path: root/security
2012-09-18xfrm: invalidate dst on policy insertion/deletionNicolas Dichtel
When a policy is inserted or deleted, all dst should be recalculated. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-17Yama: access task_struct->comm directlyKees Cook
The core ptrace access checking routine holds a task lock, and when reporting a failure, Yama takes a separate task lock. To avoid a potential deadlock with two ptracers taking the opposite locks, do not use get_task_comm() and just use ->comm directly since accuracy is not important for the report. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Suggested-by: Oleg Nesterov <oleg@redhat.com> CC: stable@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-08-10Yama: higher restrictions should block PTRACE_TRACEMEKees Cook
The higher ptrace restriction levels should be blocking even PTRACE_TRACEME requests. The comments in the LSM documentation are misleading about when the checks happen (the parent does not go through security_ptrace_access_check() on a PTRACE_TRACEME call). Signed-off-by: Kees Cook <keescook@chromium.org> Cc: stable@vger.kernel.org # 3.5.x and later Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-07-31selinux: tag avc cache alloc as non-criticalMel Gorman
Failing to allocate a cache entry will only harm performance not correctness. Do not consume valuable reserve pages for something like that. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: David S. Miller <davem@davemloft.net> Cc: Eric B Munson <emunson@mgebm.net> Cc: Mel Gorman <mgorman@suse.de> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: Neil Brown <neilb@suse.de> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's first set of patches: "Non-MM patches: - lots of misc bits - tree-wide have_clk() cleanups - quite a lot of printk tweaks. I draw your attention to "printk: convert the format for KERN_<LEVEL> to a 2 byte pattern" which looks a bit scary. But afaict it's solid. - backlight updates - lib/ feature work (notably the addition and use of memweight()) - checkpatch updates - rtc updates - nilfs updates - fatfs updates (partial, still waiting for acks) - kdump, proc, fork, IPC, sysctl, taskstats, pps, etc - new fault-injection feature work" * Merge emailed patches from Andrew Morton <akpm@linux-foundation.org>: (128 commits) drivers/misc/lkdtm.c: fix missing allocation failure check lib/scatterlist: do not re-write gfp_flags in __sg_alloc_table() fault-injection: add tool to run command with failslab or fail_page_alloc fault-injection: add selftests for cpu and memory hotplug powerpc: pSeries reconfig notifier error injection module memory: memory notifier error injection module PM: PM notifier error injection module cpu: rewrite cpu-notifier-error-inject module fault-injection: notifier error injection c/r: fcntl: add F_GETOWNER_UIDS option resource: make sure requested range is included in the root range include/linux/aio.h: cpp->C conversions fs: cachefiles: add support for large files in filesystem caching pps: return PTR_ERR on error in device_create taskstats: check nla_reserve() return sysctl: suppress kmemleak messages ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSION ipc: compat: use signed size_t types for msgsnd and msgrcv ipc: allow compat IPC version field parsing if !ARCH_WANT_OLD_COMPAT_IPC ipc: add COMPAT_SHMLBA support ...
