path: root/security
2013-05-31selinux: fix the labeled xfrm/IPsec reference count handlingPaul Moore
The SELinux labeled IPsec code was improperly handling its reference counting, dropping a reference on a delete operation instead of on a free/release operation. Reported-by: Ondrej Moris <omoris@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-04-30Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge third batch of fixes from Andrew Morton: "Most of the rest. I still have two large patchsets against AIO and IPC, but they're a bit stuck behind other trees and I'm about to vanish for six days. - random fixlets - inotify - more of the MM queue - show_stack() cleanups - DMI update - kthread/workqueue things - compat cleanups - epoll udpates - binfmt updates - nilfs2 - hfs - hfsplus - ptrace - kmod - coredump - kexec - rbtree - pids - pidns - pps - semaphore tweaks - some w1 patches - relay updates - core Kconfig changes - sysrq tweaks" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits) Documentation/sysrq: fix inconstistent help message of sysrq key ethernet/emac/sysrq: fix inconstistent help message of sysrq key sparc/sysrq: fix inconstistent help message of sysrq key powerpc/xmon/sysrq: fix inconstistent help message of sysrq key ARM/etm/sysrq: fix inconstistent help message of sysrq key power/sysrq: fix inconstistent help message of sysrq key kgdb/sysrq: fix inconstistent help message of sysrq key lib/decompress.c: fix initconst notifier-error-inject: fix module names in Kconfig kernel/sys.c: make prctl(PR_SET_MM) generally available UAPI: remove empty Kbuild files menuconfig: print more info for symbol without prompts init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig display kconfig menu: move Virtualization drivers near other virtualization options Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKS relay: use macro PAGE_ALIGN instead of FIX_SIZE kernel/relay.c: move FIX_SIZE macro into relay.c kernel/relay.c: remove unused function argument actor drivers/w1/slaves/w1_ds2760.c: fix the error handling in w1_ds2760_add_slave() drivers/w1/slaves/w1_ds2781.c: fix the error handling in w1_ds2781_add_slave() ...
2013-04-30KEYS: split call to call_usermodehelper_fns()Lucas De Marchi
Use call_usermodehelper_setup() + call_usermodehelper_exec() instead of calling call_usermodehelper_fns(). In case there's an OOM in this last function the cleanup function may not be called - in this case we would miss a call to key_put(). Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem update from James Morris: "Just some minor updates across the subsystem" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: ima: eliminate passing d_name.name to process_measurement() TPM: Retry SaveState command in suspend path tpm/tpm_i2c_infineon: Add small comment about return value of __i2c_transfer tpm/tpm_i2c_infineon.c: Add OF attributes type and name to the of_device_id table entries tpm_i2c_stm_st33: Remove duplicate inclusion of header files tpm: Add support for new Infineon I2C TPM (SLB 9645 TT 1.2 I2C) char/tpm: Convert struct i2c_msg initialization to C99 format drivers/char/tpm/tpm_ppi: use strlcpy instead of strncpy tpm/tpm_i2c_stm_st33: formatting and white space changes Smack: include magic.h in smackfs.c selinux: make security_sb_clone_mnt_opts return an error on context mismatch seccomp: allow BPF_XOR based ALU instructions. Fix NULL pointer dereference in smack_inode_unlink() and smack_inode_rmdir() Smack: add support for modification of existing rules smack: SMACK_MAGIC to include/uapi/linux/magic.h Smack: add missing support for transmute bit in smack_str_from_perm() Smack: prevent revoke-subject from failing when unseen label is written to it tomoyo: use DEFINE_SRCU() to define tomoyo_ss tomoyo: use DEFINE_SRCU() to define tomoyo_ss
2013-04-29Merge branch 'for-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - Fixes and a lot of cleanups. Locking cleanup is finally complete. cgroup_mutex is no longer exposed to individual controlelrs which used to cause nasty deadlock issues. Li fixed and cleaned up quite a bit including long standing ones like racy cgroup_path(). - device cgroup now supports proper hierarchy thanks to Aristeu. - perf_event cgroup now supports proper hierarchy. - A new mount option "__DEVEL__sane_behavior" is added. As indicated by the name, this option is to be used for development only at this point and generates a warning message when used. Unfortunately, cgroup interface currently has too many brekages and inconsistencies to implement a consistent and unified hierarchy on top. The new flag is used to collect the behavior changes which are necessary to implement consistent unified hierarchy. It's likely that this flag won't be used verbatim