[ Upstream commit f79a732a8325dfbd570d87f1435019d7e5501c6d ]
On partial_drain completion we should be in SNDRV_PCM_STATE_RUNNING
state, so set that for partially draining streams in
snd_compr_drain_notify() and use a flag for partially draining streams
While at it, add locks for stream state change in
snd_compr_drain_notify() as well.
Fixes: f44f2a5417b2 ("ALSA: compress: fix drain calls blocking other compress functions (v6)")
Reviewed-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Tested-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Reviewed-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Tested-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Signed-off-by: Vinod Koul <vkoul@kernel.org>
Link: https://lore.kernel.org/r/20200629134737.105993-4-vkoul@kernel.org
[ Upstream commit d3645b055399538415586ebaacaedebc1e5899b0 ]
Parameter fragments and fragment_size are type of u32. U32_MAX is
the correct check.
Signed-off-by: Xiaojun Sang <xsang@codeaurora.org>
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Acked-by: Vinod Koul <vkoul@kernel.org>
Link: https://lore.kernel.org/r/20191021095432.5639-1-srinivas.kandagatla@linaro.org
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 3b8179944cb0dd53e5223996966746cdc8a60657 ]
Draining makes little sense in the situation of hardware overrun, as the
hardware will have consumed all its available samples. Additionally,
draining whilst the stream is paused would presumably get stuck as no
data is being consumed on the DSP side.
Signed-off-by: Charles Keepax <ckeepax@opensource.cirrus.com>
[ Upstream commit 26c3f1542f5064310ad26794c09321780d00c57d ]
Currently, whilst in SNDRV_PCM_STATE_OPEN it is possible to call
snd_compr_stop, snd_compr_drain and snd_compr_partial_drain, which
allow a transition to SNDRV_PCM_STATE_SETUP. The stream should
only be able to move to the setup state once it has received a
SNDRV_COMPRESS_SET_PARAMS ioctl. Fix this issue by not allowing
those ioctls whilst in the open state.
[ Upstream commit 4475f8c4ab7b248991a60d9c02808dbb813d6be8 ]
A previous fix to the stop handling on compressed capture streams causes
some knock on issues. The previous fix updated snd_compr_drain_notify to
set the state back to PREPARED for capture streams. This causes some
issues however as the handling for snd_compr_poll differs between the
two states and some user-space applications were relying on the poll
failing after the stream had been stopped.
To correct this regression whilst still fixing the original problem the
patch was addressing, update the capture handling to skip the PREPARED
state rather than skipping the SETUP state as it has done until now.
Fixes: 4f2ab5e1d13d ("ALSA: compress: Fix stop handling on compressed capture streams")
commit c10368897e104c008c610915a218f0fe5fa4ec96 upstream.
Compress offload does not support ioctl calls from a 32bit userspace
in a 64 bit kernel. This patch adds support for ioctls from a 32bit
userspace in a 64bit kernel
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 678e2b44c8e3fec3afc7202f1996a4500a50be93 ]
The problem is seen in the q6asm_dai_compr_set_params() function:
ret = q6asm_map_memory_regions(dir, prtd->audio_client, prtd->phys,
(prtd->pcm_size / prtd->periods),
prtd->periods);
In this code prtd->pcm_size is the buffer_size and prtd->periods comes
from params->buffer.fragments. If we allow the number of fragments to
be zero then it results in a divide by zero bug. One possible fix would
be to use prtd->pcm_count directly instead of using the division to
re-calculate it. But I decided that it doesn't really make sense to
allow zero fragments.
commit a931b9ce93841a5b66b709ba5a244276e345e63b upstream.
Commit 04c5d5a430fc ("ALSA: compress: Embed struct device") removed
the statement that used 'str' but didn't remove the variable itself.
So remove it.
[Adding stable to Cc since pr_debug() may refer to the uninitialized
buffer -- tiwai]
Fixes: 04c5d5a430fc ("ALSA: compress: Embed struct device")
Signed-off-by: Guneshwor Singh <guneshwor.o.singh@intel.com>
commit 462b3f161beb62eeb290f4ec52f5ead29a2f8ac7 upstream.