2012-07-30c/r: fcntl: add F_GETOWNER_UIDS optionCyrill Gorcunov
When we restore file descriptors we would like them to look exactly as they were at dumping time. With help of fcntl it's almost possible, the missing snippet is file owners UIDs. To be able to read their values the F_GETOWNER_UIDS is introduced. This option is valid iif CONFIG_CHECKPOINT_RESTORE is turned on, otherwise returning -EINVAL. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serge@hallyn.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30selinux: fix selinux_inode_setxattr oopsAl Viro
OK, what we have so far is e.g. setxattr(path, name, whatever, 0, XATTR_REPLACE) with name being good enough to get through xattr_permission(). Then we reach security_inode_setxattr() with the desired value and size. Aha. name should begin with "security.selinux", or we won't get that far in selinux_inode_setxattr(). Suppose we got there and have enough permissions to relabel that sucker. We call security_context_to_sid() with value == NULL, size == 0. OK, we want ss_initialized to be non-zero. I.e. after everything had been set up and running. No problem... We do 1-byte kmalloc(), zero-length memcpy() (which doesn't oops, even thought the source is NULL) and put a NUL there. I.e. form an empty string. string_to_context_struct() is called and looks for the first ':' in there. Not found, -EINVAL we get. OK, security_context_to_sid_core() has rc == -EINVAL, force == 0, so it silently returns -EINVAL. All it takes now is not having CAP_MAC_ADMIN and we are fucked. All right, it might be a different bug (modulo strange code quoted in the report), but it's real. Easily fixed, AFAICS: Deal with size == 0, value == NULL case in selinux_inode_setxattr() Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Dave Jones <davej@redhat.com> Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-07-30smack: off by one errorAlan Cox
Consider the input case of a rule that consists entirely of non space symbols followed by a \0. Say 64 + \0 In this case strlen(data) = 64 kzalloc of subject and object are 64 byte objects sscanfdata, "%s %s %s", subject, ...) will put 65 bytes into subject. Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-07-26posix_types.h: Cleanup stale __NFDBITS and related definitionsJosh Boyer
Recently, glibc made a change to suppress sign-conversion warnings in FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the kernel's definition of __NFDBITS if applications #include <linux/types.h> after including <sys/select.h>. A build failure would be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2 flags to gcc. It was suggested that the kernel should either match the glibc definition of __NFDBITS or remove that entirely. The current in-kernel uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no uses of the related __FDELT and __FDMASK defines. Given that, we'll continue the cleanup that was started with commit 8b3d1cda4f5f ("posix_types: Remove fd_set macros") and drop the remaining unused macros. Additionally, linux/time.h has similar macros defined that expand to nothing so we'll remove those at the same time. Reported-by: Jeff Law <law@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> CC: <stable@vger.kernel.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> [ .. and fix up whitespace as per akpm ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David S Miller: 1) Remove the ipv4 routing cache. Now lookups go directly into the FIB trie and use prebuilt routes cached there. No more garbage collection, no more rDOS attacks on the routing cache. Instead we now get predictable and consistent performance, no matter what the pattern of traffic we service. This has been almost 2 years in the making. Special thanks to Julian Anastasov, Eric Dumazet, Steffen Klassert, and others who have helped along the way. I'm sure that with a change of this magnitude there will be some kind of fallout, but such things ought the be simple to fix at this point. Luckily I'm not European so I'll be around all of August to fix things :-) The major stages of this work here are each fronted by a forced merge commit whose commit message contains a top-level description of the motivations and implementation issues. 2) Pre-demux of established ipv4 TCP sockets, saves a route demux on input. 3) TCP SYN/ACK performance tweaks from Eric Dumazet. 4) Add namespace support for netfilter L4 conntrack helpers, from Gao Feng. 5) Add config mechanism for Energy Efficient Ethernet to ethtool, from Yuval Mintz. 6) Remove quadratic behavior from /proc/net/unix, from Eric Dumazet. 7) Support for connection tracker helpers in userspace, from Pablo Neira Ayuso. 8) Allow userspace driven TX load balancing functions in TEAM driver, from Jiri Pirko. 9) Kill off NLMSG_PUT and RTA_PUT macros, more gross stuff with embedded gotos. 10) TCP Small Queues, essentially minimize the amount of TCP data queued up in the packet scheduler layer. Whereas the existing BQL (Byte Queue Limits) limits the pkt_sched --> netdevice queuing levels, this controls the TCP --> pkt_sched queueing levels. From Eric Dumazet. 11) Reduce the number of get_page/put_page ops done on SKB fragments, from Alexander Duyck. 12) Implement protection against blind resets in TCP (RFC 5961), from Eric Dumazet. 13) Support the client side of TCP Fast Open, basically the ability to send data in the SYN exchange, from Yuchung Cheng. Basically, the sender queues up data with a sendmsg() call using MSG_FASTOPEN, then they do the connect() which emits the queued up fastopen data. 14) Avoid all the problems we get into in TCP when timers or PMTU events hit a locked socket. The TCP Small Queues changes added a tcp_release_cb() that allows us to queue work up to the release_sock() caller, and that's what we use here too. From Eric Dumazet. 15) Zero copy on TX support for TUN driver, from Michael S. Tsirkin. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1870 commits) genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEP r8169: revert "add byte queue limit support". ipv4: Change rt->rt_iif encoding. net: Make skb->skb_iif always track skb->dev ipv4: Prepare for change of rt->rt_iif encoding. ipv4: Remove all RTCF_DIRECTSRC handliing. ipv4: Really ignore ICMP address requests/replies. decnet: Don't set RTCF_DIRECTSRC. net/ipv4/ip_vti.c: Fix __rcu warnings detected by sparse. ipv4: Remove redundant assignment rds: set correct msg_namelen openvswitch: potential NULL deref in sample() tcp: dont drop MTU reduction indications bnx2x: Add new 57840 device IDs tcp: avoid oops in tcp_metrics and reset tcpm_stamp niu: Change niu_rbr_fill() to use unlikely() to check niu_rbr_add_page() return value niu: Fix to check for dma mapping errors. net: Fix references to out-of-scope variables in put_cmsg_compat() net: ethernet: davinci_emac: add pm_runtime support net: ethernet: davinci_emac: Remove unnecessary #include ...
