path: root/security
2014-06-05Merge branch 'linux-3.10.40' into rel-21Ishan Mittal
Bug 200004122 Conflicts: drivers/cpufreq/cpufreq.c drivers/regulator/core.c sound/soc/codecs/max98090.c Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-05-29Merge branch 'android-3.10' into rel-21Ishan Mittal
Bug 200004122 Bug 1511804 This merge takes AOSP commits from android-3.10 branch Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-05-14Revert "security: tlk_driver: Allow affinity changing"Arto Merilainen
This reverts commit 7f6caab3a015a82c3f5b8842a5bd461d61d34af1. The commit introduced a modification that made threads to change affinity to ensure that the CPU can be changed. However, this approach was not bullet proof and it was fixed in a separate patch. Bug 1506585 Change-Id: I3e280a5fae1f63015032f62b45c333344411e5da Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/408076 Reviewed-by: Riham Haidar <rhaidar@nvidia.com> Tested-by: Riham Haidar <rhaidar@nvidia.com>
2014-05-14security: tlk_driver: Run kthreads on CPU0Arto Merilainen
Currently, the driver assumes that smc requests come either from workqueue or from a thread that has possibility to set cpu affinity. However, kernel threads by default do not have this possibility and in principle the flag can be set in middle of operation. Turning on devices is sometimes done in kernel threads and in GPU case we may need to change i.e. the VPR parameters. Therefore, ensure that the communication is done on CPU0. Bug 1506585 Change-Id: I0cbd8b841a07c8400310167fa8800eaae9de21f2 Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/408075 Reviewed-by: Riham Haidar <rhaidar@nvidia.com> Tested-by: Riham Haidar <rhaidar@nvidia.com>
2014-05-14security: tlk_driver: modify secure storage glueVarun Wadekar
The secure world now sends a PREEMPT_BY_FS error code as a result of OpenSession/LaunchOp call. This indicates a pending FS request from the secure world which we need to handle and send the FS_COMPLETION SMC on completion. Until the secure firmware and the linux driver get in sync, we keep legacy SS handling alive to avoid incomaptibility issues. Once the secure firmware switches to the new handling, we would remove the legacy support from the linux driver as well. Bug 1500621 Change-Id: I9e84cd5a87d820107b1c2279c9d89dcd5c31b44b Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/375994 (cherry picked from commit 433d8d1687725ab7db23eef27e5a073e8d88e862) Reviewed-on: http://git-master/r/406769 Reviewed-by: Riham Haidar <rhaidar@nvidia.com> Tested-by: Riham Haidar <rhaidar@nvidia.com>
2014-05-13security: tlk_driver: ensure VPR SMC occurs on CPU0Chris Johnson
The te_set_vpr_params routine is called both by normal user mode threads and worker threads as part of a free/shrink of VPR. The calls from worker threads, will fail in sched_setaffinity() because they have PF_NO_SETAFFINITY set, so previously no switch occurred and the SMC issued on something other than CPU0. This change detects the worker thread case, and if needed, issues a work_on_cpu() instead for the VPR programming. Bug 1473456 Change-Id: I76fa71c577e243b073cabb93928e688fdf7833ec Signed-off-by: Chris Johnson <cwj@nvidia.com> Reviewed-on: http://git-master/r/385924 (cherry picked from commit 30fed4ced5517c8c78b34d3a8db734263cf5d798) Reviewed-on: http://git-master/r/406698 Reviewed-by: Arto Merilainen <amerilainen@nvidia.com> Tested-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
2014-05-12security: tlk_driver: Allow affinity changingArto Merilainen
Currently the driver assumes that smc requests come from a thread that already has possibility to set cpu affinity, however, kernel threads by default do not have this possibility. Turning on devices is sometimes done in kernel threads and in GPU case we may need to change i.e. the VPR parameters. Therefore, ensure that the thread can change affinity. Bug 1506585 Change-Id: Ie879f6b2f7d8cb3bc324b5d7a391dd6e8cf9b3cf Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/405915 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
2014-05-01selinux: Report permissive mode in avc: denied messages.Stephen Smalley
We cannot presently tell from an avc: denied message whether access was in fact denied or was allowed due to global or per-domain permissive mode. Add a permissive= field to the avc message to reflect this information. Change-Id: I78176f8184e01226ece12f0eb38760cdcdc1ff87 Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
2014-04-23kernel: security: Remove tf_driver from kernelSharif Inamdar
