path: root/sound/core/pcm_misc.c
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] PCM - fixed SNDRV_PCM_FORMAT_U24_BE silence constantJaroslav Kysela
Reported by Timur Tabi <timur@freescale.com> . Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] pcm: add snd_pcm_rate_to_rate_bit() helperClemens Ladisch
Add a snd_pcm_rate_to_rate_bit() function to factor out common code used by several drivers. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] pcm: merge rates[] from pcm_misc.c and pcm_native.cClemens Ladisch
Merge the rates[] arrays from pcm_misc.c and pcm_native.c because they are both the same. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Support 3-bytes 24bit format in PCM OSS emulationTakashi Iwai
Add the support of 3-bytes 24bit formats in PCM OSS emulation. Also removed snd_pcm_build_linear_format() function. It's exported just for OSS emulation, and now the code was changed without calling this function. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] Move OSS-specific hw_params helper to snd-pcm-oss moduleTakashi Iwai
Move EXPORT_SYMBOL()s to places adjacent to functions/variables. Also move OSS-specific hw_params helper functions to pcm_oss.c. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCMTakashi Iwai
Modules: PCM Midlevel Remove xxx_t typedefs from the core PCM codes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] Export missing snd_pcm_format_*()Takashi Iwai
PCM Midlevel Export snd_pcm_format_size(). This function is used by some out-of-kernel drivers. Make snd_pcm_format_cpu_endian() macro for optimization. Signed-off-by: Takashi Iwai <tiwai@suse.de>