Some architectures like PowerPC can handle the maximum struct size in
an ioctl only up to 13 bits, and struct snd_compr_codec_caps used by
SNDRV_COMPRESS_GET_CODEC_CAPS ioctl overflows this limit. This
problem was revealed recently by a powerpc change, as it's now treated
as a fatal build error.
This patch is a stop-gap for that: for architectures with less than 14
bit ioctl struct size, get rid of the handling of the relevant ioctl.
We should provide an alternative equivalent ioctl code later, but for
now just paper over it. Luckily, the compress API hasn't been used on
such architectures, so the impact must be effectively zero.
Reviewed-by: Mark Brown <broonie@kernel.org>
Acked-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Now that all callers have been replaced with
snd_device_register_for_dev(), let's drop the obsolete device
registration code and concentrate only on the code handling struct
device directly. That said,
- remove the old snd_device_register(),
- rename snd_device_register_for_dev() with snd_device_register(),
- drop superfluous arguments from snd_device_register(),
- change snd_unregister_device() to pass the device pointer directly
Reviewed-by: Jaroslav Kysela <perex@perex.cz>
Like previous patches, this one embeds the struct device into struct
snd_compr. As the dev field wasn't used beforehand, it's reused as
the new device struct.
I previously added an integer overflow check here but looking at it now,
it's still buggy.
The bug happens in snd_compr_allocate_buffer(). We multiply
".fragments" and ".fragment_size" and that doesn't overflow but then we
save it in an unsigned int so it truncates the high bits away and we
allocate a smaller than expected size.
Fixes: b35cc8225845 ('ALSA: compress_core: integer overflow in snd_compr_allocate_buffer()')
The snd_compr_open function would always return 0 even if the compressed
ops open function failed, obviously this is incorrect. Looks like this
was introduced by a small typo in:
commit a0830dbd4e42b38aefdf3fb61ba5019a1a99ea85
ALSA: Add a reference counter to card instance
This patch returns the value from the compressed op as it should.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Cc: <stable@vger.kernel.org>
commit f0e9c080 - "ALSA: compress: change the way sample rates are sent to
kernel" changed the way sample rates are sent. So now we don't need to check for
PCM_RATE_xxx in kernel
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Pausing audio playback is not an illegal state so it doesn't
seem sensible for poll() to return -EBADFD on a paused stream.
There's also no reason to assume that we can't write more data
to the DSP while playback is paused. Remove the -EBADFD so that
a stream in paused state will still report the buffer
availability from poll(). It is up to the user process to
manage its state so that it knows whether it is paused or not.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
Acked-by VInod Koul <vinod.koul@intel.com>
The drain and drain_notify callback were blocked by low level driver
until the draining was complete. Due to this being invoked with big
fat mutex held, others ops like reading timestamp, calling pause, drop
were blocked.
So to fix this we add a new snd_compr_drain_notify() API. This would
be required to be invoked by low level driver when drain or partial
drain has been completed by the DSP. Thus we make the drain and
partial_drain callback as non blocking and driver returns immediately
after notifying DSP. The waiting is done while releasing the lock so
that other ops can go ahead.
[ The commit 917f4b5cba78 was wrongly applied from the preliminary
patch. This commit corrects to the final version.
Sorry for inconvenience! -- tiwai ]
CC: stable@vger.kernel.org
The drain and drain_notify callback were blocked by low level driver untill the
draining was complete. Due to this being invoked with big fat mutex held, others
ops like reading timestamp, calling pause, drop were blocked.
So to fix this we add a new snd_compr_drain_notify() API. This would be required
to be invoked by low level driver when drain or partial drain has been completed
by the DSP. Thus we make the drain and partial_drain callback as non blocking
and driver returns immediately after notifying DSP.
The waiting is done while relasing the lock so that other ops can go ahead.