Remove tf_driver and corresponding Trusted foundations use in the kernel as our kernel is open source and we cannot expose the code of Trusted Foundations. Change-Id: I2f6bef1b6ca4b002cd121c128918c7a222786522 Signed-off-by: Sharif Inamdar <isharif@nvidia.com> Reviewed-on: http://git-master/r/398968 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2014-04-14selinux: correctly label /proc inodes in use before the policy is loadedPaul Moore
commit f64410ec665479d7b4b77b7519e814253ed0f686 upstream. This patch is based on an earlier patch by Eric Paris, he describes the problem below: "If an inode is accessed before policy load it will get placed on a list of inodes to be initialized after policy load. After policy load we call inode_doinit() which calls inode_doinit_with_dentry() on all inodes accessed before policy load. In the case of inodes in procfs that means we'll end up at the bottom where it does: /* Default to the fs superblock SID. */ isec->sid = sbsec->sid; if ((sbsec->flags & SE_SBPROC) && !S_ISLNK(inode->i_mode)) { if (opt_dentry) { isec->sclass = inode_mode_to_security_class(...) rc = selinux_proc_get_sid(opt_dentry, isec->sclass, &sid); if (rc) goto out_unlock; isec->sid = sid; } } Since opt_dentry is null, we'll never call selinux_proc_get_sid() and will leave the inode labeled with the label on the superblock. I believe a fix would be to mimic the behavior of xattrs. Look for an alias of the inode. If it can't be found, just leave the inode uninitialized (and pick it up later) if it can be found, we should be able to call selinux_proc_get_sid() ..." On a system exhibiting this problem, you will notice a lot of files in /proc with the generic "proc_t" type (at least the ones that were accessed early in the boot), for example: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:proc_t:s0 /proc/sys/kernel/shmmax However, with this patch in place we see the expected result: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:sysctl_kernel_t:s0 /proc/sys/kernel/shmmax Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-09security: tlk: move ote_print_logs to common codeVarun Wadekar
Move ote_print_logs() calls to tlk_generic_smc and tlk_extended_smc so that it gets called after every secure firmware call. Change-Id: I1603a55440ebaf10cc727a442686e1ced8b18729 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/393219 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2014-04-09security: tlk: abort driver init if dev->req_param_buf is NULLVarun Wadekar
During driver init, we allocate memory for dev->req_param_buf if the secure firmware supports the new way of accessing request params. We need to check that dev->req_param_buf was allocated before using it. Change-Id: I796255274937f46fe01aeb1f5372c23bae830b85 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/393218 GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2014-04-09security: tlk: enable logging only if secure firmware supports itVarun Wadekar
We send an SMC to the secure firmware to see if it supports logging. If it returns failure, then we disable it from the kernel too. Change-Id: Icc59fc221f6f59d1806815333f3e71a35a45ea90 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/393217 GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2014-03-18security: tlk: Move program VPR smc to SIP callAaron Gamble
Change-Id: Ibd1dcd64c990b284926a15891902d2364df66c8e Signed-off-by: Aaron Gamble <jgamble@nvidia.com> Reviewed-on: http://git-master/r/380437 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2014-03-13Merge branch 'linux-3.10.33' into dev-kernel-3.10Deepak Nibade
Bug 1456092 Change-Id: Ic563f451abb08754fea0e2bbf0ce065ca2e6e770 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Bug 1456092 Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
2014-03-12security: tlk_driver: fix memory leak from tlk loggingHyung Taek Ryoo
This change to fix memory leak from tlk logging. Bug 1467162 Change-Id: I81d520ed4637861cbaab3bd7dcda063ecce9a123 Signed-off-by: Hyung Taek Ryoo <hryoo@nvidia.com> Reviewed-on: http://git-master/r/378071 (cherry picked from commit 50810a36bf0726c3df7f3d25f886e9852d43e13b) Reviewed-on: http://git-master/r/380740 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2014-03-10Merge branch 'android-3.10' into dev-kernel-3.10Deepak Nibade
Bug 1456092 Change-Id: Idd03c5e52e7aac49f4adede54802ca66f22d2ee3 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Bug 1456092 Change-Id: I87b6b883c382000fc0dfee7c8d8f36269f504e46 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
2014-03-06SELinux: bigendian problems with filename trans rulesEric Paris
