path: root/sound/core/misc.c
2007-02-09[ALSA] Add PCI quirk list helper functionTakashi Iwai
Added a helper function snd_pci_quirk_lookup() to look up PCI SSID quirk list. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] Clean up EXPORT_SYMBOL()s in snd moduleTakashi Iwai
Move EXPORT_SYMBOL()s to places adjacent to functions/variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove kmalloc wrappersTakashi Iwai
Modules: ALSA Core Remove kmalloc wrappers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Make snd_task_name() module localTakashi Iwai
Modules: ALSA Core,ALSA<-OSS emulation Remove a global function snd_task_name(), and move it local to snd-pcm-oss module. Signed-off-by: Takashi Iwai <tiwai@suse.de>
