azx chip should be stopped during HDA suspend and during
resume NV HDA controller should be initialized first
before initializing azx chip.
Bug 827122
Change-Id: Ifdfb5d041571eab00cad44d8609f8c80af939bc3
Reviewed-on: http://git-master/r/48167
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Disable HDA related clocks when device is not connected
to HDMI. HDA clocks will be enabled from HDMI driver when
HDMI device is hot plugged.
Also register a reboot notifier so that HDA clocks can
be enabled during device reboot since HDA driver needs to
stop the azx chip during reboot.
Bug 820213
Change-Id: Ib962ac418edf25c5681f108b9a80577dc55c42af
Reviewed-on: http://git-master/r/40543
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
This reverts commit c242bcd738fa47f833822f618eff4dbff092bde7.
Bug 820213
Bug 839572
Change-Id: I268a8c099ef75cd38b84aa31e35ab6417745cc10
Reviewed-on: http://git-master/r/40031
Bug 820213
Change-Id: I4e6839aab0dc5277b11c415cbb495766f72442b8
Reviewed-on: http://git-master/r/36517
Reviewed-by: Niranjan Wartikar <nwartikar@nvidia.com>
adding support for suspend resume in hda driver
Bug 808190
Bug 808132
Original-Change-Id: I6f142312cffb990ce5dd724b93ecacfc9543e8ae
Reviewed-on: http://git-master/r/24617
Tested-by: Dara Ramesh <dramesh@nvidia.com>
Change-Id: Ibefd60e840c1bc7e3f646143434f071401f0b15d
Adding nvhdmi codec driver support for tegra
Original-Change-Id: If4a71b74850c8684b62f059d24c28dd2f433789a
Reviewed-on: http://git-master/r/18187
Reviewed-by: Dara Ramesh <dramesh@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Change-Id: I27b51b0c88c2e173f42798a39d8c6eb8bbae89de
Adding HDA audio driver support for tegra
Original-Change-Id: I484177b4c8464d7e0084f60a2c51caa388ecae98
Reviewed-on: http://git-master/r/17871
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Change-Id: I737871669443db731987675f5cb89c377b272f2f
Adding HDA audio driver support for Tegra3
Original-Change-Id: I81a76a54f6ce5390051d96dbeadf447682f9ff0e
Reviewed-on: http://git-master/r/15405
Change-Id: I8525ef7317606b895818e73ec92ca174dddf609e
The commit 29a4f2d3 used writel() at offset 0x26 which is
half-word aligned causing unaligned exceptions on a
Cortex-A8. The original patch solved the "aaci-pl041 fpga:04:
ac97 read back fail" issue on a soft reset. Reading from any
arbitrary aaci register seems to solve this issue.
Signed-off-by: Philby John <pjohn@mvista.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This fixes a warning ("pxa_free_dma: trying to free channel 0 which is
already freed") when a device was opened but the hw_params() call
failed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Now most (if not all) PXA platforms have been switched to the new MFP
API, it's rather safe to remove these unnecessary pxa_gpio_mode() calls
in pxa2xx-ac97-lib.c now.
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
This is really pxa27x specific and should be kept in pxa27x.c. With this
newly introduced function, the original set_resetgpio_mode() is deprecated.
MFP registers are saved and restored by the mfp sys_device before all
other platform devices, and it is unnecessary here.
This patch fixes a build failure introduced by the patch
ALSA: AACI: factor common hw_params logic into aaci_pcm_hw_params [1]
by adding/moving the aaci struct to the right position.
The patch mentioned above merged common source parts into one function,
but unfortunately left out the aaci struct and consequently caused a
build failure e.g. for arm versatile_config [2]
References:
[1] http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=d3aee7996c30f928bbbbfd0994148e35d2e83084
[2] http://kisskb.ellerman.id.au/kisskb/buildresult/1893605/
Patch against Linus' tree.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
We can use finer-grained locking, which makes things easier when
we gain DMA support.
Since the recording and playback paths are now the same, eliminate
the needless conditionals.
There's no need for a specific rule; ALSA's generic AC'97 support
calculates the necessary rate constraint information itself, and
we can use this directly.
Fixed a typo of the max buffer size specified for buffer allocation
changed in the commit d6797322231af98b9bb4afb175dd614cf511e5f7.
Now snd_ac97_pcm_open() is called with the exactly same arguments
for both playback and capture directions. Remove the unneeded check.
pcm->r[1].slots is the double rate slot information, not the
capture information. For capture, 'pcm' will already be the
capture ac97 pcm structure.
Cc: <stable@kernel.org>
The call of dma_mmap_coherent() is done in the PCM core now.
Fix the buffer size calculation to use the size which ALSA is expecting.
After a reboot on an ARM1176 which amounts to a softreset, it has been
noted that the ALSA driver does not get registered and the probe fails
with the error "aaci-pl041 fpga:04: ac97 read back fail". In the process
of reading from a register the SL1TxBusy bit is set indicating that the
transceiver is busy and remains so until the default timeout occurs.
Set the Power down register 0x26 to an arbitrary value as specified in
the PL041 manual (page: 3-18) so that AACISL1TX/AACISL2TX registers take
their default state.
Signed-off-by: Philby John <pjohn@in.mvista.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Today's linux-next fails to build with
sound/arm/pxa2xx-ac97.c: In function 'pxa2xx_ac97_probe':
sound/arm/pxa2xx-ac97.c:211: error: 'pxa2xx_audio_ops_t' has no member named 'codec_data'
make[2]: *** [sound/arm/pxa2xx-ac97.o] Error 1
It looks like commit e2365bf313fb21b49b1e4c911033389564428d03 has
introduced this; patch below.
Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de>
Used for applications such as direct bluetooth connections on
smartphones which don't go via the CPU. This used to be supported
before the refactoring to share code but this check was removed
during that move.
This patch adds support for passing platform data to ac97 bus devices
from PXA2xx-AC97 driver..
Check for rtd->params->drcmr != NULL before accessing it.
I found the PrimeCell/AMBA Bus drivers distrusting the resource
passed in as part of the struct amba_device abstraction. This
patch removes all hard coded resource sizes found in the PrimeCell
drivers and move the responsibility of this definition back to
the platform/board device definition, which already exist and
appear to be correct for all in-tree users of these drivers.
We do this using the resource_size() inline function which was
also replicated in the only driver using the resource size, so
that has been changed too. The KMI_SIZE was left in kmi.h in case
someone likes it. Test-compiled against Versatile and Integrator
defconfigs, seems to work but I don't posess these boards and
cannot test them.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
The second argument of the probe method points to the amba_id
structure, so it's better passed with the correct type. None of the
current in-tree drivers uses the pointer, so they have only been
checked for a clean compile.
Change suggested by Russell King.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Eric Miao <eric.miao@marvell.com>
Currently there are two possible platform datas for the PXA AC97 driver:
one supported by the generic AC97 driver only which provides callbacks
to allow board-specific configuration at stream startup and teardown,
and another for pxa2xx-ac97-lib which allows configuration of the reset
GPIO for PXA2xx CPUs.
Obviously this won't actually work when using the generic AC97 driver
since the drivers will attempt to parse the platform data in both
formats. Fix this by merging the two structures.
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Marek Vasut <marek.vasut@gmail.com>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
the variable gsr_bit is set in isr. It is however set to 0 and interrupts are
disabled prior to reset. Hence it doesn't make a lot of sense to show the
content of gsr_bit in case of a reset timeout.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
sound/soc/pxa/pxa2xx-i2s.c