commit 9085a6422900092886da8c404e1c5340c4ff1cbf upstream. When writing policy via /sys/fs/selinux/policy I wrote the type and class of filename trans rules in CPU endian instead of little endian. On x86_64 this works just fine, but it means that on big endian arch's like ppc64 and s390 userspace reads the policy and converts it from le32_to_cpu. So the values are all screwed up. Write the values in le format like it should have been to start. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-03security: tlk_driver: remove legacy ss supportScott Long
Remove support for legacy secure storage protocol now that the rest of TLK is using new protocol. Bug 1397251 Change-Id: Idbc99e46a58d77934d6c6dce41d1dcf0d175b8cc Signed-off-by: Scott Long <scottl@nvidia.com> Reviewed-on: http://git-master/r/369107 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Chris Johnson <cwj@nvidia.com> Tested-by: Chris Johnson <cwj@nvidia.com>
2014-02-20security: tlk_driver: support for secure ARM64 buildsChris Johnson
The only remaining warnings are in the non-compat path, which will be removed, once we get the ote/lib change to use the new structs. Bug 1432005 Change-Id: Ie0bc95a76a8d5ace91ca0b0bf69ac15852007dc7 Signed-off-by: Chris Johnson <cwj@nvidia.com> Reviewed-on: http://git-master/r/369403 Reviewed-by: Scott Long <scottl@nvidia.com>
2014-02-20SELinux: Fix kernel BUG on empty security contexts.Stephen Smalley
commit 2172fa709ab32ca60e86179dc67d0857be8e2c98 upstream. Setting an empty security context (length=0) on a file will lead to incorrectly dereferencing the type and other fields of the security context structure, yielding a kernel BUG. As a zero-length security context is never valid, just reject all such security contexts whether coming from userspace via setxattr or coming from the filesystem upon a getxattr request by SELinux. Setting a security context value (empty or otherwise) unknown to SELinux in the first place is only possible for a root process (CAP_MAC_ADMIN), and, if running SELinux in enforcing mode, only if the corresponding SELinux mac_admin permission is also granted to the domain by policy. In Fedora policies, this is only allowed for specific domains such as livecd for setting down security contexts that are not defined in the build host policy. Reproducer: su setenforce 0 touch foo setfattr -n security.selinux foo Caveat: Relabeling or removing foo after doing the above may not be possible without booting with SELinux disabled. Any subsequent access to foo after doing the above will also trigger the BUG. BUG output from Matthew Thode: [ 473.893141] ------------[ cut here ]------------ [ 473.962110] kernel BUG at security/selinux/ss/services.c:654! [ 473.995314] invalid opcode: 0000 [#6] SMP [ 474.027196] Modules linked in: [ 474.058118] CPU: 0 PID: 8138 Comm: ls Tainted: G D I 3.13.0-grsec #1 [ 474.116637] Hardware name: Supermicro X8ST3/X8ST3, BIOS 2.0 07/29/10 [ 474.149768] task: ffff8805f50cd010 ti: ffff8805f50cd488 task.ti: ffff8805f50cd488 [ 474.183707] RIP: 0010:[<ffffffff814681c7>] [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 474.219954] RSP: 0018:ffff8805c0ac3c38 EFLAGS: 00010246 [ 474.252253] RAX: 0000000000000000 RBX: ffff8805c0ac3d94 RCX: 0000000000000100 [ 474.287018] RDX: ffff8805e8aac000 RSI: 00000000ffffffff RDI: ffff8805e8aaa000 [ 474.321199] RBP: ffff8805c0ac3cb8 R08: 0000000000000010 R09: 0000000000000006 [ 474.357446] R10: 0000000000000000 R11: ffff8805c567a000 R12: 0000000000000006 [ 474.419191] R13: ffff8805c2b74e88 R14: 00000000000001da R15: 0000000000000000 [ 474.453816] FS: 00007f2e75220800(0000) GS:ffff88061fc00000(0000) knlGS:0000000000000000 [ 474.489254] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 474.522215] CR2: 00007f2e74716090 CR3: 00000005c085e000 CR4: 00000000000207f0 [ 474.556058] Stack: [ 474.584325] ffff8805c0ac3c98 ffffffff811b549b ffff8805c0ac3c98 ffff8805f1190a40 [ 474.618913] ffff8805a6202f08 ffff8805c2b74e88 00068800d0464990 ffff8805e8aac860 [ 474.653955] ffff8805c0ac3cb8 000700068113833a ffff880606c75060 ffff8805c0ac3d94 [ 474.690461] Call Trace: [ 474.723779] [<ffffffff811b549b>] ? lookup_fast+0x1cd/0x22a [ 474.778049] [<ffffffff81468824>] security_compute_av+0xf4/0x20b [ 474.811398] [<ffffffff8196f419>] avc_compute_av+0x2a/0x179 [ 474.843813] [<ffffffff8145727b>] avc_has_perm+0x45/0xf4 [ 474.875694] [<ffffffff81457d0e>] inode_has_perm+0x2a/0x31 [ 474.907370] [<ffffffff81457e76>] selinux_inode_getattr+0x3c/0x3e [ 474.938726] [<ffffffff81455cf6>] security_inode_getattr+0x1b/0x22 [ 474.970036] [<ffffffff811b057d>] vfs_getattr+0x19/0x2d [ 475.000618] [<ffffffff811b05e5>] vfs_fstatat+0x54/0x91 [ 475.030402] [<ffffffff811b063b>] vfs_lstat+0x19/0x1b [ 475.061097] [<ffffffff811b077e>] SyS_newlstat+0x15/0x30 [ 475.094595] [<ffffffff8113c5c1>] ? __audit_syscall_entry+0xa1/0xc3 [ 475.148405] [<ffffffff8197791e>] system_call_fastpath+0x16/0x1b [ 475.179201] Code: 00 48 85 c0 48 89 45 b8 75 02 0f 0b 48 8b 45 a0 48 8b 3d 45 d0 b6 00 8b 40 08 89 c6 ff ce e8 d1 b0 06 00 48 85 c0 49 89 c7 75 02 <0f> 0b 48 8b 45 b8 4c 8b 28 eb 1e 49 8d 7d 08 be 80 01 00 00 e8 [ 475.255884] RIP [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 475.296120] RSP <ffff8805c0ac3c38> [ 475.328734] ---[ end trace f076482e9d754adc ]--- Reported-by: Matthew Thode <mthode@mthode.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-16security: select correct default LSM_MMAP_MIN_ADDR on arm on arm64Colin Cross
