Just a tidy up to follow the standard EXPORT_SYMBOL*() declarations
in order to improve grep-ability.
- Remove superfluous blank line before EXPORT_SYMBOL*() lines
Several files are used to construct PCM core module, a.k.a snd-pcm.
Although available APIs are described in 'include/sound/pcm.h', some of
them are not exported as symbols in kernel space. Such APIs are just for
module local usage.
This commit adds module local header file and move some function prototypes
into it so that scopes of them are controlled properly and developers
get no confusion from unavailable symbols.
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
This helper function can convert a given sample rate range to
SNDRV_PCM_RATE_xxx bits.
Signed-off-by: Mengdong Lin <mengdong.lin@linux.intel.com>
Acked-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
This patch fixes XMOS DSD sample format to DSD_U32_BE and also adds
DSD_U16_BE and DSD_U32_BE sample formats.
Signed-off-by: Jussi Laako <jussi@sonarnerd.net>
Acked-by: Jurgen Kramer <gtmkramer@xs4all.nl>
Merging for-linus branch for syncing the latest STAC/IDT codec
changes to be affected by the upcoming hda-jack rewrites.
devices
XMOS based USB DACs with native DSD support expose this feature via a USB
alternate setting. The audio format is either 32-bit raw or a 32-bit PCM format.
To utilize this feature on linux this patch introduces a new 32-bit DSD
sampleformat DSD_U32_LE.
A follow up patch will add a quirk for XMOS based devices to utilize the new format.
Further patches will add support to alsa-lib.
Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl>
Right now we set 0 as the silence data for DSD_U8 and DSD_U16 formats,
but this is actually wrong. 0 is rather the most negative value.
Alternatively, we may take the repeating 0x69 pattern like ffmpeg
deploys.
Reference: https://ffmpeg.org/pipermail/ffmpeg-cvslog/2014-April/076427.html
Suggested-by: Alexander E. Patrakov <patrakov@gmail.com>
A bit of special care is necessary when creating the intersection of two rate
masks. This comes from the special meaning of the SNDRV_PCM_RATE_CONTINUOUS and
SNDRV_PCM_RATE_KNOT bits, which needs special handling when intersecting two
rate masks. SNDRV_PCM_RATE_CONTINUOUS means the hardware supports all rates in a
specific interval. SNDRV_PCM_RATE_KNOT means the hardware supports a set of
discrete rates specified by a list constraint. For all other cases the supported
rates are specified directly in the rate mask.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Mark Brown <broonie@linaro.org>
This patch adds two formats for Direct Stream Digital (DSD), a
pulse-density encoding format which is described here:
https://en.wikipedia.org/wiki/Direct_Stream_Digital
DSD operates on 2.8, 5.6 or 11.2MHz sample rates and as a 1-bit
stream.
The two new types added by this patch describe streams that are capable
of handling DSD samples in DOP format as 8-bit or in 16-bit (or at a x8
or x16 data rate, respectively).
DSD itself specifies samples in *bit*, while DOP and ALSA handle them
as *bytes*. Hence, a factor of 8 or 16 has to be applied for the sample
rare configuration, according to the following table:
configured hardware
176.4KHz 352.8kHz 705.6KHz <---- sample rate
8-bit 2.8MHz 5.6MHz
16-bit 2.8Mhz 5.6MHz 11.2MHz
actual DSD sample rates
Signed-off-by: Daniel Mack <zonque@gmail.com>
script/kernel-doc reports the following type of warnings (when run in verbose
mode):
Warning(sound/core/init.c:152): No description found for return value of
'snd_card_create'
To fix that:
- add missing descriptions of function return values
- use "Return:" sections to describe those return values
Along the way:
- complete some descriptions
- fix some typos
Signed-off-by: Yacine Belkadi <yacine.belkadi.1@gmail.com>
This is essentially the reverse of snd_pcm_rate_to_rate_bit().
This is generally useful as the Compress API uses the rate bit
directly and it helps to be able to map back to the actual sample
rate.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
These aren't modules, but they do make use of these macros, so
they will need export.h to get that definition. Previously,
they got it via the implicit module.h inclusion.
Change the core code where sparse complains. In most cases, this means
just adding annotations to confirm that we indeed want to do the dirty
things we're doing.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
This defines the 24bps and 40bps (8khz sample rate) G.723 codec
formats. They are going to be used once I submit the driver for
an mpeg4/g723 compression card.
I've updated the signed value to -1 as per Takashi's comments
since these are non-linear formats.
Signed-off-by: Ben Collins <bcollins@bluecherry.net>
Fix alsa kernel-doc warning in linux-next:
Warning(linux-next-20081016//sound/core/pcm_misc.c:327): No description found for parameter 'samples'
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Reported by Timur Tabi <timur@freescale.com> .
Add a snd_pcm_rate_to_rate_bit() function to factor out common code used
by several drivers.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Merge the rates[] arrays from pcm_misc.c and pcm_native.c because they
are both the same.
Add the support of 3-bytes 24bit formats in PCM OSS emulation.
Also removed snd_pcm_build_linear_format() function. It's exported
just for OSS emulation, and now the code was changed without calling
this function.
Move EXPORT_SYMBOL()s to places adjacent to functions/variables.
Also move OSS-specific hw_params helper functions to pcm_oss.c.
Modules: PCM Midlevel
Remove xxx_t typedefs from the core PCM codes.
PCM Midlevel
Export snd_pcm_format_size(). This function is used by some out-of-kernel
drivers.
Make snd_pcm_format_cpu_endian() macro for optimization.
infrastructure for it.
Let it rip!