2012-07-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Nothing groundbreaking for this kernel, just cleanups and fixes, and a couple of Smack enhancements." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits) Smack: Maintainer Record Smack: don't show empty rules when /smack/load or /smack/load2 is read Smack: user access check bounds Smack: onlycap limits on CAP_MAC_ADMIN Smack: fix smack_new_inode bogosities ima: audit is compiled only when enabled ima: ima_initialized is set only if successful ima: add policy for pseudo fs ima: remove unused cleanup functions ima: free securityfs violations file ima: use full pathnames in measurement list security: Fix nommu build. samples: seccomp: add .gitignore for untracked executables tpm: check the chip reference before using it TPM: fix memleak when register hardware fails TPM: chip disabled state erronously being reported as error MAINTAINERS: TPM maintainers' contacts update Merge branches 'next-queue' and 'next' into next Remove unused code from MPI library Revert "crypto: GnuPG based MPI lib - additional sources (part 4)" ...
2012-07-23Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull the big VFS changes from Al Viro: "This one is *big* and changes quite a few things around VFS. What's in there: - the first of two really major architecture changes - death to open intents. The former is finally there; it was very long in making, but with Miklos getting through really hard and messy final push in fs/namei.c, we finally have it. Unlike his variant, this one doesn't introduce struct opendata; what we have instead is ->atomic_open() taking preallocated struct file * and passing everything via its fields. Instead of returning struct file *, it returns -E... on error, 0 on success and 1 in "deal with it yourself" case (e.g. symlink found on server, etc.). See comments before fs/namei.c:atomic_open(). That made a lot of goodies finally possible and quite a few are in that pile: ->lookup(), ->d_revalidate() and ->create() do not get struct nameidata * anymore; ->lookup() and ->d_revalidate() get lookup flags instead, ->create() gets "do we want it exclusive" flag. With the introduction of new helper (kern_path_locked()) we are rid of all struct nameidata instances outside of fs/namei.c; it's still visible in namei.h, but not for long. Come the next cycle, declaration will move either to fs/internal.h or to fs/namei.c itself. [me, miklos, hch] - The second major change: behaviour of final fput(). Now we have __fput() done without any locks held by caller *and* not from deep in call stack. That obviously lifts a lot of constraints on the locking in there. Moreover, it's legal now to call fput() from atomic contexts (which has immediately simplified life for aio.c). We also don't need anti-recursion logics in __scm_destroy() anymore. There is a price, though - the damn thing has become partially asynchronous. For fput() from normal process we are guaranteed that pending __fput() will be done before the caller returns to userland, exits or gets stopped for ptrace. For kernel threads and atomic contexts it's done via schedule_work(), so theoretically we might need a way to make sure it's finished; so far only one such place had been found, but there might be more. There's flush_delayed_fput() (do all pending __fput()) and there's __fput_sync() (fput() analog doing __fput() immediately). I hope we won't need them often; see warnings in fs/file_table.c for details. [me, based on task_work series from Oleg merged last cycle] - sync series from Jan - large part of "death to sync_supers()" work from Artem; the only bits missing here are exofs and ext4 ones. As far as I understand, those are going via the exofs and ext4 trees resp.; once they are in, we can put ->write_super() to the rest, along with the thread calling it. - preparatory bits from unionmount series (from dhowells). - assorted cleanups and fixes all over the place, as usual. This is not the last pile for this cycle; there's at least jlayton's ESTALE work and fsfreeze series (the latter - in dire need of fixes, so I'm not sure it'll make the cut this cycle). I'll probably throw symlink/hardlink restrictions stuff from Kees into the next pile, too. Plus there's a lot of misc patches I hadn't thrown into that one - it's large enough as it is..." * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (127 commits) ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file() btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file() switch dentry_open() to struct path, make it grab references itself spufs: shift dget/mntget towards dentry_open() zoran: don't bother with