when it becomes ready but will be enabled implicitly along with unified hierarchy. The option currently disables some of broken behaviors in cgroup core and also .use_hierarchy switch in memcg (will be routed through -mm), which can be used to make very unusual hierarchy where nesting is partially honored. It will also be used to implement hierarchy support for blk-throttle which would be impossible otherwise without introducing a full separate set of control knobs. This is essentially versioning of interface which isn't very nice but at this point I can't see any other options which would allow keeping the interface the same while moving towards hierarchy behavior which is at least somewhat sane. The planned unified hierarchy is likely to require some level of adaptation from userland anyway, so I think it'd be best to take the chance and update the interface such that it's supportable in the long term. Maintaining the existing interface does complicate cgroup core but shouldn't put too much strain on individual controllers and I think it'd be manageable for the foreseeable future. Maybe we'll be able to drop it in a decade. Fix up conflicts (including a semantic one adding a new #include to ppc that was uncovered by header the file changes) as per Tejun. * 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (45 commits) cpuset: fix compile warning when CONFIG_SMP=n cpuset: fix cpu hotplug vs rebuild_sched_domains() race cpuset: use rebuild_sched_domains() in cpuset_hotplug_workfn() cgroup: restore the call to eventfd->poll() cgroup: fix use-after-free when umounting cgroupfs cgroup: fix broken file xattrs devcg: remove parent_cgroup. memcg: force use_hierarchy if sane_behavior cgroup: remove cgrp->top_cgroup cgroup: introduce sane_behavior mount option move cgroupfs_root to include/linux/cgroup.h cgroup: convert cgroupfs_root flag bits to masks and add CGRP_ prefix cgroup: make cgroup_path() not print double slashes Revert "cgroup: remove bind() method from cgroup_subsys." perf: make perf_event cgroup hierarchical cgroup: implement cgroup_is_descendant() cgroup: make sure parent won't be destroyed before its children cgroup: remove bind() method from cgroup_subsys. devcg: remove broken_hierarchy tag cgroup: remove cgroup_lock_is_held() ...
2013-04-29tomoyo_close_control: don't bother with return valueAl Viro
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-18devcg: remove parent_cgroup.Rami Rosen
In devcgroup_css_alloc(), there is no longer need for parent_cgroup. bd2953ebbb("devcg: propagate local changes down the hierarchy") made the variable parent_cgroup redundant. This patch removes parent_cgroup from devcgroup_css_alloc(). Signed-off-by: Rami Rosen <ramirose@gmail.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-04-17ima: eliminate passing d_name.name to process_measurement()Mimi Zohar
Passing a pointer to the dentry name, as a parameter to process_measurement(), causes a race condition with rename() and is unnecessary, as the dentry name is already accessible via the file parameter. In the normal case, we use the full pathname as provided by brpm->filename, bprm->interp, or ima_d_path(). Only on ima_d_path() failure, do we fallback to using the d_name.name, which points either to external memory or d_iname. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-04-09selinux: add a skb_owned_by() hookEric Dumazet
Commit 90ba9b1986b5ac (tcp: tcp_make_synack() can use alloc_skb()) broke certain SELinux/NetLabel configurations by no longer correctly assigning the sock to the outgoing SYNACK packet. Cost of atomic operations on the LISTEN socket is quite big, and we would like it to happen only if really needed. This patch introduces a new security_ops->skb_owned_by() method, that is a void operation unless selinux is active. Reported-by: Miroslav Vadkerti <mvadkert@redhat.com> Diagnosed-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-security-module@vger.kernel.org Acked-by: James Morris <james.l.morris@oracle.com> Tested-by: Paul Moore <pmoore@redhat.com> Acked-by: Paul Moore <pmoore@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-08devcg: remove broken_hierarchy tagTejun Heo
bd2953ebbb ("devcg: propagate local changes down the hierarchy") implemented proper hierarchy support. Remove the broken tag. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Aristeu Rozanski <aris@redhat.com>
2013-04-03Smack: include magic.h in smackfs.cCasey Schaufler
As reported for linux-next: Tree for Apr 2 (smack) Add the required include for smackfs.c Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Reported-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-04-02selinux: make security_sb_clone_mnt_opts return an error on context mismatchJeff Layton
