path: root/security
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: SELINUX: Fix build error.
2010-08-06SELINUX: Fix build error.Ralf Baechle
Fix build error caused by a stale security/selinux/av_permissions.h in the $(src) directory which will override a more recent version in $(obj) that is it appears to strike only when building with a separate object directory. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-06KEYS: request_key() should return -ENOKEY if the constructed key is negativeDavid Howells
request_key() should return -ENOKEY if the key it constructs has been negatively instantiated. Without this, request_key() can return an unusable key to its caller, and if the caller then does key_validate() that won't catch the problem. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05apparmor: depends on NETRandy Dunlap
SECURITY_APPARMOR should depend on NET since AUDIT needs (depends on) NET. Fixes 70-80 errors that occur when CONFIG_NET is not enabled, but APPARMOR selects AUDIT without qualification. E.g.: audit.c:(.text+0x33361): undefined reference to `netlink_unicast' (.text+0x333df): undefined reference to `netlink_unicast' audit.c:(.text+0x3341d): undefined reference to `skb_queue_tail' audit.c:(.text+0x33424): undefined reference to `kfree_skb' audit.c:(.text+0x334cb): undefined reference to `kfree_skb' audit.c:(.text+0x33597): undefined reference to `skb_put' audit.c:(.text+0x3369b): undefined reference to `__alloc_skb' audit.c:(.text+0x336d7): undefined reference to `kfree_skb' (.text+0x3374c): undefined reference to `__alloc_skb' auditfilter.c:(.text+0x35305): undefined reference to `skb_queue_tail' lsm_audit.c:(.text+0x2873): undefined reference to `init_net' lsm_audit.c:(.text+0x2878): undefined reference to `dev_get_by_index' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Merge branch 'master' into for-nextJiri Kosina
2010-08-02AppArmor: fix build warnings for non-const use of get_task_credJames Morris
Fix build warnings for non-const use of get_task_cred. Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: convert the policy type_attr_map to flex_arrayEric Paris
Current selinux policy can have over 3000 types. The type_attr_map in policy is an array sized by the number of types times sizeof(struct ebitmap) (12 on x86_64). Basic math tells us the array is going to be of length 3000 x 12 = 36,000 bytes. The largest 'safe' allocation on a long running system is 16k. Most of the time a 32k allocation will work. But on long running systems a 64k allocation (what we need) can fail quite regularly. In order to deal with this I am converting the type_attr_map to use flex_arrays. Let the library code deal with breaking this into PAGE_SIZE pieces. -v2 rework some of the if(!obj) BUG() to be BUG_ON(!obj) drop flex_array_put() calls and just use a _get() object directly -v3 make apply to James' tree (drop the policydb_write changes) Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: Enable configuring and building of the AppArmor security moduleJohn Johansen
Kconfig and Makefiles to enable configuration and building of AppArmor. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Use pathname specified by policy rather than execve()Tetsuo Handa
Commit c9e69318 "TOMOYO: Allow wildcard for execute permission." changed execute permission and domainname to accept wildcards. But tomoyo_find_next_domain() was using pathname passed to execve() rather than pathname specified by the execute permission. As a result, processes were not able to transit to domains which contain wildcards in their domainnames. This patch passes pathname specified by the execute permission back to tomoyo_find_next_domain() so that processes can transit to domains which contain wildcards in their domainnames. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: update path_truncate method to latest versionJames Morris
Remove extraneous path_truncate arguments from the AppArmor hook, as they've been removed from the LSM API. Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: core policy routinesJohn Johansen
The basic routines and defines for AppArmor policy. AppArmor policy is defined by a few basic components. profiles - the basic unit of confinement contain all the information to enforce policy on a task Profiles tend to be named after an executable that they will attach to but this is not required. namespaces - a container for a set of profiles that will be used during attachment and transitions between profiles. sids - which provide a unique id for each profile Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: policy routines for loading and unpacking policyJohn Johansen
AppArmor policy is loaded in a platform independent flattened binary stream. Verify and unpack the data converting it to the internal format needed for enforcement. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: mediation of non file objectsJohn Johansen
