commit 2fb1c9a4f2dbc2f0bd2431c7fa64d0b5483864e4 upstream.
Calculating the 'security.evm' HMAC value requires access to the
EVM encrypted key. Only the kernel should have access to it. This
patch prevents userspace tools(eg. setfattr, cp --preserve=xattr)
from setting/modifying the 'security.evm' HMAC value directly.
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 0430e49b6e7c6b5e076be8fefdee089958c9adad upstream.
Commit 8aac62706 "move exit_task_namespaces() outside of exit_notify"
introduced the kernel opps since the kernel v3.10, which happens when
Apparmor and IMA-appraisal are enabled at the same time.
[ 106.750167] BUG: unable to handle kernel NULL pointer dereference at
0000000000000018
[ 106.750221] IP: [<ffffffff811ec7da>] our_mnt+0x1a/0x30
[ 106.750241] PGD 0
[ 106.750254] Oops: 0000 [#1] SMP
[ 106.750272] Modules linked in: cuse parport_pc ppdev bnep rfcomm
bluetooth rpcsec_gss_krb5 nfsd auth_rpcgss nfs_acl nfs lockd sunrpc
fscache dm_crypt intel_rapl x86_pkg_temp_thermal intel_powerclamp
kvm_intel snd_hda_codec_hdmi kvm crct10dif_pclmul crc32_pclmul
ghash_clmulni_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul
ablk_helper cryptd snd_hda_codec_realtek dcdbas snd_hda_intel
snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_seq_midi
snd_seq_midi_event snd_rawmidi psmouse snd_seq microcode serio_raw
snd_timer snd_seq_device snd soundcore video lpc_ich coretemp mac_hid lp
parport mei_me mei nbd hid_generic e1000e usbhid ahci ptp hid libahci
pps_core
[ 106.750658] CPU: 6 PID: 1394 Comm: mysqld Not tainted 3.13.0-rc7-kds+ #15
[ 106.750673] Hardware name: Dell Inc. OptiPlex 9010/0M9KCM, BIOS A08
09/19/2012
[ 106.750689] task: ffff8800de804920 ti: ffff880400fca000 task.ti:
ffff880400fca000
[ 106.750704] RIP: 0010:[<ffffffff811ec7da>] [<ffffffff811ec7da>]
our_mnt+0x1a/0x30
[ 106.750725] RSP: 0018:ffff880400fcba60 EFLAGS: 00010286
[ 106.750738] RAX: 0000000000000000 RBX: 0000000000000100 RCX:
ffff8800d51523e7
[ 106.750764] RDX: ffffffffffffffea RSI: ffff880400fcba34 RDI:
ffff880402d20020
[ 106.750791] RBP: ffff880400fcbae0 R08: 0000000000000000 R09:
0000000000000001
[ 106.750817] R10: 0000000000000000 R11: 0000000000000001 R12:
ffff8800d5152300
[ 106.750844] R13: ffff8803eb8df510 R14: ffff880400fcbb28 R15:
ffff8800d51523e7
[ 106.750871] FS: 0000000000000000(0000) GS:ffff88040d200000(0000)
knlGS:0000000000000000
[ 106.750910] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 106.750935] CR2: 0000000000000018 CR3: 0000000001c0e000 CR4:
00000000001407e0
[ 106.750962] Stack:
[ 106.750981] ffffffff813434eb ffff880400fcbb20 ffff880400fcbb18
0000000000000000
[ 106.751037] ffff8800de804920 ffffffff8101b9b9 0001800000000000
0000000000000100
[ 106.751093] 0000010000000000 0000000000000002 000000000000000e
ffff8803eb8df500
[ 106.751149] Call Trace:
[ 106.751172] [<ffffffff813434eb>] ? aa_path_name+0x2ab/0x430
[ 106.751199] [<ffffffff8101b9b9>] ? sched_clock+0x9/0x10
[ 106.751225] [<ffffffff8134a68d>] aa_path_perm+0x7d/0x170
[ 106.751250] [<ffffffff8101b945>] ? native_sched_clock+0x15/0x80
[ 106.751276] [<ffffffff8134aa73>] aa_file_perm+0x33/0x40
[ 106.751301] [<ffffffff81348c5e>] common_file_perm+0x8e/0xb0
[ 106.751327] [<ffffffff81348d78>] apparmor_file_permission+0x18/0x20
[ 106.751355] [<ffffffff8130c853>] security_file_permission+0x23/0xa0
[ 106.751382] [<ffffffff811c77a2>] rw_verify_area+0x52/0xe0
[ 106.751407] [<ffffffff811c789d>] vfs_read+0x6d/0x170
[ 106.751432] [<ffffffff811cda31>] kernel_read+0x41/0x60
[ 106.751457] [<ffffffff8134fd45>] ima_calc_file_hash+0x225/0x280
[ 106.751483] [<ffffffff8134fb52>] ? ima_calc_file_hash+0x32/0x280
[ 106.751509] [<ffffffff8135022d>] ima_collect_measurement+0x9d/0x160
[ 106.751536] [<ffffffff810b552d>] ? trace_hardirqs_on+0xd/0x10
[ 106.751562] [<ffffffff8134f07c>] ? ima_file_free+0x6c/0xd0
[ 106.751587] [<ffffffff81352824>] ima_update_xattr+0x34/0x60
[ 106.751612] [<ffffffff8134f0d0>] ima_file_free+0xc0/0xd0
[ 106.751637] [<ffffffff811c9635>] __fput+0xd5/0x300
[ 106.751662] [<ffffffff811c98ae>] ____fput+0xe/0x10
[ 106.751687] [<ffffffff81086774>] task_work_run+0xc4/0xe0
[ 106.751712] [<ffffffff81066fad>] do_exit+0x2bd/0xa90
[ 106.751738] [<ffffffff8173c958>] ? retint_swapgs+0x13/0x1b
[ 106.751763] [<ffffffff8106780c>] do_group_exit+0x4c/0xc0
[ 106.751788] [<ffffffff81067894>] SyS_exit_group+0x14/0x20
[ 106.751814] [<ffffffff8174522d>] system_call_fastpath+0x1a/0x1f
[ 106.751839] Code: c3 0f 1f 44 00 00 55 48 89 e5 e8 22 fe ff ff 5d c3
0f 1f 44 00 00 55 65 48 8b 04 25 c0 c9 00 00 48 8b 80 28 06 00 00 48 89
e5 5d <48> 8b 40 18 48 39 87 c0 00 00 00 0f 94 c0 c3 0f 1f 80 00 00 00