Binaries compiled for arm may run on arm64 if CONFIG_COMPAT is selected. Set LSM_MMAP_MIN_ADDR to 32768 if ARM64 && COMPAT to prevent selinux failures launching 32-bit static executables that are mapped at 0x8000. Signed-off-by: Colin Cross <ccross@android.com> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> (cherry picked from upstream 3.14 commit 530b099dfe8499d639e7fbcad28c4199e2a720c7) Change-Id: I05d092d3539380e08e7daf0b9d2faae76147b72b Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com> Reviewed-on: http://git-master/r/367837
2014-02-13SELinux: Fix memory leak upon loading policyTetsuo Handa
commit 8ed814602876bec9bad2649ca17f34b499357a1c upstream. Hello. I got below leak with linux-3.10.0-54.0.1.el7.x86_64 . [ 681.903890] kmemleak: 5538 new suspected memory leaks (see /sys/kernel/debug/kmemleak) Below is a patch, but I don't know whether we need special handing for undoing ebitmap_set_bit() call. ---------- >>From fe97527a90fe95e2239dfbaa7558f0ed559c0992 Mon Sep 17 00:00:00 2001 From: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Date: Mon, 6 Jan 2014 16:30:21 +0900 Subject: SELinux: Fix memory leak upon loading policy Commit 2463c26d "SELinux: put name based create rules in a hashtable" did not check return value from hashtab_insert() in filename_trans_read(). It leaks memory if hashtab_insert() returns error. unreferenced object 0xffff88005c9160d0 (size 8): comm "systemd", pid 1, jiffies 4294688674 (age 235.265s) hex dump (first 8 bytes): 57 0b 00 00 6b 6b 6b a5 W...kkk. backtrace: [<ffffffff816604ae>] kmemleak_alloc+0x4e/0xb0 [<ffffffff811cba5e>] kmem_cache_alloc_trace+0x12e/0x360 [<ffffffff812aec5d>] policydb_read+0xd1d/0xf70 [<ffffffff812b345c>] security_load_policy+0x6c/0x500 [<ffffffff812a623c>] sel_write_load+0xac/0x750 [<ffffffff811eb680>] vfs_write+0xc0/0x1f0 [<ffffffff811ec08c>] SyS_write+0x4c/0xa0 [<ffffffff81690419>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff However, we should not return EEXIST error to the caller, or the systemd will show below message and the boot sequence freezes. systemd[1]: Failed to load SELinux policy. Freezing. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-09Revert "ARM: tegra: trustzone: Single kernel to work in both secure and ↵Varun Wadekar
non-secure mode." This reverts commit 7f93a0dddf39f372c064f772f9af6903e91aaacf as the t132ref builds break with the following errors - <android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:45: undefined reference to `is_secure_mode' <android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:57: undefined reference to `is_secure_mode' <android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:58: undefined reference to `tegra_generic_smc' Change-Id: I4e44c2ffba4e1c013213e543b67f2d49a928b764 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/365347
2014-02-09ARM: tegra: trustzone: Single kernel to work in both secure and non-secure mode.Nitin Sehgal
- Remove CONFIG_TEGRA_USE_SECURE_KERNEL config option - Use DBGDSCR.NS bit to dynamically get secure/non-secure mode - Replace ifdefs with dynamic code. - Keep CONFIG_TRUSTED_LITTLE_KERNEL to enable secure os bug 1411345 Change-Id: I75ddfed7a35fcb30e2772bb43057ae022bcf09b3 Signed-off-by: Nitin Sehgal <nsehgal@nvidia.com> Reviewed-on: http://git-master/r/353155 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2014-02-07security: tlk_driver: stage new interface structsChris Johnson
The current structs passed between the client lib and kernel aren't sized to allow 64bit pointers to work. This code stages ioctls based on structs that can handle 32bit or 64bit references. Once the supporting TLK library and kernel changes are checked in, we'll flip over to using these code paths. Bug 1432005 Change-Id: I7fd1b479c6ddf436ea4e380607cbb5dcfce1b2c2 Signed-off-by: Chris Johnson <cwj@nvidia.com> Reviewed-on: http://git-master/r/364252 Reviewed-by: Scott Long <scottl@nvidia.com>
2014-02-07SELinux: Fix kernel BUG on empty security contexts.Stephen Smalley