I had the following problem reported a while back. If you mount the same filesystem twice using NFSv4 with different contexts, then the second context= option is ignored. For instance: # mount server:/export /mnt/test1 # mount server:/export /mnt/test2 -o context=system_u:object_r:tmp_t:s0 # ls -dZ /mnt/test1 drwxrwxrwt. root root system_u:object_r:nfs_t:s0 /mnt/test1 # ls -dZ /mnt/test2 drwxrwxrwt. root root system_u:object_r:nfs_t:s0 /mnt/test2 When we call into SELinux to set the context of a "cloned" superblock, it will currently just bail out when it notices that we're reusing an existing superblock. Since the existing superblock is already set up and presumably in use, we can't go overwriting its context with the one from the "original" sb. Because of this, the second context= option in this case cannot take effect. This patch fixes this by turning security_sb_clone_mnt_opts into an int return operation. When it finds that the "new" superblock that it has been handed is already set up, it checks to see whether the contexts on the old superblock match it. If it does, then it will just return success, otherwise it'll return -EBUSY and emit a printk to tell the admin why the second mount failed. Note that this patch may cause casualties. The NFSv4 code relies on being able to walk down to an export from the pseudoroot. If you mount filesystems that are nested within one another with different contexts, then this patch will make those mounts fail in new and "exciting" ways. For instance, suppose that /export is a separate filesystem on the server: # mount server:/ /mnt/test1 # mount salusa:/export /mnt/test2 -o context=system_u:object_r:tmp_t:s0 mount.nfs: an incorrect mount option was specified ...with the printk in the ring buffer. Because we *might* eventually walk down to /mnt/test1/export, the mount is denied due to this patch. The second mount needs the pseudoroot superblock, but that's already present with the wrong context. OTOH, if we mount these in the reverse order, then both mounts work, because the pseudoroot superblock created when mounting /export is discarded once that mount is done. If we then however try to walk into that directory, the automount fails for the similar reasons: # cd /mnt/test1/scratch/ -bash: cd: /mnt/test1/scratch: Device or resource busy The story I've gotten from the SELinux folks that I've talked to is that this is desirable behavior. In SELinux-land, mounting the same data under different contexts is wrong -- there can be only one. Cc: Steve Dickson <steved@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-04-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/mac80211/sta_info.c net/wireless/core.h Two minor conflicts in wireless. Overlapping additions of extern declarations in net/wireless/core.h and a bug fix overlapping with the addition of a boolean parameter to __ieee80211_key_free(). Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull userns fixes from Eric W Biederman: "The bulk of the changes are fixing the worst consequences of the user namespace design oversight in not considering what happens when one namespace starts off as a clone of another namespace, as happens with the mount namespace. The rest of the changes are just plain bug fixes. Many thanks to Andy Lutomirski for pointing out many of these issues." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: userns: Restrict when proc and sysfs can be mounted ipc: Restrict mounting the mqueue filesystem vfs: Carefully propogate mounts across user namespaces vfs: Add a mount flag to lock read only bind mounts userns: Don't allow creation if the user is chrooted yama: Better permission check for ptraceme pid: Handle the exit of a multi-threaded init. scm: Require CAP_SYS_ADMIN over the current pidns to spoof pids.
2013-03-28selinux: replace obsolete NLMSG_* with type safe nlmsg_*Hong zhi guo
Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26yama: Better permission check for ptracemeEric W. Biederman
Change the permission check for yama_ptrace_ptracee to the standard ptrace permission check, testing if the traceer has CAP_SYS_PTRACE in the tracees user namespace. Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-20devcg: propagate local changes down the hierarchyAristeu Rozanski