[ 106.752185] RIP [<ffffffff811ec7da>] our_mnt+0x1a/0x30
[ 106.752214] RSP <ffff880400fcba60>
[ 106.752236] CR2: 0000000000000018
[ 106.752258] ---[ end trace 3c520748b4732721 ]---
The reason for the oops is that IMA-appraisal uses "kernel_read()" when
file is closed. kernel_read() honors LSM security hook which calls
Apparmor handler, which uses current->nsproxy->mnt_ns. The 'guilty'
commit changed the order of cleanup code so that nsproxy->mnt_ns was
not already available for Apparmor.
Discussion about the issue with Al Viro and Eric W. Biederman suggested
that kernel_read() is too high-level for IMA. Another issue, except
security checking, that was identified is mandatory locking. kernel_read
honors it as well and it might prevent IMA from calculating necessary hash.
It was suggested to use simplified version of the function without security
and locking checks.
This patch introduces special version ima_kernel_read(), which skips security
and mandatory locking checking. It prevents the kernel oops to happen.
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Suggested-by: Eric W. Biederman <ebiederm@xmission.com>
commit f9b2a735bdddf836214b5dca74f6ca7712e5a08c upstream.
Files are measured or appraised based on the IMA policy. When a
file, in policy, is opened with the O_DIRECT flag, a deadlock
occurs.
The first attempt at resolving this lockdep temporarily removed the
O_DIRECT flag and restored it, after calculating the hash. The
second attempt introduced the O_DIRECT_HAVELOCK flag. Based on this
flag, do_blockdev_direct_IO() would skip taking the i_mutex a second
time. The third attempt, by Dmitry Kasatkin, resolves the i_mutex
locking issue, by re-introducing the IMA mutex, but uncovered
another problem. Reading a file with O_DIRECT flag set, writes
directly to userspace pages. A second patch allocates a user-space
like memory. This works for all IMA hooks, except ima_file_free(),
which is called on __fput() to recalculate the file hash.
Until this last issue is addressed, do not 'collect' the
measurement for measuring, appraising, or auditing files opened
with the O_DIRECT flag set. Based on policy, permit or deny file
access. This patch defines a new IMA policy rule option named
'permit_directio'. Policy rules could be defined, based on LSM
or other criteria, to permit specific applications to open files
Changelog v1:
- permit or deny file access based IMA policy rules
Acked-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fixes from Tejun Heo:
"During recent restructuring, device_cgroup unified config input check
and enforcement logic; unfortunately, it turned out to share too much.
Aristeu's patches fix the breakage and marked for -stable backport.
The other two patches are fallouts from kernfs conversion. The blkcg
change is temporary and will go away once kernfs internal locking gets
simplified (patches pending)"
* 'for-3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
blkcg: use trylock on blkcg_pol_mutex in blkcg_reset_stats()
device_cgroup: check if exception removal is allowed
device_cgroup: fix the comment format for recently added functions
device_cgroup: rework device access check and exception checking
cgroup: fix the retry path of cgroup_mount()
Pull vfs fixes from Al Viro:
"dcache fixes + kvfree() (uninlined, exported by mm/util.c) + posix_acl
bugfix from hch"
The dcache fixes are for a subtle LRU list corruption bug reported by
Miklos Szeredi, where people inside IBM saw list corruptions with the
LTP/host01 test.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
nick kvfree() from apparmor
posix_acl: handle NULL ACL in posix_acl_equiv_mode
dcache: don't need rcu in shrink_dentry_list()
more graceful recovery in umount_collect()
don't remove from shrink list in select_collect()
dentry_kill(): don't try to remove from shrink list
expand the call of dentry_lru_del() in dentry_kill()
new helper: dentry_free()
fold try_prune_one_dentry()
fold d_kill() and d_free()
fix races between __d_instantiate() and checks of dentry flags
too many places open-code it
[PATCH v3 1/2] device_cgroup: check if exception removal is allowed
When the device cgroup hierarchy was introduced in
bd2953ebbb53 - devcg: propagate local changes down the hierarchy
a specific case was overlooked. Consider the hierarchy bellow:
A default policy: ALLOW, exceptions will deny access
B default policy: ALLOW, exceptions will deny access
There's no need to verify when an new exception is added to B because
in this case exceptions will deny access to further devices, which is
always fine. Hierarchy in device cgroup only makes sure B won't have
more access than A.
