path: root/sound/atmel
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation # extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 4122 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Enrico Weigelt <info@metux.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-02-06ALSA: atmel: Drop superfluous PCM preallocation error checksTakashi Iwai
snd_pcm_lib_preallocate_pages() and co always succeed, so the error check is simply redundant. Drop it. Reviewed-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2017-09-04Merge tag 'asoc-v4.14' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for v4.14 This is quite a large release by volume of patches and diff, a lot of that is mechanical cleanup patches but it's great to also see a range of vendors actively working on adding new features and fixing issues in their drivers. Intel and Realtek have been especially active here. - Continued work towards moving everything to the component model from Morimoto-san. - Use of devres for jack detection GPIOs, eliminating some potential resource leaks. - Jack detection support for Qualcomm MSM8916. - Support for Allwinner H3, Cirrus Logic CS43130, Intel Kabylake systems with RT5663, Realtek RT274, TI TLV320AIC32x6 and Wolfson WM8523.
2017-09-04ALSA: atmel: convert AC97c driver to GPIO descriptor APIAndy Shevchenko
Convert the driver to use GPIO descriptor API. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2017-08-31ALSA: ac97c: Fix an error handling path in 'atmel_ac97c_probe()'Christophe Jaillet
If 'clk_prepare_enable()' fails, we must release some resources before returning. Add a new label in the existing error handling path and 'goto' there. Fixes: 260ea95cc027 ("ASoC: atmel: ac97c: Handle return value of clk_prepare_enable.") Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2017-08-23ALSA: ac97c: constify ac97_pcm structuresArvind Yadav
ac97_pcm are not supposed to change at runtime. All functions working with ac97_pcm provided by <sound/ac97_codec.h> work with const ac97_pcm. So mark the non-const structs as const. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2017-08-19ALSA: atmel: constify snd_pcm_ops structuresArvind Yadav
snd_pcm_ops are not supposed to change at runtime. All functions working with snd_pcm_ops provided by <sound/pcm.h> work with const snd_pcm_ops. So mark the non-const structs as const. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2017-08-17ALSA: atmel: make snd_pcm_hardware constBhumika Goyal
Make this const as it is only used in a copy operation. Done using Coccinelle. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2017-07-26ASoC: atmel: ac97c: Handle return value of clk_prepare_enable.Arvind Yadav
clk_prepare_enable() can fail here and we must check its return value. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2017-07-01ALSA: atmel: ac97c: fix error return code in atmel_ac97c_probe()Gustavo A. R. Silva
platform_get_irq() returns an error code, but the ac97c driver ignores it and always returns -ENXIO. This is not correct, and prevents -EPROBE_DEFER from being propagated properly. Notice that platform_get_irq() no longer returns 0 on error. Print and propagate the return value of platform_get_irq on failure. Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2017-05-15ALSA: atmel: Remove AVR32 bits from the driverAndy Shevchenko
AVR32 is gone. Now it's time to clean up the driver by removing leftovers that was used by AVR32 related code. Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-05-20ALSA: sound/atmel/ac97c.c: remove unused variableArnd Bergmann
The recently added DT support for the ac97 driver is causing a gcc warning: sound/atmel/ac97c.c: In function 'atmel_ac97c_probe_dt': sound/atmel/ac97c.c:919:29: warning: unused variable 'match' [-Wunused-variable] const struct of_device_id *match; The variable is clearly unused, so we can remove it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alexander Stein <alexanders83@web.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-01-07ALSA: sound/atmel/ac97c.c: Add device tree supportAlexander Stein
This adds device tree support for the AC97 controller. It uses the soc-ac97link bindings, but actually only ac97-reset is used. Signed-off-by: Alexander Stein <alexanders83@web.de> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-27ALSA: atmel: fix building the ac97 driver for at91-multiplatformArnd Bergmann
at91 will no longer export the mach/cpu.h and mach/hardware.h header files in the future, which would break building the atmel ac97c driver. Since the cpu_is_* check is only used to find out whether we are running on avr32 or arm/at91, we can hardcode that check in the ARM case. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Link: http://www.spinics.net/lists/arm-kernel/msg382068.html Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-05ALSA: atmel_abdac: Add missing clock prepareAlexander Stein
Clocks must be prepared before enabling them. Do this in one step. Replace clk_enable with clk_prepare_enable and clk_disable with clk_disable_unprepare. Signed-off-by: Alexander Stein <alexanders83@web.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-05ALSA: sound/atmel/ac97c.c: Add missing clock prepareAlexander Stein