struct file * in zoran_map ecryptfs: don't reinvent the wheels, please - use struct completion don't expose I_NEW inodes via dentry->d_inode tidy up namei.c a bit unobfuscate follow_up() a bit ext3: pass custom EOF to generic_file_llseek_size() ext4: use core vfs llseek code for dir seeks vfs: allow custom EOF in generic_file_llseek code vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder sync passes vfs: Remove unnecessary flushing of block devices vfs: Make sys_sync writeout also block device inodes vfs: Create function for iterating over block devices vfs: Reorder operations during sys_sync quota: Move quota syncing to ->sync_fs method quota: Split dquot_quota_sync() to writeback and cache flushing part vfs: Move noop_backing_dev_info check from sync into writeback ...
2012-07-23switch dentry_open() to struct path, make it grab references itselfAl Viro
2012-07-22hold task_lock around checks in keyctlAl Viro
2012-07-22merge task_work and rcu_head, get rid of separate allocation for keyring caseAl Viro
task_work and rcu_head are identical now; merge them (calling the result struct callback_head, rcu_head #define'd to it), kill separate allocation in security/keys since we can just use cred->rcu now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22trimming task_work: kill ->dataAl Viro
get rid of the only user of ->data; this is _not_ the final variant - in the end we'll have task_work and rcu_head identical and just use cred->rcu, at which point the separate allocation will be gone completely. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/ixgbevf/ixgbevf_main.c
2012-07-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull SELinux regression fixes from James Morris. Andrew Morton has a box that hit that open perms problem. I also renamed the "epollwakeup" selinux name for the new capability to be "block_suspend", to match the rename done by commit d9914cf66181 ("PM: Rename CAP_EPOLLWAKEUP to CAP_BLOCK_SUSPEND"). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: SELinux: do not check open perms if they are not known to policy SELinux: include definition of new capabilities
2012-07-16SELinux: do not check open perms if they are not known to policyEric Paris
When I introduced open perms policy didn't understand them and I implemented them as a policycap. When I added the checking of open perm to truncate I forgot to conditionalize it on the userspace defined policy capability. Running an old policy with a new kernel will not check open on open(2) but will check it on truncate. Conditionalize the truncate check the same as the open check. Signed-off-by: Eric Paris <eparis@redhat.com> Cc: stable@vger.kernel.org # 3.4.x Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-07-16SELinux: include definition of new capabilitiesEric Paris
The kernel has added CAP_WAKE_ALARM and CAP_EPOLLWAKEUP. We need to define these in SELinux so they can be mediated by policy. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-07-13Smack: don't show empty rules when /smack/load or /smack/load2 is readRafal Krypa
This patch removes empty rules (i.e. with access set to '-') from the rule list presented to user space. Smack by design never removes labels nor rules from its lists. Access for a rule may be set to '-' to effectively disable it. Such rules would show up in the listing generated when /smack/load or /smack/load2 is read. This may cause clutter if many rules were disabled. As a rule with access set to '-' is equivalent to no rule at all, they may be safely hidden from the listing. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Rafal Krypa <r.krypa@samsung.com> Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2012-07-13Smack: user access check boundsCasey Schaufler
Some of the bounds checking used on the /smack/access interface was lost when support for long labels was added. No kernel access checks are affected, however this is a case where /smack/access could be used incorrectly and fail to detect the error. This patch reintroduces the original checks. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2012-07-13Smack: onlycap limits on CAP_MAC_ADMINCasey Schaufler
Smack is integrated with the POSIX capabilities scheme, using the capabilities CAP_MAC_OVERRIDE and CAP_MAC_ADMIN to determine if a process is allowed to ignore Smack checks or change Smack related data respectively. Smack provides an additional restriction that if an onlycap value is set by writing to /smack/onlycap only tasks with that Smack label are allowed to use CAP_MAC_OVERRIDE. This change adds CAP_MAC_ADMIN as a capability that is affected by the onlycap mechanism. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2012-07-13Smack: fix smack_new_inode bogositiesCasey Schaufler