This patch makes exception changes to propagate down in hierarchy respecting when possible local exceptions. New exceptions allowing additional access to devices won't be propagated, but it'll be possible to add an exception to access all of part of the newly allowed device(s). New exceptions disallowing access to devices will be propagated down and the local group's exceptions will be revalidated for the new situation. Example: A / \ B group behavior exceptions A allow "b 8:* rwm", "c 116:1 rw" B deny "c 1:3 rwm", "c 116:2 rwm", "b 3:* rwm" If a new exception is added to group A: # echo "c 116:* r" > A/devices.deny it'll propagate down and after revalidating B's local exceptions, the exception "c 116:2 rwm" will be removed. In case parent's exceptions change and local exceptions are not allowed anymore, they'll be deleted. v7: - do not allow behavior change when the cgroup has children - update documentation v6: fixed issues pointed by Serge Hallyn - only copy parent's exceptions while propagating behavior if the local behavior is different - while propagating exceptions, do not clear and copy parent's: it'd be against the premise we don't propagate access to more devices v5: fixed issues pointed by Serge Hallyn - updated documentation - not propagating when an exception is written to devices.allow - when propagating a new behavior, clean the local exceptions list if they're for a different behavior v4: fixed issues pointed by Tejun Heo - separated function to walk the tree and collect valid propagation targets v3: fixed issues pointed by Tejun Heo - update documentation - move css_online/css_offline changes to a new patch - use cgroup_for_each_descendant_pre() instead of own descendant walk - move exception_copy rework to a separared patch - move exception_clean rework to a separated patch v2: fixed issues pointed by Tejun Heo - instead of keeping the local settings that won't apply anymore, remove them Cc: Tejun Heo <tj@kernel.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Aristeu Rozanski <aris@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-20devcg: use css_online and css_offlineAristeu Rozanski
Allocate resources and change behavior only when online. This is needed in order to determine if a node is suitable for hierarchy propagation or if it's being removed. Locking: Both functions take devcgroup_mutex to make changes to device_cgroup structure. Hierarchy propagation will also take devcgroup_mutex before walking the tree while walking the tree itself is protected by rcu lock. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Tejun Heo <tj@kernel.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Aristeu Rozanski <aris@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-20devcg: prepare may_access() for hierarchy supportAristeu Rozanski
Currently may_access() is only able to verify if an exception is valid for the current cgroup, which has the same behavior. With hierarchy, it'll be also used to verify if a cgroup local exception is valid towards its cgroup parent, which might have different behavior. v2: - updated patch description - rebased on top of a new patch to expand the may_access() logic to make it more clear - fixed argument description order in may_access() Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Tejun Heo <tj@kernel.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Aristeu Rozanski <aris@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-20devcg: expand may_access() logicAristeu Rozanski
In order to make the next patch more clear, expand may_access() logic. v2: may_access() returns bool now Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Tejun Heo <tj@kernel.org> Cc: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Aristeu Rozanski <aris@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-19Fix NULL pointer dereference in smack_inode_unlink() and smack_inode_rmdir()Igor Zhbanov
This patch fixes kernel Oops because of wrong common_audit_data type in smack_inode_unlink() and smack_inode_rmdir(). When SMACK security module is enabled and SMACK logging is on (/smack/logging is not zero) and you try to delete the file which 1) you cannot delete due to SMACK rules and logging of failures is on or 2) you can delete and logging of success is on, you will see following: Unable to handle kernel NULL pointer dereference at virtual address 000002d7 [<...>] (strlen+0x0/0x28) [<...>] (audit_log_untrustedstring+0x14/0x28) [<...>] (common_lsm_audit+0x108/0x6ac) [<...>] (smack_log+0xc4/0xe4) [<...>] (smk_curacc+0x80/0x10c) [<...>] (smack_inode_unlink+0x74/0x80) [<...>] (security_inode_unlink+0x2c/0x30) [<...>] (vfs_unlink+0x7c/0x100) [<...