But when an exception is removed (by writing devices.allow), it isn't
checked if the user is in fact removing an inherited exception from A,
thus giving more access to B.
Example:
# echo 'a' >A/devices.allow
# echo 'c 1:3 rw' >A/devices.deny
# echo $$ >A/B/tasks
# echo >/dev/null
-bash: /dev/null: Operation not permitted
# echo 'c 1:3 w' >A/B/devices.allow
# echo >/dev/null
This shouldn't be allowed and this patch fixes it by making sure to never allow
exceptions in this case to be removed if the exception is partially or fully
present on the parent.
v3: missing '*' in function description
v2: improved log message and formatting fixes
Cc: cgroups@vger.kernel.org
Cc: Li Zefan <lizefan@huawei.com>
Cc: stable@vger.kernel.org
Signed-off-by: Aristeu Rozanski <arozansk@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Moving more extensive explanations to the end of the comment.
File-private locks have been merged into Linux for v3.15, and *now*
people are commenting that the name and macro definitions for the new
file-private locks suck.
...and I can't even disagree. The names and command macros do suck.
We're going to have to live with these for a long time, so it's
important that we be happy with the names before we're stuck with them.
The consensus on the lists so far is that they should be rechristened as
"open file description locks".
The name isn't a big deal for the kernel, but the command macros are not
visually distinct enough from the traditional POSIX lock macros. The
glibc and documentation folks are recommending that we change them to
look like F_OFD_{GETLK|SETLK|SETLKW}. That lessens the chance that a
programmer will typo one of the commands wrong, and also makes it easier
to spot this difference when reading code.
This patch makes the following changes that I think are necessary before
v3.15 ships:
1) rename the command macros to their new names. These end up in the uapi
headers and so are part of the external-facing API. It turns out that
glibc doesn't actually use the fcntl.h uapi header, but it's hard to
be sure that something else won't. Changing it now is safest.
2) make the the /proc/locks output display these as type "OFDLCK"
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Carlos O'Donell <carlos@redhat.com>
Cc: Stefan Metzmacher <metze@samba.org>
Cc: Frank Filz <ffilzlnx@mindspring.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Whenever a device file is opened and checked against current device
cgroup rules, it uses the same function (may_access()) as when a new
exception rule is added by writing devices.{allow,deny}. And in both
cases, the algorithm is the same, doesn't matter the behavior.
First problem is having device access to be considered the same as rule
checking. Consider the following structure:
A (default behavior: allow, exceptions disallow access)
B (default behavior: allow, exceptions disallow access)
A new exception is added to B by writing devices.deny:
c 12:34 rw
When checking if that exception is allowed in may_access():
if (dev_cgroup->behavior == DEVCG_DEFAULT_ALLOW) {
if (behavior == DEVCG_DEFAULT_ALLOW) {
/* the exception will deny access to certain devices */
return true;
Which is ok, since B is not getting more privileges than A, it doesn't
matter and the rule is accepted
Now, consider it's a device file open check and the process belongs to
cgroup B. The access will be generated as:
behavior: allow
exception: c 12:34 rw
The very same chunk of code will allow it, even if there's an explicit
exception telling to do otherwise.
A simple test case:
# mkdir new_group
# cd new_group
# echo $$ >tasks
# echo "c 1:3 w" >devices.deny
# echo >/dev/null
# echo $?
0
This is a serious bug and was introduced on
c39a2a3018f8 devcg: prepare may_access() for hierarchy support
To solve this problem, the device file open function was split from the
new exception check.
Second problem is how exceptions are processed by may_access(). The
first part of the said function tries to match fully with an existing
exception:
list_for_each_entry_rcu(ex, &dev_cgroup->exceptions, list) {
if ((refex->type & DEV_BLOCK) && !(ex->type & DEV_BLOCK))
continue;
if ((refex->type & DEV_CHAR) && !(ex->type & DEV_CHAR))
continue;
if (ex->major != ~0 && ex->major != refex->major)
continue;
if (ex->minor != ~0 && ex->minor != refex->minor)
continue;
if (refex->access & (~ex->access))
continue;
match = true;
break;
That means the new exception should be contained into an existing one to
be considered a match:
New exception Existing match? notes
b 12:34 rwm b 12:34 rwm yes
b 12:34 r b *:34 rw yes
b 12:34 rw b 12:34 w no extra "r"
b *:34 rw b 12:34 rw no too broad "*"
b *:34 rw b *:34 rwm yes
Which is fine in some cases. Consider:
A (default behavior: deny, exceptions allow access)
B (default behavior: deny, exceptions allow access)
In this case the full match makes sense, the new exception cannot add
more access than the parent allows
But this doesn't always work, consider:
In this case, a new exception in B shouldn't match any of the exceptions
in A, after all you can't allow something that was forbidden by A. But
consider this scenario:
New exception Existing in A match? outcome
b 12:34 rw b 12:34 r no exception is accepted
Because the new exception has "w" as extra, it doesn't match, so it'll
be added to B's exception list.