Setting an empty security context (length=0) on a file will lead to incorrectly dereferencing the type and other fields of the security context structure, yielding a kernel BUG. As a zero-length security context is never valid, just reject all such security contexts whether coming from userspace via setxattr or coming from the filesystem upon a getxattr request by SELinux. Setting a security context value (empty or otherwise) unknown to SELinux in the first place is only possible for a root process (CAP_MAC_ADMIN), and, if running SELinux in enforcing mode, only if the corresponding SELinux mac_admin permission is also granted to the domain by policy. In Fedora policies, this is only allowed for specific domains such as livecd for setting down security contexts that are not defined in the build host policy. [On Android, this can only be set by root/CAP_MAC_ADMIN processes, and if running SELinux in enforcing mode, only if mac_admin permission is granted in policy. In Android 4.4, this would only be allowed for root/CAP_MAC_ADMIN processes that are also in unconfined domains. In current AOSP master, mac_admin is not allowed for any domains except the recovery console which has a legitimate need for it. The other potential vector is mounting a maliciously crafted filesystem for which SELinux fetches xattrs (e.g. an ext4 filesystem on a SDcard). However, the end result is only a local denial-of-service (DOS) due to kernel BUG. This fix is queued for 3.14.] Reproducer: su setenforce 0 touch foo setfattr -n security.selinux foo Caveat: Relabeling or removing foo after doing the above may not be possible without booting with SELinux disabled. Any subsequent access to foo after doing the above will also trigger the BUG. BUG output from Matthew Thode: [ 473.893141] ------------[ cut here ]------------ [ 473.962110] kernel BUG at security/selinux/ss/services.c:654! [ 473.995314] invalid opcode: 0000 [#6] SMP [ 474.027196] Modules linked in: [ 474.058118] CPU: 0 PID: 8138 Comm: ls Tainted: G D I 3.13.0-grsec #1 [ 474.116637] Hardware name: Supermicro X8ST3/X8ST3, BIOS 2.0 07/29/10 [ 474.149768] task: ffff8805f50cd010 ti: ffff8805f50cd488 task.ti: ffff8805f50cd488 [ 474.183707] RIP: 0010:[<ffffffff814681c7>] [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 474.219954] RSP: 0018:ffff8805c0ac3c38 EFLAGS: 00010246 [ 474.252253] RAX: 0000000000000000 RBX: ffff8805c0ac3d94 RCX: 0000000000000100 [ 474.287018] RDX: ffff8805e8aac000 RSI: 00000000ffffffff RDI: ffff8805e8aaa000 [ 474.321199] RBP: ffff8805c0ac3cb8 R08: 0000000000000010 R09: 0000000000000006 [ 474.357446] R10: 0000000000000000 R11: ffff8805c567a000 R12: 0000000000000006 [ 474.419191] R13: ffff8805c2b74e88 R14: 00000000000001da R15: 0000000000000000 [ 474.453816] FS: 00007f2e75220800(0000) GS:ffff88061fc00000(0000) knlGS:0000000000000000 [ 474.489254] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 474.522215] CR2: 00007f2e74716090 CR3: 00000005c085e000 CR4: 00000000000207f0 [ 474.556058] Stack: [ 474.584325] ffff8805c0ac3c98 ffffffff811b549b ffff8805c0ac3c98 ffff8805f1190a40 [ 474.618913] ffff8805a6202f08 ffff8805c2b74e88 00068800d0464990 ffff8805e8aac860 [ 474.653955] ffff8805c0ac3cb8 000700068113833a ffff880606c75060 ffff8805c0ac3d94 [ 474.690461] Call Trace: [ 474.723779] [<ffffffff811b549b>] ? lookup_fast+0x1cd/0x22a [ 474.778049] [<ffffffff81468824>] security_compute_av+0xf4/0x20b [ 474.811398] [<ffffffff8196f419>] avc_compute_av+0x2a/0x179 [ 474.843813] [<ffffffff8145727b>] avc_has_perm+0x45/0xf4 [ 474.875694] [<ffffffff81457d0e>] inode_has_perm+0x2a/0x31 [ 474.907370] [<ffffffff81457e76>] selinux_inode_getattr+0x3c/0x3e [ 474.938726] [<ffffffff81455cf6>] security_inode_getattr+0x1b/0x22 [ 474.970036] [<ffffffff811b057d>] vfs_getattr+0x19/0x2d [ 475.000618] [<ffffffff811b05e5>] vfs_fstatat+0x54/0x91 [ 475.030402] [<ffffffff811b063b>] vfs_lstat+0x19/0x1b [ 475.061097] [<ffffffff811b077e>] SyS_newlstat+0x15/0x30 [ 475.094595] [<ffffffff8113c5c1>] ? __audit_syscall_entry+0xa1/0xc3 [ 475.148405] [<ffffffff8197791e>] system_call_fastpath+0x16/0x1b [ 475.179201] Code: 00 48 85 c0 48 89 45 b8 75 02 0f 0b 48 8b 45 a0 48 8b 3d 45 d0 b6 00 8b 40 08 89 c6 ff ce e8 d1 b0 06 00 48 85 c0 49 89 c7 75 02 <0f> 0b 48 8b 45 b8 4c 8b 28 eb 1e 49 8d 7d 08 be 80 01 00 00 e8 [ 475.255884] RIP [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 475.296120] RSP <ffff8805c0ac3c38> [ 475.328734] ---[ end trace f076482e9d754adc ]--- [sds: commit message edited to note Android implications and to generate a unique Change-Id for gerrit] Change-Id: I4d5389f0cfa72b5f59dada45081fa47e03805413 Reported-by: Matthew Thode <mthode@mthode.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-02-05SELinux: Fix possible NULL pointer dereference in selinux_inode_permission()Steven Rostedt