>] (do_unlinkat+0x144/0x16c) The function smack_inode_unlink() (and smack_inode_rmdir()) need to log two structures of different types. First of all it does: smk_ad_init(&ad, __func__, LSM_AUDIT_DATA_DENTRY); smk_ad_setfield_u_fs_path_dentry(&ad, dentry); This will set common audit data type to LSM_AUDIT_DATA_DENTRY and store dentry for auditing (by function smk_curacc(), which in turn calls dump_common_audit_data(), which is actually uses provided data and logs it). /* * You need write access to the thing you're unlinking */ rc = smk_curacc(smk_of_inode(ip), MAY_WRITE, &ad); if (rc == 0) { /* * You also need write access to the containing directory */ Then this function wants to log anoter data: smk_ad_setfield_u_fs_path_dentry(&ad, NULL); smk_ad_setfield_u_fs_inode(&ad, dir); The function sets inode field, but don't change common_audit_data type. rc = smk_curacc(smk_of_inode(dir), MAY_WRITE, &ad); } So the dump_common_audit() function incorrectly interprets inode structure as dentry, and Oops will happen. This patch reinitializes common_audit_data structures with correct type. Also I removed unneeded smk_ad_setfield_u_fs_path_dentry(&ad, NULL); initialization, because both dentry and inode pointers are stored in the same union. Signed-off-by: Igor Zhbanov <i.zhbanov@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2013-03-19Smack: add support for modification of existing rulesRafal Krypa
Rule modifications are enabled via /smack/change-rule. Format is as follows: "Subject Object rwaxt rwaxt" First two strings are subject and object labels up to 255 characters. Third string contains permissions to enable. Fourth string contains permissions to disable. All unmentioned permissions will be left unchanged. If no rule previously existed, it will be created. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
2013-03-19smack: SMACK_MAGIC to include/uapi/linux/magic.hJarkko Sakkinen
SMACK_MAGIC moved to a proper place for easy user space access (i.e. libsmack). Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@iki.fi>
2013-03-19Smack: add missing support for transmute bit in smack_str_from_perm()Rafal Krypa
This fixes audit logs for granting or denial of permissions to show information about transmute bit. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
2013-03-19Smack: prevent revoke-subject from failing when unseen label is written to itRafal Krypa
Special file /smack/revoke-subject will silently accept labels that are not present on the subject label list. Nothing has to be done for such labels, as there are no rules for them to revoke. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
2013-03-19selinux: use GFP_ATOMIC under spin_lockDan Carpenter
The call tree here is: sk_clone_lock() <- takes bh_lock_sock(newsk); xfrm_sk_clone_policy() __xfrm_sk_clone_policy() clone_policy() <- uses GFP_ATOMIC for allocations security_xfrm_policy_clone() security_ops->xfrm_policy_clone_security() selinux_xfrm_policy_clone() Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable@kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-03-18tomoyo: use DEFINE_SRCU() to define tomoyo_ssLai Jiangshan
DEFINE_STATIC_SRCU() defines srcu struct and do init at build time. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-03-12Fix: compat_rw_copy_check_uvector() misuse in aio, readv, writev, and ↵Mathieu Desnoyers
security keys Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to compat_process_vm_rw() shows that the compatibility code requires an explicit "access_ok()" check before calling compat_rw_copy_check_uvector(). The same difference seems to appear when we compare fs/read_write.c:do_readv_writev() to fs/compat.c:compat_do_readv_writev(). This subtle difference between the compat and non-compat requirements should probably be debated, as it seems to be error-prone. In fact, there are two others sites that use this function in the Linux kernel, and they both seem to get it wrong: Now shifting our attention to fs/aio.c, we see that aio_setup_iocb() also ends up calling compat_rw_copy_check_uvector() through aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to be missing. Same situation for security/keys/compat.c:compat_keyctl_instantiate_key_iov(). I propose that we add the access_ok() check directly into compat_rw_copy_check_uvector(), so callers don't have to worry about it, and it therefore makes the compat call code similar to its non-compat counterpart. Place the access_ok() check in the same location where copy_from_user() can trigger a -EFAULT error in the non-compat code, so the ABI behaviors are alike on both compat and non-compat. While we are here, fix compat_do_readv_writev() so it checks for compat_rw_copy_check_uvector() negative return values. And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error handling. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-12keys: fix race with concurrent install_user_keyrings()David Howells