In January of 2012 Al Viro pointed out three bits of code that he titled "new_inode_smack bogosities". This patch repairs these errors. 1. smack_sb_kern_mount() included a NULL check that is impossible. The check and NULL case are removed. 2. smack_kb_kern_mount() included pointless locking. The locking is removed. Since this is the only place that lock was used the lock is removed from the superblock_smack structure. 3. smk_fill_super() incorrectly and unnecessarily set the Smack label for the smackfs root inode. The assignment has been removed. Targeted for git://gitorious.org/smack-next/kernel.git Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2012-07-05ima: audit is compiled only when enabledDmitry Kasatkin
IMA auditing code was compiled even when CONFIG_AUDIT was not enabled. This patch compiles auditing code only when possible and enabled. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-07-05ima: ima_initialized is set only if successfulDmitry Kasatkin
Set ima_initialized only if initialization was successful. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-07-05ima: add policy for pseudo fsDmitry Kasatkin
Exclude DEVPTS and BINFMT filesystems from the measurement policy. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-07-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-07-03security: Fix nommu build.Paul Mundt
The security + nommu configuration presently blows up with an undefined reference to BDI_CAP_EXEC_MAP: security/security.c: In function 'mmap_prot': security/security.c:687:36: error: dereferencing pointer to incomplete type security/security.c:688:16: error: 'BDI_CAP_EXEC_MAP' undeclared (first use in this function) security/security.c:688:16: note: each undeclared identifier is reported only once for each function it appears in include backing-dev.h directly to fix it up. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-07-02ima: remove unused cleanup functionsDmitry Kasatkin
IMA cannot be used as module and does not need __exit functions. Removed them. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-07-02ima: free securityfs violations fileDmitry Kasatkin
On ima_fs_init() error, free securityfs violations file. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2012-07-02ima: use full pathnames in measurement listMimi Zohar
The IMA measurement list contains filename hints, which can be ambigious without the full pathname. This patch replaces the filename hint with the full pathname, simplifying for userspace the correlating of file hash measurements with files. Change log v1: - Revert to short filenames, when full pathname is longer than IMA measurement buffer size. (Based on Dmitry's review) Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-07-02security: Fix nommu build.Paul Mundt
2012-06-29netlink: add netlink_kernel_cfg parameter to netlink_kernel_createPablo Neira Ayuso
This patch adds the following structure: struct netlink_kernel_cfg { unsigned int groups; void (*input)(struct sk_buff *skb); struct mutex *cb_mutex; }; That can be passed to netlink_kernel_create to set optional configurations for netlink kernel sockets. I've populated this structure by looking for NULL and zero parameters at the existing code. The remaining parameters that always need to be set are still left in the original interface. That includes optional parameters for the netlink socket creation. This allows easy extensibility of this interface in the future. This patch also adapts all callers to use this new interface. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26selinux: netlink: Move away from NLMSG_PUT().David S. Miller
And use nlmsg_data() while we're here too. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-10Merge commit 'v3.5-rc2' into nextJames Morris
2012-06-07netfilter: selinux: switch hook PFs to nfprotoAlban Crequy
This patch is a cleanup. Use NFPROTO_* for consistency with other netfilter code. Signed-off-by: Alban Crequy <alban.crequy@collabora.co.uk> Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Vincent Sanders <vincent.sanders@collabora.co.uk> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-06-01take calculation of final prot in security_mmap_file() into a helperAl Viro
2012-06-01take security_mmap_file() outside of ->mmap_semAl Viro