ipc: AppArmor ipc is currently limited to mediation done by file mediation and basic ptrace tests. Improved mediation is a wip. rlimits: AppArmor provides basic abilities to set and control rlimits at a per profile level. Only resources specified in a profile are controled or set. AppArmor rules set the hard limit to a value <= to the current hard limit (ie. they can not currently raise hard limits), and if necessary will lower the soft limit to the new hard limit value. AppArmor does not track resource limits to reset them when a profile is left so that children processes inherit the limits set by the parent even if they are not confined by the same profile. Capabilities: AppArmor provides a per profile mask of capabilities, that will further restrict. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: LSM interface, and security module initializationJohn Johansen
AppArmor hooks to interface with the LSM, module parameters and module initialization. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: functions for domain transitionsJohn Johansen
AppArmor routines for controling domain transitions, which can occur at exec or through self directed change_profile/change_hat calls. Unconfined tasks are checked at exec against the profiles in the confining profile namespace to determine if a profile should be attached to the task. Confined tasks execs are controlled by the profile which provides rules determining which execs are allowed and if so which profiles should be transitioned to. Self directed domain transitions allow a task to request transition to a given profile. If the transition is allowed then the profile will be applied, either immeditately or at exec time depending on the request. Immeditate self directed transitions have several security limitations but have uses in setting up stub transition profiles and other limited cases. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: file enforcement routinesJohn Johansen
AppArmor does files enforcement via pathname matching. Matching is done at file open using a dfa match engine. Permission is against the final file object not parent directories, ie. the traversal of directories as part of the file match is implicitly allowed. In the case of nonexistant files (creation) permissions are checked against the target file not the directory. eg. In case of creating the file /dir/new, permissions are checked against the match /dir/new not against /dir/. The permissions for matches are currently stored in the dfa accept table, but this will change to allow for dfa reuse and also to allow for sharing of wider accept states. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: userspace interfacesJohn Johansen
The /proc/<pid>/attr/* interface is used for process introspection and commands. While the apparmorfs interface is used for global introspection and loading and removing policy. The interface currently only contains the files necessary for loading policy, and will be extended in the future to include sysfs style single per file introspection inteface. The old AppArmor 2.4 interface files have been removed into a compatibility patch, that distros can use to maintain backwards compatibility. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: dfa match engineJohn Johansen
A basic dfa matching engine based off the dfa engine in the Dragon Book. It uses simple row comb compression with a check field. This allows AppArmor to do pattern matching in linear time, and also avoids stack issues that an nfa based engine may have. The dfa engine uses a byte based comparison, with all values being valid. Any potential character encoding are handled user side when the dfa tables are created. By convention AppArmor uses \0 to separate two dependent path matches since \0 is not a valid path character (this is done in the link permission check). The dfa tables are generated in user space and are verified at load time to be internally consistent. There are several future improvements planned for the dfa engine: * The dfa engine may be converted to a hybrid nfa-dfa engine, with a fixed size limited stack. This would allow for size time tradeoffs, by inserting limited nfa states to help control state explosion that can occur with dfas. * The dfa engine may pickup the ability to do limited dynamic variable matching, instead of fixing all variables at policy load time. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: contexts used in attaching policy to system objectsJohn Johansen
AppArmor contexts attach profiles and state to tasks, files, etc. when a direct profile reference is not sufficient. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: basic auditing infrastructure.John Johansen
Update lsm_audit for AppArmor specific data, and add the core routines for AppArmor uses for auditing. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: misc. base functions and definesJohn Johansen
Miscellaneous functions and defines needed by AppArmor, including the base path resolution routines. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Update version to 2.3.0Tetsuo Handa
2010-08-02TOMOYO: Fix quota check.Tetsuo Handa
Commit d74725b9 "TOMOYO: Use callback for updating entries." broke tomoyo_domain_quota_is_ok() by counting deleted entries. It needs to count non-deleted entries. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02SELinux: Move execmod to the common permsEric Paris
