path: root/sound/aoa
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-28[ALSA] Enable stereo line input for TAS codecPaul Mackerras
Despite what the data sheet says in one place, to get stereo input from input A (line in), we have to clear the 'input B monaural' bit in the ACR. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-23[ALSA] aoa: add locking to tas codecJohannes Berg
Looks like I completely forgot to do this. This patch adds locking to the tas codec so two userspace programs can't hit the controls at the same time. Tested on my powerbook, but I obviously can't find any problems even without it since it doesn't do SMP. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Select I2C and I2C_POWERMAC in aoa/codecs/KconfigTakashi Iwai
Added the missing selection of I2C and I2C_POWERMAC for Onyx and TAS codecs in aoa/codecs/Kconfig. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-22[PATCH] aoa is pmac-onlyAl Viro
2006-08-08Merge branch 'merge'Paul Mackerras
2006-08-03[ALSA] aoa: platform function gpio: ignore errors from functions that don't ↵Johannes Berg
exist Sometimes we simply want to turn off or on everything, and when recently a warning was added when a certain platform function can't be called, this triggered all the time in those cases. This patch shows the warning only if the error was different from the function not existing. The alternative would be to not even try calling the function when it doesn't exist by first checking which exist and then only calling those that do, but that adds complexity that isn't necessary. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] aoa: fix toonie codecJohannes Berg
This patch fixes the toonie codec to be actually usable. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-03[ALSA] aoa: feature gpio layer: fix IRQ accessJohannes Berg
The IRQ rework caused some hiccups here, in some cases we call get_irq without a device node. This patch makes it catch that case and return NO_IRQ when it happens, along with changing the place where the irq is checked to check for NO_IRQ instead of -1. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-08-01Merge branch 'merge'Paul Mackerras
2006-07-31[POWERPC] sound: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. powerpc-specific sound driver changes. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-10[PATCH] aoa: tas: add missing bass/treble controlsJohannes Berg
This patch adds the bass/treble controls to snd-aoa that snd-powermac always had for tas3004 based machines. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: layout fabric: add missing module aliasesJohannes Berg
The layout fabric gained support for all IDs when I extracted those from the OSX description file. But apparently I had forgotten to add them all as module aliases so the module will also load. This patch adds them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: tas: surface DRC control againJohannes Berg
This patch makes the DRC control visible again for TAS chips. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: tas: fix initialisation/resetBenjamin Herrenschmidt
This patch fixes the initialisation and reset of the tas codec. The tas will often reset if the i2s clocks go away so it needs to be completely re-initialised when clocks come back. Also, this patch adds some code for DRC that will be exploited later to add a DRC control again, fixing a regression over snd-powermac. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: tas: change PCM1 name to PCMJohannes Berg
This patch changes the PCM1 control name to PCM to make it play nice with the softvol plugin (which will then go away if it sees a proper PCM slider) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa fabric layout: clean up messagesBenjamin Herrenschmidt
This patch cleans up the printk's in the layout fabric and also makes it display which type of GPIO access it is going to use. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: pmf gpio: report if function calling failsBenjamin Herrenschmidt
This patch makes the pmf GPIO layer in aoa report if calling a platform function failed. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: i2sbus: revamp control layerBenjamin Herrenschmidt
This patch revamps the i2sbus control layer by using the macio/keylargo functions instead of directly mapping. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: fix when all is built into the kernelBenjamin Herrenschmidt
This patch fixes initialisation issues when all of aoa is built into the kernel by re-ordering the link order in the Makefile and making the soundbus use subsys_initcall so it is initialised earlier. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: i2sbus: fix for PowerMac7,2 and 7,3Benjamin Herrenschmidt
This patch cleans up the resource handling in i2sbus and adds workarounds for the broken device trees on the PowerMac7,2 and 7,3. Some of this code will later move again when macio_asic is going to export all the sub-nodes too. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa: i2sbus: move module parameter declaration upBenjamin Herrenschmidt
This patch moves the i2sbus 'force' module parameter declaration to the top of the file. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] Fix snd-aoa irq conversionAndreas Schwab
Use proper irq mapping interface for snd-aoa-i2sbus. Signed-off-by: Andreas Schwab <schwab@suse.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[POWERPC] Add new interrupt mapping core and change platforms to use itBenjamin Herrenschmidt
This adds the new irq remapper core and removes the old one. Because there are some fundamental conflicts with the old code, like the value of NO_IRQ which I'm now setting to 0 (as per discussions with Linus), etc..., this commit also changes the relevant platform and driver code over to use the new remapper (so as not to cause difficulties later in bisecting). This patch removes the old pre-parsing of the open firmware interrupt tree along with all the bogus assumptions it made to try to renumber interrupts according to the platform. This is all to be handled by the new code now. For the pSeries XICS interrupt controller, a single remapper host is created for the whole machine regardless of how many interrupt presentation and source controllers are found, and it's set to match any device node that isn't a 8259. That works fine on pSeries and avoids having to deal with some of the complexities of split source controllers vs. presentation controllers in the pSeries device trees. The powerpc i8259 PIC driver now always requests the legacy interrupt range. It also has the feature of being able to match any device node (including NULL) if passed no device node as an input. That will help porting over platforms with broken device-trees like Pegasos who don't have a proper interrupt tree. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-28[ALSA] snd-aoa: enable dual-edge in GPIOsJohannes Berg
Apparently some firmware versions forget enabling the dual-edge bit, snd-powermac did that too and even OSX does sometimes. This should fix headphone plug detection on those machines. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-28[ALSA] snd-aoa: support iMac G5 iSightJohannes Berg
This properly adds support for the iMac G5 iSight. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-28[ALSA] snd-aoa: not experimentalJohannes Berg
The dependencies in the soundbus Kconfig were wrong, it isn't experimental any more. This patch fixes that and makes it select SND_PCM too instead of depending on it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-28[ALSA] Fix wrong dependencies of snd-aoa driverTakashi Iwai
Fixed wrong dependencies of snd-aoa driver. It selects PCM instead. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] aoa driver - Kconfig - remove spaces for SND!=nJaroslav Kysela
2006-06-22[ALSA] snd-aoa: add snd-aoaJohannes Berg
This large patch adds all of snd-aoa. Consisting of many modules, it currently replaces snd-powermac for all layout-id based machines and handles many more (for example new powerbooks and powermacs with digital output that previously couldn't be used at all). It also has support for all layout-IDs that Apple has (judging from their Info.plist file) but not all are tested. The driver currently has 2 known regressions over snd-powermac: * it doesn't handle powermac 7,2 and 7,3 * it doesn't have a DRC control on snapper-based machines I will fix those during the 2.6.18 development cycle. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