2012-05-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull second pile of signal handling patches from Al Viro: "This one is just task_work_add() series + remaining prereqs for it. There probably will be another pull request from that tree this cycle - at least for helpers, to get them out of the way for per-arch fixes remaining in the tree." Fix trivial conflict in kernel/irq/manage.c: the merge of Andrew's pile had brought in commit 97fd75b7b8e0 ("kernel/irq/manage.c: use the pr_foo() infrastructure to prefix printks") which changed one of the pr_err() calls that this merge moves around. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: keys: kill task_struct->replacement_session_keyring keys: kill the dummy key_replace_session_keyring() keys: change keyctl_session_to_parent() to use task_work_add() genirq: reimplement exit_irq_thread() hook via task_work_add() task_work_add: generic process-context callbacks avr32: missed _TIF_NOTIFY_RESUME on one of do_notify_resume callers parisc: need to check NOTIFY_RESUME when exiting from syscall move key_repace_session_keyring() into tracehook_notify_resume() TIF_NOTIFY_RESUME is defined on all targets now
2012-05-31aio/vfs: cleanup of rw_copy_check_uvector() and compat_rw_copy_check_uvector()Christopher Yeoh
A cleanup of rw_copy_check_uvector and compat_rw_copy_check_uvector after changes made to support CMA in an earlier patch. Rather than having an additional check_access parameter to these functions, the first paramater type is overloaded to allow the caller to specify CHECK_IOVEC_ONLY which means check that the contents of the iovec are valid, but do not check the memory that they point to. This is used by process_vm_readv/writev where we need to validate that a iovec passed to the syscall is valid but do not want to check the memory that it points to at this point because it refers to an address space in another process. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31kmod: convert two call sites to call_usermodehelper_fns()Boaz Harrosh
Both kernel/sys.c && security/keys/request_key.c where inlining the exact same code as call_usermodehelper_fns(); So simply convert these sites to directly use call_usermodehelper_fns(). Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31security/keys/keyctl.c: suppress memory allocation failure warningAndrew Morton
This allocation may be large. The code is probing to see if it will succeed and if not, it falls back to vmalloc(). We should suppress any page-allocation failure messages when the fallback happens. Reported-by: Dave Jones <davej@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31split ->file_mmap() into ->mmap_addr()/->mmap_file()Al Viro
... i.e. file-dependent and address-dependent checks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-31split cap_mmap_addr() out of cap_file_mmap()Al Viro
... switch callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-29selinuxfs snprintf() misusesAl Viro
a) %d does _not_ produce a page worth of output b) snprintf() doesn't return negatives - it used to in old glibc, but that's the kernel... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-25KEYS: Fix some sparse warningsDavid Howells
Fix some sparse warnings in the keyrings code: (1) compat_keyctl_instantiate_key_iov() should be static. (2) There were a couple of places where a pointer was being compared against integer 0 rather than NULL. (3) keyctl_instantiate_key_common() should not take a __user-labelled iovec pointer as the caller must have copied the iovec to kernel space. (4) __key_link_begin() takes and __key_link_end() releases keyring_serialise_link_sem under some circumstances and so this should be declared. Note that adding __acquires() and __releases() for this doesn't help cure the warnings messages - something only commenting out both helps. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-05-23keys: change keyctl_session_to_parent() to use task_work_add()Oleg Nesterov
Change keyctl_session_to_parent() to use task_work_add() and move key_replace_session_keyring() logic into task_work->func(). Note that we do task_work_cancel() before task_work_add() to ensure that only one work can be pending at any time. This is important, we must not allow user-space to abuse the parent's ->task_works list. The callback, replace_session_keyring(), checks PF_EXITING. I guess this is not really needed but looks better. As a side effect, this fixes the (unlikely) race. The callers of key_replace_session_keyring() and keyctl_session_to_parent() lack the necessary barriers, the parent can miss the request. Now we can remove task_struct->replacement_session_keyring and related code. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alexander Gordeev <agordeev@redhat.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Smith <dsmith@redhat.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-23TIF_NOTIFY_RESUME is defined on all targets nowAl Viro
