Drop a few variables that are never read.
Signed-off-by: Luca Tettamanti <kronos.it@gmail.com>
Change the core code where sparse complains. In most cases, this means
just adding annotations to confirm that we indeed want to do the dirty
things we're doing.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
snd_pcm_hw_param_near() will leak the memory allocated to 'save' if the
call to snd_pcm_hw_param_max() returns less than zero.
This patch makes sure we never leak.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
In OSS emulation, SNDCTL_DSP_RESET ioctl needs the reset of the internal
buffer state in addition to drop of the running streams. Otherwise the
succeeding access becomes inconsistent.
Tested-by: Amit Nagal <helloin.amit@gmail.com>
Cc: <stable@kernel.org>
Fix mutex release and cleanup some locking code.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Set no_llseek to llseek file ops of each sound component (but for hwdep).
This avoids the implicit BKL invocation via generic_file_llseek() used
as default when fops.llseek is NULL.
Also call nonseekable_open() at each open ops to ensure the file flags
have no seek bit.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Clemens Ladisch noted for hw_ptr_removal in "cleanup & merge hw_ptr
update functions" commit:
"It is possible for the status/delay ioctls to be called when the sound
card's pointer register alreay shows a position at the beginning of the
new period, but immediately before the interrupt is actually executed.
(This happens regularly on a SMP machine with mplayer.) When that
happens, the code thinks that the position must be at least one period
ahead of the current position and drops an entire buffer of data."
Return back the hw_ptr_interrupt variable. The last interrupt pointer
is always computed from the latest hw_ptr instead of tracking it
separately (in this case all hw_ptr checks and modifications might
influence also hw_ptr_interrupt and it is difficult to keep it
consistent).
Do general cleanup in snd_pcm_update_hw_ptr*() routines and merge them.
The main change is hw_ptr_interrupt variable removal to simplify code
logic. This variable can be computed directly from hw_ptr.
Ensure that updated hw_ptr is not lower than previous one (it was possible
with old code in some obscure situations when interrupt was delayed or
the lowlevel driver returns wrong ring buffer position value).
To unify control names, rename "PC Speaker" to "Speaker" for PPC ALSA drivers.
To avoid confusion in control names for the standard analog PC Beep generator
using a small Internal PC Speaker, rename all related "PC Speaker" and "PC
Beep" controls to "Beep" only. This name is more universal and can be also
used on more platforms without confusion.
Introduce also "Internal Speaker" in ControlNames.txt for systems with
full-featured build-in internal speaker.
* topic/oss:
ALSA: allocation may fail in snd_pcm_oss_change_params()
sound: vwsnd: Fix setting of cfgval and ctlval in li_setup_dma()
sound: fix OSS MIDI output data loss
Add appropriate const prefix to char * arguments in proc helper functions.
Also fixed the caller side to be proper const pointers.
Allocation may fail, show if it did.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
[Additional fix for invalid runtime->oss.prepare flag set by tiwai]
Replace the house-made div64_32() with the standard div_u64*() functions.
Added an else part to check
SNDRV_MIXER_OSS_PRESENT_CVOLUME for MIC (slot 7)
in commit 36c7b833e5d2501142a371e4e75281d3a29fbd6b
Similarly, checks and volume control is required for
SNDRV_MIXER_OSS_PRESENT_CSWITCH and SNDRV_MIXER_OSS_PRESENT_CROUTE
as well.
Signed-off-by: Deepika Makhija <deepika.makhija@einfochips.com>
Signed-off-by: Viral Mehta <viral.mehta@einfochips.com>
* 'bkl-removal' of git://git.lwn.net/linux-2.6:
Rationalize fasync return values
Move FASYNC bit handling to f_op->fasync()
Use f_lock to protect f_flags
Rename struct file->f_ep_lock
s/mutex_lock/mutex_unlock/ on 2 fail paths in snd_pcm_oss_proc_write.
Probably a typo, lock should be unlocked when leaving the function.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
At the time of initialization, SNDRV_MIXER_OSS_PRESENT_PVOLUME bit is not
set for MIC (slot 7).
So, the same should not be checked when an application tries to do gain
control for audio recording devices.
Just check slot->present for SNDRV_MIXER_OSS_PRESENT_CVOLUME independently.
Verified with a simple application which opens /dev/dsp for recording and
/dev/mixer for volume control.
Have tested two usb audio mic devices.