Currently we assume that userspace will shut down the compressed stream
correctly. However, if userspcae dies (e.g. cplay & ctrl-C) we dont
stop the stream before freeing it.
This now checks that the stream is stopped before freeing.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
snd_unregister_device() should return the device type and not stream
direction.
Tested-by: Vinod Koul <vinod.koul@intel.com>
the return value of SNDRV_COMPRESS_VERSION always return default -ENOTTY as the
return value was never updated for this call
assign return value from put_user()
Reported-by: Haynes <hgeorge@codeaurora.org>
for reading compressed data, we need to allow when we are paused, draining or
stopped.
Cc: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Cc: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Like the previous patch by Dan, we should clear the data to be
returned from certain compress ioctls, namely,
snd_compr_get_codec_caps() and snd_compr_get_params().
This time, we can simply replace kmalloc() with kzalloc().
If the ->get_caps() function doesn't clear the buffer then there would
stack information leaked to userspace. For example,
soc_compr_get_caps() can return success without clearing the buffer.
This patch reworks the writes to use cumulative values thus making the
app_pointer unecessary and removing it.
Only tested as far as build.
The buffer passed to the copy callback should not be const because the
copy callback can be used for capture and playback.
The app_pointer is managed locally by the compress core for memory
mapped DSPs but for DSPs that are not memory mapped this would have to
be manually updated from within the DSP driver itself, which is hardly
very idiomatic.
This patch switches to using the cumulative values to calculate the
available buffer space because these are already gracefully passed out
of the DSP driver to the compress core and otherwise should be
functionally equivalent.
this add new API for sound compress to support gapless playback.
As noted in Documentation change, we add API to send metadata of encoder and
padding delay to DSP. Also add API for indicating EOF and switching to
subsequent track
Also bump the compress API version
Signed-off-by: Jeeja KP <jeeja.kp@intel.com>
The snd_compr_update_tstamp() can only fill in the snd_compr_tstamp
if the codec implements the pointer() function. If that happened
the code was previously returning uninitialized garbage in the
tstamp because it wasn't initialized anywhere.
This change zero-fills the tstamp in the two places it is used
before calling snd_compr_update_tstamp(), and also has
snd_compr_update_tstamp() return an error indication if it
can't provide a tstamp. For the case of snd_compr_calc_avail()
it ignores this error because we still need to return info on
the available buffer space even if we can't provide tstamp
info - when the tstamp is not valid all fields are now
guaranteed to be zero.
For more strict protection for wild disconnections, a refcount is
introduced to the card instance, and let it up/down when an object is
referred via snd_lookup_*() in the open ops.
The free-after-last-close check is also changed to check this refcount
instead of the empty list, too.
Reported-by: Matthieu CASTET <matthieu.castet@parrot.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
Commit ALSA: compress_core: integer overflow in snd_compr_allocate_buffer()
added a new error check for input params.
this add new routine for input checks and moves buffer overflow check to this
new routine. This allows the error value to be propogated to user space
These are 32 bit values that come from the user, we need to check for
integer overflows or we could end up allocating a smaller buffer than
expected.
O_RDONLY is zero so the original test (f->f_flags & O_RDONLY) is always
false and it will never do compress capture. The test for O_WRONLY is
also slightly off. The original test would consider "->flags =
(O_WRONLY | O_RDWR)" as write only instead of rejecting it as invalid.
I've also removed the pr_err() because that could flood dmesg.
as the start can be called after stop again, we need to reset state
Signed-off-by: Namarta Kohli <namartax.kohli@intel.com>
during pause the core should maintain the status-quo on the device and pointers
and not wake up. If app needs it should call DROP explcitly.
If copy_from_user() does not return 0 we'll leak the memory we
allocated for 'params' when that variable goes out of scope.
Also a small CodingStyle cleanup: Use braces on both branches of
if/else when one branch needs it.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
This patch adds core.c, the file which implements the ioctls and
registers the devices
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