commit 3dc91d4338d698ce77832985f9cb183d8eeaf6be upstream. While running stress tests on adding and deleting ftrace instances I hit this bug: BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 IP: selinux_inode_permission+0x85/0x160 PGD 63681067 PUD 7ddbe067 PMD 0 Oops: 0000 [#1] PREEMPT CPU: 0 PID: 5634 Comm: ftrace-test-mki Not tainted 3.13.0-rc4-test-00033-gd2a6dde-dirty #20 Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006 task: ffff880078375800 ti: ffff88007ddb0000 task.ti: ffff88007ddb0000 RIP: 0010:[<ffffffff812d8bc5>] [<ffffffff812d8bc5>] selinux_inode_permission+0x85/0x160 RSP: 0018:ffff88007ddb1c48 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000800000 RCX: ffff88006dd43840 RDX: 0000000000000001 RSI: 0000000000000081 RDI: ffff88006ee46000 RBP: ffff88007ddb1c88 R08: 0000000000000000 R09: ffff88007ddb1c54 R10: 6e6576652f6f6f66 R11: 0000000000000003 R12: 0000000000000000 R13: 0000000000000081 R14: ffff88006ee46000 R15: 0000000000000000 FS: 00007f217b5b6700(0000) GS:ffffffff81e21000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033^M CR2: 0000000000000020 CR3: 000000006a0fe000 CR4: 00000000000007f0 Call Trace: security_inode_permission+0x1c/0x30 __inode_permission+0x41/0xa0 inode_permission+0x18/0x50 link_path_walk+0x66/0x920 path_openat+0xa6/0x6c0 do_filp_open+0x43/0xa0 do_sys_open+0x146/0x240 SyS_open+0x1e/0x20 system_call_fastpath+0x16/0x1b Code: 84 a1 00 00 00 81 e3 00 20 00 00 89 d8 83 c8 02 40 f6 c6 04 0f 45 d8 40 f6 c6 08 74 71 80 cf 02 49 8b 46 38 4c 8d 4d cc 45 31 c0 <0f> b7 50 20 8b 70 1c 48 8b 41 70 89 d9 8b 78 04 e8 36 cf ff ff RIP selinux_inode_permission+0x85/0x160 CR2: 0000000000000020 Investigating, I found that the inode->i_security was NULL, and the dereference of it caused the oops. in selinux_inode_permission(): isec = inode->i_security; rc = avc_has_perm_noaudit(sid, isec->sid, isec->sclass, perms, 0, &avd); Note, the crash came from stressing the deletion and reading of debugfs files. I was not able to recreate this via normal files. But I'm not sure they are safe. It may just be that the race window is much harder to hit. What seems to have happened (and what I have traced), is the file is being opened at the same time the file or directory is being deleted. As the dentry and inode locks are not held during the path walk, nor is the inodes ref counts being incremented, there is nothing saving these structures from being discarded except for an rcu_read_lock(). The rcu_read_lock() protects against freeing of the inode, but it does not protect freeing of the inode_security_struct. Now if the freeing of the i_security happens with a call_rcu(), and the i_security field of the inode is not changed (it gets freed as the inode gets freed) then there will be no issue here. (Linus Torvalds suggested not setting the field to NULL such that we do not need to check if it is NULL in the permission check). Note, this is a hack, but it fixes the problem at hand. A real fix is to restructure the destroy_inode() to call all the destructor handlers from the RCU callback. But that is a major job to do, and requires a lot of work. For now, we just band-aid this bug with this fix (it works), and work on a more maintainable solution in the future. Link: http://lkml.kernel.org/r/20140109101932.0508dec7@gandalf.local.home Link: http://lkml.kernel.org/r/20140109182756.17abaaa8@gandalf.local.home Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-03security: tlk_driver: add new storage supportScott Long
The existing storage protocol support will remain enabled until tlk can be switched over to the new protocol. Bug 1397251 Change-Id: I7186774e6fd6072f8260780b82203ce5d9ddf820 Signed-off-by: Scott Long <scottl@nvidia.com> Reviewed-on: http://git-master/r/361797 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Chris Johnson <cwj@nvidia.com>
2014-01-25SELinux: Fix possible NULL pointer dereference in selinux_inode_permission()Steven Rostedt
2014-01-09selinux: process labeled IPsec TCP SYN-ACK packets properly in ↵Paul Moore
selinux_ip_postroute() commit c0828e50485932b7e019df377a6b0a8d1ebd3080 upstream. Due to difficulty in arriving at the proper security label for TCP SYN-ACK packets in selinux_ip_postroute(), we need to check packets while/before they are undergoing XFRM transforms instead of waiting until afterwards so that we can determine the correct security label. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09selinux: look for IPsec labels on both inbound and outbound packetsPaul Moore