The same problem can happen during a file access check. Consider a
cgroup with allow as default behavior:
Access Exception match?
In this case, the access didn't match any of the exceptions in the
cgroup, which is required since exceptions will disallow access.
To solve this problem, two new functions were created to match an
exception either fully or partially. In the example above, a partial
check will be performed and it'll produce a match since at least
"b 12:34 r" from "b 12:34 rw" access matches.
Cc: Tejun Heo <tj@kernel.org>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
Pull file locking updates from Jeff Layton:
"Highlights:
- maintainership change for fs/locks.c. Willy's not interested in
maintaining it these days, and is OK with Bruce and I taking it.
- fix for open vs setlease race that Al ID'ed
- cleanup and consolidation of file locking code
- eliminate unneeded BUG() call
- merge of file-private lock implementation"
* 'locks-3.15' of git://git.samba.org/jlayton/linux:
locks: make locks_mandatory_area check for file-private locks
locks: fix locks_mandatory_locked to respect file-private locks
locks: require that flock->l_pid be set to 0 for file-private locks
locks: add new fcntl cmd values for handling file private locks
locks: skip deadlock detection on FL_FILE_PVT locks
locks: pass the cmd value to fcntl_getlk/getlk64
locks: report l_pid as -1 for FL_FILE_PVT locks
locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT"
locks: rename locks_remove_flock to locks_remove_file
locks: consolidate checks for compatible filp->f_mode values in setlk handlers
locks: fix posix lock range overflow handling
locks: eliminate BUG() call when there's an unexpected lock on file close
locks: add __acquires and __releases annotations to locks_start and locks_stop
locks: remove "inline" qualifier from fl_link manipulation functions
locks: clean up comment typo
locks: close potential race between setlease and open
MAINTAINERS: update entry for fs/locks.c
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull renameat2 system call from Miklos Szeredi:
"This adds a new syscall, renameat2(), which is the same as renameat()
but with a flags argument.
The purpose of extending rename is to add cross-rename, a symmetric
variant of rename, which exchanges the two files. This allows
interesting things, which were not possible before, for example
atomically replacing a directory tree with a symlink, etc... This
also allows overlayfs and friends to operate on whiteouts atomically.
Andy Lutomirski also suggested a "noreplace" flag, which disables the
overwriting behavior of rename.
These two flags, RENAME_EXCHANGE and RENAME_NOREPLACE are only
implemented for ext4 as an example and for testing"
* 'cross-rename' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ext4: add cross rename support
ext4: rename: split out helper functions
ext4: rename: move EMLINK check up
ext4: rename: create ext4_renament structure for local vars
vfs: add cross-rename
vfs: lock_two_nondirectories: allow directory args
security: add flags to rename hooks
vfs: add RENAME_NOREPLACE flag
vfs: add renameat2 syscall
vfs: rename: use common code for dir and non-dir
vfs: rename: move d_move() up
vfs: add d_is_dir()
Pull cgroup updates from Tejun Heo:
"A lot updates for cgroup:
- The biggest one is cgroup's conversion to kernfs. cgroup took
after the long abandoned vfs-entangled sysfs implementation and
made it even more convoluted over time. cgroup's internal objects
were fused with vfs objects which also brought in vfs locking and
object lifetime rules. Naturally, there are places where vfs rules
don't fit and nasty hacks, such as credential switching or lock
dance interleaving inode mutex and cgroup_mutex with object serial
number comparison thrown in to decide whether the operation is
actually necessary, needed to be employed.
After conversion to kernfs, internal object lifetime and locking
rules are mostly isolated from vfs interactions allowing shedding
of several nasty hacks and overall simplification. This will also
allow implmentation of operations which may affect multiple cgroups
which weren't possible before as it would have required nesting
i_mutexes.
- Various simplifications including dropping of module support,
easier cgroup name/path handling, simplified cgroup file type
handling and task_cg_lists optimization.
- Prepatory changes for the planned unified hierarchy, which is still
a patchset away from being actually operational. The dummy
hierarchy is updated to serve as the default unified hierarchy.
Controllers which aren't claimed by other hierarchies are
associated with it, which BTW was what the dummy hierarchy was for
anyway.
- Various fixes from Li and others. This pull request includes some
patches to add missing slab.h to various subsystems. This was
triggered xattr.h include removal from cgroup.h. cgroup.h
indirectly got included a lot of files which brought in xattr.h
which brought in slab.h.