Traditionally, changes to struct file->f_flags have been done under BKL
protection, or with no protection at all. This patch causes all f_flags
changes after file open/creation time to be done under protection of
f_lock. This allows the removal of some BKL usage and fixes a number of
longstanding (if microscopic) races.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Incorrect variable was used to get the next sample which caused S2
to be stuck with the same value resulting in loud background noise.
Signed-off-by: Steve Chen <schen at mvista.com>
AFMT_S24_LE is set twice in return value
vi sound/core/oss/pcm_oss.c +640
#define AFMT_S24_LE 0x00008000
#define AFMT_S24_BE 0x00010000
Kill snd_assert() in sound/core/*, either removed or replaced with
if () with snd_BUG_ON().
SNDRV_CTL_IOCTL_PCM_NEXT_DEVICE"
This reverts commit fb3d6f2b77bdec75d45aa9d4464287ed87927866.
New, updated patch with same subject replaces this commit.
When compiled with CONFIG_SND_DYNAMIC_MINORS the ALSA core is fine
to have more than 8 PCM devices per card, except one place - the
SNDRV_CTL_IOCTL_PCM_NEXT_DEVICE ioctl, which will not enumerate
devices > 7. This patch fixes the issue, changing the devices list
organisation.
Instead of adding new device to the tail, the list is now kept always
ordered (by card number, then device number). Thus, during enumeration,
it is easy to discover the fact that there is no more given card's
devices. The same limit was present in OSS emulation code. It has
been fixed as well.
Additionally the device field of struct snd_pcm is now int, instead of
unsigned int, as there is no obvious reason for keeping it unsigned.
This caused a lot of problems with comparing this value with other
(almost always signed) variables. There is just one more place where
device number is unsigned - in struct snd_pcm_info, which should be
also sorted out in future.
Signed-off-by: Pawel MOLL <pawel.moll@st.com>
Added more fallbacks to OSS PHONEOUT mixer mapping. This corresponds
to the speaker output in general, so now "Mono" and "Speaker" are
assigned.
The PCM OSS emulation can cause Oops at sync operation due to the wrong
data size calculation. Typically happening on Sparc64:
http://lkml.org/lkml/2008/1/24/426
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
The 'tick' in PCM is set (again) via sw_params. And, nobody uses
this feature at all except for a command line option of aplay.
(This is literally 'nobody', as I checked alsa-lib API calls in all
programs in major distros.)
Above all, if we need finer wake-ups for the position update, it's
basically an issue that the driver should solve, not tuned by each
application.
The xfer_align sw_params parameter has never been used in a sane manner,
and no one understands what this does exactly. The current
implementation looks also buggy because it allows write of shorter size
than xfer_align. So, if you do partial writes, the write isn't actually
aligned at all.
Removing this parameter will make some pcm_lib_* code more readable
(and less buggy).
with gcc-3.2
Rework this functions so that gcc-3.2 can successfully perform
constant-folding.
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
The recent OSS includes the support for 32bit and other formats, which
we already have, too. Let's define and map them.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Add the support of 3-bytes 24bit formats in PCM OSS emulation.
Also removed snd_pcm_build_linear_format() function. It's exported
just for OSS emulation, and now the code was changed without calling
this function.
Simplify the format conversion code in PCM OSS emulation.
This patch also adds the support of 3bytes 24bit formats with linear
and mulaw, but they are not enabled in pcm_plugin.c yet.
Fix Makefile to compile files conditionally to CONFIG_SND_PCM_OSS_PLUGINS,
and remove unneeded ifdefs in these files.
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Fixed the race among multiple threads accessing the OSS PCM
instance concurrently by simply introducing a mutex for protecting
a setup of the PCM.
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Fix hang-up at disconnection of usb-audio devices while accessing PCM.
Don't handle PCM operations any more after shutdown flag is set.
Orignally proposed by Sam Revitch <sam.revitch@gmail.com>.
Unregister device files at disconnection to avoid the futher accesses.
Also, the dev_unregister callback is removed and replaced with the
combination of disconnect + free.
A new function snd_card_free_when_closed() is introduced, which is
used in USB disconnect callback.
- Add the linked list to each proc entry to enable a single-shot
disconnection (unregister)
- Deprecate snd_info_unregister(), use snd_info_free_entry()
- Removed NULL checks of snd_info_free_entry()
Accept O_RDWR at opening a PCM OSS device that is read- or write-only,
just for the compatibility with the behavior of older versions.
sound: Conversions from kmalloc+memset to k(c|z)alloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