commit 817eff718dca4e54d5721211ddde0914428fbb7c upstream. Previously selinux_skb_peerlbl_sid() would only check for labeled IPsec security labels on inbound packets, this patch enables it to check both inbound and outbound traffic for labeled IPsec security labels. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09selinux: selinux_setprocattr()->ptrace_parent() needs rcu_read_lock()Oleg Nesterov
commit c0c1439541f5305b57a83d599af32b74182933fe upstream. selinux_setprocattr() does ptrace_parent(p) under task_lock(p), but task_struct->alloc_lock doesn't pin ->parent or ->ptrace, this looks confusing and triggers the "suspicious RCU usage" warning because ptrace_parent() does rcu_dereference_check(). And in theory this is wrong, spin_lock()->preempt_disable() doesn't necessarily imply rcu_read_lock() we need to access the ->parent. Reported-by: Evan McNabb <emcnabb@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09selinux: fix broken peer recv checkChad Hanson
commit 46d01d63221c3508421dd72ff9c879f61053cffc upstream. Fix a broken networking check. Return an error if peer recv fails. If secmark is active and the packet recv succeeds the peer recv error is ignored. Signed-off-by: Chad Hanson <chanson@trustedcs.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-08security: tlk_driver: delete TLK_{GENERIC|EXTENDED}_SMC macrosVarun Wadekar
Generic cleanup to remove unnecessary macros. Change-Id: Ia5d8c89622b9689c0c0a2658495cb4d33a2da7f5 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/351304
2014-01-03security: tlk_driver: delete te_pin_user_pages() and its usageSharif Inamdar
te_pin_user_pages() maps user pages, but the mapped pages never get used. Bug 1430582 Change-Id: I2d815f1d970e491058cf89cc9fef0f78b8e9764c Signed-off-by: Sharif Inamdar <isharif@nvidia.com> Reviewed-on: http://git-master/r/351021 (cherry picked from commit 7ac517f2203a41ffa4f703d9b18c46a8558873e0) Reviewed-on: http://git-master/r/351670 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2013-12-20selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute()Paul Moore
commit 446b802437f285de68ffb8d6fac3c44c3cab5b04 upstream. In selinux_ip_postroute() we perform access checks based on the packet's security label. For locally generated traffic we get the packet's security label from the associated socket; this works in all cases except for TCP SYN-ACK packets. In the case of SYN-ACK packet's the correct security label is stored in the connection's request_sock, not the server's socket. Unfortunately, at the point in time when selinux_ip_postroute() is called we can't query the request_sock directly, we need to recreate the label using the same logic that originally labeled the associated request_sock. See the inline comments for more explanation. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output()Paul Moore
commit 47180068276a04ed31d24fe04c673138208b07a9 upstream. In selinux_ip_output() we always label packets based on the parent socket. While this approach works in almost all cases, it doesn't work in the case of TCP SYN-ACK packets when the correct label is not the label of the parent socket, but rather the label of the larval socket represented by the request_sock struct. Unfortunately, since the request_sock isn't queued on the parent socket until *after* the SYN-ACK packet is sent, we can't lookup the request_sock to determine the correct label for the packet; at this point in time the best we can do is simply pass/NF_ACCEPT the packet. It must be said that simply passing the packet without any explicit labeling action, while far from ideal, is not terrible as the SYN-ACK packet will inherit any IP option based labeling from the initial connection request so the label *should* be correct and all our access controls remain in place so we shouldn't have to worry about information leaks. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-16Merge tag 'v3.10.24' into HEADAjay Nandakumar
This is the 3.10.24 stable release Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
2013-12-07security: tlk_driver: allocate uncached memory for FS operationsVarun Wadekar
Bug 1412144 Bug 1176001 Change-Id: If68806ee44a7009354efdda3d5cbf9e0e1f5f47f Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/339205
2013-12-07security: tlk_driver: forcibly map user pages if default mapping failsVarun Wadekar
There are instances when te_pin_user_pages() fails due to failure in get_user_pages(). We use default mapping policy to get user pages before pinning. But if default fails, then try using "force" option to map user pages. Bug 1412144 Bug 1176001 Change-Id: I661a15c86846816a8050ddfda7b58711c31f7aa5 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/338755