This fixes CVE-2013-1792. There is a race in install_user_keyrings() that can cause a NULL pointer dereference when called concurrently for the same user if the uid and uid-session keyrings are not yet created. It might be possible for an unprivileged user to trigger this by calling keyctl() from userspace in parallel immediately after logging in. Assume that we have two threads both executing lookup_user_key(), both looking for KEY_SPEC_USER_SESSION_KEYRING. THREAD A THREAD B =============================== =============================== ==>call install_user_keyrings(); if (!cred->user->session_keyring) ==>call install_user_keyrings() ... user->uid_keyring = uid_keyring; if (user->uid_keyring) return 0; <== key = cred->user->session_keyring [== NULL] user->session_keyring = session_keyring; atomic_inc(&key->usage); [oops] At the point thread A dereferences cred->user->session_keyring, thread B hasn't updated user->session_keyring yet, but thread A assumes it is populated because install_user_keyrings() returned ok. The race window is really small but can be exploited if, for example, thread B is interrupted or preempted after initializing uid_keyring, but before doing setting session_keyring. This couldn't be reproduced on a stock kernel. However, after placing systemtap probe on 'user->session_keyring = session_keyring;' that introduced some delay, the kernel could be crashed reliably. Fix this by checking both pointers before deciding whether to return. Alternatively, the test could be done away with entirely as it is checked inside the mutex - but since the mutex is global, that may not be the best way. Signed-off-by: David Howells <dhowells@redhat.com> Reported-by: Mateusz Guzik <mguzik@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-03-03userns: Stop oopsing in key_change_session_keyringEric W. Biederman
Dave Jones <davej@redhat.com> writes: > Just hit this on Linus' current tree. > > [ 89.621770] BUG: unable to handle kernel NULL pointer dereference at 00000000000000c8 > [ 89.623111] IP: [<ffffffff810784b0>] commit_creds+0x250/0x2f0 > [ 89.624062] PGD 122bfd067 PUD 122bfe067 PMD 0 > [ 89.624901] Oops: 0000 [#1] PREEMPT SMP > [ 89.625678] Modules linked in: caif_socket caif netrom bridge hidp 8021q garp stp mrp rose llc2 af_rxrpc phonet af_key binfmt_misc bnep l2tp_ppp can_bcm l2tp_core pppoe pppox can_raw scsi_transport_iscsi ppp_generic slhc nfnetlink can ipt_ULOG ax25 decnet irda nfc rds x25 crc_ccitt appletalk atm ipx p8023 psnap p8022 llc lockd sunrpc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_conntrack nf_conntrack ip6table_filter ip6_tables btusb bluetooth snd_hda_codec_realtek snd_hda_intel snd_hda_codec snd_pcm vhost_net snd_page_alloc snd_timer tun macvtap usb_debug snd rfkill microcode macvlan edac_core pcspkr serio_raw kvm_amd soundcore kvm r8169 mii > [ 89.637846] CPU 2 > [ 89.638175] Pid: 782, comm: trinity-main Not tainted 3.8.0+ #63 Gigabyte Technology Co., Ltd. GA-MA78GM-S2H/GA-MA78GM-S2H > [ 89.639850] RIP: 0010:[<ffffffff810784b0>] [<ffffffff810784b0>] commit_creds+0x250/0x2f0 > [ 89.641161] RSP: 0018:ffff880115657eb8 EFLAGS: 00010207 > [ 89.641984] RAX: 00000000000003e8 RBX: ffff88012688b000 RCX: 0000000000000000 > [ 89.643069] RDX: 0000000000000000 RSI: ffffffff81c32960 RDI: ffff880105839600 > [ 89.644167] RBP: ffff880115657ed8 R08: 0000000000000000 R09: 0000000000000000 > [ 89.645254] R10: 0000000000000001 R11: 0000000000000246 R12: ffff880105839600 > [ 89.646340] R13: ffff88011beea490 R14: ffff88011beea490 R15: 0000000000000000 > [ 89.647431] FS: 00007f3ac063b740(0000) GS:ffff88012b200000(0000) knlGS:0000000000000000 > [ 89.648660] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b > [ 89.649548] CR2: 00000000000000c8 CR3: 0000000122bfc000 CR4: 00000000000007e0 > [ 89.650635] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 > [ 89.651723] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 > [ 89.652812] Process trinity-main (pid: 782, threadinfo ffff880115656000, task ffff88011beea490) > [ 89.654128] Stack: > [ 89.654433] 0000000000000000 ffff8801058396a0 ffff880105839600 ffff88011beeaa78 > [ 89.655769] ffff880115657ef8 ffffffff812c7d9b ffffffff82079be0 0000000000000000 > [ 89.657073] ffff880115657f28 ffffffff8106c665 0000000000000002 ffff880115657f58 > [ 89.658399] Call Trace: > [ 89.658822] [<ffffffff812c7d9b>] key_change_session_keyring+0xfb/0x140 > [ 89.659845] [<ffffffff8106c665>] task_work_run+0xa5/0xd0 > [ 89.660698] [<ffffffff81002911>] do_notify_resume+0x71/0xb0 > [ 89.661581] [<ffffffff816c9a4a>] int_signal+0x12/0x17 > [ 89.662385] Code: 24 90 00 00 00 48 8b b3 90 00 00 00 49 8b 4c 24 40 48 39 f2 75 08 e9 83 00 00 00 48 89 ca 48 81 fa 60 29 c3 81 0f 84 41 fe ff ff <48> 8b 8a c8 00 00 00 48 39 ce 75 e4 3b 82 d0 00 00 00 0f 84 4b > [ 89.667778] RIP [<ffffffff810784b0>] commit_creds+0x250/0x2f0 > [ 89.668733] RSP <ffff880115657eb8> > [ 89.669301] CR2: 00000000000000c8 > > My fastest trinity induced oops yet! > > > Appears to be.. > > if ((set_ns == subset_ns->parent) && > 850: 48 8b 8a c8 00 00 00 mov 0xc8(%rdx),%rcx > > from the inlined cred_cap_issubset By historical accident we have been reading trying to set new->user_ns from new->user_ns. Which is totally silly as new->user_ns is NULL (as is every other field in new except session_keyring at that point). The intent is clearly to copy all of the fields from old to new so copy old->user_ns into into new->user_ns. Cc: stable@vger.kernel.org Reported-by: Dave Jones <davej@redhat.com> Tested-by: Dave Jones <davej@redhat.