Clocks must be prepared before enabling them. Do this in one step. Replace clk_enable with clk_prepare_enable and clk_disable with clk_disable_unprepare. This fixes the following warning: ------------[ cut here ]------------ WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:895 __clk_enable+0x24/0x9c() Modules linked in: CPU: 0 PID: 1 Comm: swapper Tainted: G W 3.18.0-rc7+ #245 [<c000dce8>] (unwind_backtrace) from [<c000bcf0>] (show_stack+0x10/0x14) [<c000bcf0>] (show_stack) from [<c001664c>] (warn_slowpath_common+0x60/0x80) [<c001664c>] (warn_slowpath_common) from [<c00166fc>] (warn_slowpath_null+0x18/0x20) [<c00166fc>] (warn_slowpath_null) from [<c02fd7ac>] (__clk_enable+0x24/0x9c) [<c02fd7ac>] (__clk_enable) from [<c02fdbb4>] (clk_enable+0x18/0x2c) [<c02fdbb4>] (clk_enable) from [<c0322688>] (atmel_ac97c_probe+0x154/0x694) [<c0322688>] (atmel_ac97c_probe) from [<c0235e08>] (platform_drv_probe+0x48/0x94) [<c0235e08>] (platform_drv_probe) from [<c02345f8>] (driver_probe_device+0x138/0x350) [<c02345f8>] (driver_probe_device) from [<c02348bc>] (__driver_attach+0x68/0x8c) [<c02348bc>] (__driver_attach) from [<c0232bd0>] (bus_for_each_dev+0x70/0x84) [<c0232bd0>] (bus_for_each_dev) from [<c0233cd8>] (bus_add_driver+0xfc/0x1f8) [<c0233cd8>] (bus_add_driver) from [<c0234f0c>] (driver_register+0x9c/0xe0) [<c0234f0c>] (driver_register) from [<c0008ac4>] (do_one_initcall+0x110/0x1c8) [<c0008ac4>] (do_one_initcall) from [<c053cd58>] (kernel_init_freeable+0xf8/0x1b8) [<c053cd58>] (kernel_init_freeable) from [<c03c0414>] (kernel_init+0x8/0xe4) [<c03c0414>] (kernel_init) from [<c00096d0>] (ret_from_fork+0x14/0x24) ---[ end trace cb88537fdc8fa201 ]--- atmel_ac97c fffa0000.sound: AC'97 0 does not respond - RESET atmel_ac97c fffa0000.sound: AC'97 0 access is not valid [0xffffffff], removing mixer. ------------[ cut here ]------------ Signed-off-by: Alexander Stein <alexanders83@web.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-05ALSA: sound/atmel/ac97c.c: Fix device index for pcmAlexander Stein
chip->pdev->id is -1 by default. This is an invalid index resulting in device file names like /dev/snd/pcmC0D-1p. Signed-off-by: Alexander Stein <alexanders83@web.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-10-20ALSA: atmel: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-15dmaengine: dw: split dma-dw.h to platform and private partsAndy Shevchenko
The introduced include/linux/dma/dw.h is going to contain the private extensions and structures which are shared for dw_dmac users in the kernel. Meanwhile include/linux/platform_data/dma-dw.h keeps only platform related data types and definitions. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-09-11dmaengine: dw: move dw_dmac.h to where it belongs toAndy Shevchenko
There is a common storage for platform data related structures and definitions inside kernel source tree. The patch moves file from include/linux to include/linux/platform_data and renames it acoordingly. The users are also updated. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> [For the arch/avr32/.* and .*sound/atmel.*] Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-04-16ALSA: sound/atmel/ac97c.c: Convert to module_platform_driverAlexander Stein
This reduces some boilerplate code. Signed-off-by: Alexander Stein <alexanders83@web.de> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-14ALSA: atmel: Convert to snd_card_new() with a device pointerTakashi Iwai
Also remove superfluous snd_card_set_dev() calls. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-12-16Merge branch 'for-linus' into for-nextTakashi Iwai
2013-12-10ALSA: atmel_abdac: clk_round_rate() can return a zero upon errorPaul Walmsley
Treat both negative and zero return values from clk_round_rate() as errors. This is needed since subsequent patches will convert clk_round_rate()'s return value to be an unsigned type, rather than a signed type, since some clock sources can generate rates higher than (2^31)-1 Hz. Eventually, when calling clk_round_rate(), only a return value of zero will be considered a error; all other values will be considered valid rates. The comparison against values less than 0 is kept to preserve the correct behavior in the meantime. Signed-off-by: Paul Walmsley <pwalmsley@nvidia.com> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-12-02ALSA: atmel: Fix possible array overflowTakashi Iwai
The static checker found a possible array overflow in atmel/abdac.c: static checker warning: "sound/atmel/abdac.c:373 set_sample_rates() error: buffer overflow 'dac->rates' 6 <= 6" This patch papers over the buggy point, by ensuring that dac->rates[] update not overflowing the actual array size. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-05ALSA: atmel: remove dependency on <mach/gpio.h>Linus Walleij
This include is completely unused since the AT91 sound driver actually uses gpiolib properly. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-03ALSA: atmel: Remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-29ALSA: pcm_format_to_bits strong-typed conversionEldad Zack
