the session keyring, the session keyring of the parent must be replaced if, for example, VIOCSETTOK is passed the newpag flag. This can be tested with the following program: #include <stdio.h> #include <stdlib.h> #include <keyutils.h> #define KEYCTL_SESSION_TO_PARENT 18 #define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0) int main(int argc, char **argv) { key_serial_t keyring, key; long ret; keyring = keyctl_join_session_keyring(argv[1]); OSERROR(keyring, "keyctl_join_session_keyring"); key = add_key("user", "a", "b", 1, keyring); OSERROR(key, "add_key"); ret = keyctl(KEYCTL_SESSION_TO_PARENT); OSERROR(ret, "KEYCTL_SESSION_TO_PARENT"); return 0; } Compiled and linked with -lkeyutils, you should see something like: [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 355907932 --alswrv 4043 -1 \_ keyring: _uid.4043 [dhowells@andromeda ~]$ /tmp/newpag [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 1055658746 --alswrv 4043 4043 \_ user: a [dhowells@andromeda ~]$ /tmp/newpag hello [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: hello 340417692 --alswrv 4043 4043 \_ user: a Where the test program creates a new session keyring, sticks a user key named 'a' into it and then installs it on its parent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Do some whitespace cleanups [try #6]David Howells
Do some whitespace cleanups in the key management code. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Make /proc/keys use keyid not numread as file position [try #6]Serge E. Hallyn
Make the file position maintained by /proc/keys represent the ID of the key just read rather than the number of keys read. This should make it faster to perform a lookup as we don't have to scan the key ID tree from the beginning to find the current position. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Add garbage collection for dead, revoked and expired keys. [try #6]David Howells
Add garbage collection for dead, revoked and expired keys. This involved erasing all links to such keys from keyrings that point to them. At that point, the key will be deleted in the normal manner. Keyrings from which garbage collection occurs are shrunk and their quota consumption reduced as appropriate. Dead keys (for which the key type has been removed) will be garbage collected immediately. Revoked and expired keys will hang around for a number of seconds, as set in /proc/sys/kernel/keys/gc_delay before being automatically removed. The default is 5 minutes. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Flag dead keys to induce EKEYREVOKED [try #6]David Howells
Set the KEY_FLAG_DEAD flag on keys for which the type has been removed. This causes the key_permission() function to return EKEYREVOKED in response to various commands. It does not, however, prevent unlinking or clearing of keyrings from detaching the key. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Allow keyctl_revoke() on keys that have SETATTR but not WRITE perm ↵David Howells
[try #6] Allow keyctl_revoke() to operate on keys that have SETATTR but not WRITE permission, rather than only on keys that have WRITE permission. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Deal with dead-type keys appropriately [try #6]David Howells
Allow keys for which the key type has been removed to be unlinked. Currently dead-type keys can only be disposed of by completely clearing the keyrings that point to them. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02CRED: Add some configurable debugging [try #6]David Howells
Add a config option (CONFIG_DEBUG_CREDENTIALS) to turn on some debug checking for credential management. The additional code keeps track of the number of pointers from task_structs to any given cred struct, and checks to see that this number never exceeds the usage count of the cred struct (which includes all references, not just those from task_structs). Furthermore, if SELinux is enabled, the code also checks that the security pointer in the cred struct is never seen to be invalid. This attempts to catch the bug whereby inode_has_perm() faults in an nfsd kernel thread on seeing cred->security be a NULL pointer (it appears that the credential struct has been previously released): http://www.kerneloops.org/oops.php?number=252883 Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02Merge commit 'v2.6.31-rc8' into x86/txtIngo Molnar
Conflicts: arch/x86/kernel/reboot.c security/Kconfig Merge reason: resolve the conflicts, bump up from rc3 to rc8. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-01x86, intel_txt: clean up the impact on generic code, unbreak non-x86Shane Wang
Move tboot.h from asm to linux to fix the build errors of intel_txt patch on non-X86 platforms. Remove the tboot code from generic code init/main.c and kernel/cpu.c. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-09-01selinux: Support for the new TUN LSM hooksPaul Moore
Add support for the new TUN LSM hooks: security_tun_dev_create(), security_tun_dev_post_create() and security_tun_dev_attach(). This includes the addition of a new object class, tun_socket, which represents the socks associated with TUN devices. The _tun_dev_create() and _tun_dev_post_create() hooks are fairly similar to the standard socket functions but _tun_dev_attach() is a bit special. The _tun_dev_attach() is unique because it involves a domain attaching to an existing TUN device and its associated tun_socket object, an operation which does not exist with standard sockets and most closely resembles a relabel operation. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Eric Paris <eparis@parisplace.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-01lsm: Add hooks to the TUN driverPaul Moore
The TUN driver lacks any LSM hooks which makes it difficult for LSM modules, such as SELinux, to enforce access controls on network traffic generated by TUN users; this is particularly problematic for virtualization apps such as QEMU and KVM. This patch adds three new LSM hooks designed to control the creation and attachment of TUN devices, the hooks are: * security_tun_dev_create() Provides access control for the creation of new TUN devices * security_tun_dev_post_create() Provides the ability to create the necessary socket LSM state for newly created TUN devices * security_tun_dev_attach() Provides access control for attaching to existing, persistent TUN devices and the ability to update the TUN device's socket LSM state as necessary Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Eric Paris <eparis@parisplace.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: IMA: iint put in ima_counts_get and put
2009-08-27IMA: iint put in ima_counts_get and putEric Paris
ima_counts_get() calls ima_iint_find_insert_get() which takes a reference to the iint in question, but does not put that reference at the end of the function. This can lead to a nasty memory leak. Easy enough to reproduce: #include <sys/mman.h> #include <stdio.h> int main (void) { int i; void *ptr; for (i=0; i < 100000; i++) { ptr = mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED|MAP_ANONYMOUS, -1, 0); if (ptr == MAP_FAILED) return 2; munmap(ptr, 4096); } return 0; } Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-24ima: hashing large files bug fixMimi Zohar
Hashing files larger than INT_MAX causes process to loop. Dependent on redefining kernel_read() offset type to loff_t. (http://bugzilla.kernel.org/show_bug.cgi?id=13909) Cc: stable@kernel.org Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-21selinux: adjust rules for ATTR_FORCEAmerigo Wang
As suggested by OGAWA Hirofumi in thread: http://lkml.org/lkml/2009/8/7/132, we should let selinux_inode_setattr() to match our ATTR_* rules. ATTR_FORCE should not force things like ATTR_SIZE. [hirofumi@mail.parknet.co.jp: tweaks] Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Eric Paris <eparis@redhat.com> Cc: Eugene Teo <eteo@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-20Merge branch 'master' into nextJames Morris
Conflicts: security/Kconfig Manual fix. Signed-off-by: James Morris <jmorris@namei.org>