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more VFS bits from Al Viro: "Unfortunately, it looks like xattr series will have to wait until the next cycle ;-/ This pile contains 9p cleanups and fixes (races in v9fs_fid_add() etc), fixup for nommu breakage in shmem.c, several cleanups and a bit more file_inode() work" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: constify path_get/path_put and fs_struct.c stuff fix nommu breakage in shmem.c cache the value of file_inode() in struct file 9p: if v9fs_fid_lookup() gets to asking server, it'd better have hashed dentry 9p: make sure ->lookup() adds fid to the right dentry 9p: untangle ->lookup() a bit 9p: double iput() in ->lookup() if d_materialise_unique() fails 9p: v9fs_fid_add() can't fail now v9fs: get rid of v9fs_dentry 9p: turn fid->dlist into hlist 9p: don't bother with private lock in ->d_fsdata; dentry->d_lock will do just fine more file_inode() open-coded instances selinux: opened file can't have NULL or negative ->f_path.dentry (In the meantime, the hlist traversal macros have changed, so this required a semantic conflict fixup for the newly hlistified fid->dlist)
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27selinux: opened file can't have NULL or negative ->f_path.dentryAl Viro
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26kill f_vfsmntAl Viro
very few users left... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-26block: fix part_pack_uuid() build errorMimi Zohar
Commit "85865c1 ima: add policy support for file system uuid" introduced a CONFIG_BLOCK dependency. This patch defines a wrapper called blk_part_pack_uuid(), which returns -EINVAL, when CONFIG_BLOCK is not defined. security/integrity/ima/ima_policy.c:538:4: error: implicit declaration of function 'part_pack_uuid' [-Werror=implicit-function-declaration] Changelog v2: - Reference commit number in patch description Changelog v1: - rename ima_part_pack_uuid() to blk_part_pack_uuid() - resolve scripts/checkpatch.pl warnings Changelog v0: - fix UUID scripts/Lindent msgs Reported-by: Randy Dunlap <rdunlap@infradead.org> Reported-by: David Rientjes <rientjes@google.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-02-26ima: "remove enforce checking duplication" merge fixMimi Zohar
Commit "750943a ima: remove enforce checking duplication" combined the 'in IMA policy' and 'enforcing file integrity' checks. For the non-file, kernel module verification, a specific check for 'enforcing file integrity' was not added. This patch adds the check. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21device_cgroup: don't grab mutex in rcu callbackJerry Snitselaar
Commit 103a197c0c4e ("security/device_cgroup: lock assert fails in dev_exception_clean()") grabs devcgroup_mutex to fix assert failure, but a mutex can't be grabbed in rcu callback. Since there shouldn't be any other references when css_free is called, mutex isn't needed for list cleanup in devcgroup_css_free(). Signed-off-by: Jerry Snitselaar <jerry.snitselaar@oracle.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Aristeu Rozanski <aris@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "This is basically a maintenance update for the TPM driver and EVM/IMA" Fix up conflicts in lib/digsig.c and security/integrity/ima/ima_main.c * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (45 commits) tpm/ibmvtpm: build only when IBM pseries is configured ima: digital signature verification using asymmetric keys ima: rename hash calculation functions ima: use new crypto_shash API instead of old crypto_hash ima: add policy support for file system uuid evm: add file system uuid to EVM hmac tpm_tis: check pnp_acpi_device return code char/tpm/tpm_i2c_stm_st33: drop temporary variable for return value char/tpm/tpm_i2c_stm_st33: remove dead assignment in tpm_st33_i2c_probe char/tpm/tpm_i2c_stm_st33: Remove __devexit attribute char/tpm/tpm_i2c_stm_st33: Don't use memcpy for one byte assignment tpm_i2c_stm_st33: removed unused variables/code TPM: Wait for TPM_ACCESS tpmRegValidSts to go high at startup tpm: Fix cancellation of TPM commands (interrupt mode) tpm: Fix cancellation of TPM commands (polling mode) tpm: Store TPM vendor ID TPM: Work around buggy TPMs that block during continue self test tpm_i2c_stm_st33: fix oops when i2c client is unavailable char/tpm: Use struct dev_pm_ops for power management TPM: STMicroelectronics ST33 I2C BUILD STUFF ...