Add a function to handle conversion from snd_pcm_format_t to bitwise with proper typing. Change such conversions to use this function and silence sparse warnings. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07ALSA: atmel: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: sound/atmel/ac97c.c: fix error return codeJulia Lawall
In the first case, the second test of whether retval is negative is redundant. It is dropped and the previous and subsequent tests are combined. In the second case, add an initialization of retval on failure of ioremap. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20ALSA: sound/atmel/abdac.c: fix error return codeJulia Lawall
Initialize retval before returning from a failed call to ioremap. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-09ALSA: platform: Check CONFIG_PM_SLEEP instead of CONFIG_PMTakashi Iwai
When CONFIG_PM is set but CONFIG_PM_SLEEP is unset, SIMPLE_DEV_PM_OPS() ignores the given functions, and this leads to compile warnings. For avoiding this, simply check CONFIG_PM_SLEEP instead of CONFIG_PM. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-03ALSA: convert PM ops of platform_driver to new pm opsTakashi Iwai
2012-07-02ALSA: Add missing .owner=THIS_MODULE to platform_driver definitionsTakashi Iwai
2012-05-11ALSA: atmel/ac97c: correct the unexpected behavior when using uninitial ↵Bo Shen
value for reset pin When pdata->reset_pin is passed with a negative value (means gpio is invalid), then chip->reset_pin will not be assigned to a vaule, it will use default value 0. This will cause unexpected behavior. So, add this patch to correct. Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-22dmaengine/dw_dmac: Fix dw_dmac user drivers to adapt to slave_config changesViresh Kumar
There are few existing user drivers of dw_dmac. They will break as soon as we remove unused fields from struct dw_dma_slave. This patch focuses to fix these user drivers to use dma_slave_config() routine. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-01-17Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits) ARM: mach-shmobile: specify CHCLR registers on SH7372 dma: shdma: fix runtime PM: clear channel buffers on reset dma/imx-sdma: save irq flags when use spin_lock in sdma_tx_submit dmaengine/ste_dma40: clear LNK on channel startup dmaengine: intel_mid_dma: remove legacy pm interface ASoC: mxs: correct 'direction' of device_prep_dma_cyclic dmaengine: intel_mid_dma: error path fix dmaengine: intel_mid_dma: locking and freeing fixes mtd: gpmi-nand: move to dma_transfer_direction mtd: fix compile error for gpmi-nand mmc: mxs-mmc: fix the dma_transfer_direction migration dmaengine: add DMA_TRANS_NONE to dma_transfer_direction dma: mxs-dma: Don't use CLKGATE bits in CTRL0 to disable DMA channels dma: mxs-dma: make mxs_dma_prep_slave_sg() multi user safe dma: mxs-dma: Always leave mxs_dma_init() with the clock disabled. dma: mxs-dma: fix a typo in comment DMA: PL330: Remove pm_runtime_xxx calls from pl330 probe/remove video i.MX IPU: Fix display connections i.MX IPU DMA: Fix wrong burstsize settings dmaengine/ste_dma40: allow fixed physical channel ... Fix up conflicts in drivers/dma/{Kconfig,mxs-dma.c,pl330.c} The conflicts looked pretty trivial, but I'll ask people to verify them.
2011-12-19ALSA: atmel/ac97c: using software reset instead hardware reset if not availableBo Shen
2011-10-31sound-soc: move to dma_transfer_directionVinod Koul
fixup usage of dma direction by introducing dma_transfer_direction, this patch moves asoc drivers to use new enum Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-06-28ALSA: atmel - update author email for ABDAC, AC97C and AT73C213Hans-Christian Egtvedt
This patch updates the email address of the sound drivers supported by me to an email account I will use on a more regular basis in the future. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-25ALSA: fix invalid hardware.h include in ac97c for AVR32 architectureHans-Christian Egtvedt
This patch fixes the non-compiling AC97C driver for AVR32 architecture by include mach/hardware.h only for AT91 architecture. The AVR32 architecture does not supply the hardware.h include file. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> CC: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: atmel - Fix the return value in error pathTakashi Iwai
In the commit c0763e687d0283d0db507813ca4462aa4073c5b5 ALSA: snd-atmel-abdac: test wrong variable the return value via PTR_ERR() had to be fixed as well. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: snd-atmel-abdac: test wrong variableVasiliy Kulikov
After clk_get() pclk is checked second time instead of sample_clk check. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-08ALSA: atmel: set "channel A event" output to debugYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-25ALSA: AC97: add full duplex support for atmel AT91 and AVR.Sedji Gaouaou
This patch add full duplex support on AT91 and AVR. It was a bug: we needed to check first if there are some chips opened so we could enable both reception and sending of the data. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-25ALSA: AC97: add AC97 support for AT91.Sedji Gaouaou
This patch add AC97 support for ATMEL AT91, using the AVR32 code. While AVR is using a DMA, the AT91 chips are using a Peripheral Data Controller. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