There are several merge commits - one to pull in kernfs updates
necessary for converting cgroup (already in upstream through
driver-core), others for interfering changes in the fixes branch"
* 'for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (74 commits)
cgroup: remove useless argument from cgroup_exit()
cgroup: fix spurious lockdep warning in cgroup_exit()
cgroup: Use RCU_INIT_POINTER(x, NULL) in cgroup.c
cgroup: break kernfs active_ref protection in cgroup directory operations
cgroup: fix cgroup_taskset walking order
cgroup: implement CFTYPE_ONLY_ON_DFL
cgroup: make cgrp_dfl_root mountable
cgroup: drop const from @buffer of cftype->write_string()
cgroup: rename cgroup_dummy_root and related names
cgroup: move ->subsys_mask from cgroupfs_root to cgroup
cgroup: treat cgroup_dummy_root as an equivalent hierarchy during rebinding
cgroup: remove NULL checks from [pr_cont_]cgroup_{name|path}()
cgroup: use cgroup_setup_root() to initialize cgroup_dummy_root
cgroup: reorganize cgroup bootstrapping
cgroup: relocate setting of CGRP_DEAD
cpuset: use rcu_read_lock() to protect task_cs()
cgroup_freezer: document freezer_fork() subtleties
cgroup: update cgroup_transfer_tasks() to either succeed or fail
cgroup: drop task_lock() protection around task->cgroups
cgroup: update how a newly forked task gets associated with css_set
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Apart from reordering the SELinux mmap code to ensure DAC is called
before MAC, these are minor maintenance updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits)
selinux: correctly label /proc inodes in use before the policy is loaded
selinux: put the mmap() DAC controls before the MAC controls
selinux: fix the output of ./scripts/get_maintainer.pl for SELinux
evm: enable key retention service automatically
ima: skip memory allocation for empty files
evm: EVM does not use MD5
ima: return d_name.name if d_path fails
integrity: fix checkpatch errors
ima: fix erroneous removal of security.ima xattr
security: integrity: Use a more current logging style
MAINTAINERS: email updates and other misc. changes
ima: reduce memory usage when a template containing the n field is used
ima: restore the original behavior for sending data with ima template
Integrity: Pass commname via get_task_comm()
fs: move i_readcount
ima: use static const char array definitions
security: have cap_dentry_init_security return error
ima: new helper: file_inode(file)
kernel: Mark function as static in kernel/seccomp.c
capability: Use current logging styles
Pull networking updates from David Miller:
"Here is my initial pull request for the networking subsystem during
this merge window:
1) Support for ESN in AH (RFC 4302) from Fan Du.
2) Add full kernel doc for ethtool command structures, from Ben
Hutchings.
3) Add BCM7xxx PHY driver, from Florian Fainelli.
4) Export computed TCP rate information in netlink socket dumps, from
Eric Dumazet.
5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas
Dichtel.
6) Convert many drivers to pci_enable_msix_range(), from Alexander
Gordeev.
7) Record SKB timestamps more efficiently, from Eric Dumazet.
8) Switch to microsecond resolution for TCP round trip times, also
from Eric Dumazet.
9) Clean up and fix 6lowpan fragmentation handling by making use of
the existing inet_frag api for it's implementation.
10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss.
11) Auto size SKB lengths when composing netlink messages based upon
past message sizes used, from Eric Dumazet.
12) qdisc dumps can take a long time, add a cond_resched(), From Eric
Dumazet.
13) Sanitize netpoll core and drivers wrt. SKB handling semantics.
Get rid of never-used-in-tree netpoll RX handling. From Eric W
Biederman.
14) Support inter-address-family and namespace changing in VTI tunnel
driver(s). From Steffen Klassert.
15) Add Altera TSE driver, from Vince Bridgers.
16) Optimizing csum_replace2() so that it doesn't adjust the checksum
by checksumming the entire header, from Eric Dumazet.
17) Expand BPF internal implementation for faster interpreting, more
direct translations into JIT'd code, and much cleaner uses of BPF
filtering in non-socket ocntexts. From Daniel Borkmann and Alexei
Starovoitov"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits)
netpoll: Use skb_irq_freeable to make zap_completion_queue safe.
net: Add a test to see if a skb is freeable in irq context
qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port'
net: ptp: move PTP classifier in its own file
net: sxgbe: make "core_ops" static
net: sxgbe: fix logical vs bitwise operation
net: sxgbe: sxgbe_mdio_register() frees the bus
Call efx_set_channels() before efx->type->dimension_resources()
xen-netback: disable rogue vif in kthread context
net/mlx4: Set proper build dependancy with vxlan
be2net: fix build dependency on VxLAN
mac802154: make csma/cca parameters per-wpan
mac802154: allow only one WPAN to be up at any given time
net: filter: minor: fix kdoc in __sk_run_filter
netlink: don't compare the nul-termination in nla_strcmp
can: c_can: Avoid led toggling for every packet.
can: c_can: Simplify TX interrupt cleanup
can: c_can: Store dlc private
can: c_can: Reduce register access
can: c_can: Make the code readable
If flags contain RENAME_EXCHANGE then exchange source and destination files.
There's no restriction on the type of the files; e.g. a directory can be
exchanged with a symlink.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Reviewed-by: J. Bruce Fields <bfields@redhat.com>
Add flags to security_path_rename() and security_inode_rename() hooks.
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 compat wrapper rework from Heiko Carstens:
"S390 compat system call wrapper simplification work.
The intention of this work is to get rid of all hand written assembly
compat system call wrappers on s390, which perform proper sign or zero
extension, or pointer conversion of compat system call parameters.
Instead all of this should be done with C code eg by using Al's
COMPAT_SYSCALL_DEFINEx() macro.
Therefore all common code and s390 specific compat system calls have
been converted to the COMPAT_SYSCALL_DEFINEx() macro.
In order to generate correct code all compat system calls may only
have eg compat_ulong_t parameters, but no unsigned long parameters.
Those patches which change parameter types from unsigned long to
compat_ulong_t parameters are separate in this series, but shouldn't
cause any harm.
The only compat system calls which intentionally have 64 bit
parameters (preadv64 and pwritev64) in support of the x86/32 ABI
haven't been changed, but are now only available if an architecture
defines __ARCH_WANT_COMPAT_SYS_PREADV64/PWRITEV64.