2013-12-04selinux: correct locking in selinux_netlbl_socket_connect)Paul Moore
commit 42d64e1add3a1ce8a787116036163b8724362145 upstream. The SELinux/NetLabel glue code has a locking bug that affects systems with NetLabel enabled, see the kernel error message below. This patch corrects this problem by converting the bottom half socket lock to a more conventional, and correct for this call-path, lock_sock() call. =============================== [ INFO: suspicious RCU usage. ] 3.11.0-rc3+ #19 Not tainted ------------------------------- net/ipv4/cipso_ipv4.c:1928 suspicious rcu_dereference_protected() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by ping/731: #0: (slock-AF_INET/1){+.-...}, at: [...] selinux_netlbl_socket_connect #1: (rcu_read_lock){.+.+..}, at: [<...>] netlbl_conn_setattr stack backtrace: CPU: 1 PID: 731 Comm: ping Not tainted 3.11.0-rc3+ #19 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 0000000000000001 ffff88006f659d28 ffffffff81726b6a ffff88003732c500 ffff88006f659d58 ffffffff810e4457 ffff88006b845a00 0000000000000000 000000000000000c ffff880075aa2f50 ffff88006f659d90 ffffffff8169bec7 Call Trace: [<ffffffff81726b6a>] dump_stack+0x54/0x74 [<ffffffff810e4457>] lockdep_rcu_suspicious+0xe7/0x120 [<ffffffff8169bec7>] cipso_v4_sock_setattr+0x187/0x1a0 [<ffffffff8170f317>] netlbl_conn_setattr+0x187/0x190 [<ffffffff8170f195>] ? netlbl_conn_setattr+0x5/0x190 [<ffffffff8131ac9e>] selinux_netlbl_socket_connect+0xae/0xc0 [<ffffffff81303025>] selinux_socket_connect+0x135/0x170 [<ffffffff8119d127>] ? might_fault+0x57/0xb0 [<ffffffff812fb146>] security_socket_connect+0x16/0x20 [<ffffffff815d3ad3>] SYSC_connect+0x73/0x130 [<ffffffff81739a85>] ? sysret_check+0x22/0x5d [<ffffffff810e5e2d>] ? trace_hardirqs_on_caller+0xfd/0x1c0 [<ffffffff81373d4e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff815d52be>] SyS_connect+0xe/0x10 [<ffffffff81739a59>] system_call_fastpath+0x16/0x1b Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-03security: tlk_driver: use ARM's DEN0028 v0.9 spec to define SMCsVarun Wadekar
Use Trusted Application calls (0x30000000-0x31000000) and Trusted OS calls (0x32000000-0x3F000000) from the spec. Trusted App calls are used to Open/Close session and launch a new operation. Trusted OS calls are used to talk with the TLK for IRQ handling, FS handling, VPR settings, logger init, etc. SMCs that are interrupted return a special status code to the NS world. Modify our tlk_driver to look for that status and send a restart SMC (value = 60 << 24) when received. Also removed save/restore of registers across SMC calls. This restore buffer was stored in r3 and expected to persist across the SMC. This saving/restoring isn't necessary and adds undesired overhead. Change-Id: I0b59604dfe2c4e3f4673797d756422cd7d5b64a3 Signed-off-by: Scott Long <scottl@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/332791 GVS: Gerrit_Virtual_Submit
2013-11-29Revert "ima: policy for RAMFS"Mimi Zohar
commit 08de59eb144d7c41351a467442f898d720f0f15f upstream. This reverts commit 4c2c392763a682354fac65b6a569adec4e4b5387. Everything in the initramfs should be measured and appraised, but until the initramfs has extended attribute support, at least measured. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-06security: tlk_driver: interface to program VPR base/lenJames Zhao
Add interface for the kernel to program vpr base address through TLK. Expect phys addr of vpr base, and vpr size. bug 1279160 Change-Id: I0ff6ef9783ac2bb6438afa0552f57a84e84bf567 Signed-off-by: James Zhao <jamesz@nvidia.com> Reviewed-on: http://git-master/r/302404 Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
2013-10-24security: tf_driver: remove tegra_read_cycle()Varun Wadekar
Tegra kernel now implements this function in a common place. Bug 1389113 Change-Id: I22f6448760fb10b4588f02d4d4b2b4fa76de8f90 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/303291
2013-10-24security: tlk_driver: remove tegra_read_cycle()Varun Wadekar
Tegra kernel now implements this function in a common place. Bug 1389113 Change-Id: Ie9bcd4267d0098136c18877ef67dd0da2fedbb4c Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/303290
2013-10-11security: tlk_driver: shared buffer loggingVarun Wadekar
Changes to TLK driver to allow logging for TLK via the linux kmsg file. Bug 1332411 Original author: Jay Patel <japatel@nvidia.com> Change-Id: I14d23d2598b391a98ca9e693ae47982da24e17cb Signed-off-by: Sharif Inamdar <isharif@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/289035