2013-02-21KEYS: Revert one application of "Fix unreachable code" patchDavid Howells
A patch to fix some unreachable code in search_my_process_keyrings() got applied twice by two different routes upstream as commits e67eab39bee2 and b010520ab3d2 (both "fix unreachable code"). Unfortunately, the second application removed something it shouldn't have and this wasn't detected by GIT. This is due to the patch not having sufficient lines of context to distinguish the two places of application. The effect of this is relatively minor: inside the kernel, the keyring search routines may search multiple keyrings and then prioritise the errors if no keys or negative keys are found in any of them. With the extra deletion, the presence of a negative key in the thread keyring (causing ENOKEY) is incorrectly overridden by an error searching the process keyring. So revert the second application of the patch. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-06ima: digital signature verification using asymmetric keysDmitry Kasatkin
Asymmetric keys were introduced in linux-3.7 to verify the signature on signed kernel modules. The asymmetric keys infrastructure abstracts the signature verification from the crypto details. This patch adds IMA/EVM signature verification using asymmetric keys. Support for additional signature verification methods can now be delegated to the asymmetric key infrastructure. Although the module signature header and the IMA/EVM signature header could use the same format, to minimize the signature length and save space in the extended attribute, this patch defines a new IMA/EVM header format. The main difference is that the key identifier is a sha1[12 - 19] hash of the key modulus and exponent, similar to the current implementation. The only purpose of the key identifier is to identify the corresponding key in the kernel keyring. ima-evm-utils was updated to support the new signature format. While asymmetric signature verification functionality supports many different hash algorithms, the hash used in this patch is calculated during the IMA collection phase, based on the configured algorithm. The default algorithm is sha1, but for backwards compatibility md5 is supported. Due to this current limitation, signatures should be generated using a sha1 hash algorithm. Changes in this patch: - Functionality has been moved to separate source file in order to get rid of in source #ifdefs. - keyid is derived according to the RFC 3280. It does not require to assign IMA/EVM specific "description" when loading X509 certificate. Kernel asymmetric key subsystem automatically generate the description. Also loading a certificate does not require using of ima-evm-utils and can be done using keyctl only. - keyid size is reduced to 32 bits to save xattr space. Key search is done using partial match functionality of asymmetric_key_match(). - Kconfig option title was changed Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-02-06ima: rename hash calculation functionsDmitry Kasatkin
Rename hash calculation functions to reflect meaning and change argument order in conventional way. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-02-06ima: use new crypto_shash API instead of old crypto_hashDmitry Kasatkin
Old crypto hash API internally uses shash API. Using shash API directly is more efficient. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-02-06ima: add policy support for file system uuidDmitry Kasatkin
The IMA policy permits specifying rules to enable or disable measurement/appraisal/audit based on the file system magic number. If, for example, the policy contains an ext4 measurement rule, the rule is enabled for all ext4 partitions. Sometimes it might be necessary to enable measurement/appraisal/audit only for one partition and disable it for another partition of the same type. With the existing IMA policy syntax, this can not be done. This patch provides support for IMA policy rules to specify the file system by its UUID (eg. fsuuid=397449cd-687d-4145-8698-7fed4a3e0363). For partitions not being appraised, it might be a good idea to mount file systems with the 'noexec' option to prevent executing non-verified binaries. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-02-06evm: add file system uuid to EVM hmacDmitry Kasatkin
EVM uses the same key for all file systems to calculate the HMAC, making it possible to paste inodes from one file system on to another one, without EVM being able to detect it. To prevent such an attack, it is necessary to make the EVM HMAC file system specific. This patch uses the file system UUID, a file system unique identifier, to bind the EVM HMAC to the file system. The value inode->i_sb->s_uuid is used for the HMAC hash calculation, instead of using it for deriving the file system specific key. Initializing the key for every inode HMAC calculation is a bit more expensive operation than adding the uuid to the HMAC hash. Changing the HMAC calculation method or adding additional info to the calculation, requires existing EVM labeled file systems to be relabeled. This patch adds a Kconfig HMAC version option for backwards compatability. Changelog v1: - squash "hmac version setting" Changelog v0: - add missing Kconfig depends (Mimi) Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