System calls which do not have a compat variant but still need proper
zero extension on s390, like eg "long sys_brk(unsigned long brk)" will
get a proper wrapper function with the new s390 specific
COMPAT_SYSCALL_WRAPx() macro:
COMPAT_SYSCALL_WRAP1(brk, unsigned long, brk);
which generates the following code (simplified):
asmlinkage long sys_brk(unsigned long brk);
asmlinkage long compat_sys_brk(long brk)
return sys_brk((u32)brk);
Given that the C file which contains all the COMPAT_SYSCALL_WRAP lines
includes both linux/syscall.h and linux/compat.h, it will generate
build errors, if the declaration of sys_brk() doesn't match, or if
there exists a non-matching compat_sys_brk() declaration.
In addition this will intentionally result in a link error if
somewhere else a compat_sys_brk() function exists, which probably
should have been used instead. Two more BUILD_BUG_ONs make sure the
size and type of each compat syscall parameter can be handled
correctly with the s390 specific macros.
I converted the compat system calls step by step to verify the
generated code is correct and matches the previous code. In fact it
did not always match, however that was always a bug in the hand
written asm code.
In result we get less code, less bugs, and much more sanity checking"
* 'compat' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (44 commits)
s390/compat: add copyright statement
compat: include linux/unistd.h within linux/compat.h
s390/compat: get rid of compat wrapper assembly code
s390/compat: build error for large compat syscall args
mm/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
kexec/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
net/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
ipc/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
fs/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
security/compat: convert to COMPAT_SYSCALL_DEFINE
kernel/compat: convert to COMPAT_SYSCALL_DEFINE
fs/compat: optional preadv64/pwrite64 compat system calls
ipc/compat_sys_msgrcv: change msgtyp type from long to compat_long_t
s390/compat: partial parameter conversion within syscall wrappers
s390/compat: automatic zero, sign and pointer conversion of syscalls
s390/compat: add sync_file_range and fallocate compat syscalls
Due to some unfortunate history, POSIX locks have very strange and
unhelpful semantics. The thing that usually catches people by surprise
is that they are dropped whenever the process closes any file descriptor
associated with the inode.
This is extremely problematic for people developing file servers that
need to implement byte-range locks. Developers often need a "lock
management" facility to ensure that file descriptors are not closed
until all of the locks associated with the inode are finished.
Additionally, "classic" POSIX locks are owned by the process. Locks
taken between threads within the same process won't conflict with one
another, which renders them useless for synchronization between threads.
This patchset adds a new type of lock that attempts to address these
issues. These locks conflict with classic POSIX read/write locks, but
have semantics that are more like BSD locks with respect to inheritance
and behavior on close.
This is implemented primarily by changing how fl_owner field is set for
these locks. Instead of having them owned by the files_struct of the
process, they are instead owned by the filp on which they were acquired.
Thus, they are inherited across fork() and are only released when the
last reference to a filp is put.
These new semantics prevent them from being merged with classic POSIX
locks, even if they are acquired by the same process. These locks will
also conflict with classic POSIX locks even if they are acquired by
the same process or on the same file descriptor.
The new locks are managed using a new set of cmd values to the fcntl()
syscall. The initial implementation of this converts these values to
"classic" cmd values at a fairly high level, and the details are not
exposed to the underlying filesystem. We may eventually want to push
this handing out to the lower filesystem code but for now I don't
see any need for it.
Also, note that with this implementation the new cmd values are only
available via fcntl64() on 32-bit arches. There's little need to
add support for legacy apps on a new interface like this.
Documentation/devicetree/bindings/net/micrel-ks8851.txt
net/core/netpoll.c
The net/core/netpoll.c conflict is a bug fix in 'net' happening
to code which is completely removed in 'net-next'.
In micrel-ks8851.txt we simply have overlapping changes.
Store and log all PIDs with reference to the initial PID namespace and
use the access functions task_pid_nr() and task_tgid_nr() for task->pid
and task->tgid.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
(informed by ebiederman's c776b5d2)
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
This patch is based on an earlier patch by Eric Paris, he describes
the problem below:
"If an inode is accessed before policy load it will get placed on a
list of inodes to be initialized after policy load. After policy
load we call inode_doinit() which calls inode_doinit_with_dentry()
on all inodes accessed before policy load. In the case of inodes
in procfs that means we'll end up at the bottom where it does:
/* Default to the fs superblock SID. */
isec->sid = sbsec->sid;
if ((sbsec->flags & SE_SBPROC) && !S_ISLNK(inode->i_mode)) {
if (opt_dentry) {
isec->sclass = inode_mode_to_security_class(...)
rc = selinux_proc_get_sid(opt_dentry,
isec->sclass,
&sid);
if (rc)
goto out_unlock;
isec->sid = sid;
Since opt_dentry is null, we'll never call selinux_proc_get_sid()
and will leave the inode labeled with the label on the superblock.
I believe a fix would be to mimic the behavior of xattrs. Look
for an alias of the inode. If it can't be found, just leave the
inode uninitialized (and pick it up later) if it can be found, we
should be able to call selinux_proc_get_sid() ..."