execmod "could" show up on non regular files and non chr files. The current implementation would actually make these checks against non-existant bits since the code assumes the execmod permission is same for all file types. To make this line up for chr files we had to define execute_no_trans and entrypoint permissions. These permissions are unreachable and only existed to to make FILE__EXECMOD and CHR_FILE__EXECMOD the same. This patch drops those needless perms as well. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: place open in the common file permsEric Paris
kernel can dynamically remap perms. Drop the open lookup table and put open in the common file perms. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02SELinux: special dontaudit for access checksEric Paris
Currently there are a number of applications (nautilus being the main one) which calls access() on files in order to determine how they should be displayed. It is normal and expected that nautilus will want to see if files are executable or if they are really read/write-able. access() should return the real permission. SELinux policy checks are done in access() and can result in lots of AVC denials as policy denies RWX on files which DAC allows. Currently SELinux must dontaudit actual attempts to read/write/execute a file in order to silence these messages (and not flood the logs.) But dontaudit rules like that can hide real attacks. This patch addes a new common file permission audit_access. This permission is special in that it is meaningless and should never show up in an allow rule. Instead the only place this permission has meaning is in a dontaudit rule like so: dontaudit nautilus_t sbin_t:file audit_access With such a rule if nautilus just checks access() we will still get denied and thus userspace will still get the correct answer but we will not log the denial. If nautilus attempted to actually perform one of the forbidden actions (rather than just querying access(2) about it) we would still log a denial. This type of dontaudit rule should be used sparingly, as it could be a method for an attacker to probe the system permissions without detection. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02security: make LSMs explicitly mask off permissionsEric Paris
SELinux needs to pass the MAY_ACCESS flag so it can handle auditting correctly. Presently the masking of MAY_* flags is done in the VFS. In order to allow LSMs to decide what flags they care about and what flags they don't just pass them all and the each LSM mask off what they don't need. This patch should contain no functional changes to either the VFS or any LSM. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02SELinux: break ocontext reading into a separate functionEric Paris
Move the reading of ocontext type data out of policydb_read() in a separate function ocontext_read() Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02SELinux: move genfs read to a separate functionEric Paris
move genfs read functionality out of policydb_read() and into a new function called genfs_read() Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: fix error codes in symtab_init()Dan Carpenter
hashtab_create() only returns NULL on allocation failures to -ENOMEM is appropriate here. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: fix error codes in cond_read_bool()Dan Carpenter
The original code always returned -1 (-EPERM) on error. The new code returns either -ENOMEM, or -EINVAL or it propagates the error codes from lower level functions next_entry() or hashtab_insert(). next_entry() returns -EINVAL. hashtab_insert() returns -EINVAL, -EEXIST, or -ENOMEM. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: fix error codes in cond_policydb_init()Dan Carpenter
It's better to propagate the error code from avtab_init() instead of returning -1 (-EPERM). It turns out that avtab_init() never fails so this patch doesn't change how the code runs but it's still a clean up. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: fix error codes in cond_read_node()Dan Carpenter
Originally cond_read_node() returned -1 (-EPERM) on errors which was incorrect. Now it either propagates the error codes from lower level functions next_entry() or cond_read_av_list() or it returns -ENOMEM or -EINVAL. next_entry() returns -EINVAL. cond_read_av_list() returns -EINVAL or -ENOMEM. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: fix error codes in cond_read_av_list()Dan Carpenter
After this patch cond_read_av_list() no longer returns -1 for any errors. It just propagates error code back from lower levels. Those can either be -EINVAL or -ENOMEM. I also modified cond_insertf() since cond_read_av_list() passes that as a function pointer to avtab_read_item(). It isn't used anywhere else. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: propagate error codes in cond_read_list()Dan Carpenter
These are passed back when the security module gets loaded. The original code always returned -1 (-EPERM) on error but after this patch it can return -EINVAL, or -ENOMEM or propagate the error code from cond_read_node(). cond_read_node() still returns -1 all the time, but I fix that in a later patch. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: cleanup return codes in avtab_read_item()Dan Carpenter
