path: root/sound/ac97_bus.c
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 152Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 3029 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-31Merge tag 'asoc-v4.2-rc8' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for v4.3 Not many updates to the core here, but an awful lot of driver updates this time round: - Factoring out of AC'97 reset code into the core - New drivers for Cirrus CS4349, GTM601, InvenSense ICS43432, Realtek RT298 and ST STI controllers. - Machine drivers for Rockchip systems with MAX98090 and RT5645 and RT5650. - Initial driver support for Intel Skylake devices. - A large number of cleanups for Lars-Peter Clausen and Axel Lin.
2015-08-21ALSA: ac97: Switch to dev_pm_opsLars-Peter Clausen
Convert the ac97_bus from legacy suspend/resume callbacks to dev_pm_ops. Since there isn't anything special to do at the bus level the bus driver does not have to implement any callbacks. The device driver core will automatically pick up and execute the device's PM ops. As there is only a single AC'97 driver implementing suspend and resume, update both the core and driver at the same time to avoid unnecessary code churn. While we are at it also drop the ifdefs around the suspend/resume functions to increase compile test coverage. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-23ALSA: ac97: Add helper function to reset the AC97 deviceLars-Peter Clausen
There is currently a lot of code duplication in ASoC drivers regarding the reset handling of devices. This patch introduces a new generic reset function in the generic AC'97 framework that can be used to replace most the custom reset functions. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Reviewed-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2010-12-06sound: Fixed line limit issue in sound/ac97_bus.cJeffrin Jose
This is a patch to the sound/ac97_bus.c file that fixes up a 80 character line limit issue found by the checkpatch.pl tool. Signed-off-by: Jeffrin Jose <ahiliation@yahoo.co.in> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-02ALSA: ac97 - Include ac97_codec.h for ac97_bus_type declarationMark Brown
This fixes a sparse warning caused by the lack of a connection with the prototype for ac97_bus_type. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2007-02-09[ALSA] ac97_bus power managementMartin Langer
This patch adds CONFIG_PM to the ac97_bus driver. Signed-off-by: Martin Langer <martin-langer@gmx.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-12[PATCH] remove config ordering/dependency between ucb1400-ts and sound subsystemNicolas Pitre
Commit 2d4ba4a3b9aef95d328d74a17ae84f8d658059e2 introduced a dependency that was never meant to exist when the ac97_bus.c module was created. Move ac97_bus.c up the directory hierarchy to make sure it is built when selected even if sound is configured out so things work as originally intended. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