On a system exhibiting this problem, you will notice a lot of files in
/proc with the generic "proc_t" type (at least the ones that were
accessed early in the boot), for example:
# ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }'
system_u:object_r:proc_t:s0 /proc/sys/kernel/shmmax
However, with this patch in place we see the expected result:
system_u:object_r:sysctl_kernel_t:s0 /proc/sys/kernel/shmmax
Cc: Eric Paris <eparis@redhat.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Acked-by: Eric Paris <eparis@redhat.com>
It turns out that doing the SELinux MAC checks for mmap() before the
DAC checks was causing users and the SELinux policy folks headaches
as users were seeing a lot of SELinux AVC denials for the
memprotect:mmap_zero permission that would have also been denied by
the normal DAC capability checks (CAP_SYS_RAWIO).
Example:
# cat mmap_test.c
#include <stdlib.h>
#include <stdio.h>
#include <errno.h>
#include <sys/mman.h>
int main(int argc, char *argv[])
int rc;
void *mem;
mem = mmap(0x0, 4096,
PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
if (mem == MAP_FAILED)
return errno;
printf("mem = %p\n", mem);
munmap(mem, 4096);
return 0;
# gcc -g -O0 -o mmap_test mmap_test.c
# ./mmap_test
mem = (nil)
# ausearch -m AVC | grep mmap_zero
type=AVC msg=audit(...): avc: denied { mmap_zero }
for pid=1025 comm="mmap_test"
scontext=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023
tcontext=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023
tclass=memprotect
This patch corrects things so that when the above example is run by a
user without CAP_SYS_RAWIO the SELinux AVC is no longer generated as
the DAC capability check fails before the SELinux permission check.
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
cftype->write_string() just passes on the writeable buffer from kernfs
and there's no reason to add const restriction on the buffer. The
only thing const achieves is unnecessarily complicating parsing of the
buffer. Drop const from @buffer.
Acked-by: Li Zefan <lizefan@huawei.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Daniel Borkmann <dborkman@redhat.com>
Cc: Balbir Singh <bsingharora@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec
Steffen Klassert says:
1) Fix a sleep in atomic when pfkey_sadb2xfrm_user_sec_ctx()
is called from pfkey_compile_policy().
Fix from Nikolay Aleksandrov.
2) security_xfrm_policy_alloc() can be called in process and atomic
context. Add an argument to let the callers choose the appropriate
way. Fix from Nikolay Aleksandrov.
drivers/net/usb/r8152.c
drivers/net/xen-netback/netback.c
Both the r8152 and netback conflicts were simple overlapping
changes.
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into next
security_xfrm_policy_alloc can be called in atomic context so the
allocation should be done with GFP_ATOMIC. Add an argument to let the
callers choose the appropriate way. In order to do so a gfp argument
needs to be added to the method xfrm_policy_alloc_security in struct
security_operations and to the internal function
selinux_xfrm_alloc_user. After that switch to GFP_ATOMIC in the atomic
callers and leave GFP_KERNEL as before for the rest.
The path that needed the gfp argument addition is:
security_xfrm_policy_alloc -> security_ops.xfrm_policy_alloc_security ->
all users of xfrm_policy_alloc_security (e.g. selinux_xfrm_policy_alloc) ->
selinux_xfrm_alloc_user (here the allocation used to be GFP_KERNEL only)
Now adding a gfp argument to selinux_xfrm_alloc_user requires us to also
add it to security_context_to_sid which is used inside and prior to this
patch did only GFP_KERNEL allocation. So add gfp argument to
security_context_to_sid and adjust all of its callers as well.
CC: Paul Moore <paul@paul-moore.com>
CC: Dave Jones <davej@redhat.com>
CC: Steffen Klassert <steffen.klassert@secunet.com>
CC: Fan Du <fan.du@windriver.com>
CC: David S. Miller <davem@davemloft.net>
CC: LSM list <linux-security-module@vger.kernel.org>
CC: SELinux list <selinux@tycho.nsa.gov>
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
This fixes CVE-2014-0102.
The following command sequence produces an oops:
keyctl new_session
i=`keyctl newring _ses @s`
keyctl link @s $i
The problem is that search_nested_keyrings() sees two keyrings that have
matching type and description, so keyring_compare_object() returns true.
s_n_k() then passes the key to the iterator function -
keyring_detect_cycle_iterator() - which *should* check to see whether this is
the keyring of interest, not just one with the same name.
Because assoc_array_find() will return one and only one match, I assumed that
the iterator function would only see an exact match or never be called - but
the iterator isn't only called from assoc_array_find()...
The oops looks something like this:
kernel BUG at /data/fs/linux-2.6-fscache/security/keys/keyring.c:1003!
invalid opcode: 0000 [#1] SMP
RIP: keyring_detect_cycle_iterator+0xe/0x1f
Call Trace:
search_nested_keyrings+0x76/0x2aa
__key_link_check_live_key+0x50/0x5f
key_link+0x4e/0x85
keyctl_keyring_link+0x60/0x81
SyS_keyctl+0x65/0xe4
tracesys+0xdd/0xe2
The fix is to make keyring_detect_cycle_iterator() check that the key it
has is the key it was actually looking for rather than calling BUG_ON().
A testcase has been included in the keyutils testsuite for this:
http://git.kernel.org/cgit/linux/kernel/git/dhowells/keyutils.git/commit/?id=891f3365d07f1996778ade0e3428f01878a1790b
Reported-by: Tommi Rantala <tt.rantala@gmail.com>
Acked-by: James Morris <james.l.morris@oracle.com>
If keys are not enabled, EVM is not visible in the configuration menu.