The avtab_read_item() function tends to return -1 as a default error code which is wrong (-1 means -EPERM). I modified it to return appropriate error codes which is -EINVAL or the error code from next_entry() or insertf(). next_entry() returns -EINVAL. insertf() is a function pointer to either avtab_insert() or cond_insertf(). avtab_insert() returns -EINVAL, -ENOMEM, and -EEXIST. cond_insertf() currently returns -1, but I will fix it in a later patch. There is code in avtab_read() which translates the -1 returns from avtab_read_item() to -EINVAL. The translation is no longer needed, so I removed it. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02Security: capability: code style issueChihau Chau
This fix a little code style issue deleting a space between a function name and a open parenthesis. Signed-off-by: Chihau Chau <chihau@gmail.com> Acked-by: Andrew G. Morgan <morgan@kernel.org> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02securityfs: Drop dentry reference count when mknod failsTvrtko Ursulin
lookup_one_len increments dentry reference count which is not decremented when the create operation fails. This can cause a kernel BUG at fs/dcache.c:676 at unmount time. Also error code returned when new_inode() fails was replaced with more appropriate -ENOMEM. Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@sophos.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02selinux: use generic_file_llseekArnd Bergmann
The default for llseek will change to no_llseek, so selinuxfs needs to add explicit .llseek assignments. Since we're dealing with regular files from a VFS perspective, use generic_file_llseek. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02ima: use generic_file_llseek for securityfsArnd Bergmann
The default for llseek will change to no_llseek, so securityfs users need to add explicit .llseek assignments. Since we're dealing with regular files from a VFS perspective, use generic_file_llseek. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Explicitly set file_operations->llseek pointer.Tetsuo Handa
TOMOYO does not deal offset pointer. Thus seek operation makes no sense. Changing default seek operation from default_llseek() to no_llseek() might break some applications. Thus, explicitly set noop_llseek(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02security: move LSM xattrnames to xattr.hMimi Zohar
Make the security extended attributes names global. Updated to move the remaining Smack xattrs. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02KEYS: Reinstate lost passing of process keyring ID in call_sbin_request_key()Justin P. Mattock
In commit bb952bb98a7e479262c7eb25d5592545a3af147d there was the accidental deletion of a statement from call_sbin_request_key() to render the process keyring ID to a text string so that it can be passed to /sbin/request-key. With gcc 4.6.0 this causes the following warning: CC security/keys/request_key.o security/keys/request_key.c: In function 'call_sbin_request_key': security/keys/request_key.c:102:15: warning: variable 'prkey' set but not used This patch reinstates that statement. Without this statement, /sbin/request-key will get some random rubbish from the stack as that parameter. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02KEYS: Use the variable 'key' in keyctl_describe_key()David Howells
keyctl_describe_key() turns the key reference it gets into a usable key pointer and assigns that to a variable called 'key', which it then ignores in favour of recomputing the key pointer each time it needs it. Make it use the precomputed pointer instead. Without this patch, gcc 4.6 reports that the variable key is set but not used: building with gcc 4.6 I'm getting a warning message: CC security/keys/keyctl.o security/keys/keyctl.c: In function 'keyctl_describe_key': security/keys/keyctl.c:472:14: warning: variable 'key' set but not used Reported-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Add missing poll() hook.Tetsuo Handa
Commit 1dae08c "TOMOYO: Add interactive enforcing mode." forgot to register poll() hook. As a result, /usr/sbin/tomoyo-queryd was doing busy loop. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Rename symbols.Tetsuo Handa
Use shorter name in order to make it easier to fit 80 columns limit. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Small cleanup.Tetsuo Handa
Split tomoyo_write_profile() into several functions. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Copy directly to userspace buffer.Tetsuo Handa
When userspace program reads policy from /sys/kernel/security/tomoyo/ interface, TOMOYO uses line buffered mode. A line has at least one word. Commit 006dacc "TOMOYO: Support longer pathname." changed a word's max length from 4000 bytes to max kmalloc()able bytes. By that commit, a line's max length changed from 8192 bytes to more than max kmalloc()able bytes. Max number of words in a line remains finite. This patch changes the way of buffering so that all words in a line are firstly directly copied to userspace buffer as much as possible and are secondly queued for next read request. Words queued are guaranteed to be valid until /sys/kernel/security/tomoyo/ interface is close()d. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