It may be difficult to figure out what to do unless you really know.
Other subsystems as NFS, CIFS select keys automatically. This patch does
the same.
This patch also removes '(TRUSTED_KEYS=y || TRUSTED_KEYS=n)' dependency,
which is unnecessary. EVM does not depend on trusted keys, but on
encrypted keys. evm.h provides compile time dependency.
Memory allocation is unnecessary for empty files.
This patch calculates the hash without memory allocation.
EVM does not use MD5 HMAC. Selection of CRYPTO_MD5 can be safely removed.
This is a small refactoring so ima_d_path() returns dentry name
if path reconstruction fails. It simplifies callers actions
and removes code duplication.
Between checkpatch changes (eg. sizeof) and inconsistencies between
Lindent and checkpatch, unfixed checkpatch errors make it difficult
to see new errors. This patch fixes them. Some lines with over 80 chars
remained unchanged to improve code readability.
The "extern" keyword is removed from internal evm.h to make it consistent
with internal ima.h.
ima_inode_post_setattr() calls ima_must_appraise() to check if the
file needs to be appraised. If it does not then it removes security.ima
xattr. With original policy matching code it might happen that even
file needs to be appraised with FILE_CHECK hook, it might not be
for POST_SETATTR hook. 'security.ima' might be erronously removed.
This patch treats POST_SETATTR as special wildcard function and will
cause ima_must_appraise() to be true if any of the hooks rules matches.
security.ima will not be removed if any of the hooks would require
appraisal.
Convert printks to pr_<level>.
Add pr_fmt.
Remove embedded prefixes.
Linux 3.13
include/net/xfrm.h
Simple merge where v3.13 removed 'extern' from definitions and the audit
tree did s/u32/unsigned int/ to the same definitions.
Before this change, to correctly calculate the template digest for the
'ima' template, the event name field (id: 'n') length was set to the fixed
size of 256 bytes.
This patch reduces the length of the event name field to the string
length incremented of one (to make room for the termination character '\0')
and handles the specific case of the digest calculation for the 'ima'
template directly in ima_calc_field_array_hash_tfm().
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
With the new template mechanism introduced in IMA since kernel 3.13,
the format of data sent through the binary_runtime_measurements interface
is slightly changed. Now, for a generic measurement, the format of
template data (after the template name) is:
template_len | field1_len | field1 | ... | fieldN_len | fieldN
In addition, fields containing a string now include the '\0' termination
character.
Instead, the format for the 'ima' template should be:
SHA1 digest | event name length | event name
It must be noted that while in the IMA 3.13 code 'event name length' is
'IMA_EVENT_NAME_LEN_MAX + 1' (256 bytes), so that the template digest
is calculated correctly, and 'event name' contains '\0', in the pre 3.13
code 'event name length' is exactly the string length and 'event name'
does not contain the termination character.
The patch restores the behavior of the IMA code pre 3.13 for the 'ima'
template so that legacy userspace tools obtain a consistent behavior
when receiving data from the binary_runtime_measurements interface
regardless of which kernel version is used.
Cc: <stable@vger.kernel.org> # 3.3.13: 3ce1217 ima: define template fields library
When we pass task->comm to audit_log_untrustedstring(), we need to pass it
via get_task_comm() because task->comm can be changed to contain untrusted
string by other threads after audit_log_untrustedstring() confirmed that
task->comm does not contain untrusted string.
A const char pointer allocates memory for a pointer as well as for
a string, This patch replaces a number of the const char pointers
throughout IMA, with a static const char array.
Suggested-by: David Howells <dhowells@redhat.com>
Currently, cap_dentry_init_security returns 0 without actually
initializing the security label. This confuses its only caller
(nfs4_label_init_security) which expects an error in that situation, and
causes it to end up sending out junk onto the wire instead of simply
suppressing the label in the attributes sent.
When CONFIG_SECURITY is disabled, security_dentry_init_security returns
-EOPNOTSUPP. Have cap_dentry_init_security do the same.
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Convert all compat system call functions where all parameter types
have a size of four or less than four bytes, or are pointer types
to COMPAT_SYSCALL_DEFINE.
The implicit casts within COMPAT_SYSCALL_DEFINE will perform proper
zero and sign extension to 64 bit of all parameters if needed.
drivers/net/wireless/ath/ath9k/recv.c
drivers/net/wireless/mwifiex/pcie.c
net/ipv6/sit.c
The SIT driver conflict consists of a bug fix being done by hand
in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper
was created (netdev_alloc_pcpu_stats()) which takes care of this.
The two wireless conflicts were overlapping changes.
Replace "file->f_dentry->d_inode" with the new file_inode() helper
function.
Signed-off-by: Libo Chen <clbchenlibo.chen@huawei.com>
into for-linus
When writing policy via /sys/fs/selinux/policy I wrote the type and class
of filename trans rules in CPU endian instead of little endian. On
x86_64 this works just fine, but it means that on big endian arch's like
ppc64 and s390 userspace reads the policy and converts it from
le32_to_cpu. So the values are all screwed up. Write the values in le
format like it should have been to start.
Signed-off-by: Eric Paris <eparis@redhat.com>
